antivir solution pro
Post by pbrown on 5th August 2010, 5:45 pm
Does anyone happen to know if the antivir solution pro has to be downloaded or can it just appear on your computer. My computer was being used by someone else and is now infected. This person says they didn't download anything so I'm just checking. thanks for any information.
pbrown
Posts Posts : 4
Joined Joined : 2010-08-05
OS OS : windows xp
Points Points : 23218
Re: antivir solution pro
Post by Belahzur on 5th August 2010, 8:39 pm
Points Points : 245091
Post by pbrown on 5th August 2010, 10:33 pm
Sorry, but I am not computer literate. Where would I find OTL.exe? I'm not sure virus will allow me to do anything-I can't even restore the operating system. What will posting these logs tell you? Thank you for your help.
pbrown
Posts Posts : 4
OS OS : windows xp
Post by Belahzur on 5th August 2010, 11:10 pm
Click the bold text in my above post, it's a hyperlink to the tool we'll need to use.
Post by pbrown on 6th August 2010, 12:56 am
I guess I have to give up on the computer-it won't let the internet open. thank you for your help.
pbrown
Posts Posts : 4
OS OS : windows xp
Post by Belahzur on 6th August 2010, 7:49 pm
Stay with me. Do you have another machine we can use and external hardware?
Post by pbrown on 6th August 2010, 8:14 pm
No. thanks anyway. i really appreciate your help. the computer is 5 yrs old, and i was looking into a new one anyway. i was just curious if this particular virus has to be downloaded to infect the computer or if it's possible for this virus to infect on its own-not thru emails, attachments or anything like that. turn the computer off one night and it's fine, the next day when you turn it on, it's infected.
pbrown
Posts Posts : 4
OS OS : windows xp
