antivir solution pro win32/Nuqel.E and
Post by jogismo on Mon 26 Jul 2010, 3:41 am
I have both of the viruses listed above on my laptop. I cant do anything with my computer without pop ups saying i have infected files pop up to the point where I can not execute and file . The only thing that seems to be unaffected is mozilla firefox. .I can not run any spyware or removal programs or access my control panel. I also have internet explorer popping up with ad sites.
thanks
jogismo
Rookie Surfer
Rookie Surfer
Operating System : windows xp
Re: antivir solution pro win32/Nuqel.E and
Post by Crush on Mon 26 Jul 2010, 4:00 am
Welcome to GeekPolice Forums! I'm Crush but, you can call me Chris too and I will be helping you with your Malware issues.
A few things to keep in mind as we progress:
1. We are all volunteer staff here so we log in and assess threads when real life, work, family, and other obligations permit. Additionally, we are located all over the world. There may be a bit of a time delay due to this.
2. Malware Removal threads are very time intensive. Each entry must be researched until it can be said with 100% certainty whether or not it can stay or needs to be removed. Sometimes additional work is needed to weed out suspect entries
3. This may turn into a long ordeal but, rest assured we will stay with you until you are completely disinfected.
4. Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer. Do not run any tools unless specifically asked to by a member of one of these usergroups
5. If you are not the original poster of this thread DO NOT run any fixes given to the poster in this thread. They are all custom tailored specifically to this user. It could prove to be disastrous.
6. Please keep responding until I give you the "All Clear". Absence of symptoms does not mean that everything is clear.
7. Your security programs may give warnings for some of the tools I will ask you to use. Be assured, any links I give are safe.
8. If you have any questions or issues please stop and ask! We are all here to help.
IMPORTANT: Please be aware that removing Malware is a potentially hazardous undertaking. I will take care not to knowingly suggest courses of action that might damage your computer. However it is impossible for me to foresee all interactions that may happen between the software on your computer and those we'll use to clear you of infection, and I cannot guarantee the safety of your system. It is possible that we might encounter situations where the only recourse is to re-format and re-install your operating system, or to necessitate you taking your computer to a repair shop.
Because of this, I advise you to backup any personal files and folders before you start.
If you follow these instructions, everything should go smoothly .
Please subscribe to this thread to get immediate notification of replies as soon as they are posted.
To do this click , then click Preferences. Make sure Always notify me of replies is set to Yes
With that out of the way:
Please download and run RKill.
Download mirror 1 - Download mirror 2 - Download mirror 3
  • It will quickly run and launch a log. If it does not launch a log, try another download link until it does.
  • Please post its log in your next reply.
  • After it has run successfully, delete RKill.
Note: This tool only kills the active infection, the actual infection will not be gone. Once you reboot the infection will be active again! Please do not reboot until instructed further to do so.
Download OTL to your Desktop
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    %SYSTEMDRIVE%\*.exe
    %systemroot%\*. /mp /s
    c:\$recycle.bin\*.* /s
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    nvstor32.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    explorer.exe
    svchost.exe
    userinit.exe
    qmgr.dll
    ws2_32.dll
    proquota.exe
    imm32.dll
    kernel32.dll
    ndis.sys
    autochk.exe
    spoolsv.exe
    xmlprov.dll
    ntmssvc.dll
    mswsock.dll
    Beep.SYS
    ntfs.sys
    termsrv.dll
    sfcfiles.dll
    st3shark.sys
    ahcix86.sys
    srsvc.dll
    nvrd32.sys
    /md5stop
  • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
Crush
Tech Officer
Tech Officer
Post by jogismo on Mon 26 Jul 2010, 4:20 am
Hi Chris
thanks for you time, I'm Joan
I can not download nothing with my computer because i don't have internet acces. virus don't allow to me start internet
what can I do?
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Mon 26 Jul 2010, 4:22 am
Hi Joan
Do you have access to another machine? Perhaps we can get the files needed on to your PC by downloading them from another machine and putting them on a USB stick or CD.
EDIT: You mentioned Mozilla is unaffected. Can you use that?
Crush
Tech Officer
Tech Officer
Post by jogismo on Mon 26 Jul 2010, 4:25 am
yes I already tried but in normal mode I can't run them, and neither in safe mode
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Mon 26 Jul 2010, 4:26 am
Try my instructions from Post 2 in Normal Mode. RKill will kill the active infection so it's like your computer is clean. But, the infection will only be prevented from running, not actually off your machine. The next time you reboot it will be back. That should let OTL run and we'll go from there
Crush
Tech Officer
Tech Officer
Post by jogismo on Mon 26 Jul 2010, 4:34 am
I can't open USB the the trojan block it
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Mon 26 Jul 2010, 4:38 am
Can't open in Normal or Safe mode? If safe mode, try Normal
Crush
Tech Officer
Tech Officer
Post by jogismo on Tue 27 Jul 2010, 1:51 am
Hi Chris, are you there?
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Tue 27 Jul 2010, 4:12 am
Did you see post 8?
Crush
Tech Officer
Tech Officer
Post by jogismo on Tue 27 Jul 2010, 4:31 am
yes, I tried in normal and in safe mode but it didn't work
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Tue 27 Jul 2010, 4:36 am
Do you have another browser? Chrome, Firefox, SeaMonkey, etc. Do they work there?
Crush
Tech Officer
Tech Officer
Post by jogismo on Tue 27 Jul 2010, 4:49 am
I have Chrome, it doesn't work, all its blocked by the virus
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Tue 27 Jul 2010, 5:05 am
We're slowly running out of options here. I'm going to have a conversation with a few colleagues about this and I will be back to you asap
Crush
Tech Officer
Tech Officer
Post by jogismo on Tue 27 Jul 2010, 5:12 am
OK, thak you very much
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Tue 27 Jul 2010, 5:15 am
  • Place a blank CD-R disc in to your CD burning drive.
  • Download OTLPEStd.exe and double-click on it to burn to a CD using ISO Burner.
Crush
Tech Officer
Tech Officer
Post by jogismo on Tue 27 Jul 2010, 5:52 am
Can we meet for tomorrow?I ve to give back the computer to my roomie.
I'll be connected from 15h00 (I live in Europe).
See you tomorrow
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Tue 27 Jul 2010, 5:55 am
Ok. I look forward to your reply.
Crush
Tech Officer
Tech Officer
Post by jogismo on Wed 28 Jul 2010, 12:18 am
Hi Chris,
It's very strange, this morning I tried to run 'rkill' and it works, here you are:
This log file is located at C:\rkill.log.
Please post this only if requested to by the person helping you.
Otherwise you can close this log when you wish.
Ran as Usuario on 27/07/2010 at 14:41:10.
Processes terminated by Rkill or while it was running:
C:\Documents and Settings\Usuario\Escritorio\rkill.exe
Rkill completed on 27/07/2010 at 14:41:27.
jogismo
Rookie Surfer
Rookie Surfer
Post by jogismo on Wed 28 Jul 2010, 12:41 am
Hi Chris,
I tried this morning and it works, here you are
jogismo
Rookie Surfer
Rookie Surfer
Post by jogismo on Wed 28 Jul 2010, 12:46 am
but I can't open OTL
jogismo
Rookie Surfer
Rookie Surfer
Post by Crush on Wed 28 Jul 2010, 4:09 am
Ok try RKill and then try this:
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Crush
Tech Officer
Tech Officer
Post by Sponsored content Today at 4:36 am
