Hearing Navigation Clicks and Random Ads. Please Help.
Re: Hearing Navigation Clicks and Random Ads. Please Help.
Post by Crush on Sun Aug 01, 2010 12:15 am
Great. That's removed an infection. Try running Combofix now. You can find instructions in post 2.
Crush
Posts Posts : 3889
Joined Joined : 2010-01-27
Points Points : 42118
Post by skippy8805 on Sun Aug 01, 2010 5:49 pm
Remember it doesnt work? that's why you gave me the alternate route.
skippy8805
Posts Posts : 16
Joined Joined : 2010-07-31
Points Points : 23448
Post by Crush on Sun Aug 01, 2010 9:20 pm
Right but, seeing as we have removed some of the infections on your machine it might run now. Have you tried since running Bootkit Remover?
Crush
Posts Posts : 3889
Post by skippy8805 on Sun Aug 01, 2010 9:40 pm
Yep, it still shuts off.
skippy8805
Posts Posts : 16
Post by Crush on Sun Aug 01, 2010 9:48 pm
Ok. Let's attack this from a different angle:
  • Place a blank CD-R disc in to your CD burning drive.
  • Download [You must be registered and logged in to see this link.] and double-click on it to burn to a CD using ISO Burner.
    Note : If you do not know how to set your computer to boot from CD follow the steps [You must be registered and logged in to see this link.]
Crush
Posts Posts : 3889
Post by skippy8805 on Sun Aug 01, 2010 10:03 pm
i have a netbook. no disc drive
skippy8805
Posts Posts : 16
Post by Crush on Sun Aug 01, 2010 10:07 pm
hi skippy,
I'm running out of ideas here. I have PMed you with instructions. Let's, for the time being, take this there.
Crush
Posts Posts : 3889
