antivir soulution pro problem
Post by csigmon on Sat 17 Jul 2010, 8:15 am
I got infected with it, and i saw the other section you had showed to remove it but the one i have is not letting me run any exe. files so everytime i try to open any sort of program to get rid of it like the Hackthis it just brings up a screen saying It is infected and wont open exe. files. Thanks in advance for any help
csigmon
Unborn
Unborn
Operating System : Windows XP
Re: antivir soulution pro problem
Post by DragonMaster Jay on Sun 18 Jul 2010, 2:07 pm
Hello, and welcome to GeekPolice.
Please note the following information about the malware forum:
  • Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
  • From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by the staff I noted above.
  • Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
  • If you have already asked for help somewhere, please post the link to the topic you were helped.
  • We try our best to reply quickly, but for any reason we do not reply in two days, do one of two things:
    Reply to this topic with the word BUMP, or
    see [You must be registered and logged in to see this link.].
  • Lastly, keep in mind that we are volunteers, so you do not have to pay for malware removal. Persist in this topic until its close, and your computer is declared clean.
Please download Malwarebytes Anti-Malware from Malwarebytes.org.
Alternate link: BleepingComputer.com.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. If you are prompted to restart, please allow it to restart your computer. Failure to do this, will cause the infection to still be active on the computer.
  • The log can also be found at C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
~DMJ
GeekPolice Academy Manager
Donations/Contributions
DragonMaster Jay
Manager | Tech Officer
View user profile http://www.twitter.com/jaypfoutz
