PC Wont Power On
PC Wont Power On
Post by Sir $wat on Mon Jul 26, 2010 12:18 pm
My pc is not coming on and i know the power supply is good since i tested it with the paper clip trick. Then I tot maybe the CMOS battery was dead, so i changed it and the pc came on (coincidence). Anyway, i tried puttin it on and it DID NOT COME On. So it wasnt the cmos battery that needed the change. what can it be?
OS : Windows XP Professional SP3
# Likes : 0
Re: PC Wont Power On
Post by karananand on Tue Aug 03, 2010 3:10 pm
Motherboard!
karananand
OS : XP
# Likes : 0
