Security Suite Problems
Solved Security Suite Problems
Post by selooselm on 19th August 2010, 1:15 am
Having a fun time working on a friend's laptop with Security Suite on it. Not able to get much running on it, having to transfer any files using a flash drive at the moment.
Thanks in advance!
selooselm
Posts Posts : 16
Joined Joined : 2009-07-12
Points Points : 27094
Solved Re: Security Suite Problems
Post by Dr Jay on 19th August 2010, 7:50 pm
Note: the following tool is to only be used under the guidance of a malware helper. In the event you already have the tool, please delete the old copy and download a new copy.
[You must be registered and logged in to see this link.] (Click the green button on the page to download it).
Rename ComboFix.exe to combo-fix.exe before you save it to your Desktop
  • Click Start>Run then copy paste the following command into the Run box & click OK "%userprofile%\desktop\combo-fix.exe" /killall
  • As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed.
    *NOTE*: If you already have the Recovery Console installed, ComboFix will skip this part and will continue scanning for malware.
    With malware infections being as they are today, it's strongly recommended to have this pre-installed on your machine before doing any malware removal. It will allow you to boot up into a special recovery/repair mode that will allow us to more easily help you should your computer have a problem after an attempted removal of malware.
Posts Posts : 13950
Points Points : 302577
Post by selooselm on 19th August 2010, 8:00 pm
Sorry, i forgot to reply. I solved the problem and got it all take care of. Thanks for the response and sorry again for not updating the post.
selooselm
Posts Posts : 16
Post by Dr Jay on 20th August 2010, 8:24 am
Ok.
Make sure to uninstall ComboFix, if it is still installed.
  • Click the Start button. Click Run.
Posts Posts : 13950
