i need help with deleting 13 viruses and 2 trojans
Post by marc_army26 on Thu Jul 01, 2010 4:40 am
im having a hard time deleting or fixing viruses on my computer kaspersky located? can you help?
marc_army26
OS : window7
# Likes : 0
Re: i need help with deleting 13 viruses and 2 trojans
Post by Crush on Thu Jul 01, 2010 4:45 am
Hi marc,
Welcome to GeekPolice Forums! I'm Crush but, you can call me Chris too Smile and I will be helping you with your Malware issues.
A few things to keep in mind as we progress:
1. We are all volunteer staff here so we log in and assess threads when real life, work, family, and other obligations permit. Additionally, we are located all over the world. There may be a bit of a time delay due to this.
2. Malware Removal threads are very time intensive. Each entry must be researched until it can be said with 100% certainty whether or not it can stay or needs to be removed. Sometimes additional work is needed to weed out suspect entries
3. This may turn into a long ordeal but, rest assured we will stay with you until you are completely disinfected.
4. Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer. Do not run any tools unless specifically asked to by a member of one of these usergroups
5. If you are not the original poster of this thread DO NOT run any fixes given to the poster in this thread. They are all custom tailored specifically to this user. It could prove to be disastrous.
6. Please keep responding until I give you the "All Clear". Absence of symptoms does not mean that everything is clear.
7. Your security programs may give warnings for some of the tools I will ask you to use. Be assured, any links I give are safe.
8. If you have any questions or issues please stop and ask! We are all here to help.
IMPORTANT: Please be aware that removing Malware is a potentially hazardous undertaking. I will take care not to knowingly suggest courses of action that might damage your computer. However it is impossible for me to foresee all interactions that may happen between the software on your computer and those we'll use to clear you of infection, and I cannot guarantee the safety of your system. It is possible that we might encounter situations where the only recourse is to re-format and re-install your operating system, or to necessitate you taking your computer to a repair shop.
Because of this, I advise you to backup any personal files and folders before you start.
If you follow these instructions, everything should go smoothly Smile.
Please subscribe to this thread to get immediate notification of replies as soon as they are posted.
To do this click , then click Preferences. Make sure Always notify me of replies is set to Yes
With that out of the way:
Download [You must be registered and logged in to see this link.] to your Desktop
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    %SYSTEMDRIVE%\*.exe
    %systemroot%\*. /mp /s
    c:\$recycle.bin\*.* /s
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    nvstor32.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    explorer.exe
    svchost.exe
    userinit.exe
    qmgr.dll
    ws2_32.dll
    proquota.exe
    imm32.dll
    kernel32.dll
    ndis.sys
    autochk.exe
    spoolsv.exe
    xmlprov.dll
    ntmssvc.dll
    mswsock.dll
    Beep.SYS
    ntfs.sys
    termsrv.dll
    sfcfiles.dll
    st3shark.sys
    ahcix86.sys
    srsvc.dll
    nvrd32.sys
    /md5stop
  • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
Crush
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 5:05 am
it keeps telling me cant download through temporary files must download to desktop but dont know how?
marc_army26
OS : window7
# Likes : 0
Post by Crush on Thu Jul 01, 2010 5:07 am
hi marc,
When you download it choose Save as opposed to Run and you will be asked where to save it to. Choose your Desktop
Crush
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 10:14 pm
OTL logfile created on: 7/1/2010 5:03:33 PM - Run 1
OTL by OldTimer - Version 3.2.7.0 Folder = C:\Users\marc\Downloads
64bit- Home Premium Edition (Version = 6.1.7600) - Type = NTWorkstation
Internet Explorer (Version = 8.0.7600.16385)
4.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 65.00% Memory free
7.00 Gb Paging File | 6.00 Gb Available in Paging File | 81.00% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 453.94 Gb Total Space | 413.19 Gb Free Space | 91.02% Space Free | Partition Type: NTFS
Computer Name: MARC_ARMY26-PC
Current User Name: marc
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Include 64bit Scans
Company Name Whitelist: On
Skip Microsoft Files: On
File Age = 90 Days
Output = Standard
Quick Scan
PRC - [2010/07/01 17:02:25 | 000,574,464 | ---- | M] (OldTimer Tools) -- C:\Users\marc\Downloads\OTL.exe
PRC - [2010/07/01 17:00:56 | 000,095,232 | ---- | M] () -- c:\Program Files (x86)\Adobe\Acrobat_com\Acrobat_com.exe
PRC - [2010/06/30 13:00:27 | 001,352,832 | ---- | M] (Lavasoft) -- C:\Program Files (x86)\Lavasoft\Ad-Aware\AAWService.exe
PRC - [2010/06/27 18:01:12 | 000,014,808 | ---- | M] (Mozilla Corporation) -- C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe
PRC - [2010/06/27 18:01:11 | 000,910,296 | ---- | M] (Mozilla Corporation) -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe
PRC - [2010/06/24 22:49:38 | 000,864,112 | ---- | M] (Lavasoft) -- C:\Program Files (x86)\Lavasoft\Ad-Aware\AAWTray.exe
PRC - [2009/11/20 18:34:08 | 000,200,704 | ---- | M] () -- C:\Windows\PLFSetI.exe
PRC - [2009/11/09 19:20:08 | 001,519,743 | ---- | M] (Suyin) -- C:\Program Files (x86)\VideoWebCamera\VideoWebCamera.exe
PRC - [2009/11/01 18:39:48 | 001,094,736 | ---- | M] (Dritek System Inc.) -- C:\Program Files (x86)\Launch Manager\LManager.exe
PRC - [2009/10/29 15:22:18 | 000,039,408 | ---- | M] (Google Inc.) -- C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2009/10/29 15:19:30 | 000,117,640 | ---- | M] (Symantec Corporation) -- C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\ccSvcHst.exe
PRC - [2009/10/20 22:39:28 | 000,340,456 | ---- | M] (Kaspersky Lab) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\avp.exe
PRC - [2009/09/24 18:42:34 | 000,244,480 | ---- | M] (NewTech Infosystems, Inc.) -- C:\Program Files (x86)\NewTech Infosystems\Gateway MyBackup\BackupManagerTray.exe
PRC - [2009/09/24 18:42:28 | 000,062,720 | ---- | M] (NewTech Infosystems, Inc.) -- C:\Program Files (x86)\NewTech Infosystems\Gateway MyBackup\IScheduleSvc.exe
PRC - [2009/08/28 04:38:58 | 001,150,496 | ---- | M] (Acer Incorporated) -- C:\Program Files (x86)\Gateway\Registration\GregHSRW.exe
PRC - [2009/08/03 11:05:48 | 000,498,160 | ---- | M] () -- C:\Program Files (x86)\Roxio\Roxio Burn\RoxioBurnLauncher.exe
PRC - [2009/07/03 20:47:12 | 000,240,160 | ---- | M] (Acer) -- C:\Program Files\Gateway\Gateway Updater\UpdaterService.exe
PRC - [2009/04/16 02:52:06 | 000,091,432 | ---- | M] (CyberLink Corp.) -- C:\Program Files (x86)\CyberLink\PowerDVD8\PDVD8Serv.exe
PRC - [2009/02/27 19:10:32 | 000,349,544 | ---- | M] (Adobe Systems Incorporated) -- c:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe
PRC - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) -- C:\Program Files (x86)\Yahoo!\SoftwareUpdate\YahooAUService.exe
MOD - [2010/07/01 17:02:25 | 000,574,464 | ---- | M] (OldTimer Tools) -- C:\Users\marc\Downloads\OTL.exe
MOD - [2009/07/13 20:14:10 | 000,095,232 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysWOW64\msscript.ocx
MOD - [2009/07/13 20:03:50 | 001,680,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_none_421189da2b7fabfc\comctl32.dll
SRV:64bit: - [2009/09/30 17:44:58 | 000,844,320 | ---- | M] (Acer Incorporated) [Auto | Running] -- C:\Program Files\Gateway\Gateway Power Management\ePowerSvc.exe -- (ePowerSvc)
SRV:64bit: - [2009/07/30 02:03:42 | 000,203,264 | ---- | M] (AMD) [Auto | Running] -- C:\Windows\SysNative\atiesrxx.exe -- (AMD External Events Utility)
SRV:64bit: - [2009/07/13 20:41:27 | 001,011,712 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV:64bit: - [2009/07/03 20:47:12 | 000,240,160 | ---- | M] (Acer) [Auto | Running] -- C:\Program Files\Gateway\Gateway Updater\UpdaterService.exe -- (Updater Service)
SRV - [2010/06/30 13:00:27 | 001,352,832 | ---- | M] (Lavasoft) [Auto | Running] -- C:\Program Files (x86)\Lavasoft\Ad-Aware\AAWService.exe -- (Lavasoft Ad-Aware Service)
SRV - [2009/10/29 15:19:30 | 000,117,640 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\ccSvcHst.exe -- (Norton Internet Security)
SRV - [2009/10/20 22:39:28 | 000,340,456 | ---- | M] (Kaspersky Lab) [Auto | Running] -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\avp.exe -- (AVP)
SRV - [2009/09/24 18:42:28 | 000,062,720 | ---- | M] (NewTech Infosystems, Inc.) [Auto | Running] -- C:\Program Files (x86)\NewTech Infosystems\Gateway MyBackup\IScheduleSvc.exe -- (NTI IScheduleSvc)
SRV - [2009/08/28 04:38:58 | 001,150,496 | ---- | M] (Acer Incorporated) [Auto | Running] -- C:\Program Files (x86)\Gateway\Registration\GregHSRW.exe -- (Greg_Service)
SRV - [2009/07/13 22:20:14 | 000,000,000 | ---D | M] [On_Demand | Stopped] -- C:\Windows\Vss -- (VSS)
SRV - [2009/07/13 22:20:14 | 000,000,000 | ---D | M] [Unknown | Stopped] -- C:\Windows\SysWOW64\Msdtc -- (MSDTC)
SRV - [2009/07/13 15:30:11 | 000,061,056 | ---- | M] () [On_Demand | Stopped] -- C:\Windows\SysWOW64\wbem\vds.mof -- (vds)
SRV - [2009/04/29 14:21:18 | 000,436,736 | ---- | M] (Conexant Systems, Inc.) [Auto | Running] -- C:\Windows\SysWOW64\XAudio64.dll -- (HsfXAudioService)
SRV - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto | Running] -- C:\Program Files (x86)\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
DRV:64bit: - [2010/06/24 22:50:55 | 000,069,152 | ---- | M] (Lavasoft AB) [File_System | Boot | Running] -- C:\Windows\SysNative\drivers\Lbd.sys -- (Lbd)
DRV:64bit: - [2010/06/15 00:24:43 | 000,353,296 | ---- | M] (Kaspersky Lab) [File_System | System | Running] -- C:\Windows\SysNative\drivers\klif.sys -- (KLIF)
DRV:64bit: - [2010/06/07 13:17:25 | 000,172,592 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\SYMEVENT64x86.SYS -- (SymEvent)
DRV:64bit: - [2010/04/27 13:40:40 | 000,055,856 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\PxHlpa64.sys -- (PxHlpa64)
DRV:64bit: - [2009/10/29 15:19:31 | 000,583,296 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\cchpx64.sys -- (ccHP)
DRV:64bit: - [2009/10/29 15:19:31 | 000,476,720 | ---- | M] (Symantec Corporation) [File_System | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\srtsp64.sys -- (SRTSP)
DRV:64bit: - [2009/10/29 15:19:31 | 000,402,992 | ---- | M] (Symantec Corporation) [File_System | Boot | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\SymEFA64.sys -- (SymEFA)
DRV:64bit: - [2009/10/29 15:19:31 | 000,334,384 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\BHDrvx64.sys -- (BHDrvx64)
DRV:64bit: - [2009/10/29 15:19:31 | 000,278,576 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\symtdi.sys -- (SYMTDI)
DRV:64bit: - [2009/10/29 15:19:31 | 000,120,880 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\symfw.sys -- (SYMFW)
DRV:64bit: - [2009/10/29 15:19:31 | 000,056,880 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\symndisv.sys -- (SYMNDISV)
DRV:64bit: - [2009/10/29 15:19:31 | 000,032,304 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\srtspx64.sys -- (SRTSPX) Symantec Real Time Storage Protection (PEL)
DRV:64bit: - [2009/10/29 15:19:31 | 000,031,280 | R--- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\SymIMV.sys -- (SymIM)
DRV:64bit: - [2009/10/14 23:18:38 | 000,040,464 | ---- | M] (Kaspersky Lab) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\klbg.sys -- (KLBG)
DRV:64bit: - [2009/10/02 21:39:32 | 000,021,008 | ---- | M] (Kaspersky Lab) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\klmouflt.sys -- (klmouflt)
DRV:64bit: - [2009/09/21 14:00:44 | 001,537,024 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\athrx.sys -- (athr)
DRV:64bit: - [2009/09/14 16:46:42 | 000,027,152 | ---- | M] (Kaspersky Lab) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\klim6.sys -- (KLIM6)
DRV:64bit: - [2009/09/01 17:29:56 | 000,157,712 | ---- | M] (Kaspersky Lab) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\kl1.sys -- (kl1)
DRV:64bit: - [2009/08/11 15:59:50 | 000,686,080 | ---- | M] (Conexant Systems Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\CHDRT64.sys -- (CnxtHdAudService)
DRV:64bit: - [2009/07/30 12:11:24 | 006,038,016 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\atikmdag.sys -- (atikmdag)
DRV:64bit: - [2009/07/24 05:49:00 | 000,119,312 | ---- | M] (ATI Technologies, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\AtiHdmi.sys -- (AtiHdmiService)
DRV:64bit: - [2009/07/13 20:52:20 | 000,194,128 | ---- | M] (AMD Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\amdsbs.sys -- (amdsbs)
DRV:64bit: - [2009/07/13 20:48:04 | 000,065,600 | ---- | M] (LSI Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\lsi_sas2.sys -- (LSI_SAS2)
DRV:64bit: - [2009/07/13 20:47:48 | 000,077,888 | ---- | M] (Hewlett-Packard Company) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\HpSAMD.sys -- (HpSAMD)
DRV:64bit: - [2009/07/13 20:45:55 | 000,024,656 | ---- | M] (Promise Technology) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\stexstor.sys -- (stexstor)
DRV:64bit: - [2009/07/13 19:10:47 | 000,011,264 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\rootmdm.sys -- (ROOTMODEM)
DRV:64bit: - [2009/06/20 06:35:00 | 000,317,480 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\k57nd60a.sys -- (k57nd60a) Broadcom NetLink (TM)
DRV:64bit: - [2009/06/19 21:09:57 | 000,054,272 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\L1E62x64.sys -- (L1E) NDIS Miniport Driver for Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller(NDIS6.20)
DRV:64bit: - [2009/06/10 16:01:11 | 001,485,312 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\VSTDPV6.SYS -- (SrvHsfV92)
DRV:64bit: - [2009/06/10 16:01:11 | 000,740,864 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\VSTCNXT6.SYS -- (SrvHsfWinac)
DRV:64bit: - [2009/06/10 16:01:11 | 000,292,864 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\VSTAZL6.SYS -- (SrvHsfHDA)
DRV:64bit: - [2009/06/10 15:37:05 | 006,108,416 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\igdkmd64.sys -- (igfx)
DRV:64bit: - [2009/06/10 15:35:35 | 000,620,544 | ---- | M] (Ralink Technology, Corp.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\netr28x.sys -- (netr28x)
DRV:64bit: - [2009/06/10 15:34:38 | 001,311,232 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\BCMWL664.SYS -- (BCM43XX)
DRV:64bit: - [2009/06/10 15:34:33 | 003,286,016 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\evbda.sys -- (ebdrv)
DRV:64bit: - [2009/06/10 15:34:28 | 000,468,480 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\bxvbda.sys -- (b06bdrv)
DRV:64bit: - [2009/06/10 15:34:23 | 000,270,848 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\b57nd60a.sys -- (b57nd60a)
DRV:64bit: - [2009/06/10 15:31:59 | 000,031,232 | ---- | M] (Hauppauge Computer Works, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\hcw85cir.sys -- (hcw85cir)
DRV:64bit: - [2009/05/24 22:57:42 | 000,243,760 | ---- | M] (Alps Electric Co., Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\Apfiltr.sys -- (ApfiltrService)
DRV:64bit: - [2009/05/05 19:46:08 | 000,018,432 | ---- | M] (NewTech Infosystems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\NTIDrvr.sys -- (NTIDrvr)
DRV:64bit: - [2009/05/05 19:46:08 | 000,016,896 | ---- | M] (NewTech Infosystems Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\UBHelper.sys -- (UBHelper)
DRV:64bit: - [2009/05/05 03:30:28 | 000,016,440 | ---- | M] (Advanced Micro Devices Inc.) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\AtiPcie.sys -- (AtiPcie) AMD PCI Express (3GIO)
DRV:64bit: - [2009/04/29 14:21:08 | 000,010,240 | ---- | M] (Conexant Systems, Inc.) [Kernel | Auto | Running] -- C:\Windows\SysNative\drivers\XAudio64.sys -- (XAudio)
DRV:64bit: - [2009/04/28 12:03:42 | 000,067,128 | ---- | M] (Advanced Micro Devices) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\amdsata.sys -- (amdsata)
DRV:64bit: - [2009/04/28 12:03:42 | 000,028,216 | ---- | M] (Advanced Micro Devices) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\amdxata.sys -- (amdxata)
DRV:64bit: - [2009/04/03 09:39:58 | 000,034,872 | ---- | M] (Advanced Micro Devices) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\usbfilter.sys -- (usbfilter)
DRV:64bit: - [2009/02/13 01:24:56 | 001,485,824 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\CAX_DPV.sys -- (HSF_DPV)
DRV:64bit: - [2009/02/13 01:20:56 | 000,292,864 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\CAXHWAZL.sys -- (CAXHWAZL)
DRV:64bit: - [2009/02/13 01:19:34 | 000,740,864 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\CAX_CNXT.sys -- (winachsf)
DRV:64bit: - [2009/01/09 17:02:08 | 000,031,744 | ---- | M] (Research in Motion Ltd) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\RimSerial_AMD64.sys -- (RimVSerPort)
DRV:64bit: - [2008/05/20 20:33:36 | 000,028,416 | ---- | M] (Research In Motion Limited) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\RimUsb_AMD64.sys -- (RimUsb)
DRV:64bit: - [2007/03/07 15:13:20 | 000,017,920 | ---- | M] (June Fabrics Technology) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\pnetmdm64.sys -- (pnetmdm)
DRV:64bit: - [2006/06/18 09:27:24 | 000,017,024 | ---- | M] (Conexant) [Kernel | Auto | Running] -- C:\Windows\SysNative\drivers\mdmxsdk.sys -- (mdmxsdk)
DRV - [2009/10/29 15:19:31 | 000,397,360 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090712.001\IDSvia64.sys -- (IDSVia64)
DRV - [2009/09/02 12:58:08 | 000,225,280 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\Drivers\RtsUStor.sys -- (RSUSBSTOR)
DRV - [2009/06/10 16:28:14 | 000,001,088 | ---- | M] () [Kernel | On_Demand | Running] -- C:\Windows\SysWOW64\wbem\mpsdrv.mof -- (mpsdrv)
DRV - [2009/06/10 16:15:18 | 000,003,066 | ---- | M] () [Kernel | Boot | Running] -- C:\Windows\SysWOW64\wbem\tcpip.mof -- (Tcpip)
DRV - [2009/03/26 14:16:08 | 000,025,608 | ---- | M] (Dritek System Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysWOW64\drivers\DKbFltr.sys -- (DKbFltr) Dritek Keyboard Filter Driver (64-bit)
DRV - [2006/06/18 09:26:50 | 000,094,208 | ---- | M] (Conexant) [Kernel | Auto | Running] -- C:\Windows\SysWOW64\mdmxsdk.dll -- (mdmxsdk)
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,start page = about:blank
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKLM\..\URLSearchHook: {414b6d9d-4a95-4e8d-b5b1-149dd2d93bb3} - C:\Program Files (x86)\Softonic-Eng7\tbSoft.dll (Conduit Ltd.)
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,start page = about:blank
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Restore = [You must be registered and logged in to see this link.]
IE - HKCU\..\URLSearchHook: {00000000-6E41-4FD3-8538-502F5495E5FC} - C:\Program Files (x86)\Ask.com\GenericAskToolbar.dll (Ask.com)
IE - HKCU\..\URLSearchHook: {414b6d9d-4a95-4e8d-b5b1-149dd2d93bb3} - C:\Program Files (x86)\Softonic-Eng7\tbSoft.dll (Conduit Ltd.)
IE - HKCU\..\URLSearchHook: {CA3EB689-8F09-4026-AA10-B9534C691CE0} - C:\Program Files (x86)\Search Toolbar\tbhelper.dll ()
========== FireFox ==========
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:9.0.0.736
FF - HKLM\software\mozilla\Firefox\Extensions\\ShopperReports@ShopperReports.com: C:\Program Files (x86)\ShopperReports3\bin\3.0.470.0\firefox\firefoxtoolbar\extensions
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.6\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2010/06/27 18:01:13 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.6\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2010/06/27 18:01:13 | 000,000,000 | ---D | M]
[2010/06/20 22:30:05 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\Mozilla\Extensions
[2010/06/20 19:44:11 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\Mozilla\Extensions\IMVUClientXUL@imvu.com
[2010/06/20 22:30:05 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\Mozilla\Firefox\Profiles\giqcou0l.default\extensions
[2010/06/24 02:26:39 | 000,000,000 | ---D | M] -- C:\Program Files (x86)\Mozilla Firefox\extensions
[2010/06/24 02:26:41 | 000,000,000 | ---D | M] -- C:\Program Files (x86)\Mozilla Firefox\extensions\linkfilter@kaspersky.ru
O1 HOSTS File: ([2009/06/10 16:00:26 | 000,000,824 | ---- | M]) - C:\Windows\SysNative\drivers\etc\hosts
O2:64bit: - BHO: (IEVkbdBHO Class) - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\x64\ievkbd.dll (Kaspersky Lab)
O2:64bit: - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll (Google Inc.)
O2:64bit: - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.5126.1836\swg64.dll (Google Inc.)
O2:64bit: - BHO: (FilterBHO Class) - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\x64\klwtbbho.dll (Kaspersky Lab)
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files (x86)\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O2 - BHO: (Softonic-Eng7 Toolbar) - {414b6d9d-4a95-4e8d-b5b1-149dd2d93bb3} - C:\Program Files (x86)\Softonic-Eng7\tbSoft.dll (Conduit Ltd.)
O2 - BHO: (IEVkbdBHO Class) - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\ievkbd.dll (Kaspersky Lab)
O2 - BHO: (Symantec NCO BHO) - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\CoIEPlg.dll (Symantec Corporation)
O2 - BHO: (Symantec Intrusion Prevention) - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\IPSBHO.dll (Symantec Corporation)
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Skype add-on for Internet Explorer) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files (x86)\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll (Google Inc.)
O2 - BHO: (Paltalk Toolbar) - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files (x86)\Ask.com\GenericAskToolbar.dll (Ask.com)
O2 - BHO: (FilterBHO Class) - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\klwtbbho.dll (Kaspersky Lab)
O2 - BHO: (TBSB05974 Class) - {FCBCCB87-9224-4B8D-B117-F56D924BEB18} - C:\Program Files (x86)\Search Toolbar\tbcore3.dll ()
O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files (x86)\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll (Yahoo! Inc)
O3:64bit: - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll (Google Inc.)
O3:64bit: - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
O3 - HKLM\..\Toolbar: (Search Toolbar) - {0C8413C1-FAD1-446C-8584-BE50576F863E} - C:\Program Files (x86)\Search Toolbar\tbcore3.dll ()
O3 - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (Softonic-Eng7 Toolbar) - {414b6d9d-4a95-4e8d-b5b1-149dd2d93bb3} - C:\Program Files (x86)\Softonic-Eng7\tbSoft.dll (Conduit Ltd.)
O3 - HKLM\..\Toolbar: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\CoIEPlg.dll (Symantec Corporation)
O3 - HKLM\..\Toolbar: (Paltalk Toolbar) - {D4027C7F-154A-4066-A1AD-4243D8127440} - C:\Program Files (x86)\Ask.com\GenericAskToolbar.dll (Ask.com)
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files (x86)\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
O3:64bit: - HKCU\..\Toolbar\WebBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll (Google Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\CoIEPlg.dll (Symantec Corporation)
O4:64bit: - HKLM..\Run: [Acer ePower Management] C:\Program Files\Gateway\Gateway Power Management\ePowerTray.exe (Acer Incorporated)
O4:64bit: - HKLM..\Run: [cAudioFilterAgent] C:\Program Files\CONEXANT\cAudioFilterAgent\cAudioFilterAgent64.exe (Conexant Systems, Inc.)
O4:64bit: - HKLM..\Run: [PLFSetI] C:\Windows\PLFSetI.exe ()
O4 - HKLM..\Run: [AVP] C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\avp.exe (Kaspersky Lab)
O4 - HKLM..\Run: [BackupManagerTray] C:\Program Files (x86)\NewTech Infosystems\Gateway MyBackup\BackupManagerTray.exe (NewTech Infosystems, Inc.)
O4 - HKLM..\Run: [Desktop Disc Tool] C:\Program Files (x86)\Roxio\Roxio Burn\RoxioBurnLauncher.exe ()
O4 - HKLM..\Run: [LManager] C:\Program Files (x86)\Launch Manager\LManager.exe (Dritek System Inc.)
O4 - HKLM..\Run: [PDVD8LanguageShortcut] c:\Program Files (x86)\CyberLink\PowerDVD8\Language\Language.exe (CyberLink Corp.)
O4 - HKLM..\Run: [RemoteControl8] c:\Program Files (x86)\CyberLink\PowerDVD8\PDVD8Serv.exe (CyberLink Corp.)
O4 - HKLM..\Run: [StartCCC] C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
O4 - HKLM..\Run: [VideoWebCamera] C:\Program Files (x86)\VideoWebCamera\VideoWebCamera.exe (Suyin)
O4 - HKCU..\Run: [msnmsgr] C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe (Microsoft Corporation)
O4 - HKCU..\Run: [RESTART_STICKY_NOTES] C:\Windows\SysWow64\StikyNot.exe File not found
O4 - HKCU..\Run: [swg] C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
O4 - Startup: C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Best Buy Software Installer.lnk = C:\Program Files (x86)\Best Buy Software Installer\Best Buy Software Installer.exe File not found
O4 - Startup: C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\IMVU.lnk = C:\Users\marc\AppData\Roaming\IMVUClient\IMVUQualityAgent.exe ()
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 28
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 5
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 3
O8:64bit: - Extra context menu item: Google Sidewiki... - C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll (Google Inc.)
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll (Google Inc.)
O9:64bit: - Extra Button: &Virtual keyboard - {4248FE82-7FCB-46AC-B270-339F08212110} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\x64\klwtbbho.dll (Kaspersky Lab)
O9:64bit: - Extra Button: URLs c&heck - {CCF151D8-D089-449F-A5A4-D9909053F20F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\x64\klwtbbho.dll (Kaspersky Lab)
O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: &Virtual keyboard - {4248FE82-7FCB-46AC-B270-339F08212110} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\klwtbbho.dll (Kaspersky Lab)
O9 - Extra Button: PalTalk - {4EAFEF58-EEFA-4116-983D-03B49BCBFFFE} - C:\Program Files (x86)\Paltalk Messenger\paltalk.exe (AVM Software Inc.)
O9 - Extra Button: Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O9 - Extra 'Tools' menuitem : Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O9 - Extra Button: URLs c&heck - {CCF151D8-D089-449F-A5A4-D9909053F20F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\klwtbbho.dll (Kaspersky Lab)
O13 - gopher Prefix: missing
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 97.64.180.150 97.64.168.13
O18:64bit: - Protocol\Handler\livecall {828030A1-22C1-4009-854F-8E305202313F} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-itss {0A9007C0-4076-11D3-8789-0000F8105754} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\msnim {828030A1-22C1-4009-854F-8E305202313F} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\symres {AA1061FE-6C41-421f-9344-69640C9732AB} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - Reg Error: Key error. File not found
O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll (Skype Technologies)
O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O18 - Protocol\Handler\symres {AA1061FE-6C41-421f-9344-69640C9732AB} - C:\Program Files (x86)\Norton Internet Security\Engine\16.7.0.30\CoIEPlg.dll (Symantec Corporation)
O20 - AppInit_DLLs: (C:\PROGRA~2\KASPER~1\KASPER~1\mzvkbd3.dll) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Anti-Virus 2010\mzvkbd3.dll (Kaspersky Lab)
O20:64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (SystemPropertiesPerformance.exe) - C:\Windows\SysNative\SystemPropertiesPerformance.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (/pagefile) - File not found
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (SystemPropertiesPerformance.exe) - C:\Windows\SysWow64\SystemPropertiesPerformance.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (/pagefile) - File not found
O20:64bit: - Winlogon\Notify\klogon: DllName - Reg Error: Key error. - C:\Windows\SysNative\klogon.dll (Kaspersky Lab)
O21:64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
O32 - HKLM CDRom: AutoRun - 0
O34 - HKLM BootExecute: (lsdelete) - File not found
O35:64bit: - HKLM\..comfile [open] -- "%1" %*
O35:64bit: - HKLM\..exefile [open] -- "%1" %*
O37:64bit: - HKLM\...com [@ = comfile] -- "%1" %*
O37:64bit: - HKLM\...exe [@ = exefile] -- "%1" %*
========== Files/Folders - Created Within 90 Days ==========
[2010/07/01 16:54:19 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
[2010/06/25 13:41:02 | 000,000,000 | R-SD | C] -- C:\Users\marc\Documents\My Stationery
[2010/06/24 23:32:58 | 000,069,152 | ---- | C] (Lavasoft AB) -- C:\Windows\SysNative\drivers\Lbd.sys
[2010/06/24 23:32:35 | 000,095,024 | ---- | C] (Sunbelt Software) -- C:\Windows\SysNative\drivers\SBREDrv.sys
[2010/06/24 22:41:12 | 000,000,000 | -H-D | C] -- C:\ProgramData\{74D08EB8-01D1-4BAE-91E3-F30C1B031AC6}
[2010/06/24 22:41:02 | 000,000,000 | ---D | C] -- C:\ProgramData\Lavasoft
[2010/06/24 22:41:02 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Lavasoft
[2010/06/24 22:12:40 | 000,000,000 | ---D | C] -- C:\Windows\pss
[2010/06/24 22:08:06 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\CCleaner
[2010/06/22 18:03:32 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\DivX
[2010/06/22 18:03:12 | 000,000,000 | ---D | C] -- C:\Program Files\DivX
[2010/06/22 18:02:57 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\DivX Shared
[2010/06/22 17:57:21 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\DivX
[2010/06/22 17:56:29 | 000,000,000 | ---D | C] -- C:\ProgramData\DivX
[2010/06/20 22:29:58 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Mozilla
[2010/06/20 22:29:09 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Mozilla Firefox
[2010/06/20 19:44:07 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\IMVU
[2010/06/20 19:43:51 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\IMVUClient
[2010/06/20 15:23:16 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Singlesnet
[2010/06/20 11:58:50 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Ask.com
[2010/06/20 11:58:39 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Paltalk
[2010/06/20 11:58:37 | 000,000,000 | ---D | C] -- C:\Windows\PaltalkScene
[2010/06/20 11:58:37 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Paltalk Messenger
[2010/06/19 03:34:37 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Search Toolbar
[2010/06/15 00:16:06 | 000,353,296 | ---- | C] (Kaspersky Lab) -- C:\Windows\SysNative\drivers\klif.sys
[2010/06/15 00:13:55 | 000,000,000 | ---D | C] -- C:\ProgramData\Kaspersky Lab Setup Files
[2010/06/14 11:39:13 | 000,000,000 | ---D | C] -- C:\Windows\SysWow64\Wat
[2010/06/14 11:39:13 | 000,000,000 | ---D | C] -- C:\Windows\SysNative\Wat
[2010/06/14 11:38:57 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Microsoft Help
[2010/06/14 11:19:14 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Softonic-Eng7
[2010/06/14 11:19:14 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Conduit
[2010/06/14 11:17:23 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Softonic-Eng7
[2010/06/14 11:17:23 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Conduit
[2010/06/14 11:08:19 | 000,233,472 | ---- | C] (CACE Technologies) -- C:\Windows\SysWow64\wpcap.dll
[2010/06/14 11:08:19 | 000,081,920 | ---- | C] (CACE Technologies) -- C:\Windows\SysWow64\Packet.dll
[2010/06/14 11:08:19 | 000,061,440 | ---- | C] (CACE Technologies) -- C:\Windows\SysWow64\WanPacket.dll
[2010/06/14 11:08:19 | 000,057,344 | ---- | C] (Acrotech Solutions) -- C:\Windows\SysWow64\XButton.ocx
[2010/06/14 11:08:19 | 000,032,512 | ---- | C] (CACE Technologies) -- C:\Windows\SysWow64\drivers\npf.sys
[2010/06/14 11:08:18 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Makayama Interactive
[2010/06/14 00:23:32 | 000,000,000 | ---D | C] -- C:\Users\marc\Documents\CyberLink
[2010/06/14 00:23:31 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\CyberLink
[2010/06/14 00:23:31 | 000,000,000 | ---D | C] -- C:\ProgramData\CyberLink
[2010/06/12 16:38:19 | 000,017,920 | ---- | C] (June Fabrics Technology) -- C:\Windows\SysNative\drivers\pnetmdm64.sys
[2010/06/12 16:38:19 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\PdaNet for BlackBerry
[2010/06/12 16:18:32 | 000,031,744 | ---- | C] (Research in Motion Ltd) -- C:\Windows\SysNative\drivers\RimSerial_AMD64.sys
[2010/06/12 16:18:22 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Research In Motion
[2010/06/12 16:18:22 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Research In Motion
[2010/06/11 19:19:31 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\skypePM
[2010/06/11 19:17:44 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Skype
[2010/06/11 19:17:01 | 000,000,000 | R--D | C] -- C:\Program Files (x86)\Skype
[2010/06/11 19:17:01 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Skype
[2010/06/11 19:16:58 | 000,000,000 | ---D | C] -- C:\ProgramData\Skype
[2010/06/11 11:19:41 | 000,000,000 | ---D | C] -- C:\Users\marc\Tracing
[2010/06/11 10:20:11 | 000,000,000 | ---D | C] -- C:\Windows\Minidump
[2010/06/11 04:20:15 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\WinRAR
[2010/06/11 00:35:17 | 000,000,000 | ---D | C] -- C:\Graboid
[2010/06/11 00:20:28 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\vlc
[2010/06/11 00:09:11 | 000,000,000 | ---D | C] -- C:\Users\marc\Documents\Graboid
[2010/06/11 00:04:15 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Graboid
[2010/06/11 00:04:12 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\MozillaControl
[2010/06/11 00:03:44 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\VideoLAN
[2010/06/11 00:03:16 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Graboid
[2010/06/10 19:43:57 | 000,000,000 | ---D | C] -- C:\ProgramData\Kaspersky Lab
[2010/06/10 19:43:57 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Kaspersky Lab
[2010/06/10 19:30:47 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Adobe
[2010/06/10 12:24:03 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\ElevatedDiagnostics
[2010/06/08 10:02:40 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Diagnostics
[2010/06/08 03:09:31 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Microsoft Games
[2010/06/08 00:10:11 | 000,000,000 | ---D | C] -- C:\ProgramData\Symantec
[2010/06/07 15:03:29 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Symantec Shared
[2010/06/07 14:16:05 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Yahoo
[2010/06/07 14:08:16 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Yahoo!
[2010/06/07 14:07:54 | 000,000,000 | ---D | C] -- C:\ProgramData\Yahoo! Companion
[2010/06/07 14:07:52 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Yahoo!
[2010/06/07 14:07:23 | 000,000,000 | ---D | C] -- C:\ProgramData\Yahoo!
[2010/06/07 14:03:27 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Yahoo!
[2010/06/07 13:46:52 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Adobe
[2010/06/07 13:39:56 | 000,000,000 | ---D | C] -- C:\Users\marc\Documents\OneNote Notebooks
[2010/06/07 13:39:20 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Template
[2010/06/07 13:26:46 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Google
[2010/06/07 13:26:45 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Google
[2010/06/07 13:20:48 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Best_Buy®
[2010/06/07 13:17:30 | 000,031,280 | R--- | C] (Symantec Corporation) -- C:\Windows\SysNative\drivers\SymIMV.sys
[2010/06/07 13:17:25 | 000,172,592 | ---- | C] (Symantec Corporation) -- C:\Windows\SysNative\drivers\SYMEVENT64x86.SYS
[2010/06/07 13:17:25 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Symantec Shared
[2010/06/07 13:17:17 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\ATI
[2010/06/07 13:17:17 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\ATI
[2010/06/07 13:17:17 | 000,000,000 | ---D | C] -- C:\ProgramData\ATI
[2010/06/07 13:16:40 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Roxio
[2010/06/07 13:16:29 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Macromedia
[2010/06/07 13:15:04 | 000,000,000 | R--D | C] -- C:\Users\marc\Searches
[2010/06/07 13:15:04 | 000,000,000 | -H-D | C] -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\User Pinned
[2010/06/07 13:14:52 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Identities
[2010/06/07 13:14:46 | 000,000,000 | R--D | C] -- C:\Users\marc\Contacts
[2010/06/07 13:14:42 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\VirtualStore
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\AppData\Local\Temporary Internet Files
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Templates
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Start Menu
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\SendTo
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Recent
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\PrintHood
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\NetHood
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Documents\My Videos
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Documents\My Pictures
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Documents\My Music
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\My Documents
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Local Settings
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\AppData\Local\History
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Cookies
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\Application Data
[2010/06/07 13:14:17 | 000,000,000 | -HSD | C] -- C:\Users\marc\AppData\Local\Application Data
[2010/06/07 13:14:16 | 000,000,000 | --SD | C] -- C:\Users\marc\AppData\Roaming\Microsoft
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Videos
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Saved Games
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Pictures
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Music
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Links
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Favorites
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Downloads
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\My Documents
[2010/06/07 13:14:16 | 000,000,000 | R--D | C] -- C:\Users\marc\Desktop
[2010/06/07 13:14:16 | 000,000,000 | -H-D | C] -- C:\Users\marc\AppData
[2010/06/07 13:14:16 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Temp
[2010/06/07 13:14:16 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Local\Microsoft
[2010/06/07 13:14:16 | 000,000,000 | ---D | C] -- C:\Users\marc\AppData\Roaming\Media Center Programs
[2010/06/07 13:14:06 | 000,000,000 | -HSD | C] -- C:\Recovery
[2010/04/26 17:04:42 | 000,353,592 | ---- | C] (DivX, Inc.) -- C:\Windows\SysWow64\DivXControlPanelApplet.cpl
========== Files - Modified Within 90 Days ==========
[2010/07/01 17:11:23 | 001,572,864 | -HS- | M] () -- C:\Users\marc\ntuser.dat
[2010/07/01 17:01:21 | 000,001,002 | ---- | M] () -- C:\Users\Public\Desktop\Acrobat_com.lnk
[2010/07/01 17:00:13 | 000,000,354 | ---- | M] () -- C:\Windows\tasks\Gateway Registration Data Sending.job
[2010/07/01 16:54:53 | 000,017,376 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
[2010/07/01 16:54:53 | 000,017,376 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
[2010/07/01 16:47:53 | 000,000,930 | ---- | M] () -- C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\IMVU.lnk
[2010/07/01 16:46:09 | 000,000,894 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2010/07/01 16:46:04 | 000,065,536 | ---- | M] () -- C:\Windows\SysNative\Ikeext.etl
[2010/07/01 16:46:02 | 000,000,006 | -H-- | M] () -- C:\Windows\tasks\SA.DAT
[2010/07/01 16:45:58 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2010/07/01 16:45:55 | 3018,608,640 | -HS- | M] () -- C:\hiberfil.sys
[2010/07/01 16:14:05 | 000,000,898 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2010/07/01 05:21:39 | 002,869,231 | -H-- | M] () -- C:\Users\marc\AppData\Local\IconCache.db
[2010/07/01 00:03:16 | 001,140,012 | ---- | M] () -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\Cat.DB
[2010/06/30 23:50:48 | 000,007,605 | ---- | M] () -- C:\Users\marc\AppData\Local\Resmon.ResmonCfg
[2010/06/30 23:32:06 | 000,002,971 | ---- | M] () -- C:\Users\marc\Documents\HiJackThis.lnk
[2010/06/28 20:54:59 | 000,002,351 | ---- | M] () -- C:\Users\Public\Desktop\Google Chrome.lnk
[2010/06/24 22:53:05 | 000,095,024 | ---- | M] (Sunbelt Software) -- C:\Windows\SysNative\drivers\SBREDrv.sys
[2010/06/24 22:52:53 | 000,015,880 | ---- | M] () -- C:\Windows\SysNative\lsdelete.exe
[2010/06/24 22:50:55 | 000,069,152 | ---- | M] (Lavasoft AB) -- C:\Windows\SysNative\drivers\Lbd.sys
[2010/06/24 22:41:10 | 000,001,173 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Ad-Aware.lnk
[2010/06/24 22:41:10 | 000,001,149 | ---- | M] () -- C:\Users\Public\Desktop\Ad-Aware.lnk
[2010/06/24 22:08:08 | 000,001,018 | ---- | M] () -- C:\Users\marc\Desktop\CCleaner.lnk
[2010/06/24 21:21:28 | 000,713,888 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
[2010/06/24 21:21:28 | 000,615,360 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
[2010/06/24 21:21:28 | 000,103,702 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
[2010/06/24 17:00:17 | 001,139,532 | ---- | M] () -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\Cat(33).DB
[2010/06/24 03:11:00 | 001,139,532 | ---- | M] () -- C:\Windows\SysNative\drivers\NISx64\1007000.01E\Cat(37).DB
[2010/06/22 18:03:53 | 000,001,626 | ---- | M] () -- C:\Users\marc\Desktop\DivX Movies.lnk
[2010/06/22 18:03:28 | 000,001,123 | ---- | M] () -- C:\Users\Public\Desktop\DivX Plus Player.lnk
[2010/06/22 18:03:10 | 000,001,163 | ---- | M] () -- C:\Users\Public\Desktop\DivX Plus Converter.lnk
[2010/06/20 22:29:13 | 000,001,974 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Mozilla Firefox.lnk
[2010/06/20 22:29:13 | 000,001,950 | ---- | M] () -- C:\Users\Public\Desktop\Mozilla Firefox.lnk
[2010/06/20 19:44:04 | 000,001,884 | ---- | M] () -- C:\Users\marc\Desktop\IMVU.lnk
[2010/06/20 15:23:17 | 000,001,137 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Start Singlesnet.lnk
[2010/06/20 15:23:17 | 000,001,113 | ---- | M] () -- C:\Users\Public\Desktop\Start Singlesnet.lnk
[2010/06/20 11:58:42 | 000,001,120 | ---- | M] () -- C:\Users\marc\Desktop\Upgrade to Paltalk Extreme.lnk
[2010/06/20 11:58:41 | 000,001,968 | ---- | M] () -- C:\Users\marc\Desktop\PaltalkScene.lnk
[2010/06/20 10:34:23 | 000,001,172 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Yahoo! Messenger.lnk
[2010/06/20 10:34:23 | 000,001,148 | ---- | M] () -- C:\Users\Public\Desktop\Yahoo! Messenger.lnk
[2010/06/15 01:32:00 | 000,002,515 | ---- | M] () -- C:\Users\Public\Desktop\Skype.lnk
[2010/06/15 00:24:43 | 000,353,296 | ---- | M] (Kaspersky Lab) -- C:\Windows\SysNative\drivers\klif.sys
[2010/06/15 00:24:42 | 000,149,773 | ---- | M] () -- C:\Windows\SysNative\drivers\klin.dat
[2010/06/15 00:24:42 | 000,106,765 | ---- | M] () -- C:\Windows\SysNative\drivers\klick.dat
[2010/06/13 05:26:02 | 000,343,552 | ---- | M] () -- C:\Windows\SysNative\FNTCACHE.DAT
[2010/06/13 05:24:26 | 000,524,288 | -HS- | M] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TMContainer00000000000000000002.regtrans-ms
[2010/06/13 05:24:26 | 000,524,288 | -HS- | M] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TMContainer00000000000000000001.regtrans-ms
[2010/06/13 05:24:26 | 000,065,536 | -HS- | M] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TM.blf
[2010/06/13 05:12:18 | 000,001,142 | ---- | M] () -- C:\Users\Public\Desktop\Microsoft Works.lnk
[2010/06/11 19:19:32 | 000,000,056 | -H-- | M] () -- C:\ProgramData\ezsidmv.dat
[2010/06/11 19:17:59 | 000,002,250 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/06/11 11:02:31 | 000,001,420 | ---- | M] () -- C:\Users\marc\Desktop\Internet Explorer (64-bit).lnk
[2010/06/08 00:54:53 | 000,524,288 | -HS- | M] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000002.regtrans-ms
[2010/06/08 00:54:53 | 000,524,288 | -HS- | M] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000001.regtrans-ms
[2010/06/08 00:54:53 | 000,065,536 | -HS- | M] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TM.blf
[2010/06/07 13:39:19 | 000,000,000 | ---- | M] () -- C:\Users\marc\AppData\Roaming\wklnhst.dat
[2010/06/07 13:26:38 | 000,001,448 | ---- | M] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk
[2010/06/07 13:20:42 | 000,001,069 | ---- | M] () -- C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Best Buy Software Installer.lnk
[2010/06/07 13:18:02 | 000,000,201 | ---- | M] () -- C:\Windows\USER.XML
[2010/06/07 13:17:25 | 000,172,592 | ---- | M] (Symantec Corporation) -- C:\Windows\SysNative\drivers\SYMEVENT64x86.SYS
[2010/06/07 13:17:25 | 000,007,440 | ---- | M] () -- C:\Windows\SysNative\drivers\SYMEVENT64x86.CAT
[2010/06/07 13:17:25 | 000,000,855 | ---- | M] () -- C:\Windows\SysNative\drivers\SYMEVENT64x86.INF
[2010/06/07 13:17:19 | 000,002,572 | ---- | M] () -- C:\Users\Public\Desktop\Norton Internet Security.lnk
[2010/06/07 13:14:34 | 000,079,152 | ---- | M] () -- C:\Users\marc\AppData\Local\GDIPFONTCACHEV1.DAT
[2010/06/07 13:14:23 | 000,000,201 | RHS- | M] () -- C:\Preload.rev
[2010/06/07 13:14:23 | 000,000,168 | ---- | M] () -- C:\Windows\WisLangCode.ini
[2010/06/07 13:14:17 | 000,000,020 | -HS- | M] () -- C:\Users\marc\ntuser.ini
[2010/06/07 13:11:58 | 000,039,252 | ---- | M] () -- C:\Windows\SysWow64\license.rtf
[2010/06/07 13:11:58 | 000,039,252 | ---- | M] () -- C:\Windows\SysNative\license.rtf
[2010/04/26 17:04:42 | 000,353,592 | ---- | M] (DivX, Inc.) -- C:\Windows\SysWow64\DivXControlPanelApplet.cpl
[2010/07/01 16:57:48 | 000,001,002 | ---- | C] () -- C:\Users\Public\Desktop\Acrobat_com.lnk
[2010/06/30 23:50:48 | 000,007,605 | ---- | C] () -- C:\Users\marc\AppData\Local\Resmon.ResmonCfg
[2010/06/30 23:37:39 | 000,002,971 | ---- | C] () -- C:\Users\marc\Documents\HiJackThis.lnk
[2010/06/27 18:43:37 | 000,015,880 | ---- | C] () -- C:\Windows\SysNative\lsdelete.exe
[2010/06/24 22:41:10 | 000,001,173 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Ad-Aware.lnk
[2010/06/24 22:41:10 | 000,001,149 | ---- | C] () -- C:\Users\Public\Desktop\Ad-Aware.lnk
[2010/06/24 22:08:08 | 000,001,018 | ---- | C] () -- C:\Users\marc\Desktop\CCleaner.lnk
[2010/06/22 18:03:53 | 000,001,626 | ---- | C] () -- C:\Users\marc\Desktop\DivX Movies.lnk
[2010/06/22 18:03:28 | 000,001,123 | ---- | C] () -- C:\Users\Public\Desktop\DivX Plus Player.lnk
[2010/06/22 18:03:10 | 000,001,163 | ---- | C] () -- C:\Users\Public\Desktop\DivX Plus Converter.lnk
[2010/06/20 22:29:13 | 000,001,974 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Mozilla Firefox.lnk
[2010/06/20 22:29:13 | 000,001,950 | ---- | C] () -- C:\Users\Public\Desktop\Mozilla Firefox.lnk
[2010/06/20 19:45:02 | 000,000,930 | ---- | C] () -- C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\IMVU.lnk
[2010/06/20 19:44:04 | 000,001,884 | ---- | C] () -- C:\Users\marc\Desktop\IMVU.lnk
[2010/06/20 15:23:17 | 000,001,137 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Start Singlesnet.lnk
[2010/06/20 15:23:17 | 000,001,113 | ---- | C] () -- C:\Users\Public\Desktop\Start Singlesnet.lnk
[2010/06/20 11:58:42 | 000,001,120 | ---- | C] () -- C:\Users\marc\Desktop\Upgrade to Paltalk Extreme.lnk
[2010/06/20 11:58:41 | 000,001,968 | ---- | C] () -- C:\Users\marc\Desktop\PaltalkScene.lnk
[2010/06/20 10:34:23 | 000,001,172 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Yahoo! Messenger.lnk
[2010/06/20 10:34:23 | 000,001,148 | ---- | C] () -- C:\Users\Public\Desktop\Yahoo! Messenger.lnk
[2010/06/15 00:17:00 | 000,149,773 | ---- | C] () -- C:\Windows\SysNative\drivers\klin.dat
[2010/06/15 00:17:00 | 000,106,765 | ---- | C] () -- C:\Windows\SysNative\drivers\klick.dat
[2010/06/14 11:08:19 | 000,389,120 | ---- | C] () -- C:\Windows\SysWow64\actskn43.ocx
[2010/06/13 23:17:34 | 000,065,536 | ---- | C] () -- C:\Windows\SysNative\Ikeext.etl
[2010/06/13 05:12:18 | 000,001,142 | ---- | C] () -- C:\Users\Public\Desktop\Microsoft Works.lnk
[2010/06/11 19:19:32 | 000,000,056 | -H-- | C] () -- C:\ProgramData\ezsidmv.dat
[2010/06/11 19:17:59 | 000,002,351 | ---- | C] () -- C:\Users\Public\Desktop\Google Chrome.lnk
[2010/06/11 19:17:59 | 000,002,250 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/06/11 19:17:02 | 000,002,515 | ---- | C] () -- C:\Users\Public\Desktop\Skype.lnk
[2010/06/11 13:09:41 | 000,000,898 | ---- | C] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2010/06/11 13:09:39 | 000,000,894 | ---- | C] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2010/06/11 11:02:31 | 000,001,420 | ---- | C] () -- C:\Users\marc\Desktop\Internet Explorer (64-bit).lnk
[2010/06/11 10:20:36 | 000,524,288 | -HS- | C] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TMContainer00000000000000000002.regtrans-ms
[2010/06/11 10:20:35 | 000,524,288 | -HS- | C] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TMContainer00000000000000000001.regtrans-ms
[2010/06/11 10:20:35 | 000,065,536 | -HS- | C] () -- C:\Users\marc\ntuser.dat{c3b8f361-756c-11df-98f0-00262d8082a4}.TM.blf
[2010/06/07 13:39:19 | 000,000,000 | ---- | C] () -- C:\Users\marc\AppData\Roaming\wklnhst.dat
[2010/06/07 13:26:38 | 000,001,448 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk
[2010/06/07 13:17:25 | 000,007,440 | ---- | C] () -- C:\Windows\SysNative\drivers\SYMEVENT64x86.CAT
[2010/06/07 13:17:25 | 000,000,855 | ---- | C] () -- C:\Windows\SysNative\drivers\SYMEVENT64x86.INF
[2010/06/07 13:16:59 | 000,000,354 | ---- | C] () -- C:\Windows\tasks\Gateway Registration Data Sending.job
[2010/06/07 13:14:17 | 000,524,288 | -HS- | C] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000002.regtrans-ms
[2010/06/07 13:14:17 | 000,000,020 | -HS- | C] () -- C:\Users\marc\ntuser.ini
[2010/06/07 13:14:16 | 001,572,864 | -HS- | C] () -- C:\Users\marc\ntuser.dat
[2010/06/07 13:14:16 | 000,524,288 | -HS- | C] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000001.regtrans-ms
[2010/06/07 13:14:16 | 000,262,144 | -HS- | C] () -- C:\Users\marc\ntuser.dat.LOG1
[2010/06/07 13:14:16 | 000,065,536 | -HS- | C] () -- C:\Users\marc\NTUSER.DAT{016888bd-6c6f-11de-8d1d-001e0bcde3ec}.TM.blf
[2010/06/07 13:14:16 | 000,001,069 | ---- | C] () -- C:\Users\marc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Best Buy Software Installer.lnk
[2010/06/07 13:14:16 | 000,000,290 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Shows Desktop.lnk
[2010/06/07 13:14:16 | 000,000,272 | ---- | C] () -- C:\Users\marc\Application Data\Microsoft\Internet Explorer\Quick Launch\Window Switcher.lnk
[2010/06/07 13:14:16 | 000,000,000 | -HS- | C] () -- C:\Users\marc\ntuser.dat.LOG2
[2010/01/26 20:19:11 | 000,000,033 | ---- | C] () -- C:\Windows\LaunApp.ini
[2010/01/26 20:01:31 | 000,000,323 | ---- | C] () -- C:\Windows\PidList.ini
[2010/01/26 19:38:37 | 000,001,642 | ---- | C] () -- C:\Windows\WPatchProgress.ini
[2009/10/29 15:56:57 | 000,000,189 | ---- | C] () -- C:\Windows\Prelaunch.ini
[2009/10/29 15:56:57 | 000,000,168 | ---- | C] () -- C:\Windows\WisLangCode.ini
[2009/10/29 15:56:57 | 000,000,147 | ---- | C] () -- C:\Windows\WisPriority.ini
[2009/07/13 18:42:10 | 000,064,000 | ---- | C] () -- C:\Windows\SysWow64\BWContextHandler.dll
[2009/07/13 16:03:59 | 000,364,544 | ---- | C] () -- C:\Windows\SysWow64\msjetoledb40.dll
[2010/07/01 16:54:19 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
[2010/07/01 16:47:51 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\IMVU
[2010/06/20 19:44:03 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\IMVUClient
[2010/06/20 12:06:26 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\Paltalk
[2010/06/07 13:39:20 | 000,000,000 | ---D | M] -- C:\Users\marc\AppData\Roaming\Template
[2010/07/01 17:00:13 | 000,000,354 | ---- | M] () -- C:\Windows\Tasks\Gateway Registration Data Sending.job
[2009/07/14 00:08:49 | 000,008,904 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
marc_army26
OS : window7
# Likes : 0
Re: i need help with deleting 13 viruses and 2 trojans
Post by marc_army26 on Thu Jul 01, 2010 10:15 pm
OTL Extras logfile created on: 7/1/2010 5:03:33 PM - Run 1
Include 64bit Scans
File Age = 90 Days
Output = Standard
Quick Scan
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\]
.cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
.html [@ = FirefoxHTML] -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\shell\[command]\command]
batfile [open] -- "%1" %* File not found
cmdfile [open] -- "%1" %* File not found
comfile [open] -- "%1" %* File not found
exefile [open] -- "%1" %* File not found
htmlfile [edit] -- "C:\Program Files (x86)\Microsoft Office\Office12\msohtmed.exe" %1 (Microsoft Corporation)
htmlfile [print] -- "C:\Program Files (x86)\Microsoft Office\Office12\msohtmed.exe" /p %1 (Microsoft Corporation)
InternetShortcut [print] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\mshtml.dll",PrintHTML "%1" (Microsoft Corporation)
piffile [open] -- "%1" %* File not found
scrfile [config] -- "%1" File not found
scrfile [open] -- "%1" /S File not found
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 File not found
Directory [OneNote.Open] -- C:\PROGRA~2\MICROS~2\Office12\ONENOTE.EXE "%L" (Microsoft Corporation)
Folder [open] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
Folder [explore] -- Reg Error: Value error.
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"VistaSp1" = 28 4D B2 76 41 04 CA 01 [binary data]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"DisableMonitoring" = 1
"DisableNotifications" = 0
"EnableFirewall" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{8220EEFE-38CD-377E-8595-13398D740ACE}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17
"{90120000-002A-0000-1000-0000000FF1CE}" = Microsoft Office Office 64-bit Components 2007
"{90120000-002A-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit MUI (English) 2007
"{90120000-0116-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit Setup Metadata MUI (English) 2007
"{95120000-00B9-0409-1000-0000000FF1CE}" = Microsoft Application Error Reporting
"{96F70DF8-160F-4F9C-9B9E-2A9B439B4EB9}" = Broadcom Gigabit NetLink Controller
"{9F72EF8B-AEC9-4CA5-B483-143980AFD6FD}" = ALPS Touch Pad Driver
"{A8DDE3ED-9B6A-F806-32AF-EC53A836A04F}" = ATI Catalyst Install Manager
"{B6E3757B-5E77-3915-866A-CCFC4B8D194C}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053
"{B7CF178A-2F3D-0125-0D78-98EB53D92A52}" = ccc-utility64
"{EE936C7A-EA40-31D5-9B65-8E3E089C3828}" = Microsoft Visual C++ 2008 ATL Update kb973924 - x64 9.0.30729.4148
"{FBBC4667-2521-4E78-B1BD-8706F774549B}" = Best Buy Software Installer
"CNXT_AUDIO_HDA" = Conexant HD Audio
"CNXT_MODEM_HDA_HSF" = HDAUDIO Soft Data Fax Modem with SmartCP
"{0695DD0E-0E07-061B-5317-1FCCEA3CA51F}" = CCC Help Czech
"{06A02948-CE93-82A0-7BD4-5FB9562136F7}" = CCC Help Japanese
"{0B7169C2-4FC9-0454-6E6F-CDBA27D9C3CF}" = CCC Help Spanish
"{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
"{1FFA2D28-F77A-E27C-0659-F497926805AA}" = CCC Help Polish
"{2BF2E31F-B8BB-40A7-B650-98D28E0F7D47}" = CyberLink PowerDVD 8
"{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Roxio Update Manager
"{338F08AB-C262-42C7-B000-34DE1A475273}" = Ad-Aware Email Scanner for Outlook
"{37DA7059-EC42-8F87-2593-AB273A13CDE4}" = CCC Help Hungarian
"{3B4E636E-9D65-4D67-BA61-189800823F52}" = Windows Live Communications Platform
"{3D5044A5-97B8-45C0-B956-BB2376569188}" = Windows Live Movie Maker
"{3DB0448D-AD82-4923-B305-D001E521A964}" = Gateway Power Management
"{45338B07-A236-4270-9A77-EBB4115517B5}" = Windows Live Sign-in Assistant
"{4F535C04-86BE-47D1-98C6-8AB26D28482B}" = Singlesnet
"{554B7217-1988-2E1E-8CAC-30CB8498DA8E}" = CCC Help Portuguese
"{5920C2D5-2969-9BAE-E5A7-947721CFF1F1}" = CCC Help English
"{5C8C6C22-5B84-E88C-C38C-9E66DB569600}" = CCC Help Thai
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{6122170D-F78E-182F-1D70-9187108F0AB7}" = Catalyst Control Center Graphics Light
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{67E03279-F703-408F-B4BF-46B5FC8D70CD}" = Microsoft Works
"{6D9021DC-CF1B-4148-8C80-6D8E8A8A33EB}" = Video Web Camera
"{72B776E5-4530-4C4B-9453-751DF87D9D93}" = Backup Manager Basic
"{79BF8F0E-A3A6-D677-F4AE-157BE4AB9E46}" = CCC Help Danish
"{7E9E6DC1-BE81-F3C8-2D61-F9AFADC7B2F8}" = CCC Help Chinese Standard
"{7EFE7605-8879-F08C-9EBD-F0B0EBEDE2AA}" = CCC Help French
"{7F811A54-5A09-4579-90E1-C93498E230D9}" = Gateway Recovery Management
"{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
"{81CA0ED5-7522-01D4-2E20-018033B50087}" = CCC Help Korean
"{82809116-D1EE-443C-AE31-F19E709DDF7A}" = AMD USB Filter Driver
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{86D4B82A-ABED-442A-BE86-96357B70F4FE}" = Ask Toolbar
"{8B999A44-8314-493B-877E-A1DA5B54D9B8}" = Catalyst Control Center - Branding
"{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-002A-0000-1000-0000000FF1CE}_HOMESTUDENTR_{E64BA721-2310-4B55-BE5A-2925F9706192}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-002A-0409-1000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{90120000-0116-0409-1000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = 2007 Microsoft Office Suite Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{91903291-1546-5B74-AC17-FDBBFD57D3F9}" = CCC Help Russian
"{943B6738-4801-4982-90EC-0442EF7AEB16}" = Kaspersky Anti-Virus 2010
"{96AE7E41-E34E-47D0-AC07-1091A8127911}" = Realtek USB 2.0 Card Reader
"{974A6749-A030-9EC2-D200-7BD29CA886AC}" = ccc-core-static
"{981029E0-7FC9-4CF3-AB39-6F133621921A}" = Skype Toolbars
"{9D318C86-AF4C-409F-A6AC-7183FF4CF424}" = Internet TV for Windows Media Center
"{9D77E042-7D73-0DDA-DAEF-95AD3247C63F}" = Catalyst Control Center Localization All
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A33E7B0C-B99C-4EC9-B702-8A328B161AF9}" = Roxio Burn
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{AA404934-A326-AC94-154A-73F65B2DBEFE}" = CCC Help Finnish
"{AC76BA86-7AD7-FFFF-7B44-A91000000001}" = Adobe Reader 9.1 MUI
"{B04FC2D5-AE5C-1526-69B8-7121BD8CE3B1}" = CCC Help Swedish
"{B1C45394-E332-23F3-35EE-4086C5167C29}" = Catalyst Control Center Core Implementation
"{B2E47DE7-800B-40BB-BD1F-9F221C3AEE87}" = Roxio Burn
"{B6C21804-0E6C-D4E6-0CF1-4E7F96AAE930}" = CCC Help Turkish
"{BF59CB97-0475-8CDC-1DEB-F6565D3868FA}" = CCC Help Greek
"{C3A68A9A-2541-6171-3092-09C8AFAC4924}" = CCC Help Italian
"{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.2
"{D4C3DAFC-2F7A-E7A9-89D1-70E53F44D231}" = Catalyst Control Center InstallProxy
"{D547F98C-7111-4503-BF30-B5633C2A81F8}" = BlackBerry Device Manager
"{D6C75F0B-3BC1-4FC9-B8C5-3F7E8ED059CA}" = Windows Live Photo Gallery
"{DCF9791F-07F7-3FE8-E639-22EAE582C244}" = CCC Help Norwegian
"{DED53B0B-B67C-4244-AE6A-D6FD3C28D1EF}" = Ad-Aware
"{E2DFE069-083E-4631-9B6C-43C48E991DE5}" = Junk Mail filter update
"{E50AE784-FABE-46DA-A1F8-7B6B56DCB22E}" = Microsoft Office Suite Activation Assistant
"{E7C97E98-4C2D-BEAF-5D2F-CC45A2F95D90}" = Acrobat.com
"{EB7879B9-891A-2502-1CAC-4D328A7DA434}" = Catalyst Control Center Graphics Full Existing
"{EC3102A1-F7D5-F4D7-0BBE-E9A336852DD5}" = CCC Help Dutch
"{EE171732-BEB4-4576-887D-CB62727F01CA}" = Gateway Updater
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}" = Visual C++ 2008 x86 Runtime - (v9.0.30729)
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}.vc_x86runtime_30729_01" = Visual C++ 2008 x86 Runtime - v9.0.30729.01
"{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
"{FA03EF4C-DE79-C463-6B50-AAC28A9A64FD}" = Catalyst Control Center Graphics Full New
"{FAAAA82D-E8FE-04C8-72D5-619A2632E1DF}" = CCC Help Chinese Traditional
"{FCB13E0B-09AD-7133-0B7E-52A157C6582E}" = CCC Help German
"Ad-Aware" = Ad-Aware
"Adobe AIR" = Adobe AIR
"Best Buy Software Installer" = Best Buy Software Installer
"BlackBerry_{D547F98C-7111-4503-BF30-B5633C2A81F8}" = BlackBerry Device Manager
"CCleaner" = CCleaner
"DivX Setup.divx.com" = DivX Setup
"Easy WiFi Radar" = Easy WiFi Radar 1.0.5
"Gateway InfoCentre" = Gateway InfoCentre
"Gateway Registration" = Gateway Registration
"Gateway Screensaver" = Gateway ScreenSaver
"Gateway Welcome Center" = Welcome Center
"Google Chrome" = Google Chrome
"Identity Card" = Identity Card
"InstallShield_{2BF2E31F-B8BB-40A7-B650-98D28E0F7D47}" = CyberLink PowerDVD 8
"InstallShield_{72B776E5-4530-4C4B-9453-751DF87D9D93}" = Gateway MyBackup
"InstallWIX_{943B6738-4801-4982-90EC-0442EF7AEB16}" = Kaspersky Anti-Virus 2010
"LManager" = Launch Manager
"Mozilla Firefox (3.6.6)" = Mozilla Firefox (3.6.6)
"NIS" = Norton Internet Security
"PalTalk8.2" = PaltalkScene
"PdaNet_is1" = PdaNet for BlackBerry 1.30
"Search Toolbar" = Search Toolbar
"ShopperReportsSA" = ShopperReports
"Softonic-Eng7 Toolbar" = Softonic-Eng7 Toolbar
"Yahoo! Companion" = Yahoo! Toolbar
"Yahoo! Messenger" = Yahoo! Messenger
"Yahoo! Software Update" = Yahoo! Software Update
"IMVU Avatar chat client software BETA" = IMVU Avatar Chat Software
"Yahoo! BrowserPlus" = Yahoo! BrowserPlus 2.7.1
Error reading Event Logs: The Event Service is not operating properly or the Event Logs are corrupt!
marc_army26
OS : window7
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 10:24 pm
well I will wait on your answer or reply what to do after this? I know you are probably really busy lol
marc_army26
OS : window7
# Likes : 0
Post by Crush on Thu Jul 01, 2010 11:11 pm
hi marc,
Please run OTL.exe.
    :OTL
    :commands
    [emptytemp]
    [purity]
  • Close OTL.exe
Please download Malwarebytes Anti-Malware from [URL="http://www.malwarebytes.org/mbam/program/mbam-setup.exe"]Malwarebytes.org[/URL].
Alternate link: [URL="http://download.bleepingcomputer.com/malwarebytes/mbam-setup.exe"]BleepingComputer.com[/URL].
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. If you are prompted to restart, please allow it to restart your computer. Failure to do this, will cause the infection to still be active on the computer.
  • The log can also be found at C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
Crush
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 11:31 pm
what do you mean? run otl.exe where is that at so I can run it? I don't see it
marc_army26
OS : window7
# Likes : 0
Post by Crush on Thu Jul 01, 2010 11:36 pm
It says it is currently running from C:\Users\marc\Downloads
It's best if run from the Desktop Smile
Crush
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 11:41 pm
oh ok... well is it ok to run it the way its running now or do I need to go ahead and run it from my desktop?
marc_army26
OS : window7
# Likes : 0
Post by Crush on Thu Jul 01, 2010 11:43 pm
Just for ease of use i'd run it from the desktop.
Crush
# Likes : 0
Post by marc_army26 on Thu Jul 01, 2010 11:57 pm
so do i need to copy the whole page or just the ones that say file? or the processes and drivers and all?
marc_army26
OS : window7
# Likes : 0
Post by Crush on Thu Jul 01, 2010 11:59 pm
Copy from :OTL down to and including [purity] in post 8 please
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 12:06 am
I dont see where it says commands only O2 BHO? and there isnt anything in purity?
marc_army26
OS : window7
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 12:07 am
oh ok so the whole page
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 12:08 am
You need to copy this:
:OTL
:commands
[emptytemp]
[purity]
into the Custom Scans/Fixes box as you did with the Custom Scans in my first post.
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 12:10 am
ok did it
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 12:11 am
Ok looking forward to seeing the log. Additionally, please review Post 8 for further instructions
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 2:15 am
Database version: 4266
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
7/1/2010 9:12:51 PM
mbam-log-2010-07-01 (21-12-51).txt
Scan type: Full scan (C:\|D:\|)
Objects scanned: 215858
Time elapsed: 1 hour(s), 20 minute(s), 36 second(s)
Registry Keys Infected: 73
Files Infected: 6
HKEY_CLASSES_ROOT\shopperreports.hbax (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.hbax.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.hbinfoband (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.hbinfoband.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.iebutton (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.iebutton.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.iebuttona (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.iebuttona.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.rprtctrl (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.rprtctrl.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{21ba420e-161c-413a-b21e-4e42ae1f4226} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{453db0c5-f41c-4d97-8dd6-cc72ecd5f699} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{4afc07d0-59bb-46b8-b097-1a46e88eef71} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6511ce4c-4722-40d0-ad3d-4afa2f50978a} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{9bec9b38-bf39-4899-806e-a1c5dfeb60a2} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{b86d82bf-d39f-439a-a07c-43eddc6f6ea6} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{da6305b9-0869-4235-8c1d-533a65e639e5} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e6961c59-cfce-4ccd-b794-bc78db98413a} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f8b4ec8a-2407-4be0-aee2-0f430d65a90d} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{0d82acd6-a652-4496-a298-2bde705f4227} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{7025e484-d4b0-441a-9f0b-69063bd679ce} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{8258b35c-05b8-4c0e-9525-9bccc70f8f2d} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{a89256ad-ec17-4a83-bef5-4b8bc4f39306} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{100eb1fd-d03e-47fd-81f3-ee91287f9465} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{20ea9658-6bc3-4599-a87d-6371fe9295fc} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a16ad1e9-f69a-45af-9462-b1c286708842} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a7cddcdc-beeb-4685-a062-978f5e07ceee} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9ccbb35-d123-4a31-affc-9b2933132116} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{acc62306-9a63-4864-bd2f-c8825d2d7ea6} (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{100eb1fd-d03e-47fd-81f3-ee91287f9465} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{100eb1fd-d03e-47fd-81f3-ee91287f9465} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{a7cddcdc-beeb-4685-a062-978f5e07ceee} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c5428486-50a0-4a02-9d20-520b59a9f9b2} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c5428486-50a0-4a02-9d20-520b59a9f9b3} (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\search toolbar (Adware.Zugo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\ShopperReports3 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\ShopperReports3 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ShopperReportsSA (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.asyncreporter (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.asyncreporter.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.cntntdic (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.cntntdic.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.cntntdisp (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.cntntdisp.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.dwnldr (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.dwnldr.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.hbguru (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.hbguru.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.kopff (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.kopff.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.mozillanvgtntrpr (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.mozillanvgtntrpr.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.mozillapsexecuter (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.mozillapsexecuter.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.reportdata (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.reportdata.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.reporter (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.reporter.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.scopes (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.scopes.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.stock (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.stock.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggerimmidiate (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggerimmidiate.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggerimmidiateorrandomts (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggerimmidiateorrandomts.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggeronceinday (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\shopperreports.triggeronceinday.1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\Pltfrm.DLL (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\mozillaps.dll (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\CmndFF.DLL (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\BRNstIE.DLL (Adware.ClickPotato) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\AppDataLow\HavingFunOnline (Adware.BHO.FL) -> Quarantined and deleted successfully.
C:\Program Files (x86)\Search Toolbar\SearchToolbarUninstall.exe (Adware.Zugo) -> Quarantined and deleted successfully.
C:\Users\marc\Downloads\ApplicationSetup(2).exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\marc\Downloads\ApplicationSetup(3).exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\marc\Downloads\ApplicationSetup(4).exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\marc\Downloads\ApplicationSetup(5).exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\marc\Downloads\ApplicationSetup.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 2:17 am
Hi Marc,
Do you have the OTL fix log? Also, how are things running now?
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 3:10 am
idk i didnt click fix it in otl was i suppose to?
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 3:11 am
Yes. See the first part of Post #8 Smile
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 3:36 am
hey did it and it rebooted and my kaspersky is saying there are still 13 viruses and 2 trojans on my computer? Didnt we delete them or are there still more processes?
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 3:41 am
Can you produce the log or screenshots of the filepaths?
Crush
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 4:06 am
you mean from otl? or what?
marc_army26
OS : window7
# Likes : 0
Post by marc_army26 on Fri Jul 02, 2010 4:09 am
Windows 6.1.7600
7/1/2010 9:12:51 PM
Files Infected: 6
marc_army26
OS : window7
# Likes : 0
Post by Crush on Fri Jul 02, 2010 4:23 am
No, the kaspersky log you were talking about. or screenshots of the screen that says you have viruses
Crush
# Likes : 0
