Please help with banker.a
Page 1 of 2 1, 2  Next
Post by mdev30@aol.com on Sun 11 Jul 2010, 3:38 pm
Hi Im new here & Im on computer alot but am not advanced in it. I got this (I guess) virus and couldnt do anything so I restarted and went to fix computer and went to restore point and that worked kinda Im not having pop-ups and can get on internet but I was worried so downloaded malwarebytes which is scanning now and already has found 163 objects infected Can someone walk me through what to do in laymens terms Please and thank you
mdev30@aol.com
Operating System : vista
Re: Please help with banker.a
Post by Sneakyone on Sun 11 Jul 2010, 3:44 pm
Hi, welcome to GeekPolice.net!
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Sun 11 Jul 2010, 3:46 pm
malware is still scanning is it ok to do otl now?
mdev30@aol.com
Post by Sneakyone on Sun 11 Jul 2010, 3:49 pm
Yes, could you also please post the Malwarebytes log along with the OTL logs.
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Sun 11 Jul 2010, 3:51 pm
Ok be back soon as finished ;)
mdev30@aol.com
Post by mdev30@aol.com on Sun 11 Jul 2010, 5:12 pm
Still scanning, didn't think it would take this long started almost 2 hrs ago I got to goto sleep will post logs in the morning. Hope you'll be around ;)
mdev30@aol.com
Post by Sneakyone on Sun 11 Jul 2010, 5:16 pm
Alright, I await your logs.
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Mon 12 Jul 2010, 12:52 am
Holey moley Batman 900 something problems!
So I hit view and save log do I remove selected? and click log tab?
mdev30@aol.com
Post by mdev30@aol.com on Mon 12 Jul 2010, 4:28 am
Otl kept not responding. so i looked at other post and yall said to remove so heres the log:
Database version: 4301
Windows 6.0.6000
Internet Explorer 8.0.6001.18904
7/11/2010 1:17:43 PM
mbam-log-2010-07-11 (13-17-43).txt
Scan type: Full scan (C:\|D:\|)
Objects scanned: 410578
Time elapsed: 3 hour(s), 46 minute(s), 32 second(s)
Memory Modules Infected: 1
Registry Keys Infected: 167
Registry Values Infected: 4
Registry Data Items Infected: 4
Folders Infected: 42
Files Infected: 716
C:\ProgramData\BPK\toolsbpkwb.dll (Spyware.Logger) -> Delete on reboot.
HKEY_CLASSES_ROOT\bestshoppingtipsprogram.bestshoppingtipsprogram (Adware.PlayMP3z) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\bestshoppingtipsprogram.bestshoppingtipsprogram.1 (Adware.PlayMP3z) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c8cecde3-1ae1-4c4a-ad82-6d5b00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{17de5e5e-bfe3-4e83-8e1f-8755795359ec} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1f52a5fa-a705-4415-b975-88503b291728} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a626cdbd-3d13-4f78-b819-440a28d7e8fc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8ca01f0e-987c-49c3-b852-2f1ac4a7094c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1093995a-ba37-41d2-836e-091067c4ad17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{120927bf-1700-43bc-810f-fab92549b390} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{247a115f-06c2-4fb3-967d-2d62d3cf4f0a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e53e2cb-86db-4a4a-8bd9-ffeb7a64df82} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{90449521-d834-4703-bb4e-d3aa44042ff8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{991aac62-b100-47ce-8b75-253965244f69} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{bbabdc90-f3d5-4801-863a-ee6ae529862d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{d6ff3684-ad3b-48eb-bbb4-b9e6c5a355c1} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{eb9e5c1c-b1f9-4c2b-be8a-27d6446fdaf8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0f8ecf4f-3646-4c3a-8881-8e138ffcaf70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b813095c-81c0-4e40-aa14-67520372b987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9d7be3e-141a-4c85-8cd6-32461f3df2c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{cff4ce82-3aa2-451f-9b77-7165605fb835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e47caee0-deea-464a-9326-3f2801535a4d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e1656ed-f60e-4597-b6aa-b6a58e171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8e6f1830-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2b-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{8e6f1832-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a9571378-68a1-443d-b082-284f960c6d17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproductsinstaller.start (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproductsinstaller.start.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e79dfbc0-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{72ee7f04-15bd-4845-a005-d6711144d86a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbc9-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbcb-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{3e720450-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720451-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720453-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{adb01e81-3c79-4272-a0f1-7b2be7a782dc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{7473d290-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d291-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d293-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d295-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d297-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d292-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d296-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{07b18ea0-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eaa-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eac-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{53ced2d0-5e9a-4761-9005-648404e6f7e5} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\ss.ss (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{1d1b286c-99ff-11e3-8d96-d7acac95952a} (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1d1b2878-99ff-11e3-8d96-d7acac95952a} (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1d1b2879-99ff-11e3-8d96-d7acac95952a} (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d1b2879-99ff-11e3-8d96-d7acac95952a} (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{1d1b2879-99ff-11e3-8d96-d7acac95952a} (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\ss.ss.1 (Spyware.Logger) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1d4db7d1-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1d4db7d3-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6e74766c-4d93-4cc0-96d1-47b8e07ff9ca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{de38c398-b328-4f4c-a3ad-1b5e4ed93477} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{6802e635-cb18-f544-790d-700bac51e508} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{418d86be-7386-4f1a-83e0-53604adbda74} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{84da4fdf-a1cf-4195-8688-3e961f505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a4730ebe-43a6-443e-9776-36915d323ad3} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{4e3a97d3-9f15-4067-d0f9-241cc9cc9541} (Adware.PlayMP3z) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{1d4db7d0-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{f42228fb-e84e-479e-b922-fbbd096e792c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{4e3a97d3-9f15-4067-d0f9-241cc9cc9541} (Adware.PlayMP3z) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{4e3a97d3-9f15-4067-d0f9-241cc9cc9541} (Adware.PlayMP3z) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\AppDataLow\HavingFunOnline (Adware.BHO.FL) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\ErrorRepairTool (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\ErrorSmart (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MediaHoldings (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\PlayMP3 (Adware.PLayMP3z) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\ErrorRepairTool (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyWebSearch bar Uninstall (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PlayMP3 (Adware.PLayMP3z) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MyWebSearchService (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{394d8891-7c6d-4b92-97f2-a3fc20fc844e} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{394d8891-7c6d-4b92-97f2-a3fc20fc844e} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs\C:\Windows\System32\Memman.vxd (Rogue.sysCleaner) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\MenuExt\&Search\(default) (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform\funwebproducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\scrfile\shell\open\command\(default) (Broken.OpenCommand) -> Bad: (NOTEPAD.EXE %1) Good: ("%1" /S) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\regfile\shell\open\command\(default) (Broken.OpenCommand) -> Bad: (NOTEPAD.EXE %1) Good: (regedit.exe "%1") -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\Search Bar (Hijack.SearchPage) -> Bad: (http://www.mirarsearch.com/?useie5=1&q=) Good: (http://www.google.com) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Start Page (Hijack.StartPage) -> Bad: (http://bing.zugo.com/?cfg=2-78-0-LNh3) Good: (http://www.google.com) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-22 13-56-190 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-03-10 12-54-090 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-09-07 12-17-040 (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Registry Backups (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Program Files\BestShoppingTipsProgram (Adware.PlayMP3z) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Installr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Installr\3.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Installr\setups (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver\Images (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\HighQualityAds (Adware.PlayMP3z) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\extensions\{9CE11043-9A15-4207-A565-0C94C42D590D} (Worm.Prolaco.M) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\extensions\{9CE11043-9A15-4207-A565-0C94C42D590D}\chrome (Worm.Prolaco.M) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\extensions\{9CE11043-9A15-4207-A565-0C94C42D590D}\chrome\content (Worm.Prolaco.M) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\PlayMP3z (Adware.PLayMP3z) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PlayMP3z (Adware.PLayMP3z) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Installr\3.bin\F3EZSETP.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3MSG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\ProgramData\BPK\toolsbpkwb.dll (Spyware.Logger) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\plugins\NPMyWebS.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3IMSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3HIGHIN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IMPIPE.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3MEDINT.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SRCHMN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSSVC.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\NPMYWEBS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\Internet Explorer\msimg32.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\PlayMP3z\PlayMP3.exe (Adware.BHO) -> Quarantined and deleted successfully.
C:\ProgramData\BPK\toolsbpk.exe (Malware.Packer.T) -> Quarantined and deleted successfully.
C:\ProgramData\BPK\toolsbpkvw.exe (Malware.Packer.T) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\3H64BLQX\n008105304801r0409J11000601R3cbf3af8We7150cb1Xd88cd13aY94b47eacZ07f026190[1] (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\Shell\Documents\Smooth\Nero_6.6.0.8 Keygen\Keygen.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Users\Shell\Downloads\setup.exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Windows\System32\f3PSSavr.scr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\resultsw.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-21 12-21-570.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-21 14-32-150.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-22 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-22 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-23 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-23 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-24 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-24 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-24 12-00-002.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-24 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-25 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-02-25 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-04 12-03-040.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-05 06-56-530.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-05 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-05 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-06 06-53-430.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-08 06-30-090.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-08 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-08 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-10 10-12-110.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-10 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-10 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-10 13-18-270.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-11 12-20-120.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-11 13-02-520.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-12 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-12 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-16 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-16 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-17 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-17 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-21 03-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-21 03-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-22 03-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-03-22 03-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-14 03-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-14 03-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-14 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-14 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-20 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-20 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-23 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-23 12-00-011.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-26 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-05-26 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-03 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-03 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-04 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-04 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-06 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-06 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-07 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-07 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-08 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-08 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-11 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-11 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-12 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-12 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-17 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-17 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-19 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-19 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-21 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-21 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-23 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-23 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-24 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-24 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-26 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-26 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-29 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-29 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-30 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-06-30 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-03 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-03 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-14 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-14 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-16 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-16 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-19 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-19 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-27 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-27 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-28 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-07-28 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-11 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-11 12-00-011.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-19 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-19 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-20 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-20 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-22 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-08-22 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-05 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-05 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-07 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-07 12-00-010.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-08 12-00-000.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\Logs\2009-09-08 12-00-001.log (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-100.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-101.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-102.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-103.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-104.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-105.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-106.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-107.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-108.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-109.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-110.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-111.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-112.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-113.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-114.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-115.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-116.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-117.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-118.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-119.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-120.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-121.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-122.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-123.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-124.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-125.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-126.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-127.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-128.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-129.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-130.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-131.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-132.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-133.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-134.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-135.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-136.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-137.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-138.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-139.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-140.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
mdev30@aol.com
Post by mdev30@aol.com on Mon 12 Jul 2010, 4:29 am
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-141.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-142.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-143.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-144.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-145.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-146.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-147.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-148.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-149.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-150.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-151.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-152.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-153.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-154.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-155.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-156.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-157.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-158.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-159.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-16.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-160.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-161.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-162.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-163.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-164.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-165.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-166.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-167.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-168.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-169.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-17.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-170.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-171.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-172.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-173.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-174.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-175.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-176.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-177.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-178.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-179.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-18.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-180.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-181.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-182.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-183.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-184.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-185.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-186.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-187.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-188.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-189.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-19.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-190.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-191.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-192.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-193.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-194.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-195.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-196.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully. -
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-197.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-198.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-199.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-20.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-200.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-201.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-202.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-203.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-204.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-205.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-206.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-207.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-208.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-209.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-21.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-210.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-211.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-212.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-213.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-214.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-215.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-216.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-217.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-218.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-219.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-22.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-220.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-221.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-222.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-223.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-224.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-225.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-226.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-227.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-228.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-229.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-23.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-230.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-231.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-232.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-233.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-234.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-235.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-236.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-237.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-238.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-239.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-24.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-240.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-241.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-242.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
mdev30@aol.com
Operating System : vista
Re: Please help with banker.a
Post by mdev30@aol.com on Mon 12 Jul 2010, 4:30 am
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-243.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-244.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-245.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-246.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-247.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-248.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-249.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-25.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-250.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-251.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-252.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-253.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-254.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-255.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-256.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-257.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-258.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-259.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-26.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-260.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-261.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-262.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-263.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-264.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-265.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-266.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-267.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-268.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-269.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-27.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-270.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-271.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-272.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-273.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-274.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-275.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-28.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-29.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-30.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-31.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-32.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-33.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-34.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-35.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-36.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-37.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-38.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-39.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-40.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-41.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-42.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-43.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-44.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-45.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-46.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-47.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-48.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-49.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-50.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-51.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-52.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-53.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-54.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-55.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-56.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-57.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-58.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-59.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-60.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-61.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-62.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-63.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-64.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-65.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-66.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-67.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-68.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-69.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-70.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-71.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-72.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-73.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-74.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-75.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-76.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-77.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-78.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-79.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-80.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-81.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-82.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-83.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-84.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-85.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-86.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-87.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-88.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-89.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-90.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-91.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-92.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-93.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-94.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-95.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-96.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-97.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-98.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-21 12-25-360\regb-99.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-22 13-56-190\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-22 13-56-190\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-02-24 12-03-490\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-03-10 12-54-090\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-03-10 12-54-090\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-03-10 12-54-090\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-03-10 12-54-090\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-16.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-17.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-18.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
mdev30@aol.com
Post by mdev30@aol.com on Mon 12 Jul 2010, 4:31 am
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-19.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-20.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-21.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-22.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-23.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-24.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-25.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-26.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-27.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-28.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-29.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-30.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-31.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-15 21-41-110\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-16.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-17.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-18.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-19.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-05-20 12-28-580\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-16.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-17.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-18.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-19.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-20.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-21.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-22.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-23.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-24.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-25.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-26.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-27.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-28.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-29.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-30.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-07-27 12-59-390\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-10.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-100.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-101.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-102.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-103.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-104.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-11.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-12.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-13.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-14.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-15.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-16.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-17.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-18.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-19.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-20.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-21.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-22.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-23.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-24.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-25.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-26.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-27.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-28.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-29.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-30.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-31.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-32.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-33.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-34.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-35.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-36.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-37.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-38.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-39.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-40.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-41.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-42.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-43.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-44.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-45.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-46.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-47.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-48.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-49.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-50.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-51.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-52.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-53.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-54.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-55.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-56.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-57.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-58.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-59.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-6.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-60.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-61.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-62.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-63.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-64.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-65.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-66.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-67.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-68.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-69.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-7.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-70.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-71.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-72.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-73.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-74.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-75.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-76.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-77.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-78.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-79.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-8.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-80.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-81.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-82.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-83.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-84.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-85.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-86.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-87.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-88.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-89.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-9.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-90.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-91.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-92.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-93.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-94.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-95.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-96.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-97.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-98.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-20 17-28-310\regb-99.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-0.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-1.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-2.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-3.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-4.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-08-22 13-05-100\regb-5.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorRepairTool\QuarantineW\2009-09-07 12-17-040\filelist.db (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2008 Dec 21 - 03_30_02 AM_158.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Apr 23 - 03_30_04 AM_664.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Apr 25 - 03_30_00 AM_886.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Apr 28 - 03_30_00 AM_466.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Apr 30 - 03_30_00 AM_415.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Aug 20 - 03_30_01 AM_337.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Aug 22 - 03_30_01 AM_499.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Feb 13 - 03_30_02 AM_042.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Feb 15 - 03_30_00 AM_971.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jan 14 - 03_30_01 AM_535.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 01 - 03_30_00 AM_615.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 04 - 03_30_00 AM_939.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 15 - 03_30_00 AM_819.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 19 - 03_30_00 AM_471.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 21 - 03_30_00 AM_767.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jul 29 - 03_30_00 AM_577.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jun 13 - 03_30_01 AM_207.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jun 22 - 03_30_00 AM_938.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jun 25 - 03_30_00 AM_482.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Jun 29 - 03_30_00 AM_580.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Mar 16 - 03_30_00 AM_458.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Mar 20 - 03_30_00 AM_362.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Mar 21 - 03_30_00 AM_895.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 May 14 - 03_30_00 AM_304.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 May 19 - 03_30_00 AM_856.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 May 30 - 03_30_00 AM_604.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Sep 03 - 03_30_00 AM_514.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Sep 05 - 03_30_01 AM_089.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Log\2009 Sep 07 - 03_30_00 AM_807.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\ErrorSmart\Registry Backups\2008-11-25_09-08-39.reg (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Program Files\BestShoppingTipsProgram\uninstall.exe (Adware.PlayMP3z) -> Quarantined and deleted successfully.
C:\Program Files\HighQualityAds\uninstall.exe (Adware.PlayMP3z) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\extensions\{9CE11043-9A15-4207-A565-0C94C42D590D}\install.rdf (Worm.Prolaco.M) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\extensions\{9CE11043-9A15-4207-A565-0C94C42D590D}\chrome\content\timer.xul (Worm.Prolaco.M) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3BKGERR.JPG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SPACER.WMV (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WALLPP.DAT (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\FWPBUDDY.PNG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3FFXTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3FFXTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3NTSTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3NTSTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\files.ini (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHECKERS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHESS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\REVERSI.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\DOG.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\FISH.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\KUNGFU.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\LIFEGARD.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAID.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAILBOX.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\OPERA.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\ROBOT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SEDUCT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SURFER.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\PlayMP3z\uninstall.exe (Adware.PLayMP3z) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PlayMP3z\Run PlayMP3z.pif (Adware.PLayMP3z) -> Quarantined and deleted successfully.
C:\Users\Shell\AppData\Roaming\cglogs.dat (Malware.Trace) -> Quarantined and deleted successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AntiVirus\Uninstall.lnk (Rogue.AntiVirus) -> Quarantined and deleted successfully.
C:\Windows\Tasks\ErrorRepairTool Scan.job (Rogue.ErrorRepairTool) -> Quarantined and deleted successfully.
C:\Windows\Tasks\ErrorSmart Scheduled Scan.job (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
mdev30@aol.com
Operating System : vista
Re: Please help with banker.a
Post by Sneakyone on Mon 12 Jul 2010, 4:40 am
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Alternate link: Forospyware.com
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Mon 12 Jul 2010, 5:04 am
I use avg which do disable Resident Shield,
E-mail Scanner,AVG LinkScanner
mdev30@aol.com
Post by mdev30@aol.com on Mon 12 Jul 2010, 5:18 am
well just did all be back after combo fix
mdev30@aol.com
Post by Sneakyone on Mon 12 Jul 2010, 5:29 am
Alright, I await your logs.
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Mon 12 Jul 2010, 6:14 am
ComboFix 10-07-11.01 - Shell 07/11/2010 14:24:39.1.2 - x86
Microsoft® Windows Vista™ Home Premium 6.0.6000.0.1252.1.1033.18.3006.1980 [GMT -4:00]
Running from: c:\users\Shell\Downloads\ComboFix.exe
c:\program files\Antivirus
c:\program files\Cheat Engine\dbk32.sys
c:\program files\iWin Games\iWinGamesHookIE.dll
c:\programdata\SysWoW32
c:\programdata\SysWoW32\mu1800360260v4
c:\programdata\SysWoW32\mu1800360260v4.kwd
c:\programdata\SysWoW32\mu1800360260v5
c:\programdata\SysWoW32\mu1800360260v5.kwd
c:\programdata\SysWoW32\mu1800360260v6
c:\programdata\SysWoW32\mu1800360260v6.kwd
c:\programdata\SysWoW32\mu1800360260v7
c:\programdata\SysWoW32\mu1800360260v7.kwd
c:\programdata\SysWoW32\wu1800360260v0
c:\programdata\SysWoW32\wu1800360260v0.kwd
c:\programdata\SysWoW32\wu1800360260v1.kwd
c:\programdata\SysWoW32\wu1800360260v2.kwd
c:\programdata\SysWoW32\wu1800360260v3.kwd
c:\users\Shell\AppData\Roaming\Microsoft\dtPaper
c:\users\Shell\AppData\Roaming\Microsoft\dtPaper\1.html
c:\users\Shell\AppData\Roaming\Microsoft\dtPaper\cfg.msg
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\ANTIGEN.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\ANTIGEN.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cb.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cb.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cid.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cid.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cid.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\cid.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\CLSV.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\DBOLE.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\DBOLE.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\DBOLE.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\ddv.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\ddv.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\dudl.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\eb.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\eb.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\eb.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\energy.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\exec.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\exec.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\fan.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\fan.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\fix.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\FS.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\FS.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\FS.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\FW.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\FW.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\gid.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\gid.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\grid.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\hymt.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\hymt.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\hymt.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\kernel32.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\kernel32.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\kernel32.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\pal.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\pal.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\PE.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\ppal.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\runddl.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\runddl.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\runddlkey.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\runddlkey.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\runddlkey.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\SICKBOY.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\SICKBOY.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\SICKBOY.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\sld.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\SM.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\snl2w.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\snl2w.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\std.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\tempdoc.drv
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\tempdoc.exe
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\tempdoc.sys
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\the Cyberlink LabelPrint Program.url
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\tjd.dll
c:\users\Shell\AppData\Roaming\Microsoft\Windows\Recent\tjd.drv
c:\users\Shell\AppData\Roaming\SQLite3.dll
c:\users\Shell\Documents\SYS
c:\windows\system32\Ijl11.dll
c:\windows\system32\KBL.LOG
c:\windows\system32\skinboxer43.dll
((((((((((((((((((((((((( Files Created from 2010-06-11 to 2010-07-11 )))))))))))))))))))))))))))))))
2010-07-11 18:40 . 2010-07-11 18:40 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-07-11 04:23 . 2010-07-11 04:23 -------- d-----w- c:\users\Shell\AppData\Roaming\Malwarebytes
2010-07-11 04:22 . 2010-04-29 19:39 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-07-11 04:22 . 2010-07-11 04:22 -------- d-----w- c:\programdata\Malwarebytes
2010-07-11 04:22 . 2010-07-11 13:42 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-07-11 04:22 . 2010-04-29 19:39 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-07-04 18:44 . 2009-09-04 21:29 453456 ----a-w- c:\windows\system32\d3dx10_42.dll
2010-07-04 18:43 . 2008-05-30 18:11 3850760 ----a-w- c:\windows\system32\D3DX9_38.dll
2010-07-04 18:32 . 2010-07-04 18:41 -------- d--h--w- c:\windows\msdownld.tmp
2010-06-30 15:09 . 2010-06-30 15:09 -------- d-----w- c:\users\Shell\AppData\Roaming\GameInvest
2010-06-24 00:18 . 2010-06-24 17:20 -------- d-----w- c:\program files\Starcraft
2010-06-23 23:19 . 2010-06-23 23:19 -------- d-----w- c:\users\Shell\AppData\Local\PunkBuster
2010-06-23 21:29 . 2010-06-27 18:04 22328 ----a-w- c:\windows\system32\drivers\PnkBstrK.sys
2010-06-23 21:29 . 2010-06-23 21:29 22328 ----a-w- c:\users\Shell\AppData\Roaming\PnkBstrK.sys
2010-06-23 21:29 . 2010-06-27 18:03 103736 ----a-w- c:\windows\system32\PnkBstrB.exe
2010-06-23 21:29 . 2010-06-23 23:19 66872 ----a-w- c:\windows\system32\PnkBstrA.exe
2010-06-23 20:41 . 2010-06-23 20:41 -------- d-----w- c:\program files\Activision
2010-06-19 04:18 . 2010-06-19 04:18 -------- d-----w- c:\program files\FarmVilleBot
2010-06-14 19:06 . 2010-06-14 19:11 -------- d-----w- c:\programdata\NOS
2010-06-14 19:06 . 2010-06-14 19:06 -------- d-----w- c:\program files\NOS
2010-07-11 18:38 . 2010-01-15 19:38 -------- d-----w- c:\program files\iWin Games
2010-07-11 18:38 . 2010-03-30 19:15 -------- d-----w- c:\program files\Cheat Engine
2010-07-11 17:58 . 2010-01-21 22:03 31871 ----a-w- c:\programdata\nvModes.dat
2010-07-11 17:17 . 2009-02-19 15:15 -------- d--h--w- c:\programdata\BPK
2010-07-11 09:58 . 2009-02-19 20:43 518 ----a-w- c:\users\Shell\AppData\Roaming\iolo\Registry\Last\restore.bat
2010-07-11 07:46 . 2008-03-18 01:00 -------- d-----w- c:\program files\LimeWire
2010-07-11 07:46 . 2008-03-18 01:01 -------- d-----w- c:\users\Shell\AppData\Roaming\LimeWire
2010-07-08 00:06 . 2008-10-17 12:45 -------- d-----w- c:\programdata\iolo
2010-07-06 19:16 . 2010-02-18 18:40 94384 ----a-w- c:\windows\system32\IncContxMenu.dll
2010-07-06 19:16 . 2008-10-22 14:39 2319536 ----a-w- c:\windows\system32\Incinerator.dll
2010-07-04 21:45 . 2008-10-22 16:45 1228 ----a-w- c:\users\Shell\AppData\Roaming\iolo\restore.bat
2010-07-04 00:18 . 2010-01-07 19:20 -------- d-----w- c:\users\Shell\AppData\Roaming\DVD Flick
2010-07-02 00:24 . 2008-02-24 06:24 -------- d-----w- c:\program files\Google
2010-06-25 20:29 . 2009-08-13 00:43 -------- d-----w- c:\programdata\PlayFirst
2010-06-25 20:29 . 2008-02-06 02:08 -------- d-----w- c:\users\Shell\AppData\Roaming\PlayFirst
2010-06-23 21:28 . 2007-11-02 07:23 -------- d--h--w- c:\program files\InstallShield Installation Information
2010-06-20 17:16 . 2010-04-20 03:50 -------- d-----w- c:\program files\Free Ride Games
2010-06-20 17:16 . 2010-04-20 03:51 64 ----a-w- c:\windows\GPlrLanc.dat
2010-06-20 17:16 . 2010-04-20 03:51 -------- d-----w- c:\programdata\Free Ride Games
2010-06-17 06:01 . 2005-12-06 22:04 -------- d-sh--r- c:\users\Shell\AppData\Roaming\Windir
2010-06-10 19:33 . 2007-11-02 09:16 -------- d-----w- c:\programdata\Microsoft Help
2010-06-08 22:55 . 2010-06-08 22:54 -------- d-----w- c:\program files\MzVistaForce
2010-06-05 16:16 . 2010-04-29 02:23 -------- d-----w- c:\program files\Farm Helper
2010-06-05 09:00 . 2009-09-10 02:31 242896 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2010-06-05 09:00 . 2009-09-10 02:30 29584 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2010-06-05 08:35 . 2010-01-02 23:06 -------- d-----w- c:\users\Shell\AppData\Roaming\FrostWire
2010-06-04 12:16 . 2010-01-21 21:55 -------- d-----w- c:\program files\Microsoft Silverlight
2010-06-02 08:55 . 2010-07-04 18:45 74072 ----a-w- c:\windows\system32\XAPOFX1_5.dll
2010-06-02 08:55 . 2010-07-04 18:45 527192 ----a-w- c:\windows\system32\XAudio2_7.dll
2010-06-02 08:55 . 2010-07-04 18:45 239960 ----a-w- c:\windows\system32\xactengine3_7.dll
2010-05-26 15:41 . 2010-07-04 18:45 2106216 ----a-w- c:\windows\system32\D3DCompiler_43.dll
2010-05-26 15:41 . 2010-07-04 18:45 248672 ----a-w- c:\windows\system32\d3dx11_43.dll
2010-05-26 15:41 . 2010-07-04 18:45 1868128 ----a-w- c:\windows\system32\d3dcsx_43.dll
2010-05-26 15:41 . 2010-07-04 18:45 470880 ----a-w- c:\windows\system32\d3dx10_43.dll
2010-05-26 15:41 . 2010-07-04 18:45 1998168 ----a-w- c:\windows\system32\D3DX9_43.dll
2010-05-22 14:44 . 2009-09-10 02:30 216200 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2010-05-22 14:43 . 2009-09-10 02:31 12464 ----a-w- c:\windows\system32\avgrsstx.dll
2010-05-22 14:36 . 2010-05-22 14:35 -------- d-----w- c:\programdata\avg9
2010-05-22 14:36 . 2009-09-10 02:28 -------- d-----w- c:\program files\AVG
2010-05-22 06:35 . 2010-05-22 06:35 -------- d-----w- c:\users\Shell\AppData\Roaming\Sammsoft
2010-05-22 06:32 . 2010-05-22 06:32 -------- d-----w- c:\program files\MemTurbo 4
2010-05-22 06:31 . 2010-05-22 06:30 -------- d-----w- c:\program files\Advanced Registry Optimizer
2010-05-21 18:14 . 2009-10-08 20:35 221568 ------w- c:\windows\system32\MpSigStub.exe
2010-05-20 03:36 . 2010-03-21 00:07 -------- d-----w- c:\program files\Zynga
2010-05-19 23:46 . 2008-10-25 19:47 -------- d-----w- c:\program files\AOL 9.0a
2010-05-17 00:21 . 2010-04-20 03:51 53314 ------w- c:\windows\ExentInfo.exe
2010-05-14 17:28 . 2010-05-08 19:48 -------- d-----w- c:\programdata\Meridian93
2010-05-14 17:27 . 2010-05-14 17:27 -------- d-----w- c:\users\Shell\AppData\Roaming\Meridian93
2010-05-13 22:55 . 2010-04-24 15:48 -------- d-----w- c:\users\Shell\AppData\Roaming\vlc
2010-05-12 21:21 . 2010-05-12 21:21 -------- d-----w- c:\programdata\MumboJumbo
2010-04-29 09:47 . 2010-04-29 09:47 499712 ----a-w- c:\windows\system32\msvcp71.dll
2010-04-27 02:46 . 2010-04-27 02:46 10134 ----a-r- c:\users\Shell\AppData\Roaming\Microsoft\Installer\{CAE7D1D9-3794-4169-B4DD-964ADBC534EE}\ARPPRODUCTICON.exe
2010-04-24 23:11 . 2010-04-24 23:11 690952 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{7b13ec3e-999a-4b70-b9cb-2617b8323822}"= "c:\program files\Zynga\tbZyn0.dll" [2010-02-22 2353176]
[HKEY_CLASSES_ROOT\clsid\{7b13ec3e-999a-4b70-b9cb-2617b8323822}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{DD1849EA-8403-4441-8DFF-7575AAE1DC16}]
2008-01-28 18:06 641464 ----a-w- c:\program files\BearShare Applications\Personalization\BearSharePersonalizationIE_v1040.dll
"ehTray.exe"="c:\windows\ehome\ehTray.exe" [2006-11-02 125440]
"Exetender"="c:\program files\Free Ride Games\GPlayer.exe" [2010-05-17 1773568]
"Google Update"="c:\users\Shell\AppData\Local\Google\Update\GoogleUpdate.exe" [2010-05-05 136176]
"AROReminder"="c:\program files\Advanced Registry Optimizer\ARO.exe" [2009-12-28 2137600]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2006-11-02 201728]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2009-06-24 13601312]
"Apoint"="c:\program files\Apoint2K\Apoint.exe" [2007-07-09 159744]
"QlbCtrl"="c:\program files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe" [2007-09-19 202032]
"OnScreenDisplay"="c:\program files\Hewlett-Packard\HP QuickTouch\HPKBDAPP.exe" [2007-09-04 554320]
"UCam_Menu"="c:\program files\CyberLink\YouCam\MUITransfer\MUIStartMenu.exe" [2007-08-17 218408]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2007-11-02 1006264]
"hpqSRMon"="c:\program files\HP\Digital Imaging\bin\hpqSRMon.exe" [2008-06-02 80896]
"hpWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe" [2007-09-13 480560]
"WAWifiMessage"="c:\program files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe" [2007-01-08 311296]
"WPCUMI"="c:\windows\system32\WpcUmi.exe" [2006-11-02 176128]
"iolo Startup"="c:\program files\iolo\Common\Lib\ioloLManager.exe" [2010-07-06 378048]
"AVG9_TRAY"="c:\progra~1\AVG\AVG9\avgtray.exe" [2010-06-05 2065248]
"Malwarebytes Anti-Malware (reboot)"="c:\program files\Malwarebytes' Anti-Malware\mbam.exe" [2010-04-29 1090952]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
"NoSecCPL"= 0 (0x0)
"NoDevMgrPage"= 0 (0x0)
"NoConfigPage"= 0 (0x0)
"NoVirtMemPage"= 0 (0x0)
"NoFileSysPage"= 0 (0x0)
"NoNetSetup"= 0 (0x0)
"NoNetSetupIDPage"= 0 (0x0)
"NoNetSetupSecurityPage"= 0 (0x0)
"NoWorkgroupContents"= 0 (0x0)
"NoEntireNetwork"= 0 (0x0)
"NoFileSharingControl"= 0 (0x0)
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"NoFileSharing"= 1 (0x1)
"AppInit_DLLs"=c:\windows\System32\avgrsstx.dll
@="Driver"
R0 TfFsMon;TfFsMon; [x]
R0 TfSysMon;TfSysMon; [x]
R2 CSHelper;CopySafe Helper Service;c:\windows\system32\CSHelper.exe [2010-01-27 266240]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-06-18 136176]
R3 CASMSI;SMSI Con App Svc;c:\program files\US Cellular\QuickLink Mobile\ConAppsSvc.exe [2009-03-14 124184]
R3 I97DRIVER;I97DRIVER; [x]
R3 PTDUBus;PANTECH UM175 Composite Device Driver ;c:\windows\system32\DRIVERS\PTDUBus.sys [2008-03-11 29824]
R3 PTDUMdm;PANTECH UM175 Drivers ;c:\windows\system32\DRIVERS\PTDUMdm.sys [2008-03-11 41344]
R3 PTDUVsp;PANTECH UM175 Diagnostic Port ;c:\windows\system32\DRIVERS\PTDUVsp.sys [2008-03-11 39936]
R3 PTDUWWAN;PANTECH UM175 WWAN Driver;c:\windows\system32\DRIVERS\PTDUWWAN.sys [2008-03-11 59776]
R3 SMSIRcAppSvc;SMSI Rc App Svc;c:\program files\US Cellular\QuickLink Mobile\RcAppSvc.exe [2009-03-14 111896]
S1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\Drivers\avgldx86.sys [2010-05-22 216200]
S1 AvgTdiX;AVG Free Network Redirector;c:\windows\system32\Drivers\avgtdix.sys [2010-06-05 242896]
S1 ElRawDisk;ElRawDisk;c:\windows\system32\drivers\elrawdsk.sys [2009-09-08 20392]
S2 avg9emc;AVG Free E-mail Scanner;c:\program files\AVG\AVG9\avgemc.exe [2010-05-22 916760]
S2 avg9wd;AVG Free WatchDog;c:\program files\AVG\AVG9\avgwdsvc.exe [2010-05-22 308064]
S2 ioloFileInfoList;iolo FileInfoList Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [2010-04-21 704432]
S2 ioloSystemService;iolo System Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [2010-04-21 704432]
S2 iWinTrusted;iWinTrusted;c:\program files\iWin Games\iWinTrusted.exe [2010-01-21 78104]
S2 lxcy_device;lxcy_device;c:\windows\system32\lxcycoms.exe [2007-06-20 537264]
S2 X4HSEx;X4HSEx;c:\program files\Free Ride Games\X4HSEx.Sys [2010-03-11 56352]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2007-08-24 01:34 451872 ----a-w- c:\program files\Common Files\LightScribe\LSRunOnce.exe
2010-07-11 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-07-02 02:12]
2010-07-11 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-07-08 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3675819506-889393583-3195363467-1000Core.job
- c:\users\Shell\AppData\Local\Google\Update\GoogleUpdate.exe [2010-05-05 01:04]
2010-07-11 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3675819506-889393583-3195363467-1000UA.job
2010-07-11 c:\windows\Tasks\User_Feed_Synchronization-{8FDA2530-A347-4AC9-93F0-B23C8D4E160D}.job
- c:\windows\system32\msfeedssync.exe [2010-03-31 04:54]
mWindow Title = Microsoft Internet Explorer
IE: Customize Menu - [You must be registered and logged in to see this link.] files\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html
IE: Fill Forms - [You must be registered and logged in to see this link.] files\Siber Systems\AI RoboForm\RoboFormComFillForms.html
IE: RoboForm Toolbar - [You must be registered and logged in to see this link.] files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html
IE: Save Forms - [You must be registered and logged in to see this link.] files\Siber Systems\AI RoboForm\RoboFormComSavePass.html
DPF: {F7EDBBEA-1AD2-4EBF-AA07-D453CC29EE65} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\users\Shell\AppData\Roaming\Mozilla\Firefox\Profiles\yxpjku5k.default\
FF - prefs.js: browser.search.selectedEngine - Bing
FF - component: c:\program files\AVG\AVG9\Firefox\components\avgssff.dll
FF - component: c:\users\Shell\AppData\Roaming\Mozilla\Firefox\Profiles\yxpjku5k.default\extensions\firefox@kidzui.com\platform\WINNT_x86-msvc\components\WinKiosk.dll
FF - plugin: c:\program files\Free Ride Games\npExentCtl.dll
FF - plugin: c:\program files\Google\Google Earth\plugin\npgeplugin.dll
FF - plugin: c:\program files\Google\Update\1.2.183.29\npGoogleOneClick8.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npArtistScope42.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npArtistScopeDRM11.dll
FF - plugin: c:\users\Shell\AppData\Local\Google\Update\1.2.183.29\npGoogleOneClick8.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.lu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nz", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--p1ai", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbayh7gpa", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.tel", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.proxy.type", 5);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("dom.ipc.plugins.timeoutSecs", 45);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("accelerometer.enabled", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.nptest.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npswf32.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npctrl.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npqtplugin.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
------- File Associations -------
JSEFile=NOTEPAD.EXE %1
Toolbar-{394D8890-7C6D-4B92-97F2-A3FC20FC844E} - (no file)
Toolbar-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
WebBrowser-{D0523BB4-21E7-11DD-9AB7-415B56D89593} - (no file)
WebBrowser-{394D8890-7C6D-4B92-97F2-A3FC20FC844E} - (no file)
WebBrowser-{CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
AddRemove-WT039045 - c:\program files\HP Games\G.H.O.S.T. Hunters
Rootkit scan 2010-07-11 14:47
Windows 6.0.6000 NTFS
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0003\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0004\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0005\AllUserSettings]
Completion time: 2010-07-11 14:54:17
ComboFix-quarantined-files.txt 2010-07-11 18:54
Pre-Run: 77,156,286,464 bytes free
Post-Run: 77,309,841,408 bytes free
- - End Of File - - F850E43846C1E22421A664A9825AC810
mdev30@aol.com
Post by Sneakyone on Mon 12 Jul 2010, 6:41 am
Please run a free online scan with the ESET Online Scanner
  • Click Start
  • Click Start
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Mon 12 Jul 2010, 2:56 pm
It finished do I uninstall app on close? do I delete quarantine?
mdev30@aol.com
Post by Sneakyone on Mon 12 Jul 2010, 3:08 pm
Yes please do that, and post the log here.
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Mon 12 Jul 2010, 3:34 pm
ok I did that and waited like 15 mins for something to pop up So I did asearch for C:\Program Files\EsetOnlineScanner\log.txt and it says path does not exsist ???
mdev30@aol.com
Post by Sneakyone on Mon 12 Jul 2010, 7:26 pm
Sorry for the delay, I had some things I needed to get done.
Your computer is now clean. Now, time to remove the tools used, and update your computer to prevent vulnerability.
Updating System Restore
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE.
You now have a clean restore point.
To get rid of the bad ones:
  • Click OK
  • The System will do a calculation of temporary/old files, and then display a dialogue box.
  • At the bottom will be a System Restore box with a CLEANUP button click this
  • Accept the Warning and select OK again, the program will close and you are done.
Removing the tools
Now, to remove all of the tools we used and the files and folders they created, please do the following:
Download OTC.exe by OldTimer:
  • Double click OTC.exe.
  • Click the CleanUp! button.
Service Pack upgrade
Please consider upgrading to Windows XP SP3, because it includes all previously released updates. It also includes a small number of new functionalities. Some of the updates that Service Pack 3 provides, you may not have. It is now available via Windows Update.
More info about SP3: [You must be registered and logged in to see this link.]
Update Programs
Please download the newest version of Adobe Acrobat Reader from Adobe.com
Please download the newest version of Java from Java.com.
Search in the list for all previous installed versions of Java (J2SE Runtime Environment). Please uninstall/remove each of them.
If you don't have a AntiSpyware I recommend to download these free programs to help keep you spyware free:
1. SpywareBlaster
2. Spybot - Search & Destroy
If you don't have a Antivirus I recommend to download these free Antivirus programs:
1. Microsoft Security Essentials
2. AVG Free
3. Avast!
If you don't have a good Firewall I recommend these free firewalls:
1. Tallemu Online Armor
2. Comodo Firewall
I recommend using MalwareBytes Anti-Malware for a antimalware program.
Please don't download more than one Antivirus, firewall, or antispyware because they will conflict with each other making your computer slow, data loss, and false results so just don't do it.
Here are some prevention tips I have provided:
1. Don't download files from untrusted websites or websites that seem suspious.
2. Don't use torrents they are a good way to get lots of malware.
3. Don't download and use cracks/warez/keygens they are illegal and are another good way to contract malware.
4. Disable autorun XP or Vista/7
5. Always make sure you have the latest Windows updates. windowsupdate.microsoft.com
6. Don't ever click on the links inside of a popup.
7. Make sure you know what you install you can make sure it is not know for being a virus by just simply searching about it on google.
8. Use a Site Advisor so you don't go to sites that will infect you. Mcafee Siteadvisor
9. Also there are many holes and flaws in Internet Explorer I recommend using Firefox 3 to keep you more safe.
10. Always keep your Java and Adobe updated.
11. Don't fall for the Scareware. What is Scareware? it is a website made to download a rogue Antivirus on your system that will scare you into buying their fake software due to false detections.
12. Always have a Firewall and a Antivirus.
Thanks for choosing GeekPolice, see [You must be registered and logged in to see this link.] if you would like to leave feedback or contribute to our site. Do you have any more questions?
For more information please visit [You must be registered and logged in to see this link.]
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Tue 13 Jul 2010, 12:32 am
Thanks so much for the help but how do you know its clean if you didnt get the log???
mdev30@aol.com
Post by Sneakyone on Tue 13 Jul 2010, 4:00 am
Because ESET will automatically remove what it finds, that is the important part.
You're welcome, glad I could help.
Sneakyone
Tech Officer
Tech Officer
Post by mdev30@aol.com on Tue 13 Jul 2010, 4:34 am
Ok Im just parinoid lol Thanks a bunch Biggg Huggggs! Do you play FarmVille by any chance?
mdev30@aol.com
Post by Sponsored content Today at 12:59 pm
Page 1 of 2 1, 2  Next
