Anti-virus soft removal HELP HELP HELP HELP HELP HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by vascanj on Tue 13 Jul 2010, 6:16 am
So, a few days ago, I was on an application that I downloaded, called PalTalk Scene. It is a chatroom application, similar to skype, except that ads appear in the chatrooms. 2 days ago, I used it, and a rouge ad made AV Antivirus soft install on my computer. It just popped out of nowhere. I followed your instructions, but it's not letting me go into safe mode with networking, so I put the installations and the programs onto a CD and tried to transfer it to the infected computer while it is in safe mode. But it's NOT LETTING ME INSTALL. WHAT DO I DO? I NEED TO GET THIS VIRUS OFF BECAUSE THAT WINDOWS COMPUTER HAS MY MOST IMPORTANT FILES ON IT. HELP!!!
vascanj
Unborn
Unborn
Operating System : windows xp home personal
Re: Anti-virus soft removal HELP HELP HELP HELP HELP HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by Sneakyone on Tue 13 Jul 2010, 6:23 am
Hi, Welcome to GeekPolice.net!
Please download and run RKill.
Download mirror 1 - Download mirror 2 - Download mirror 3
  • It will quickly run and launch a log. If it does not launch a log, try another download link until it does.
  • Please post its log in your next reply.
  • After it has run successfully, delete RKill.
Note: This tool only kills the active infection, the actual infection will not be gone. Once you reboot the infection will be active again! Please do not reboot until instructed further to do so.
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
Post by vascanj on Tue 13 Jul 2010, 6:46 am
How would i do it though? I can't connect to the internet on that computer because it's not letting me in on Safe Mode with networking, only just regular safe mode. So, It's not working. I'm currently in regular safe mode as we speak, typing this from the clean MAC, and running my old version of norton anti-virus... It's not letting picking up anything infected as of now, what do I do?
vascanj
Unborn
Unborn
Post by Sneakyone on Tue 13 Jul 2010, 10:12 am
Could you please transfer them over to the infected machine using a USB drive?
Sneakyone
Tech Officer
Tech Officer
Post by vascanj on Wed 14 Jul 2010, 4:04 am
That's just it though. I TRIED that. But the program needs to be updated in order to work, and in order to update, we need internet. So what now?
vascanj
Unborn
Unborn
Post by Sneakyone on Wed 14 Jul 2010, 8:14 am
What do you mean by "The program needs to be updated"? OTL or Rkill shouldn't need to be updated or connected to the internet to use.
Sneakyone
Tech Officer
Tech Officer
Post by Sponsored content Today at 9:39 am
