Running two Operating Systems with one PC?
Post by stinkfist on 10th July 2010, 6:32 am
I am getting ready to use a SSD drive as my main drive. I have a SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb as my main drive right now. Should I just keep the W7 OS that is on there now and use it as a backup or should I wipe the drive clean and use it for store only? Is there a certain program to run two OS with one PC? Also if I leave the W7 on the Samsung drive will I be able to move files from my new SSD drive to the Samsung? The SSD drive will have W7 also.
stinkfist
Posts Posts : 16
Joined Joined : 2010-03-15
Points Points : 24691
Re: Running two Operating Systems with one PC?
Post by Doctor Inferno on 10th July 2010, 12:48 pm
What OS are you planning to run Win 7 with?
This is known as dual booting. You run Win 7 on your SSD if its your main OS. And another OS on another partition or hard drive.
See here on how to dual boot:
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
http://apcmag.com/the_definitive_dualbooting_guide_linux_vista_and_xp_stepbystep.htm
http://lifehacker.com/5126781/how-to-dual-boot-windows-7-with-xp-or-vista
Points Points : 104630
Post by stinkfist on 10th July 2010, 7:38 pm
@Doctor Inferno wrote:Hello,
They both will be W7. Do I still need to do this dual booting installation if both hard drives have W7? Also will I be able to moving file from hard drive to hard drive normally if the both have W7 OS on them?
stinkfist
Posts Posts : 16
Post by Doctor Inferno on 11th July 2010, 2:16 am
Yes, it is still dual booting. You need two partitions to install Windows 7 on. You can move files like moving from one folder to the other, but not system files though.
