No internet connection and slow load up/run time after maleware removal with MB
Post by Tiwin on Sat Aug 14, 2010 2:02 pm
We woke up and suddenly, after have some IE redirection pop up issues, my wifes computer had 6 new icons on the desk top with names like spyware, trojan, porntube.com, and nudetube.com. We pulled the connection, threw it into safemode and ran virus scans and malwarebytes. We found 19 infected files 2 days after getting a clean bill of health. Restarted the machine and ran it in regular mode and ran MB again this time no infections however start up is extreamly slow, the notification area shows no runnign programs other than soundmax, and she can not connect to the internet even with a working connection. I tried using wired and wireless and got a confirmed connection with the wireless. Also VMware just randomly started up. I was worried about that this meant so I have it disconnected from the net still just in case.
I loaded up Hijakthis on a USB drive and here is the resulting log file. If there is any other diagnostics I need please let me know and, as long as I can use the USB drive to get them there I'll run them.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:40:51 AM, on 8/14/2010
C:\WINDOWS.0\System32\smss.exe
C:\WINDOWS.0\system32\winlogon.exe
C:\WINDOWS.0\system32\services.exe
C:\WINDOWS.0\system32\lsass.exe
C:\WINDOWS.0\system32\Ati2evxx.exe
C:\WINDOWS.0\system32\svchost.exe
C:\WINDOWS.0\System32\svchost.exe
C:\WINDOWS.0\system32\spoolsv.exe
C:\WINDOWS.0\Explorer.EXE
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\Analog Devices\SoundMAX\Smax4.exe
C:\WINDOWS.0\system32\ctfmon.exe
C:\DOCUME~1\OWNER~1.JAD\LOCALS~1\Temp\mcupdate_1281746678.exe
C:\WINDOWS.0\system32\HPZipm12.exe
C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe
C:\WINDOWS.0\system32\vmnat.exe
C:\WINDOWS.0\system32\SearchIndexer.exe
C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe
C:\WINDOWS.0\system32\wuauclt.exe
C:\WINDOWS.0\system32\vmnetdhcp.exe
C:\WINDOWS.0\system32\wscntfy.exe
C:\WINDOWS.0\system32\SearchProtocolHost.exe
C:\WINDOWS.0\system32\msiexec.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
O2 - BHO: Internet Explorer Plugin - {9FE088DC-C3B2-479C-A314-08F90CE5166F} - vecrits93.dll (file missing)
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll
O4 - HKLM\..\Run: [SoundMAX] "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS.0\system32\ctfmon.exe
O4 - HKCU\..\Run: [McAfee Update] C:\DOCUME~1\OWNER~1.JAD\LOCALS~1\Temp\mcupdate_1281746678.exe /syncfin C:\DOCUME~1\OWNER~1.JAD\LOCALS~1\Temp\mcupdate_1281746678.ini /insfin
O4 - HKUS\S-1-5-18\..\Run: [tlhdrlyn] C:\Documents and Settings\NetworkService.NT AUTHORITY\Local Settings\Application Data\stfbonukh\fhljceutssd.exe (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\Run: [wgfeuigb] C:\Documents and Settings\NetworkService.NT AUTHORITY\Local Settings\Application Data\knlcjobxx\uahuhsxtssd.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [tlhdrlyn] C:\Documents and Settings\NetworkService.NT AUTHORITY\Local Settings\Application Data\stfbonukh\fhljceutssd.exe (User 'Default user')
O4 - Global Startup: Amazon Unbox.lnk = ?
O8 - Extra context menu item: Google Sidewiki... - [You must be registered and logged in to see this link.] Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} (asusTek_sysctrl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {4871A87A-BFDD-4106-8153-FFDE2BAC2967} (DLM Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {A9F8D9EC-3D0A-4A60-BD82-FBD64BAD370D} (DDRevision Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - [You must be registered and logged in to see this link.]
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS.0\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS.0\system32\browseui.dll
O23 - Service: Amazon Unbox Video Service (ADVService) - Amazon.com - C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS.0\system32\Ati2evxx.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS.0\system32\HPZipm12.exe
O23 - Service: VMware Agent Service (ufad-ws60) - VMware, Inc. - C:\Program Files\VMware\VMware Player\vmware-ufad.exe
O23 - Service: VMware Authorization Service (VMAuthdService) - VMware, Inc. - C:\Program Files\VMware\VMware Player\vmware-authd.exe
O23 - Service: VMware DHCP Service (VMnetDHCP) - VMware, Inc. - C:\WINDOWS.0\system32\vmnetdhcp.exe
O23 - Service: VMware USB Arbitration Service (VMUSBArbService) - VMware, Inc. - C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe
O23 - Service: VMware NAT Service - VMware, Inc. - C:\WINDOWS.0\system32\vmnat.exe
End of file - 8636 bytes
Thanks for any assistance.
Tiwin
Posts Posts : 6
Joined Joined : 2010-08-14
OS OS : Windows XP Pro
Points Points : 23128
Re: No internet connection and slow load up/run time after maleware removal with MB
Post by Belahzur on Sat Aug 14, 2010 3:31 pm
Points Points : 245059
Post by Tiwin on Sat Aug 14, 2010 4:01 pm
Thanks for the prompt response. I followed your instructions and here is the resulting MBAM log. However I was not able to do an update past the previous update we had due ot lack of conectivity.
Database version: 4415
8/14/2010 10:51:39 AM
mbam-log-2010-08-14 (10-51-39).txt
Scan type: Quick scan
Objects scanned: 205888
Time elapsed: 9 minute(s), 13 second(s)
Something my just told me is that she did not have a password set up for her computer but now at startup it tells her that her password will expire in 11 days would she like to change it now. However this time when she started up this time the computer detected her Ethernet Controller as new hardware but can't find the drivers on her computer so we are getting farther.
Tiwin
Posts Posts : 6
Post by Belahzur on Sat Aug 14, 2010 8:04 pm
Post by Tiwin on Sat Aug 14, 2010 11:58 pm
OTL logfile created on: 8/14/2010 6:26:37 PM - Run 1
OTL by OldTimer - Version 3.2.9.0 Folder = E:\
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
2.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 79.00% Memory free
4.00 Gb Paging File | 4.00 Gb Available in Paging File | 92.00% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
%SystemDrive% = C: | %SystemRoot% = C:\WINDOWS.0 | %ProgramFiles% = C:\Program Files
Drive C: | 232.88 Gb Total Space | 37.89 Gb Free Space | 16.27% Space Free | Partition Type: NTFS
Unable to calculate disk information.
Drive E: | 954.05 Mb Total Space | 939.23 Mb Free Space | 98.45% Space Free | Partition Type: FAT
Computer Name: JADEFORLORN
Current User Name: Owner
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/08/14 18:19:54 | 000,574,976 | ---- | M] (OldTimer Tools) -- E:\OTL.com
PRC - [2010/06/16 21:24:02 | 000,039,408 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2010/03/04 13:00:56 | 000,025,704 | R--- | M] (Amazon.com) -- C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe
PRC - [2010/02/11 13:36:12 | 000,562,928 | ---- | M] (McAfee, Inc.) -- C:\Documents and Settings\Owner.JADEFORLORN\Local Settings\Temp\mcupdate_1281746678.exe
PRC - [2009/10/22 04:44:24 | 000,395,824 | ---- | M] (VMware, Inc.) -- C:\WINDOWS.0\system32\vmnat.exe
PRC - [2009/10/22 04:44:08 | 000,334,384 | ---- | M] (VMware, Inc.) -- C:\WINDOWS.0\system32\vmnetdhcp.exe
PRC - [2009/10/22 03:47:54 | 000,563,760 | ---- | M] (VMware, Inc.) -- C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS.0\explorer.exe
PRC - [2006/12/18 21:34:00 | 000,868,352 | ---- | M] (Analog Devices, Inc.) -- C:\Program Files\Analog Devices\Core\smax4pnp.exe
PRC - [2006/07/13 07:12:26 | 000,729,088 | ---- | M] (Analog Devices, Inc.) -- C:\Program Files\Analog Devices\SoundMAX\SMax4.exe
PRC - [2005/03/14 13:05:02 | 000,069,632 | ---- | M] (HP) -- C:\WINDOWS.0\system32\HPZipm12.exe
MOD - [2010/08/14 18:19:54 | 000,574,976 | ---- | M] (OldTimer Tools) -- E:\OTL.com
MOD - [2010/08/13 01:06:08 | 000,047,616 | -H-- | M] () -- C:\WINDOWS.0\system32\autos-sd.dll
MOD - [2008/04/13 19:10:20 | 000,110,592 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS.0\system32\msscript.ocx
SRV - [2010/03/04 13:00:56 | 000,025,704 | R--- | M] (Amazon.com) [Auto | Running] -- C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe -- (ADVService)
SRV - [2009/10/22 04:44:24 | 000,395,824 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\WINDOWS.0\system32\vmnat.exe -- (VMware NAT Service)
SRV - [2009/10/22 04:44:18 | 000,113,200 | ---- | M] (VMware, Inc.) [Auto | Stopped] -- C:\Program Files\VMware\VMware Player\vmware-authd.exe -- (VMAuthdService)
SRV - [2009/10/22 04:44:08 | 000,334,384 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\WINDOWS.0\system32\vmnetdhcp.exe -- (VMnetDHCP)
SRV - [2009/10/22 03:47:54 | 000,563,760 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe -- (VMUSBArbService)
SRV - [2009/10/12 14:32:24 | 000,191,024 | ---- | M] (VMware, Inc.) [On_Demand | Stopped] -- C:\Program Files\VMware\VMware Player\vmware-ufad.exe -- (ufad-ws60)
SRV - [2005/03/14 13:05:02 | 000,069,632 | ---- | M] (HP) [Auto | Running] -- C:\WINDOWS.0\system32\HPZipm12.exe -- (Pml Driver HPZ12)
DRV - [2010/08/13 14:15:37 | 000,361,600 | ---- | M] () [Kernel | System | Stopped] -- C:\WINDOWS.0\system32\drivers\tcpip.sys -- (Tcpip)
DRV - [2009/10/22 04:45:06 | 000,032,688 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS.0\system32\drivers\vmnetbridge.sys -- (VMnetBridge)
DRV - [2009/10/22 04:45:02 | 000,853,936 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS.0\system32\drivers\vmx86.sys -- (vmx86)
DRV - [2009/10/22 04:45:00 | 000,070,704 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS.0\system32\drivers\vmci.sys -- (vmci)
DRV - [2009/10/22 04:45:00 | 000,023,216 | ---- | M] (VMware, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\VMkbd.sys -- (vmkbd)
DRV - [2009/10/22 04:44:58 | 000,026,288 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS.0\system32\drivers\vmnetuserif.sys -- (VMnetuserif)
DRV - [2009/10/22 03:47:52 | 000,032,304 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS.0\system32\drivers\hcmon.sys -- (hcmon)
DRV - [2009/10/22 00:13:32 | 000,016,560 | R--- | M] (VMware, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\vmnetadapter.sys -- (VMnetAdapter)
DRV - [2009/10/12 14:31:52 | 000,022,448 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\Program Files\VMware\VMware Player\vstor2-ws60.sys -- (vstor2-ws60)
DRV - [2009/09/16 10:22:48 | 000,214,664 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\WINDOWS.0\system32\drivers\mfehidk.sys -- (mfehidk)
DRV - [2009/09/16 10:22:48 | 000,079,816 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\mfeavfk.sys -- (mfeavfk)
DRV - [2009/09/16 10:22:48 | 000,040,552 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\mfesmfk.sys -- (mfesmfk)
DRV - [2009/09/16 10:22:48 | 000,035,272 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\mfebopk.sys -- (mfebopk)
DRV - [2009/09/16 10:22:14 | 000,034,248 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\mferkdk.sys -- (mferkdk)
DRV - [2009/05/16 03:58:46 | 004,069,888 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2008/04/13 11:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2007/12/06 09:51:00 | 000,285,952 | ---- | M] (Marvell) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\yk51x86.sys -- (yukonwxp)
DRV - [2007/07/20 18:40:10 | 000,084,992 | ---- | M] (ATI Research Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\AtiHdmi.sys -- (AtiHdmiService)
DRV - [2007/04/16 21:46:00 | 000,033,792 | ---- | M] (Advanced Micro Devices) [Kernel | System | Running] -- C:\WINDOWS.0\system32\drivers\AmdPPM.sys -- (AmdPPM)
DRV - [2007/01/16 09:09:00 | 000,293,888 | ---- | M] (Analog Devices, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\ADIHdAud.sys -- (ADIHdAudAddService)
DRV - [2006/12/18 11:30:08 | 000,556,832 | ---- | M] (AzureWave Technologies, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS.0\system32\drivers\aw5006.sys -- (AR2425)
DRV - [2006/03/17 17:18:00 | 000,392,960 | ---- | M] (Sensaura) [Kernel | On_Demand | Running] -- C:\WINDOWS.0\system32\drivers\senfilt.sys -- (SenFiltService)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\WINDOWS.0\system32\blank.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\WINDOWS.0\system32\blank.htm
[2009/07/13 13:23:27 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2009/06/17 10:03:02 | 000,000,000 | ---D | M] (pdfforge Toolbar Plugin) -- C:\Program Files\Mozilla Firefox\extensions\{B922D405-6D13-4A2B-AE89-08A030DA4402}
[2009/06/17 10:03:02 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions\search@searchsettings.com
O1 HOSTS File: ([2010/07/22 21:26:29 | 000,414,972 | R--- | M]) - C:\WINDOWS.0\system32\drivers\etc\hosts
O1 - Hosts: 127.0.0.1 [You must be registered and logged in to see this link.]
O1 - Hosts: 127.0.0.1 007guard.com
O1 - Hosts: 127.0.0.1 008i.com
O1 - Hosts: 127.0.0.1 008k.com
O1 - Hosts: 127.0.0.1 00hq.com
O1 - Hosts: 127.0.0.1 010402.com
O1 - Hosts: 127.0.0.1 032439.com
O1 - Hosts: 127.0.0.1 0scan.com
O1 - Hosts: 127.0.0.1 1000gratisproben.com
O1 - Hosts: 127.0.0.1 1001namen.com
O1 - Hosts: 127.0.0.1 100888290cs.com
O1 - Hosts: 127.0.0.1 100sexlinks.com
O1 - Hosts: 127.0.0.1 10sek.com
O1 - Hosts: 127.0.0.1 1-2005-search.com
O1 - Hosts: 14331 more lines...
O2 - BHO: (Spybot-S&D IE Protection) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O2 - BHO: (Internet Explorer Plugin) - {9FE088DC-C3B2-479C-A314-08F90CE5166F} - File not found
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll (Google Inc.)
O4 - HKLM..\Run: [SoundMAX] C:\Program Files\Analog Devices\SoundMAX\Smax4.exe (Analog Devices, Inc.)
O4 - HKLM..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe (Analog Devices, Inc.)
O4 - HKCU..\Run: [McAfee Update] C:\Documents and Settings\Owner.JADEFORLORN\Local Settings\Temp\mcupdate_1281746678.exe (McAfee, Inc.)
O4 - Startup: C:\Documents and Settings\All Users.WINDOWS.0\Start Menu\Programs\Startup\Amazon Unbox.lnk = C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientSystemTray.exe (Amazon.com)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 255
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoControlPanel = 0
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll (Google Inc.)
O9 - Extra 'Tools' menuitem : Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} [You must be registered and logged in to see this link.] (asusTek_sysctrl Class)
O16 - DPF: {4871A87A-BFDD-4106-8153-FFDE2BAC2967} [You must be registered and logged in to see this link.] (DLM Control)
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} [You must be registered and logged in to see this link.] (Facebook Photo Uploader 5 Control)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {A9F8D9EC-3D0A-4A60-BD82-FBD64BAD370D} [You must be registered and logged in to see this link.] (DDRevision Class)
O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.254
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS.0\explorer.exe (Microsoft Corporation)
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS.0\System32\ati2evxx.dll (ATI Technologies Inc.)
O28 - HKLM ShellExecuteHooks: {56F9679E-7826-4C84-81F3-532071A8BCC5} - C:\Program Files\Windows Desktop Search\MsnlNamespaceMgr.dll (Microsoft Corporation)
O30 - LSA: Authentication Packages - (qopmmk.dll) - File not found
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2008/01/08 07:18:48 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O36 - AppCertDlls: dmrereg - (C:\WINDOWS.0\system32\autos-sd.dll) - C:\WINDOWS.0\system32\autos-sd.dll ()
[2010/08/14 08:39:55 | 000,000,000 | ---D | C] -- C:\Program Files\Trend Micro
[2010/08/13 20:05:03 | 000,000,000 | -HSD | C] -- C:\WINDOWS.0\CSC
[2010/08/08 22:56:10 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\Recent
[2010/08/07 12:33:39 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Electronic Arts
[2010/08/07 12:31:48 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\Application Data\Electronic Arts
[2010/08/07 11:22:34 | 000,000,000 | ---D | C] -- C:\Program Files\Electronic Arts
[2010/08/06 13:15:43 | 000,000,000 | ---D | C] -- C:\spoolerlogs
[2010/08/06 10:20:35 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Dresden Files
[2010/08/03 15:55:41 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\Local Settings\Application Data\jZip
[2010/08/03 15:53:37 | 000,000,000 | ---D | C] -- C:\Program Files\jZip
[2010/07/27 21:43:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner.JADEFORLORN\Application Data\Malwarebytes
[2010/07/27 21:40:40 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS.0\System32\drivers\mbamswissarmy.sys
[2010/07/27 21:40:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users.WINDOWS.0\Application Data\Malwarebytes
[2010/07/27 21:40:39 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS.0\System32\drivers\mbam.sys
[2010/07/27 21:39:38 | 006,153,352 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\domi.exe
[2010/07/27 21:20:58 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[4 C:\WINDOWS.0\*.tmp files -> C:\WINDOWS.0\*.tmp -> ]
[3 C:\WINDOWS.0\System32\*.tmp files -> C:\WINDOWS.0\System32\*.tmp -> ]
[2010/08/14 18:18:27 | 000,000,426 | -H-- | M] () -- C:\WINDOWS.0\tasks\User_Feed_Synchronization-{23A8C4CB-31E3-4E3D-8278-82E63D55F10A}.job
[2010/08/14 17:31:15 | 000,001,002 | ---- | M] () -- C:\WINDOWS.0\tasks\GoogleUpdateTaskUserS-1-5-21-2052111302-1078081533-839522115-1003UA.job
[2010/08/14 17:29:05 | 000,000,884 | ---- | M] () -- C:\WINDOWS.0\tasks\GoogleUpdateTaskMachineUA.job
[2010/08/14 10:57:27 | 000,002,206 | ---- | M] () -- C:\WINDOWS.0\System32\wpa.dbl
[2010/08/14 10:55:52 | 000,000,880 | ---- | M] () -- C:\WINDOWS.0\tasks\GoogleUpdateTaskMachineCore.job
[2010/08/14 10:54:45 | 000,000,006 | -H-- | M] () -- C:\WINDOWS.0\tasks\SA.DAT
[2010/08/14 10:54:42 | 000,002,048 | --S- | M] () -- C:\WINDOWS.0\bootstat.dat
[2010/08/14 10:53:28 | 006,291,456 | -H-- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\NTUSER.DAT
[2010/08/14 10:53:28 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\ntuser.ini
[2010/08/14 10:40:08 | 000,002,457 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\HiJackThis.lnk
[2010/08/13 23:36:06 | 001,402,880 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\bob.msi
[2010/08/13 20:03:58 | 005,371,074 | -H-- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Local Settings\Application Data\IconCache.db
[2010/08/13 19:58:35 | 000,558,818 | ---- | M] () -- C:\WINDOWS.0\System32\PerfStringBackup.INI
[2010/08/13 19:58:35 | 000,467,316 | ---- | M] () -- C:\WINDOWS.0\System32\perfh009.dat
[2010/08/13 19:58:35 | 000,080,110 | ---- | M] () -- C:\WINDOWS.0\System32\perfc009.dat
[2010/08/13 19:44:44 | 000,262,144 | ---- | M] () -- C:\Documents and Settings\All Users.WINDOWS.0\NTUSER.DAT
[2010/08/13 14:15:37 | 000,361,600 | ---- | M] () -- C:\WINDOWS.0\System32\drivers\tcpip.sys
[2010/08/13 01:56:32 | 000,000,664 | ---- | M] () -- C:\WINDOWS.0\System32\d3d9caps.dat
[2010/08/13 01:06:08 | 000,047,616 | -H-- | M] () -- C:\WINDOWS.0\System32\autos-sd.dll
[2010/08/12 08:31:02 | 000,000,950 | ---- | M] () -- C:\WINDOWS.0\tasks\GoogleUpdateTaskUserS-1-5-21-2052111302-1078081533-839522115-1003Core.job
[2010/08/10 23:31:36 | 000,002,374 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\Google Chrome.lnk
[2010/08/10 23:31:36 | 000,002,352 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/08/09 20:36:05 | 000,000,284 | ---- | M] () -- C:\WINDOWS.0\tasks\AppleSoftwareUpdate.job
[2010/08/07 11:22:34 | 000,000,910 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\Dark Age of Camelot.lnk
[2010/08/05 17:37:08 | 000,000,682 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\CCleaner.lnk
[2010/07/29 11:04:11 | 000,000,725 | ---- | M] () -- C:\Documents and Settings\All Users.WINDOWS.0\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/07/28 13:11:16 | 000,024,576 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Dark Tutelage fling.doc
[2010/07/27 21:39:42 | 006,153,352 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\domi.exe
[2010/07/26 16:20:28 | 000,042,980 | ---- | M] () -- C:\WINDOWS.0\System32\oiffl
[2010/07/26 16:20:27 | 000,105,472 | ---- | M] () -- C:\WINDOWS.0\System32\klgd.bmp
[2010/07/22 21:26:29 | 000,414,972 | R--- | M] () -- C:\WINDOWS.0\System32\drivers\etc\hosts
[2010/07/21 22:36:19 | 000,026,112 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Articaft deck skeleton.doc
[2010/07/21 09:16:38 | 000,011,976 | ---- | M] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\76uy kityi.docx
[2010/07/21 01:08:12 | 000,000,552 | ---- | M] () -- C:\WINDOWS.0\System32\d3d8caps.dat
[2010/08/14 08:39:55 | 000,002,457 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\HiJackThis.lnk
[2010/08/14 08:36:10 | 001,402,880 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\bob.msi
[2010/08/13 19:51:05 | 000,007,986 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\reset.log
[2010/08/13 19:44:44 | 000,262,144 | ---- | C] () -- C:\Documents and Settings\All Users.WINDOWS.0\NTUSER.DAT
[2010/08/13 19:44:44 | 000,001,024 | -H-- | C] () -- C:\Documents and Settings\All Users.WINDOWS.0\NTUSER.DAT.LOG
[2010/08/13 01:06:08 | 000,047,616 | -H-- | C] () -- C:\WINDOWS.0\System32\autos-sd.dll
[2010/08/07 11:22:34 | 000,000,910 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\Desktop\Dark Age of Camelot.lnk
[2010/07/28 13:11:16 | 000,024,576 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Dark Tutelage fling.doc
[2010/07/27 21:40:43 | 000,000,725 | ---- | C] () -- C:\Documents and Settings\All Users.WINDOWS.0\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/07/26 16:20:28 | 000,042,980 | ---- | C] () -- C:\WINDOWS.0\System32\oiffl
[2010/07/26 16:20:27 | 000,105,472 | ---- | C] () -- C:\WINDOWS.0\System32\klgd.bmp
[2010/07/21 22:36:19 | 000,026,112 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\Articaft deck skeleton.doc
[2010/07/21 09:16:36 | 000,011,976 | ---- | C] () -- C:\Documents and Settings\Owner.JADEFORLORN\My Documents\76uy kityi.docx
[2010/07/21 01:08:12 | 000,000,552 | ---- | C] () -- C:\WINDOWS.0\System32\d3d8caps.dat
[2010/07/20 17:15:34 | 000,000,664 | ---- | C] () -- C:\WINDOWS.0\System32\d3d9caps.dat
[2009/08/30 13:54:40 | 000,000,754 | ---- | C] () -- C:\WINDOWS.0\WORDPAD.INI
[2009/08/03 15:07:42 | 000,403,816 | ---- | C] () -- C:\WINDOWS.0\System32\OGACheckControl.dll
[2008/02/13 12:24:52 | 000,077,824 | ---- | C] () -- C:\WINDOWS.0\System32\hpzids01.dll
[2007/09/27 11:51:02 | 000,020,698 | ---- | C] () -- C:\WINDOWS.0\System32\idxcntrs.ini
[2007/09/27 11:48:48 | 000,030,628 | ---- | C] () -- C:\WINDOWS.0\System32\gsrvctr.ini
[2007/09/27 11:48:28 | 000,031,698 | ---- | C] () -- C:\WINDOWS.0\System32\gthrctr.ini
[2004/08/03 20:07:00 | 000,361,600 | ---- | C] () -- C:\WINDOWS.0\System32\drivers\tcpip.sys
[2001/07/06 17:30:00 | 000,003,399 | ---- | C] () -- C:\WINDOWS.0\System32\hptcpmon.ini
Tiwin
Posts Posts : 6
Post by Tiwin on Sat Aug 14, 2010 11:59 pm
OTL Extras logfile created on: 8/14/2010 6:26:37 PM - Run 1
File Age = 30 Days
Output = Standard
.html [@ = htmlfile] -- Reg Error: Key error. File not found
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [print] -- "C:\Program Files\Microsoft Office\Office12\msohtmed.exe" /p %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"139:TCP" = 139:TCP:*:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:*:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:*:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:*:Enabled:@xpsp2res.dll,-22002
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"139:TCP" = 139:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22002
"56885:TCP" = 56885:TCP:*:Enabled:Pando Media Booster
"56885:UDP" = 56885:UDP:*:Enabled:Pando Media Booster
"C:\Program Files\Curse\CurseClient.exe" = C:\Program Files\Curse\CurseClient.exe:*:Enabled:Curse Client -- File not found
"C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe" = C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe:*:Enabled:McAfee Network Agent -- File not found
"C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" = C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE:*:Enabled:Microsoft Office Outlook -- (Microsoft Corporation)
"C:\Program Files\Pando Networks\Media Booster\PMB.exe" = C:\Program Files\Pando Networks\Media Booster\PMB.exe:*:Enabled:Pando Media Booster -- ()
"C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe" = C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe:*:Enabled:hpofxm08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe" = C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe:*:Enabled:hposfx08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hposid01.exe" = C:\Program Files\HP\Digital Imaging\bin\hposid01.exe:*:Enabled:hposid01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqCopy.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqCopy.exe:*:Enabled:hpqcopy.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpfccopy.exe" = C:\Program Files\HP\Digital Imaging\bin\hpfccopy.exe:*:Enabled:hpfccopy.exe -- (Hewlett-Packard)
"C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe:*:Enabled:hpzwiz01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\Unload\HpqPhUnl.exe" = C:\Program Files\HP\Digital Imaging\Unload\HpqPhUnl.exe:*:Enabled:hpqphunl.exe -- ()
"C:\Program Files\HP\Digital Imaging\Unload\HpqDIA.exe" = C:\Program Files\HP\Digital Imaging\Unload\HpqDIA.exe:*:Enabled:hpqdia.exe -- ( )
"C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe:*:Enabled:hpoews01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\VMware\VMware Player\vmware-authd.exe" = C:\Program Files\VMware\VMware Player\vmware-authd.exe:*:Enabled:VMware Authd -- (VMware, Inc.)
"C:\Program Files\SquareEnix\FINAL FANTASY XIV Beta Version\ffxivboot.exe" = C:\Program Files\SquareEnix\FINAL FANTASY XIV Beta Version\ffxivboot.exe:*:Enabled:FINAL FANTASY XIV Beta Version BOOT -- (SQUARE ENIX CO., LTD.)
"{05C56753-F144-44BC-BA67-83CC5DBF395C}" = F300
"{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
"{0BF5FBE7-3907-4A1F-9E48-8B66E52850D6}" = TrayApp
"{1451DE6B-ABE1-4F62-BE9A-B363A17588A2}" = QuickTime
"{1E1F1E70-14D8-4380-8652-BD1A895A7D65}" = Status
"{23B35809-5E4A-4F14-8332-1CDEDDFAC089}" = CP_Package_Variety2
"{24BEBF2E-73F3-4599-840B-EDC612CCDD0D}" = Destinations
"{26A24AE4-039D-4CA4-87B4-2F83216017FF}" = Java(TM) 6 Update 17
"{295941F1-484E-4C23-B43C-7EFDC3E6DF43}" = ASUS WiFi-AP Solo
"{31263605-FC84-4787-B847-BA445B147E24}" = ScannerCopy
"{34F3FCF1-817B-4D61-B6AF-19D9486AFEA0}" = Unload
"{3FA365DF-2D68-45ED-8F83-8C8A33E65143}" = Apple Application Support
"{4041C245-7099-4C96-9738-5EBC23827B3C}" = BufferChm
"{45A66726-69BC-466B-A7A4-12FCBA4883D7}" = HiJackThis
"{4BE53DB2-C1F2-44D1-A9AB-1630BA7F2AF1}" = SolutionCenter
"{4CCC7F68-A437-4559-A840-F5E010934951}" = HP Driver Diagnostics
"{522D1D79-9C0A-4361-91F8-2AFF8EC6C2E1}" = CP_Package_Variety1
"{54A4839E-87F8-4BD1-9682-A349E9943F0A}" = Amazon Unbox Video
"{597E70FF-7C46-4EED-8092-91B7C2E0529D}" = Google SketchUp 7
"{626C034B-50B8-47BD-AF93-EEFD0FA78FF4}" = Character Builder
"{66E6CE0C-5A1E-430C-B40A-0C90FF1804A8}" = eSupportQFolder
"{68763C27-235D-4165-A961-FDEA228CE504}" = AiOSoftwareNPI
"{6D8D64BE-F500-55B6-705D-DFD08AFE0624}" = Acrobat.com
"{71D9B000-CD43-4DE9-9729-49434415B8F7}" = F300Trb
"{736C803C-DD3B-4015-BC51-AFB9E67B9076}" = Readme
"{7E7B7865-6C80-4373-8BC1-C2EB9431F9DE}" = ProductContextNPI
"{90120000-0011-0000-0000-0000000FF1CE}" = Microsoft Office Professional Plus 2007
"{90120000-0011-0000-0000-0000000FF1CE}_PROPLUS_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0011-0000-0000-0000000FF1CE}_PROPLUS_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0015-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_PROPLUS_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_PROPLUS_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_PROPLUS_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0044-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_PROPLUS_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_PROPLUS_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_PROPLUS_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{980A182F-E0A2-4A40-94C1-AE0C1235902E}" = Pando Media Booster
"{9C1BB613-F398-49B7-B346-5DEBA8ABBF38}" = FINAL FANTASY XIV Beta Version
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A2F166A0-F031-4E27-A057-C69733219434}_is1" = Runes of Magic
"{A4552E28-AF1D-4C3E-9991-8112F40265F4}" = Adventure Tools
"{A53A11EA-0095-493F-86FA-A15E8A86A405}" = VMware Player
"{AAA11090-6E99-4655-AAF5-57EB5F677D0C}" = MarketResearch
"{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}" = Apple Mobile Device Support
"{AB5D51AE-EBC3-438D-872C-705C7C2084B0}" = DeviceManagementQFolder
"{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3.2
"{AF7733C1-FB0B-4FED-9730-E0433AF7A2EF}" = Magic Online III
"{B0C60A57-0353-498B-BDF0-AE83BFE3B4B9}_is1" = championBuilder v0.4.0
"{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{B57F2FF0-5A25-4332-B503-4592B370C02F}" = CP_Package_Variety3
"{B6F7DBE7-2FE2-458F-A738-B10832746036}" = Microsoft Reader
"{BF4E9ED0-EF26-4A4C-A123-6A6A1ABEE411}" = DocProc
"{C6812939-B117-48E6-A3BA-1709C14A3C8C}" = Scan
"{C8753E28-2680-49BF-BD48-DD38FD086EFE}" = AiO_Scan_CDA
"{C98E8D9D-21DE-4F87-A9B7-142BB89840FC}" = Toolbox
"{CD95F661-A5C4-44F5-A6AA-ECDD91C240BD}" = WinZip 14.5
"{CFE9EB66-DFD8-40B4-BC9C-F0CCEEBE8FE3}" = ASUS WiFi-AP Solo
"{D7CAE58E-26DE-49B7-A75D-EAEDF76726BE}" = HP Photosmart Essential
"{DEBB2986-15B0-4D28-95FA-5C966A396589}" = HPProductAssistant
"{E5966E4C-0A93-4F59-A981-BD3173D4799F}" = F300_Help
"{E5A8DDAB-AE80-48C6-A75B-D0FAB83B299D}" = HP PSC & OfficeJet 6.1.A
"{E6B87DC4-2B3D-4483-ADFF-E483BF718991}" = OpenOffice.org 3.1
"{EC2715CE-C182-483C-84CC-81D7D914CF14}" = WebReg
"{ECFDD6BD-E0C0-41CC-A171-E6D6AF4C0E93}" = HP Software Update
"{F0A37341-D692-11D4-A984-009027EC0A9C}" = SoundMAX
"{F0E2B312-D7FD-4349-A9B6-E90B36DB1BD0}" = Paint.NET v3.5.5
"{F439D7AF-03F3-4F8E-AEC4-571BFE977C61}" = iTunes
"{F6076EF9-08E1-442F-B6A2-BFB61B295A14}" = Fax_CDA
"{FBB980B0-63F8-4B48-8D65-90F1D9F81D9F}" = NewCopy_CDA
"Adobe AIR" = Adobe AIR
"ATI Display Driver" = ATI Display Driver
"CCleaner" = CCleaner
"Champions Online" = Champions Online
"COH" = City of Villains/City of Heroes (remove only)
"Dark Age of Camelot" = Dark Age of Camelot
"Defraggler" = Defraggler
"HP Imaging Device Functions" = HP Imaging Device Functions 6.1
"HP Solution Center & Imaging Support Tools" = HP Solution Center and Imaging Support Tools 6.1
"HPExtendedCapabilities" = HP Extended Capabilities 6.1
"InstallShield_{54A4839E-87F8-4BD1-9682-A349E9943F0A}" = Amazon Unbox Video
"jZip" = jZip
"PROPLUS" = Microsoft Office Professional Plus 2007
"VMware_Player" = VMware Player
"090215de958f1060" = Curse Client
"Google Chrome" = Google Chrome
"Move Media Player" = Move Media Player
"RPTools MapTool" = RPTools MapTool
[ Application Events ]
Error - 7/14/2010 8:36:23 AM | Computer Name = JADEFORLORN | Source = Application Hang | ID = 1002
Description = Hanging application iexplore.exe, version 8.0.6001.18702, hang module
hungapp, version 0.0.0.0, hang address 0x00000000.
Error - 7/14/2010 9:05:18 AM | Computer Name = JADEFORLORN | Source = vmauthd | ID = 100
Description = Call to listen failed with error 10013.
Description = Failed to create event for listen socket: An attempt was made to access
a socket in a way forbidden by its access permissions (10013)
Error - 7/14/2010 10:35:55 AM | Computer Name = JADEFORLORN | Source = Application Hang | ID = 1002
Error - 7/20/2010 9:47:52 AM | Computer Name = JADEFORLORN | Source = Application Hang | ID = 1002
[ ODiag Events ]
Error - 8/6/2010 2:16:01 PM | Computer Name = JADEFORLORN | Source = Microsoft Office 12 Diagnostics | ID = 320
Description = An unexpected error occurred. Tag: 2kd0. Error code: 800706BA
[ OSession Events ]
Error - 2/11/2010 4:49:42 PM | Computer Name = JADEFORLORN | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 8, Application Name: Microsoft Office Publisher, Application Version:
12.0.6501.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 45
seconds with 0 seconds of active time. This session ended with a crash.
[ System Events ]
Error - 8/13/2010 9:12:29 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7001
Description = The Network Location Awareness (NLA) service depends on the TCP/IP
Protocol Driver service which failed to start because of the following error: %%2001
Error - 8/13/2010 9:12:29 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7000
Description = The TCP/IP Protocol Driver service failed to start due to the following
error: %%2001
Error - 8/13/2010 9:56:47 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7000
error: %%2001
Error - 8/13/2010 9:56:47 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7001
Error - 8/13/2010 10:09:42 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7000
error: %%2001
Error - 8/13/2010 10:09:42 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7001
Error - 8/13/2010 10:10:24 PM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7000
error: %%2001
Error - 8/14/2010 9:34:52 AM | Computer Name = JADEFORLORN | Source = NetBT | ID = 4311
Description = Initialization failed because the driver device could not be created.
Error - 8/14/2010 10:24:35 AM | Computer Name = JADEFORLORN | Source = Service Control Manager | ID = 7000
error: %%2001
Tiwin
Posts Posts : 6
Post by Belahzur on Sun Aug 15, 2010 12:38 am
Please run OTL.exe.
    :OTL
  • Close OTL.exe
Post by Tiwin on Sun Aug 15, 2010 1:12 am
The latest log info:
========== OTL ==========
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\AppCertDlls\\dmrereg:C:\WINDOWS.0\system32\autos-sd.dll deleted successfully.
C:\WINDOWS.0\system32\autos-sd.dll moved successfully.
OTL by OldTimer - Version 3.2.9.0 log created on 08142010_201104
Tiwin
Posts Posts : 6
Post by Tiwin on Sun Aug 15, 2010 1:30 pm
Unfortunately I still have no internet connectivity. In the hardware profiles it says that some unknown Ethernet controller has no drivers, but then it also says that my actual Ethernet controller, a Marvell Yukon, is working perfectly fine and has fully updated drivers.
Tiwin
Posts Posts : 6
Post by Belahzur on Mon Aug 16, 2010 12:47 am
