Problem deleting desktop icons!
Post by mjomisko on 10th July 2010, 7:16 pm
How do you remove a program when you try to delete a desktop icon and it says it will only remove the icon; to remove the program you have to use Add/Remove in Control Panel. Then I go to the list in Add/Remove and I don't see the program there? Would deleting it in Explorer be good enough? Thanks!
mjomisko
Posts Posts : 53
Joined Joined : 2010-07-09
OS OS : vista
Points Points : 24081
Re: Problem deleting desktop icons!
Post by Gabethebabe on 14th July 2010, 2:07 pm
What program are you trying to uninstall?
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38268
Post by mjomisko on 25th July 2010, 1:08 pm
Since it's been a while I can't remember which one. Can you close out this question and I'll repost the next time I'm stuck? Thanks!
mjomisko
Posts Posts : 53
OS OS : vista
Post by mjomisko on 8th August 2010, 5:28 pm
I just tried to delete uTorrent but it said I had to remove it through Control Panel. When I open up "Programs & Features", uTorrent is not listed.
mjomisko
Posts Posts : 53
OS OS : vista
Post by Buttons on 9th August 2010, 12:10 am
Hi mjomisko,
uTorrent is usually listed at the top rather then alphabetical. You can easily delete folder and not have to worry about uninstalling. Just an executable that add's shortcuts and a folder. Nothing more.Wink
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26336
