Unknown problem =S
Unknown problem =S
Post by Biglowz on Fri Jul 30, 2010 1:20 pm
i have a problem with my PC.. im unable to play Warcraft 3 but i'm able to play MW2 and Dirt 2.. How come? it says something about a direct x8 missing or something.. used to be able to play.. this problem occurred when i changed my computer screen. can anyone help me?
Points Points : 32045
Re: Unknown problem =S
Post by Biglowz on Mon Aug 02, 2010 5:08 am
It says unable to initialize direct X.. please ensure u have direct x 8.1 or newer.. Help please?
Post by Gabethebabe on Mon Aug 02, 2010 10:02 am
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38218
Post by Biglowz on Tue Aug 03, 2010 2:42 am
Okay, i'll try it when i get home.. but why am i unable to play it? all i did was change the screen.. it should have not have affected the software right? Thanks btw~
Post by Biglowz on Tue Aug 03, 2010 8:38 am
The problem has not been resolved.. the same pop up still comes up.. it keeps saying the problem can be fixed by changing the settings under options in the disc.. but i dun have the game disc.. i've been playing the pirated version all this while and it works fine until the day i changed my screen..
Post by Biglowz on Tue Aug 03, 2010 11:54 am
It still keeps saying make sure i have direct x 8.1 or newer, and the settings can be changed under options in the install menu.. but mine is a pirated version, i dun have a disc.. i've been playing this game for afew years and this is the first time i have this problem.. just because i switched my screen.. i dunno what is wrong..
Post by Biglowz on Wed Aug 04, 2010 10:18 am
OMG.. i've changed back to the previous screen and it works again.. O.O! Does the screen really affect the game?
