Infected with Antivir Solution Pro
Post by icetrash on 21st July 2010, 3:23 pm
Hey guys!
Would like to firstly say thanks for looking at my post and (hopefully) having the time to reply. Really appreciate it!
I have recieved the 'Antivir Solution Pro' trojan/virus. I could not access any program; Internet, Windows Defender, CCleaner... ANYTHING! So I went on my mothers laptop and found many sites that recommended entering safe mode with network capabilities. I have, and am currently on the infected laptop typing this post.
Many sites suggest downloading Spyware Doctor, but as I do not own a credit card and my mother does not trust entering details online, I have had to resort to doing it manually! (Unless there are free programs about I don't know about?)
I tried to follow this sites way of manually removing it (http://www.411-spyware.com/remove-antivir-solution-pro) but just got waaay to scared when it came to deleting the registry bits. I deleted the 'files' section, and am quite comfortable I deleted the right one. The only other thing I deleted was the 'HKEY_CURRENT_USER\Software\avSofT' in the registry folder, but it was named like 'AVSolutions' instead of 'avSofT'. Once again I am quite comfortable. But then I am having troubles deciding what are all the others, so this is as far as I went and the only files I deleted.
I am currently running a Windows Defender full system scan over night, so I shall see how that goes.
I have tried to help you by downloading the 'OTL' but it says access denied?
EDIT: Am currently running Vista Business
~~Icetrash
icetrash
Joined Joined : 2010-07-21
OS OS : PC
Points Points : 23328
Re: Infected with Antivir Solution Pro
Post by Sneakyone on 21st July 2010, 6:43 pm
Hi, Welcome to GeekPolice.net! Smile
Geekstogo is down due to a URL injection attack that is why you are unable to download OTL.
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56094
Post by icetrash on 22nd July 2010, 2:50 am
ComboFix seemed to cause more trouble. I couldn't get it to work it kept popping up with a message that it is not a Win32 application. Then it said 'Access Denied'
Anyway, Windows Defender deleted the virus (or so it said...) I am currently in Normal Mode typing on the infected computer. But there still are some symptoms:
- When on startup comes up with a messge ' "Run DLL" Error loading C:\Users\User\AppData\Local\kerct8.dll'. This has never come up before
- Overall slowness to the computer
~~Icetrash
icetrash
OS OS : PC
Post by Sneakyone on 22nd July 2010, 3:59 am
Hi, Smile
That thing on startup is malware, probably what windows defender deleted and now it is missing so it notifies you on startup.
After you have done this, please try to run ComboFix again.
Sneakyone
Posts Posts : 2707
