Security Tool and Antivir Solution Pro
Post by GMan316 on 10th August 2010, 8:27 am
Hi, I seemed to have caught Security Tool and Antivir Solution Pro. I tried to follow the security tool removal instructions. I ran Malware Bytes in safe mode (because it wouldn't let me install in normal mode) and I deleted everything it found. However when I rebooted in normal mode security tool was still present. I ran hijackthis in safe mode and here is what I got. I also have my malwarebytes log.
Malware Bytes:
Database version: 4052
Windows 5.1.2600 Service Pack 3 (Safe Mode)
Internet Explorer 6.0.2900.5512
8/9/2010 4:20:15 PM
mbam-log-2010-08-09 (16-20-15).txt
Scan type: Quick scan
Objects scanned: 112176
Time elapsed: 3 minute(s), 21 second(s)
Registry Keys Infected: 10
Registry Values Infected: 6
Files Infected: 7
HKEY_CLASSES_ROOT\cscrptxt.cscrptxt (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e0ec6fba-f009-3535-95d6-b6390db27da1} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{f43ebb98-334c-4ae2-9ce3-1b22d9830fe7} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{f43ebb98-334c-4ae2-9ce3-1b22d9830fe7} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{f43ebb98-334c-4ae2-9ce3-1b22d9830fe7} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\cscrptxt.cscrptxt.1.0 (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{38061edc-40bb-4618-a8da-e56353347e6d} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adshothlpr.adshothlpr (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adshothlpr.adshothlpr.1.0 (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\qpnatbda (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\fcytovts (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\qpnatbda (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\fcytovts (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\lsdefrag (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ewrgetuj (Worm.Prolaco.M) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\NameServer (Trojan.DNSChanger) -> Data: 93.188.164.73,93.188.166.223 -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{ddfd9e8b-75c1-4778-9019-7095ee9815ca}\NameServer (Trojan.DNSChanger) -> Data: 93.188.164.73,93.188.166.223 -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wsxip.dll (Adware.EZlife) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jerome\Local Settings\temp\oenraxcmws.tmp (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jerome\Local Settings\Application Data\tanpkfhwe\vhsefhctssd.exe (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jerome\Local Settings\Application Data\babokpihk\vxcbsgvtssd.exe (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jerome\Start Menu\Programs\Security Tool.LNK (Rogue.SecurityTool) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jerome\Local Settings\temp\mxcwasnero.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
HiJackThis:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 10:48:31 PM, on 8/9/2010
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\Documents and Settings\Jerome\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1:6522
O2 - BHO: Google Gears Helper - {E0FEFE40-FBF9-42AE-BA58-794CA7E3FB53} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.36.0\gears.dll
O2 - BHO: Street-Ads Browser Enhancer ssxip - {F151F1F5-DE3F-492D-AC95-7ADA9A5B3838} - C:\WINDOWS\system32\ssxip.dll
O4 - HKLM\..\Run: [WINDVDPatch] CTHELPER.EXE
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [Jet Detection] "C:\Program Files\Creative\SBLive\PROGRAM\ADGJDet.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [Hkigovit] rundll32.exe "C:\WINDOWS\oyarediqa.dll",Startup
O4 - HKLM\..\Run: [sta] rundll32 "wsxip.dll",,Run
O4 - HKLM\..\Run: [MChk] C:\WINDOWS\system32\jsxip.exe
O4 - HKCU\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NVMCTRAY.DLL,NvTaskbarInit
O4 - HKCU\..\Run: [cdloader] "C:\Documents and Settings\Jerome\Application Data\mjusbsp\cdloader2.exe" MAGICJACK
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [Tqazipejoxired] rundll32.exe "C:\WINDOWS\pskbd2.dll",Startup
O4 - HKCU\..\Run: [ZE18MW23GY] C:\DOCUME~1\Jerome\LOCALS~1\Temp\Tve.exe
O4 - HKCU\..\RunOnce: [260751743] "C:\DOCUME~1\Jerome\LOCALS~1\APPLIC~1\260751743.exe" 0 45
O4 - HKCU\..\RunOnce: [413023478] "C:\DOCUME~1\Jerome\LOCALS~1\APPLIC~1\413023478.exe" 0 47
O9 - Extra button: (no name) - {09C04DA7-5B76-4EBC-BBEE-B25EAC5965F5} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.36.0\gears.dll
O9 - Extra 'Tools' menuitem: &Gears Settings - {09C04DA7-5B76-4EBC-BBEE-B25EAC5965F5} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.36.0\gears.dll
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - [You must be registered and logged in to see this link.]
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: BCL easyPDF SDK 5 Loader (bepldr) - Unknown owner - C:\Program Files\Common Files\BCL Technologies\easyPDF 5\bepldr.exe
O23 - Service: FLEXnet Licensing Service - Acresso Software Inc. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Forceware Web Interface (ForcewareWebInterface) - Apache Software Foundation - C:\NVIDIA\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: ForceWare IP service (nSvcIp) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: ForceWare user log service (nSvcLog) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcLog.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
End of file - 5776 bytes
Thanks.
GMan316
Posts Posts : 88
Joined Joined : 2009-08-23
OS OS : Windows XP Pro
Points Points : 27670
Re: Security Tool and Antivir Solution Pro
Post by Dr Jay on 10th August 2010, 7:19 pm
Please visit this webpage for a tutorial on downloading and running ComboFix:
See the area: Using ComboFix, and when done, post the log back here.
Posts Posts : 13743
Points Points : 302211
Post by Dr Jay on 18th August 2010, 6:09 am
Still with us? Please let me know how things are going!
Posts Posts : 13743
