Antivir Solution Pro
Post by rob864 on Fri 06 Aug 2010, 6:27 am
Dear GeekPolice
Recently picked up a virus on my computer called Antivir Solution Pro. Now i im unable to login, when i try it crashses and goes to blue screen. Sometimes i get past the login but crashes before anything loads.
Before this stage the virus was an icon in the system tray that pretended to be anti virus software, but i have McAfee. This all started about 5 days ago. Using a second computer atm, can you help?
Rob
rob864
Operating System : xp
Re: Antivir Solution Pro
Post by Belahzur on Fri 06 Aug 2010, 7:39 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
Post by rob864 on Sun 08 Aug 2010, 1:36 am
I used F12 when powering up and 'Last known good configuration'. This came up with Fatal system error C000021a, Windows logon process terminated 0xC0000005.
I powered up again and booted from the Windows recover Disk. Again winlogon.exe error and loads of other errors. However I managed to run OTL from the USB stick. As I am using another computer for comms to you. Notepad was not saving, so copied to Word. Xfered to this computer then back to notepad.
Here is OTL.txt
OTL logfile created on: 07/08/2010 14:51:41 - Run 1
OTL by OldTimer - Version 3.2.9.1 Folder = F:\
Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
1,022.00 Mb Total Physical Memory | 210.00 Mb Available Physical Memory | 21.00% Memory free
2.00 Gb Paging File | 2.00 Gb Available in Paging File | 76.00% Paging File free
Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
Drive C: | 108.57 Gb Total Space | 3.08 Gb Free Space | 2.84% Space Free | Partition Type: NTFS
Drive D: | 37.23 Gb Total Space | 37.16 Gb Free Space | 99.83% Space Free | Partition Type: NTFS
Drive E: | 581.97 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
Drive F: | 1.86 Gb Total Space | 1.86 Gb Free Space | 99.96% Space Free | Partition Type: FAT
Computer Name: ROBS_PC
Current User Name: Rob
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/08/07 13:32:52 | 000,574,976 | ---- | M] (OldTimer Tools) -- F:\OTL.exe
PRC - [2010/08/02 07:56:11 | 000,060,004 | -H-- | M] () -- C:\Documents and Settings\Rob\Local Settings\Temp\install.exe
PRC - [2010/08/02 07:56:06 | 000,030,001 | -H-- | M] () -- C:\Documents and Settings\Rob\Local Settings\Temp\j9o5vm23.exe
PRC - [2010/07/21 21:03:31 | 000,048,644 | -H-- | M] () -- C:\Documents and Settings\Rob\Local Settings\Temp\smss.exe
PRC - [2010/07/07 18:10:26 | 000,048,644 | -H-- | M] () -- C:\Documents and Settings\Rob\Local Settings\Temp\wininst.exe
PRC - [2010/06/24 21:22:08 | 000,020,724 | -H-- | M] () -- C:\Documents and Settings\Rob\Local Settings\Temp\nvsvc32.exe
PRC - [2010/06/03 01:50:58 | 001,144,104 | ---- | M] () -- C:\Program Files\DivX\DivX Update\DivXUpdate.exe
PRC - [2009/11/13 01:07:54 | 000,323,392 | ---- | M] (BitTorrent, Inc.) -- C:\Program Files\DNA\btdna.exe
PRC - [2009/11/01 12:47:00 | 000,119,296 | ---- | M] () -- C:\Program Files\Rainmeter\Rainmeter.exe
PRC - [2009/09/15 21:04:58 | 000,331,824 | ---- | M] (AnchorFree Inc.) -- C:\Program Files\Hotspot Shield\HssWPR\hsssrv.exe
PRC - [2009/08/22 11:31:06 | 005,148,672 | ---- | M] () -- C:\Program Files\Rainlendar2\Rainlendar2.exe
PRC - [2009/05/19 11:36:18 | 000,240,512 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
PRC - [2007/11/19 15:13:12 | 000,274,432 | ---- | M] () -- C:\Program Files\VentSrv\ventrilo_srv.exe
PRC - [2007/06/28 20:47:15 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2007/06/27 20:04:00 | 001,213,736 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe
PRC - [2007/06/27 20:03:40 | 000,152,872 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
PRC - [2007/06/13 11:23:07 | 001,033,216 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2007/04/30 20:43:54 | 003,450,608 | ---- | M] (Stardock) -- C:\Program Files\Stardock\ObjectDock\ObjectDock.exe
PRC - [2007/02/20 00:59:20 | 000,914,992 | ---- | M] (SingleClick Systems) -- C:\Program Files\Dell Network Assistant\ezi_hnm2.exe
PRC - [2007/02/20 00:58:30 | 000,083,504 | ---- | M] (SingleClick Systems) -- C:\Program Files\Dell Network Assistant\hnm_svc.exe
PRC - [2006/11/24 02:06:38 | 000,487,424 | R--- | M] () -- C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe
PRC - [2006/11/07 15:49:50 | 001,121,280 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\SpamKiller\MSKDetct.exe
PRC - [2006/10/13 10:11:16 | 000,983,040 | R--- | M] (Obigo AB) -- C:\Program Files\Common Files\Teleca Shared\Generic.exe
PRC - [2006/09/27 14:33:19 | 000,026,112 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Real\RealPlayer\realplay.exe
PRC - [2006/01/02 17:41:22 | 000,045,056 | ---- | M] (ATI Technologies Inc.) -- C:\Program Files\ATI Technologies\ATI.ACE\CLI.exe
PRC - [2005/11/11 17:00:56 | 001,005,096 | ---- | M] (McAfee Security) -- C:\Program Files\McAfee.com\Personal Firewall\MpfTray.exe
PRC - [2005/11/11 16:43:04 | 000,548,864 | ---- | M] (McAfee Corporation) -- C:\Program Files\McAfee.com\Personal Firewall\MpfService.exe
PRC - [2005/11/11 16:42:12 | 000,524,288 | ---- | M] (McAfee Security) -- C:\Program Files\McAfee.com\Personal Firewall\MpfAgent.exe
PRC - [2005/10/13 19:56:16 | 000,126,976 | ---- | M] (McAfee, Inc) -- c:\Program Files\McAfee.com\Agent\Mcdetect.exe
PRC - [2005/10/05 03:12:00 | 000,094,208 | ---- | M] () -- C:\Program Files\Dell\Media Experience\DMXLauncher.exe
PRC - [2005/09/26 10:26:58 | 000,110,592 | ---- | M] (McAfee Inc.) -- C:\Program Files\McAfee\SpamKiller\MSKAgent.exe
PRC - [2005/09/22 18:29:08 | 000,303,104 | ---- | M] (McAfee, Inc) -- C:\Program Files\McAfee.com\Agent\mcagent.exe
PRC - [2005/09/08 05:20:00 | 000,122,940 | ---- | M] (Sonic Solutions) -- C:\WINDOWS\system32\DLA\DLACTRLW.EXE
PRC - [2005/08/24 16:01:04 | 000,122,368 | ---- | M] (McAfee, Inc) -- c:\Program Files\McAfee.com\Agent\McTskshd.exe
PRC - [2005/08/11 22:02:44 | 000,053,248 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee.com\VSO\oasclnt.exe
PRC - [2005/08/10 12:49:20 | 000,163,840 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\VSO\mcvsshld.exe
PRC - [2005/08/10 11:22:02 | 000,221,184 | ---- | M] (McAfee Inc.) -- c:\Program Files\McAfee.com\VSO\McShield.exe
PRC - [2005/08/04 03:42:00 | 000,528,384 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\SetPoint\SetPoint.exe
PRC - [2005/08/04 03:42:00 | 000,028,160 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\Logitech\KHAL\KHALMNPR.EXE
PRC - [2005/07/13 21:18:10 | 000,065,536 | ---- | M] () -- C:\Program Files\VentSrv\ventrilo_svc.exe
PRC - [2005/07/08 18:16:16 | 000,483,328 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\VSO\McVSEscn.exe
PRC - [2005/07/01 20:43:00 | 000,299,008 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\VSO\mcvsftsn.exe
PRC - [2005/06/10 10:44:02 | 000,081,920 | ---- | M] (InstallShield Software Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
PRC - [2005/01/26 15:15:16 | 000,884,838 | ---- | M] (NETGEAR) -- C:\Program Files\NETGEAR\WPN111\WPN111.exe
PRC - [2004/11/10 00:22:17 | 000,497,240 | ---- | M] (America Online, Inc) -- C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
PRC - [2004/11/10 00:22:16 | 001,140,312 | ---- | M] (America Online, Inc.) -- C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
PRC - [2004/08/04 05:00:00 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\dwwin.exe
PRC - [2004/03/19 14:17:00 | 000,078,960 | ---- | M] () -- C:\Program Files\Common Files\AOL\AOL Spyware Protection\AOLSP Scheduler.exe
MOD - [2010/08/07 13:32:52 | 000,574,976 | ---- | M] (OldTimer Tools) -- F:\OTL.exe
MOD - [2007/04/30 20:18:50 | 000,112,400 | ---- | M] () -- C:\Program Files\Stardock\ObjectDock\DockShellHook.dll
MOD - [2007/03/08 16:36:28 | 000,152,064 | ---- | M] () -- C:\WINDOWS\ajovupoqoxevuqa.dll
MOD - [2006/08/25 16:45:55 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
MOD - [2005/09/26 18:12:52 | 000,098,304 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\VSO\McVSSkt.Dll
MOD - [2005/08/17 10:38:00 | 000,143,360 | ---- | M] (McAfee Inc.) -- C:\Program Files\McAfee\SpamKiller\MSKOEPlg.dll
MOD - [2005/08/04 03:42:00 | 000,499,712 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msvcp71.dll
MOD - [2005/08/04 03:42:00 | 000,348,160 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msvcr71.dll
MOD - [2005/08/04 03:42:00 | 000,057,344 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\SetPoint\lgscroll.dll
MOD - [2005/08/04 03:42:00 | 000,036,352 | ---- | M] (Logitech Inc.) -- C:\Program Files\Logitech\SetPoint\gamehook.dll
MOD - [2004/08/04 05:00:00 | 000,102,400 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msscript.ocx
SRV - File not found [On_Demand | Stopped] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
SRV - [2009/09/15 21:29:04 | 000,057,640 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\Hotspot Shield\bin\HssTrayService.exe -- (HssTrayService)
SRV - [2009/09/15 21:28:52 | 000,204,848 | ---- | M] () [Auto | Stopped] -- C:\Program Files\Hotspot Shield\bin\openvpnas.exe -- (HotspotShieldService)
SRV - [2009/09/15 21:04:58 | 000,331,824 | ---- | M] (AnchorFree Inc.) [Auto | Running] -- C:\Program Files\Hotspot Shield\HssWPR\hsssrv.exe -- (HssSrv)
SRV - [2009/08/05 23:48:42 | 000,704,864 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Live\Family Safety\fsssvc.exe -- (fsssvc)
SRV - [2009/05/19 11:36:18 | 000,240,512 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe -- (SeaPort)
SRV - [2007/03/28 21:07:10 | 012,798,152 | RHS- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Program Files\NetMeeting\comp.exe -- (RPCER) Remote Procedure Call (HNM)
SRV - [2007/02/20 00:58:30 | 000,083,504 | ---- | M] (SingleClick Systems) [Auto | Running] -- C:\Program Files\Dell Network Assistant\hnm_svc.exe -- (hnmsvc)
SRV - [2005/11/24 17:03:22 | 000,053,337 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe -- (MSCSPTISRV)
SRV - [2005/11/24 16:57:44 | 000,053,337 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe -- (PACSPTISVR)
SRV - [2005/11/24 16:47:30 | 000,069,718 | ---- | M] (Sony Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe -- (SPTISRV)
SRV - [2005/11/11 16:43:04 | 000,548,864 | ---- | M] (McAfee Corporation) [Auto | Running] -- C:\Program Files\McAfee.com\Personal Firewall\MpfService.exe -- (MpfService)
SRV - [2005/10/13 19:56:16 | 000,126,976 | ---- | M] (McAfee, Inc) [Auto | Running] -- c:\Program Files\McAfee.com\Agent\Mcdetect.exe -- (McDetect.exe)
SRV - [2005/08/24 16:01:04 | 000,122,368 | ---- | M] (McAfee, Inc) [Auto | Running] -- c:\Program Files\McAfee.com\Agent\McTskshd.exe -- (McTskshd.exe)
SRV - [2005/08/10 11:22:02 | 000,221,184 | ---- | M] (McAfee Inc.) [Auto | Running] -- c:\Program Files\McAfee.com\VSO\McShield.exe -- (McShield)
SRV - [2005/07/13 21:18:10 | 000,065,536 | ---- | M] () [Auto | Running] -- C:\Program Files\VentSrv\ventrilo_svc.exe -- (Ventrilo)
SRV - [2005/07/12 18:10:18 | 000,963,072 | ---- | M] (McAfee Inc.) [Auto | Stopped] -- C:\Program Files\McAfee\SpamKiller\MSKSrvr.exe -- (MskService)
SRV - [2005/07/01 19:22:50 | 000,245,760 | ---- | M] (McAfee, Inc) [On_Demand | Stopped] -- C:\Program Files\McAfee.com\Agent\mcupdmgr.exe -- (mcupdmgr.exe)
SRV - [2004/11/10 00:22:16 | 001,140,312 | ---- | M] (America Online, Inc.) [Auto | Running] -- C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe -- (AOL ACS)
DRV - [2010/07/09 00:06:28 | 000,004,096 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nocashio.sys -- (nocashio)
DRV - [2009/10/28 22:24:36 | 000,002,368 | ---- | M] (AntiCracking) [Kernel | Auto | Running] -- C:\WINDOWS\system32\STEC3.sys -- (STEC3)
DRV - [2009/09/15 21:04:58 | 000,032,768 | ---- | M] (AnchorFree Inc) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\taphss.sys -- (taphss)
DRV - [2009/08/05 23:48:42 | 000,054,752 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\fssfltr_tdi.sys -- (fssfltr)
DRV - [2009/07/22 20:13:20 | 000,028,592 | ---- | M] (The OpenVPN Project) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tap0901.sys -- (tap0901)
DRV - [2009/07/08 22:51:04 | 000,721,904 | ---- | M] () [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\sptd.sys -- (sptd)
DRV - [2006/12/18 19:01:20 | 000,012,672 | ---- | M] (SingleClick Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\packet.sys -- (Packet)
DRV - [2006/09/27 14:33:21 | 000,008,552 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\asctrm.sys -- (ASCTRM)
DRV - [2006/09/18 14:59:08 | 000,090,800 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\se27unic.sys -- (se27unic) Sony Ericsson Device 039 USB Ethernet Emulation SEMC39 (WDM)
DRV - [2006/09/18 14:59:02 | 000,086,560 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SE27obex.sys -- (SE27obex)
DRV - [2006/09/18 14:59:00 | 000,018,704 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\se27nd5.sys -- (se27nd5) Sony Ericsson Device 039 USB Ethernet Emulation SEMC39 (NDIS)
DRV - [2006/09/18 14:58:58 | 000,088,688 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SE27mgmt.sys -- (SE27mgmt) Sony Ericsson Device 039 USB WMC Device Management Drivers (WDM)
DRV - [2006/09/18 14:58:54 | 000,097,184 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SE27mdm.sys -- (SE27mdm)
DRV - [2006/09/18 14:58:52 | 000,009,360 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SE27mdfl.sys -- (SE27mdfl)
DRV - [2006/08/15 09:38:14 | 001,171,464 | ---- | M] (SigmaTel, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\sthda.sys -- (STHDA)
DRV - [2006/08/14 13:29:44 | 000,044,544 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\bcm4sbxp.sys -- (bcm4sbxp)
DRV - [2006/06/19 04:37:34 | 000,036,864 | ---- | M] (Advanced Micro Devices) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\AmdK8.sys -- (AmdK8)
DRV - [2006/06/07 22:08:58 | 001,580,544 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2006/05/15 14:35:36 | 000,061,600 | R--- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SE27bus.sys -- (SE27bus) Sony Ericsson Device 039 Driver driver (WDM)
DRV - [2006/01/10 12:07:58 | 000,004,864 | ---- | M] (GTek Technologies Ltd.) [Kernel | On_Demand | Stopped] -- C:\Program Files\Dell Support\GTAction\triggers\DSproct.sys -- (DSproct)
DRV - [2005/11/11 16:43:52 | 000,080,640 | ---- | M] (McAfee) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\MpFirewall.sys -- (MPFIREWL)
DRV - [2005/09/26 16:02:50 | 000,362,944 | ---- | M] (NETGEAR, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\WPN111.sys -- (WPN111)
DRV - [2005/09/12 03:30:00 | 000,089,264 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\DRVMCDB.SYS -- (DRVMCDB)
DRV - [2005/09/08 05:20:00 | 000,094,332 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAUDFAM.SYS -- (DLAUDFAM)
DRV - [2005/09/08 05:20:00 | 000,087,036 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAUDF_M.SYS -- (DLAUDF_M)
DRV - [2005/09/08 05:20:00 | 000,086,524 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAIFS_M.SYS -- (DLAIFS_M)
DRV - [2005/09/08 05:20:00 | 000,025,628 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLABOIOM.SYS -- (DLABOIOM)
DRV - [2005/09/08 05:20:00 | 000,014,684 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAOPIOM.SYS -- (DLAOPIOM)
DRV - [2005/09/08 05:20:00 | 000,006,364 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAPoolM.SYS -- (DLAPoolM)
DRV - [2005/09/08 05:20:00 | 000,002,496 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLADResN.SYS -- (DLADResN)
DRV - [2005/08/25 12:16:52 | 000,005,628 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\DLACDBHM.SYS -- (DLACDBHM)
DRV - [2005/08/25 12:16:16 | 000,022,684 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\DLARTL_N.SYS -- (DLARTL_N)
DRV - [2005/08/12 05:20:00 | 000,040,544 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\DRVNDDM.SYS -- (DRVNDDM)
DRV - [2005/08/10 11:22:10 | 000,114,464 | ---- | M] (McAfee Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\naiavf5x.sys -- (NaiAvFilter1)
DRV - [2005/07/23 00:41:46 | 000,026,112 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LHidKE.Sys -- (LHidKe)
DRV - [2005/07/23 00:41:42 | 000,068,864 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LMouKE.Sys -- (LMouKE)
DRV - [2004/08/12 17:45:54 | 000,137,728 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Hdaudbus.sys -- (HDAudBus)
DRV - [2004/08/03 23:07:44 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\amdagp.sys -- (amdagp)
DRV - [2004/08/03 23:07:44 | 000,041,088 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sisagp.sys -- (sisagp)
DRV - [2004/08/03 22:29:56 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
DRV - [2003/07/24 12:10:34 | 000,017,149 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\DNINDIS5.sys -- (DNINDIS5)
DRV - [2003/01/10 22:13:04 | 000,033,588 | ---- | M] (America Online, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
DRV - [2001/08/17 14:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sparrow.sys -- (Sparrow)
DRV - [2001/08/17 14:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_u3.sys -- (sym_u3)
DRV - [2001/08/17 14:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_hi.sys -- (sym_hi)
DRV - [2001/08/17 14:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc8xx.sys -- (symc8xx)
DRV - [2001/08/17 14:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc810.sys -- (symc810)
DRV - [2001/08/17 13:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ultra.sys -- (ultra)
DRV - [2001/08/17 13:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql12160.sys -- (ql12160)
DRV - [2001/08/17 13:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1080.sys -- (ql1080)
DRV - [2001/08/17 13:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1280.sys -- (ql1280)
DRV - [2001/08/17 13:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\dac2w2k.sys -- (dac2w2k)
DRV - [2001/08/17 13:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\mraid35x.sys -- (mraid35x)
DRV - [2001/08/17 13:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc.sys -- (asc)
DRV - [2001/08/17 13:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc3550.sys -- (asc3550)
DRV - [2001/08/17 13:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\aliide.sys -- (AliIde)
DRV - [2001/08/17 13:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\cmdide.sys -- (CmdIde)
DRV - [1999/09/10 12:06:00 | 000,025,244 | R--- | M] (Adaptec) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\ASPI32.sys -- (Aspi32)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Start Page = [You must be registered and logged in to see this link.]
IE - HKLM\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Google
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultURL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - Reg Error: Key error. File not found
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:5643
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Ask"
FF - prefs.js..browser.search.defaulturl: "http://www.google.com/search?lr=&ie=UTF-8&oe=UTF-8&q="
FF - prefs.js..browser.search.order.1: "Ask"
FF - prefs.js..browser.startup.homepage: "http://www.google.com/webhp?hl=en"
FF - prefs.js..extensions.enabledItems: {6502847E-AD16-4D91-867A-4009295CF7C6}:1.9.1
FF - prefs.js..extensions.enabledItems: {3D8B6F79-97D7-40A1-85BB-DD2902F64883}:1.9.1
FF - prefs.js..keyword.URL: "http://toolbar.ask.com/toolbarv/askRedirect?o=101761&gct=&gc=1&q="
FF - HKLM\software\mozilla\Firefox\extensions\\{6502847E-AD16-4D91-867A-4009295CF7C6}: C:\Documents and Settings\Rob\Local Settings\Application Data\{6502847E-AD16-4D91-867A-4009295CF7C6} [2010/02/12 19:14:15 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\extensions\\{3D8B6F79-97D7-40A1-85BB-DD2902F64883}: C:\Documents and Settings\Administrator\Local Settings\Application Data\{3D8B6F79-97D7-40A1-85BB-DD2902F64883}\ [2010/02/15 09:23:01 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.8\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/07/26 20:39:42 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.8\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/07/26 20:39:42 | 000,000,000 | ---D | M]
[2009/04/09 00:47:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Rob\Application Data\Mozilla\Extensions
[2009/04/09 00:47:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Rob\Application Data\Mozilla\Extensions\mozswing@mozswing.org
[2010/08/02 21:04:39 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions
[2009/09/02 14:37:27 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2010/08/02 05:38:51 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
[2008/07/20 03:28:26 | 000,000,000 | ---D | M] (Yahoo! Toolbar) -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2008/10/02 17:43:56 | 000,000,000 | ---D | M] (iMacros for Firefox) -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{81BF1D23-5F17-408D-AC6B-BD6DF7CAF670}
[2009/04/08 18:46:06 | 000,000,000 | ---D | M] (ReloadEvery) -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{888d99e7-e8b5-46a3-851e-1ec45da1e644}
[2008/06/13 00:13:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\NPDyyno@dyyno.com
[2010/08/02 21:04:39 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2007/05/10 16:44:13 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Program Files\Mozilla Firefox\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
[2008/09/04 01:11:24 | 000,054,600 | ---- | M] (BitTorrent, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npbittorrent.dll
[2009/04/09 16:18:04 | 000,151,552 | ---- | M] (PopCap Games) -- C:\Program Files\Mozilla Firefox\plugins\nppopcaploader.dll
O1 HOSTS File: ([2007/05/21 22:42:33 | 000,000,023 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (C:\WINDOWS\system32\qvedt7.dll) - {A3BA40A2-74F0-42BD-F434-00B15A2C8953} - C:\WINDOWS\system32\qvedt7.dll ()
O3 - HKLM\..\Toolbar: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
O3 - HKLM\..\Toolbar: (no name) - {84938242-5C5B-4A55-B6B9-A1507543B418} - No CLSID value found.
O3 - HKLM\..\Toolbar: (McAfee VirusScan) - {BA52B914-B692-46c4-B683-905236F6F655} - c:\Program Files\McAfee.com\VSO\mcvsshl.dll (McAfee, Inc.)
O3 - HKLM\..\Toolbar: (no name) - {DF4E7A0C-E233-4906-B4C1-A404356541FF} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
O4 - HKLM..\Run: [AOL Spyware Protection] C:\Program Files\Common Files\AOL\AOL Spyware Protection\AOLSP Scheduler.exe ()
O4 - HKLM..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe (America Online, Inc)
O4 - HKLM..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe (Apple Inc.)
O4 - HKLM..\Run: [ATICCC] C:\Program Files\ATI Technologies\ATI.ACE\cli.exe (ATI Technologies Inc.)
O4 - HKLM..\Run: [DivXUpdate] C:\Program Files\DivX\DivX Update\DivXUpdate.exe ()
O4 - HKLM..\Run: [DLA] C:\WINDOWS\system32\DLA\DLACTRLW.EXE (Sonic Solutions)
O4 - HKLM..\Run: [DMXLauncher] C:\Program Files\Dell\Media Experience\DMXLauncher.exe ()
O4 - HKLM..\Run: [ISUSPM Startup] C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe (InstallShield Software Corporation)
O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (InstallShield Software Corporation)
O4 - HKLM..\Run: [KernelFaultCheck] File not found
O4 - HKLM..\Run: [Logitech Hardware Abstraction Layer] C:\WINDOWS\KHALMNPR.Exe (Logitech Inc.)
O4 - HKLM..\Run: [MCAgentExe] c:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc)
O4 - HKLM..\Run: [MCUpdateExe] c:\Program Files\McAfee.com\Agent\mcupdate.exe (McAfee, Inc)
O4 - HKLM..\Run: [MPFExe] C:\Program Files\McAfee.com\Personal Firewall\MpfTray.exe (McAfee Security)
O4 - HKLM..\Run: [MSKAGENTEXE] C:\Program Files\McAfee\SpamKiller\MSKAgent.exe (McAfee Inc.)
O4 - HKLM..\Run: [MSKDetectorExe] C:\Program Files\McAfee\SpamKiller\MSKDetct.exe (McAfee, Inc.)
O4 - HKLM..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe (Nero AG)
O4 - HKLM..\Run: [OASClnt] C:\Program Files\McAfee.com\VSO\oasclnt.exe (McAfee, Inc.)
O4 - HKLM..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe (RealNetworks, Inc.)
O4 - HKLM..\Run: [SigmatelSysTrayApp] C:\WINDOWS\stsystra.exe (SigmaTel, Inc.)
O4 - HKLM..\Run: [Sony Ericsson PC Suite] C:\Program Files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe ()
O4 - HKLM..\Run: [sylcysre] C:\Documents and Settings\Rob\Local Settings\Application Data\jqyuwnusn\xexcfqitssd.exe ()
O4 - HKLM..\Run: [UserFaultCheck] File not found
O4 - HKLM..\Run: [VirusScan Online] C:\Program Files\McAfee.com\VSO\mcvsshld.exe (McAfee, Inc.)
O4 - HKLM..\Run: [VSOCheckTask] C:\Program Files\McAfee.com\VSO\mcmnhdlr.exe (McAfee, Inc.)
O4 - HKLM..\Run: [Ysegonejiqa] C:\WINDOWS\ajovupoqoxevuqa.DLL ()
O4 - HKCU..\Run: [{FF40DE1A-23CC-2F08-F36F-60B8E5FCF148}] C:\Documents and Settings\Rob\Application Data\Heriih\toup.exe (Wocrq Zpxzwf Ca Yv)
O4 - HKCU..\Run: [ahai2kjndfdfkjhsioudghd] C:\Documents and Settings\Rob\Local Settings\Temp\nvsvc32.exe ()
O4 - HKCU..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe (Nero AG)
O4 - HKCU..\Run: [BitTorrent DNA] C:\Program Files\DNA\btdna.exe (BitTorrent, Inc.)
O4 - HKCU..\Run: [DAEMON Tools Pro Agent] C:\Program Files\DAEMON Tools Pro\DTProAgent.exe (DT Soft Ltd)
O4 - HKCU..\Run: [hsehf98u34i9tjioaugy987iuegdsg] C:\Documents and Settings\Rob\Local Settings\Temp\smss.exe ()
O4 - HKCU..\Run: [hsf87efjhdsf87f3jfsdi7fhsujfd] C:\Documents and Settings\Rob\Local Settings\Temp\nvsvc32.exe ()
O4 - HKCU..\Run: [hsfe8owijfisjhgs7ye39gjsoighsd7y3eu] C:\Documents and Settings\Rob\Local Settings\Temp\j9o5vm23.exe ()
O4 - HKCU..\Run: [hsfg9w8gujsokgahi8gysgnsdgefshyjy] C:\Documents and Settings\Rob\Local Settings\Temp\install.exe ()
O4 - HKCU..\Run: [mcexecwin] C:\Documents and Settings\Rob\Local Settings\Temp\oggdw96sx.dll ()
O4 - HKCU..\Run: [Rainlendar2] C:\Program Files\Rainlendar2\Rainlendar2.exe ()
O4 - HKCU..\Run: [Remote System Protection] C:\WINDOWS\System32\qvedt7.DLL ()
O4 - HKCU..\Run: [sdr8gdrgdrgke49orkgsjkjfjhsd] C:\Documents and Settings\Rob\Local Settings\Temp\wininst.exe ()
O4 - HKCU..\Run: [Steam] c:\program files\steam\steam.exe (Valve Corporation)
O4 - HKCU..\Run: [sylcysre] C:\Documents and Settings\Rob\Local Settings\Application Data\jqyuwnusn\xexcfqitssd.exe ()
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe (Adobe Systems Incorporated)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Dell Network Assistant.lnk = C:\WINDOWS\Installer\{0240BDFB-2995-4A3F-8C96-18D41282B716}\Icon0240BDFB3.exe ()
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe (Logitech Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\NETGEAR WPN111 Smart Wizard.lnk = C:\Program Files\NETGEAR\WPN111\WPN111.exe (NETGEAR)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Rainmeter.lnk = C:\Program Files\Rainmeter\Rainmeter.exe ()
O4 - Startup: C:\Documents and Settings\Rob\Start Menu\Programs\Startup\Stardock ObjectDock.lnk = C:\Program Files\Stardock\ObjectDock\ObjectDock.exe (Stardock)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 0
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoFolderOptions = 1
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableRegistryTools = 1
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll (Google Inc.)
O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : McAfee AntiPhishing Filter - {39FD89BF-D3F1-45b6-BB56-3582CCF489E1} - c:\Program Files\McAfee\SpamKiller\McApfBHO.dll (McAfee, Inc.)
O15 - HKLM\..Trusted Domains: buy-internetsecurity10.com ([]http in Trusted sites)
O15 - HKLM\..Trusted Domains: buy-is2010.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: buy-internetsecurity10.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: buy-is2010.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: is10-soft-download.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: is-software-download.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: is-software-download25.com ([]http in Trusted sites)
O16 - DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} [You must be registered and logged in to see this link.] (SpinTop DRM Control)
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} [You must be registered and logged in to see this link.] (Windows Genuine Advantage Validation Tool)
O16 - DPF: {233C1507-6A77-46A4-9443-F871F945D258} [You must be registered and logged in to see this link.] (Shockwave ActiveX Control)
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} [You must be registered and logged in to see this link.] (McAfee.com Operating System Class)
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} [You must be registered and logged in to see this link.] (DivXBrowserPlugin Object)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_14)
O16 - DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_14)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_14)
O16 - DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} [You must be registered and logged in to see this link.] (ArmHelper Control)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 212.159.13.49 212.159.13.50
O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-internet-signup {A173B69A-1F9B-4823-9FDA-412F641E65D6} - C:\Program Files\Tiscali\Tiscali Internet\dlls\tiscalifilter.dll ()
O21 - SSODL: eitheror - {2016a466-91a2-43c6-97d8-2fd380f065ef} - CLSID or File not found.
O22 - SharedTaskScheduler: {1984DD45-52CF-49cd-AB77-18F378FEA264} - FencesShellExt - C:\Program Files\Stardock\Fences\FencesMenu.dll (Stardock)
O22 - SharedTaskScheduler: {2016a466-91a2-43c6-97d8-2fd380f065ef} - eitheror - Reg Error: Key error. File not found
O22 - SharedTaskScheduler: {A3BA40A2-74F0-42BD-F434-00B15A2C8953} - 7whfiudhf8s7f3oifhif7syfdhsof - C:\WINDOWS\system32\qvedt7.dll ()
O22 - SharedTaskScheduler: {C7BA40A1-74F2-52BD-F411-04B15A2C8953} - har98fefiesjfs93s8i9sejsdf - C:\WINDOWS\system32\y0azio.dll ()
O24 - Desktop WallPaper: C:\Documents and Settings\Rob\Local Settings\Application Data\Stardock\Fences\SolidColorBackgrounds\2\Solid Color.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Rob\Local Settings\Application Data\Stardock\Fences\SolidColorBackgrounds\2\Solid Color.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2004/08/10 13:04:08 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O32 - AutoRun File - [2004/08/04 13:00:00 | 000,000,110 | R--- | M] () - E:\AUTORUN.INF -- [ CDFS ]
O33 - MountPoints2\{0aa145b1-c920-11dc-8874-00184d36134e}\Shell - "" = AutoRun
O33 - MountPoints2\{0aa145b1-c920-11dc-8874-00184d36134e}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{55d07e11-5e42-11dd-891a-00184d36134e}\Shell\AutoRun\command - "" = G:\AutoTransfer.exe -- File not found
O33 - MountPoints2\{66f8fbde-ff83-11dd-89fe-00184d36134e}\Shell - "" = AutoRun
O33 - MountPoints2\{66f8fbde-ff83-11dd-89fe-00184d36134e}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{82f62235-180a-11df-8aca-00184d36134e}\Shell - "" = AutoRun
O33 - MountPoints2\{82f62235-180a-11df-8aca-00184d36134e}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{8642bc71-11d9-11df-8ac8-00184d36134e}\Shell - "" = AutoRun
O33 - MountPoints2\{8642bc71-11d9-11df-8ac8-00184d36134e}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{903a3fbc-f2f2-11de-8ab4-806d6172696f}\Shell - "" = AutoRun
O33 - MountPoints2\{903a3fbc-f2f2-11de-8ab4-806d6172696f}\Shell\AutoRun - "" = Auto&Play
[2010/08/04 03:05:12 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\SeaPort
[2010/08/04 00:50:50 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\InstallShield Installation Information
[2010/08/03 22:52:30 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Rob\My Documents\My Webs
[2010/08/02 08:43:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Rob\Local Settings\Application Data\jqyuwnusn
[2010/07/27 14:54:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Rob\Local Settings\Application Data\Windows Server
[2010/07/23 19:52:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Norton
[2010/07/23 19:52:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\NortonInstaller
[2010/07/14 17:04:30 | 000,743,936 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\dllcache\helpsvc.exe
[3 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[1 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\Documents and Settings\Rob\My Documents\*.tmp files -> C:\Documents and Settings\Rob\My Documents\*.tmp -> ]
[2010/08/07 14:38:07 | 022,020,096 | -H-- | M] () -- C:\Documents and Settings\Rob\NTUSER.DAT
[2010/08/07 14:36:56 | 000,002,333 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Dell Network Assistant.lnk
[2010/08/07 14:36:40 | 000,118,336 | ---- | M] () -- C:\WINDOWS\System32\Status.MPF
[2010/08/07 14:35:26 | 000,000,346 | ---- | M] () -- C:\WINDOWS\tasks\McAfee.com Scan for Viruses - My Computer (ROBS_PC-Rob).job
[2010/08/07 14:35:14 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/08/07 14:35:09 | 000,000,880 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/08/07 14:33:27 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/08/07 14:33:15 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/08/07 14:33:05 | 1072,156,672 | -HS- | M] () -- C:\hiberfil.sys
[2010/08/03 22:52:55 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Rob\ntuser.ini
[2010/08/03 20:27:29 | 000,188,200 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2010/08/03 20:08:45 | 000,002,279 | ---- | M] () -- C:\Documents and Settings\Rob\My Documents\vba1.ini
[2010/08/03 19:13:00 | 000,000,884 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/08/03 10:12:33 | 000,000,107 | ---- | M] () -- C:\Documents and Settings\Rob\default.pls
[2010/08/03 10:09:53 | 000,000,069 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
[2010/08/03 02:04:08 | 000,043,576 | ---- | M] () -- C:\Documents and Settings\Rob\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
[2010/08/03 01:58:09 | 000,000,000 | ---- | M] () -- C:\WINDOWS\Ahucihehafileyo.dat
[2010/08/02 07:56:04 | 000,030,000 | ---- | M] () -- C:\WINDOWS\System32\lmvji.dll
[2010/07/31 20:59:03 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/07/31 04:31:36 | 000,000,151 | ---- | M] () -- C:\WINDOWS\PhotoSnapViewer.INI
[2010/07/25 14:45:41 | 000,003,584 | -H-- | M] () -- C:\Documents and Settings\Rob\Application Data\dvd.bmk
[2010/07/23 16:45:44 | 000,001,463 | ---- | M] () -- C:\Documents and Settings\Rob\Desktop\DivX Movies.lnk
[2010/07/23 16:45:25 | 000,000,777 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\DivX Plus Player.lnk
[2010/07/20 18:41:31 | 000,043,520 | ---- | M] () -- C:\Documents and Settings\Rob\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/07/16 11:35:47 | 000,001,503 | ---- | M] () -- C:\Documents and Settings\Rob\My Documents\Paint.lnk
[2010/07/10 14:11:57 | 000,000,000 | ---- | M] () -- C:\WINDOWS\Mjebupiyepete.bin
[2010/07/09 00:06:28 | 000,004,096 | ---- | M] () -- C:\WINDOWS\System32\drivers\nocashio.sys
rob864
Post by rob864 on Sun 08 Aug 2010, 1:38 am
Part 2 of OTL.txt
[2010/08/03 22:56:13 | 1072,156,672 | -HS- | C] () -- C:\hiberfil.sys
[2010/08/02 07:56:04 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\lmvji.dll
[2010/07/23 16:45:25 | 000,000,777 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\DivX Plus Player.lnk
[2010/07/16 11:33:20 | 000,930,685 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\198-199.png
[2010/07/16 11:33:20 | 000,534,085 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\200.png
[2010/07/16 11:33:19 | 001,186,907 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\196-197.png
[2010/07/16 11:33:19 | 000,939,516 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\194.jpg
[2010/07/16 11:33:19 | 000,868,853 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\195.jpg
[2010/07/16 11:33:19 | 000,747,116 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\193.png
[2010/07/16 11:33:19 | 000,710,927 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\192.png
[2010/07/16 11:33:19 | 000,370,227 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\191.png
[2010/07/16 11:33:18 | 001,043,094 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\182-183.png
[2010/07/16 11:33:18 | 000,808,099 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\176.png
[2010/07/16 11:33:18 | 000,757,767 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\174.png
[2010/07/16 11:33:18 | 000,710,081 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\190.png
[2010/07/16 11:33:18 | 000,625,017 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\175.png
[2010/07/16 11:33:18 | 000,615,933 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\154-155.png
[2010/07/16 11:33:18 | 000,592,741 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\185.png
[2010/07/16 11:33:18 | 000,586,876 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\178.png
[2010/07/16 11:33:18 | 000,585,828 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\181.png
[2010/07/16 11:33:18 | 000,546,605 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\166.png
[2010/07/16 11:33:18 | 000,532,899 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\177.png
[2010/07/16 11:33:18 | 000,515,850 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\186.png
[2010/07/16 11:33:18 | 000,514,471 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\167.png
[2010/07/16 11:33:18 | 000,448,668 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\184.png
[2010/07/16 11:33:18 | 000,438,348 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\179.png
[2010/07/16 11:33:18 | 000,431,318 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\180.png
[2010/07/16 11:33:18 | 000,405,704 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\172.png
[2010/07/16 11:33:18 | 000,392,133 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\152.png
[2010/07/16 11:33:18 | 000,363,793 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\188.png
[2010/07/16 11:33:18 | 000,357,589 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\170.png
[2010/07/16 11:33:18 | 000,354,586 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\187.png
[2010/07/16 11:33:18 | 000,351,200 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\173.png
[2010/07/16 11:33:18 | 000,343,369 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\171.png
[2010/07/16 11:33:18 | 000,334,572 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\143.png
[2010/07/16 11:33:18 | 000,316,494 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\146.png
[2010/07/16 11:33:18 | 000,314,804 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\189.png
[2010/07/16 11:33:18 | 000,313,154 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\156.png
[2010/07/16 11:33:18 | 000,305,148 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\151.png
[2010/07/16 11:33:18 | 000,296,866 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\157.png
[2010/07/16 11:33:18 | 000,291,842 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\150.png
[2010/07/16 11:33:18 | 000,280,945 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\153.png
[2010/07/16 11:33:18 | 000,256,777 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\164.png
[2010/07/16 11:33:18 | 000,246,776 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\147.png
[2010/07/16 11:33:18 | 000,246,359 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\148.png
[2010/07/16 11:33:18 | 000,232,068 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\165.png
[2010/07/16 11:33:18 | 000,227,084 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\163.png
[2010/07/16 11:33:18 | 000,221,840 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\161.png
[2010/07/16 11:33:18 | 000,221,203 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\149.png
[2010/07/16 11:33:18 | 000,220,177 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\144-145.png
[2010/07/16 11:33:18 | 000,208,885 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\158-159.png
[2010/07/16 11:33:18 | 000,202,810 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\162.png
[2010/07/16 11:33:18 | 000,198,425 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\160.png
[2010/07/16 11:33:18 | 000,189,403 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\168-169.png
[2010/07/16 11:33:17 | 000,633,389 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\132-133.png
[2010/07/16 11:33:17 | 000,475,501 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\137.png
[2010/07/16 11:33:17 | 000,470,793 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\140-141.png
[2010/07/16 11:33:17 | 000,424,994 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\131.png
[2010/07/16 11:33:17 | 000,413,526 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\142.png
[2010/07/16 11:33:17 | 000,393,360 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\139.png
[2010/07/16 11:33:17 | 000,360,199 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\130.png
[2010/07/16 11:33:17 | 000,334,341 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\136.png
[2010/07/16 11:33:17 | 000,290,268 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\138.png
[2010/07/16 11:33:17 | 000,288,913 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\135.png
[2010/07/16 11:33:17 | 000,288,413 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\134.png
[2010/07/16 11:33:16 | 000,966,875 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\122-123.png
[2010/07/16 11:33:16 | 000,908,743 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\128-129.png
[2010/07/16 11:33:16 | 000,480,847 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\120.png
[2010/07/16 11:33:16 | 000,371,031 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\117.png
[2010/07/16 11:33:16 | 000,351,094 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\121.png
[2010/07/16 11:33:16 | 000,342,435 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\118.png
[2010/07/16 11:33:16 | 000,333,907 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\124.png
[2010/07/16 11:33:16 | 000,331,864 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\126.png
[2010/07/16 11:33:16 | 000,304,652 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\119.png
[2010/07/16 11:33:16 | 000,294,344 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\125.png
[2010/07/16 11:33:16 | 000,292,595 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\127.png
[2010/07/16 11:33:15 | 000,992,849 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\087.png
[2010/07/16 11:33:15 | 000,983,399 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\084.png
[2010/07/16 11:33:15 | 000,854,988 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\080-081.png
[2010/07/16 11:33:15 | 000,851,889 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\086.png
[2010/07/16 11:33:15 | 000,794,127 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\096.png
[2010/07/16 11:33:15 | 000,789,751 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\089.jpg
[2010/07/16 11:33:15 | 000,744,312 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\091.jpg
[2010/07/16 11:33:15 | 000,690,328 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\088.jpg
[2010/07/16 11:33:15 | 000,677,721 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\100.png
[2010/07/16 11:33:15 | 000,672,828 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\090.jpg
[2010/07/16 11:33:15 | 000,647,238 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\111.png
[2010/07/16 11:33:15 | 000,631,397 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\085.jpg
[2010/07/16 11:33:15 | 000,611,079 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\083.png
[2010/07/16 11:33:15 | 000,609,984 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\101.png
[2010/07/16 11:33:15 | 000,556,558 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\112.png
[2010/07/16 11:33:15 | 000,553,968 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\099.png
[2010/07/16 11:33:15 | 000,470,497 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\115.png
[2010/07/16 11:33:15 | 000,468,753 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\093.png
[2010/07/16 11:33:15 | 000,439,965 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\097.png
[2010/07/16 11:33:15 | 000,434,344 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\105.png
[2010/07/16 11:33:15 | 000,430,764 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\116.png
[2010/07/16 11:33:15 | 000,411,595 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\106.png
[2010/07/16 11:33:15 | 000,404,655 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\113.png
[2010/07/16 11:33:15 | 000,400,174 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\104.png
[2010/07/16 11:33:15 | 000,377,022 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\098.png
[2010/07/16 11:33:15 | 000,355,124 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\094.png
[2010/07/16 11:33:15 | 000,351,534 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\114.png
[2010/07/16 11:33:15 | 000,351,426 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\103.png
[2010/07/16 11:33:15 | 000,350,589 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\082.png
[2010/07/16 11:33:15 | 000,343,006 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\102.png
[2010/07/16 11:33:15 | 000,338,182 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\092.png
[2010/07/16 11:33:15 | 000,333,788 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\095.png
[2010/07/16 11:33:15 | 000,327,473 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\108.png
[2010/07/16 11:33:15 | 000,320,494 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\110.png
[2010/07/16 11:33:15 | 000,308,087 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\109.png
[2010/07/16 11:33:15 | 000,307,737 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\107.png
[2010/07/16 11:33:14 | 000,596,373 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\077.png
[2010/07/16 11:33:14 | 000,444,127 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\078.png
[2010/07/16 11:33:14 | 000,379,070 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\079.png
[2010/07/16 11:33:14 | 000,307,788 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\076.png
[2010/07/16 11:33:13 | 000,883,141 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\063.png
[2010/07/16 11:33:13 | 000,754,137 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\051.png
[2010/07/16 11:33:13 | 000,579,063 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\054.png
[2010/07/16 11:33:13 | 000,475,288 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\066.png
[2010/07/16 11:33:13 | 000,473,420 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\071.png
[2010/07/16 11:33:13 | 000,467,338 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\065.png
[2010/07/16 11:33:13 | 000,448,021 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\064.png
[2010/07/16 11:33:13 | 000,443,844 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\068.png
[2010/07/16 11:33:13 | 000,442,668 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\073.png
[2010/07/16 11:33:13 | 000,434,358 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\050.png
[2010/07/16 11:33:13 | 000,431,422 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\070.png
[2010/07/16 11:33:13 | 000,429,083 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\072.png
[2010/07/16 11:33:13 | 000,418,356 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\067.png
[2010/07/16 11:33:13 | 000,409,581 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\057.png
[2010/07/16 11:33:13 | 000,405,489 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\069.png
[2010/07/16 11:33:13 | 000,401,424 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\055.png
[2010/07/16 11:33:13 | 000,386,355 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\046.png
[2010/07/16 11:33:13 | 000,381,052 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\062.png
[2010/07/16 11:33:13 | 000,363,519 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\052.png
[2010/07/16 11:33:13 | 000,358,111 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\058.png
[2010/07/16 11:33:13 | 000,357,878 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\056.png
[2010/07/16 11:33:13 | 000,352,962 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\075.png
[2010/07/16 11:33:13 | 000,345,905 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\044.png
[2010/07/16 11:33:13 | 000,344,357 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\045.png
[2010/07/16 11:33:13 | 000,335,542 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\059.png
[2010/07/16 11:33:13 | 000,309,254 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\061.png
[2010/07/16 11:33:13 | 000,305,038 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\060.png
[2010/07/16 11:33:13 | 000,288,438 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\053.png
[2010/07/16 11:33:13 | 000,283,600 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\047.png
[2010/07/16 11:33:13 | 000,239,860 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\074.png
[2010/07/16 11:33:13 | 000,118,277 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\048.png
[2010/07/16 11:33:13 | 000,117,464 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\049.png
[2010/07/16 11:33:12 | 001,576,233 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\028-029.png
[2010/07/16 11:33:12 | 001,188,697 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\026-027.png
[2010/07/16 11:33:12 | 000,794,815 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\037.png
[2010/07/16 11:33:12 | 000,707,011 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\043.png
[2010/07/16 11:33:12 | 000,675,483 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\030.jpg
[2010/07/16 11:33:12 | 000,641,592 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\022-023.png
[2010/07/16 11:33:12 | 000,615,689 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\035.png
[2010/07/16 11:33:12 | 000,606,236 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\033.png
[2010/07/16 11:33:12 | 000,572,400 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\034.png
[2010/07/16 11:33:12 | 000,494,134 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\021.png
[2010/07/16 11:33:12 | 000,485,020 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\031.png
[2010/07/16 11:33:12 | 000,465,484 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\015.png
[2010/07/16 11:33:12 | 000,465,288 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\042.png
[2010/07/16 11:33:12 | 000,457,934 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\032.png
[2010/07/16 11:33:12 | 000,443,906 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\025.png
[2010/07/16 11:33:12 | 000,438,598 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\038.png
[2010/07/16 11:33:12 | 000,391,042 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\017.png
[2010/07/16 11:33:12 | 000,361,861 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\024.png
[2010/07/16 11:33:12 | 000,351,704 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\019.png
[2010/07/16 11:33:12 | 000,346,443 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\014.png
[2010/07/16 11:33:12 | 000,345,154 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\020.png
[2010/07/16 11:33:12 | 000,344,842 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\040.png
[2010/07/16 11:33:12 | 000,338,524 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\041.png
[2010/07/16 11:33:12 | 000,327,514 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\039.png
[2010/07/16 11:33:12 | 000,318,591 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\018.png
[2010/07/16 11:33:12 | 000,310,830 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\013.png
[2010/07/16 11:33:12 | 000,296,935 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\016.png
[2010/07/16 11:33:12 | 000,285,240 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\011.png
[2010/07/16 11:33:12 | 000,274,979 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\012.png
[2010/07/16 11:33:12 | 000,267,573 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\036.png
[2010/07/16 11:33:12 | 000,250,352 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\010.png
[2010/07/16 11:33:12 | 000,249,757 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\008.png
[2010/07/16 11:33:12 | 000,229,751 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\004-005.png
[2010/07/16 11:33:12 | 000,226,174 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\009.png
[2010/07/16 11:33:12 | 000,212,241 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\006.png
[2010/07/16 11:33:12 | 000,211,352 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\007.png
[2010/07/16 11:33:11 | 000,800,200 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\000a-001.png
[2010/07/16 11:33:11 | 000,709,567 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\000.jpg
[2010/07/16 11:33:11 | 000,530,402 | ---- | C] () -- C:\Documents and Settings\Rob\My Documents\002-003.png
[2010/07/09 00:06:28 | 000,004,096 | ---- | C] () -- C:\WINDOWS\System32\drivers\nocashio.sys
[2010/05/19 14:26:31 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\bri5b913.dll
[2010/05/19 12:09:41 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\smqdzle.dll
[2010/05/19 01:23:43 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\q7032w.dll
[2010/05/19 00:34:44 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\rk67xrw.dll
[2010/05/18 22:14:14 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\ho4ndjbsu.dll
[2010/05/18 15:09:37 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\t6ymgwvuzk.dll
[2010/05/18 12:47:28 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\kwok5s.dll
[2010/05/18 06:09:53 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\y0azio.dll
[2010/05/18 03:49:10 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\rrh7v.dll
[2010/05/18 01:28:13 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\mcuuxpbs.dll
[2010/05/17 23:07:35 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\xlt89.dll
[2010/05/17 20:46:56 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\x8bwdetn3x.dll
[2010/05/17 18:26:26 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\va7jms3j75.dll
[2010/05/17 16:05:30 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\d5ytv35.dll
[2010/05/17 11:24:31 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\niqscu.dll
[2010/05/17 09:04:06 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\tc5d5.dll
[2010/05/17 06:44:25 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\asmcu4fbq.dll
[2010/04/03 06:20:56 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
[2010/03/20 22:41:57 | 000,001,156 | ---- | C] () -- C:\WINDOWS\SSPRO.INI
[2010/02/14 03:25:35 | 000,020,000 | ---- | C] () -- C:\WINDOWS\System32\qvedt7.dll
[2010/02/08 15:00:19 | 000,000,151 | ---- | C] () -- C:\WINDOWS\PhotoSnapViewer.INI
[2009/10/28 22:25:40 | 000,000,029 | ---- | C] () -- C:\WINDOWS\AlphaPlayer.INI
[2009/03/22 11:48:15 | 000,721,904 | ---- | C] () -- C:\WINDOWS\System32\drivers\sptd.sys
[2009/03/07 01:33:17 | 000,000,069 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
[2008/11/06 17:34:00 | 000,000,416 | ---- | C] () -- C:\WINDOWS\System32\dtu100.dll.manifest
[2008/06/11 01:07:20 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
[2008/03/15 02:41:20 | 000,000,000 | ---- | C] () -- C:\WINDOWS\mngui.INI
[2007/09/28 20:44:01 | 000,043,520 | ---- | C] () -- C:\WINDOWS\System32\CmdLineExt03.dll
[2007/09/24 22:34:02 | 000,000,036 | ---- | C] () -- C:\WINDOWS\webica.ini
[2007/07/25 14:24:30 | 001,559,040 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
[2007/03/16 01:19:36 | 000,000,216 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
[2006/12/29 21:11:51 | 000,000,088 | RHS- | C] () -- C:\WINDOWS\System32\0CE0BC7103.sys
[2006/12/19 20:13:00 | 000,000,056 | RHS- | C] () -- C:\WINDOWS\System32\0371BCE00C.sys
[2006/10/05 18:30:05 | 000,000,248 | ---- | C] () -- C:\WINDOWS\RomeTW.ini
[2006/10/01 14:44:07 | 000,006,580 | -HS- | C] () -- C:\WINDOWS\System32\KGyGaAvL.sys
[2006/09/30 15:50:04 | 000,147,456 | ---- | C] () -- C:\WINDOWS\System32\ssleay32.dll
[2006/09/30 15:50:03 | 000,651,264 | ---- | C] () -- C:\WINDOWS\System32\libeay32.dll
[2006/09/29 19:42:11 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2006/09/27 14:43:12 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2006/09/27 14:36:37 | 000,000,126 | ---- | C] () -- C:\WINDOWS\wininit.ini
[2006/09/27 14:31:21 | 000,712,704 | ---- | C] () -- C:\WINDOWS\System32\DellSystemRestore.dll
[2006/09/27 14:09:34 | 000,000,477 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
[2006/02/26 15:08:28 | 000,585,728 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
[2005/11/10 08:56:34 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
[2004/08/18 14:00:00 | 000,032,256 | -H-- | C] () -- C:\WINDOWS\System32\msls51.dll
[2004/08/10 13:12:05 | 000,000,780 | ---- | C] () -- C:\WINDOWS\orun32.ini
[2004/08/10 13:01:18 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
[2004/08/10 12:51:27 | 000,152,064 | ---- | C] () -- C:\WINDOWS\ajovupoqoxevuqa.dll
[2002/10/15 23:54:04 | 000,153,088 | ---- | C] () -- C:\WINDOWS\System32\unrar.dll
[2002/08/01 16:35:04 | 000,002,831 | ---- | C] () -- C:\WINDOWS\wavemix.ini
[1999/03/22 02:00:00 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\MSRTEDIT.DLL
[1997/06/14 01:56:08 | 000,056,832 | ---- | C] () -- C:\WINDOWS\System32\iyvu9_32.dll
@Alternate Data Stream - 134 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:BEB71B81
@Alternate Data Stream - 125 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:CAAA7DD7
@Alternate Data Stream - 124 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:63238B95
@Alternate Data Stream - 123 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:8AD27A66
@Alternate Data Stream - 123 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:57DC3B52
@Alternate Data Stream - 118 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:E758E1CB
@Alternate Data Stream - 106 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:C7F04040
Extras.txt
OTL Extras logfile created on: 07/08/2010 14:51:41 - Run 1
OTL by OldTimer - Version 3.2.9.1 Folder = F:\
Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
1,022.00 Mb Total Physical Memory | 210.00 Mb Available Physical Memory | 21.00% Memory free
2.00 Gb Paging File | 2.00 Gb Available in Paging File | 76.00% Paging File free
Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
Drive C: | 108.57 Gb Total Space | 3.08 Gb Free Space | 2.84% Space Free | Partition Type: NTFS
Drive D: | 37.23 Gb Total Space | 37.16 Gb Free Space | 99.83% Space Free | Partition Type: NTFS
Drive E: | 581.97 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
Drive F: | 1.86 Gb Total Space | 1.86 Gb Free Space | 99.96% Space Free | Partition Type: FAT
Computer Name: ROBS_PC
Current User Name: Rob
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [edit] -- "C:\Program Files\Microsoft Office\Office\msohtmed.exe" %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"AntiVirusOverride" = 1
"FirewallOverride" = 1
"AntiVirusDisableNotify" = 1
"FirewallDisableNotify" = 1
"UpdatesDisableNotify" = 0
"DisableMonitoring" = 1
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"DisableNotifications" = 1
"1900:UDP" = 1900:UDP:LocalSubNet:Disabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Disabled:@xpsp2res.dll,-22008
"C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL -- (America Online, Inc)
"C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL -- (America Online, Inc.)
"C:\Program Files\AOL 9.0\waol.exe" = C:\Program Files\AOL 9.0\waol.exe:*:Enabled:AOL 9.0 -- (America Online, Inc.)
"C:\Program Files\Windows Live\Messenger\wlcsdk.exe" = C:\Program Files\Windows Live\Messenger\wlcsdk.exe:*:Enabled:Windows Live Call -- (Microsoft Corporation)
"C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe" = C:\Program Files\Windows Live\Sync\WindowsLiveSync.exe:*:Enabled:Windows Live Sync -- (Microsoft Corporation)
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- (Lime Wire, LLC)
"C:\Program Files\Steam\Steam.exe" = C:\Program Files\Steam\Steam.exe:*:Enabled:Steam Client -- (Valve Corporation)
"C:\Program Files\Veoh Networks\Veoh\VeohClient.exe" = C:\Program Files\Veoh Networks\Veoh\VeohClient.exe:*:Disabled:Veoh Client -- File not found
"C:\Program Files\Dell Network Assistant\ezi_hnm2.exe" = C:\Program Files\Dell Network Assistant\ezi_hnm2.exe:*:Disabled:Home Networking Application -- (SingleClick Systems)
"C:\World of Warcraft\Repair.exe" = C:\World of Warcraft\Repair.exe:*:Enabled:Blizzard Repair Utility -- File not found
"C:\Program Files\Steam\steamapps\rob399\team fortress 2\hl2.exe" = C:\Program Files\Steam\steamapps\rob399\team fortress 2\hl2.exe:*:Enabled:hl2 -- ()
"C:\Program Files\Wyzo\wyzo.exe" = C:\Program Files\Wyzo\wyzo.exe:*:Enabled:Wyzo -- File not found
"C:\Program Files\VentSrv\ventrilo_srv.exe" = C:\Program Files\VentSrv\ventrilo_srv.exe:*:Enabled:ventrilo_srv -- ()
"C:\Program Files\Tortun\gui.exe" = C:\Program Files\Tortun\gui.exe:*:Enabled:gui -- ()
"C:\Program Files\uTorrent\uTorrent.exe" = C:\Program Files\uTorrent\uTorrent.exe:*:Enabled:µTorrent -- (BitTorrent, Inc.)
"C:\Documents and Settings\Rob\Local Settings\Application Data\Dyyno Receiver\DPPM.exe" = C:\Documents and Settings\Rob\Local Settings\Application Data\Dyyno Receiver\DPPM.exe:*:Enabled:Dyyno P2P Receiver -- ()
"C:\Program Files\Common Files\PocketSoft\RTPatch\AutoRTP\artpschd.exe" = C:\Program Files\Common Files\PocketSoft\RTPatch\AutoRTP\artpschd.exe:*:Enabled:artpschd -- File not found
"C:\Program Files\Electronic Arts\EADM\Core.exe" = C:\Program Files\Electronic Arts\EADM\Core.exe:*:Enabled:EA Download Manager -- File not found
"C:\Program Files\BitTorrent\bittorrent.exe" = C:\Program Files\BitTorrent\bittorrent.exe:*:Enabled:BitTorrent -- (BitTorrent, Inc.)
"C:\Program Files\Steam\steamapps\common\peggle deluxe\Peggle.exe" = C:\Program Files\Steam\steamapps\common\peggle deluxe\Peggle.exe:*:Enabled:Peggle Deluxe Demo -- ()
"C:\Program Files\Steam\steamapps\common\peggle extreme\PeggleExtreme.exe" = C:\Program Files\Steam\steamapps\common\peggle extreme\PeggleExtreme.exe:*:Enabled:Peggle Extreme -- ()
"C:\Program Files\Age Of Empires 2 & The Conquerors Expansion - Full Game\age2_x1.exe" = C:\Program Files\Age Of Empires 2 & The Conquerors Expansion - Full Game\age2_x1.exe:*:Enabled:Age of Empires II Expansion -- (Microsoft Corporation)
"C:\Documents and Settings\Rob\My Documents\utorrent.exe" = C:\Documents and Settings\Rob\My Documents\utorrent.exe:*:Enabled:µTorrent -- (BitTorrent, Inc.)
"C:\Program Files\DNA\btdna.exe" = C:\Program Files\DNA\btdna.exe:*:Enabled:DNA -- (BitTorrent, Inc.)
"{00000409-78E1-11D2-B60F-006097C998E7}" = Microsoft Office 2000 Premium
"{0240BDFB-2995-4A3F-8C96-18D41282B716}" = Dell Network Assistant
"{048298C9-A4D3-490B-9FF9-AB023A9238F3}" = Steam
"{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
"{075473F5-846A-448B-BCB3-104AA1760205}" = Roxio RecordNow Data
"{10CD364B-FFCC-48BE-B469-B9622A033075}" = Fences
"{1206EF92-2E83-4859-ACCB-2048C3CB7DA6}" = Roxio DLA
"{12760E10-1413-4B35-91F4-7F5EB692B6E9}" = Autograph 3.20 (30-day)
"{139E303E-1050-497F-98B1-9AE87B15C463}" = Windows Live Family Safety
"{13F3917B56CD4C25848BDC69916971BB}" = DivX Converter
"{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
"{1D3C662A-F6C6-4767-A788-7AA43A9A1317}" = ARTEuro
"{1D46A3A0-B37D-423A-91C2-101A49E2FF80}" = Ventrilo Server
"{21657574-BD54-48A2-9450-EB03B2C7FC29}" = Roxio MyDVD LE
"{26A24AE4-039D-4CA4-87B4-2F83216012FF}" = Java(TM) 6 Update 14
"{2CA41BA1-9842-4819-8ABB-76FDC14AB9EA}" = ATI Catalyst Control Center
"{2CCBABCB-6427-4A55-B091-49864623C43F}" = Google Toolbar for Firefox
"{2E8EAC71-BFE4-417A-88F0-5A1BDFBCF5D3}" = Logitech SetPoint
"{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Sonic Update Manager
"{3248F0A8-6813-11D6-A77B-00B0D0150060}" = J2SE Runtime Environment 5.0 Update 6
"{3248F0A8-6813-11D6-A77B-00B0D0150100}" = J2SE Runtime Environment 5.0 Update 10
"{3248F0A8-6813-11D6-A77B-00B0D0160070}" = Java(TM) 6 Update 7
"{3846E811-639D-4DE1-844B-30491C0A6C0C}" = Dell Support 3.2
"{3B4E636E-9D65-4D67-BA61-189800823F52}" = Windows Live Communications Platform
"{3EE33958-7381-4E7B-A4F3-6E43098E9E9C}" = URL Assistant
"{3FC7CBBC4C1E11DCA1A752EA55D89593}" = DivX Version Checker
"{43CAC9A1-1993-4F65-9096-7C9AFC2BBF54}" = Dell CinePlayer
"{4BDFD2CE-6329-42E4-9801-9B3D1F10D79B}" = Adobe® Photoshop® Album Starter Edition 3.0
"{4CBA3D4C-8F51-4D60-B27E-F6B641C571E7}" = Microsoft Search Enhancement Pack
"{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
"{582E9125-32B6-4CBA-AB48-3E33CE3DB389}" = NETGEAR RangeMax(TM) Wireless USB 2.0 Adapter WPN111
"{58B2B6D3-E5FF-4D16-87AC-52CC5717C7C6}" = Tiscali Internet
"{5B6BE547-21E2-49CA-B2E2-6A5F470593B1}" = Sonic Activation Module
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{6D52C408-B09A-4520-9B18-475B81D393F1}" = Microsoft Works
"{74F7662C-B1DB-489E-A8AC-07A06B24978B}" = Dell System Restore
"{75AE638F-750A-11DF-96D5-005056806466}" = Google Earth Plug-in
"{789289CA-F73A-4A16-A331-54D498CE069F}" = Ventrilo Client
"{7B63B2922B174135AFC0E1377DD81EC2}" =
"{7B9CC60A-9B81-46A3-A953-76B6BF9EEC97}" = Age of Empires III
"{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{8A74E887-8F0F-4017-AF53-CBA42211AAA5}" = Microsoft Sync Framework Runtime Native v1.0 (x86)
"{8B7443F5-E141-42A0-AB61-ED2331AAD606}" = 4oD
"{8C3727F2-8E37-49E4-820C-03B1677F53B6}" = Stronghold Crusader
"{9422C8EA-B0C6-4197-B8FC-DC797658CA00}" = Windows Live Sign-in Assistant
"{995F1E2E-F542-4310-8E1D-9926F5A279B3}" = Windows Live Toolbar
"{99ECF41F-5CCA-42BD-B8B8-A8333E2E2944}" = iTunes
"{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}" = Segoe UI
"{A642BB6B-CA1D-4142-8DD4-318C3F3DC834}" = Rome - Total War(TM)
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{AAD37EE3-50A7-45DB-97B9-1C8B900E9E8B}" = Movavi Video Converter 7
"{AB708C9B-97C8-4AC9-899B-DBF226AC9382}" = Roxio RecordNow Audio
"{AC76BA86-7AD7-1033-7B44-A70800000002}" = Adobe Reader 7.0.8
"{B12665F4-4E93-4AB4-B7FC-37053B524629}" = Roxio RecordNow Copy
"{B13A7C41581B411290FBC0395694E2A9}" = DivX Converter
"{B7AC5A96-C8BC-431C-B661-27A09781DFA8}" = Wanadoo Europe Installer
"{BD64AF4A-8C80-4152-AD77-FCDDF05208AB}" = Microsoft Sync Framework Services Native v1.0 (x86)
"{BEAD39CD-901D-4267-8B8B-EAA83CB4B70D}" = Pivot Stickfigure Animator
"{C337BDAF-CB4E-47E2-BE1A-CB31BB7DD0E3}" = Apple Mobile Device Support
"{C78EAC6F-7A73-452E-8134-DBB2165C5A68}" = QuickTime
"{CF097717-F174-4144-954A-FBC4BF301033}" = Nero 7 Ultra Edition
"{CFB17307-B244-4EAD-AE8E-CDAF440477C2}" = OpenMG Secure Module 4.4.00
"{D2988E9B-C73F-422C-AD4B-A66EBE257120}" = MCU
"{D6C75F0B-3BC1-4FC9-B8C5-3F7E8ED059CA}" = Windows Live Photo Gallery
"{DDBB28C8-B2AA-45A1-8DCE-059A798509FB}" = MobileMe Control Panel
"{E2DFE069-083E-4631-9B6C-43C48E991DE5}" = Junk Mail filter update
"{E38C00D0-A68B-4318-A8A6-F7D4B5B1DF0E}" = Windows Media Encoder 9 Series
"{E9E3EE81-6E7F-47A3-8D38-3470256704DB}_is1" = Tortun 0.76
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
"{FB64BF25-3593-4E4E-AA85-84AEF1D1475F}" = Broadcom Management Programs
"{FC906D5C-91F9-4DA4-A765-6DCBB669F317}" = Sony Ericsson PC Suite
"{FFAB5ABB-8AAB-42E2-847F-1743E51E01E9}" = Disc2Phone
"4oD" = 4oD
"AC3Filter" = AC3Filter (remove only)
"Adobe Shockwave Player" = Adobe Shockwave Player
"Age Of Empires 2 & The Conquerors Expansion - Full Game" = Age Of Empires 2 & The Conquerors Expansion - Full Game
"America Online uk" = AOL UK (Choose which version to remove)
"AOL Connectivity Services" = AOL Connectivity Services
"AOL Spyware Protection" = AOL Spyware Protection
"AOL YGP Screensaver" = AOL You've Got Pictures Screensaver
"AOLCoach uk" = AOL Coach Version 1.0(Build:20040229.1 uk)
"ATI Display Driver" = ATI Display Driver
"AVS Update Manager_is1" = AVS Update Manager 1.0
"AVS4YOU Software Navigator_is1" = AVS4YOU Software Navigator 1.3
"AVS4YOU Video Converter 6_is1" = AVS Video Converter 6
"Bejeweled 2" = Bejeweled 2
"CCleaner" = CCleaner
"CDisplay_is1" = CDisplay 1.8
"Comanche 4" = Comanche 4
"DivX Plus DirectShow Filters" = DivX Plus DirectShow Filters
"DivX Setup.divx.com" = DivX Setup
"DyynoPlayer" = DyynoPlayer 0.8.6f
"Fences" = Fences
"HotspotShield" = Hotspot Shield 1.30
"InstallShield_{7B9CC60A-9B81-46A3-A953-76B6BF9EEC97}" = Age of Empires III
"InstallShield_{CFB17307-B244-4EAD-AE8E-CDAF440477C2}" = OpenMG Secure Module 4.4.00
"LimeWire" = LimeWire 5.1.2
"LiveUpdate" = LiveUpdate 2.6 (Symantec Corporation)
"McAfee Uninstall Utility" = McAfee Uninstaller
"Mozilla Firefox (3.6.8)" = Mozilla Firefox (3.6.8)
"ObjectDock" = ObjectDock
"OpenMG HotFix4.4-05-12-06-01" = OpenMG Limited Patch 4.4-06-13-19-01
"Peggle" = Peggle (remove only)
"PopCap Browser Plugin" = PopCap Browser Plugin
"Rainlendar2" = Rainlendar2 (remove only)
"Rainmeter" = Rainmeter (remove only)
"RealPlayer 6.0" = RealPlayer Basic
"Recover My Files_is1" = Recover My Files
"SearchAssist" = SearchAssist
"SinkSub Pro" = SinkSub Pro
"Steam App 220" = Half-Life 2
"Steam App 340" = Half-Life 2: Lost Coast
"Steam App 3482" = Peggle Deluxe Demo
"Steam App 3483" = Peggle Extreme
"Steam App 380" = Half-Life 2: Episode One
"Steam App 400" = Portal
"Steam App 420" = Half-Life 2: Episode Two
"Steam App 440" = Team Fortress 2
"StreetPlugin" = Learn2 Player (Uninstall Only)
"SystemRequirementsLab" = System Requirements Lab
"Teamspeak 2 RC2_is1" = TeamSpeak 2 RC2
"VobSub" = VobSub v2.23 (Remove Only)
"Wanadoo" = Wanadoo UK
"WIC" = Windows Imaging Component
"Windows Media Encoder 9" = Windows Media Encoder 9 Series
"BitTorrent" = BitTorrent
"BitTorrent DNA" = DNA
"uTorrent" = µTorrent
[ Application Events ]
Error - 07/08/2010 09:35:58 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Description = Faulting application winlogon.exe, version 0.0.0.0, faulting module
unknown, version 0.0.0.0, fault address 0x00572571.
Error - 07/08/2010 09:37:05 | Computer Name = ROBS_PC | Source = Application Error | ID = 1000
Description = Faulting application stsystra.exe, version 1.0.5143.0, faulting module
unknown, version 0.0.0.0, fault address 0x71aa1958.
Error - 07/08/2010 09:38:16 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:39:46 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:39:52 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:40:04 | Computer Name = ROBS_PC | Source = Application Error | ID = 1000
Description = Faulting application epmworker.exe, version 1.2.0.1219, faulting module
epmworker.exe, version 1.2.0.1219, fault address 0x0000332a.
Error - 07/08/2010 09:40:32 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:40:35 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:40:37 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
Error - 07/08/2010 09:40:39 | Computer Name = ROBS_PC | Source = Application Error | ID = 1004
msgina.dll, version 5.1.2600.2180, fault address 0x00008e1b.
[ System Events ]
Error - 07/08/2010 09:33:54 | Computer Name = ROBS_PC | Source = Service Control Manager | ID = 7034
Description = The Remote Procedure Call (HNM) service terminated unexpectedly.
It has done this 1 time(s).
Error - 07/08/2010 09:38:19 | Computer Name = ROBS_PC | Source = DCOM | ID = 10005
Description = DCOM got error "%1053" attempting to start the service MskService
with arguments "" in order to run the server: {5109B8D8-73AF-4C41-A70E-73707E1F908A}
Error - 07/08/2010 09:38:20 | Computer Name = ROBS_PC | Source = Service Control Manager | ID = 7009
Description = Timeout (30000 milliseconds) waiting for the McAfee SpamKiller Server
service to connect.
Error - 07/08/2010 09:38:20 | Computer Name = ROBS_PC | Source = Service Control Manager | ID = 7000
Description = The McAfee SpamKiller Server service failed to start due to the following
error: %%1053
Error - 07/08/2010 09:38:35 | Computer Name = ROBS_PC | Source = System Error | ID = 1003
Description = Error code 10000050, parameter1 ffffffd4, parameter2 00000000, parameter3
a7bf3582, parameter4 00000000.
Error - 07/08/2010 09:39:49 | Computer Name = ROBS_PC | Source = System Error | ID = 1003
a81ff582, parameter4 00000000.
Error - 07/08/2010 09:39:51 | Computer Name = ROBS_PC | Source = System Error | ID = 1003
Description = Error code 00000027, parameter1 baad00a3, parameter2 f7089acc, parameter3
f70897c8, parameter4 a8227582.
Error - 07/08/2010 09:40:20 | Computer Name = ROBS_PC | Source = DCOM | ID = 10005
Error - 07/08/2010 09:40:20 | Computer Name = ROBS_PC | Source = Service Control Manager | ID = 7009
service to connect.
Error - 07/08/2010 09:40:20 | Computer Name = ROBS_PC | Source = Service Control Manager | ID = 7000
error: %%1053
rob864
Operating System : xp
Re: Antivir Solution Pro
Post by Belahzur on Sun 08 Aug 2010, 1:54 am
Nasty infection you got here.
  • Download combofix from here
    Link 1
    Link 2
  • See HERE for how to disable your AV.
Manager | Tech Officer
Post by rob864 on Mon 09 Aug 2010, 3:19 am
I had to boot from the recovery disk again and the Windows XP recovery seems to work better this time, but some files missing. Anyway here is Combo-Fix log
ComboFix 10-08-07.02 - Rob 08/08/2010 16:54:00.2.1 - x86
Running from: c:\documents and settings\Rob\Desktop\Combo-Fix.exe
* Resident AV is active
((((((((((((((((((((((((( Files Created from 2010-07-08 to 2010-08-08 )))))))))))))))))))))))))))))))
2010-08-08 14:12 . 2010-08-08 14:12 -------- d-----w- c:\windows\dell
2010-08-08 13:38 . 2004-08-04 10:00 70144 -c--a-w- c:\windows\system32\dllcache\pintlphr.exe
2010-08-08 13:37 . 2004-08-04 10:00 18944 -c--a-w- c:\windows\system32\dllcache\cprofile.exe
2010-08-08 13:34 . 2004-08-04 10:00 7680 -c--a-w- c:\windows\system32\dllcache\migregdb.exe
2010-08-08 13:25 . 2004-08-04 10:00 24661 -c--a-w- c:\windows\system32\dllcache\spxcoins.dll
2010-08-08 13:25 . 2004-08-04 10:00 24661 ----a-w- c:\windows\system32\spxcoins.dll
2010-08-08 13:25 . 2004-08-04 10:00 13312 -c--a-w- c:\windows\system32\dllcache\irclass.dll
2010-08-08 13:25 . 2004-08-04 10:00 13312 ----a-w- c:\windows\system32\irclass.dll
2010-08-04 02:05 . 2010-08-04 02:05 -------- d-----w- c:\windows\system32\SeaPort
2010-08-03 23:50 . 2010-08-03 23:50 -------- d-----w- c:\windows\system32\InstallShield Installation Information
2010-08-02 04:38 . 2010-07-23 16:22 1496064 ----a-w- c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\components\frozen.dll
2010-08-02 04:38 . 2010-07-23 16:22 43008 ----a-w- c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\components\googletoolbarloader.dll
2010-08-02 04:38 . 2010-07-23 16:22 338944 ----a-w- c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\libraries\googletoolbar-ff2.dll
2010-08-02 04:38 . 2010-07-23 16:22 346112 ----a-w- c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\libraries\googletoolbar-ff3.dll
2010-07-23 18:52 . 2010-08-01 16:42 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
2010-07-23 18:52 . 2010-07-23 18:52 -------- d-----w- c:\documents and settings\All Users\Application Data\NortonInstaller
2010-07-23 15:45 . 2010-07-23 15:45 56765 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DivXPlusShortcuts\Uninstaller.exe
2010-07-23 15:45 . 2010-07-23 15:45 57715 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Player\Uninstaller.exe
2010-07-23 15:45 . 2010-07-23 15:45 84054 ----a-w- c:\documents and settings\All Users\Application Data\DivX\TransferWizard\Uninstaller.exe
2010-07-23 15:44 . 2010-07-23 15:44 54153 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DFXPlugin\Uninstaller.exe
2010-07-23 15:27 . 2010-07-23 15:28 144696 ----a-w- c:\documents and settings\All Users\Application Data\DivX\RunAsUser\RUNASUSERPROCESS.exe
2010-08-08 15:51 . 2008-12-30 04:36 -------- d--h--w- c:\documents and settings\Rob\Application Data\DNA
2010-08-08 15:42 . 2007-09-06 20:32 -------- d-----w- c:\program files\Steam
2010-08-08 15:42 . 2007-02-13 10:44 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2010-08-08 15:41 . 2008-12-30 04:36 -------- d-----w- c:\program files\DNA
2010-08-08 14:58 . 2006-09-29 18:32 43576 ----a-w- c:\documents and settings\Rob\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2010-08-03 19:02 . 2010-04-07 22:57 -------- d-----w- c:\documents and settings\Rob\Application Data\Xoik
2010-08-03 00:58 . 2010-02-12 18:14 0 ----a-w- c:\windows\Ahucihehafileyo.dat
2010-08-01 16:39 . 2006-09-27 13:30 -------- d-----w- c:\program files\Common Files\Symantec Shared
2010-07-23 18:52 . 2006-09-27 13:30 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
2010-07-23 16:18 . 2010-06-24 11:02 57344 ----a-w- c:\documents and settings\All Users\Application Data\DivX\RunAsUser\RUNASUSERPROCESS.dll
2010-07-23 16:18 . 2010-06-24 01:34 -------- d-----w- c:\documents and settings\All Users\Application Data\DivX
2010-07-23 15:45 . 2007-05-10 15:41 -------- d-----w- c:\program files\DivX
2010-07-23 15:27 . 2010-06-24 02:24 1062184 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Setup\Resource.dll
2010-07-23 15:27 . 2010-06-24 02:24 895256 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Setup\DivXSetup.exe
2010-07-23 02:35 . 2008-05-29 01:52 -------- d-----w- c:\documents and settings\Rob\Application Data\uTorrent
2010-07-10 13:11 . 2010-02-12 18:14 0 ----a-w- c:\windows\Mjebupiyepete.bin
2010-07-08 23:06 . 2010-07-08 23:06 4096 ----a-w- c:\windows\system32\drivers\nocashio.sys
2010-07-04 20:08 . 2006-09-27 13:37 -------- d-----w- c:\program files\Google
2010-06-28 04:52 . 2010-06-28 04:52 -------- d-----w- c:\program files\directx
2010-06-26 18:00 . 2009-06-11 15:36 64 ----a-w- c:\windows\popcinfot.dat
2010-06-24 02:24 . 2010-06-24 02:24 56997 ----a-w- c:\documents and settings\All Users\Application Data\DivX\WebPlayer\Uninstaller.exe
2010-06-24 02:24 . 2010-06-24 02:24 53600 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Update\Uninstaller.exe
2010-06-24 02:24 . 2007-11-10 20:51 -------- d--h--w- c:\documents and settings\Rob\Application Data\DivX
2010-06-24 02:23 . 2010-06-24 02:23 57054 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DSDesktopComponents\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 54166 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DSAVCDecoder\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 57532 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DSASPDecoder\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 56458 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DivXDecoderShortcut\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 54174 ----a-w- c:\documents and settings\All Users\Application Data\DivX\DSAACDecoder\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 54128 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Converter\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 54644 ----a-w- c:\documents and settings\All Users\Application Data\DivX\TranscodeEngine\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 57409 ----a-w- c:\documents and settings\All Users\Application Data\DivX\ControlPanel\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 54101 ----a-w- c:\documents and settings\All Users\Application Data\DivX\MPEG2Plugin\Uninstaller.exe
2010-06-24 02:23 . 2010-06-24 02:23 52963 ----a-w- c:\documents and settings\All Users\Application Data\DivX\MSVC80CRTRedist\Uninstaller.exe
2010-06-24 02:22 . 2010-06-24 02:22 54073 ----a-w- c:\documents and settings\All Users\Application Data\DivX\Qt4.5\Uninstaller.exe
2010-06-24 02:22 . 2010-06-24 02:22 -------- d-----w- c:\program files\Common Files\DivX Shared
2010-06-24 02:22 . 2010-06-24 02:22 56969 ----a-w- c:\documents and settings\All Users\Application Data\DivX\ASPEncoder\Uninstaller.exe
2010-06-21 17:21 . 2010-03-20 21:41 -------- d-----w- c:\program files\SSPRO
2010-06-21 17:21 . 2002-08-01 15:35 35328 ----a-w- c:\windows\system32\wavmix32.dll
2007-01-01 14:25 . 2007-01-01 14:25 283960 -c--a-w- c:\program files\dxwebsetup.exe
2006-12-19 19:17 . 2006-12-19 19:17 0 ----a-w- c:\program files\pspbrwse.jbf
2009-04-18 21:22 . 2006-12-19 19:13 56 --sh--r- c:\windows\system32\0371BCE00C.sys
2009-03-04 13:10 . 2006-12-29 20:11 88 --sh--r- c:\windows\system32\0CE0BC7103.sys
2009-04-18 21:22 . 2006-10-01 13:44 6580 --sha-w- c:\windows\system32\KGyGaAvL.sys
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-28 68856]
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2009-07-26 3883856]
"Steam"="c:\program files\steam\steam.exe" [2010-05-07 1238352]
"BitTorrent DNA"="c:\program files\DNA\btdna.exe" [2009-11-13 323392]
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe" [2007-06-27 152872]
"DAEMON Tools Pro Agent"="c:\program files\DAEMON Tools Pro\DTProAgent.exe" [2009-04-09 228808]
"Rainlendar2"="c:\program files\Rainlendar2\Rainlendar2.exe" [2009-08-22 5148672]
"ATICCC"="c:\program files\ATI Technologies\ATI.ACE\cli.exe" [2006-01-02 45056]
"DMXLauncher"="c:\program files\Dell\Media Experience\DMXLauncher.exe" [2005-10-05 94208]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2005-06-10 81920]
"AOLDialer"="c:\program files\Common Files\AOL\ACS\AOLDial.exe" [2004-11-09 497240]
"RealTray"="c:\program files\Real\RealPlayer\RealPlay.exe" [2006-09-27 26112]
"AOL Spyware Protection"="c:\progra~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe" [2004-03-19 78960]
"VSOCheckTask"="c:\progra~1\McAfee.com\VSO\mcmnhdlr.exe" [2005-07-08 151552]
"OASClnt"="c:\program files\McAfee.com\VSO\oasclnt.exe" [2005-08-11 53248]
"MCAgentExe"="c:\progra~1\mcafee.com\agent\mcagent.exe" [2005-09-22 303104]
"MCUpdateExe"="c:\progra~1\mcafee.com\agent\mcupdate.exe" [2006-01-11 212992]
"MSKDetectorExe"="c:\progra~1\McAfee\SPAMKI~1\MSKDetct.exe" [2006-11-07 1121280]
"DLA"="c:\windows\System32\DLA\DLACTRLW.EXE" [2005-09-08 122940]
"MSKAGENTEXE"="c:\progra~1\McAfee\SPAMKI~1\MskAgent.exe" [2005-09-26 110592]
"VirusScan Online"="c:\program files\McAfee.com\VSO\mcvsshld.exe" [2005-08-10 163840]
"MPFExe"="c:\progra~1\McAfee.com\PERSON~1\MpfTray.exe" [2005-11-11 1005096]
"Logitech Hardware Abstraction Layer"="KHALMNPR.EXE" [2005-07-22 28160]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-05-13 177472]
"Sony Ericsson PC Suite"="c:\program files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe" [2006-11-24 487424]
"NeroFilterCheck"="c:\program files\Common Files\Ahead\Lib\NeroCheck.exe" [2007-03-01 153136]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"ISUSPM Startup"="c:\program files\Common Files\InstallShield\UpdateService\isuspm.exe" [2005-06-10 249856]
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" [2010-06-03 1144104]
"SigmatelSysTrayApp"="stsystra.exe" [2006-08-15 282624]
"CTFMON.EXE"="c:\windows\system32\CTFMON.EXE" [2004-08-04 15360]
"RunNarrator"="Narrator.exe" [2004-08-04 53760]
c:\documents and settings\Rob\Start Menu\Programs\Startup\
Stardock ObjectDock.lnk - c:\program files\Stardock\ObjectDock\ObjectDock.exe [2010-1-6 3450608]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-9-23 29696]
Dell Network Assistant.lnk - c:\windows\Installer\{0240BDFB-2995-4A3F-8C96-18D41282B716}\Icon0240BDFB3.exe [2006-9-27 7168]
Logitech SetPoint.lnk - c:\program files\Logitech\SetPoint\SetPoint.exe [2006-12-29 528384]
NETGEAR WPN111 Smart Wizard.lnk - c:\program files\NETGEAR\WPN111\wpn111.exe [2007-4-12 884838]
Rainmeter.lnk - c:\program files\Rainmeter\Rainmeter.exe [2009-11-1 119296]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\SharedTaskScheduler]
"{1984DD45-52CF-49cd-AB77-18F378FEA264}"= "c:\program files\Stardock\Fences\FencesMenu.dll" [2009-10-02 128360]
"EnableFirewall"= 0 (0x0)
"DisableNotifications"= 1 (0x1)
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\AOL 9.0\\waol.exe"=
"c:\\Program Files\\Steam\\Steam.exe"=
"c:\\Program Files\\Dell Network Assistant\\ezi_hnm2.exe"=
"c:\\Program Files\\Steam\\steamapps\\rob399\\team fortress 2\\hl2.exe"=
"c:\\Program Files\\VentSrv\\ventrilo_srv.exe"=
"c:\\Program Files\\Tortun\\gui.exe"=
"c:\\Program Files\\uTorrent\\uTorrent.exe"=
"c:\\Documents and Settings\\Rob\\Local Settings\\Application Data\\Dyyno Receiver\\DPPM.exe"=
"c:\\Program Files\\BitTorrent\\bittorrent.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\peggle deluxe\\Peggle.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\peggle extreme\\PeggleExtreme.exe"=
"c:\\Program Files\\Age Of Empires 2 & The Conquerors Expansion - Full Game\\age2_x1.exe"=
"c:\\Program Files\\Windows Live\\Sync\\WindowsLiveSync.exe"=
"c:\\Documents and Settings\\Rob\\My Documents\\utorrent.exe"=
"c:\\Program Files\\DNA\\btdna.exe"=
R0 sptd;sptd;c:\windows\System32\Drivers\sptd.sys [2009-07-08 721904]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-02-14 135664]
R2 RPCER;Remote Procedure Call (HNM);c:\program files\NetMeeting\comp.exe [2007-03-28 12798152]
R3 DNINDIS5;DNINDIS5 NDIS Protocol Driver;c:\windows\system32\DNINDIS5.SYS [2003-07-24 17149]
R3 WPN111;Wireless USB 2.0 Adapter with RangeMax Service;c:\windows\system32\DRIVERS\WPN111.sys [2005-09-26 362944]
2010-07-31 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-04-11 11:34]
2010-08-08 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-02-14 03:53]
2010-08-08 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-08-08 c:\windows\Tasks\McAfee.com Scan for Viruses - My Computer (ROBS_PC-Rob).job
- c:\program files\mcafee.com\vso\mcmnhdlr.exe [2006-09-27 17:18]
uInternet Settings,ProxyServer = http=127.0.0.1:5643
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
Trusted Zone: buy-internetsecurity10.com
Trusted Zone: buy-is2010.com
Trusted Zone: is-software-download.com
Trusted Zone: is-software-download25.com
Trusted Zone: is10-soft-download.com
FF - ProfilePath - c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\
FF - component: c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}\components\frozen.dll
FF - HiddenExtension: XULRunner: {3D8B6F79-97D7-40A1-85BB-DD2902F64883} - c:\documents and settings\Administrator\Local Settings\Application Data\{3D8B6F79-97D7-40A1-85BB-DD2902F64883}\
---- FIREFOX POLICIES ----
FF - user.js: network.cookie.cookieBehavior - 0
FF - user.js: privacy.clearOnShutdown.cookies - false
FF - user.js: security.warn_viewing_mixed - false
FF - user.js: security.warn_viewing_mixed.show_once - false
FF - user.js: security.warn_submit_insecure - false
FF - user.js: security.warn_submit_insecure.show_once - false
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.lu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nz", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbaam7a8h", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--p1ai", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbayh7gpa", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.tel", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.proxy.type", 5);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.buffer.cache.count", 24);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.buffer.cache.size", 4096);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("dom.ipc.plugins.timeoutSecs", 45);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("accelerometer.enabled", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.nptest.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npswf32.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npctrl.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npqtplugin.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
Rootkit scan 2010-08-08 16:59
[HKEY_USERS\S-1-5-21-147038334-2158946348-2334436982-1006\Software\Microsoft\SystemCertificates\AddressBook*]
[HKEY_USERS\S-1-5-21-147038334-2158946348-2334436982-1006\Software\SecuROM\!CAUTION! NEVER A OR CHANGE ANY KEY*]
"??"=hex:5e,3c,da,7b,39,6f,7f,b3,a4,e5,e1,c0,14,5f,93,01,18,dc,11,1c,85,19,a3,
ce,b2,85,42,49,fe,49,98,de,dd,51,fd,4c,11,2d,71,a6,f4,5e,f2,bf,ee,dd,ae,67,\
"??"=hex:5d,2e,bc,00,9b,07,bc,9c,34,34,87,88,c9,ab,ca,0d
[HKEY_USERS\S-1-5-21-147038334-2158946348-2334436982-1006\Software\SecuROM\License information*]
"datasecu"=hex:e1,4d,2d,b6,16,e7,39,57,ab,55,5e,d8,87,ef,02,3e,9d,af,39,29,ab,
0d,62,cf,b5,b7,e4,f8,ee,43,8b,62,17,d2,54,64,dc,72,22,1b,6f,cd,0d,a6,72,62,\
"rkeysecu"=hex:5b,b1,f1,96,e6,e7,05,7e,0c,23,86,99,20,fc,03,4c
- - - - - - - > 'explorer.exe'(568)
c:\program files\Stardock\ObjectDock\DockShellHook.dll
c:\progra~1\McAfee\SPAMKI~1\mskoeplg.dll
c:\program files\Logitech\SetPoint\GameHook.dll
c:\program files\Logitech\SetPoint\lgscroll.dll
c:\progra~1\WINDOW~2\wmpband.dll
c:\program files\iTunes\iTunesMiniPlayer.dll
c:\program files\iTunes\iTunesMiniPlayer.Resources\en.lproj\iTunesMiniPlayerLocalized.dll
c:\program files\iTunes\iTunesMiniPlayer.Resources\iTunesMiniPlayer.dll
c:\progra~1\mcafee.com\vso\McVSSkt.dll
c:\program files\stardock\fences\DesktopDock.dll
Completion time: 2010-08-08 17:01:32
ComboFix-quarantined-files.txt 2010-08-08 16:01
ComboFix2.txt 2010-08-08 15:47
Pre-Run: 5,819,150,336 bytes free
Post-Run: 5,804,244,992 bytes free
Current=3 Default=3 Failed=0 LastKnownGood=4 Sets=1,2,3,4
- - End Of File - - 0638627259793FA7AF2B85EF2FAA47F7
rob864
Post by Belahzur on Mon 09 Aug 2010, 6:31 am
Please download GooredFix from one of the locations below and save it to your Desktop
Download Mirror #1
Download Mirror #2
  • Ensure all Firefox windows are closed.
  • To run the tool, double-click it (XP), or right-click and select Run As Administrator (Vista).
  • When prompted to run the scan, click Yes.
  • GooredFix will check for infections, and then a log will appear. Please post the contents of that log in your next reply (it can also be found on your desktop, called GooredFix.txt).
  1. Close any open browsers.
    KILLALL::
    File::
    DDS::
    Firefox::
    FF - prefs.js: keyword.URL - hxxp://toolbar.ask.com/toolbarv/askRedirect?o=101761&gct=&gc=1&q=
    Domains::
Post by rob864 on Tue 10 Aug 2010, 8:16 am
GooredFix by jpshortstuff (03.07.10.1)
Log created at 21:42 on 09/08/2010 (Rob)
Firefox version 3.6.8 (en-US)
========== Script ==========
Deleting "KILLALL::
" -> Failed [1026]
Deleting "
" -> Failed [1026]
Deleting "File::
" -> Failed [1026]
Deleting "c:\windows\Ahucihehafileyo.dat
" -> Failed [1026]
Deleting "c:\windows\Mjebupiyepete.bin
" -> Failed [1026]
Deleting "
" -> Failed [1026]
Deleting "DDS::
" -> Failed [1026]
Deleting "uInternet Settings,ProxyOverride =
" -> Failed [1026]
Deleting "uInternet Settings,ProxyServer = http=127.0.0.1:5643
" -> Failed [1026]
Deleting "
" -> Failed [1026]
Deleting "Firefox::
" -> Failed [1026]
Deleting "FF - ProfilePath - c:\documents and settings\Rob\Application Data\Mozilla\Firefox\Profiles\xa62z737.default\
" -> Failed [1026]
Deleting "FF - prefs.js: keyword.URL - [You must be registered and logged in to see this link.]
" -> Failed [1026]
Deleting "
" -> Failed [1026]
Deleting "
" -> Failed [1026]
Deleting "Domains::
" -> Failed [1026]
========== GooredScan ==========
ComboFix log output
ComboFix 10-08-07.02 - Rob 09/08/2010 21:47:10.3.1 - x86
Command switches used :: c:\documents and settings\Rob\Desktop\CFScript.txt.txt
* Created a new restore point
FILE ::
"c:\windows\Ahucihehafileyo.dat"
"c:\windows\Mjebupiyepete.bin"
((((((((((((((((((((((((( Files Created from 2010-07-09 to 2010-08-09 )))))))))))))))))))))))))))))))
2010-08-08 15:52 . 2010-08-08 16:01 -------- d-----w- C:\Combo-Fix
2010-08-09 20:58 . 2007-09-06 20:32 -------- d-----w- c:\program files\Steam
2010-08-09 20:58 . 2007-02-13 10:44 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2010-08-09 20:57 . 2008-12-30 04:36 -------- d--h--w- c:\documents and settings\Rob\Application Data\DNA
2010-08-09 20:57 . 2008-12-30 04:36 -------- d-----w- c:\program files\DNA
2010-08-09 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2010-08-09 c:\windows\Tasks\McAfee.com Scan for Viruses - My Computer (ROBS_PC-Rob).job
mDefault_Search_URL = [You must be registered and logged in to see this link.]
Rootkit scan 2010-08-09 21:56
- - - - - - - > 'explorer.exe'(1560)
c:\program files\Common Files\AOL\ACS\AOLAcsd.exe
c:\program files\Dell Network Assistant\hnm_svc.exe
c:\program files\Hotspot Shield\HssWPR\hsssrv.exe
c:\program files\mcafee.com\agent\mcdetect.exe
c:\progra~1\mcafee.com\vso\mcshield.exe
c:\progra~1\mcafee.com\agent\mctskshd.exe
c:\progra~1\McAfee.com\PERSON~1\MpfService.exe
c:\program files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
c:\program files\VentSrv\ventrilo_svc.exe
c:\program files\VentSrv\ventrilo_srv.exe
c:\progra~1\mcafee.com\vso\mcvsescn.exe
c:\progra~1\McAfee.com\PERSON~1\MpfAgent.exe
c:\windows\stsystra.exe
c:\program files\Dell Network Assistant\ezi_hnm2.exe
c:\program files\Common Files\Ahead\Lib\NMIndexingService.exe
c:\program files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe
c:\program files\Common Files\Logitech\KHAL\KHALMNPR.EXE
c:\progra~1\mcafee.com\vso\mcvsftsn.exe
c:\program files\Messenger\msmsgs.exe
c:\program files\Common Files\Teleca Shared\Generic.exe
c:\program files\Sony Ericsson\Mobile2\Mobile Phone Monitor\epmworker.exe
c:\windows\system32\dwwin.exe
Completion time: 2010-08-09 22:02:19 - machine was rebooted
ComboFix-quarantined-files.txt 2010-08-09 21:02
ComboFix2.txt 2010-08-08 16:01
ComboFix3.txt 2010-08-08 15:47
Pre-Run: 5,810,876,416 bytes free
Post-Run: 5,799,833,600 bytes free
- - End Of File - - AD54F0FEF08414205785049980D2B222
rob864
Post by Belahzur on Tue 10 Aug 2010, 11:07 am
ComboFix /uninstall
Run ESET Online Scan
Please do an online scan with ESET Online Scanner. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by rob864 on Sat 14 Aug 2010, 3:30 am
Combofix / uninstall did a re-scan, see log below
When I tried to run eset online scan using IE I got the following message 'The requested lookup key was not found in any active activation context'. So I ran eset online scan on another PC and took the .exe to my PC. Then it ran OK, downloaded stuff etc. Log output below.
ComboFix 10-08-07.02 - Rob 13/08/2010 14:27:49.4.1 - x86
Command switches used :: / uninstall
((((((((((((((((((((((((( Files Created from 2010-07-13 to 2010-08-13 )))))))))))))))))))))))))))))))
2010-08-13 13:25 . 2007-09-06 20:32 -------- d-----w- c:\program files\Steam
2010-08-13 13:25 . 2007-02-13 10:44 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2010-08-13 13:24 . 2008-12-30 04:36 -------- d--h--w- c:\documents and settings\Rob\Application Data\DNA
2010-08-13 13:24 . 2008-12-30 04:36 -------- d-----w- c:\program files\DNA
+ 2010-08-13 13:22 . 2010-08-13 13:22 16384 c:\windows\temp\Perflib_Perfdata_780.dat
2010-08-13 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2010-08-13 c:\windows\Tasks\McAfee.com Scan for Viruses - My Computer (ROBS_PC-Rob).job
Rootkit scan 2010-08-13 14:34
- - - - - - - > 'explorer.exe'(2212)
Completion time: 2010-08-13 14:36:19
ComboFix-quarantined-files.txt 2010-08-13 13:36
ComboFix2.txt 2010-08-09 21:02
ComboFix3.txt 2010-08-08 16:01
ComboFix4.txt 2010-08-08 15:47
Pre-Run: 5,807,132,672 bytes free
Post-Run: 5,792,796,672 bytes free
- - End Of File - - 02FFBC80CEA5F7EE0B5DDC4DB5FBDF80
Can not open internetESETSmartInstaller@High as downloader log:
Can not open internetCan not open internetESETSmartInstaller@High as downloader log:
Can not open internet# version=7
# api_version=3.0.2
# EOSSerial=eb5c47f58ec9364695d2e7e20eb00a6f
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-08-13 03:16:56
# local_time=2010-08-13 04:16:56 (+0000, GMT Daylight Time)
# country="United Kingdom"
# lang=2057
# osver=5.1.2600 NT Service Pack 2
# compatibility_mode=crash
# scanned=93739
# found=40
# cleaned=40
# scan_time=4034
C:\Documents and Settings\Administrator\Application Data\Microsoft\Internet Explorer\Desktop.htt Win32/TrojanDownloader.FakeAlert.ATP trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\Administrator\Local Settings\Application Data\av.exe a variant of Win32/Kryptik.CJV trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\Rob\Desktop\GooredFix Backups\C\Documents and Settings\Administrator\Local Settings\Application Data\{3D8B6F79-97D7-40A1-85BB-DD2902F64883}\chrome\content\overlay.xul probably a variant of Win32/Agent.NVQFFQI trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\Rob\My Documents\Nero 7.10.1.0\Nero-7.10.1.0_eng_full.exe Win32/Toolbar.AskSBar application (deleted - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Hotspot Shield\bin\openvpnas.exe a variant of Win32/HotSpotShield application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Program Files\NetMeeting\comp.exe probably a variant of Win32/Genetik trojan (cleaned by deleting (after the next restart) - quarantined) 00000000000000000000000000000000 C
C:\Program1\EA GAMES\Command & Conquer Generals\Zero Hour\generals.exe probably unknown NewHeur_PE virus (deleted - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Rob\autorun.inf.vir INF/Autorun virus (deleted - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Rob\Application Data\Heriih\toup.exe.vir Win32/Spy.Zbot.YW trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Rob\Local Settings\Application Data\MSASCui.exe.vir a variant of Win32/Kryptik.CSB trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Rob\Local Settings\Application Data\jqyuwnusn\xexcfqitssd.exe.vir Win32/Adware.SpywareProtect2009 application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Rob\Local Settings\Application Data\{6502847E-AD16-4D91-867A-4009295CF7C6}\chrome\content\overlay.xul.vir probably a variant of Win32/Agent.NVQFFQI trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\DOCUME~1\Rob\LOCALS~1\Temp\oggdw96sx.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\ajovupoqoxevuqa.dll.vir a variant of Win32/Cimag.BQ trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\asmcu4fbq.dll.vir a variant of Win32/TrojanDownloader.Small.NFD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\bri5b913.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\d5ytv35.dll.vir a variant of Win32/TrojanDownloader.Small.NFD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\ho4ndjbsu.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\kwok5s.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\lmvji.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\mcuuxpbs.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\msls51.dll.vir a variant of Win32/Kryptik.CMD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\niqscu.dll.vir a variant of Win32/TrojanDownloader.Small.NFD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\q7032w.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\qvedt7.dll.vir probably a variant of Win32/Agent.BUEJTQ trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\rk67xrw.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\rrh7v.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\smqdzle.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\t6ymgwvuzk.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\tc5d5.dll.vir a variant of Win32/TrojanDownloader.Small.NFD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\va7jms3j75.dll.vir a variant of Win32/TrojanDownloader.Small.NFD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\warning.html.vir Win32/TrojanDownloader.FakeAlert.ATP trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\x8bwdetn3x.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\xlt89.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\WINDOWS\system32\y0azio.dll.vir probably a variant of Win32/TrojanDownloader.Agent.HYQTCNO trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP1\A0000385.exe a variant of Win32/Kryptik.CJV trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP1\A0000388.exe a variant of Win32/HotSpotShield application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP1\A0000389.exe probably a variant of Win32/Genetik trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP1\A0000390.exe probably unknown NewHeur_PE virus (deleted - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\system32\hlp.dat Win32/Bamital.DP trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
rob864
Post by Belahzur on Sat 14 Aug 2010, 8:51 am
Post by Sponsored content Today at 9:44 pm
