svchost and browser problems plz help
Post by grumpygillz on 16th August 2010, 10:59 pm
I've been having annoying problems with my svchost.exe system and my browser. I think they are both related.
Until the past couple months I have not really had any problems with my svchost (ive had this computer for years). But now it seems that for no reason at all is just skyrockets and takes up a huge amount of my memory. A few times I have ended the process to see what would happen. Usually it messes up the whole look of my desktop (mostly the toolbar) and it disables the sound.
And about my browser issues. Around the same time I started getting the svchost issue I also noticed problems with my browser, or I guess I should say with all my search engines. Id say that 85% of the time the links I click from my search results all get redirected. Also around that time all my browsers were disabled except for internet explorer. I used to use Opera often, but now it says I can't.
I've tried running virus scanners but they obviously have not worked. I only use the free versions though.. can't really afford to pay for anything at this time. I've also tried looking up information about this issue, but it's hard since I'm not able to click on most search results due to the fact that I get redirected. I'm also not very smart when it comes to computers.
Any help, advice or suggestions anyone can give would be greatly apprciated.
grumpygillz
Posts Posts : 10
Joined Joined : 2010-08-16
Points Points : 23198
Re: svchost and browser problems plz help
Post by Belahzur on 16th August 2010, 11:41 pm
Points Points : 245091
Post by grumpygillz on 17th August 2010, 4:55 am
I hope I did this right.. and sorry, there's a lot of crap on my computer :\
OTL logfile created on: 8/16/2010 9:02:51 PM - Run 1
OTL by OldTimer - Version 3.2.10.0 Folder = C:\Documents and Settings\LMR.DELL\Desktop
254.00 Mb Total Physical Memory | 72.00 Mb Available Physical Memory | 28.00% Memory free
769.00 Mb Paging File | 160.00 Mb Available in Paging File | 21.00% Paging File free
Paging file location(s): C:\pagefile.sys 384 768 [binary data]
Drive C: | 52.71 Gb Total Space | 26.70 Gb Free Space | 50.66% Space Free | Partition Type: NTFS
Drive D: | 18.61 Gb Total Space | 18.53 Gb Free Space | 99.61% Space Free | Partition Type: NTFS
Computer Name: SLEEPY
Current User Name: LMR
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/08/16 20:59:00 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\LMR.DELL\Desktop\OTL.exe
PRC - [2010/05/31 09:05:06 | 000,048,106 | ---- | M] (The Pidgin developer community) -- C:\Program Files\Pidgin\pidgin.exe
PRC - [2009/08/17 09:40:50 | 000,486,680 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgrsx.exe
PRC - [2009/08/17 09:40:43 | 000,693,016 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgcsrvx.exe
PRC - [2009/08/17 09:40:19 | 000,595,736 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgnsx.exe
PRC - [2009/08/17 09:39:54 | 000,908,056 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgemc.exe
PRC - [2009/08/17 09:38:26 | 000,297,752 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgwdsvc.exe
PRC - [2008/11/09 13:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
PRC - [2008/08/14 18:11:48 | 000,565,008 | ---- | M] () -- C:\Program Files\Common Files\logishrd\LComMgr\Communications_Helper.exe
PRC - [2008/08/13 18:32:40 | 000,206,064 | ---- | M] (SupportSoft, Inc.) -- C:\Program Files\Dell Support Center\bin\sprtcmd.exe
PRC - [2008/08/13 18:32:40 | 000,201,968 | ---- | M] (SupportSoft, Inc.) -- C:\Program Files\Dell Support Center\bin\sprtsvc.exe
PRC - [2008/07/26 09:25:36 | 000,150,040 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\logishrd\LVMVFM\LVPrcSrv.exe
PRC - [2008/07/26 09:23:42 | 000,186,904 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\logishrd\LVCOMSER\LVComSer.exe
PRC - [2008/07/11 17:51:32 | 000,423,200 | ---- | M] (Sony Corporation) -- C:\Program Files\Sony\Content Transfer\ContentTransferWMDetector.exe
PRC - [2008/04/13 17:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2006/11/03 19:20:12 | 000,866,584 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MSASCui.exe
PRC - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MsMpEng.exe
PRC - [2006/07/25 18:03:42 | 000,100,032 | ---- | M] (Symantec Corporation) -- C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
PRC - [2006/04/18 17:32:26 | 000,483,328 | ---- | M] () -- C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtWLan.exe
PRC - [2006/04/06 21:19:28 | 000,745,472 | ---- | M] () -- C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe
PRC - [2006/03/03 15:18:10 | 000,200,704 | ---- | M] (Yahoo!, Inc.) -- C:\Program Files\Yahoo!\browser\ycommon.exe
PRC - [2004/10/14 17:42:54 | 001,404,928 | ---- | M] (Analog Devices, Inc.) -- C:\Program Files\Analog Devices\Core\smax4pnp.exe
PRC - [2003/12/10 04:52:40 | 000,380,928 | ---- | M] (Motive Communications, Inc.) -- C:\Program Files\SBC Self Support Tool\SmartBridge\MotiveSB.exe
PRC - [2003/10/29 00:06:00 | 000,024,576 | R--- | M] (BVRP Software) -- C:\Program Files\Digital Line Detect\DLG.exe
PRC - [2003/07/14 14:35:46 | 000,480,368 | ---- | M] (Yahoo!, Inc.) -- C:\Program Files\Yahoo!\browser\ybrowser.exe
PRC - [2003/07/11 14:51:16 | 000,057,344 | ---- | M] (Yahoo!, Inc.) -- C:\Program Files\Yahoo!\browser\ybrwicon.exe
PRC - [2003/06/11 02:52:26 | 000,122,880 | ---- | M] (Visual Networks) -- C:\Program Files\Visual Networks\Visual IP InSight\SBC\ipmon32.exe
PRC - [2003/06/11 02:52:24 | 000,380,928 | ---- | M] (Visual Networks) -- C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPClient.exe
MOD - [2010/08/16 20:59:00 | 000,575,488 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\LMR.DELL\Desktop\OTL.exe
MOD - [2008/07/26 09:25:24 | 000,109,080 | ---- | M] (Logitech Inc.) -- C:\WINDOWS\Temp\logishrd\LVPrcInj01.dll
MOD - [2008/04/13 17:10:20 | 000,110,592 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msscript.ocx
MOD - [2003/10/07 04:41:56 | 000,081,920 | ---- | M] (Motive Communications, Inc.) -- C:\Program Files\SBC Self Support Tool\SmartBridge\SBHook.dll
MOD - [2003/06/11 02:52:24 | 000,098,304 | ---- | M] (Visual Networks) -- C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPHk2KS2.dll
SRV - File not found [Disabled | Stopped] -- C:\WINDOWS\System32\hidserv.dll -- (HidServ)
SRV - File not found [Auto | Stopped] -- C:\Program Files\Google\Update\GoogleUpdate.exe -- (gupdate1ca02a8d12818d7) Google Update Service (gupdate1ca02a8d12818d7)
SRV - File not found [On_Demand | Stopped] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
SRV - [2009/08/17 09:39:54 | 000,908,056 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG8\avgemc.exe -- (avg8emc)
SRV - [2009/08/17 09:38:26 | 000,297,752 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG8\avgwdsvc.exe -- (avg8wd)
SRV - [2008/11/09 13:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto | Running] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
SRV - [2008/08/13 18:32:40 | 000,201,968 | ---- | M] (SupportSoft, Inc.) [Auto | Running] -- C:\Program Files\Dell Support Center\bin\sprtsvc.exe -- (sprtsvc_dellsupportcenter) SupportSoft Sprocket Service (dellsupportcenter)
SRV - [2008/07/26 09:25:36 | 000,150,040 | ---- | M] (Logitech Inc.) [Auto | Running] -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe -- (LVPrcSrv)
SRV - [2008/07/26 09:23:42 | 000,186,904 | ---- | M] (Logitech Inc.) [Auto | Running] -- C:\Program Files\Common Files\LogiShrd\LVCOMSER\LVComSer.exe -- (LVCOMSer)
SRV - [2007/03/07 15:47:46 | 000,076,848 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\DellSupport\brkrsvc.exe -- (DSBrokerService)
SRV - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MsMpEng.exe -- (WinDefend)
SRV - [2006/07/25 18:03:42 | 002,119,360 | ---- | M] (Symantec Corporation) [On_Demand | Stopped] -- C:\Program Files\Symantec\LiveUpdate\LuComServer_3_0.EXE -- (LiveUpdate)
SRV - [2006/07/25 18:03:42 | 000,100,032 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe -- (Automatic LiveUpdate Scheduler)
SRV - [2005/06/21 13:19:38 | 000,491,520 | ---- | M] () [On_Demand | Stopped] -- C:\WINDOWS\System32\dlcccoms.exe -- (dlcc_device)
SRV - [2002/12/24 12:01:22 | 000,065,536 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe -- (SPTISRV)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\WINDOWS\System32\DRIVERS\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
DRV - [2010/05/10 11:41:30 | 000,067,656 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
DRV - [2010/02/17 11:25:48 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
DRV - [2009/08/17 09:40:48 | 000,027,784 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2009/08/17 09:40:46 | 000,335,240 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2009/05/08 12:15:31 | 000,108,552 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2008/07/26 09:25:02 | 000,025,624 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LVPr2Mon.sys -- (LVPr2Mon)
DRV - [2008/07/26 08:26:22 | 000,041,752 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LVUSBSta.sys -- (LVUSBSta)
DRV - [2008/07/26 08:22:34 | 002,570,520 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LV302V32.SYS -- (PID_PEPI) Logitech QuickCam IM(PID_PEPI)
DRV - [2008/04/13 11:36:39 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\amdagp.sys -- (amdagp)
DRV - [2008/04/13 11:36:39 | 000,040,960 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sisagp.sys -- (sisagp)
DRV - [2007/02/25 12:10:48 | 000,005,376 | --S- | M] (Gteko Ltd.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\dsunidrv.sys -- (dsunidrv)
DRV - [2006/10/13 17:00:06 | 000,035,107 | ---- | M] (Service & Quality Technology.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Capt905c.sys -- (SQTECH905C)
DRV - [2006/10/05 16:07:28 | 000,004,736 | ---- | M] (Gteko Ltd.) [Kernel | On_Demand | Stopped] -- C:\Program Files\DellSupport\GTAction\triggers\DSproct.sys -- (DSproct)
DRV - [2006/03/27 18:53:28 | 000,167,808 | ---- | M] (NETGEAR Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wg111v2.sys -- (RTLWUSB)
DRV - [2004/09/17 12:02:54 | 000,732,928 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\senfilt.sys -- (senfilt)
DRV - [2004/08/03 20:29:56 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
DRV - [2003/11/17 19:59:20 | 000,212,224 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSFHWBS2.sys -- (HSFHWBS2)
DRV - [2003/11/17 19:58:02 | 000,680,704 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
DRV - [2003/11/17 19:56:26 | 001,042,432 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_DP.sys -- (HSF_DP)
DRV - [2002/10/02 09:57:12 | 000,013,532 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SjyPkt.sys -- (SjyPkt)
DRV - [2002/08/08 16:51:32 | 000,038,951 | ---- | M] (Sony Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\NETMDUSB.sys -- (NETMDUSB)
DRV - [2001/08/17 12:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sparrow.sys -- (Sparrow)
DRV - [2001/08/17 12:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_u3.sys -- (sym_u3)
DRV - [2001/08/17 12:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_hi.sys -- (sym_hi)
DRV - [2001/08/17 12:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc8xx.sys -- (symc8xx)
DRV - [2001/08/17 12:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc810.sys -- (symc810)
DRV - [2001/08/17 11:57:38 | 000,016,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\MODEMCSA.sys -- (MODEMCSA)
DRV - [2001/08/17 11:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ultra.sys -- (ultra)
DRV - [2001/08/17 11:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql12160.sys -- (ql12160)
DRV - [2001/08/17 11:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1080.sys -- (ql1080)
DRV - [2001/08/17 11:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1280.sys -- (ql1280)
DRV - [2001/08/17 11:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\dac2w2k.sys -- (dac2w2k)
DRV - [2001/08/17 11:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\mraid35x.sys -- (mraid35x)
DRV - [2001/08/17 11:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc.sys -- (asc)
DRV - [2001/08/17 11:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc3550.sys -- (asc3550)
DRV - [2001/08/17 11:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\aliide.sys -- (AliIde)
DRV - [2001/08/17 11:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\cmdide.sys -- (CmdIde)
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 4:59 am
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Yahoo! Search
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultURL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,CustomSearch = [You must be registered and logged in to see this link.]
IE - HKCU\..\URLSearchHook: {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll ()
FF - HKLM\software\mozilla\eMusic Remote\Extensions\\Components: C:\Program Files\eMusic Remote\xulrunner\components [2010/08/16 19:48:53 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\eMusic Remote\Extensions\\Plugins: C:\Program Files\eMusic Remote\xulrunner\plugins [2010/08/16 19:48:53 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\extensions\\avg@igeared: C:\Program Files\AVG\AVG8\Toolbar\Firefox\avg@igeared [2009/06/24 11:38:34 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.0.11\extensions\\Components: C:\Program Files\Mozilla Firefox\components
FF - HKLM\software\mozilla\Mozilla Firefox 3.0.11\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/06/05 17:39:50 | 000,000,000 | ---D | M]
[2010/06/05 17:33:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Extensions
[2010/06/05 17:39:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions
[2010/06/05 17:33:56 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{13407856-f9ea-4536-bd03-70fb56d5d0cd}(2)
[2010/06/05 17:33:56 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{526fd696-27a0-11dc-8314-0800200c9a66}(2)
[2010/06/05 17:33:56 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{59c81df5-4b7a-477b-912d-4e0fdf64e5f2}(2)
[2010/06/05 17:33:56 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{59c81df5-4b7a-477b-912d-4e0fdf64e5f2}(3)
[2010/07/30 01:05:55 | 000,000,000 | ---D | M] (Yahoo! Toolbar) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{7affbfae-c4e2-4915-8c0f-00fa3ec610a1}
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{7affbfae-c4e2-4915-8c0f-00fa3ec610a1}(2)
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{9f94fab0-58a2-11dd-ae16-0800200c9a66}(2)
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d}
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}
[2010/06/05 17:33:55 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\{FDE3FEE9-893E-4cc7-A814-60E0DE7B2E01}(2)
[2010/06/05 17:33:56 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LMR.DELL\Application Data\Mozilla\Firefox\Profiles\3dtmf0uw.default\extensions\FoxdieGraphite@tanjihay(2).com
O1 HOSTS File: ([2009/02/01 21:11:01 | 000,291,996 | R--- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O1 - Hosts: 127.0.0.1 [You must be registered and logged in to see this link.]
O1 - Hosts: 127.0.0.1 007guard.com
O1 - Hosts: 127.0.0.1 008i.com
O1 - Hosts: 127.0.0.1 008k.com
O1 - Hosts: 127.0.0.1 00hq.com
O1 - Hosts: 127.0.0.1 010402.com
O1 - Hosts: 127.0.0.1 032439.com
O1 - Hosts: 127.0.0.1 0scan.com
O1 - Hosts: 127.0.0.1 1000gratisproben.com
O1 - Hosts: 127.0.0.1 1001namen.com
O1 - Hosts: 127.0.0.1 100888290cs.com
O1 - Hosts: 127.0.0.1 100sexlinks.com
O1 - Hosts: 127.0.0.1 10sek.com
O1 - Hosts: 127.0.0.1 1-2005-search.com
O1 - Hosts: 10056 more lines...
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll (Yahoo! Inc.)
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (AVG Technologies CZ, s.r.o.)
O2 - BHO: (no name) - {3E290198-446F-4183-B884-A076288C4F41} - C:\WINDOWS\System32\opnnkiiG.dll File not found
O2 - BHO: (Yahoo! IE Services Button) - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll (Yahoo! Inc.)
O2 - BHO: (SSVHelper Class) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (AVG Security Toolbar BHO) - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll ()
O2 - BHO: (no name) - {D4214342-3E46-44A1-80A3-4F802A2A67A2} - C:\WINDOWS\System32\xxyabbCt.dll File not found
O2 - BHO: (no name) - {D7ECD7D2-D9B3-4DFB-A58F-3FF5A938B1FA} - C:\WINDOWS\System32\cbXNEXrQ.dll File not found
O2 - BHO: (no name) - {F6B20354-A2A9-47D4-9CE5-64D29FACF61F} - C:\WINDOWS\System32\urqNDWop.dll File not found
O2 - BHO: (no name) - {F8F57818-934C-4E37-B892-5908FD8EDC73} - C:\WINDOWS\System32\jkkLBtRh.dll File not found
O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\YTSingleInstance.dll (Yahoo! Inc)
O3 - HKLM\..\Toolbar: (ALOT eMusic Toolbar) - {8260C2B8-E0D1-448a-B062-33D12D468BF0} - C:\Program Files\alot\bin\alot.dll File not found
O3 - HKLM\..\Toolbar: (AVG Security Toolbar) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll ()
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (AVG Security Toolbar) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll ()
O4 - HKLM..\Run: [ContentTransferWMDetector.exe] C:\Program Files\Sony\Content Transfer\ContentTransferWMDetector.exe (Sony Corporation)
O4 - HKLM..\Run: [DellSupportCenter] C:\Program Files\Dell Support Center\bin\sprtcmd.exe (SupportSoft, Inc.)
O4 - HKLM..\Run: [DLCCCATS] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\DLCCtime.DLL ()
O4 - HKLM..\Run: [dscactivate] C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe ( )
O4 - HKLM..\Run: [IPInSightLAN 02] C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPClient.exe (Visual Networks)
O4 - HKLM..\Run: [IPInSightMonitor 02] C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPMon32.exe (Visual Networks)
O4 - HKLM..\Run: [LogitechCommunicationsManager] C:\Program Files\Common Files\LogiShrd\LComMgr\Communications_Helper.exe ()
O4 - HKLM..\Run: [Motive SmartBridge] C:\Program Files\SBC Self Support Tool\SmartBridge\MotiveSB.exe (Motive Communications, Inc.)
O4 - HKLM..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe (Analog Devices, Inc.)
O4 - HKCU..\Run: [DellSupportCenter] C:\Program Files\Dell Support Center\bin\sprtcmd.exe (SupportSoft, Inc.)
O4 - HKCU..\Run: [Search Protection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe File not found
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Digital Line Detect.lnk = C:\Program Files\Digital Line Detect\DLG.exe (BVRP Software)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\WG111v2 Smart Wizard Wireless Setting.lnk = C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe ()
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 255
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 255
O9 - Extra 'Tools' menuitem : Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\npjpi160_13.dll (Sun Microsystems, Inc.)
O9 - Extra Button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll (Yahoo! Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000011 - C:\WINDOWS\System32\mclsp.dll (McAfee, Inc.)
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 5:03 am
O16 - DPF: {01A88BB1-1174-41EC-ACCB-963509EAE56B} [You must be registered and logged in to see this link.] (SysProWmi Class)
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} [You must be registered and logged in to see this link.] (Facebook Photo Uploader 5)
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} [You must be registered and logged in to see this link.] (Windows Genuine Advantage Validation Tool)
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} [You must be registered and logged in to see this link.] (Checkers Class)
O16 - DPF: {233C1507-6A77-46A4-9443-F871F945D258} [You must be registered and logged in to see this link.] (Shockwave ActiveX Control)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} [You must be registered and logged in to see this link.] (Snapfish Activia)
O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} [You must be registered and logged in to see this link.] (MySpace Uploader Control)
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} [You must be registered and logged in to see this link.] (MSN Photo Upload Tool)
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 5:11 am
I seem to be having problems finishing the 'internet explorer' section. If that's important to see I can try putting the rest up later.
[2010/08/16 20:57:30 | 000,575,488 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\LMR.DELL\Desktop\OTL.exe
[2010/08/16 15:38:55 | 000,000,000 | ---D | C] -- C:\Program Files\ESET
[2010/08/04 16:04:21 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Application Data\Real
[2010/07/30 00:51:08 | 000,185,920 | ---- | C] (RealNetworks, Inc.) -- C:\WINDOWS\System32\rmoc3260.dll
[2010/07/30 00:50:59 | 000,006,656 | ---- | C] (RealNetworks, Inc.) -- C:\WINDOWS\System32\pndx5016.dll
[2010/07/30 00:50:59 | 000,005,632 | ---- | C] (RealNetworks, Inc.) -- C:\WINDOWS\System32\pndx5032.dll
[2010/07/30 00:50:51 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\xing shared
[2010/07/30 00:50:08 | 000,278,528 | ---- | C] (Real Networks, Inc) -- C:\WINDOWS\System32\pncrt.dll
[2010/07/30 00:50:02 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Real
[2010/07/30 00:50:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LMR.DELL\Application Data\Real
[2010/07/25 22:16:20 | 000,000,000 | ---D | C] -- C:\Program Files\Windows Live SkyDrive
[2010/07/23 16:40:01 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LMR.DELL\Desktop\BakingLife
[2010/07/18 22:57:43 | 000,000,000 | ---D | C] -- C:\Program Files\iPod
[2 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[1 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[2010/08/16 20:25:07 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
[2010/08/16 20:12:52 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/08/16 20:12:32 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/08/16 20:11:01 | 009,961,472 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\ntuser.dat
[2010/08/16 20:11:01 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\LMR.DELL\ntuser.ini
[2010/08/16 19:42:23 | 000,000,579 | ---- | M] () -- C:\WINDOWS\win.ini
[2010/08/16 19:42:23 | 000,000,227 | ---- | M] () -- C:\WINDOWS\system.ini
[2010/08/16 19:42:23 | 000,000,211 | -HS- | M] () -- C:\boot.ini
[2010/08/16 19:01:30 | 000,046,104 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
[2010/08/16 18:51:49 | 000,197,752 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2010/08/16 18:50:16 | 002,205,456 | -H-- | M] () -- C:\Documents and Settings\LMR.DELL\Local Settings\Application Data\IconCache.db
[2010/08/16 14:32:16 | 000,000,814 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Application Data\Microsoft\Internet Explorer\Quick Launch\Auslogics BoostSpeed.lnk
[2010/08/16 14:32:15 | 000,000,796 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Desktop\Auslogics BoostSpeed.lnk
[2010/08/16 12:38:23 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/08/14 20:58:59 | 000,029,077 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Desktop\200_tyrabanks-waist_081310.jpg
[2010/08/14 03:16:44 | 000,001,324 | ---- | M] () -- C:\WINDOWS\System32\d3d9caps.dat
[2010/08/05 22:37:14 | 000,003,571 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Desktop\ATACC.jpg
[2010/08/02 17:55:51 | 000,004,398 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Desktop\TheCrow.jpg
[2010/07/30 19:02:31 | 000,380,350 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2010/07/30 19:02:30 | 000,052,764 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2010/07/30 19:02:29 | 000,439,376 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
[2010/07/30 00:58:55 | 000,051,200 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/07/30 00:51:24 | 000,000,929 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\My Documents\RealPlayer SP.lnk
[2010/07/30 00:51:08 | 000,185,920 | ---- | M] (RealNetworks, Inc.) -- C:\WINDOWS\System32\rmoc3260.dll
[2010/07/30 00:50:59 | 000,006,656 | ---- | M] (RealNetworks, Inc.) -- C:\WINDOWS\System32\pndx5016.dll
[2010/07/30 00:50:59 | 000,005,632 | ---- | M] (RealNetworks, Inc.) -- C:\WINDOWS\System32\pndx5032.dll
[2010/07/30 00:50:09 | 000,348,160 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\System32\msvcr71.dll
[2010/07/30 00:50:08 | 000,278,528 | ---- | M] (Real Networks, Inc) -- C:\WINDOWS\System32\pncrt.dll
[2010/07/26 18:00:36 | 000,000,218 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\.recently-used.xbel
[2010/07/18 23:02:52 | 000,001,910 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/07/18 23:00:02 | 002,795,904 | ---- | M] () -- C:\Documents and Settings\LMR.DELL\My Documents\practice.mp3
[2010/08/16 14:32:16 | 000,000,814 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Application Data\Microsoft\Internet Explorer\Quick Launch\Auslogics BoostSpeed.lnk
[2010/08/16 14:32:15 | 000,000,796 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Desktop\Auslogics BoostSpeed.lnk
[2010/08/14 21:00:33 | 000,029,077 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Desktop\200_tyrabanks-waist_081310.jpg
[2010/08/12 12:55:11 | 000,026,071 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\My Documents\TWc1ZZ1D70WKXEyDb2R3iiu30Sk=.png
[2010/08/05 22:37:14 | 000,003,571 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Desktop\ATACC.jpg
[2010/08/02 17:55:51 | 000,004,398 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Desktop\TheCrow.jpg
[2010/07/30 00:51:24 | 000,000,929 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\My Documents\RealPlayer SP.lnk
[2010/07/26 18:00:36 | 000,000,218 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\.recently-used.xbel
[2010/07/18 22:40:28 | 002,795,904 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\My Documents\practice.mp3
[2010/06/05 18:17:33 | 000,000,180 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Application Data\setup.log
[2010/06/05 18:17:15 | 000,000,760 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Application Data\setup_ldm.iss
[2010/01/15 03:22:39 | 000,004,943 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\qxsjgexe.dxg
[2009/04/30 23:39:36 | 000,066,482 | R--- | C] () -- C:\WINDOWS\System32\lvcoinst.ini
[2009/02/22 18:40:54 | 000,000,002 | ---- | C] () -- C:\WINDOWS\msoffice.ini
[2008/08/10 03:54:02 | 000,000,021 | ---- | C] () -- C:\WINDOWS\VI_setup.ini
[2008/08/10 03:53:51 | 000,000,021 | ---- | C] () -- C:\WINDOWS\PI4_setup.ini
[2008/07/26 09:25:02 | 000,025,624 | ---- | C] () -- C:\WINDOWS\System32\drivers\LVPr2Mon.sys
[2008/07/08 02:54:54 | 000,051,200 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2008/06/04 14:11:14 | 000,061,678 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Application Data\PFP120JPR.{PB
[2008/06/04 14:11:14 | 000,012,358 | ---- | C] () -- C:\Documents and Settings\LMR.DELL\Application Data\PFP120JCM.{PB
[2008/05/29 15:45:49 | 002,085,024 | -HS- | C] () -- C:\WINDOWS\System32\xubiidcj.ini
[2008/05/29 14:11:34 | 000,800,153 | -HS- | C] () -- C:\WINDOWS\System32\nnWHNqru.ini
[2008/05/28 20:32:53 | 001,493,450 | -HS- | C] () -- C:\WINDOWS\System32\auqqlvxu.ini
[2008/05/28 19:55:27 | 000,000,294 | -HS- | C] () -- C:\WINDOWS\System32\qybbmtle.ini
[2008/05/28 16:26:02 | 000,800,118 | -HS- | C] () -- C:\WINDOWS\System32\QrXENXbc.ini
[2008/05/28 13:01:08 | 001,493,284 | -HS- | C] () -- C:\WINDOWS\System32\cfmnenyb.ini
[2008/05/28 12:45:56 | 000,801,005 | -HS- | C] () -- C:\WINDOWS\System32\poWDNqru.ini
[2008/05/28 03:58:42 | 001,477,235 | -HS- | C] () -- C:\WINDOWS\System32\adbhsplc.ini
[2008/05/28 03:34:35 | 000,787,896 | -HS- | C] () -- C:\WINDOWS\System32\Giiknnpo.ini
[2008/05/28 02:04:49 | 001,478,666 | -HS- | C] () -- C:\WINDOWS\System32\jcskwgew.ini
[2008/05/27 18:42:16 | 001,471,877 | -HS- | C] () -- C:\WINDOWS\System32\gqdurabd.ini
[2008/05/27 18:29:11 | 000,818,976 | -HS- | C] () -- C:\WINDOWS\System32\aIlVwyxx.ini
[2008/05/27 15:05:00 | 000,816,898 | -HS- | C] () -- C:\WINDOWS\System32\yFfedfii.ini
[2008/05/27 14:39:22 | 001,470,819 | -HS- | C] () -- C:\WINDOWS\System32\vixafjnn.ini
[2008/05/27 01:59:23 | 001,430,382 | -HS- | C] () -- C:\WINDOWS\System32\jjqlhoud.ini
[2008/05/27 00:28:51 | 000,818,844 | -HS- | C] () -- C:\WINDOWS\System32\hRtBLkkj.ini
[2008/05/27 00:12:12 | 001,431,602 | -HS- | C] () -- C:\WINDOWS\System32\lcyiupyi.ini
[2008/05/26 00:02:50 | 001,431,482 | -HS- | C] () -- C:\WINDOWS\System32\sfokksmq.ini
[2008/05/25 00:49:16 | 001,417,602 | -HS- | C] () -- C:\WINDOWS\System32\wdqamhbe.ini
[2008/05/03 17:05:19 | 001,485,748 | -HS- | C] () -- C:\WINDOWS\System32\bmmkxbkc.ini
[2008/04/30 12:26:00 | 001,482,989 | -HS- | C] () -- C:\WINDOWS\System32\eiyiltrt.ini
[2008/04/29 12:24:02 | 001,484,658 | -HS- | C] () -- C:\WINDOWS\System32\ktrevwqe.ini
[2008/04/28 12:24:25 | 001,485,059 | -HS- | C] () -- C:\WINDOWS\System32\uqokoajk.ini
[2008/04/27 12:22:33 | 001,483,847 | -HS- | C] () -- C:\WINDOWS\System32\amulwwoy.ini
[2008/04/26 14:07:41 | 001,483,419 | -HS- | C] () -- C:\WINDOWS\System32\wxecbjgk.ini
[2008/04/25 14:07:22 | 001,505,904 | -HS- | C] () -- C:\WINDOWS\System32\dcmwcvej.ini
[2008/04/24 14:07:20 | 001,509,539 | -HS- | C] () -- C:\WINDOWS\System32\pjieydqq.ini
[2008/04/23 14:05:22 | 001,540,644 | -HS- | C] () -- C:\WINDOWS\System32\cphvvmpr.ini
[2008/04/22 14:04:43 | 001,541,717 | -HS- | C] () -- C:\WINDOWS\System32\dsulxsie.ini
[2008/04/21 14:04:02 | 001,541,193 | -HS- | C] () -- C:\WINDOWS\System32\knvnxdjd.ini
[2008/04/20 14:03:33 | 000,000,294 | -HS- | C] () -- C:\WINDOWS\System32\veiitlyp.ini
[2008/04/19 18:19:24 | 000,429,184 | -HS- | C] () -- C:\WINDOWS\System32\tCbbayxx.ini
[2008/02/29 14:44:32 | 000,000,414 | ---- | C] () -- C:\WINDOWS\videoimp.ini
[2008/02/29 14:39:10 | 000,010,240 | ---- | C] () -- C:\WINDOWS\System32\vidx16.dll
[2007/07/12 03:08:13 | 000,000,118 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
[2007/06/09 15:39:04 | 000,000,736 | ---- | C] () -- C:\WINDOWS\DigimaxMaster.INI
[2007/06/09 14:25:27 | 000,552,960 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
[2007/06/09 14:25:27 | 000,159,744 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
[2007/06/06 00:18:26 | 000,000,000 | ---- | C] () -- C:\WINDOWS\Textart.INI
[2007/03/04 16:01:45 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
[2007/01/17 10:21:04 | 000,262,416 | ---- | C] () -- C:\WINDOWS\System32\ASFV2.DLL
[2007/01/17 10:18:36 | 000,524,288 | ---- | C] () -- C:\WINDOWS\System32\TDI-SonyOMG.dll
[2006/04/21 20:50:33 | 000,005,852 | -HS- | C] () -- C:\WINDOWS\System32\KGyGaAvL.sys
[2006/04/21 20:50:33 | 000,000,104 | RHS- | C] () -- C:\WINDOWS\System32\B3C1F42516.sys
[2006/04/21 19:06:09 | 000,638,976 | ---- | C] () -- C:\WINDOWS\System32\dlccpmui.dll
[2006/04/21 19:06:08 | 000,155,648 | ---- | C] () -- C:\WINDOWS\System32\dlccins.dll
[2006/04/21 19:06:08 | 000,106,496 | ---- | C] () -- C:\WINDOWS\System32\dlccinsr.dll
[2006/04/21 19:06:06 | 000,040,960 | ---- | C] () -- C:\WINDOWS\System32\dlccvs.dll
[2006/04/21 19:06:05 | 000,413,696 | ---- | C] () -- C:\WINDOWS\System32\dlcccomm.dll
[2006/04/21 19:06:05 | 000,114,688 | ---- | C] () -- C:\WINDOWS\System32\dlccpplc.dll
[2006/04/21 19:06:04 | 001,134,592 | ---- | C] () -- C:\WINDOWS\System32\dlccusb1.dll
[2006/04/21 19:06:04 | 000,483,328 | ---- | C] () -- C:\WINDOWS\System32\dlcclmpm.dll
[2006/04/21 19:06:03 | 000,770,048 | ---- | C] () -- C:\WINDOWS\System32\dlcchbn3.dll
[2006/04/21 19:06:02 | 001,183,744 | ---- | C] () -- C:\WINDOWS\System32\dlccserv.dll
[2006/04/21 19:06:02 | 000,704,512 | ---- | C] () -- C:\WINDOWS\System32\dlcccomc.dll
[2006/04/21 19:06:02 | 000,155,648 | ---- | C] () -- C:\WINDOWS\System32\dlccprox.dll
[2006/04/21 19:05:59 | 000,430,080 | ---- | C] () -- C:\WINDOWS\System32\dlccutil.dll
[2006/04/21 19:05:59 | 000,073,728 | ---- | C] () -- C:\WINDOWS\System32\dlcccu.dll
[2006/04/21 19:05:59 | 000,036,864 | ---- | C] () -- C:\WINDOWS\System32\dlcccur.dll
[2006/04/21 19:05:54 | 000,176,128 | ---- | C] () -- C:\WINDOWS\System32\dlccinsb.dll
[2006/04/21 19:05:54 | 000,086,016 | ---- | C] () -- C:\WINDOWS\System32\dlcccub.dll
[2006/04/21 19:05:52 | 000,131,072 | ---- | C] () -- C:\WINDOWS\System32\dlccjswr.dll
[2006/04/21 19:05:46 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\dlcccfg.dll
[2006/04/21 16:47:02 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\YCRWin32.dll
[2006/04/14 18:51:42 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2006/04/14 18:48:10 | 000,000,167 | ---- | C] () -- C:\WINDOWS\wininit.ini
[2006/04/14 18:40:37 | 000,712,704 | ---- | C] () -- C:\WINDOWS\System32\DellSystemRestore.dll
[2006/04/14 18:13:16 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\e100bmsg.dll
[2006/04/14 18:13:16 | 000,000,392 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
[2004/08/10 11:12:05 | 000,000,780 | ---- | C] () -- C:\WINDOWS\orun32.ini
[2003/07/14 12:30:28 | 000,197,120 | ---- | C] () -- C:\WINDOWS\patchw32.dll
========== Files - Unicode (All) ==========
[2008/05/29 15:29:11 | 000,000,000 | ---D | M](C:\WINDOWS\??sks) -- C:\WINDOWS\Таsks
[2008/05/25 00:30:45 | 000,000,000 | ---D | C](C:\WINDOWS\??sks) -- C:\WINDOWS\Таsks
@Alternate Data Stream - 98 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
@Alternate Data Stream - 135 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:07BF512B
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 5:18 am
Oh my goodness. I just looked back at some of the things I posted and realized there are "naughty" links posted. That's kinda embarrassing, I swear I didn't know I had that nonsense on my computer!.. Anyways, Here's the rest from 'Extras'.
OTL Extras logfile created on: 8/16/2010 9:02:51 PM - Run 1
File Age = 30 Days
Output = Standard
.html [@ = htmlfile] -- Reg Error: Key error. File not found
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
exefile [open] -- "%1" %*
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"AntiVirusDisableNotify" = 0
"DisableMonitoring" = 1
"139:TCP" = 139:TCP:*:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:*:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:*:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:*:Enabled:@xpsp2res.dll,-22002
"EnableFirewall" = 1
"DoNotAllowExceptions" = 0
"DisableNotifications" = 0
"139:TCP" = 139:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22002
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 5:23 am
"C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL -- File not found
"C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL -- File not found
"C:\Program Files\America Online 9.0\waol.exe" = C:\Program Files\America Online 9.0\waol.exe:*:Enabled:America Online 9.0 -- File not found
"C:\PROGRA~1\Yahoo!\MESSEN~1\YPAGER.EXE" = C:\PROGRA~1\Yahoo!\MESSEN~1\YPAGER.EXE:*:Enabled:Yahoo! Messenger -- File not found
"C:\PROGRA~1\Yahoo!\MESSEN~1\yserver.exe" = C:\PROGRA~1\Yahoo!\MESSEN~1\yserver.exe:*:Enabled:Yahoo! FT Server -- File not found
"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" = C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger -- (Yahoo! Inc.)
"C:\Program Files\Yahoo!\browser\ybrowser.exe" = C:\Program Files\Yahoo!\browser\ybrowser.exe:*:Enabled:Yahoo! Browser -- (Yahoo!, Inc.)
"C:\Program Files\FrostWire\FrostWire.exe" = C:\Program Files\FrostWire\FrostWire.exe:*:Enabled:LimeWire -- File not found
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- File not found
"C:\Program Files\mIRC\mirc.exe" = C:\Program Files\mIRC\mirc.exe:*:Enabled:mIRC -- (mIRC Co. Ltd.)
"C:\Program Files\America Online 9.0\waol.exe" = C:\Program Files\America Online 9.0\waol.exe:*:Disabled:America Online 9.0 -- File not found
"C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Disabled:AOL -- File not found
"C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Disabled:AOL -- File not found
"C:\Program Files\Kazaa\kazaa.exe" = C:\Program Files\Kazaa\kazaa.exe:*:Disabled:Kazaa -- File not found
"C:\Program Files\AVG\AVG8\avgupd.exe" = C:\Program Files\AVG\AVG8\avgupd.exe:*:Enabled:avgupd.exe -- (AVG Technologies CZ, s.r.o.)
"C:\Program Files\AVG\AVG8\avgemc.exe" = C:\Program Files\AVG\AVG8\avgemc.exe:*:Enabled:avgemc.exe -- (AVG Technologies CZ, s.r.o.)
"C:\Program Files\Common Files\AOL\Loader\aolload.exe" = C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader -- File not found
"C:\Program Files\AIM6\aim6.exe" = C:\Program Files\AIM6\aim6.exe:*:Enabled:AIM -- File not found
"C:\Program Files\Mozilla Firefox\firefox.exe" = C:\Program Files\Mozilla Firefox\firefox.exe:*:Enabled:Firefox -- File not found
"C:\Program Files\Java\jre6\bin\java.exe" = C:\Program Files\Java\jre6\bin\java.exe:*:Enabled:Java(TM) Platform SE binary -- File not found
"C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX05.829\WLM Lite 8.5.exe" = C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX05.829\WLM Lite 8.5.exe:*:Enabled:Windows Live Messenger Lite -- File not found
"C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX01.672\WLM Lite 8.5.exe" = C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX01.672\WLM Lite 8.5.exe:*:Enabled:Windows Live Messenger Lite -- File not found
"C:\Documents and Settings\LMR.DELL\Desktop\WLM Lite 8.5.exe" = C:\Documents and Settings\LMR.DELL\Desktop\WLM Lite 8.5.exe:*:Enabled:Windows Live Messenger Lite -- File not found
"C:\Program Files\AIM\aim.exe" = C:\Program Files\AIM\aim.exe:*:Enabled:AIM -- File not found
"C:\Program Files\Opera\opera.exe" = C:\Program Files\Opera\opera.exe:*:Enabled:Opera Internet Browser -- (Opera Software)
"C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX24.4265\Windows Live\Stubs\21b3aa58fa203a764422c9362410fcaf60dc969\msnmsgr.exe" = C:\Documents and Settings\LMR.DELL\Local Settings\Temp\Rar$EX24.4265\Windows Live\Stubs\21b3aa58fa203a764422c9362410fcaf60dc969\msnmsgr.exe:*:Enabled:msnmsgr -- File not found
"C:\Documents and Settings\LMR.DELL\Desktop\Windows Live\Windows Live Messenger.exe" = C:\Documents and Settings\LMR.DELL\Desktop\Windows Live\Windows Live Messenger.exe:*:Enabled:Windows Live Messenger -- File not found
"C:\Program Files\Pidgin\pidgin.exe" = C:\Program Files\Pidgin\pidgin.exe:*:Enabled:Pidgin -- (The Pidgin developer community)
"C:\Program Files\Google\Google Talk\googletalk.exe" = C:\Program Files\Google\Google Talk\googletalk.exe:*:Enabled:Google Talk -- File not found
"C:\Program Files\aMSN\bin\wish.exe" = C:\Program Files\aMSN\bin\wish.exe:*:Enabled:Wish Application -- (ActiveState Corporation)
"C:\WINDOWS\system32\dpvsetup.exe" = C:\WINDOWS\system32\dpvsetup.exe:*:Enabled:Microsoft DirectPlay Voice Test -- (Microsoft Corporation)
"{097346E0-6A51-11D1-AD16-00A0C95E0503}(SBC)" = Visual IP InSight(SBC)
"{17334AAF-C9E7-483B-9F45-E3FCAF07FFA7}" = Intel(R) PROSet for Wired Connections
"{1CB92574-96F2-467B-B793-5CEB35C40C29}" = Image Resizer Powertoy for Windows XP
"{26A24AE4-039D-4CA4-87B4-2F83216011FF}" = Java(TM) 6 Update 13
"{3175E049-F9A9-4A3D-8F19-AC9FB04514D1}" = Windows Live Communications Platform
"{318AB667-3230-41B5-A617-CB3BF748D371}" = iTunes
"{33BB4982-DC52-4886-A03B-F4C5C80BEE89}" = Windows Media Player 10
"{35B8CC58-F128-4169-82EB-0E6CB0C3AFE6}" = ArcSoft PhotoImpression
"{3AF8FCCD-F51A-4014-9002-F195E1CBC876}" = Logitech QuickCam
"{3B24B725-D81F-442D-8CE5-2AF05A4A4CC9}" = Music Visualizer Library 1.4.00
"{407B9B5C-DAC5-4F44-A756-B57CAB4E6A8B}" = Google Earth
"{4192EAC0-6B36-4723-B216-D0E86E7757AC}" = Jasc Paint Shop Photo Album 5
"{43DCF766-6838-4F9A-8C91-D92DA586DFA8}" = Microsoft Windows Journal Viewer
"{45338B07-A236-4270-9A77-EBB4115517B5}" = Windows Live Sign-in Assistant
"{4667B940-BB01-428B-986E-A0CC46497BF7}" = ELIcon
"{474F25F5-BDC9-40E5-B1B6-F6BF23FC106F}" = Windows Live Essentials
"{53735ECE-E461-4FD0-B742-23A352436D3A}" = Logitech Updater
"{5905F42D-3F5F-4916-ADA6-94A3646AEE76}" = Dell Driver Reset Tool
"{5B6BE547-21E2-49CA-B2E2-6A5F470593B1}" = Sonic Activation Module
"{62BD0AE0-4EB1-4BBB-8F43-B6400C8FEB2C}" = AOLIcon
"{62F33B80-6244-4A70-A233-0DA13B640364}" = OpenMG Secure Module 3.2
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{66A7A386-6F35-41A7-A731-101F0C0153C8}" = Popup Blocker (Windows Live Toolbar)
"{68108E66-D13A-4EE8-A6F4-40E4B90C2A26}" = Windows Live Toolbar Feed Detector (Windows Live Toolbar)
"{6D5FCA42-1486-4E32-AFE8-1B7E2AA59D33}" = Digital Content Portal
"{71D6CE84-B7DC-4166-8E0D-56C1C37BFB5A}" = SonicStage 1.5.53
"{7216871F-869E-437C-B9BF-2A13F2DCE63F}_is1" = Auslogics BoostSpeed
"{7242D513-4AF3-436F-90CF-970D51CBC6AB}_is1" = AimOne Video Converter 2.04
"{74F7662C-B1DB-489E-A8AC-07A06B24978B}" = Dell System Restore
"{78C496B9-5A6B-4692-8C2E-AFFFC34E4961}" = Jasc Paint Shop Pro Studio, Dell Editon
"{7EFA5E6F-74F7-4AFB-8AEA-AA790BD3A76D}" = DellSupport
"{7F142D56-3326-11D5-B229-002078017FBF}" = Modem Helper
"{86D6A20D-3910-4441-A3E5-EB6977251C86}" = Samsung USB Driver
"{8A708DD8-A5E6-11D4-A706-000629E95E20}" = Intel(R) Extreme Graphics 2 Driver
"{8E5233E1-7495-44FB-8DEB-4BE906D59619}" = Junk Mail filter update
"{90AF0409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office PowerPoint Viewer 2003
"{A06275F4-324B-4E85-95E6-87B2CD729401}" = Windows Defender
"{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}" = Segoe UI
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{AC76BA86-7AD7-1033-7B44-A81200000003}" = Adobe Reader 8.1.2
"{AEC0CEBC-0FC7-4716-8222-1C4A742719B1}" = Digimax Master
"{AF19F291-F22F-4798-9662-525305AE9E48}" = WordPerfect Office 12
"{B57EAFF2-D6EE-4C6C-9175-ED9F17BFC1BC}" = Windows Live Messenger
"{B65313CB-1612-4F64-A244-8BF3E5147C90}" = MyDSC2
"{B7050CBDB2504B34BC2A9CA0A692CC29}" = DivX Web Player
"{BCE72AED-3332-4863-9567-C5DCB9052CA2}" = Netflix Movie Viewer
"{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
"{CFADE4AF-C0CF-4A04-A776-741318F1658F}" = Content Transfer
"{D1E44702-21F5-4918-B8A3-6D126D5BD33C}" = Windows Messenger 5.1
"{D2988E9B-C73F-422C-AD4B-A66EBE257120}" = MCU
"{DEF2E5A3-0317-4822-B930-8B721EB483E4}" = ArcSoft VideoImpression 1.6
"{DF6A13C0-77DF-41FE-BD05-6D5201EB0CE7}_is1" = Auslogics Disk Defrag
"{E0F252A6-DE85-4E93-A93B-DFC3537B3965}" = WG111v2 Configuration Utility
"{E3BFEE55-39E2-4BE0-B966-89FE583822C1}" = Dell Support Center (Support Software)
"{E6158D07-2637-4ECF-B576-37C489669174}" = Windows Live Call
"{E646DCF0-5A68-11D5-B229-002078017FBF}" = Digital Line Detect
"{FB8148DD-C575-4B0A-9F6C-0CFC46937930}" = Opera 10.10
"Adobe Shockwave Player" = Adobe Shockwave Player
"Advanced Registry Optimizer_is1" = Advanced Registry Optimizer
"aMSN" = aMSN 0.98.3
"Aspell English Dictionary_is1" = Aspell English Dictionary-0.50-2
"AVG8Uninstall" = AVG Free 8.5
"BroadJump Client Foundation" = BroadJump Client Foundation
"CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1" = Conexant D850 56K V.9x DFVc Modem
"CopySafe Plugin" = CopySafe Plugin
"Dell Photo AIO Printer 924" = Dell Photo AIO Printer 924
"eMusic Remote" = eMusic Remote 1.0
"ESET Online Scanner" = ESET Online Scanner v3
"Foxit Reader" = Foxit Reader
"GNU Aspell_is1" = GNU Aspell 0.50-3
"GTK 2.0" = GTK+ Runtime 2.14.7 rev a (remove only)
"ie7" = Windows Internet Explorer 7
"IrfanView" = IrfanView (remove only)
"LiveUpdate" = LiveUpdate 3.0 (Symantec Corporation)
"lvdrivers_11.80" = Logitech QuickCam Driver Package
"mIRC" = mIRC
"MobiRise 3GP Converter" = MobiRise 3GP Converter
"OpenMG HotFix3.2-03-01-16-01" = OpenMG Limited Patch 3.2-03-02-21-08
"OpenMG HotFix3.2-03-01-16-02" = OpenMG Limited Patch 3.2-03-04-17-02
"OpenMG HotFix3.2-03-04-14-02" = OpenMG Limited Patch 3.2-03-04-14-02
"Pidgin" = Pidgin
"PROSet" = Intel(R) PRO Network Adapters and Drivers
"RealPlayer 12.0" = RealPlayer
"RegistryBooster 2_is1" = Uniblue RegistryBooster 2
"SBC Yahoo! Applications" = SBC Yahoo! Applications
"SBC.MCCInstall" = SBC Self Support Tool
"Yahoo! Applications" = AT&T Yahoo! Applications
"Yahoo! Extras" = Yahoo! Browser Services
"Yahoo! Software Update" = Yahoo! Software Update
"Move Networks Player - IE" = Move Networks Media Player for Internet Explorer
grumpygillz
Posts Posts : 10
Post by grumpygillz on 17th August 2010, 5:31 am
I can't seem to put the "Last 10 Event Log Errors" on here either. But other than that, that was the last of it.
grumpygillz
Posts Posts : 10
Post by Belahzur on 17th August 2010, 4:22 pm
Please run OTL.exe.
    :OTL
    :commands
    [purity]
    [emptytemp]
    [reboot]
  • Close OTL.exe
Post by grumpygillz on 18th August 2010, 10:58 pm
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3E290198-446F-4183-B884-A076288C4F41}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{3E290198-446F-4183-B884-A076288C4F41}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D4214342-3E46-44A1-80A3-4F802A2A67A2}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D4214342-3E46-44A1-80A3-4F802A2A67A2}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D7ECD7D2-D9B3-4DFB-A58F-3FF5A938B1FA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D7ECD7D2-D9B3-4DFB-A58F-3FF5A938B1FA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F6B20354-A2A9-47D4-9CE5-64D29FACF61F}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F6B20354-A2A9-47D4-9CE5-64D29FACF61F}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F8F57818-934C-4E37-B892-5908FD8EDC73}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F8F57818-934C-4E37-B892-5908FD8EDC73}\ deleted successfully.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{21FA44EF-376D-4D53-9B0F-8A89D3229068} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{21FA44EF-376D-4D53-9B0F-8A89D3229068}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{2318C2B1-4965-11D4-9B18-009027A5CD4F} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{2318C2B1-4965-11D4-9B18-009027A5CD4F}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{A057A204-BACC-4D26-9990-79A187E2698E} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0}\ not found.
C:\WINDOWS\system32\xubiidcj.ini moved successfully.
C:\WINDOWS\system32\nnWHNqru.ini moved successfully.
C:\WINDOWS\system32\auqqlvxu.ini moved successfully.
C:\WINDOWS\system32\qybbmtle.ini moved successfully.
C:\WINDOWS\system32\QrXENXbc.ini moved successfully.
C:\WINDOWS\system32\cfmnenyb.ini moved successfully.
C:\WINDOWS\system32\poWDNqru.ini moved successfully.
C:\WINDOWS\system32\adbhsplc.ini moved successfully.
C:\WINDOWS\system32\Giiknnpo.ini moved successfully.
C:\WINDOWS\system32\jcskwgew.ini moved successfully.
C:\WINDOWS\system32\gqdurabd.ini moved successfully.
C:\WINDOWS\system32\aIlVwyxx.ini moved successfully.
C:\WINDOWS\system32\yFfedfii.ini moved successfully.
C:\WINDOWS\system32\vixafjnn.ini moved successfully.
C:\WINDOWS\system32\jjqlhoud.ini moved successfully.
C:\WINDOWS\system32\hRtBLkkj.ini moved successfully.
C:\WINDOWS\system32\lcyiupyi.ini moved successfully.
C:\WINDOWS\system32\sfokksmq.ini moved successfully.
C:\WINDOWS\system32\wdqamhbe.ini moved successfully.
C:\WINDOWS\system32\bmmkxbkc.ini moved successfully.
C:\WINDOWS\system32\eiyiltrt.ini moved successfully.
C:\WINDOWS\system32\ktrevwqe.ini moved successfully.
C:\WINDOWS\system32\uqokoajk.ini moved successfully.
C:\WINDOWS\system32\amulwwoy.ini moved successfully.
C:\WINDOWS\system32\wxecbjgk.ini moved successfully.
C:\WINDOWS\system32\dcmwcvej.ini moved successfully.
C:\WINDOWS\system32\pjieydqq.ini moved successfully.
C:\WINDOWS\system32\cphvvmpr.ini moved successfully.
C:\WINDOWS\system32\dsulxsie.ini moved successfully.
C:\WINDOWS\system32\knvnxdjd.ini moved successfully.
C:\WINDOWS\system32\veiitlyp.ini moved successfully.
C:\WINDOWS\system32\tCbbayxx.ini moved successfully.
C:\WINDOWS\Таsks\Таsks folder moved successfully.
C:\WINDOWS\Таsks folder moved successfully.
[EMPTYTEMP]
User: Administrator
->Temp folder emptied: 27526 bytes
->Temporary Internet Files folder emptied: 1639465 bytes
->Flash cache emptied: 405 bytes
User: All Users
User: Application Data
User: blah
->Java cache emptied: 0 bytes
->FireFox cache emptied: 0 bytes
User: Default User
->Temporary Internet Files folder emptied: 32768 bytes
User: Guest
User: Guest 2
User: Guestx
->Temp folder emptied: 14040892 bytes
->Temporary Internet Files folder emptied: 62039480 bytes
->Java cache emptied: 264533 bytes
->Flash cache emptied: 4881 bytes
User: Larae Ramirez
User: LMR
->FireFox cache emptied: 3705751 bytes
User: LMR.DELL
->Temp folder emptied: 215978 bytes
->Temporary Internet Files folder emptied: 122361749 bytes
->Google Chrome cache emptied: 819568 bytes
->Opera cache emptied: 6089869 bytes
->Flash cache emptied: 14386 bytes
User: LocalService
->Temporary Internet Files folder emptied: 258450564 bytes
->Flash cache emptied: 60561 bytes
User: NetworkService
->Temp folder emptied: 536272 bytes
->Temporary Internet Files folder emptied: 95604838 bytes
->Flash cache emptied: 45441 bytes
User: Owner
%systemroot% .tmp files removed: 19569 bytes
%systemroot%\System32 .tmp files removed: 1495680 bytes
Windows Temp folder emptied: 111088 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 34318 bytes
RecycleBin emptied: 19393507 bytes
Total Files Cleaned = 560.00 mb
OTL by OldTimer - Version 3.2.10.0 log created on 08182010_153204
File\Folder C:\Documents and Settings\LMR.DELL\Local Settings\Temp\~DFF770.tmp not found!
File move failed. C:\WINDOWS\temp\logishrd\LVPrcInj01.dll scheduled to be moved on reboot.
grumpygillz
Posts Posts : 10
Joined Joined : 2010-08-16
Points Points : 23198
Re: svchost and browser problems plz help
Post by Sneakyone on 20th August 2010, 3:06 am
Hi.
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56104
Post by grumpygillz on 27th August 2010, 10:19 pm
I'm sorry for the late response.
I am not able to run combo fix because there are other antivirus applications running and i'm having a hard time disabling them.
I am still having all the same problems that I mentioned in my first post. Since then though a new problem has come up. I now have a corrupted file in my pidgin application that I can't get rid of. I tried running chkdsk utility thingy but my computer would not allow me to.
I tried just deleting the corrupted file on my own but I was unable to do that also. Very frustrating..
I will keep trying to disable the anti-viruses running on my computer. While I'm doing that though I'd appreciate any help for my corrupted file. Thank you.
grumpygillz
Posts Posts : 10
Post by Sneakyone on 30th August 2010, 1:21 am
Hi.
Try re-installing pidgin, I await your ComboFix log.
Sneakyone
Posts Posts : 2707
