wireless connection issue.
Post by siouxlini on 12th August 2010, 6:39 am
Having issues connecting to the internet via a wireless router. The computer connects to the internet fine when connected to the router via the ethernet. Computer will connect to the router fine but is unable to establish a connection to the internet.
Toshiba Satillite laptop
Windows 7
Motorola SBG941 SURFboard Wireless Cable Modem Gateway
siouxlini
Posts Posts : 48
Joined Joined : 2010-03-09
OS OS : windows xp
Points Points : 25320
Re: wireless connection issue.
Post by bigcat on 22nd August 2010, 1:11 am
I know this sounds basic, but it has bit me before. Are you seeing any signal when checking for your wireless connection? Does it should the wireless avalible? It maybe a physical switch turned off that needs to be toggled to turn wireless on.
bigcat
Posts Posts : 34
Joined Joined : 2010-06-19
OS OS : Vista
Protection Protection : Comodo
Points Points : 23941
