Computer is acting way funky (Antivir Solution Pro)
Post by drokness on 5th August 2010, 8:31 pm
This Antivir Solution Pro popped up in my tray and started "scanning" for viruses, ever since I haven't been able to access any of my antivirus software. An "INFILTRATION ALERT" is popping up saying my computer is being attacked. What should I do? I can't currently access my hijack this either.
drokness
Posts Posts : 105
Joined Joined : 2008-12-01
Points Points : 30078
Re: Computer is acting way funky (Antivir Solution Pro)
Post by Belahzur on 5th August 2010, 8:40 pm
Points Points : 245079
Post by drokness on 5th August 2010, 8:44 pm
I downloaded it, but it's not allowing me to access it. A Security Warning pops up and says "Application cannot be executed. The file otl.exe is infected. Do you want to activate your antivirus software now? Yes/No
Edit: Was wondering if I should try a System Restore? If so, where is that again? Sorry, I always forget. Also, a bit afraid to restart my computer at this point in case Windows would not re-open.
drokness
Posts Posts : 105
Post by drokness on 5th August 2010, 11:35 pm
Hi Belazhur. I know you're incredibly busy, so I may have been lost in the shuffle. If not and you just haven't gotten to me yet, please forgive this bump. But should I possibly try the Rkill program? That seems to be the advice given to those suffering from the same problem as me. I greatly appreciate your help.
drokness
Posts Posts : 105
Post by Belahzur on 5th August 2010, 11:47 pm
We need to use the RKill Tool by Grinler
  • Please Download Rkill.com. Save it to your Desktop.
  • Before we begin, you should disable your anti-malware softwares you have installed so they do not interfere RKill running as some anti-malware softwares detect RKill as malicious. Please refer to this [You must be registered and logged in to see this link.] if you are not sure how.
  • NOTE: If you are unable to connect to the site to download rkill, then you should download it to a clean computer and copy it to the infected one via a USB flash drive or CDROM.
  • Once it is downloaded, double-click on the rkill.com in order to automatically attempt to stop any processes associated with Rogue programs.
  • Please be patient while the program looks for various malware programs and ends them.
  • When it has finished, the black window will automatically close and you can continue with the next step.
NOTE: If you get a message that rkill is an infection, do not be concerned. This message is just a fake warning given by the rogue program, when it terminates programs that may potentially remove it. If you run into these infections warnings that close Rkill, a trick is to leave the warning on the screen and then run Rkill again. By not closing the warning, this typically will allow you to bypass the malware trying to protect itself so that rkill can terminate the rogue program. So, please try running Rkill until the malware is no longer running. You will then be able to proceed with the rest of the steps.
If you continue having problems running rkill.com, you can download:
[You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
which are renamed copies of rkill.com, and try them instead.
Try OTL now.
Post by drokness on 5th August 2010, 11:57 pm
Thanks. I was able to download it, but I'm still getting the same Security Alert indicating that it's infected. I also tried the iExplore.exe and eXplorer.exe files, same result.
Edit: Sorry, disregard. Read your previous post more thoroughly, and was able to run it with the security warning up. Sorry about that. Running OTL now, will post when done.
drokness
Posts Posts : 105
Post by drokness on 6th August 2010, 12:06 am
OTL logfile created on: 8/5/2010 7:00:45 PM - Run 1
OTL by OldTimer - Version 3.2.9.1 Folder = C:\Documents and Settings\Daniel Schneider\Desktop
Windows XP Media Center Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
1,023.00 Mb Total Physical Memory | 497.00 Mb Available Physical Memory | 49.00% Memory free
2.00 Gb Paging File | 2.00 Gb Available in Paging File | 65.00% Paging File free
Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
Drive C: | 225.88 Gb Total Space | 11.41 Gb Free Space | 5.05% Space Free | Partition Type: NTFS
Computer Name: WHITETUNDRA
Current User Name: Daniel Schneider
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/08/05 15:42:20 | 000,574,976 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Daniel Schneider\Desktop\OTL.exe
PRC - [2010/07/26 11:23:50 | 000,908,248 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
PRC - [2010/03/24 13:58:22 | 000,309,760 | ---- | M] (ArcSoft Inc.) -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ArcCon.ac
PRC - [2010/03/18 11:19:26 | 000,207,360 | ---- | M] (ArcSoft Inc.) -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
PRC - [2010/03/18 11:19:26 | 000,113,152 | ---- | M] (ArcSoft Inc.) -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
PRC - [2009/10/14 14:36:56 | 002,793,304 | ---- | M] () -- C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe
PRC - [2009/10/14 14:34:18 | 000,560,472 | ---- | M] () -- C:\Program Files\Common Files\LogiShrd\LQCVFX\COCIManager.exe
PRC - [2009/10/07 02:47:34 | 000,154,136 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
PRC - [2009/04/20 16:34:18 | 000,816,904 | ---- | M] (Logitech, Inc.) -- c:\Program Files\Logitech\Logitech WebCam Software\LU\LogitechUpdate.exe
PRC - [2009/04/20 16:34:00 | 000,300,296 | ---- | M] (Logitech, Inc.) -- c:\Program Files\Logitech\Logitech WebCam Software\LU\LULnchr.exe
PRC - [2008/10/15 13:31:53 | 000,068,865 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
PRC - [2008/10/15 13:30:02 | 000,151,297 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
PRC - [2008/09/16 13:03:18 | 000,169,312 | ---- | M] (Adobe Systems Incorporated) -- C:\Program Files\Adobe\Photoshop Elements 7.0\PhotoshopElementsFileAgent.exe
PRC - [2008/09/10 14:01:28 | 000,611,664 | ---- | M] (Lavasoft) -- C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
PRC - [2008/07/07 10:42:06 | 002,156,368 | RHS- | M] (Safer Networking Limited) -- C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
PRC - [2008/06/12 13:28:45 | 000,266,497 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2008/02/20 15:42:38 | 000,161,160 | ---- | M] (Matsushita Electric Industrial Co., Ltd.) -- C:\Program Files\Panasonic\VideoCamSuite\VideoCamSuiteAutoStart.exe
PRC - [2007/11/06 18:04:48 | 000,810,632 | ---- | M] (ExtendMedia Inc.) -- C:\Program Files\OpenCASE\OpenCASE Media Agent\MediaAgent.exe
PRC - [2007/09/05 17:58:44 | 000,188,416 | ---- | M] (Wavexpress, Inc) -- C:\Program Files\Wavexpress\TVTonic\WXRSS.exe
PRC - [2007/08/15 13:19:44 | 001,564,672 | ---- | M] (Belkin) -- C:\Program Files\Belkin\F5D7050v5\Belkinwcui.exe
PRC - [2007/08/09 02:27:52 | 000,073,728 | ---- | M] (HP) -- C:\WINDOWS\system32\HPZipm12.exe
PRC - [2007/06/15 12:57:42 | 000,145,504 | ---- | M] (B.H.A Corporation) -- C:\WINDOWS\system32\bgsvcgen.exe
PRC - [2007/06/14 06:12:55 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2005/03/11 19:55:40 | 000,135,168 | ---- | M] (Sony Corporation) -- C:\Program Files\Common Files\Sony Shared\WMPlugIn\SonicStageMonitoring.exe
PRC - [2005/02/09 12:43:52 | 000,167,936 | ---- | M] (Sony Corporation) -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
PRC - [2005/02/09 12:43:52 | 000,135,168 | ---- | M] (Sony Corporation) -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
PRC - [2005/02/09 12:43:50 | 000,270,336 | ---- | M] (Sony Corporation) -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
PRC - [2005/01/14 16:43:28 | 000,151,552 | ---- | M] (Sony Corporation) -- C:\Program Files\Sony\VAIO Update 2\VAIOUpdt.exe
PRC - [2003/08/13 15:23:00 | 000,106,496 | ---- | M] (Sony Corporation) -- C:\Program Files\Sony\Sony TV Tuner Library\SMceMan.exe
PRC - [2003/08/13 15:07:22 | 000,094,208 | ---- | M] (Sony Corporation) -- C:\Program Files\Sony\Sony TV Tuner Library\RM_SV.exe
MOD - [2010/08/05 15:42:20 | 000,574,976 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Daniel Schneider\Desktop\OTL.exe
MOD - [2008/04/13 19:10:20 | 000,110,592 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msscript.ocx
SRV - [2010/03/18 11:19:26 | 000,113,152 | ---- | M] (ArcSoft Inc.) [Auto | Running] -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe -- (ACDaemon)
SRV - [2010/02/19 19:31:44 | 000,067,360 | ---- | M] (NOS Microsystems Ltd.) [On_Demand | Stopped] -- C:\Program Files\NOS\bin\getPlus_Helper.dll -- (getPlusHelper) getPlus(R)
SRV - [2009/10/07 02:47:34 | 000,154,136 | ---- | M] (Logitech Inc.) [Auto | Running] -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe -- (LVPrcSrv)
SRV - [2008/12/27 15:03:22 | 000,651,720 | ---- | M] (Macrovision Europe Ltd.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe -- (FLEXnet Licensing Service)
SRV - [2008/10/15 13:31:53 | 000,068,865 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe -- (AntiVirScheduler)
SRV - [2008/10/15 13:30:02 | 000,151,297 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe -- (AntiVirService)
SRV - [2008/09/16 13:03:18 | 000,169,312 | ---- | M] (Adobe Systems Incorporated) [Auto | Running] -- C:\Program Files\Adobe\Photoshop Elements 7.0\PhotoshopElementsFileAgent.exe -- (AdobeActiveFileMonitor7.0)
SRV - [2008/09/10 14:01:28 | 000,611,664 | ---- | M] (Lavasoft) [Auto | Running] -- C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe -- (aawservice)
SRV - [2007/11/06 18:04:48 | 000,810,632 | ---- | M] (ExtendMedia Inc.) [Auto | Running] -- C:\Program Files\OpenCASE\OpenCASE Media Agent\MediaAgent.exe -- (OpenCASE Media Agent)
SRV - [2007/09/05 17:58:44 | 000,188,416 | ---- | M] (Wavexpress, Inc) [Auto | Running] -- C:\Program Files\Wavexpress\TVTonic\WXRSS.exe -- (WXRSS)
SRV - [2007/08/09 02:27:52 | 000,073,728 | ---- | M] (HP) [Auto | Running] -- C:\WINDOWS\system32\HPZipm12.exe -- (Pml Driver HPZ12)
SRV - [2007/06/15 12:57:42 | 000,145,504 | ---- | M] (B.H.A Corporation) [Auto | Running] -- C:\WINDOWS\System32\bgsvcgen.exe -- (bgsvcgen)
SRV - [2005/03/11 19:55:40 | 000,135,168 | ---- | M] (Sony Corporation) [Auto | Running] -- C:\Program Files\Common Files\Sony Shared\WMPlugIn\SonicStageMonitoring.exe -- (SonicStageMonitoring)
SRV - [2005/02/14 23:30:02 | 000,032,768 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\Image Converter 2\IcVzMon.exe -- (Image Converter video recording monitor for VAIO Entertainment)
SRV - [2005/02/09 12:43:52 | 000,167,936 | ---- | M] (Sony Corporation) [Auto | Running] -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe -- (VzCdbSvc)
SRV - [2005/02/09 12:43:52 | 000,135,168 | ---- | M] (Sony Corporation) [Auto | Running] -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe -- (VzFw)
SRV - [2005/02/09 12:43:52 | 000,073,728 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCs\VzHardwareResourceManager\VzHardwareResourceManager.exe -- (VAIO Entertainment TV Device Arbitration Service)
SRV - [2005/02/09 12:43:50 | 000,270,336 | ---- | M] (Sony Corporation) [On_Demand | Running] -- C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe -- (Vcsw)
SRV - [2005/01/26 18:30:04 | 000,053,337 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe -- (MSCSPTISRV)
SRV - [2005/01/26 18:25:34 | 000,053,337 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe -- (PACSPTISVR)
SRV - [2005/01/26 18:20:14 | 000,069,718 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe -- (SPTISRV)
SRV - [2005/01/24 20:36:52 | 000,069,632 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe -- (SSScsiSV)
SRV - [2005/01/14 18:18:48 | 001,839,104 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\VAIO Media Integrated Server\VMISrv.exe -- (VAIOMediaPlatform-IntegratedServer-AppServer)
SRV - [2005/01/14 17:26:56 | 000,745,472 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\VAIO Media Integrated Server\Platform\UPnPFramework.exe -- (VAIOMediaPlatform-IntegratedServer-UPnP) VAIO Media Integrated Server (UPnP)
SRV - [2005/01/14 17:21:32 | 000,057,344 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\VAIO Media Integrated Server\Platform\SV_Httpd.exe -- (VAIOMediaPlatform-IntegratedServer-HTTP) VAIO Media Integrated Server (HTTP)
SRV - [2005/01/14 17:20:14 | 000,188,416 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\VAIO Media Integrated Server\Platform\VmGateway.exe -- (VAIOMediaPlatform-Mobile-Gateway)
SRV - [2003/08/13 15:23:00 | 000,106,496 | ---- | M] (Sony Corporation) [Auto | Running] -- C:\Program Files\Sony\Sony TV Tuner Library\SMceMan.exe -- (Sony TVTA Manager)
SRV - [2003/08/13 15:10:04 | 000,118,784 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Sony\Sony TV Tuner Library\halsv.exe -- (Sony TV Tuner Controller)
SRV - [2003/08/13 15:07:22 | 000,094,208 | ---- | M] (Sony Corporation) [On_Demand | Running] -- C:\Program Files\Sony\Sony TV Tuner Library\RM_SV.exe -- (Sony TV Tuner Manager)
DRV - [2009/10/07 03:49:50 | 000,023,832 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvuvcflt.sys -- (FilterService)
DRV - [2009/10/07 03:49:38 | 006,756,632 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\lvuvc.sys -- (LVUVC) Logitech Webcam 500(UVC)
DRV - [2009/10/07 03:47:54 | 000,266,008 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\lvrs.sys -- (LVRS)
DRV - [2009/10/07 02:46:36 | 000,025,752 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LVPr2Mon.sys -- (LVPr2Mon)
DRV - [2009/07/15 10:27:05 | 000,075,096 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avipbb.sys -- (avipbb)
DRV - [2009/07/15 10:17:51 | 000,052,056 | ---- | M] (Avira GmbH) [File_System | On_Demand | Running] -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgntflt.sys -- (avgntflt)
DRV - [2009/07/15 10:17:39 | 000,011,608 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgio.sys -- (avgio)
DRV - [2008/04/13 14:45:12 | 000,060,032 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\USBAUDIO.sys -- (usbaudio) USB Audio Driver (WDM)
DRV - [2008/04/13 13:45:34 | 000,046,592 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\irbus.sys -- (IrBus)
DRV - [2008/04/13 11:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2007/06/01 00:13:20 | 000,238,848 | R--- | M] (Belkin Corporation. ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\BLKWGU.sys -- (BELKIN)
DRV - [2007/03/01 09:34:22 | 000,028,352 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ssmdrv.sys -- (ssmdrv)
DRV - [2006/02/20 19:17:40 | 000,033,408 | ---- | M] (B.H.A Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\cdrbsdrv.sys -- (cdrbsdrv)
DRV - [2004/11/29 19:42:54 | 002,319,808 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2004/09/29 07:22:22 | 000,800,256 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2004/08/12 20:45:52 | 000,113,664 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Hdaudio.sys -- (HdAudAddService)
DRV - [2004/08/05 23:20:34 | 000,788,736 | ---- | M] (Sony Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\smrt.sys -- (smrt)
DRV - [2004/06/29 09:07:18 | 001,268,204 | ---- | M] (Agere Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AGRSM.sys -- (AgereSoftModem)
DRV - [2001/08/17 08:57:38 | 000,016,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\MODEMCSA.sys -- (MODEMCSA)
DRV - [2000/12/05 19:18:02 | 000,003,952 | ---- | M] (Sony Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\DMICall.sys -- (DMICall)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Google
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultURL = [You must be registered and logged in to see this link.]
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:6522
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Google"
FF - prefs.js..browser.search.defaulturl: "http://www.google.com/search?lr=&ie=UTF-8&oe=UTF-8&q="
FF - prefs.js..browser.search.selectedEngine: "Google"
FF - prefs.js..extensions.enabledItems: {E2883E8F-472F-4fb0-9522-AC9BF37916A7}:1.6.2.63
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:4.0.15.0
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:7
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.11\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/07/28 17:56:15 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.11\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/07/26 11:24:12 | 000,000,000 | ---D | M]
[2008/12/06 14:10:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Extensions
[2010/08/05 15:37:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions
[2010/05/04 22:10:36 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2010/07/30 19:15:13 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
[2010/03/18 15:02:39 | 000,000,000 | ---D | M] (Adobe DLM (powered by getPlus(R))) -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\{E2883E8F-472F-4fb0-9522-AC9BF37916A7}
[2009/05/06 13:42:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\battlefieldheroespatcher@ea.com
[2010/08/05 13:13:35 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2007/12/06 13:40:12 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Program Files\Mozilla Firefox\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
O1 HOSTS File: ([2009/02/22 10:12:44 | 000,000,029 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (Skype add-on (mastermind)) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O2 - BHO: (SpywareGuardDLBLOCK.CBrowserHelper) - {4A368E80-174F-4872-96B5-0B27DDD11DB2} - C:\Program Files\SpywareGuard\dlprotect.dll ()
O2 - BHO: (Spybot-S&D IE Protection) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O2 - BHO: (Java(tm) Plug-In SSV Helper) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (no name) - {9E3DCAB2-1B63-44D9-AF91-7751CB9F605B} - No CLSID value found.
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (no name) - - No CLSID value found.
O3 - HKCU\..\Toolbar\ShellBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O4 - HKLM..\Run: [ArcSoft Connection Service] C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe (ArcSoft Inc.)
O4 - HKLM..\Run: [avgnt] C:\Program Files\Avira\AntiVir PersonalEdition Classic\avgnt.exe (Avira GmbH)
O4 - HKLM..\Run: [CreateCD_Reminder] C:\WINDOWS\SONYSYS\VAIO Recovery\Reminder.exe (Sony Electronics, Inc)
O4 - HKLM..\Run: [High Definition Audio Property Page Shortcut] C:\WINDOWS\System32\Hdaudpropshortcut.exe (Windows (R) Server 2003 DDK provider)
O4 - HKLM..\Run: [LogitechQuickCamRibbon] C:\Program Files\Logitech\Logitech WebCam Software\LWS.exe ()
O4 - HKLM..\Run: [VAIO Update 2] C:\Program Files\Sony\VAIO Update 2\VAIOUpdt.exe (Sony Corporation)
O4 - HKCU..\Run: [EA Core] C:\Program Files\Electronic Arts\EA Link\Core.exe (Electronic Arts)
O4 - HKCU..\Run: [Logitech Vid] C:\Program Files\Logitech\Logitech Vid\Vid.exe (Logitech Inc.)
O4 - HKCU..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe (Safer Networking Limited)
O4 - HKCU..\Run: [updateMgr] C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe File not found
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Auto run of VideoCam Suite 1.0.lnk = C:\Program Files\Panasonic\VideoCamSuite\VideoCamSuiteAutoStart.exe (Matsushita Electric Industrial Co., Ltd.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Belkin Wireless G USB Adapter Client Utility.lnk = C:\Program Files\Belkin\F5D7050v5\Belkinwcui.exe (Belkin)
O4 - Startup: C:\Documents and Settings\Daniel Schneider\Start Menu\Programs\Startup\SpywareGuard.lnk = C:\Program Files\SpywareGuard\sgmain.exe ()
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallVisualStyle = C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles (Microsoft)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallTheme = C:\WINDOWS\Resources\Themes\Royale.theme ()
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files\Microsoft Office\Office10\EXCEL.EXE (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O9 - Extra Button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O9 - Extra 'Tools' menuitem : Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O9 - Extra Button: PartyPoker.net - {F4430FE8-2638-42e5-B849-800749B94EED} - C:\Program Files\PartyGaming.Net\PartyPokerNet\RunPF.exe ()
O9 - Extra 'Tools' menuitem : PartyPoker.net - {F4430FE8-2638-42e5-B849-800749B94EED} - C:\Program Files\PartyGaming.Net\PartyPokerNet\RunPF.exe ()
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} [You must be registered and logged in to see this link.] (Facebook Photo Uploader 5)
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} [You must be registered and logged in to see this link.] (Windows Genuine Advantage Validation Tool)
O16 - DPF: {31435657-9980-0010-8000-00AA00389B71} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {4E73C07D-0A23-42DF-9E32-BBBB027D869A} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} [You must be registered and logged in to see this link.] (DivXBrowserPlugin Object)
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_11)
O16 - DPF: {CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_11)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_11)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.0.1
O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files\Common Files\Skype\Skype4COM.dll (Skype Technologies)
O20 - HKLM Winlogon: Shell - (Explorer.exe) - Explorer.exe ()
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
O20 - Winlogon\Notify\igfxcui: DllName - igfxsrvc.dll - C:\WINDOWS\System32\igfxsrvc.dll (Intel Corporation)
O20 - Winlogon\Notify\opnlICSl: DllName - Reg Error: Value error. - Reg Error: Value error. File not found
O24 - Desktop WallPaper: C:\WINDOWS\VAIO Structure Wallpaper TrueColor 1024x768.bmp
O24 - Desktop BackupWallPaper: C:\WINDOWS\VAIO Structure Wallpaper TrueColor 1024x768.bmp
O28 - HKLM ShellExecuteHooks: {81559C35-8464-49F7-BB0E-07A383BEF910} - C:\Program Files\SpywareGuard\spywareguard.dll ()
O29 - HKLM SecurityProviders - (mcenspc.dll) - File not found
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2005/02/23 15:12:17 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O34 - HKLM BootExecute: (lsdelete) - C:\WINDOWS\System32\lsdelete.exe ()
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
[2010/08/05 15:42:19 | 000,574,976 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Daniel Schneider\Desktop\OTL.exe
[2010/08/05 15:21:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Daniel Schneider\Local Settings\Application Data\yqrjmxuqi
[2010/07/29 21:00:56 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Daniel Schneider\My Documents\CRACKEDSTUFF
[2010/07/23 23:35:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Daniel Schneider\My Documents\Downloads
[2010/07/13 15:47:45 | 000,744,448 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\dllcache\helpsvc.exe
[8 C:\Documents and Settings\Daniel Schneider\My Documents\*.tmp files -> C:\Documents and Settings\Daniel Schneider\My Documents\*.tmp -> ]
[4 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[2010/08/05 18:54:57 | 000,363,520 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\Desktop\eXplorer.exe
[2010/08/05 18:54:34 | 000,363,520 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\Desktop\iExplore.exe
[2010/08/05 18:50:40 | 000,363,520 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\Desktop\rkill.com
[2010/08/05 18:23:00 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/08/05 11:32:00 | 000,000,314 | ---- | M] () -- C:\WINDOWS\tasks\WebReg psc 1600 series.job
[2010/08/04 19:23:01 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/08/04 08:22:18 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/08/04 03:22:35 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/08/04 03:22:28 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/08/04 03:22:26 | 1072,480,256 | -HS- | M] () -- C:\hiberfil.sys
[2010/08/04 03:22:23 | 000,000,000 | ---- | M] () -- C:\WINDOWS\System32\drivers\lvuvc.hs
[2010/08/04 03:22:12 | 000,000,000 | ---- | M] () -- C:\WINDOWS\System32\drivers\logiflt.iad
[2010/08/04 03:20:49 | 004,980,736 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\ntuser.dat
[2010/08/04 03:20:11 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Daniel Schneider\ntuser.ini
[2010/08/02 23:36:13 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/08/02 18:00:51 | 000,002,137 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/07/27 01:30:35 | 008,462,336 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\System32\dllcache\shell32.dll
[2010/07/23 23:35:37 | 000,029,569 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\My Documents\middle-finger.jpg
[2010/07/15 13:29:10 | 000,022,528 | ---- | M] () -- C:\Documents and Settings\Daniel Schneider\My Documents\f***.doc
[2010/07/15 03:00:58 | 000,000,628 | ---- | M] () -- C:\WINDOWS\win.ini
[2010/07/14 03:13:45 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/08/05 18:54:56 | 000,363,520 | ---- | C] () -- C:\Documents and Settings\Daniel Schneider\Desktop\eXplorer.exe
[2010/08/05 18:54:34 | 000,363,520 | ---- | C] () -- C:\Documents and Settings\Daniel Schneider\Desktop\iExplore.exe
[2010/08/05 18:50:39 | 000,363,520 | ---- | C] () -- C:\Documents and Settings\Daniel Schneider\Desktop\rkill.com
[2010/07/23 23:35:34 | 000,029,569 | ---- | C] () -- C:\Documents and Settings\Daniel Schneider\My Documents\middle-finger.jpg
[2010/07/15 13:29:09 | 000,022,528 | ---- | C] () -- C:\Documents and Settings\Daniel Schneider\My Documents\f***.doc
[2009/11/29 17:53:02 | 000,082,289 | ---- | C] () -- C:\WINDOWS\System32\lvcoinst.ini
[2009/10/07 02:46:36 | 000,025,752 | ---- | C] () -- C:\WINDOWS\System32\drivers\LVPr2Mon.sys
[2009/10/07 02:23:08 | 000,013,584 | ---- | C] () -- C:\WINDOWS\System32\drivers\iKeyLFT2.dll
[2008/12/05 22:24:27 | 000,116,224 | ---- | C] () -- C:\WINDOWS\System32\pdfmonnt.dll
[2008/12/05 22:24:25 | 000,000,164 | ---- | C] () -- C:\WINDOWS\System32\psconv.ini
[2008/09/02 14:57:09 | 000,013,768 | ---- | C] () -- C:\WINDOWS\System32\drivers\string.ini
[2007/09/13 20:24:18 | 000,139,128 | ---- | C] () -- C:\WINDOWS\System32\drivers\PnkBstrK.sys
[2005/10/16 23:54:07 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
[2005/08/09 17:13:31 | 000,831,488 | ---- | C] () -- C:\WINDOWS\System32\libeay32.dll
[2005/08/09 17:13:31 | 000,159,744 | ---- | C] () -- C:\WINDOWS\System32\ssleay32.dll
[2005/08/09 17:12:28 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
[2005/05/20 17:51:03 | 000,002,158 | ---- | C] () -- C:\WINDOWS\System32\ssmute.ini
[2005/05/20 17:48:20 | 000,204,800 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeW7.dll
[2005/05/20 17:48:20 | 000,200,704 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeA6.dll
[2005/05/20 17:48:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeP6.dll
[2005/05/20 17:48:20 | 000,192,512 | ---- | C] () -- C:\WINDOWS\System32\IVIresizeM6.dll
[2005/05/20 17:48:20 | 000,188,416 | ---- | C] () -- C:\WINDOWS\System32\IVIresizePX.dll
[2005/05/20 17:48:20 | 000,020,480 | ---- | C] () -- C:\WINDOWS\System32\IVIresize.dll
[2005/05/20 17:47:34 | 000,000,598 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2005/05/20 17:42:11 | 000,019,968 | ---- | C] () -- C:\WINDOWS\System32\Cpuinf32.dll
[2005/02/23 17:44:38 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2005/02/23 17:18:09 | 000,156,672 | ---- | C] () -- C:\WINDOWS\System32\RTLCPAPI.dll
[2005/02/23 16:35:48 | 000,000,000 | ---- | C] () -- C:\WINDOWS\VAIOUpdt.INI
[2005/02/23 15:17:15 | 000,000,811 | ---- | C] () -- C:\WINDOWS\orun32.ini
[2005/02/23 13:58:33 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\e100bmsg.dll
[2005/02/23 13:57:37 | 000,000,762 | ---- | C] () -- C:\WINDOWS\System32\oeminfo.ini
[2005/01/18 13:31:00 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
[2002/06/12 15:21:12 | 000,049,152 | R--- | C] () -- C:\WINDOWS\System32\winchip.dll
[2001/10/24 19:00:40 | 000,524,288 | ---- | C] () -- C:\WINDOWS\System32\TDI-SonyOMG.dll
drokness
Posts Posts : 105
Post by drokness on 6th August 2010, 12:07 am
OTL Extras logfile created on: 8/5/2010 7:00:45 PM - Run 1
File Age = 30 Days
Output = Standard
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [edit] -- "C:\Program Files\Microsoft Office\Office10\msohtmed.exe" %1 (Microsoft Corporation)
htmlfile [print] -- "C:\Program Files\Microsoft Office\Office10\msohtmed.exe" /p %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [Scan with SpySubtract...] -- "C:\Program Files\InterMute\SpySubtract\SpySub.exe" "-sc" "%1" (InterMute, Inc.)
"FirstRunDisabled" = 1
"AntiVirusDisableNotify" = 1
"FirewallDisableNotify" = 1
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"DisableMonitoring" = 1
"EnableFirewall" = 1
"DoNotAllowExceptions" = 0
"DisableNotifications" = 0
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"139:TCP" = 139:TCP:LocalSubNet:Disabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Disabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Disabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Disabled:@xpsp2res.dll,-22002
"C:\Program Files\TESTOUT\Cmi\Navigator.exe" = C:\Program Files\TESTOUT\Cmi\Navigator.exe:*:Disabled:TestOut Navigator -- File not found
"C:\Program Files\EA GAMES\Battlefield 2\BF2.exe" = C:\Program Files\EA GAMES\Battlefield 2\BF2.exe:*:Enabled:Battlefield 2 -- ()
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- File not found
"C:\Program Files\Adobe\Photoshop Elements 7.0\AdobePhotoshopElementsMediaServer.exe" = C:\Program Files\Adobe\Photoshop Elements 7.0\AdobePhotoshopElementsMediaServer.exe:*:Disabled:Adobe Photoshop Elements Media Server -- (Adobe Systems Incorporated)
"C:\Program Files\GameSpy Arcade\Aphex.exe" = C:\Program Files\GameSpy Arcade\Aphex.exe:*:Enabled:GameSpy Arcade -- (IGN Entertainment, Inc.)
"C:\Documents and Settings\Daniel Schneider\Local Settings\Temp\7zS9.tmp\SymNRT.exe" = C:\Documents and Settings\Daniel Schneider\Local Settings\Temp\7zS9.tmp\SymNRT.exe:*:Enabled:Norton Removal Tool -- File not found
"C:\Program Files\Electronic Arts\Battlefield Bad Company 2 - BETA\BFBC2BetaUpdater.exe" = C:\Program Files\Electronic Arts\Battlefield Bad Company 2 - BETA\BFBC2BetaUpdater.exe:*:Enabled:Battlefield Bad Company 2 - BETA -- File not found
"C:\Program Files\Logitech\Logitech Vid\Vid.exe" = C:\Program Files\Logitech\Logitech Vid\Vid.exe:*:Enabled:Logitech Vid -- (Logitech Inc.)
"{013E1BA8-C815-4E27-BCB9-D6B1B2E24094}" = SonicStage Mastering Studio Audio Filter Custom Preset
"{01FDC9FC-4D4F-4DB0-ACD1-D3E8E1D52902}" = Sony MP4 Shared Library
"{04858915-9F49-4B2A-AED4-DC49A7DE6A7B}" = Battlefield 2(TM)
"{0BEDBD4E-2D34-47B5-9973-57E62B29307C}" = ATI Control Panel
"{0DC86BEC-5CE3-413A-BB61-C40A3D186B24}" = Scan
"{0FF18B53-CA57-40BB-B562-21A27B662005}" = 1600
"{14BEB6DF-A499-4A38-8E06-E173BCD5C087}" = ScannerCopy
"{17293791-C82E-476C-9997-9A0FF234A19B}" = HP Product Assistant
"{1771FDC8-D846-4B77-996A-C80DAD42C03F}" = OpenCASE Media Agent
"{181821B7-82AA-44DA-9DAF-EF254CCB670A}" = Fax
"{18D10072035C4515918F7E37EAFAACFC}" = AutoUpdate
"{1AD5F465-8282-4DAD-B957-E09C0B783D18}" = InstantShare
"{1B680FBA-E317-4E93-AF43-3B59798A4BE0}" = Copy
"{1BEF9285-5530-426B-A5F1-5836B95C7EB1}" = VAIO Original Screen Saver
"{1EB317D8-8945-4FD6-B37F-DF470317C6AB}" = VAIO Media 4.0
"{2063C2E8-3812-4BBD-9998-6610F80C1DD4}" = VAIO Media AC3 Decoder 1.0
"{20FBC0A0-3160-4F14-83ED-3A74BB6B8C31}" = TrayApp
"{26A24AE4-039D-4CA4-87B4-2F83216011FF}" = Java(TM) 6 Update 11
"{272EC8BA-5A08-4ea1-A189-684466A06B02}" = cp_dwShrek2Albums1
"{27337663-2619-11D4-99DC-0000F49094C7}" = Memory Stick Formatter
"{287ECFA4-719A-2143-A09B-D6A12DE54E40}" = Acrobat.com
"{2E8428AD-6CD2-4031-916A-3CF9BBF2DEC9}" = Unload
"{2F151B50-B434-4838-B51D-70442EBA093E}" = OpenMG Secure Module 4.1.00
"{315BA29D-2644-4760-B5FD-5AC04A52B8C5}" = VAIO Registration
"{318AB667-3230-41B5-A617-CB3BF748D371}" = iTunes
"{342C7C88-D335-4bc2-8CF1-281857629CE2}" = HP PSC & OfficeJet 4.7
"{3762DB2D-71BD-421F-9E55-C74DA7DF4D07}" = CueTour
"{391E18CE-7D3B-45E9-A8F0-34E77F14F47A}" = ProductContext
"{40D1BC4F-56CB-458E-BE8C-35A025CC52FB}" = Sony TV Tuner Library 1.0
"{416D80BA-6F6D-4672-B7CF-F54DA2F80B44}" = Microsoft Works
"{442BE28B-782B-4DC0-B490-E70A403B1C69}" = Readme
"{48820099-ED7D-424B-890C-9A82EF00656D}" = VAIO Update 2
"{49FC50FC-F965-40D9-89B4-CBFF80941033}" = Windows Movie Maker 2.0
"{4E993095-28F2-4060-9101-99C1FD1195C0}" = VAIO Control Center
"{4FBCEA31-5D18-4212-9231-DE7CF1BE7DBB}" = Logitech Vid
"{50D4CB89-AF34-4978-96DC-C3034062E901}" = Battlefield 2: Special Forces
"{51735133-A296-4EB0-BF16-AD93B55BD000}" = VAIO Original Screen Saver VAIO Motion SD Wide Contents
"{541DEAC0-5F3D-45E6-B7CB-94ECF3B96748}" = Skype web features
"{542CDB83-3599-48B6-9C84-7F56CEF0D2B0}" = TVTonic
"{5E8D588F-307C-4250-B622-26969027319A}" = PanoStandAlone
"{5F638781-7754-411F-974C-F20F27292E24}" = VideoCam Suite
"{63569CE9-FA00-469C-AF5C-E5D4D93ACF91}" = Windows Genuine Advantage v1.3.0254.0
"{644D04A2-C682-4FD5-977D-03B804C4B9C5}" = CreativeProjects
"{646A65DD-23FC-418E-B9F0-E0500FB42CB1}" = PhotoGallery
"{655CB07D-C944-40BE-B93F-55957CAC7625}" = AiO_Scan
"{685BCC47-B8EC-45EC-BBCE-77DF2451502C}" = DVgate Plus
"{68963635-14A4-48D9-B431-DF3A74D1AAE1}" = Destinations
"{700A6597-3CE6-49C1-AA75-846B24CDA66D}" = BufferChm
"{7128C69B-8F7E-4336-8698-3FD3CDD955EC}" = VAIO Media Redistribution 4.0
"{724517BD-1DE1-4986-BFCA-C1DFD379E3BC}" = cp_dwShrek2Cards1
"{78D62D17-D970-42DA-B8CF-5E5576293B33}" = Final Draft 7
"{7A79D11B-FD82-4A5E-834F-20173515DD14}" = VAIO Media Integrated Server 4.1
"{7AD25C9F-9957-4D1C-95EF-9BCD09F6D31B}" = HPSystemDiagnostics
"{7B63B2922B174135AFC0E1377DD81EC2}" = DivX
"{7CDC26F7-D6BF-442A-B599-0075A48310F7}" = SA32xx Device Manager
"{80EE18E6-F16C-11D4-8BE8-006097C9A3ED}" = ISScript
"{84CDF5A8-1D57-4B69-BAB6-1F11D8923375}" = SkinsHP1
"{85AF94EC-55DE-452A-8FD7-C34E598B3F1F}" = Adobe Premiere Elements 7.0 Templates
"{85CFD253-38AE-4DB1-ACB7-F0F4C791990D}" = AiOSoftware
"{8777AC6D-89F9-4793-8266-DE406F343E89}" = QFolder
"{88DA0A52-3372-4803-971A-ADFB961707E8}" = PictureGear Studio 2.0
"{8A25392D-C5D2-4E79-A2BD-C15DDC5B0959}" = Bonjour
"{8A708DD8-A5E6-11D4-A706-000629E95E20}" = Intel(R) Graphics Media Accelerator Driver
"{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
"{8BC3B99B-A6BE-4A0B-8535-B1B94BA4B1B1}" = DocProc
"{8D8B167A-ED0F-43F1-AC10-3F4379F7CBBB}" = ArcSoft MediaConverter 2.5
"{91110409-6000-11D3-8CFE-0050048383C9}" = Microsoft Office XP Professional
"{9155A84B-A94B-496E-9661-9978EB0CBC7C}" = Image Converter 2
"{91810AFC-A4F8-4EBA-A5AA-B198BBC81144}" = InterVideo WinDVD for VAIO
"{9541FED0-327F-4DF0-8B96-EF57EF622F19}" = Sonic RecordNow!
"{9941F0AA-B903-4AF4-A055-83A9815CC011}" = Sonic Encoders
"{9B953606-000E-491C-B74D-78ECFDD520A0}" = OpenMG Metadata Extractor for Windows Media Player
"{9E407618-D9CD-4F39-9490-9ED45294073D}" = Click to DVD 2.0.03 Menu Data
"{9EDF1A5D-D8E0-413E-9782-75DD4A8C831B}" = VideoCam Suite 1.0
"{A0EB195B-5876-48E6-879D-33D4B2102610}" = SonicStage 3.0
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A5B9D22C-755A-4AC6-9904-875E80838BB6}" = CP_AtenaShokunin1Config
"{AC76BA86-7AD7-1033-7B44-A91000000001}" = Adobe Reader 9.1.2
"{AC76BA86-7AD7-5464-3428-900000000004}" = Spelling Dictionaries Support For Adobe Reader 9
"{AEB9948B-4FF2-47C9-990E-47014492A0FE}" = MSXML 6.0 Parser
"{AF9A04EB-7D8E-41DE-9EDE-4AB9BB2B71B6}" = VAIO Media Registration Tool 4.0
"{AFBBF30D-ADA9-4313-464E-14458B6BE034}" = PhotoshopdotcomInspirationBrowser
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{B6ACFF51-248A-4290-B50B-E50C81F25B97}" = iPod for Windows 2005-02-22
"{B7050CBDB2504B34BC2A9CA0A692CC29}" = DivX Web Player
"{B911B811-BA3E-46D4-90F8-6F3338359651}" = Director
"{BD29EBAC-AD7D-4b27-B727-4CC6AC52D36B}" = MarketResearch
"{BD57EA4D-026E-4F08-9B93-080E282B81FE}" = iPod for Windows 2006-06-28
"{BE56FEF0-1A0F-4719-B3AD-34B5087AFA6D}" = Sony Video Shared Library
"{C27BC2A2-30DD-4014-B22E-63EB0DB572F9}" = Logitech Webcam Software
"{C91EF330-F152-44ED-A33A-0F4FF3FAF813}" = NBC Direct Beta
"{CB449D5A-7710-47aa-B9F5-352B877C90E6}" = 1600_Help
"{CB6075D9-F912-40AE-BEA6-E590DA24F16B}" = Adobe Photoshop Elements 7.0
"{CDFCF124-115F-4976-8BF4-08C89187A146}" = WebReg
"{CE0C8CC5-E396-442B-A50E-D1D374A9E820}" = DocumentViewer
"{D0448678-1203-4158-A58F-B3D0B616BF9E}" = Sony Certificate PCH
"{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.1
"{D564B5E2-CCB5-4A5C-B35E-2FC30BBC9336}" = Adobe Premiere Elements 7.0
"{D593C72C-435B-4171-8106-9CA8AA34D716}" = Belkin Wireless G USB Adapter Software
"{D917FD82-6CE5-489A-AAF8-C701AAC85C4D}" = VAIO Entertainment Platform
"{DC6E3CD5-A93D-44EA-85AE-894C1603B7E2}" = VAIO TV Tuner Library 1.4
"{DED53B0B-B67C-4244-AE6A-D6FD3C28D1EF}" = Ad-Aware
"{E09B48B5-E141-427A-AB0C-D3605127224A}" = Microsoft SQL Server Desktop Engine (VAIO_VEDB)
"{E2883E8F-472F-4fb0-9522-AC9BF37916A7}" = Adobe Download Manager
"{E715FA41-46EB-4D3F-B4D9-A45973E76026}" = VAIO Structure Wallpaper
"{E809063C-51A3-4269-8984-D1EB742F2151}" = Click to DVD 2.4.02
"{EC4455AB-F155-4CC1-A4C5-88F3777F9886}" = Apple Mobile Device Support
"{F4C6CC40-1142-49be-A28C-7BBD36F0B41A}" = 1600Trb
"{F5577101-33CC-4711-8235-3A95BCD49DB0}" = EA Link
"{F6234880-85BE-4DCB-8A45-1FF85A1A8552}" = SmartSound Quicktracks for Premiere Elements
"{F958CA02-BB40-4007-894B-258729456EE4}" = QuickTime
"{FA11D5B5-7D0A-43E8-88C4-960F97B194DE}" = VAIO Survey Standalone
"{FC22D020-3005-4715-8DF9-F3EDE81DEB3D}" = CreativeProjectsTemplates
"{FE57DE70-95DE-4B64-9266-84DA811053DB}" = HP Update
"AC3Filter" = AC3Filter (remove only)
"ActiveXControlPad" = Microsoft ActiveX Control Pad
"Adobe AIR" = Adobe AIR
"Adobe Flash Player ActiveX" = Adobe Flash Player ActiveX
"Adobe Photoshop Elements 7" = Adobe Photoshop Elements 7.0
"Agere Systems Soft Modem" = Agere Systems PCI Soft Modem
"All ATI Software" = ATI - Software Uninstall Utility
"AntiVir PersonalEdition Classic" = Avira AntiVir Personal - Free Antivirus
"ATI Display Driver" = ATI Display Driver
"CONNECT" = CONNECT
"ExpressBurn" = Express Burn Uninstall
"Free PS Convert driver_is1" = Free PS Convert driver 8.15
"GameSpy Arcade" = GameSpy Arcade
"HijackThis" = HijackThis 2.0.2
"HP Photo & Imaging" = HP Image Zone 4.7
"HPExtendedCapabilities" = HP Extended Capabilities 4.7
"ie7" = Windows Internet Explorer 7
"InstallShield_{2F151B50-B434-4838-B51D-70442EBA093E}" = OpenMG Secure Module 4.1.00
"InstallShield_{315BA29D-2644-4760-B5FD-5AC04A52B8C5}" = VAIO Registration
"InstallShield_{B6ACFF51-248A-4290-B50B-E50C81F25B97}" = iPod for Windows 2005-02-22
"InstallShield_{BD57EA4D-026E-4F08-9B93-080E282B81FE}" = iPod for Windows 2006-06-28
"InstallShield_{F5577101-33CC-4711-8235-3A95BCD49DB0}" = EA Link
"InstallShield_{F6234880-85BE-4DCB-8A45-1FF85A1A8552}" = SmartSound Quicktracks for Premiere Elements
"InstallShield_{FA11D5B5-7D0A-43E8-88C4-960F97B194DE}" = VAIO Survey Standalone
"InterActual Player" = InterActual Player
"IrfanView" = IrfanView (remove only)
"lvdrivers_12.10" = Logitech Webcam Software Driver Package
"MoodLogic" = MoodLogic
"Movielink eHome_is1" = Movielink eHome version 1.1
"Mozilla Firefox (3.5.11)" = Mozilla Firefox (3.5.11)
"Netscape Online Setup" = Netscape Internet Service Setup
"OpenMG HotFix4.1-05-13-31-01" = OpenMG Limited Patch 4.1-05-13-31-01
"PartyPokerNet" = PartyPokerNet
"PhotoshopdotcomInspirationBrowser.4C35C4D325D350FE0114230CBADCA2DDD0AC8D25.1" = Adobe Photoshop.com Inspiration Browser
"PremElem70" = Adobe Premiere Elements 7.0
"PremElem70Templates" = Adobe Premiere Elements 7.0 Templates
"PROSet" = Intel(R) PRO Network Adapters and Drivers
"PunkBusterSvc" = PunkBuster Services
"ShockwaveFlash" = Adobe Flash Player 9 ActiveX
"SpySubtract" = SpySubtract
"SpywareGuard_is1" = SpywareGuard v2.2
"V CAST Music with Rhapsody" = V CAST Music with Rhapsody
"WavePad" = WavePad Uninstall
"Windows Media Format Runtime" = Windows Media Format Runtime
"Word to PDF Converter_is1" = Word to PDF Converter 3.00
"Move Media Player" = Move Media Player
[ Application Events ]
Error - 7/27/2010 4:42:35 AM | Computer Name = WHITETUNDRA | Source = Media Center Guide | ID = 0
Description = Event Info: Unable to initialize connection to the database. Process:
DefaultDomain Object Name: Media Center Guide
Error - 8/3/2010 4:46:04 AM | Computer Name = WHITETUNDRA | Source = Media Center Scheduler | ID = 0
Description =
Error - 8/3/2010 4:46:05 AM | Computer Name = WHITETUNDRA | Source = Media Center Scheduler | ID = 0
Description =
Error - 8/3/2010 4:46:19 AM | Computer Name = WHITETUNDRA | Source = Media Center Guide | ID = 0
Description = Event Info: TitleQuery: DoQuery Error Process: DefaultDomain Object
Error - 8/3/2010 4:46:20 AM | Computer Name = WHITETUNDRA | Source = Media Center Scheduler | ID = 0
Description =
Description =
Error - 8/3/2010 4:46:21 AM | Computer Name = WHITETUNDRA | Source = Media Center Guide | ID = 0
Description = Event Info: Unexpected exception in QueryWorker.DoQuery() Process:
DefaultDomain Object Name: Microsoft.Ehome.Epg.Query.TitleQuery
Error - 8/4/2010 9:32:01 AM | Computer Name = WHITETUNDRA | Source = MsiInstaller | ID = 11001
Description =
Error - 8/4/2010 8:21:58 PM | Computer Name = WHITETUNDRA | Source = Application Error | ID = 1000
Description = Faulting application final draft.exe, version 7.1.2.34, faulting module
final draft.exe, version 7.1.2.34, fault address 0x00255aa3.
Error - 8/5/2010 4:22:43 PM | Computer Name = WHITETUNDRA | Source = Application Error | ID = 1000
Description = Faulting application firefox.exe, version 1.9.1.3834, faulting module
icucnv36.dll, version 3.6.0.0, fault address 0x000013df.
[ Media Center Events ]
Error - 5/23/2009 4:40:24 AM | Computer Name = WHITETUNDRA | Source = Recording | ID = 19
Description = The recording schedule has been corrupted and was automatically deleted
on 5/23/2009 3:40:24 AM. You may need to reschedule your recordings.
Error - 5/26/2009 7:53:07 PM | Computer Name = WHITETUNDRA | Source = Recording | ID = 19
on 5/26/2009 6:53:07 PM. You may need to reschedule your recordings.
Error - 9/5/2009 4:40:27 AM | Computer Name = WHITETUNDRA | Source = Recording | ID = 19
on 9/5/2009 3:40:26 AM. You may need to reschedule your recordings.
[ System Events ]
Error - 7/14/2010 9:58:27 PM | Computer Name = WHITETUNDRA | Source = Service Control Manager | ID = 7000
Description = The MCSTRM service failed to start due to the following error: %%2
Error - 7/22/2010 8:27:15 PM | Computer Name = WHITETUNDRA | Source = Service Control Manager | ID = 7000
Error - 7/24/2010 8:38:11 PM | Computer Name = WHITETUNDRA | Source = W32Time | ID = 39452689
Description = Time Provider NtpClient: An error occurred during DNS lookup of the
manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup
again in 15 minutes. The error was: A socket operation was attempted to an unreachable
host. (0x80072751)
Error - 7/24/2010 8:38:11 PM | Computer Name = WHITETUNDRA | Source = W32Time | ID = 39452701
Description = The time provider NtpClient is configured to acquire time from one
or more time sources, however none of the sources are currently accessible. No attempt
to contact a source will be made for 14 minutes. NtpClient has no source of accurate
time.
Error - 7/24/2010 8:38:13 PM | Computer Name = WHITETUNDRA | Source = W32Time | ID = 39452689
host. (0x80072751)
Error - 7/24/2010 8:38:13 PM | Computer Name = WHITETUNDRA | Source = W32Time | ID = 39452701
to contact a source will be made for 15 minutes. NtpClient has no source of accurate
time.
Error - 8/4/2010 4:23:05 AM | Computer Name = WHITETUNDRA | Source = Service Control Manager | ID = 7000
Error - 8/5/2010 4:55:01 PM | Computer Name = WHITETUNDRA | Source = DCOM | ID = 10010
Description = The server {781B925F-0BF8-4C7B-A2A8-A8B11B488A07} did not register
with DCOM within the required timeout.
Error - 8/5/2010 5:09:02 PM | Computer Name = WHITETUNDRA | Source = DCOM | ID = 10010
Error - 8/5/2010 6:54:06 PM | Computer Name = WHITETUNDRA | Source = DCOM | ID = 10010
drokness
Posts Posts : 105
Post by Belahzur on 6th August 2010, 7:45 pm
    In Internet Explorer
    In Firefox
Please run OTL.exe.
    :OTL
  • Close OTL.exe
Post by drokness on 6th August 2010, 7:56 pm
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9E3DCAB2-1B63-44D9-AF91-7751CB9F605B}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9E3DCAB2-1B63-44D9-AF91-7751CB9F605B}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\opnlICSl\ deleted successfully.
C:\Documents and Settings\Daniel Schneider\Local Settings\Application Data\yqrjmxuqi folder moved successfully.
OTL by OldTimer - Version 3.2.9.1 log created on 08062010_145241
drokness
Posts Posts : 105
Joined Joined : 2008-12-01
Points Points : 30078
Re: Computer is acting way funky (Antivir Solution Pro)
Post by Belahzur on 6th August 2010, 8:12 pm
Post by drokness on 6th August 2010, 8:42 pm
Database version: 4400
8/6/2010 3:41:53 PM
mbam-log-2010-08-06 (15-41-53).txt
Scan type: Quick scan
Objects scanned: 170423
Time elapsed: 18 minute(s), 10 second(s)
Registry Keys Infected: 5
Files Infected: 2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\CONNECT (Trojan.PornDialer) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\CrucialSoft Ltd (Rogue.MSAntiSpyware) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\UAC (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\SolutionAV (Rogue.AntivirSolutionPro) -> Quarantined and deleted successfully.
C:\Documents and Settings\Daniel Schneider\Local Settings\Temporary Internet Files\Content.IE5\M1F4B9NB\5fb5ad[1].exe (Rogue.AntivirSolutionPro) -> Quarantined and deleted successfully.
C:\Documents and Settings\Daniel Schneider\Desktop\eXplorer.exe (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
drokness
Posts Posts : 105
Post by drokness on 7th August 2010, 5:51 pm
So am I in the clear?
drokness
Posts Posts : 105
Post by Belahzur on 7th August 2010, 5:52 pm
  • Download combofix from here
Points Points : 245079
Post by drokness on 7th August 2010, 6:53 pm
ComboFix 10-08-06.03 - Daniel Schneider 08/07/2010 13:06:30.4.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.568 [GMT -5:00]
Running from: c:\documents and settings\Daniel Schneider\Desktop\Combo-Fix.exe
AV: Avira AntiVir PersonalEdition *On-access scanning disabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
c:\docume~1\DANIEL~1\LOCALS~1\Temp\1.wmv
c:\windows\system32\Thumbs.db
c:\windows\system32\UACafihcmsh.log
c:\windows\TEMP\logishrd\LVPrcInj01.dll
((((((((((((((((((((((((( Files Created from 2010-07-07 to 2010-08-07 )))))))))))))))))))))))))))))))
2010-08-06 20:19 . 2010-08-06 20:19 6153352 ----a-w- C:\mbam-setup-1.46.exe
2010-08-06 19:52 . 2010-08-06 19:52 -------- d-----w- C:\_OTL
2010-07-13 20:47 . 2010-06-14 14:31 744448 -c----w- c:\windows\system32\dllcache\helpsvc.exe
2010-08-07 18:27 . 2009-11-29 22:53 0 ----a-w- c:\windows\system32\drivers\lvuvc.hs
2010-08-07 18:27 . 2009-11-29 22:51 0 ----a-w- c:\windows\system32\drivers\logiflt.iad
2010-08-06 20:20 . 2009-01-31 19:09 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-08-04 13:29 . 2005-02-23 20:25 -------- d--h--w- c:\program files\InstallShield Installation Information
2010-08-04 13:28 . 2007-01-07 04:19 -------- d-----w- c:\documents and settings\Daniel Schneider\Application Data\Lionhead Studios
2010-08-04 13:26 . 2005-05-20 22:48 -------- d-----w- c:\program files\Quicken
2010-07-28 23:12 . 2005-10-15 01:40 -------- d-----w- c:\program files\EA GAMES
2010-06-11 08:51 . 2008-08-25 04:08 -------- d-----w- c:\program files\Microsoft Silverlight
2010-02-23 19:00 . 2010-02-23 19:00 318904 ----a-w- c:\program files\wmpfirefoxplugin.exe
2009-11-29 23:03 . 2009-11-29 23:03 2025768 ----a-w- c:\program files\SkypeSetup.exe
2008-12-28 00:01 . 2006-10-08 18:53 302928 ----a-w- c:\program files\dxwebsetup.exe
2008-12-27 23:56 . 2008-12-27 23:54 27288880 ----a-w- c:\program files\QuickTimeInstaller.exe
2008-10-13 16:18 . 2008-10-13 16:18 12580696 ----a-w- c:\program files\mm20enu.exe
2008-02-10 20:54 . 2008-02-10 20:51 28868320 ----a-w- c:\program files\FileFormatConverters.exe
2007-12-06 18:39 . 2007-12-06 18:38 6820520 ----a-w- c:\program files\FirefoxGoogleToolbarSetup.exe
2007-11-18 07:12 . 2007-11-18 07:12 13532808 ----a-w- c:\program files\NBCDirectInstaller.exe
2007-10-14 21:09 . 2007-10-14 21:06 1473748992 ----a-w- c:\program files\CoD4MWDemoSetup.exe
2007-04-11 20:54 . 2007-04-11 20:54 414637 ----a-w- c:\program files\police-quest-in-pursuit-of-the-death-angel.zip
2007-04-11 20:53 . 2007-04-11 20:53 1049705 ----a-w- c:\program files\DOSBox-0.63-install.exe
2006-08-13 22:51 . 2006-08-13 22:50 432552 ----a-w- c:\program files\wpsetup.exe
2006-07-01 17:55 . 2006-07-01 17:55 905728 ----a-w- c:\program files\iview398.exe
2006-05-17 00:03 . 2006-05-17 00:03 359112 ----a-w- c:\program files\LimeWireWin.exe
2006-04-13 17:53 . 2006-04-13 17:53 2871168 ----a-w- c:\program files\setuppad.exe
2006-04-13 17:38 . 2005-10-17 01:21 36465208 ----a-w- c:\program files\iTunesSetup.exe
2005-10-17 01:31 . 2005-10-17 01:31 7739192 ----a-w- c:\program files\DivXPlay.exe
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-14 68856]
"EA Core"="c:\program files\Electronic Arts\EA Link\Core.exe" [2007-07-19 2887680]
"Logitech Vid"="c:\program files\Logitech\Logitech Vid\Vid.exe" [2009-07-16 5458704]
"AGRSMMSG"="AGRSMMSG.exe" [2004-06-29 88363]
"ATIPTA"="c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2004-09-29 344064]
"High Definition Audio Property Page Shortcut"="HDAudPropShortcut.exe" [2004-08-13 61952]
"CreateCD_Reminder"="c:\windows\Sonysys\VAIO Recovery\reminder.exe" [2004-07-16 53248]
"VAIO Update 2"="c:\program files\Sony\VAIO Update 2\VAIOUpdt.exe" [2005-01-14 151552]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-27 35696]
"avgnt"="c:\program files\Avira\AntiVir PersonalEdition Classic\avgnt.exe" [2008-06-12 266497]
"ArcSoft Connection Service"="c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe" [2010-03-18 207360]
"LogitechQuickCamRibbon"="c:\program files\Logitech\Logitech WebCam Software\LWS.exe" [2009-10-14 2793304]
c:\documents and settings\Daniel Schneider\Start Menu\Programs\Startup\
SpywareGuard.lnk - c:\program files\SpywareGuard\sgmain.exe [2003-8-29 360448]
Auto run of VideoCam Suite 1.0.lnk - c:\program files\Panasonic\VideoCamSuite\VideoCamSuiteAutoStart.exe [2008-10-13 161160]
Belkin Wireless G USB Adapter Client Utility.lnk - c:\program files\Belkin\F5D7050v5\Belkinwcui.exe [2008-9-2 1564672]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Image Zone Fast Start.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Image Zone Fast Start.lnk
backup=c:\windows\pss\HP Image Zone Fast Start.lnkCommon Startup
2008-11-20 19:20 290088 ----a-w- c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
2008-04-14 00:12 1695232 ----a-w- c:\program files\Messenger\msmsgs.exe
2008-11-04 16:30 413696 ----a-w- c:\program files\QuickTime\QTTask.exe
"c:\\Program Files\\EA GAMES\\Battlefield 2\\BF2.exe"=
"c:\\Program Files\\Adobe\\Photoshop Elements 7.0\\AdobePhotoshopElementsMediaServer.exe"=
"c:\\Program Files\\GameSpy Arcade\\Aphex.exe"=
"c:\\Program Files\\Skype\\Plugin Manager\\skypePM.exe"=
"c:\\WINDOWS\\system32\\PnkBstrA.exe"=
"c:\\WINDOWS\\system32\\PnkBstrB.exe"=
"c:\\WINDOWS\\system32\\msiexec.exe"=
"c:\\Program Files\\Logitech\\Logitech Vid\\Vid.exe"=
R2 AdobeActiveFileMonitor7.0;Adobe Active File Monitor V7;c:\program files\Adobe\Photoshop Elements 7.0\PhotoshopElementsFileAgent.exe [9/16/2008 1:03 PM 169312]
R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [9/2/2008 2:57 PM 38144]
R2 MSSQL$VAIO_VEDB;MSSQL$VAIO_VEDB;c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe -sVAIO_VEDB --> c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe -sVAIO_VEDB [?]
R2 OpenCASE Media Agent;OpenCASE Media Agent;c:\program files\OpenCASE\OpenCASE Media Agent\MediaAgent.exe [11/6/2007 6:04 PM 810632]
R2 WXRSS;TVTonic RSS;c:\program files\Wavexpress\TVTonic\WXRSS.exe [9/5/2007 5:58 PM 188416]
R3 BELKIN;Belkin Wireless G USB Network Adapter;c:\windows\system32\drivers\BLKWGU.sys [9/2/2008 2:58 PM 238848]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [1/30/2010 10:03 PM 135664]
S3 SQLAgent$VAIO_VEDB;SQLAgent$VAIO_VEDB;c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlagent.EXE -i VAIO_VEDB --> c:\program files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlagent.EXE -i VAIO_VEDB [?]
getPlusHelper REG_MULTI_SZ getPlusHelper
2010-08-03 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 18:34]
2010-08-07 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-01-31 03:03]
2010-08-07 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-08-07 c:\windows\Tasks\WebReg psc 1600 series.job
- c:\program files\HP\Digital Imaging\bin\hpqwrg.exe [2004-11-05 22:45]
uInternet Settings,ProxyServer = http=127.0.0.1:6522
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office10\EXCEL.EXE/3000
FF - ProfilePath - c:\documents and settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - component: c:\documents and settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\components\frozen.dll
FF - plugin: c:\documents and settings\Daniel Schneider\Application Data\Move Networks\plugins\npqmp071701000002.dll
FF - plugin: c:\documents and settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\{E2883E8F-472F-4fb0-9522-AC9BF37916A7}\plugins\np_gp.dll
FF - plugin: c:\documents and settings\Daniel Schneider\Application Data\Mozilla\Firefox\Profiles\5a10nuia.default\extensions\battlefieldheroespatcher@ea.com\platform\WINNT_x86-msvc\plugins\npBFHUpdater.dll
FF - plugin: c:\program files\Google\Update\1.2.183.29\npGoogleOneClick8.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.lu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nz", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbaam7a8h", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--p1ai", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbayh7gpa", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.tel", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation", false);
BHO-{9E3DCAB2-1B63-44D9-AF91-7751CB9F605B} - (no file)
HKCU-Run-updateMgr - c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe
Notify-opnlICSl - (no file)
AddRemove-HijackThis - c:\documents and settings\Daniel Schneider\Desktop\HijackThis.exe
AddRemove-ShockwaveFlash - c:\windows\system32\Macromed\Flash\FlashUtil9c.exe
AddRemove-V CAST Music with Rhapsody - c:\progra~1\VCASTM~1\Unwise32.exe
Rootkit scan 2010-08-07 13:35
- - - - - - - > 'winlogon.exe'(900)
- - - - - - - > 'explorer.exe'(5148)
c:\program files\Lavasoft\Ad-Aware\aawservice.exe
c:\program files\Avira\AntiVir PersonalEdition Classic\sched.exe
c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
c:\program files\Avira\AntiVir PersonalEdition Classic\avguard.exe
c:\windows\system32\bgsvcgen.exe
c:\windows\eHome\ehRecvr.exe
c:\windows\eHome\ehSched.exe
c:\program files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
c:\windows\system32\HPZipm12.exe
c:\windows\system32\PnkBstrA.exe
c:\program files\Common Files\Sony Shared\WMPlugIn\SonicStageMonitoring.exe
c:\program files\Sony\Sony TV Tuner Library\SMceMan.exe
c:\windows\system32\wdfmgr.exe
c:\program files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
c:\program files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
c:\program files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
c:\windows\system32\dllhost.exe
c:\program files\Sony\Sony TV Tuner Library\RM_SV.exe
c:\windows\AGRSMMSG.exe
c:\program files\Common Files\ArcSoft\Connection Service\Bin\ArcCon.ac
c:\program files\Common Files\Logishrd\LQCVFX\COCIManager.exe
c:\program files\SpywareGuard\sgbhp.exe
c:\program files\logitech\logitech webcam software\lu\lulnchr.exe
c:\program files\logitech\logitech webcam software\lu\LogitechUpdate.exe
Completion time: 2010-08-07 13:52:09 - machine was rebooted
ComboFix-quarantined-files.txt 2010-08-07 18:52
Pre-Run: 12,385,001,472 bytes free
Post-Run: 12,803,637,248 bytes free
- - End Of File - - FC22BB215522E0236CA38B8B38E3B3FB
drokness
Posts Posts : 105
Post by drokness on 8th August 2010, 7:37 pm
Also, a new development: my AntiVir Guard: Attention, Detection has since found (since the posting of the ComboFix log) a TR/Trash.Gen Trojan (C:\WINDOWS\Temp\logishrd\LVPrcInj01.dll) that I am unable to remove, even after trying to delete it. I had turned off my AntiVir when I ran ComboFix, but it reactivated upon reboot.
Edit: ComboFix log is posted on page 1 (Post 15).
drokness
Posts Posts : 105
Post by Belahzur on 8th August 2010, 7:48 pm
Don't worry about that, false positive, it's just Logitech are bad developers.
Last bit of the infection to fix.
  1. Close any open browsers.
    File::
    DDS::
Post by drokness on 8th August 2010, 8:40 pm
Sweet, so should I just "Ignore" that AntiVir alert? ComboFix log follows:
ComboFix 10-08-06.03 - Daniel Schneider 08/08/2010 15:03:48.5.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.542 [GMT -5:00]
Command switches used :: c:\documents and settings\Daniel Schneider\Desktop\CFScript.txt
FILE ::
"c:\program files\LimeWireWin.exe"
((((((((((((((((((((((((( Files Created from 2010-07-08 to 2010-08-08 )))))))))))))))))))))))))))))))
2010-08-08 00:54 . 2009-11-29 22:53 0 ----a-w- c:\windows\system32\drivers\lvuvc.hs
2010-08-07 21:01 . 2009-11-29 23:07 -------- d-----w- c:\documents and settings\Daniel Schneider\Application Data\Skype
2010-08-07 21:00 . 2009-11-29 23:10 -------- d-----w- c:\documents and settings\Daniel Schneider\Application Data\skypePM
2010-06-14 14:31 . 2005-02-23 20:09 744448 ----a-w- c:\windows\pchealth\helpctr\binaries\helpsvc.exe
------- Sigcheck -------
[-] 2008-11-30 . 63999D0ABD8DABFD76A9C07F6E104868 . 295424 . . [5.1.2600.5512] . . c:\windows\system32\termsrv.dll
[7] 2008-04-14 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\termsrv.dll
[-] 2004-08-10 . B60C877D16D9C880B952FDA04ADF16E6 . 295424 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\termsrv.dll
2010-08-08 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-08-08 c:\windows\Tasks\WebReg psc 1600 series.job
Rootkit scan 2010-08-08 15:23
Completion time: 2010-08-08 15:33:23
ComboFix-quarantined-files.txt 2010-08-08 20:33
ComboFix2.txt 2010-08-07 18:52
Pre-Run: 12,766,650,368 bytes free
Post-Run: 12,741,279,744 bytes free
- - End Of File - - D1F3A4C9E8EC70B79A154D76C439830E
drokness
Posts Posts : 105
Post by Belahzur on 8th August 2010, 9:41 pm
Something else just snuck in, we need to fix it.
    FCopy::
    c:\windows\ServicePackFiles\i386\termsrv.dll | c:\windows\system32\termsrv.dll
    c:\windows\ServicePackFiles\i386\termsrv.dll | c:\windows\$NtServicePackUninstall$\termsrv.dll
Post by drokness on 8th August 2010, 11:01 pm
How should/do I get rid of that AntiVir Guard alert, then? Should I just click on "Ignore"/Ok? New ComboFix log follows:
ComboFix 10-08-06.03 - Daniel Schneider 08/08/2010 17:29:48.6.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.496 [GMT -5:00]
c:\windows\ServicePackFiles\i386\termsrv.dll --> c:\windows\system32\termsrv.dll
c:\windows\ServicePackFiles\i386\termsrv.dll --> c:\windows\$NtServicePackUninstall$\termsrv.dll
Rootkit scan 2010-08-08 17:48
- - - - - - - > 'explorer.exe'(6060)
Completion time: 2010-08-08 17:58:57
ComboFix-quarantined-files.txt 2010-08-08 22:58
ComboFix2.txt 2010-08-08 20:33
ComboFix3.txt 2010-08-07 18:52
Pre-Run: 12,755,091,456 bytes free
Post-Run: 12,733,329,408 bytes free
- - End Of File - - F7CEE6E8A8A1FE5E70FC09D639EB0DF4
drokness
Posts Posts : 105
Post by Belahzur on 10th August 2010, 12:01 am
ComboFix /uninstall
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by drokness on 10th August 2010, 1:39 am
# version=7
# iexplore.exe=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# EOSSerial=032f5dea050941468a6a4eecec9ca964
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-08-10 01:37:01
# local_time=2010-08-09 08:37:01 (-0600, Central Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=512 16777215 100 0 0 0 0 0
# compatibility_mode=1792 16777191 100 0 32807370 32807370 0 0
# scanned=120484
# found=1
# cleaned=1
# scan_time=4362
C:\_OTL\MovedFiles\08062010_145241\C_Documents and Settings\Daniel Schneider\Local Settings\Application Data\yqrjmxuqi\hawgtertssd.exe a variant of Win32/Kryptik.FWK trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
drokness
Posts Posts : 105
Post by Belahzur on 10th August 2010, 11:35 pm
Post by drokness on 10th August 2010, 11:44 pm
Smooth as a baby's a$$!!! Seriously can't thank you enough, Belahzur. You've saved my butt on numerous occasions. Is there anything else I need to do?
drokness
Posts Posts : 105
Post by Belahzur on 11th August 2010, 12:01 am
Yeah, just a few things last things to do now.
    Adobe Reader 9.1.2
Updating Java:
  • Click the "Download JRE" button to the right.
  • In the Window that opens, select your platform, check the "agree" box, and click Continue.
  • Then from your desktop double-click on jre-6u21-windows-i586.exe that you downloaded to install the newest version.
Then download and install [You must be registered and logged in to see this link.]
Also, your Firefox needs updating.
Please download [You must be registered and logged in to see this link.] and install it. It will install over version 3.5 you currently have installed, so you won't lose any bookmarked websites.
Post by drokness on 11th August 2010, 12:31 am
Done and done! Anything else? Should I delete the rKill program and OTL logs from my desktop?
drokness
Posts Posts : 105
Post by drokness on 11th August 2010, 3:02 am
Here's my AntiVir scan log, just for good measure:
Report file date: Tuesday, August 10, 2010 20:14
Scanning for 2701388 virus strains and unwanted programs.
Licensed to: Avira AntiVir Personal - FREE Antivirus
Serial number: 0000149996-ADJIE-0000001
Platform: Windows XP
Windows version: (Service Pack 3) [5.1.2600]
Boot mode: Normally booted
Username: SYSTEM
Computer name: WHITETUNDRA
Version information:
BUILD.DAT : 8.2.0.354 17048 Bytes 10/23/2009 13:15:00
AVSCAN.EXE : 8.1.4.10 315649 Bytes 11/18/2008 14:21:26
AVSCAN.DLL : 8.1.4.0 40705 Bytes 5/26/2008 13:56:40
LUKE.DLL : 8.1.4.5 164097 Bytes 6/12/2008 18:44:19
LUKERES.DLL : 8.1.4.0 12033 Bytes 5/26/2008 13:58:52
ANTIVIR0.VDF : 7.10.0.0 19875328 Bytes 11/6/2009 16:27:30
ANTIVIR1.VDF : 7.10.9.170 16733040 Bytes 7/23/2010 05:10:13
ANTIVIR2.VDF : 7.10.10.119 1761696 Bytes 8/9/2010 05:09:10
ANTIVIR3.VDF : 7.10.10.126 94720 Bytes 8/9/2010 05:09:12
Engineversion : 8.2.4.34
AEVDF.DLL : 8.1.2.1 106868 Bytes 7/30/2010 05:08:41
AESCRIPT.DLL : 8.1.3.42 1364347 Bytes 7/30/2010 05:08:39
AESCN.DLL : 8.1.6.1 127347 Bytes 5/13/2010 05:01:28
AESBX.DLL : 8.1.3.1 254324 Bytes 4/23/2010 15:40:03
AERDL.DLL : 8.1.8.2 614772 Bytes 7/21/2010 05:08:00
AEPACK.DLL : 8.2.3.5 471412 Bytes 8/7/2010 05:09:16
AEOFFICE.DLL : 8.1.1.8 201081 Bytes 7/22/2010 05:07:52
AEHEUR.DLL : 8.1.2.11 2834805 Bytes 8/7/2010 05:09:13
AEHELP.DLL : 8.1.13.2 242039 Bytes 7/21/2010 05:07:40
AEGEN.DLL : 8.1.3.19 393587 Bytes 8/7/2010 05:09:01
AEEMU.DLL : 8.1.2.0 393588 Bytes 4/23/2010 15:40:02
AECORE.DLL : 8.1.16.2 192887 Bytes 7/21/2010 05:07:36
AEBB.DLL : 8.1.1.0 53618 Bytes 4/23/2010 15:40:00
AVWINLL.DLL : 1.0.0.12 15105 Bytes 7/9/2008 14:40:05
AVPREF.DLL : 8.0.2.0 38657 Bytes 5/16/2008 15:28:01
AVREP.DLL : 8.0.0.7 159784 Bytes 2/17/2010 15:36:00
AVREG.DLL : 8.0.0.1 33537 Bytes 5/9/2008 17:26:40
AVARKT.DLL : 1.0.0.23 307457 Bytes 2/12/2008 14:29:23
AVEVTLOG.DLL : 8.0.0.16 119041 Bytes 6/12/2008 18:27:49
SQLITE3.DLL : 3.3.17.1 339968 Bytes 1/22/2008 23:28:02
SMTPLIB.DLL : 1.2.0.23 28929 Bytes 6/12/2008 18:49:40
NETNT.DLL : 8.0.0.1 7937 Bytes 1/25/2008 18:05:10
RCIMAGE.DLL : 8.0.0.51 2371841 Bytes 6/12/2008 19:48:07
RCTEXT.DLL : 8.0.52.0 86273 Bytes 6/27/2008 19:34:37
Configuration settings for the scan:
Jobname..........................: Complete system scan
Configuration file...............: c:\program files\avira\antivir personaledition classic\sysscan.avp
Logging..........................: low
Primary action...................: interactive
Secondary action.................: ignore
Scan master boot sector..........: on
Scan boot sector.................: on
Boot sectors.....................: C:,
Process scan.....................: on
Scan registry....................: on
Search for rootkits..............: off
Scan all files...................: Intelligent file selection
Scan archives....................: on
Recursion depth..................: 20
Smart extensions.................: on
Macro heuristic..................: on
File heuristic...................: medium
Start of the scan: Tuesday, August 10, 2010 20:14
The scan of running processes will be started
Scan process 'avscan.exe' - '1' Module(s) have been scanned
Scan process 'avcenter.exe' - '1' Module(s) have been scanned
Scan process 'jqs.exe' - '1' Module(s) have been scanned
Scan process 'sgbhp.exe' - '1' Module(s) have been scanned
Scan process 'sgmain.exe' - '1' Module(s) have been scanned
Scan process 'TeaTimer.exe' - '1' Module(s) have been scanned
Scan process 'ctfmon.exe' - '1' Module(s) have been scanned
Scan process 'COCIManager.exe' - '1' Module(s) have been scanned
Scan process 'Belkinwcui.exe' - '1' Module(s) have been scanned
Scan process 'VideoCamSuiteAutoStart.exe' - '1' Module(s) have been scanned
Scan process 'ArcCon.ac' - '1' Module(s) have been scanned
Scan process 'GoogleToolbarNotifier.exe' - '1' Module(s) have been scanned
Scan process 'LWS.exe' - '1' Module(s) have been scanned
Scan process 'ACDaemon.exe' - '1' Module(s) have been scanned
Scan process 'avgnt.exe' - '1' Module(s) have been scanned
Scan process 'VAIOUpdt.exe' - '1' Module(s) have been scanned
Scan process 'atiptaxx.exe' - '1' Module(s) have been scanned
Scan process 'AGRSMMSG.exe' - '1' Module(s) have been scanned
Scan process 'alg.exe' - '1' Module(s) have been scanned
Scan process 'RM_SV.exe' - '1' Module(s) have been scanned
Scan process 'dllhost.exe' - '1' Module(s) have been scanned
Scan process 'VzFw.exe' - '1' Module(s) have been scanned
Scan process 'VzCdbSvc.exe' - '1' Module(s) have been scanned
Scan process 'WXRSS.exe' - '1' Module(s) have been scanned
Scan process 'VCSW.exe' - '1' Module(s) have been scanned
Scan process 'wdfmgr.exe' - '1' Module(s) have been scanned
Scan process 'svchost.exe' - '1' Module(s) have been scanned
Scan process 'explorer.exe' - '1' Module(s) have been scanned
Scan process 'SMceMan.exe' - '1' Module(s) have been scanned
Scan process 'SonicStageMonitoring.exe' - '1' Module(s) have been scanned
Scan process 'ati2evxx.exe' - '1' Module(s) have been scanned
Scan process 'PnkBstrA.exe' - '1' Module(s) have been scanned
Scan process 'MediaAgent.exe' - '1' Module(s) have been scanned
Scan process 'sqlservr.exe' - '1' Module(s) have been scanned
Scan process 'ehSched.exe' - '1' Module(s) have been scanned
Scan process 'ehRecvr.exe' - '1' Module(s) have been scanned
Scan process 'mDNSResponder.exe' - '1' Module(s) have been scanned
Scan process 'bgsvcgen.exe' - '1' Module(s) have been scanned
Scan process 'AppleMobileDeviceService.exe' - '1' Module(s) have been scanned
Scan process 'avguard.exe' - '1' Module(s) have been scanned
Scan process 'PhotoshopElementsFileAgent.exe' - '1' Module(s) have been scanned
Scan process 'ACService.exe' - '1' Module(s) have been scanned
Scan process 'sched.exe' - '1' Module(s) have been scanned
Scan process 'spoolsv.exe' - '1' Module(s) have been scanned
Scan process 'aawservice.exe' - '1' Module(s) have been scanned
Scan process 'lsass.exe' - '1' Module(s) have been scanned
Scan process 'services.exe' - '1' Module(s) have been scanned
Scan process 'winlogon.exe' - '1' Module(s) have been scanned
Scan process 'csrss.exe' - '1' Module(s) have been scanned
Scan process 'smss.exe' - '1' Module(s) have been scanned
57 processes with 57 modules were scanned
Starting master boot sector scan:
Master boot sector HD0
[INFO] No virus was found!
Master boot sector HD1
[WARNING] System error [21]: The device is not ready.
Master boot sector HD2
Master boot sector HD3
Master boot sector HD4
Master boot sector HD5
Start scanning boot sectors:
Boot sector 'C:'
Starting to scan the registry.
The registry was scanned ( '66' files ).
Starting the file scan:
Begin scan in 'C:'
C:\hiberfil.sys
[WARNING] The file could not be opened!
C:\pagefile.sys
C:\Documents and Settings\Daniel Schneider\Application Data\Sun\Java\Deployment\cache\6.0\13\7c6ad54d-574624c9
[0] Archive type: ZIP
--> Keyworq.class
[DETECTION] Contains recognition pattern of the JAVA/Agent.a Java virus
--> Uutecwv.class
[DETECTION] Contains recognition pattern of the JAVA/ClassLoad.IC.1 Java virus
[NOTE] The file was deleted!
C:\Documents and Settings\Daniel Schneider\Application Data\Sun\Java\Deployment\cache\6.0\17\2d949ad1-49a56414
--> sklif/Hieeyfc.class
[DETECTION] Contains recognition pattern of the JAVA/ClassLoade.I.1 Java virus
--> sklif/Hirwfee.class
[DETECTION] Contains recognition pattern of the JAVA/ClassLoad.IB.2 Java virus
--> sklif/Hiydcxed.class
[DETECTION] Contains recognition pattern of the JAVA/Djewers.CP Java virus
C:\Documents and Settings\Daniel Schneider\Application Data\Sun\Java\Deployment\cache\6.0\45\4521ff2d-7fc08d4e
--> dev/s/DyesyasZ.class
[DETECTION] Contains recognition pattern of the JAVA/Agent.M.2 Java virus
--> dev/s/LoaderX.class
[DETECTION] Contains recognition pattern of the JAVA/Agent.M.1 Java virus
End of the scan: Tuesday, August 10, 2010 21:57
Used time: 1:42:17 Hour(s)
The scan has been done completely.
25449 Scanning directories
362187 Files were scanned
7 viruses and/or unwanted programs were found
0 Files were classified as suspicious:
3 files were deleted
0 files were repaired
0 files were moved to quarantine
0 files were renamed
2 Files cannot be scanned
362178 Files not concerned
8377 Archives were scanned
7 Warnings
3 Notes
drokness
Posts Posts : 105
Post by Belahzur on 11th August 2010, 1:52 pm
Just your Java cache. See here for instructions on how to delete the cache.
If everything is good, then you should be free to go.
Post by drokness on 11th August 2010, 4:40 pm
Thanks a million, Belahzur!
drokness
Posts Posts : 105
