Need Help to remove Antimalware Doctor
Post by cutenik211 on Tue Jul 27, 2010 7:05 pm
This program Antimalware Doctor just installed itself in my computer desktop. I dont know where it came from and things keep popping out. I tried to scan my computer with AVG but it wont let me open it. It always says that this application is infected and you need to activate your antivirus program. Any program i click it always says that. My firefox and internet explorer wont work either. What should i do?
cutenik211
Posts Posts : 27
Joined Joined : 2009-08-22
Points Points : 26958
Re: Need Help to remove Antimalware Doctor
Post by Dr Jay on Tue Jul 27, 2010 8:06 pm
Please note the following information about the malware forum:
  • Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
  • From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by the staff I noted above.
  • Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
  • If you have already asked for help somewhere, please post the link to the topic you were helped.
  • We try our best to reply quickly, but for any reason we do not reply in two days, do one of two things:
    Reply to this topic with the word BUMP, or
    see [You must be registered and logged in to see this link.].
  • Lastly, keep in mind that we are volunteers, so you do not have to pay for malware removal. Persist in this topic until its close, and your computer is declared clean.
We need to do some diagnostics to get started.
1. Please download and run RKill.
[You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.]
  • It will quickly run and launch a log. If it does not launch a log, try another download link until it does.
  • Please post its log in your next reply.
  • After it has run successfully, delete RKill.
Note: This tool only kills the active infection, the actual infection will not be gone. Once you reboot the infection will be active again! Please do not reboot until instructed further to do so.
2. Download [You must be registered and logged in to see this link.] to your desktop.
  • Double click MBRCheck.exe to run (Vista and Windows 7 users, right click and select Run as Administrator).
  • It will show a black screen with some data on it.
  • A report called MBRcheckxxxx.txt will be on your desktop
  • Open this report and post its content in your next reply.
3. Please download [You must be registered and logged in to see this link.] by me, and save to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.zip, and extract the file to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.cmd to start.
  • It will finish quickly and launch a log.
  • Post the contents of it in your next reply.
4. In your next reply, please post the following logs for my review:
  • MBRCheck log (2)
  • Cheetah log (3)
Thanks! Smile
Posts Posts : 13717
Points Points : 302127
Post by cutenik211 on Tue Jul 27, 2010 9:04 pm
Hello
Here are the logs :
This log file is located at C:\rkill.log.
Please post this only if requested to by the person helping you.
Otherwise you can close this log when you wish.
Ran as nikki on 07/27/2010 at 15:54:56.
Processes terminated by Rkill or while it was running:
Rkill completed on 07/27/2010 at 15:55:03.
MBRCheck, version 1.1.1
(c) 2010, AD
\\.\C: --> \\.\PhysicalDrive0
Size Device Name MBR Status
74 GB \\.\PhysicalDrive0 Windows XP MBR code detected
Done! Press ENTER to exit...
Cheetah-Anti-Rogue v1.5.1
by DragonMaster Jay
Date: 07/27/2010 - Time: 15:59:59 - Arch.: x86
-- Malware removal tools check --
Malwarebytes' Anti-Malware
OTL
RKILL
-- Known infection --
C:\DOCUME~1\nikki\LOCALS~1\Temp\1.tmp (Trj.Bredavi-Backdoor)
C:\DOCUME~1\nikki\LOCALS~1\Temp\2.tmp (HEUR:::Trj.Bredavi-Backdoor)
C:\WINDOWS\system32\dllcache\ndis.sys (HEUR:::Rtk.Agent)(!!The legit C:\WINDOWS\system32\drivers\ndis.sys may be infected!!)
Extra message: Detection only.
EOF
cutenik211
Posts Posts : 27
Post by Dr Jay on Wed Jul 28, 2010 2:38 am
  • Please go to VirSCAN.org FREE on-line scan
    service
  • Browse for the following file path into the "Suspicious files to scan" box on the top of the page:
    • C:\WINDOWS\system32\dllcache\ndis.sys
  • Click on the Upload button
  • If a pop-up appears saying the file has been scanned already, please select the ReScan button.
  • Once the Scan is completed, click on the "Copy to Clipboard" button. This will copy the link of the report into the Clipboard.
  • Paste the contents of the Clipboard in your next reply.
Posts Posts : 13717
Post by cutenik211 on Wed Jul 28, 2010 6:26 pm
VirSCAN.org Scanned Report :
Scanned time : 2010/07/29 02:21:48 (CST)
Scanner results: Scanners did not find malware!
File Name : ndis.sys
File Size : 182912 byte
File Type : PE32 executable for MS Windows (native) Intel 80386 32-bit
MD5 : 558635d3af1c7546d26067d5d9b6959e
SHA1 : de08d6d587fe19ce3c61a1cf3773158df212dbe8
Online report : [You must be registered and logged in to see this link.]
Scanner Engine Ver Sig Ver Sig Date Time Scan result
a-squared 5.0.0.13 20100729002914 2010-07-29 5.91 -
AhnLab V3 2010.07.14.00 2010.07.14 2010-07-14 1.21 -
AntiVir 8.2.4.26 7.10.9.249 2010-07-28 0.27 -
Antiy 2.0.18 20100728.4872143 2010-07-28 0.02 -
Arcavir 2009 201006281601 2010-06-28 0.01 -
Authentium 5.1.1 201007280228 2010-07-28 1.61 -
AVAST! 4.7.4 100728-0 2010-07-28 0.02 -
AVG 8.5.793 271.1.1/3034 2010-07-28 0.25 -
BitDefender 7.90123.6191706 7.33050 2010-07-29 4.26 -
ClamAV 0.96.1 11451 2010-07-28 0.05 -
Comodo 4.0 5570 2010-07-28 1.10 -
CP Secure 1.3.0.5 2010.07.29 2010-07-29 0.08 -
Dr.Web 5.0.2.3300 2010.07.29 2010-07-29 8.80 -
F-Prot 4.4.4.56 20100727 2010-07-27 1.60 -
F-Secure 7.02.73807 2010.07.28.06 2010-07-28 4.46 -
Fortinet 4.1.143 12.189 2010-07-28 0.18 -
GData 21.584/21.218 20100728 2010-07-28 7.75 -
ViRobot 20100726 2010.07.26 2010-07-26 0.38 -
Ikarus T3.1.01.84 2010.07.28.76356 2010-07-28 7.29 -
JiangMin 13.0.900 2010.07.28 2010-07-28 1.29 -
Kaspersky 5.5.10 2010.07.28 2010-07-28 0.09 -
KingSoft 2009.2.5.15 2010.7.28.18 2010-07-28 0.64 -
McAfee 5400.1158 6057 2010-07-28 17.14 -
Microsoft 1.6004 2010.07.28 2010-07-28 5.96 -
Norman 6.05.11 6.05.00 2010-07-28 8.01 -
Panda 9.05.01 2010.07.25 2010-07-25 2.28 -
Trend Micro 9.120-1004 7.342.10 2010-07-28 0.00 -
Quick Heal 11.00 2010.07.27 2010-07-27 2.26 -
Rising 20.0 22.58.02.04 2010-07-28 1.55 -
Sophos 3.10.0 4.56 2010-07-29 3.46 -
Sunbelt 3.9.2432.2 6654 2010-07-28 9.03 -
Symantec 1.3.0.24 20100728.002 2010-07-28 0.28 -
nProtect 20100728.02 8808013 2010-07-28 8.96 -
The Hacker 6.5.2.1 v00325 2010-07-25 0.33 -
VBA32 3.12.12.6 20100728.1148 2010-07-28 2.92 -
VirusBuster 4.5.11.10 10.127.30/2000686 2010-07-28 2.46 -
cutenik211
Posts Posts : 27
Post by Dr Jay on Wed Jul 28, 2010 9:16 pm
Scan with Malwarebytes' Anti-Malware
Please open Malwarebytes' Anti-Malware, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan. Remove selected, and post the log in your next reply.
MySystem-Search
Please download MySystem-Search from one of the following links:
  • Save the file to your Desktop.
  • Double-click on mss.exe
  • Allow it to run, and follow the prompts.
  • Once done, it will launch a log.
  • Post it in your next reply.
Note: the logs are long. Please use more than one post, if necessary.
In your next reply, please tell me any symptoms on the computer after the scans were run, and include the following logs:
  • MBAM log
  • MySystem-Search log
Posts Posts : 13717
Post by cutenik211 on Thu Jul 29, 2010 12:42 am
Database version: 2955
7/28/2010 7:40:48 PM
mbam-log-2010-07-28 (19-40-45).txt
Objects scanned: 134573
Time elapsed: 18 minute(s), 8 second(s)
Files Infected: 1
C:\WINDOWS\system32\certstore.dat (Trojan.Agent) -> No action taken.
cutenik211
Posts Posts : 27
Post by cutenik211 on Thu Jul 29, 2010 12:45 am
MySystem-Search
MSS v1.6
Basic System Information
Username: admin - Date: 07/28/2010 - Time: 19:42:07
Processor type: x86 Family 15 Model 6 Stepping 5, GenuineIntel
Total processors: 2
Computer Name: JGAZA-BDC3015D9
Logon Server: \\JGAZA-BDC3015D9
CD Emulation Drivers running?
Peer-to-Peer applications?
LimeWire found!
File associations
.exe=exefile
.scr=scrfile
.pif=piffile
.com=comfile
.bat=batfile
.cmd=cmdfile
.log=txtfile
.txt=txtfile
.reg=regfile
.sys=sysfile
.dll=dllfile
.ini=inifile
.inf=inffile
Running processes
Image Name PID Session Name Session# Mem Usage
System Idle Process 0 Console 0 28 K
System 4 Console 0 101,548 K
smss.exe 592 Console 0 416 K
csrss.exe 648 Console 0 5,068 K
winlogon.exe 672 Console 0 1,852 K
services.exe 720 Console 0 4,880 K
lsass.exe 732 Console 0 1,580 K
nvsvc32.exe 912 Console 0 4,676 K
svchost.exe 944 Console 0 5,284 K
svchost.exe 1016 Console 0 4,868 K
svchost.exe 1236 Console 0 7,072 K
svchost.exe 1340 Console 0 4,324 K
spoolsv.exe 1480 Console 0 6,264 K
avgchsvx.exe 1492 Console 0 1,972 K
avgrsx.exe 1512 Console 0 720 K
svchost.exe 1672 Console 0 3,796 K
avgcsrvx.exe 1700 Console 0 12,572 K
AppleMobileDeviceService. 1756 Console 0 3,968 K
AsfIpMon.exe 2036 Console 0 3,680 K
avgwdsvc.exe 164 Console 0 2,116 K
mDNSResponder.exe 196 Console 0 4,016 K
jqs.exe 620 Console 0 1,392 K
SeaPort.exe 1192 Console 0 11,816 K
explorer.exe 1964 Console 0 16,020 K
svchost.exe 440 Console 0 4,700 K
WLService.exe 420 Console 0 2,416 K
WMP54Gv4.exe 936 Console 0 7,956 K
avgemc.exe 1068 Console 0 1,544 K
avgnsx.exe 1292 Console 0 200 K
avgcsrvx.exe 2328 Console 0 6,180 K
smax4pnp.exe 2396 Console 0 5,012 K
rundll32.exe 2728 Console 0 4,304 K
CamTray.exe 2764 Console 0 5,140 K
jusched.exe 2772 Console 0 9,464 K
iTunesHelper.exe 2808 Console 0 13,668 K
avgtray.exe 2908 Console 0 952 K
AdobeARM.exe 2964 Console 0 9,628 K
ctfmon.exe 2984 Console 0 3,908 K
SSScheduler.exe 3032 Console 0 2,532 K
iPodService.exe 808 Console 0 4,556 K
firefox.exe 1476 Console 0 138,328 K
wuauclt.exe 3760 Console 0 6,288 K
plugin-container.exe 3224 Console 0 21,880 K
jucheck.exe 4012 Console 0 9,592 K
svchost.exe 3496 Console 0 157,276 K
mbam.exe 1992 Console 0 40,408 K
notepad.exe 1212 Console 0 584 K
mss.exe 2896 Console 0 3,152 K
cmd.exe 1396 Console 0 2,604 K
tasklist.exe 2552 Console 0 5,012 K
wmiprvse.exe 2100 Console 0 6,236 K
Hidden objects
PATH: C:\windows
$hf_mig$
$MSI31Uninstall_KB893803v2$
$NtUninstallKB2229593$
$NtUninstallKB835221WXP$
$NtUninstallKB898461$
$NtUninstallKB923561$
$NtUninstallKB925720$
$NtUninstallKB932823-v3$
$NtUninstallKB938464-v2$
$NtUninstallKB944338-v2$
$NtUninstallKB946648$
$NtUninstallKB950760$
$NtUninstallKB950762$
$NtUninstallKB950974$
$NtUninstallKB951066$
$NtUninstallKB951376-v2$
$NtUninstallKB951748$
$NtUninstallKB952004$
$NtUninstallKB952069_WM9$
$NtUninstallKB952287$
$NtUninstallKB952954$
$NtUninstallKB954600$
$NtUninstallKB955069$
$NtUninstallKB955759$
$NtUninstallKB955839$
$NtUninstallKB956572$
$NtUninstallKB956802$
$NtUninstallKB956803$
$NtUninstallKB956844$
$NtUninstallKB957097$
$NtUninstallKB958470$
$NtUninstallKB958644$
$NtUninstallKB958687$
$NtUninstallKB958690$
$NtUninstallKB958869$
$NtUninstallKB959426$
$NtUninstallKB960225$
$NtUninstallKB960715$
$NtUninstallKB960803$
$NtUninstallKB960859$
$NtUninstallKB961118$
$NtUninstallKB961371$
$NtUninstallKB961373$
$NtUninstallKB961501$
$NtUninstallKB963027$
$NtUninstallKB967715$
$NtUninstallKB968389$
$NtUninstallKB968537$
$NtUninstallKB969059$
$NtUninstallKB969897$
$NtUninstallKB969898$
$NtUninstallKB969947$
$NtUninstallKB970238$
$NtUninstallKB970430$
$NtUninstallKB970653-v3$
$NtUninstallKB971032$
$NtUninstallKB971468$
$NtUninstallKB971486$
$NtUninstallKB971557$
$NtUninstallKB971633$
$NtUninstallKB971657$
$NtUninstallKB971737$
$NtUninstallKB972260$
$NtUninstallKB972270$
$NtUninstallKB973346$
$NtUninstallKB973354$
$NtUninstallKB973507$
$NtUninstallKB973525$
$NtUninstallKB973540_WM9L$
$NtUninstallKB973687$
$NtUninstallKB973815$
$NtUninstallKB973869$
$NtUninstallKB973904$
$NtUninstallKB974112$
$NtUninstallKB974318$
$NtUninstallKB974392$
$NtUninstallKB974571$
$NtUninstallKB975025$
$NtUninstallKB975467$
$NtUninstallKB975560$
$NtUninstallKB975561$
$NtUninstallKB975562$
$NtUninstallKB975713$
$NtUninstallKB976098-v2$
$NtUninstallKB977165$
$NtUninstallKB977816$
$NtUninstallKB977914$
$NtUninstallKB978037$
$NtUninstallKB978251$
$NtUninstallKB978262$
$NtUninstallKB978338$
$NtUninstallKB978542$
$NtUninstallKB978601$
$NtUninstallKB978706$
$NtUninstallKB979306$
$NtUninstallKB979309$
$NtUninstallKB979402_WM9L$
$NtUninstallKB979482$
$NtUninstallKB979559$
$NtUninstallKB979683$
$NtUninstallKB980195$
$NtUninstallKB980218$
$NtUninstallKB980232$
$NtUninstallKB981793$
$NtUninstallWIC$
$NtUninstallWMFDist11$
CSC
ie8
inf
Installer
WindowsShell.Manifest
PATH: C:\windows\system32
1a66be40.dll
24c1d03.dll
2d39dc0.dll
70c2c44.dll
cdplayer.exe.manifest
dllcache
ezsidmv.dat
HsInfo.dat
logonui.exe.manifest
mlfcache.dat
ncpa.cpl.manifest
nwc.cpl.manifest
sapi.cpl.manifest
WindowsLogon.manifest
wuaucpl.cpl.manifest
PATH: C:\windows\system32\drivers
PATH: C:\
$AVG
boot.ini
cmdcons
IO.SYS
MSDOS.SYS
MSOCache
NTDETECT.COM
ntldr
pagefile.sys
RECYCLER
System Volume Information
User Profile check
! REG.EXE VERSION 3.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
ProfilesDirectory REG_EXPAND_SZ %SystemDrive%\Documents and Settings
DefaultUserProfile REG_SZ Default User
AllUsersProfile REG_SZ All Users
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-18
Flags REG_DWORD 0xc
State REG_DWORD 0x0
RefCount REG_DWORD 0x1
Sid REG_BINARY 010100000000000512000000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-19
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\LocalService
Sid REG_BINARY 010100000000000513000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
CentralProfile REG_SZ
ProfileLoadTimeLow REG_DWORD 0xeacc8b5a
ProfileLoadTimeHigh REG_DWORD 0x1cb2e80
RefCount REG_DWORD 0x2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-20
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\NetworkService
Sid REG_BINARY 010100000000000514000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0xea89c982
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-823518204-573735546-725345543-1003
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\admin
Sid REG_BINARY 010500000000000515000000FCE315317A82322207E53B2BEB030000
Flags REG_DWORD 0x0
State REG_DWORD 0x100
ProfileLoadTimeLow REG_DWORD 0xeef181cc
RunLogonScriptSync REG_DWORD 0x0
OptimizedLogonStatus REG_DWORD 0xb
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-823518204-573735546-725345543-1004
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\nikki
Sid REG_BINARY 010500000000000515000000FCE315317A82322207E53B2BEC030000
Flags REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0xfce22256
ProfileLoadTimeHigh REG_DWORD 0x1cb2e7f
RefCount REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-823518204-573735546-725345543-500
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\Administrator
Sid REG_BINARY 010500000000000515000000FCE315317A82322207E53B2BF4010000
Flags REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0x68dc9614
ProfileLoadTimeHigh REG_DWORD 0x1c8c247
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-823518204-573735546-725345543-501
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\Guest
Sid REG_BINARY 010500000000000515000000FCE315317A82322207E53B2BF5010000
Flags REG_DWORD 0x0
State REG_DWORD 0x80
ProfileLoadTimeLow REG_DWORD 0xd8e8dada
ProfileLoadTimeHigh REG_DWORD 0x1cb2de3
Current Scheduled Tasks
PATH: C:\Windows\Tasks
AppleSoftwareUpdate.job
GoogleUpdateTaskMachineCore.job
GoogleUpdateTaskMachineUA.job
mixpadShakeIcon.job
photostageSevenDays.job
photostageShakeIcon.job
Updater.job
videopadShakeIcon.job
wavepadShakeIcon.job
desktop.ini
SA.DAT
User_Feed_Synchronization-{9387AF0C-9827-4C56-8418-C356C23D5B76}.job
Windows Drivers and NT-Services
Volume in drive C has no label.
Volume Serial Number is 5C0E-6A10
08/17/2001 08:59 AM 3,072 audstub.sys
08/17/2001 01:51 PM 3,328 pciide.sys
08/17/2001 01:58 PM 35,840 isapnp.sys
08/17/2001 03:48 PM 12,160 mouhid.sys
08/17/2001 04:00 PM 54,272 swmidi.sys
10/01/2002 03:43 PM 119,798 SPCA561.SYS
03/16/2004 01:58 PM 136,960 portcls.sys
04/16/2004 01:20 AM 90,700 P0620Vid.sys
08/03/2004 05:59 PM 57,472 redbook.sys
08/03/2004 10:58 PM 15,104 usbscan.sys
08/03/2004 10:59 PM 25,088 pciidex.sys
08/03/2004 10:59 PM 95,360 atapi.sys
08/03/2004 11:01 PM 25,856 usbprint.sys
08/03/2004 11:07 PM 68,224 pci.sys
08/03/2004 11:08 PM 20,480 usbuhci.sys
08/03/2004 11:08 PM 57,600 usbhub.sys
08/03/2004 11:58 PM 5,504 MSTEE.sys
08/04/2004 12:10 AM 10,880 NdisIP.sys
08/04/2004 12:10 AM 15,360 StreamIP.sys
08/04/2004 12:10 AM 17,024 CCDECODE.sys
08/04/2004 12:10 AM 11,136 SLIP.sys
08/04/2004 12:10 AM 19,328 WSTCODEC.SYS
08/04/2004 12:10 AM 85,376 NABTSFEC.sys
08/04/2004 12:15 AM 140,928 ks.sys
08/04/2004 12:39 AM 142,464 aec.sys
08/04/2004 12:58 AM 23,040 mouclass.sys
08/04/2004 12:58 AM 5,376 MSPCLOCK.sys
08/04/2004 12:58 AM 4,992 MSPQM.sys
08/04/2004 12:58 AM 7,552 MSKSSRV.sys
08/04/2004 01:01 AM 196,864 rdpdr.sys
08/04/2004 01:07 AM 52,864 DMusic.sys
08/04/2004 01:07 AM 6,400 splitter.sys
08/04/2004 01:07 AM 171,776 kmixer.sys
08/04/2004 01:07 AM 2,944 drmkaud.sys
08/04/2004 01:08 AM 60,288 drmk.sys
08/04/2004 01:08 AM 48,640 stream.sys
08/04/2004 01:08 AM 31,616 usbccgp.sys
08/04/2004 01:08 AM 26,496 USBSTOR.SYS
08/04/2004 01:15 AM 82,944 wdmaud.sys
08/04/2004 01:15 AM 60,800 sysaudio.sys
08/04/2004 03:01 AM 40,840 termdd.sys
08/04/2004 05:00 AM 36,352 disk.sys
08/04/2004 05:00 AM 14,208 diskdump.sys
08/04/2004 05:00 AM 799,744 dmboot.sys
08/04/2004 05:00 AM 153,344 dmio.sys
08/04/2004 05:00 AM 5,888 dmload.sys
08/04/2004 05:00 AM 11,776 cpqdap01.sys
08/04/2004 05:00 AM 49,664 classpnp.sys
08/04/2004 05:00 AM 262,528 cinemst2.sys
08/04/2004 05:00 AM 10,496 dxapi.sys
08/04/2004 05:00 AM 71,040 dxg.sys
08/04/2004 05:00 AM 3,328 dxgthk.sys
08/04/2004 05:00 AM 12,672 usb8023.sys
08/04/2004 05:00 AM 143,360 fastfat.sys
08/04/2004 05:00 AM 27,392 fdc.sys
08/04/2004 05:00 AM 34,944 fips.sys
08/04/2004 05:00 AM 20,480 flpydisk.sys
08/04/2004 05:00 AM 124,800 fltMgr.sys
08/04/2004 05:00 AM 12,160 fsvga.sys
08/04/2004 05:00 AM 7,936 fs_rec.sys
08/04/2004 05:00 AM 125,056 ftdisk.sys
08/04/2004 05:00 AM 209,408 update.sys
08/04/2004 05:00 AM 3,440,660 gm.dls
08/04/2004 05:00 AM 646 gmreadme.txt
08/04/2004 05:00 AM 66,176 udfs.sys
08/04/2004 05:00 AM 12,416 tunmp.sys
08/04/2004 05:00 AM 36,224 hidclass.sys
08/04/2004 05:00 AM 24,960 hidparse.sys
08/04/2004 05:00 AM 9,600 hidusb.sys
08/04/2004 05:00 AM 21,376 tsbvcap.sys
08/04/2004 05:00 AM 51,712 tosdvd.sys
08/04/2004 05:00 AM 23,808 usbcamd.sys
08/04/2004 05:00 AM 21,896 tdtcp.sys
08/04/2004 05:00 AM 12,040 tdpipe.sys
08/04/2004 05:00 AM 41,856 imapi.sys
08/04/2004 05:00 AM 36,096 intelppm.sys
08/04/2004 05:00 AM 29,056 ip6fw.sys
08/04/2004 05:00 AM 32,896 ipfltdrv.sys
08/04/2004 05:00 AM 20,992 ipinip.sys
08/04/2004 05:00 AM 134,912 ipnat.sys
08/04/2004 05:00 AM 74,752 ipsec.sys
08/04/2004 05:00 AM 11,264 irenum.sys
08/04/2004 05:00 AM 31,360 atmepvc.sys
08/04/2004 05:00 AM 24,576 kbdclass.sys
08/04/2004 05:00 AM 14,848 kbdhid.sys
08/04/2004 05:00 AM 49,536 cdrom.sys
08/04/2004 05:00 AM 4,736 usbd.sys
08/04/2004 05:00 AM 59,904 atmarpc.sys
08/04/2004 05:00 AM 14,976 tape.sys
08/04/2004 05:00 AM 23,936 usbcamd2.sys
08/04/2004 05:00 AM 7,680 mcd.sys
08/04/2004 05:00 AM 63,744 mf.sys
08/04/2004 05:00 AM 4,224 mnmdd.sys
08/04/2004 05:00 AM 30,080 modem.sys
08/04/2004 05:00 AM 63,744 cdfs.sys
08/04/2004 05:00 AM 14,336 asyncmac.sys
08/04/2004 05:00 AM 42,240 mountmgr.sys
08/04/2004 05:00 AM 60,800 arp1394.sys
08/04/2004 05:00 AM 181,248 mrxdav.sys
08/04/2004 05:00 AM 4,352 swenum.sys
08/04/2004 05:00 AM 19,072 msfs.sys
08/04/2004 05:00 AM 35,072 msgpc.sys
08/04/2004 05:00 AM 18,688 cdaudio.sys
08/04/2004 05:00 AM 352,256 atmuni.sys
08/04/2004 05:00 AM 13,952 cbidf2k.sys
08/04/2004 05:00 AM 15,488 mssmbios.sys
08/04/2004 05:00 AM 37,376 amdk7.sys
08/04/2004 05:00 AM 107,904 mup.sys
08/04/2004 05:00 AM 16,000 usbintel.sys
08/04/2004 05:00 AM 182,912 ndis.sys
08/04/2004 05:00 AM 36,992 amdk6.sys
08/04/2004 05:00 AM 9,600 ndistapi.sys
08/04/2004 05:00 AM 12,928 ndisuio.sys
08/04/2004 05:00 AM 91,776 ndiswan.sys
08/04/2004 05:00 AM 38,016 ndproxy.sys
08/04/2004 05:00 AM 34,560 netbios.sys
08/04/2004 05:00 AM 162,816 netbt.sys
08/04/2004 05:00 AM 61,824 nic1394.sys
08/04/2004 05:00 AM 12,032 nikedrv.sys
08/04/2004 05:00 AM 40,320 nmnt.sys
08/04/2004 05:00 AM 30,848 npfs.sys
08/04/2004 05:00 AM 574,592 ntfs.sys
08/04/2004 05:00 AM 2,944 null.sys
08/04/2004 05:00 AM 52,352 volsnap.sys
08/04/2004 05:00 AM 71,552 bridge.sys
08/04/2004 05:00 AM 73,472 sr.sys
08/04/2004 05:00 AM 12,416 nwlnkflt.sys
08/04/2004 05:00 AM 32,512 nwlnkfwd.sys
08/04/2004 05:00 AM 88,448 nwlnkipx.sys
08/04/2004 05:00 AM 63,232 nwlnknb.sys
08/04/2004 05:00 AM 55,936 nwlnkspx.sys
08/04/2004 05:00 AM 163,584 nwrdr.sys
08/04/2004 05:00 AM 3,456 oprghdlr.sys
08/04/2004 05:00 AM 34,560 wanarp.sys
08/04/2004 05:00 AM 42,496 p3.sys
08/04/2004 05:00 AM 80,128 parport.sys
08/04/2004 05:00 AM 18,688 partmgr.sys
08/04/2004 05:00 AM 6,784 parvdm.sys
08/04/2004 05:00 AM 20,992 vga.sys
08/04/2004 05:00 AM 55,936 atmlane.sys
08/04/2004 05:00 AM 11,648 acpiec.sys
08/04/2004 05:00 AM 119,936 pcmcia.sys
08/04/2004 05:00 AM 187,776 acpi.sys
08/04/2004 05:00 AM 35,328 processr.sys
08/04/2004 05:00 AM 69,120 psched.sys
08/04/2004 05:00 AM 17,792 ptilink.sys
08/04/2004 05:00 AM 58,112 vdmindvd.sys
08/04/2004 05:00 AM 8,832 rasacd.sys
08/04/2004 05:00 AM 51,328 rasl2tp.sys
08/04/2004 05:00 AM 41,472 raspppoe.sys
08/04/2004 05:00 AM 48,384 raspptp.sys
08/04/2004 05:00 AM 16,512 raspti.sys
08/04/2004 05:00 AM 34,432 rawwan.sys
08/04/2004 05:00 AM 176,512 rdbss.sys
08/04/2004 05:00 AM 4,224 rdpcdd.sys
08/04/2004 05:00 AM 36,480 crusoe.sys
08/04/2004 05:00 AM 139,400 rdpwd.sys
08/04/2004 05:00 AM 4,352 wmilib.sys
08/04/2004 05:00 AM 12,032 rio8drv.sys
08/04/2004 05:00 AM 12,032 riodrv.sys
08/04/2004 05:00 AM 12,032 ws2ifsl.sys
08/04/2004 05:00 AM 30,080 rndismp.sys
08/04/2004 05:00 AM 5,888 rootmdm.sys
08/04/2004 05:00 AM 25,472 sonydcam.sys
08/04/2004 05:00 AM 96,256 scsiport.sys
08/04/2004 05:00 AM 67,584 sdbus.sys
08/04/2004 05:00 AM 27,440 secdrv.sys
08/04/2004 05:00 AM 14,592 smclib.sys
08/04/2004 05:00 AM 15,488 serenum.sys
08/04/2004 05:00 AM 64,896 serial.sys
08/04/2004 05:00 AM 11,136 sffdisk.sys
08/04/2004 05:00 AM 10,240 sffp_sd.sys
08/04/2004 05:00 AM 11,392 sfloppy.sys
08/04/2004 05:00 AM 18,560 tdi.sys
08/12/2004 07:45 PM 113,664 Hdaudio.sys
08/12/2004 07:45 PM 137,728 Hdaudbus.sys
12/13/2004 04:14 PM 39,904 cercsr6.sys
02/01/2005 06:18 PM 17,992 bcm42rly.sys
10/25/2005 06:39 PM 27,264 usbehci.sys
10/25/2005 06:39 PM 143,104 usbport.sys
10/27/2005 03:06 PM 356,096 rt61.sys
12/17/2005 12:56 AM 51,120 HPZid412.sys
12/17/2005 12:56 AM 16,496 HPZipr12.sys
12/17/2005 12:56 AM 21,744 HPZius12.sys
03/17/2006 08:18 PM 392,960 senfilt.sys
07/05/2006 06:08 PM 241,152 ADIHdAud.sys
08/03/2006 09:02 AM 81,664 videoprt.sys
08/24/2006 08:26 PM 38,656 wpdusb.sys
06/06/2007 02:51 PM 161,792 b57xp32.sys
04/02/2008 03:15 PM 6,008,704 igxpmp32.sys
05/08/2008 07:28 AM 202,752 rmcast.sys
06/13/2008 08:10 AM 272,128 bthport.sys
06/20/2008 05:45 AM 360,320 tcpip.sys
07/17/2008 02:24 PM 141,582 NVCAP.SYS
07/17/2008 02:24 PM 16,496 NVXBAR.SYS
08/14/2008 04:51 AM 138,368 afd.sys
08/24/2008 10:00 PM 20,747 AegisP.sys
04/24/2009 10:41 AM disdn
04/27/2009 08:40 PM 5 DELL_OPT_745.MRK
04/27/2009 08:40 PM 5 1028_DELL_OPT_745.MRK
05/01/2009 04:03 PM 9,464 cdralw2k.sys
05/01/2009 04:03 PM 43,528 PxHelp20.sys
05/01/2009 04:03 PM 9,336 cdr4_xp.sys
05/18/2009 02:17 PM 26,600 GEARAspiWDM.sys
06/22/2009 06:35 AM 92,544 ksecdd.sys
06/22/2009 06:48 AM 91,776 mqac.sys
07/14/2009 01:54 PM 7,741,664 nv4_mini.sys
08/28/2009 07:42 PM 40,448 usbaapl.sys
09/05/2009 03:30 PM umdf
09/10/2009 02:53 PM 19,160 mbam.sys
09/10/2009 02:54 PM 38,224 mbamswissarmy.sys
10/14/2009 07:03 PM etc
10/20/2009 09:58 AM 263,552 http.sys
12/31/2009 11:14 AM 352,640 srv.sys
02/11/2010 07:01 AM 226,880 tcpip6.sys
02/24/2010 07:31 AM 454,016 mrxsmb.sys
06/02/2010 09:46 AM 29,584 avgmfx86.sys
07/15/2010 12:04 PM 216,400 avgldx86.sys
07/15/2010 12:05 PM 243,024 avgtdix.sys
07/15/2010 12:10 PM ..
07/28/2010 06:36 PM Avg
216 File(s) 32,211,535 bytes
6 Dir(s) 6,356,422,656 bytes free
Virtual drives found?
Environment variables
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\admin\Application Data
CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=JGAZA-BDC3015D9
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\admin
LOGONSERVER=\\JGAZA-BDC3015D9
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program Files\Common Files\DivX Shared;C:\Program Files\QuickTime\QTSystem;C:\Program Files\QuickTime\QTSystem\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 6 Stepping 5, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0605
PROMPT=$P$G
QTJAVA=C:\Program Files\Java\jre6\lib\ext\QTJava.zip
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\admin\LOCALS~1\Temp
TMP=C:\DOCUME~1\admin\LOCALS~1\Temp
USERDOMAIN=JGAZA-BDC3015D9
USERNAME=admin
USERPROFILE=C:\Documents and Settings\admin
windir=C:\WINDOWS
Stealth malware?
Internet Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main
Default_Page_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
Default_Search_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Search Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Enable_Disk_Cache REG_SZ yes
Cache_Percent_of_Disk REG_BINARY 0A000000
Delete_Temp_Files_On_Exit REG_SZ yes
Local Page REG_SZ C:\WINDOWS\system32\blank.htm
Anchor_Visitation_Horizon REG_BINARY 01000000
Use_Async_DNS REG_SZ yes
Placeholder_Width REG_BINARY 1A000000
Placeholder_Height REG_BINARY 1A000000
Start Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
CompanyName REG_SZ Microsoft Corporation
Custom_Key REG_SZ MICROSO
Wizard_Version REG_SZ 6.0.2600.0000
FullScreen REG_SZ no
Search Bar REG_SZ http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr9/*http://www.yahoo.com/ext/search/search.html
Check_Associations REG_SZ no
Default_Secondary_Page_URL REG_MULTI_SZ \0
Extensions Off Page REG_SZ about:NoAdd-ons
Security Risk Page REG_SZ about:SecurityRisk
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\ErrorThresholds
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
User Agent REG_SZ Mozilla/4.0 (compatible; MSIE 8.0; Win32)
IE5_UA_Backup_Flag REG_SZ 5.0
NoNetAutodial REG_DWORD 0x0
MigrateProxy REG_DWORD 0x1
EmailName REG_SZ IEUser@
AutoConfigProxy REG_SZ wininet.dll
MimeExclusionListForCache REG_SZ multipart/mixed multipart/x-mixed-replace multipart/x-byteranges
WarnOnPost REG_BINARY 01000000
UseSchannelDirectly REG_BINARY 01000000
EnableHttp1_1 REG_DWORD 0x1
PrivacyAdvanced REG_DWORD 0x0
EnableNegotiate REG_DWORD 0x1
ProxyEnable REG_DWORD 0x0
UrlEncoding REG_DWORD 0x0
SecureProtocols REG_DWORD 0xa0
PrivDiscUiShown REG_DWORD 0x1
ZonesSecurityUpgrade REG_BINARY BEA4126DCB17CA01
DisableCachingOfSSLPages REG_DWORD 0x0
WarnonZoneCrossing REG_DWORD 0x0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Lockdown_Zones
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\P3P
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Passport
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main
NoUpdateCheck REG_DWORD 0x1
NoJITSetup REG_DWORD 0x1
Disable Script Debugger REG_SZ yes
Show_ChannelBand REG_SZ No
Anchor Underline REG_SZ yes
Cache_Update_Frequency REG_SZ Once_Per_Session
Display Inline Images REG_SZ yes
Do404Search REG_BINARY 01000000
Save_Session_History_On_Exit REG_SZ no
Show_FullURL REG_SZ no
Show_StatusBar REG_SZ yes
Show_ToolBar REG_SZ yes
Show_URLinStatusBar REG_SZ yes
Show_URLToolBar REG_SZ yes
Start Page REG_SZ http://www.microsoft.com/isapi/redir.dll?prd=ie&pver=6&ar=msnhome
Use_DlgBox_Colors REG_SZ yes
Search Page REG_SZ http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
ShowedCheckBrowser REG_SZ Yes
Window_Placement REG_BINARY 2C00000000000000010000000083FFFF0083FFFFFFFFFFFFFFFFFFFF2700000027000000470300007F020000
XMLHTTP REG_DWORD 0x1
UseClearType REG_SZ yes
Enable Browser Extensions REG_SZ yes
Play_Background_Sounds REG_SZ yes
Play_Animations REG_SZ yes
CompatibilityFlags REG_DWORD 0x0
IE8RunOnceLastShown REG_DWORD 0x1
IE8RunOnceLastShown_TIMESTAMP REG_BINARY 1EF0855E802ECB01
IE8TourShown REG_DWORD 0x1
IE8TourShownTime REG_BINARY 5E94D3A8CB17CA01
AutoHide REG_SZ yes
Use FormSuggest REG_SZ yes
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Default Feeds
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\WindowsSearch
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search
SearchAssistant REG_SZ http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm
CustomizeSearch REG_SZ http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm
CustomSearch REG_SZ http://us.rd.yahoo.com/customize/ie/defaults/cs/msgr9/*http://www.yahoo.com/ext/search/search.html
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks
{CFBFAE00-17A6-11D0-99CB-00C04FD64497} REG_SZ
{EF99BD32-C1FB-11D2-892F-0090271D4F88} REG_SZ
{A3BC75A2-1F87-4686-AA43-5347D756017C} REG_SZ
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4efb-9B51-7695ECA05670}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{53707962-6F74-2D53-2644-206D7942484F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{6EBF7485-159F-4bff-A14F-B9E3AAC4465B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{d2ce3e00-f94a-4740-988e-03dc2f38c34f}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DA3F1CDD-8C2D-4446-B6AE-09680DAFDF05}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar
{EF99BD32-C1FB-11D2-892F-0090271D4F88} REG_BINARY 00
{0FBB9689-D3D7-4f7a-A2E2-585B10099BFC} REG_SZ Veoh Web Player Video Finder
{52836EB0-631A-47B1-94A6-61F9D9112DAE} REG_SZ Veoh Video Compass
{1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} REG_BINARY 00
{CCC7A320-B3CA-4199-B1A6-9F516DD69829} REG_SZ AVG Security Toolbar
{2318C2B1-4965-11d4-9B18-009027A5CD4F} REG_BINARY 00
Protocol hijack?
Security Center
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center
FirstRunDisabled REG_DWORD 0x1
AntiVirusDisableNotify REG_DWORD 0x0
FirewallDisableNotify REG_DWORD 0x0
AntiVirusOverride REG_DWORD 0x0
FirewallOverride REG_DWORD 0x0
UpdatesDisableNotify REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile
EnableFirewall REG_DWORD 0x1
DoNotAllowExceptions REG_DWORD 0x0
DisableNotifications REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List
%windir%\system32\sessmgr.exe REG_SZ %windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019
C:\Program Files\Ventrilo\Ventrilo.exe REG_SZ C:\Program Files\Ventrilo\Ventrilo.exe:*:Enabled:Ventrilo.exe
C:\Program Files\World of Warcraft\Launcher.exe REG_SZ C:\Program Files\World of Warcraft\Launcher.exe:*:Enabled:World of Warcraft
C:\Program Files\Curse\CurseClient.exe REG_SZ C:\Program Files\Curse\CurseClient.exe:*:Enabled:Curse Client
C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe REG_SZ C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger
C:\Program Files\Bonjour\mDNSResponder.exe REG_SZ C:\Program Files\Bonjour\mDNSResponder.exe:*:Enabled:Bonjour
C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe REG_SZ C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe:*:Enabled:Veoh Web Player
C:\Program Files\Linksys Wireless-G PCI Wireless Network Monitor\WMP54Gv4.exe REG_SZ C:\Program Files\Linksys Wireless-G PCI Wireless Network Monitor\WMP54Gv4.exe:*:Enabled:WMP54Gv4
C:\Program Files\iPod\bin\iPodService.exe REG_SZ C:\Program Files\iPod\bin\iPodService.exe:*:Enabled:iPodService
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe REG_SZ C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe:*:Enabled:AppleMobileDeviceService
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe REG_SZ C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe:*:Enabled:SeaPort
C:\Program Files\Skype\Plugin Manager\skypePM.exe REG_SZ C:\Program Files\Skype\Plugin Manager\skypePM.exe:*:Enabled:Skype Extras Manager
C:\Program Files\iTunes\iTunes.exe REG_SZ C:\Program Files\iTunes\iTunes.exe:*:Enabled:iTunes
C:\Program Files\AVG\AVG9\avgemc.exe REG_SZ C:\Program Files\AVG\AVG9\avgemc.exe:*:Enabled:avgemc.exe
C:\Program Files\AVG\AVG9\avgupd.exe REG_SZ C:\Program Files\AVG\AVG9\avgupd.exe:*:Enabled:avgupd.exe
C:\Program Files\AVG\AVG9\avgnsx.exe REG_SZ C:\Program Files\AVG\AVG9\avgnsx.exe:*:Enabled:avgnsx.exe
C:\Program Files\LimeWire\LimeWire.exe REG_SZ C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire
C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE REG_SZ C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE:*:Enabled:Microsoft Office OneNote
C:\Program Files\Skype\Phone\Skype.exe REG_SZ C:\Program Files\Skype\Phone\Skype.exe:*:Enabled:Skype
Uninstall List
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\$NtUninstallMTF1011$
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\7-Zip
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AddressBook
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe AIR
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Any DVD Converter Professional_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Any Video Converter_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Branding
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\CamStudio
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\CamStudio Lossless Codec_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Connection Manager
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Creative PD0620
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Creative WebCam Center
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Creative WebCam Instant
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Creative WebCam Instant User's Guide English
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DirectAnimation
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DirectDrawEx
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DXM_Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ffdshow_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fontcore
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fraps
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Get Yahoo! Messenger
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Google Chrome
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HDMI
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HOMESTUDENTR
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ICW
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IDNMitigationAPIs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE40
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE4Data
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE5BAKEX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ie7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ie8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IEData
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2229593
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB835221WXP
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB839210
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884267
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB885353
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB886612
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887078
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887626
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB888656
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB891122
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB892130
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893240
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893241
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893803v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895181
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895316
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB897586
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB898461
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB898549
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB900399
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB902344
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB908673
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB911854
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB912812
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB921411
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB923232
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB923561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB925720
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB932823-v3
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB938464-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB944338-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB946648
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950760
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950762
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950974
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951066
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951376-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952004
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952069_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952287
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952954
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954550-v5
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954600
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955069
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955759
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955839
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956572
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956802
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956844
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB957097
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958470
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958644
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958690
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB959426
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960225
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960715
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960859
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961118
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961371
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961373
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961501
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB963027
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB967715
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968389
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968537
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969059
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969897
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969898
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969947
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970238
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970430
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970653-v3
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971032
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971468
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971486
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971557
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971633
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971657
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971737
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971961-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972260
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972260-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972270
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973346
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973354
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973507
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973525
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973540_WM9L
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973815
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973904
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974112
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974318
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974392
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974455-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974571
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975025
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975467
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975560
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975562
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975713
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976098-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976325-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976662-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976749-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977165
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977816
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977914
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978037
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978207-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978251
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978262
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978338
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978601
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978706
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979306
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979309
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979402_WM9L
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979482
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979559
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979683
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980182-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980195
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980218
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980232
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981332-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981793
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB982381-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\LimeWire
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\M979906
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Malwarebytes' Anti-Malware_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\McAfee Security Scan
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MetaFrame Presentation Server Web Client for Win32
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 1.1 (1033)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 3.5 SP1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MixPad
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MobileOptionPack
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Mozilla Firefox (3.6.7)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MPlayer2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30a-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-Beta
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NetMeeting
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NLSDownlevelMapping
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NVIDIA Drivers
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NVIDIA nView Desktop Manager
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\OutlookExpress
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PCHealth
cutenik211
Posts Posts : 27
Post by cutenik211 on Thu Jul 29, 2010 12:48 am
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PhotoPad
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PhotoScape
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PhotoStage
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SchedulingAgent
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SCLS
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SolveigMM AVI Trimmer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SystemRequirementsLab
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Tales of Pirates Online_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Veoh Video Compass
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Veoh Web Player Beta
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\VideoPad
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ViiKiiDesktopPlugin.5E22EA0FF243470AB5EDDF282C0A5B52E9909C36.1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WavePad
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WGA
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WgaNotify
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WIC
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows Media Format Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WinGimp-2.0_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WMFDist11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\World of Warcraft
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\XpsEPSC
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Yahoo! Companion
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Yahoo! Messenger
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Yahoo! Toolbar
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{071B9AFA-EBE8-4ABF-8F4A-9F92612F517E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{07287123-B8AC-41CE-8346-3D777245C35B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{13F3917B56CD4C25848BDC69916971BB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1451DE6B-ABE1-4F62-BE9A-B363A17588A2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{14E94112-5F6B-4049-B177-4C7E69D3C3A0}_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{177D1318-3E4B-4A7C-A300-AC4E21BE090B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{18455581-E099-4BA8-BC6B-F34B2F06600C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{18D10072035C4515918F7E37EAFAACFC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2318C2B1-4965-11d4-9B18-009027A5CD4F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216015FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216016FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216017FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{363435F2-7426-11D8-9966-00A0C9663221}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3FA365DF-2D68-45ED-8F83-8C8A33E65143}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3FC7CBBC4C1E11DCA1A752EA55D89593}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{475CEB7F-F373-743A-AC19-7CE00D01A74A}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4DDC3BED-CC68-44AA-B435-D727B620CA5B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{56EA8BC0-3751-4B93-BC9D-6651CC36E5AA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5905F42D-3F5F-4916-ADA6-94A3646AEE76}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5CDDF96A-BC34-4D72-9ABA-E1FFF0C39977}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{62369F2F77534556AEF4C58152E3BDE5}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6956856F-B6B3-4BE0-BA0B-8F495BE32033}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6D8D64BE-F500-55B6-705D-DFD08AFE0624}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7585478E9D9B42108671C12F8714CEFE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{767CC44C-9BBC-438D-BAD3-FD4595DD148B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{789289CA-F73A-4A16-A331-54D498CE069F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7B63B2922B174135AFC0E1377DD81EC2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8ADFC4160D694100B5B8A22DE9DCABD9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0010-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0016-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0018-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001B-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-040C-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-0C0A-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-002C-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-006E-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-00A1-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0115-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0112C750-A06F-4F92-9C40-E5C1EA9A70EB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{1D53FB73-9826-4541-B2E0-A239C6EBA718}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{329050A9-EF80-40F9-B633-74508F54C1FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{69F52148-9BF6-4CDC-BF76-103DEAF3DD08}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{71127777-8B2C-4F97-AF7A-6CF8CAC8224D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{7F207DCA-3399-40CB-A968-6E5991B1421A}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{8CCB781A-CF6B-4FCB-B6D8-59C64DF5C6DB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{B0EC5722-241F-4CDA-83B4-AA5846B6F9F4}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{C3F9A0DC-A5D1-4BB6-870E-2953E5A2487B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{C444285D-5E4F-48A4-91DD-47AAAA68E92D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{E8766951-2B6C-4022-86E8-80D2D1762B76}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{F5B70033-E79C-4569-90BF-BC9B4E4F3F46}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{FCD742B9-7A55-44BC-A776-F795F21FEDDC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{981029E0-7FC9-4CF3-AB39-6F133621921A}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{98177940-C048-4831-A279-F3888B1E2C7F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9C9CEB9D-53FD-49A7-85D2-FE674F72F24E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB300003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB958483
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB975195
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976570
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976578
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976578v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976769
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976769v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB977354
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB977354v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A8AC89BA-D8CB-4372-9743-1C54D23286B0}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC067AB0-2594-4A7E-A1DE-ADEB7D15EB4B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC76BA86-7AD7-1033-7B44-A93000000001}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B023185F-F1EF-4F97-B0BD-AE6D802226D1}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B13A7C41581B411290FBC0395694E2A9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B194272D-1F92-46DF-99EB-8D5CE91CB4EC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B6EF6DCE-078E-4952-A7FA-352A9C349EB0}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B7148D71-0A8F-4501-96B4-4E1CC67F874E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BAF78226-3200-4DB4-BE33-4D922A799840}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BB8B979E-E336-47E7-96BC-1031C1B94561}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB200003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB431780
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB946922
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB947748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB949272
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952137
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952677
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953300
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953990
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB954832
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB956860
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957541
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957543
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958129
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958481
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB971111
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB974417
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976569
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976576
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976765v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB979909
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB980773
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB350003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB953595
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB958484
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB963707
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{D103C4BA-F905-437A-8049-DB24763BBE36}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F0A37341-D692-11D4-A984-009027EC0A9C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F439D7AF-03F3-4F8E-AEC4-571BFE977C61}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F48C6EA5-3B43-11D6-86A6-0050BA0259A2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FC57FC53-104C-415C-98D7-B05E659461A9}
Adobe Products
DisplayName REG_SZ Adobe Flash Player 10 ActiveX
DisplayVersion REG_SZ 10.0.45.2
Publisher REG_SZ Adobe Systems Incorporated
URLInfoAbout REG_SZ http://www.adobe.com/go/getflashplayer
VersionMajor REG_SZ 10
VersionMinor REG_SZ 0
HelpLink REG_SZ http://www.adobe.com/go/flashplayer_support/
URLUpdateInfo REG_SZ http://www.adobe.com/go/flashplayer/
DisplayIcon REG_SZ C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
UninstallString REG_SZ C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
RequiresIESysFile REG_SZ 4.70.0.1155
NoModify REG_DWORD 0x1
NoRepair REG_DWORD 0x1
! REG.EXE VERSION 3.0
DisplayName REG_SZ Adobe Flash Player 10 Plugin
DisplayVersion REG_SZ 10.1.53.64
URLUpdateInfo REG_SZ http://www.adobe.com/go/getflashplayer/
VersionMajor REG_DWORD 0xa
VersionMinor REG_DWORD 0x1
UninstallString REG_SZ C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe -maintain plugin
DisplayIcon REG_SZ C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
EstimatedSize REG_DWORD 0x1800
Autorun
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
ctfmon.exe REG_SZ C:\WINDOWS\system32\ctfmon.exe
SoundMAXPnP REG_SZ C:\Program Files\Analog Devices\Core\smax4pnp.exe
IgfxTray REG_SZ C:\WINDOWS\system32\igfxtray.exe
HotKeysCmds REG_SZ C:\WINDOWS\system32\hkcmd.exe
Persistence REG_SZ C:\WINDOWS\system32\igfxpers.exe
Microsoft Default Manager REG_SZ "C:\Program Files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
nwiz REG_SZ C:\Program Files\NVIDIA Corporation\nView\nwiz.exe /install
NvMediaCenter REG_SZ RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
NvCplDaemon REG_SZ RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
Malwarebytes Anti-Malware (reboot) REG_SZ "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
Creative WebCam Tray REG_SZ C:\Program Files\Creative\Shared Files\CAMTRAY.EXE
SunJavaUpdateSched REG_SZ "C:\Program Files\Java\jre6\bin\jusched.exe"
QuickTime Task REG_SZ "C:\Program Files\QuickTime\QTTask.exe" -atboottime
iTunesHelper REG_SZ "C:\Program Files\iTunes\iTunesHelper.exe"
AVG9_TRAY REG_SZ C:\PROGRA~1\AVG\AVG9\avgtray.exe
Adobe Reader Speed Launcher REG_SZ "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
Adobe ARM REG_SZ "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
sta REG_SZ rundll32 "oxigp.dll",,Run
MChk REG_SZ C:\WINDOWS\system32\bxigp.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\OptionalComponents
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices
Restrictions - Internet Explorer
Restrictions - REGEDIT
Restrictions - Explorer
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoDriveTypeAutoRun REG_DWORD 0x91
DNS Settings
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2C1186E1-1472-49EC-8B7E-5FB6E8BA60FA}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{7658A51B-EDFC-4EA2-B4DD-BD75A4DF6D45}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{802D7FB0-940A-4940-9867-747CAD8E393B}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{8D0F8D02-A47A-457F-9A5D-526E2C2506F6}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{8DE5F24C-9888-48C9-97BB-7BFB0FA1F8CE}
Windows IP Configuration
Host Name . . . . . . . . . . . . : jgaza-bdc3015d9
Node Type . . . . . . . . . . . . : Broadcast
DNS Suffix Search List. . . . . . : gateway.2wire.net
Connection-specific DNS Suffix . : gateway.2wire.net
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
Physical Address. . . . . . . . . : 00-19-B9-1F-8B-F2
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.64
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
Lease Obtained. . . . . . . . . . : Wednesday, July 28, 2010 1:15:53 PM
Lease Expires . . . . . . . . . . : Thursday, July 29, 2010 1:15:53 PM
AppInit DLLs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
AppInit_DLLs REG_SZ
Shell Service Object Delay Load
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
PostBootReminder REG_SZ {7849596a-48ea-486e-8937-a2a3009f31a9}
CDBurn REG_SZ {fbeb8a05-beee-4442-804e-409d6c4515e9}
WebCheck REG_SZ {E6FB5E20-DE35-11CF-9C87-00AA005127ED}
SysTray REG_SZ {35CEC8A3-2BE6-11D2-8773-92E220524153}
WPDShServiceObj REG_SZ {AAA288BA-9A4C-45B0-95D7-94D524869DB5}
Shell Execute Hooks
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks
{AEB6717E-7E19-11d0-97EE-00C04FD91972} REG_SZ
Image File Execution Options
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\apitrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Cleanup.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\cqw32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divx.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divxdec.ax
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DJSMAR00.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRMINST.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\enc98.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncodeDivXExt.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncryptPatchVer.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\front.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\fullsoft.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBROWSER.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmarq.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmm.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\install.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ishscan.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ISSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\javai.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm_g.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\main123w.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mngreg32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msci_uno.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscoree.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorsvr.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorwks.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msjava.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mso.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVOPTRF.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NeVideoFX.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPMLIC.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSWSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\photohse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PMSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ppw32hlp.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\printhse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\prwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ps80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\psdmt.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qfinder.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qpw.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\salwrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup32.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\sevinst.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\symlcnet.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\tcore_ebook.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFDTCTT8.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ua80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\udtapi.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ums.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vb40032.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vbe6.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\wpwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xlmlEN.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xwsetup.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Your Image File Name Here without a path
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\_INSTPGM.EXE
Security Providers
Local Security Authority
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa
Authentication Packages REG_MULTI_SZ msv1_0\0\0
Bounds REG_BINARY 0030000000200000
Security Packages REG_MULTI_SZ kerberos\0msv1_0\0schannel\0wdigest\0\0
ImpersonatePrivilegeUpgradeToolHasRun REG_DWORD 0x1
LsaPid REG_DWORD 0x2dc
SecureBoot REG_DWORD 0x1
auditbaseobjects REG_DWORD 0x0
crashonauditfail REG_DWORD 0x0
disabledomaincreds REG_DWORD 0x0
everyoneincludesanonymous REG_DWORD 0x0
fipsalgorithmpolicy REG_DWORD 0x0
forceguest REG_DWORD 0x1
fullprivilegeauditing REG_BINARY 00
limitblankpassworduse REG_DWORD 0x1
lmcompatibilitylevel REG_DWORD 0x0
nodefaultadminowner REG_DWORD 0x1
nolmhash REG_DWORD 0x0
restrictanonymous REG_DWORD 0x0
restrictanonymoussam REG_DWORD 0x1
Notification Packages REG_MULTI_SZ scecli\0\0
enabledcom REG_SZ y
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\AccessProviders
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Audit
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Data
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\GBG
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\JD
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Kerberos
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\MSV1_0
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Skew1
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SSO
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SspiCache
AppCert DLLs
App Paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\7zFM.exe
REG_SZ C:\Program Files\7-Zip\7zFM.exe
Path REG_SZ C:\Program Files\7-Zip
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\AcroRd32.exe
REG_SZ C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
Path REG_SZ C:\Program Files\Adobe\Reader 9.0\Reader\
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\AVGSE.DLL
REG_SZ C:\PROGRA~1\AVG\AVG9\avgse.dll
Menu1 REG_SZ Scan with &AVG Free
Help1 REG_SZ Scan against viruses with AVG Free
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\bckgzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\bckgzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\Camtray.exe
Path REG_SZ C:\Program Files\Creative\Shared Files
REG_SZ C:\Program Files\Creative\Shared Files\Camtray.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\chkrzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\chkrzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\chrome.exe
REG_SZ C:\Program Files\Google\Chrome\Application\chrome.exe
Path REG_SZ C:\Program Files\Google\Chrome\Application
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\cmmgr32.exe
REG_SZ C:\WINDOWS\system32\cmmgr32.exe
Path REG_SZ C:\WINDOWS\system32
CmstpExtensionDll REG_SZ C:\WINDOWS\system32\cmcfg32.dll
CMInternalVersion REG_SZ 1.2
CmNative REG_DWORD 0x1
ProfilesUpgraded REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\CONF.EXE
REG_SZ C:\Program Files\NetMeeting\conf.exe
Path REG_SZ C:\Program Files\NetMeeting;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\CTRegSvr.exe
REG_SZ C:\Program Files\Creative\Shared Files\CTRegSvr.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\dialer.exe
REG_SZ C:\Program Files\Windows NT\dialer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\excel.exe
REG_SZ C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE
Path REG_SZ C:\Program Files\Microsoft Office\Office12\
SaveURL REG_SZ 1
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\firefox.exe
REG_SZ C:\Program Files\Mozilla Firefox\firefox.exe
Path REG_SZ C:\Program Files\Mozilla Firefox
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\GET_YM.EXE
Path REG_SZ C:\Program Files\Creative\Get Yahoo! Messenger
REG_SZ C:\Program Files\Creative\Get Yahoo! Messenger\GET_YM.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\gimp-2.6.exe
REG_SZ C:\Program Files\GIMP-2.0\bin\gimp-2.6.exe
Path REG_SZ C:\Program Files\GIMP-2.0\bin
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\HELPCTR.EXE
REG_EXPAND_SZ %Systemroot%\PCHealth\HelpCtr\Binaries\HelpCtr.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hrtzzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\hrtzzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hypertrm.exe
REG_SZ "C:\Program Files\Windows NT\hypertrm.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN1.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN1.EXE"
Path REG_SZ C:\Program Files\Internet Explorer\Connection Wizard;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN2.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN2.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\IEXPLORE.EXE
REG_SZ C:\Program Files\Internet Explorer\IEXPLORE.EXE
Path REG_SZ C:\Program Files\Internet Explorer;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\INETWIZ.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\INETWIZ.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\install.exe
RunAsOnNonAdminInstall REG_DWORD 0x1
BlockOnTSNonInstallMode REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ISIGNUP.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ISIGNUP.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\iTunes.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\javaws.exe
REG_SZ C:\Program Files\Java\jre6\bin\javaws.exe
Path REG_SZ C:\Program Files\Java\jre6\bin
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mbam.exe
REG_SZ C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
Path REG_SZ C:\Program Files\Malwarebytes' Anti-Malware
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\migwiz.exe
REG_EXPAND_SZ %SystemRoot%\system32\usmt\migwiz.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\moviemk.exe
REG_SZ C:\Program Files\Movie Maker\moviemk.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mplayer2.exe
REG_SZ "C:\Program Files\Windows Media Player\mplayer2.exe"
Path REG_SZ "C:\Program Files\Windows Media Player"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSCONFIG.EXE
REG_EXPAND_SZ %systemroot%\pchealth\helpctr\Binaries\MSCONFIG.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msimn.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\msimn.exe
Path REG_EXPAND_SZ %ProgramFiles%\Outlook Express
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msinfo32.exe
REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo\MSInfo32.exe
Path REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSMSGS.EXE
REG_SZ C:\Program Files\Messenger\msmsgs.exe
Path REG_SZ C:\Program Files\Messenger;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MsoHtmEd.exe
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msoxmled.exe
REG_SZ C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLED.EXE
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ois.exe
REG_SZ C:\PROGRA~1\MICROS~3\Office12\OIS.EXE
SaveURL REG_SZ 0
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\OneNote.exe
REG_SZ C:\PROGRA~1\MICROS~3\Office12\ONENOTE.EXE
SaveURL REG_SZ 1
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pbrush.exe
REG_EXPAND_SZ %SystemRoot%\system32\mspaint.exe
Path REG_EXPAND_SZ %SystemRoot%\system32
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\PhotoScape.exe
REG_SZ "C:\Program Files\PhotoScape\PhotoScape.exe"
Path REG_SZ "C:\Program Files\PhotoScape\PhotoScape.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\PictureViewer.exe
Path REG_SZ C:\Program Files\QuickTime\
REG_SZ C:\Program Files\QuickTime\PictureViewer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pinball.exe
REG_SZ C:\Program Files\Windows NT\Pinball\pinball.exe
Path REG_SZ C:\Program Files\Windows NT\Pinball
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\powerpnt.exe
REG_SZ C:\PROGRA~1\MICROS~3\Office12\POWERPNT.EXE
useURL REG_SZ 1
SaveURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\QuickTimePlayer.exe
REG_SZ C:\Program Files\QuickTime\QuickTimePlayer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\rvsezm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\rvsezm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\setup.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\shvlzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\shvlzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\smax4pnp.exe
Path REG_SZ C:\Program Files\Analog Devices\Core
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\SMaxCore
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\smwdmif.dll
REG_SZ C:\Program Files\Analog Devices\Core\smwdmif.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\SoundMAX
Path REG_SZ C:\Program Files\Analog Devices\SoundMAX
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\table30.exe
UseShortName REG_SZ
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\USB
Path REG_SZ C:\WINDOWS\SYSTEM32\drivers\
REG_SZ C:\WINDOWS\SYSTEM32\drivers\USB
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\veohwebplayer.exe
REG_SZ "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wab.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wab.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wabmig.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wabmig.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WebCamCenter.exe
Path REG_SZ C:\Program Files\Creative\Creative WebCam Instant\WebCam Center
REG_SZ C:\Program Files\Creative\Creative WebCam Instant\WebCam Center\WebCamCenter.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\winnt32.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\Winword.exe
REG_SZ C:\PROGRA~1\MICROS~3\Office12\WINWORD.EXE
useURL REG_SZ 1
SaveURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wmplayer.exe
REG_SZ C:\Program Files\Windows Media Player\wmplayer.exe
Path REG_SZ C:\Program Files\Windows Media Player
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WORDPAD.EXE
REG_EXPAND_SZ "%ProgramFiles%\Windows NT\Accessories\WORDPAD.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WRITE.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\XPSViewer.exe
REG_SZ "c:\WINDOWS\system32\XPSViewer\XPSViewer.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\YourApp.exe
Path REG_SZ C:\Program Files\Linksys Wireless-G PCI Wireless Network Monitor
REG_SZ C:\Program Files\Linksys Wireless-G PCI Wireless Network Monitor\YourApp.exe
Mozilla
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox\Extensions
{3f963a5b-e555-4543-90e2-c3908898db71} REG_SZ C:\Program Files\AVG\AVG9\Firefox
avg@igeared REG_SZ C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared
[You must be registered and logged in to see this link.] REG_EXPAND_SZ C:\Program Files\Java\jre6\lib\deploy\jqs\ff
{20a82645-c095-46ed-80e3-08825760534b} REG_SZ c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox
REG_SZ 1.9.2.7
CurrentVersion REG_SZ 3.6.7 (en-US)
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox\3.6.7 (en-US)
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox\3.6.7 (en-US)\Main
Install Directory REG_SZ C:\Program Files\Mozilla Firefox
PathToExe REG_SZ C:\Program Files\Mozilla Firefox\firefox.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox\3.6.7 (en-US)\Uninstall
Description REG_SZ Mozilla Firefox (3.6.7)
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox 3.6.7
GeckoVer REG_SZ 1.9.2.7
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox 3.6.7\bin
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla Firefox 3.6.7\extensions
Components REG_SZ C:\Program Files\Mozilla Firefox\components
Plugins REG_SZ C:\Program Files\Mozilla Firefox\plugins
Shared Task Scheduler
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler
{438755C2-A8BA-11D1-B96B-00A0C90312E1} REG_SZ Browseui preloader
{8C7461EF-2B13-11d2-BE35-3078302C2030} REG_SZ Component Categories cache daemon
SafeBoot
SafeBootMinimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
SafeBootNetwork
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AFD
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Browser
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Dhcp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DnsCache
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ip6fw.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ipnat.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanServer
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanWorkstation
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LmHosts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Messenger
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS Wrapper
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Ndisuio
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOSGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBT
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetDDEGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetMan
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetworkProvider
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NtLmSsp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP_TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpcdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpwd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdsessmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SharedAccess
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Streams Drivers
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Tcpip
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdpipe.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdtcp.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\termservice
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WZCSVC
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E973-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E974-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E975-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
File Rename Operations - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\FileRenameOperations
Known DLLs - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDlls
advapi32 REG_SZ advapi32.dll
comdlg32 REG_SZ comdlg32.dll
DllDirectory REG_EXPAND_SZ %SystemRoot%\system32
gdi32 REG_SZ gdi32.dll
imagehlp REG_SZ imagehlp.dll
kernel32 REG_SZ kernel32.dll
lz32 REG_SZ lz32.dll
ole32 REG_SZ ole32.dll
oleaut32 REG_SZ oleaut32.dll
olecli32 REG_SZ olecli32.dll
olecnv32 REG_SZ olecnv32.dll
olesvr32 REG_SZ olesvr32.dll
olethk32 REG_SZ olethk32.dll
rpcrt4 REG_SZ rpcrt4.dll
shell32 REG_SZ shell32.dll
url REG_SZ url.dll
urlmon REG_SZ urlmon.dll
user32 REG_SZ user32.dll
version REG_SZ version.dll
wininet REG_SZ wininet.dll
wldap32 REG_SZ wldap32.dll
Downloaded program files (ActiveX)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{149E45D8-163E-4189-86FC-45022AB2B6C9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1E54D648-B804-468d-BC78-4AFFED8E262F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CC450D71-CC90-424C-8638-1F2DBAC87A54}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}
PATH: C:\windows\Downloaded Program Files
armhelper.ocx
stg_drm.ocx
sysreqlab.osd
sysreqlab_nvd.dll
Mountpoints
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\A
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\C
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\D
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\E
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\F
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\G
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\H
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{377a3be4-30e6-11de-9918-806d6172696f}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{377a3be5-30e6-11de-9918-806d6172696f}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{5f877f9e-3267-11dd-a55f-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ae18358c-682b-11dd-a507-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{c13b2b00-8356-11de-a5b4-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{c13b2b01-8356-11de-a5b4-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{c13b2b02-8356-11de-a5b4-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{c13b2b03-8356-11de-a5b4-0019b91f8bf2}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC
Winlogon
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
AutoRestartShell REG_DWORD 0x1
DefaultDomainName REG_SZ JGAZA-BDC3015D9
DefaultUserName REG_SZ admin
LegalNoticeCaption REG_SZ
LegalNoticeText REG_SZ
PowerdownAfterShutdown REG_SZ 0
ReportBootOk REG_SZ 1
Shell REG_SZ Explorer.exe
ShutdownWithoutLogon REG_SZ 0
System REG_SZ
Userinit REG_SZ C:\WINDOWS\system32\userinit.exe,
VmApplet REG_SZ rundll32 shell32,Control_RunDLL "sysdm.cpl"
SfcQuota REG_DWORD 0xffffffff
allocatecdroms REG_SZ 0
allocatedasd REG_SZ 0
allocatefloppies REG_SZ 0
cachedlogonscount REG_SZ 10
forceunlocklogon REG_DWORD 0x0
passwordexpirywarning REG_DWORD 0xe
scremoveoption REG_SZ 0
AllowMultipleTSSessions REG_DWORD 0x1
UIHost REG_EXPAND_SZ logonui.exe
LogonType REG_DWORD 0x1
Background REG_SZ 0 0 0
DebugServerCommand REG_SZ no
SFCDisable REG_DWORD 0x0
WinStationsDisabled REG_SZ 0
HibernationPreviouslyEnabled REG_DWORD 0x1
ShowLogonOptions REG_DWORD 0x0
AltDefaultUserName REG_SZ admin
AltDefaultDomainName REG_SZ JGAZA-BDC3015D9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SCLogon
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Credentials
Windows Update
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\windowsupdate\auto update\results\install
LastSuccessTime REG_SZ 2010-07-14 21:51:24
LastError REG_DWORD 0x0
Security Software Information
*Note*: Some security software does not store itself in the WMI.
{END OF FILE}
cutenik211
Posts Posts : 27
Joined Joined : 2009-08-22
Points Points : 26958
Re: Need Help to remove Antimalware Doctor
Post by Dr Jay on Thu Jul 29, 2010 4:33 am
Firefox is out of date. Firefox is a very popular web browser, and if it is out of date, it is very vulnerable to security bugs, and other holes. To update it now, click Help > Check for Updates.
ESET Online Scan
  • Click Start
  • Click Start
Posts Posts : 13717
Points Points : 302127
Post by cutenik211 on Sat Jul 31, 2010 10:04 pm
all ok
# version=7
# api_version=3.0.2
# EOSSerial=25da58727e6ebb42b15da5020dff6015
# end=finished
# remove_checked=true
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2010-07-31 09:54:08
# local_time=2010-07-31 04:54:08 (-0600, Central Daylight Time)
# country="United States"
# lang=1033
# osver=5.1.2600 NT Service Pack 2
# compatibility_mode=1024 16777215 100 0 9202855 9202855 0 0
# scanned=122855
# found=10
# cleaned=10
# scan_time=8051
C:\Documents and Settings\nikki\Application Data\Sun\Java\Deployment\cache\6.0\31\475ee9f-4f061400 multiple threats (deleted - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Application Data\Sun\Java\Deployment\cache\6.0\42\3c071b2a-54b6c946 multiple threats (deleted - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Application Data\Sun\Java\Deployment\cache\6.0\6\13b98886-414ec045 a variant of Java/TrojanDownloader.Agent.NAN trojan (deleted - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\92.tmp a variant of Win32/Olmarik.UL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\jar_cache3974793204991448007.tmp a variant of Java/TrojanDownloader.Agent.NBA trojan (deleted - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\jar_cache6146789445735889649.tmp a variant of Java/Exploit.Agent.NAC trojan (deleted - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\soenxrwcma.tmp a variant of Win32/Injector.BCP trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\xwcaonmres.tmp a variant of Win32/VB.PAM trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\Local Settings\temp\plugtmp-45\plugin-Notes2.pdf JS/Exploit.Pdfka.OAH trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\nikki\My Documents\Downloads\exeHelper.com probably a variant of Win32/Agent trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
cutenik211
Posts Posts : 27
Post by Dr Jay on Sun Aug 01, 2010 7:52 pm
Clear your Java Cache
  • Click on Start-> Control Panel (Classic View)-> Java (looks like a coffee cup)
    • On the General tab, under Temporary Internet Files, click the Settings button.
    • Next, click on the Delete Files button
    • There are two options in the window to clear the cache - Leave BOTH Checked
        Applications and Applets
        Trace and Log Files
    • Click OK on Delete Temporary Files Window
      Note: This deletes ALL the Downloaded Applications and Applets from the CACHE.
    • Click OK to leave the Temporary Files Window
    • Click OK to leave the Java Control Panel.
Clean Temporary Files
  • Click the Start
Run Kaspersky Online Scan
Please do a scan with [You must be registered and logged in to see this link.]
Click on the Accept button and install any components it needs.
  • The program will install and then begin downloading the latest definition files.
  • After the files have been downloaded on the left side of the page in the Scan section select My Computer.
  • This will start the program and scan your system.
  • The scan will take a while, so be patient and let it run.
  • Once the scan is complete, click on View scan report
  • Now, click on the Save Report as button.
  • Save the file to your desktop.
  • Copy and paste that information in your next post.
Note: If the scan freezes for more than 30 minutes, stop the scan, and report back to me.
Posts Posts : 13717
Post by cutenik211 on Mon Aug 09, 2010 9:50 pm
Sorry for the long reply but here is the result of the scan
KASPERSKY ONLINE SCANNER 7.0: scan report
Monday, August 9, 2010
Operating system: Microsoft Windows XP Professional Service Pack 2 (build 2600)
Kaspersky Online Scanner version: 7.0.26.13
Last database update: Monday, August 09, 2010 02:35:13
Records in database: 4131622
Scan settings
scan using the following database extended
Scan archives yes
Scan e-mail databases yes
Scan area My Computer
A:\
C:\
D:\
E:\
F:\
G:\
H:\
Scan statistics
Objects scanned 70696
Threats found 2
Infected objects found 4
Suspicious objects found 0
Scan duration 01:45:11
File name Threat Threats count
C:\Documents and Settings\All Users\Application Data\Update\seupd.exe Infected: Trojan.Win32.Clicker.hd 1
C:\Program Files\Mozilla Firefox\extensions\{1CE11043-9A15-4207-A565-0C94C42D590D}\chrome\content\plug.xul Infected: Trojan-Spy.JS.Agent.a 1
C:\Program Files\Mozilla Firefox\searchplugins\google_search.xml Infected: Trojan.Win32.Clicker.hd 1
C:\WINDOWS\temp\tkmr.exe Infected: Trojan.Win32.Clicker.hd 1
Selected area has been scanned.
cutenik211
Posts Posts : 27
Post by Dr Jay on Tue Aug 10, 2010 5:14 am
  • Save it to your desktop.
  • Please double-click OTM to run it. (Note for Vista: Right-click on the file and choose Run As Administrator).
  • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL C (or, after highlighting, right-click and choose Copy):
    :files
    :Commands
    [emptytemp]
    [purity]
    [Reboot]
  • Return to OTM, right click in the "Paste Instructions for Items to be Moved" window (under the yellow bar) and choose Paste.
  • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
  • Close OTM and reboot your PC.
Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes. In this case, after the reboot, open Notepad (Start->All Programs->Accessories->Notepad), click File->Open, in the File Name box enter *.log and press the Enter key, navigate to the C:\_OTMoveIt\MovedFiles folder, and
open the newest .log file present, and copy/paste the contents of that document back here in your next post.
Since this infection has killed your Google search plugin in Firefox, we will need to have you download a new one after OTM is run.
Visit Google.com in Firefox, and you will see a glow in your Search Box (top right of browser), drop that down, and click on Add Google Search.
Let me know how it goes.
Posts Posts : 13717
Post by cutenik211 on Tue Aug 10, 2010 7:33 pm
All processes killed
========== FILES ==========
Unable to create HKLM\Software\OldTimer Tools\OTM key.
File move failed. C:\WINDOWS\temp\tkmr.exe scheduled to be moved on reboot.
File move failed. C:\Program Files\Mozilla Firefox\searchplugins\google_search.xml scheduled to be moved on reboot.
File move failed. C:\Program Files\Mozilla Firefox\extensions\{1CE11043-9A15-4207-A565-0C94C42D590D}\chrome\content\plug.xul scheduled to be moved on reboot.
File move failed. C:\Documents and Settings\All Users\Application Data\Update\seupd.exe scheduled to be moved on reboot.
[EMPTYTEMP]
User: admin
User: Administrator
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 0 bytes
User: Guest
->Temp folder emptied: 107590420 bytes
->Temporary Internet Files folder emptied: 305746632 bytes
->Java cache emptied: 1009351 bytes
->FireFox cache emptied: 38818393 bytes
->Google Chrome cache emptied: 0 bytes
->Flash cache emptied: 1211 bytes
User: LocalService
User: NetworkService
User: nikki
->Apple Safari cache emptied: 0 bytes
%systemroot% .tmp files removed: 0 bytes
Windows Temp folder emptied: 1546341 bytes
RecycleBin emptied: 28484 bytes
Total Files Cleaned = 434.00 mb
OTM by OldTimer - Version 3.1.15.0 log created on 08102010_142544
cutenik211
Posts Posts : 27
Post by Dr Jay on Wed Aug 11, 2010 5:26 am
ESET Online Scan
  • Click Start
  • Click Start
Posts Posts : 13717
Post by cutenik211 on Wed Aug 11, 2010 4:21 pm
all ok
# version=7
# api_version=3.0.2
# end=finished
# lang=1033
# scanned=122855
# found=10
# cleaned=10
# scan_time=8051
# version=7
# IEXPLORE.EXE=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# end=finished
# archives_checked=false
# unsafe_checked=false
# utc_time=2010-08-11 03:58:16
# local_time=2010-08-11 10:58:16 (-0600, Central Daylight Time)
# lang=1033
# compatibility_mode=1024 16777215 100 0 10135816 10135816 0 0
# compatibility_mode=8192 67108863 100 0 846733 846733 0 0
# scanned=95988
# found=7
# cleaned=7
# scan_time=4141
C:\System Volume Information\_restore{4A0D1951-71BC-4D67-9DE1-F4CF525A2DED}\RP352\A0137845.dll Win32/Adware.Lifze.N application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{4A0D1951-71BC-4D67-9DE1-F4CF525A2DED}\RP354\A0137954.exe Win32/Adware.SpywareProtect2009 application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\sxlsex80.dll a variant of Win32/Cimag.DC trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\system32\kxigp.dll Win32/Adware.Lifze.N application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\system32\drivers\srenum.sys Win32/Rootkit.Agent.NTI trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\temp\gilnnw.exe Win32/Adware.SpywareProtect2009 application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\WINDOWS\temp\rmukuo.exe a variant of Win32/Cimag.DC trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
cutenik211
Posts Posts : 27
Post by Dr Jay on Wed Aug 11, 2010 7:46 pm
I'd like to see this a bit closer...
Please download RootRepeal from [You must be registered and logged in to see this link.].
  • Extract the program file to your Desktop.
  • Run the program RootRepeal.exe.
  • Click Settings > Options. Drag the slider to High Level. Then, click the Red X.
  • Go to the Report tab and click on the Scan button.
  • Select ALL of the checkboxes and then click OK and it will start scanning your system.
  • If you have multiple drives you only need to check the C: drive or the one Windows is installed on.
  • When done, click on Save Report
  • Save it to the Desktop.
  • Please copy/paste the contents of the report in your next reply.
Posts Posts : 13717
Post by cutenik211 on Wed Aug 11, 2010 10:02 pm
ROOTREPEAL (c) AD, 2007-2009
Scan Start Time: 2010/08/11 16:49
Program Version: Version 1.3.5.0
Windows Version: Windows XP SP2
Drivers
Image Path: C:\WINDOWS\system32\drivers\rootrepeal.sys
Address: 0xB7477000 Size: 49152 File Visible: No Signed: -
Status: -
Hidden/Locked Files
Path: C:\WINDOWS\system32\drivers\alfexj.sys
Status: Locked to the Windows API!
Stealth Objects
Object: Hidden Code [Driver: Ntfs, IRP_MJ_CREATE]
Process: System Address: 0x89c035e0 Size: 2593
Hidden Services
Service Name: alfexj
Image Path: C:\WINDOWS\system32\drivers\alfexj.sys
==EOF==
cutenik211
Posts Posts : 27
Post by Dr Jay on Fri Aug 13, 2010 6:53 am
I wonder what this is: C:\WINDOWS\system32\drivers\alfexj.sys
  • Please go to [You must be registered and logged in to see this link.]
  • Browse for the following file path into the "Suspicious files to scan" box on the top of the page:
    • C:\WINDOWS\system32\drivers\alfexj.sys
  • Click on the Upload button
  • If a pop-up appears saying the file has been scanned already, please select the ReScan button.
  • Once the Scan is completed, click on the "Copy to Clipboard" button. This will copy the link of the report into the Clipboard.
  • Paste the contents of the Clipboard in your next reply.
Posts Posts : 13717
Post by cutenik211 on Fri Aug 13, 2010 3:48 pm
It wont let me upload it. it says "ERROR: Can't Upload file!"
cutenik211
Posts Posts : 27
Post by Dr Jay on Sat Aug 14, 2010 5:20 am
Your computer gets reinfected, I noticed, which is why I had you run an online scan so much.
Note: the following tool is to only be used under the guidance of a malware helper. In the event you already have the tool, please delete the old copy and download a new copy.
[You must be registered and logged in to see this link.] (Click the green button on the page to download it).
Rename ComboFix.exe to combo-fix.exe before you save it to your Desktop
  • Click Start>Run then copy paste the following command into the Run box & click OK "%userprofile%\desktop\combo-fix.exe" /killall
  • As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed.
    *NOTE*: If you already have the Recovery Console installed, ComboFix will skip this part and will continue scanning for malware.
    With malware infections being as they are today, it's strongly recommended to have this pre-installed on your machine before doing any malware removal. It will allow you to boot up into a special recovery/repair mode that will allow us to more easily help you should your computer have a problem after an attempted removal of malware.
Posts Posts : 13717
Post by Dr Jay on Wed Aug 18, 2010 6:08 am
Still with us? Please let me know how things are going!
Posts Posts : 13717
