DIVXWeb Player Won't Work on VISTA 64bit
Solved DIVXWeb Player Won't Work on VISTA 64bit
Post by Zorx on Sun 15 Aug 2010, 1:22 am
I use to have a Windows XP and DIVX Web Player worked fine and now i have a Windows Vista 64bit. This OS has been a problem since 1st time i got this laptop 1 week now. For some reason DIVX Web Player won't work. I reinstalled DIVX over and over, I used earlier versions, still no luck. Maybe i should just return to XP or upgrade to Win 7 . Anyway below are some screen shots. Thanks.
here is on of the error message i got online @ stagevu
And here is one to prove that it is installed.
Zorx
Operating System : vista 64bit
Solved Re: DIVXWeb Player Won't Work on VISTA 64bit
Post by Zorx on Sun 15 Aug 2010, 1:23 am
Never mind i fixed my own problem I actually fixed it by installing an old version of divx web player v1.5 and removed web player v2.0. If anyone has the same problem it's @http://support.divx.com/faq/view/supportFAQen003/DivX-Legacy-Version.
i also found out after all this that DIVX saves movie files in it's installed location and according to a DIVX error prompt i don't have write privileges to that file path in order to make the web player work. Vista is really trying to make things difficult for me. Even though I'm on an administrators account it still wants me to get write privileges. So what i did was just change the location to the
account: USER default download folder and VOILA! MAGIC!
Hopefully i can solve that account privileges issue, might as well fix it now than have it pop again later.
Zorx
