Antivir Pro Solution
Post by seano on Sat Jul 24, 2010 3:51 am
Hey Guys,
I followed the step illustrated to remove antivir pro solution and have had no luck.
I downloaded hijack this but the virus shuts down the program as soon as it launches.
It does this for every program I try top start up, including task manager.
Is there a way around this Dammed program/virus?
Thanks guys,
Any help you can give me would be greatly appreciated Smile
seano
OS : windows vista
Re: Antivir Pro Solution
Post by Sneakyone on Sat Jul 24, 2010 6:57 am
Hi, Welcome to GeekPolice.net! Smile
Please download and run RKill.
[You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.]
  • It will quickly run and launch a log. If it does not launch a log, try another download link until it does.
  • Please post its log in your next reply.
  • After it has run successfully, delete RKill.
Note: This tool only kills the active infection, the actual infection will not be gone. Once you reboot the infection will be active again! Please do not reboot until instructed further to do so.
Please download [You must be registered and logged in to see this link.] to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
OS : Windows 7 Ultimate 64-bit
