Wireless connectivity problem
Post by CRC on 2nd August 2010, 3:56 am
I have a dell inspiron and i use a linksys wireless g router. About 3 weeks ago my daughter dropped the router and thought it was broken. I bought a Belkin n-150 wireless router and after 4 days with their CS i returned the belkin and hooked my linksys back up. The linksys is working fine especially wired, (xbox and computers). My daughters Ipod Touch are able to connect wirelessly but my Inspiron wireless card will loose connectivity frequently.
What should i do from here?
CRC
CRC
Posts Posts : 106
Joined Joined : 2010-07-08
Points Points : 25151
Re: Wireless connectivity problem
Post by CRC on 4th August 2010, 4:00 am
Bump
CRC
Posts Posts : 106
Post by CRC on 6th August 2010, 1:45 am
Bump
CRC
Posts Posts : 106
Post by Buttons on 6th August 2010, 1:48 am
What model do you have? I have an inspiron 1318 which often losses connectivity or is low. Have you tried going to dell and checking for an updated driver?
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26326
Post by CRC on 6th August 2010, 2:13 am
Ive got the el-cheapo b120....i have gone to the dell site and downloaded a driver update that was around the time i purchased the laptop (2006). It hasn't seem to help.
ETA: i tried the dell site, downloaded and installed the wlan card again. It seems to be working and holding a signal for now. I will let you know if it looses connectivity again.
CRC
CRC
Posts Posts : 106
Post by Buttons on 6th August 2010, 3:38 am
Sure.Smile
Buttons
Posts Posts : 869
