Banker Fox and Win32/Nuqel need help
Page 2 of 2 Previous  1, 2
Post by guerro on Wed 18 Aug 2010, 1:02 pm
Hi, after helping my mom with her computer about 6 months ago, my brother now has similar problems. I need help removing these virii.
Please advise.
guerro
Operating System : Win XP
Re: Banker Fox and Win32/Nuqel need help
Post by guerro on Thu 02 Sep 2010, 2:10 pm
Stealth MBR rootkit/Mebroot/Sinowal detector 0.3.7 by Gmer, [You must be registered and logged in to see this link.]
device: opened successfully
user: MBR read successfully
kernel: MBR read successfully
user & kernel MBR OK
guerro
Post by DragonMaster Jay on Sat 04 Sep 2010, 3:24 pm
How is the computer running?
~DMJ
GeekPolice Academy Manager
Donations/Contributions
DragonMaster Jay
Manager | Tech Officer
View user profile http://www.twitter.com/jaypfoutz
Post by guerro on Sat 04 Sep 2010, 4:03 pm
It seems to be running fine. Would you say that everything has been remedied?
guerro
Post by DragonMaster Jay on Sat 04 Sep 2010, 4:16 pm
Sure. If there are no more issues, then we shall clean up!
Clean up System Restore
Now, to get you off to a clean start, we will be creating a new Restore Point, then clearing the old ones to make sure you do not get reinfected, in case you need to "restore back."
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
Run OTC to remove our tools
Please download OTC.exe by OldTimer:
  • Double click OTC.exe.
  • Click the CleanUp! button.
Purge old temporary files
Please download TFC by OldTimer to your desktop
  • Click the Start
Security Check
Please download Security Check by screen317 from SpywareInfoforum.org or Changelog.fr.
Tell me in your next reply, if you have completed these tasks:
  • Cleaned System Restore
  • Ran OTC
  • Ran TFC
  • Ran Security Check
Also, let me know how your computer is running, and don't forget to post the contents of the Security Check log.
~DMJ
DragonMaster Jay
Post by guerro on Tue 07 Sep 2010, 5:22 am
DragonMaster Jay wrote:Sure. If there are no more issues, then we shall clean up!
  • Click NEXT
  • Click CREATE
  • Click OK
  • Click the Start
Security Check
  • Ran OTC
  • Ran TFC
Results of screen317's Security Check version 0.99.5
Windows XP Service Pack 3
Internet Explorer 7 Out of date!
Antivirus/Firewall Check:
Windows Firewall Enabled!
ESET Online Scanner v3
McAfee VirusScan Enterprise
Antivirus out of date!
Malwarebytes' Anti-Malware
Java(TM) 6 Update 21
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Out of date Java installed!
Adobe Flash Player 10.0.22.87
Mozilla Firefox (3.6.8)
Process Check:
objlist.exe by Laurent
McAfee VirusScan Enterprise mcshield.exe
McAfee VirusScan Enterprise vstskmgr.exe
McAfee VirusScan Enterprise SHSTAT.EXE
DNS Vulnerability Check:
Request Timed Out (Wireless Internet connection/Disconnected Internet/Proxy?)
i ran all the programs you listed complete with no errors. Everything seems to be working fine.
guerro
Post by DragonMaster Jay on Tue 07 Sep 2010, 2:24 pm
Java Update!
Please download the newest version of Java from Java.com.
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Software recommendations
AntiSpyware
  • SpywareBlaster
    SpywareBlaster is a program that prevents spyware from installing on your computer. A tutorial on using SpywareBlaster may be found here.
  • Spybot - Search & Destroy.
Resident Protection help
Securing your computer
  • Windows Updates - It is very important to make sure that both Internet Explorer and Windows are kept current with the latest critical security patches from Microsoft. To do this just start Internet Explorer and select Tools > Windows Update, and follow the online instructions from there.
  • hpHosts file replaces your current HOSTS file with one containing well known ad sites and other bad sites. This prevents your computer from connecting to those sites by redirecting them to 127.0.0.1, which is your local computer's loopback address, meaning it will be difficult to infect your computer in the future.
If you are interested:
~DMJ
DragonMaster Jay
Post by guerro on Tue 07 Sep 2010, 3:13 pm
The only thing I cannot get to update is the McAfee antivirus. It keeps barfing when downloading the new DAT file. Not sure what to do about that.
guerro
Post by DragonMaster Jay on Thu 09 Sep 2010, 8:22 am
Seems like an internal software issue with McAfee.
What version of McAfee Antivirus are you running?
~DMJ
DragonMaster Jay
Post by guerro on Thu 09 Sep 2010, 8:23 am
8.5i
guerro
Post by DragonMaster Jay on Fri 10 Sep 2010, 6:54 am
My bad, I wanted to ask this earlier. Do you have the install media for the McAfee product?
~DMJ
DragonMaster Jay
Post by guerro on Fri 10 Sep 2010, 8:46 am
Yes, and I reinstalled but either it is not connecting to the McAfee ftp for download or the files it pulls down are corrupt/have a problem. I get the same error as I got before reinstalling. I will post a log of the error later tonight when I get home from work.
guerro
Post by guerro on Fri 10 Sep 2010, 12:36 pm
Well, I ran the update on McAfee so I could post the log but it looks like the update worked this time. i think everything is fixed and updated. thanks again for all your help. i will be sure my brother makes a donation.
Antivirus up to date!
Adobe Reader 9.3.4
Process Check:
guerro
Post by DragonMaster Jay on Sat 11 Sep 2010, 3:31 pm
Let me know of any more issues.
~DMJ
DragonMaster Jay
Post by Sponsored content Today at 9:24 pm
