Need Help with AV Security
Post by greich2 on 26th June 2010, 6:49 pm
I have tried using the guides for AV Security, but keep running into the same problem with internet explorer and firefox. I am not able to download or use OTL, Malwarebytes, or HiJackthis. I even tried to download to a flash drive and it won't let me run any of them. It keeps saying that these are all infected. Please help.
greich2
Posts Posts : 25
Joined Joined : 2010-02-06
OS OS : windows xp
Points Points : 25270
Re: Need Help with AV Security
Post by Sneakyone on 26th June 2010, 6:56 pm
Hello and welcome to GeekPolice.net.
My name is Sneakyone, and I will do my best to help get your problem resolved today.
I am currently a student in GeekPolice Academy, and will be a little delayed on each reply, as my instructors must review and approve each reply.
If you have any questions, please ask, and I will do my best to get to the question promptly.
Please wait here, while I get the first set of instructions for you.
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56114
Post by Sneakyone on 26th June 2010, 7:23 pm
Hi greich2, Smile
My username is Sneakyone and I will be assisting you today on your issue.
Please download and run RKill.
[You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.] - [You must be registered and logged in to see this link.]
  • It will quickly run and launch a log. If it does not launch a log, try another download link until it does.
  • Please post its log in your next reply.
  • After it has run successfully, delete RKill.
Note: This tool only kills the active infection, the actual infection will not be gone. Once you reboot the infection will be active again! Please do not reboot until instructed further to do so.
Download [You must be registered and logged in to see this link.] to your Desktop
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    %SYSTEMDRIVE%\*.exe
    %systemroot%\*. /mp /s
    c:\$recycle.bin\*.* /s
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    nvstor32.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    explorer.exe
    svchost.exe
    userinit.exe
    qmgr.dll
    ws2_32.dll
    proquota.exe
    imm32.dll
    kernel32.dll
    ndis.sys
    autochk.exe
    spoolsv.exe
    xmlprov.dll
    ntmssvc.dll
    mswsock.dll
    Beep.SYS
    ntfs.sys
    termsrv.dll
    sfcfiles.dll
    st3shark.sys
    ahcix86.sys
    srsvc.dll
    nvrd32.sys
    /md5stop
  • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
Sneakyone
Posts Posts : 2707
Post by greich2 on 26th June 2010, 8:03 pm
Here are the logs:
Processes terminated by Rkill or while it was running:
C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg\pfvsljmtssd.exe
C:\Documents and Settings\freich.freich-us\Desktop\rkill.exe
OTL logfile created on: 6/26/2010 3:51:26 PM - Run 4
OTL by OldTimer - Version 3.2.7.0 Folder = C:\Documents and Settings\freich.freich-us\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
2.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 58.00% Memory free
4.00 Gb Paging File | 3.00 Gb Available in Paging File | 85.00% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 20.00 Gb Total Space | 2.82 Gb Free Space | 14.10% Space Free | Partition Type: NTFS
Drive D: | 69.16 Gb Total Space | 64.73 Gb Free Space | 93.59% Space Free | Partition Type: NTFS
Computer Name: freich-us
Current User Name: freich
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: On
Skip Microsoft Files: On
File Age = 90 Days
Output = Standard
Quick Scan
PRC - [2010/06/26 15:50:08 | 000,574,464 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\freich.freich-us\Desktop\OTL.exe
PRC - [2010/06/23 08:30:45 | 000,039,408 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2010/06/02 09:07:27 | 002,065,248 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgtray.exe
PRC - [2010/06/02 09:07:26 | 000,515,424 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgrsx.exe
PRC - [2010/06/02 09:07:25 | 000,620,896 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgnsx.exe
PRC - [2010/06/02 09:07:22 | 002,331,544 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgfws9.exe
PRC - [2010/06/02 09:07:20 | 000,722,784 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgcsrvx.exe
PRC - [2010/06/02 09:07:18 | 001,101,152 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgchsvx.exe
PRC - [2010/03/13 10:54:19 | 000,308,064 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgwdsvc.exe
PRC - [2010/02/08 23:10:14 | 000,788,880 | ---- | M] (Lavasoft) -- C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
PRC - [2010/02/08 23:10:13 | 001,181,328 | ---- | M] (Lavasoft) -- C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
PRC - [2010/01/15 23:09:37 | 000,910,296 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
PRC - [2009/11/10 10:14:38 | 000,443,728 | ---- | M] (LeapFrog Enterprises, Inc.) -- C:\Program Files\LeapFrog\LeapFrog Connect\Monitor.exe
PRC - [2009/11/10 09:28:06 | 001,131,808 | ---- | M] (LeapFrog Enterprises, Inc.) -- C:\Program Files\LeapFrog\LeapFrog Connect\CommandService.exe
PRC - [2009/09/29 09:17:50 | 000,013,088 | ---- | M] (Intuit Inc.) -- C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
PRC - [2008/05/07 05:07:23 | 000,135,168 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\cscript.exe
PRC - [2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2007/07/04 15:41:22 | 000,339,968 | ---- | M] (Western Digital Technologies, Inc.) -- C:\WINDOWS\system32\WDBtnMgr.exe
PRC - [2007/04/17 15:30:58 | 000,960,512 | ---- | M] (Oracle Corporation) -- C:\WINDOWS\ORCLOBI\MyDesktop\MyDesktopService.exe
PRC - [2006/10/18 08:39:00 | 000,286,604 | ---- | M] () -- C:\WINDOWS\ORCLOBI\gdswsuspatch.exe
PRC - [2006/09/11 05:40:34 | 000,086,960 | ---- | M] (Macrovision Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
PRC - [2006/09/11 05:40:32 | 000,218,032 | ---- | M] (Macrovision Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
PRC - [2006/08/01 20:25:16 | 000,622,653 | ---- | M] (Broadcom Corporation.) -- C:\Program Files\ThinkPad\Bluetooth Software\BTTray.exe
PRC - [2006/08/01 20:23:52 | 001,376,340 | ---- | M] (Broadcom Corporation.) -- C:\Program Files\ThinkPad\Bluetooth Software\BTStackServer.exe
PRC - [2006/08/01 20:18:00 | 000,266,295 | ---- | M] (Broadcom Corporation.) -- C:\Program Files\ThinkPad\Bluetooth Software\bin\btwdins.exe
PRC - [2006/05/10 15:03:44 | 000,094,208 | ---- | M] () -- C:\Program Files\Lenovo\PkgMgr\HOTKEY\TPHKMGR.exe
PRC - [2006/04/21 15:14:00 | 000,450,560 | ---- | M] (Oracle) -- C:\WINDOWS\ORCLOBI\MyDesktop\MyDesktopQOS.exe
PRC - [2006/04/20 08:34:26 | 001,520,688 | ---- | M] (Cisco Systems, Inc.) -- c:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
PRC - [2006/03/23 01:10:00 | 000,106,496 | ---- | M] (Lenovo Group Limited) -- C:\Program Files\ThinkVantage\PrdCtr\LPMGR.EXE
PRC - [2006/02/24 02:22:00 | 000,237,568 | ---- | M] (Lenovo Group Limited) -- C:\Program Files\ThinkPad\Utilities\EZEJMNAP.EXE
PRC - [2006/02/14 14:17:28 | 000,110,592 | ---- | M] (Synaptics, Inc.) -- C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
PRC - [2006/01/22 18:30:16 | 000,098,304 | ---- | M] (ArcSoft, Inc.) -- C:\Program Files\My Book\WD Backup\uBBMonitor.exe
PRC - [2005/11/11 01:33:00 | 000,073,782 | ---- | M] () -- C:\WINDOWS\system32\ibmpmsvc.exe
PRC - [2005/11/07 12:14:16 | 000,106,496 | ---- | M] (Lenovo, Ltd. and IBM Corporation.) -- C:\WINDOWS\system32\TpShocks.exe
PRC - [2005/10/26 00:44:30 | 000,086,016 | ---- | M] (Lenovo Group Limited) -- C:\Program Files\Lenovo\PkgMgr\HOTKEY_1\TpScrex.exe
PRC - [2005/08/01 06:10:00 | 000,122,940 | ---- | M] (Sonic Solutions) -- C:\WINDOWS\system32\DLA\DLACTRLW.EXE
PRC - [2005/07/05 14:57:12 | 000,077,824 | ---- | M] () -- C:\Program Files\Lenovo\PkgMgr\HOTKEY\TPONSCR.exe
PRC - [2005/06/20 13:15:00 | 000,077,824 | ---- | M] (Lenovo.) -- C:\WINDOWS\system32\TPHDEXLG.exe
PRC - [2005/06/16 18:23:48 | 000,939,776 | ---- | M] (Zone Labs LLC) -- C:\WINDOWS\system32\ZoneLabs\vsmon.exe
PRC - [2005/06/16 18:15:34 | 000,444,160 | ---- | M] (Zone Labs LLC) -- C:\Program Files\Zone Labs\Integrity Client\iclient.exe
PRC - [2005/05/20 05:11:06 | 000,925,696 | ---- | M] (Analog Devices, Inc.) -- C:\Program Files\Analog Devices\Core\smax4pnp.exe
PRC - [2003/04/08 14:42:28 | 000,135,168 | ---- | M] () -- C:\Program Files\Belkin\F1U201.401\usbshare.exe
PRC - [2001/10/08 13:59:36 | 000,045,632 | ---- | M] () -- C:\WINDOWS\system32\TaskSwitch.exe
MOD - [2010/06/26 15:50:08 | 000,574,464 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\freich.freich-us\Desktop\OTL.exe
MOD - [2008/04/13 20:10:20 | 000,110,592 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msscript.ocx
MOD - [2006/02/14 14:17:12 | 000,065,536 | ---- | M] (Synaptics, Inc.) -- C:\WINDOWS\system32\SynTPFcs.dll
SRV - File not found [Auto | Stopped] -- -- (WMDM PMSP Service)
SRV - File not found [On_Demand | Stopped] -- -- (LiveUpdate)
SRV - [2010/06/02 09:07:22 | 002,331,544 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgfws9.exe -- (avgfws9)
SRV - [2010/03/13 10:54:19 | 000,308,064 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgwdsvc.exe -- (avg9wd)
SRV - [2010/03/13 10:54:13 | 005,888,008 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Stopped] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe -- (AVGIDSAgent)
SRV - [2010/02/08 23:10:13 | 001,181,328 | ---- | M] (Lavasoft) [Auto | Running] -- C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe -- (Lavasoft Ad-Aware Service)
SRV - [2009/11/10 09:28:06 | 001,131,808 | ---- | M] (LeapFrog Enterprises, Inc.) [Auto | Running] -- C:\Program Files\LeapFrog\LeapFrog Connect\CommandService.exe -- (LeapFrog Connect Device Service)
SRV - [2009/09/29 09:17:50 | 000,013,088 | ---- | M] (Intuit Inc.) [Auto | Running] -- C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe -- (IntuitUpdateService)
SRV - [2007/04/17 15:30:58 | 000,960,512 | ---- | M] (Oracle Corporation) [Auto | Running] -- C:\WINDOWS\ORCLOBI\MyDesktop\MyDesktopService.exe -- (MyDesktopWindows)
SRV - [2006/08/01 20:18:00 | 000,266,295 | ---- | M] (Broadcom Corporation.) [Auto | Running] -- C:\Program Files\ThinkPad\Bluetooth Software\bin\btwdins.exe -- (btwdins)
SRV - [2006/04/21 15:14:00 | 000,450,560 | ---- | M] (Oracle) [Auto | Running] -- C:\WINDOWS\ORCLOBI\MyDesktop\MyDesktopQOS.exe -- (QOSMyDesktop)
SRV - [2006/04/20 08:34:26 | 001,520,688 | ---- | M] (Cisco Systems, Inc.) [Auto | Running] -- c:\Program Files\Cisco Systems\VPN Client\cvpnd.exe -- (CVPND)
SRV - [2005/11/11 01:33:00 | 000,073,782 | ---- | M] () [Auto | Running] -- C:\WINDOWS\system32\ibmpmsvc.exe -- (IBMPMSVC)
SRV - [2005/06/20 13:15:00 | 000,077,824 | ---- | M] (Lenovo.) [Auto | Running] -- C:\WINDOWS\system32\TPHDEXLG.exe -- (TPHDEXLGSVC)
SRV - [2005/06/16 18:23:48 | 000,939,776 | ---- | M] (Zone Labs LLC) [Auto | Running] -- C:\WINDOWS\System32\ZONELABS\vsmon.exe -- (vsmon)
DRV - [2010/06/02 09:07:26 | 000,242,896 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2010/06/02 09:07:25 | 000,029,584 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2010/03/13 10:54:15 | 000,122,376 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys -- (AVGIDSDriverxpx)
DRV - [2010/03/13 10:54:15 | 000,030,216 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys -- (AVGIDSFilterxpx)
DRV - [2010/03/13 10:54:15 | 000,026,120 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys -- (AVGIDSShimxpx)
DRV - [2010/03/13 10:54:15 | 000,025,096 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\AVGIDSxx.sys -- (AVGIDSErHrxpx)
DRV - [2010/03/13 10:53:39 | 000,216,200 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2010/03/13 10:53:36 | 000,052,872 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | Boot | Running] -- C:\WINDOWS\System32\Drivers\avgrkx86.sys -- (AvgRkx86)
DRV - [2010/01/02 14:10:44 | 000,030,104 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\avgfwdx.sys -- (Avgfwfd)
DRV - [2010/01/02 14:10:44 | 000,030,104 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\avgfwdx.sys -- (Avgfwdx)
DRV - [2009/12/02 09:19:06 | 000,064,288 | ---- | M] (Lavasoft AB) [File_System | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\Lbd.sys -- (Lbd)
DRV - [2009/11/10 09:27:06 | 000,018,560 | ---- | M] (LeapFrog) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\FlyUsb.sys -- (FlyUsb)
DRV - [2009/05/28 22:23:24 | 004,203,392 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\NETw5x32.sys -- (NETw5x32) Intel(R)
DRV - [2008/04/13 14:54:36 | 000,028,672 | ---- | M] (National Semiconductor Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nscirda.sys -- (NSCIRDA)
DRV - [2008/04/13 14:36:39 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\amdagp.sys -- (amdagp)
DRV - [2008/04/13 14:36:39 | 000,040,960 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\sisagp.sys -- (sisagp)
DRV - [2008/04/13 12:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2007/05/02 11:34:32 | 000,161,792 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\b57xp32.sys -- (b57w2k)
DRV - [2007/02/26 19:59:10 | 005,700,096 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\igxpmp32.sys -- (ialm)
DRV - [2006/12/22 11:56:44 | 000,988,800 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_DPV.sys -- (HSF_DPV)
DRV - [2006/12/22 11:56:00 | 000,209,664 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSFHWAZL.sys -- (HSFHWAZL)
DRV - [2006/12/22 11:55:56 | 000,730,112 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
DRV - [2006/08/01 20:00:34 | 000,851,706 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btkrnl.sys -- (BTKRNL)
DRV - [2006/08/01 19:57:26 | 000,067,384 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btwusb.sys -- (BTWUSB)
DRV - [2006/04/25 20:13:20 | 000,028,800 | ---- | M] (UPEK Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tcusb.sys -- (TcUsb)
DRV - [2006/04/25 20:00:00 | 000,003,456 | ---- | M] (UPEK Inc.) [Kernel | Auto | Running] -- C:\Program Files\ThinkVantage Fingerprint Software\smihlp.sys -- (smihlp)
DRV - [2006/04/20 08:33:40 | 000,303,740 | ---- | M] (Cisco Systems, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\CVPNDRVA.sys -- (CVPNDRVA)
DRV - [2006/03/23 01:13:00 | 000,004,442 | ---- | M] () [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\TPPWRIF.SYS -- (TPPWRIF)
DRV - [2006/02/14 14:04:58 | 000,177,664 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
DRV - [2006/01/31 07:19:34 | 000,176,128 | ---- | M] (Analog Devices, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ADIHdAud.sys -- (ADIHdAudAddService)
DRV - [2006/01/17 01:52:00 | 000,014,848 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\SMAPINT.SYS -- (Smapint)
DRV - [2006/01/17 01:52:00 | 000,009,343 | ---- | M] () [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\TDSMAPI.SYS -- (TDSMAPI)
DRV - [2005/12/06 08:20:48 | 000,192,512 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\hsxhwazl.sys -- (HSXHWAZL)
DRV - [2005/12/04 23:55:30 | 001,428,096 | ---- | M] (Intelģ Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\w39n51.sys -- (w39n51) Intel(R)
DRV - [2005/11/30 16:58:00 | 000,085,760 | ---- | M] (Lenovo) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\shockprf.sys -- (Shockprf)
DRV - [2005/11/30 10:12:36 | 000,162,560 | ---- | M] (Texas Instruments) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tifm21.sys -- (tifm21)
DRV - [2005/11/11 01:33:00 | 000,010,112 | ---- | M] (Lenovo.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ibmpmdrv.sys -- (IBMPMDRV)
DRV - [2005/10/12 09:07:12 | 000,874,240 | ---- | M] (Intel Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\iaStor.sys -- (iaStor)
DRV - [2005/08/18 19:22:30 | 000,110,080 | ---- | M] (Deterministic Networks, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\dne2000.sys -- (DNE)
DRV - [2005/08/01 06:10:00 | 000,092,700 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAUDFAM.SYS -- (DLAUDFAM)
DRV - [2005/08/01 06:10:00 | 000,087,004 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAUDF_M.SYS -- (DLAUDF_M)
DRV - [2005/08/01 06:10:00 | 000,086,524 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAIFS_M.SYS -- (DLAIFS_M)
DRV - [2005/08/01 06:10:00 | 000,025,628 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLABOIOM.SYS -- (DLABOIOM)
DRV - [2005/08/01 06:10:00 | 000,014,684 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAOPIOM.SYS -- (DLAOPIOM)
DRV - [2005/08/01 06:10:00 | 000,006,364 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLAPoolM.SYS -- (DLAPoolM)
DRV - [2005/08/01 06:10:00 | 000,002,496 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\DLA\DLADResN.SYS -- (DLADResN)
DRV - [2005/07/28 04:30:00 | 000,088,704 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\DRVMCDB.SYS -- (DRVMCDB)
DRV - [2005/07/07 10:03:34 | 000,005,628 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\DLACDBHM.SYS -- (DLACDBHM)
DRV - [2005/07/07 10:02:56 | 000,022,684 | ---- | M] (Sonic Solutions) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\DLARTL_N.SYS -- (DLARTL_N)
DRV - [2005/07/07 06:10:00 | 000,040,544 | ---- | M] (Sonic Solutions) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\DRVNDDM.SYS -- (DRVNDDM)
DRV - [2005/07/05 14:57:06 | 000,017,699 | ---- | M] (IBM Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\TPHKDRV.sys -- (TPHKDRV)
DRV - [2005/06/20 13:18:00 | 000,004,736 | ---- | M] (Lenovo.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ShockMgr.sys -- (ShockMgr)
DRV - [2005/06/16 18:23:36 | 000,203,272 | ---- | M] (Zone Labs LLC) [Kernel | Auto | Running] -- C:\WINDOWS\system32\vsdatant.sys -- (vsdatant)
DRV - [2005/05/17 07:20:06 | 000,015,872 | ---- | M] (Atmel, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\atmeltpm.sys -- (atmeltpm)
DRV - [2005/05/17 04:51:34 | 000,005,315 | ---- | M] (Cisco Systems, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\CVirtA.sys -- (CVirtA)
DRV - [2005/02/23 14:58:56 | 000,011,776 | ---- | M] (Arcsoft, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\afc.sys -- (Afc)
DRV - [2004/03/05 13:52:22 | 000,008,368 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\awechomd.sys -- (awecho)
DRV - [2003/11/17 19:06:48 | 000,011,165 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\awlegacy.sys -- (awlegacy)
DRV - [2003/10/23 10:32:20 | 000,016,984 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\AW_HOST5.sys -- (AW_HOST)
DRV - [2003/04/21 13:00:32 | 000,013,898 | ---- | M] (Symantec Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\GERNUWA.sys -- (Gernuwa)
DRV - [2001/08/17 15:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\sparrow.sys -- (Sparrow)
DRV - [2001/08/17 15:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\sym_u3.sys -- (sym_u3)
DRV - [2001/08/17 15:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\sym_hi.sys -- (sym_hi)
DRV - [2001/08/17 15:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\symc8xx.sys -- (symc8xx)
DRV - [2001/08/17 15:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\symc810.sys -- (symc810)
DRV - [2001/08/17 14:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\ultra.sys -- (ultra)
DRV - [2001/08/17 14:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\ql12160.sys -- (ql12160)
DRV - [2001/08/17 14:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\ql1080.sys -- (ql1080)
DRV - [2001/08/17 14:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\ql1280.sys -- (ql1280)
DRV - [2001/08/17 14:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\dac2w2k.sys -- (dac2w2k)
DRV - [2001/08/17 14:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\mraid35x.sys -- (mraid35x)
DRV - [2001/08/17 14:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\asc.sys -- (asc)
DRV - [2001/08/17 14:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\asc3550.sys -- (asc3550)
DRV - [2001/08/17 14:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\aliide.sys -- (AliIde)
DRV - [2001/08/17 14:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\cmdide.sys -- (CmdIde)
DRV - [2000/09/01 09:11:06 | 000,007,012 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Stopped] -- C:\WINDOWS\system32\drivers\PMEMNT.SYS -- (PMEMNT)
IE - HKCU\..\URLSearchHook: *{CFBFAE00-17A6-11D0-99CB-00C04FD64497} - Reg Error: Key error. File not found
IE - HKCU\..\URLSearchHook: {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll ()
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:5577
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Yahoo! Search"
FF - prefs.js..browser.search.selectedEngine: "Yahoo! Search"
FF - prefs.js..browser.startup.homepage: "http://my.oracle.com"
FF - prefs.js..extensions.enabledItems: {3f963a5b-e555-4543-90e2-c3908898db71}:9.0.0.825
FF - prefs.js..extensions.enabledItems: avg@igeared:4.504.019.002
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:1.01
FF - prefs.js..network.proxy.autoconfig_url: "http://wpad/wpad.dat"
FF - HKLM\software\mozilla\Firefox\Extensions\\{3f963a5b-e555-4543-90e2-c3908898db71}: C:\Program Files\AVG\AVG9\Firefox [2010/06/02 15:08:13 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\avg@igeared: C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared [2010/06/26 14:49:36 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/02/06 15:42:49 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/06/24 10:50:51 | 000,000,000 | ---D | M]
[2010/02/06 15:43:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Mozilla\Extensions
[2010/06/26 15:42:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Mozilla\Firefox\Profiles\b6at4lbb.default\extensions
[2010/02/06 15:43:01 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\freich.freich-us\Application Data\Mozilla\Firefox\Profiles\b6at4lbb.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2010/02/06 15:43:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Mozilla\Firefox\Profiles\b6at4lbb.default\extensions\fsonlinescanner@f-secure.com
[2010/02/06 15:43:01 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
O1 HOSTS File: ([2001/08/23 13:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (Adobe PDF Reader Link Helper) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll (AVG Technologies CZ, s.r.o.)
O2 - BHO: (Java(tm) Plug-In SSV Helper) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (AVG Security Toolbar) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll ()
O3 - HKCU\..\Toolbar\WebBrowser: (AVG Security Toolbar) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll ()
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [AVG9_TRAY] C:\Program Files\AVG\AVG9\avgtray.exe (AVG Technologies CZ, s.r.o.)
O4 - HKLM..\Run: [BLOG] C:\Program Files\ThinkPad\Utilities\BATLOGEX.DLL ()
O4 - HKLM..\Run: [CoolSwitch] C:\WINDOWS\system32\TaskSwitch.exe ()
O4 - HKLM..\Run: [DLA] C:\WINDOWS\system32\DLA\DLACTRLW.EXE (Sonic Solutions)
O4 - HKLM..\Run: [EZEJMNAP] C:\Program Files\ThinkPad\Utilities\EZEJMNAP.EXE (Lenovo Group Limited)
O4 - HKLM..\Run: [hfrplqrx] C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg\pfvsljmtssd.exe ()
O4 - HKLM..\Run: [IMEKRMIG6.1] C:\WINDOWS\ime\imkr6_1\imekrmig.exe (Microsoft Corporation)
O4 - HKLM..\Run: [IMJPMIG8.1] C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [ISUSPM Startup] c:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe (Macrovision Corporation)
O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (Macrovision Corporation)
O4 - HKLM..\Run: [KernelFaultCheck] File not found
O4 - HKLM..\Run: [LPManager] C:\Program Files\ThinkVantage\PrdCtr\LPMGR.EXE (Lenovo Group Limited)
O4 - HKLM..\Run: [Monitor] C:\Program Files\LeapFrog\LeapFrog Connect\Monitor.exe (LeapFrog Enterprises, Inc.)
O4 - HKLM..\Run: [MSPY2002] C:\WINDOWS\System32\IME\PINTLGNT\ImScInst.exe ()
O4 - HKLM..\Run: [ntpgds] C:\WINDOWS\ORCLOBI\synctime.exe ()
O4 - HKLM..\Run: [PHIME2002A] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [PHIME2002ASync] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [PWRMGRTR] C:\Program Files\ThinkPad\Utilities\PWRMGRTR.DLL (Lenovo Group Limited)
O4 - HKLM..\Run: [RoxWatchTray] C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe (Sonic Solutions)
O4 - HKLM..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe (Analog Devices, Inc.)
O4 - HKLM..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe (Synaptics, Inc.)
O4 - HKLM..\Run: [TPHOTKEY] C:\Program Files\Lenovo\PkgMgr\HOTKEY\TPHKMGR.exe ()
O4 - HKLM..\Run: [TpShocks] C:\WINDOWS\System32\TpShocks.exe (Lenovo, Ltd. and IBM Corporation.)
O4 - HKLM..\Run: [TweakAutomaticUpdates] C:\WINDOWS\orclobi\gdswsuspatch_soon.exe ()
O4 - HKLM..\Run: [WD Button Manager] C:\WINDOWS\System32\WDBtnMgr.exe (Western Digital Technologies, Inc.)
O4 - HKLM..\Run: [Zone Labs Client] C:\Program Files\Zone Labs\Integrity Client\iclient.exe (Zone Labs LLC)
O4 - HKCU..\Run: [hfrplqrx] C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg\pfvsljmtssd.exe ()
O4 - HKCU..\Run: [ISUSPM] C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe (Macrovision Corporation)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe (Adobe Systems Incorporated)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk = C:\Program Files\ThinkPad\Bluetooth Software\BTTray.exe (Broadcom Corporation.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\F1U201.401.lnk = C:\Program Files\Belkin\F1U201.401\usbshare.exe ()
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Office OneNote 2003 Quick Launch.lnk = C:\Program Files\microsoft office\OFFICE11\ONENOTEM.EXE (Microsoft Corporation)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\VPN Client.lnk = c:\WINDOWS\Installer\{D25122BC-A60E-4663-B602-B01718F12044}\Icon3E5562ED7.ico ()
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\WD Backup Monitor.lnk = C:\Program Files\My Book\WD Backup\uBBMonitor.exe (ArcSoft, Inc.)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll (Google Inc.)
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\ThinkPad\Bluetooth Software\btsendto_ie_ctx.htm ()
O9 - Extra Button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\ThinkPad\Bluetooth Software\btsendto_ie.htm ()
O9 - Extra 'Tools' menuitem : @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\ThinkPad\Bluetooth Software\btsendto_ie.htm ()
O15 - HKCU\..Trusted Domains: intuit.com ([ttlc] https in Trusted sites)
O15 - HKCU\..Trusted Domains: oraclecorp.com ([global-service] https in Trusted sites)
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} [You must be registered and logged in to see this link.] (QuickTime Plugin Control)
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} [You must be registered and logged in to see this link.] (WUWebControl Class)
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_18)
O16 - DPF: {CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.5.0_08)
O16 - DPF: {CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_18)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_18)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = us.oracle.com
O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll (AVG Technologies CZ, s.r.o.)
O20 - HKLM Winlogon: GinaDLL - (vrlogon.dll) - C:\WINDOWS\System32\vrlogon.dll (UPEK Inc.)
O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\WINDOWS\System32\igfxdev.dll (Intel Corporation)
O20 - Winlogon\Notify\PCANotify: DllName - PCANotify.dll - C:\WINDOWS\System32\PCANotify.dll (Symantec Corporation)
O20 - Winlogon\Notify\psfus: DllName - psqlpwd.dll - C:\WINDOWS\System32\psqlpwd.dll (UPEK Inc.)
O20 - Winlogon\Notify\tpfnf2: DllName - notifyf2.dll - C:\WINDOWS\System32\notifyf2.dll ()
O20 - Winlogon\Notify\tphotkey: DllName - tphklock.dll - C:\WINDOWS\System32\tphklock.dll ()
O24 - Desktop WallPaper: C:\Documents and Settings\freich.freich-us\My Documents\My Pictures\plasma.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\freich.freich-us\My Documents\My Pictures\plasma.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2003/02/04 10:52:28 | 000,000,000 | -HS- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O34 - HKLM BootExecute: (lsdelete) - C:\WINDOWS\System32\lsdelete.exe ()
NetSvcs: 6to4 - File not found
NetSvcs: Ias - C:\WINDOWS\system32\ias [2003/02/04 10:44:54 | 000,000,000 | ---D | M]
NetSvcs: Iprip - File not found
MsConfig - Services: "ERSvc"
MsConfig - State: "system.ini" - 0
MsConfig - State: "win.ini" - 0
MsConfig - State: "bootini" - 0
MsConfig - State: "services" - 2
MsConfig - State: "startup" - 0
SafeBootMin: Lavasoft Ad-Aware Service - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe (Lavasoft)
SafeBootMin: sermouse.sys - Driver
SafeBootMin: vds - Service
SafeBootMin: vga.sys - Driver
SafeBootMin: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootNet: Lavasoft Ad-Aware Service - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe (Lavasoft)
SafeBootNet: sermouse.sys - Driver
SafeBootNet: UploadMgr - Service
SafeBootNet: vga.sys - Driver
ActiveX: {03F998B2-0E00-11D3-A498-00104B6EB52E} - Viewpoint Media Player
ActiveX: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} - Java (Sun)
ActiveX: {0fde1f56-0d59-4fd7-9624-e3df6b419d0e} - Internet Explorer ReadMe
ActiveX: {0fde1f56-0d59-4fd7-9624-e3df6b419d0f} - IEEX
ActiveX: {10072CEC-8CC1-11D1-986E-00A0C955B42F} - Vector Graphics Rendering (VML)
ActiveX: {1B00725B-C455-4DE6-BFB6-AD540AD427CD} - Viewpoint Media Player
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} - NetShow
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - Microsoft Windows Media Player 6.4
ActiveX: {283807B5-2C60-11D0-A31D-00AA00B92C03} - DirectAnimation
ActiveX: {2A3320D6-C805-4280-B423-B665BDE33D8F} - Microsoft .NET Framework 1.1 Security Update (KB979906)
ActiveX: {36f8ec70-c29a-11d1-b5c7-0000f8051515} - Dynamic HTML Data Binding for Java
ActiveX: {3bf42070-b3b1-11d1-b5c5-0000f8051515} - Uniscribe
ActiveX: {411EDCF7-755D-414E-A74B-3DCD6583F589} - Microsoft .NET Framework 1.1 Service Pack 1 (KB867460)
ActiveX: {4278c270-a269-11d1-b5bf-0000f8051515} - Advanced Authoring
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
ActiveX: {44BBA842-CC51-11CF-AAFA-00AA00B6015B} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} - DirectShow
ActiveX: {4f216970-c90c-11d1-b5c7-0000f8051515} - DirectAnimation Java Classes
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows script 5.8
ActiveX: {5056b317-8d4c-43ee-8543-b9d1e234b8f4} - Security Update for Windows XP (KB923789)
ActiveX: {5945c046-1e7d-11d1-bc44-00c04fd912be} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
ActiveX: {5A8D6EE0-3E18-11D0-821E-444553540000} - ICW
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - Microsoft Windows Media Player
ActiveX: {7131646D-CD3C-40F4-97B9-CD9E4E6262EF} - .NET Framework
ActiveX: {73FA19D0-2D75-11D2-995D-00C04F98BBC9} - Web Folders
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - C:\WINDOWS\system32\Rundll32.exe C:\WINDOWS\system32\mscories.dll,Install
ActiveX: {C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F} - .NET Framework
ActiveX: {CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1} - .NET Framework
ActiveX: {CC2A9BA0-3BDD-11D0-821E-444553540000} - Task Scheduler
ActiveX: {D27CDB6E-AE6D-11cf-96B8-444553540000} - Adobe Flash Player
ActiveX: {ECD292A0-0347-4244-8C24-5DBCE990FB40} - Hotfix for Microsoft .NET Framework 3.0 (KB932471)
ActiveX: {EF289A85-8E57-408d-BE47-73B55609861A} - RootsUpdate
ActiveX: <{12d0ed0d-0ee0-4f90-8827-78cefb8f4988} - C:\WINDOWS\system32\ieudinit.exe
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\WINDOWS\inf\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{531CA1D4-0CCC-4DD1-BB14-A6CD06571525} - RunDLL32 IEDKCS32.DLL,BrandIE4 CUSTOM
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - "C:\WINDOWS\system32\rundll32.exe" "C:\WINDOWS\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
ActiveX: >{881dd1c5-3dcf-431b-b061-f3f88e8be88a} - %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
ActiveX: Microsoft Base Smart Card Crypto Provider Package -
Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
========== Files/Folders - Created Within 90 Days ==========
[2010/06/26 15:50:16 | 000,574,464 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\freich.freich-us\Desktop\OTL.exe
[2010/06/26 14:42:34 | 000,401,720 | ---- | C] (Trend Micro Inc.) -- C:\Documents and Settings\freich.freich-us\Desktop\HiJackThis.exe
[2010/06/26 12:47:55 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg
[2010/06/25 01:01:32 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\freich.freich-us\Recent
[2010/06/24 09:40:20 | 000,000,000 | ---D | C] -- C:\Program Files\QuickTime
[2010/06/23 08:30:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Google
[2010/05/15 13:49:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Bluetooth Software
[2010/05/15 13:49:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\My Documents\Bluetooth Exchange Folder
[2010/04/25 16:25:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\My Documents\TurboTax
[2010/04/25 16:25:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\Intuit
[2010/04/25 16:14:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Application Data\Intuit
[2010/04/25 16:14:25 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\AnswerWorks 5.0
[2010/04/25 16:08:33 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\IsolatedStorage
[2010/04/25 16:08:30 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Intuit
[2010/04/24 21:26:49 | 000,000,000 | ---D | C] -- C:\Program Files\TurboTax
[2010/04/24 21:26:13 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Intuit
[2010/04/07 13:34:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\Temp
[2010/04/07 12:34:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Google
[2010/04/07 12:29:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Google
[4 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
========== Files - Modified Within 90 Days ==========
[2010/06/26 15:46:11 | 000,525,770 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
[2010/06/26 15:46:11 | 000,444,596 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2010/06/26 15:46:11 | 000,072,306 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2010/06/26 15:45:25 | 000,363,520 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Desktop\rkill.exe
[2010/06/26 15:44:24 | 000,363,520 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Desktop\rkill.com
[2010/06/26 15:44:00 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/06/26 15:42:27 | 000,000,579 | -H-- | M] () -- C:\WINDOWS\System32\vsconfig.xml
[2010/06/26 15:42:22 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/06/26 15:42:02 | 000,002,447 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\VPN Client.lnk
[2010/06/26 15:41:54 | 000,000,300 | ---- | M] () -- C:\WINDOWS\tasks\PMTask.job
[2010/06/26 15:41:53 | 000,004,212 | -H-- | M] () -- C:\WINDOWS\System32\zllictbl.dat
[2010/06/26 15:41:44 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/06/26 15:41:22 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/06/26 15:41:18 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/06/26 15:41:17 | 2137,509,888 | -HS- | M] () -- C:\hiberfil.sys
[2010/06/26 14:50:02 | 004,718,592 | -H-- | M] () -- C:\Documents and Settings\freich.freich-us\ntuser.dat
[2010/06/26 14:50:02 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\freich.freich-us\ntuser.ini
[2010/06/26 14:42:29 | 000,401,720 | ---- | M] (Trend Micro Inc.) -- C:\Documents and Settings\freich.freich-us\Desktop\HiJackThis.exe
[2010/06/26 14:10:57 | 000,000,714 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Application Data\Microsoft\Internet Explorer\Quick Launch\Malwarebytes' Anti-Malware.lnk
[2010/06/26 14:10:57 | 000,000,696 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/06/26 10:38:07 | 061,420,629 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
[2010/06/25 18:51:07 | 000,599,358 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\iavifw.avm
[2010/06/25 01:02:17 | 000,000,312 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_010215.reg
[2010/06/25 01:02:02 | 000,042,722 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_010155.reg
[2010/06/25 00:59:14 | 000,000,020 | ---- | M] () -- C:\WINDOWS\Hposcv07.INI
[2010/06/25 00:55:19 | 000,000,312 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005516.reg
[2010/06/25 00:55:05 | 000,000,596 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005500.reg
[2010/06/25 00:54:48 | 000,001,842 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005443.reg
[2010/06/25 00:54:20 | 000,188,458 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005402.reg
[2010/06/25 00:42:19 | 000,000,682 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Desktop\CCleaner.lnk
[2010/06/23 23:42:08 | 000,034,284 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Desktop\billm.jpg
[2010/06/22 09:27:24 | 000,322,728 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2010/06/21 22:49:21 | 000,000,792 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Application Data\Microsoft\Internet Explorer\Quick Launch\Launch Microsoft Office Outlook.lnk
[2010/06/21 21:36:03 | 000,000,863 | ---- | M] () -- C:\WINDOWS\win.ini
[2010/06/08 10:28:27 | 000,056,050 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Desktop\Fax Message.tif
[2010/06/02 09:07:26 | 000,242,896 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/06/02 09:07:25 | 000,029,584 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/05/08 16:34:53 | 000,000,256 | ---- | M] () -- C:\WINDOWS\System32\pool.bin
[2010/05/08 16:34:33 | 002,594,724 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\ChristopherBackup-(2010-05-08).ipd
[2010/05/08 16:31:51 | 000,000,000 | -H-- | M] () -- C:\WINDOWS\System32\drivers\UMDF\Msft_User_WpdMtpDr_01_00_00.Wdf
[2010/05/08 16:29:49 | 001,326,107 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\GregBackup-(2010-05-08).ipd
[2010/05/08 16:28:40 | 000,439,121 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\KatieBackup-(2010-05-08).ipd
[2010/05/02 17:53:17 | 000,000,049 | ---- | M] () -- C:\WINDOWS\cdplayer.ini
[2010/04/28 22:44:45 | 000,000,815 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\Application Data\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk
[2010/04/28 22:35:47 | 000,002,521 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Microsoft Office Outlook 2003.lnk
[2010/04/28 00:29:16 | 000,000,376 | ---- | M] () -- C:\WINDOWS\ODBC.INI
[2010/04/25 16:24:39 | 000,002,393 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\TurboTax 2009.lnk
[2010/04/25 16:21:10 | 004,838,440 | -H-- | M] () -- C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\IconCache.db
[2010/04/10 17:36:40 | 007,732,773 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\St. Pauls bball diamond-carter.JPG
[2010/04/10 17:33:00 | 003,668,053 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\St Paul's bball Diamond 3.jpg
[2010/04/10 17:33:00 | 003,629,742 | ---- | M] () -- C:\Documents and Settings\freich.freich-us\My Documents\St. Paul's Baseball Diamond 1.jpg
[2010/04/02 20:21:18 | 000,000,054 | ---- | M] () -- C:\WINDOWS\System32\rp_stats.dat
[2010/04/02 20:21:18 | 000,000,039 | ---- | M] () -- C:\WINDOWS\System32\rp_rules.dat
[2010/06/26 15:45:29 | 000,363,520 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Desktop\rkill.exe
[2010/06/26 15:44:39 | 000,363,520 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Desktop\rkill.com
[2010/06/26 14:10:57 | 000,000,714 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Application Data\Microsoft\Internet Explorer\Quick Launch\Malwarebytes' Anti-Malware.lnk
[2010/06/25 01:02:16 | 000,000,312 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_010215.reg
[2010/06/25 01:01:57 | 000,042,722 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_010155.reg
[2010/06/25 00:55:18 | 000,000,312 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005516.reg
[2010/06/25 00:55:01 | 000,000,596 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005500.reg
[2010/06/25 00:54:45 | 000,001,842 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005443.reg
[2010/06/25 00:54:11 | 000,188,458 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\cc_20100625_005402.reg
[2010/06/25 00:42:19 | 000,000,682 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Desktop\CCleaner.lnk
[2010/06/23 23:42:40 | 000,034,284 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Desktop\billm.jpg
[2010/06/08 10:28:36 | 000,056,050 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\Desktop\Fax Message.tif
[2010/05/08 16:34:33 | 002,594,724 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\ChristopherBackup-(2010-05-08).ipd
[2010/05/08 16:29:49 | 001,326,107 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\GregBackup-(2010-05-08).ipd
[2010/05/08 16:28:40 | 000,439,121 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\KatieBackup-(2010-05-08).ipd
[2010/05/02 17:53:16 | 000,000,049 | ---- | C] () -- C:\WINDOWS\cdplayer.ini
[2010/04/25 16:11:40 | 000,002,393 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\TurboTax 2009.lnk
[2010/04/10 17:36:38 | 007,732,773 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\St. Pauls bball diamond-carter.JPG
[2010/04/10 17:33:00 | 003,668,053 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\St Paul's bball Diamond 3.jpg
[2010/04/10 17:33:00 | 003,629,742 | ---- | C] () -- C:\Documents and Settings\freich.freich-us\My Documents\St. Paul's Baseball Diamond 1.jpg
[2010/04/07 12:29:48 | 000,000,886 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/04/07 12:29:47 | 000,000,882 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/04/02 20:21:18 | 000,000,054 | ---- | C] () -- C:\WINDOWS\System32\rp_stats.dat
[2010/04/02 20:21:18 | 000,000,039 | ---- | C] () -- C:\WINDOWS\System32\rp_rules.dat
[2010/03/23 13:39:55 | 000,000,110 | ---- | C] () -- C:\WINDOWS\{7E7D778E-121D-4BBD-BA29-FAA81B9FBD8C}_WiseFW.ini
[2009/08/03 16:07:42 | 000,403,816 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.dll
[2009/07/09 20:31:57 | 000,000,000 | ---- | C] () -- C:\WINDOWS\iPlayer.INI
[2007/07/10 08:53:56 | 000,002,723 | ---- | C] () -- C:\WINDOWS\DevMgr.ini
[2007/07/03 20:19:40 | 000,000,020 | ---- | C] () -- C:\WINDOWS\Hposcv07.INI
[2007/03/21 14:03:10 | 000,000,175 | ---- | C] () -- C:\WINDOWS\wininit.ini
[2007/03/21 14:00:47 | 000,077,824 | ---- | C] () -- C:\WINDOWS\System32\SynTPCoI.dll
[2007/03/21 14:00:38 | 000,009,343 | ---- | C] () -- C:\WINDOWS\System32\drivers\TDSMAPI.SYS
[2007/03/21 14:00:29 | 000,004,442 | ---- | C] () -- C:\WINDOWS\System32\drivers\TPPWRIF.SYS
[2007/03/21 13:59:49 | 000,028,672 | ---- | C] () -- C:\WINDOWS\System32\notifyf2.dll
[2007/03/21 13:59:49 | 000,024,576 | ---- | C] () -- C:\WINDOWS\System32\tphklock.dll
[2007/03/21 10:10:03 | 000,000,227 | ---- | C] () -- C:\WINDOWS\BJLOG.INI
[2007/02/26 20:34:34 | 000,204,800 | ---- | C] () -- C:\WINDOWS\System32\igfxCoIn_v4785.dll
[2006/11/09 14:03:52 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2006/11/06 21:42:46 | 000,001,212 | ---- | C] () -- C:\WINDOWS\System32\oeminfo.ini
[2006/11/06 19:28:27 | 000,000,000 | ---- | C] () -- C:\WINDOWS\vpc32.INI
[2006/11/06 19:25:38 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\wisemsg.dll
[2006/11/06 19:16:55 | 000,176,235 | ---- | C] () -- C:\WINDOWS\System32\Primomonnt.dll
[2006/11/06 19:16:55 | 000,000,129 | ---- | C] () -- C:\WINDOWS\primopdf.ini
[2006/11/06 17:19:42 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2006/11/06 17:19:42 | 000,000,063 | ---- | C] () -- C:\WINDOWS\mdm.ini
[2006/11/06 17:19:37 | 000,000,000 | ---- | C] () -- C:\WINDOWS\NSREX.INI
[2006/08/01 20:13:02 | 000,090,112 | ---- | C] () -- C:\WINDOWS\System32\btprn2k.dll
[2006/04/20 08:34:38 | 000,197,680 | ---- | C] () -- C:\WINDOWS\System32\vpnapi.dll
[2006/04/20 08:34:24 | 000,193,584 | ---- | C] () -- C:\WINDOWS\System32\CSGina.dll
[2006/01/30 11:54:28 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
[2005/09/06 11:05:46 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
[2005/02/17 13:41:32 | 000,000,603 | ---- | C] () -- C:\WINDOWS\System32\BTNeighborhood.dll.manifest
[2005/02/17 13:41:30 | 000,000,593 | ---- | C] () -- C:\WINDOWS\System32\btcss.dll.manifest
[2003/01/31 09:49:26 | 000,009,785 | ---- | C] () -- C:\WINDOWS\System32\drivers\a312.sys
[2003/01/07 15:05:08 | 000,002,695 | ---- | C] () -- C:\WINDOWS\System32\OUTLPERF.INI
[2001/11/14 14:56:00 | 001,802,240 | ---- | C] () -- C:\WINDOWS\System32\lcppn21.dll
[2010/02/06 13:23:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar
[2010/01/02 14:10:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\avg9
[2010/03/23 13:38:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Leapfrog
[2010/02/07 10:38:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
[2007/07/03 16:00:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
[2010/01/02 19:54:49 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{BC9FCCF7-E686-494B-8C9B-55C9A39A7CA9}
[2010/06/25 00:58:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Aim
[2010/02/02 01:15:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\AVG9
[2006/11/06 18:50:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Oracle
[2006/11/06 19:32:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Oracle RTC Messenger
[2010/02/19 02:28:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Research In Motion
[2006/11/06 16:39:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\freich.freich-us\Application Data\Thunderbird
[2010/06/26 15:41:54 | 000,000,300 | ---- | M] () -- C:\WINDOWS\Tasks\PMTask.job
greich2
Posts Posts : 25
Joined Joined : 2010-02-06
OS OS : windows xp
Points Points : 25270
Re: Need Help with AV Security
Post by greich2 on 26th June 2010, 8:04 pm
here is the second part of the log.
< %SYSTEMDRIVE%\*.exe >
< %systemroot%\*. /mp /s >
< c:\$recycle.bin\*.* /s >
< MD5 for: AGP440.SYS >
[2004/08/04 02:05:44 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp2.cab:AGP440.sys
[2009/10/26 00:55:45 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:AGP440.sys
[2004/08/04 02:05:44 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp2.cab:AGP440.sys
[2009/10/26 00:55:45 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:AGP440.sys
[2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\ServicePackFiles\i386\agp440.sys
[2008/04/13 14:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\system32\drivers\agp440.sys
[2004/08/04 00:07:42 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=2C428FA0C3E3A01ED93C9B2A27D8D4BB -- C:\WINDOWS\$NtServicePackUninstall$\agp440.sys
[2004/10/19 14:43:34 | 000,020,656 | ---- | M] (Microsoft Corporation) MD5=EF0B06C91C81FB3AF3D31CF9EA5B2591 -- C:\Drivers\System\intl_chp\agp440.sys
< MD5 for: ATAPI.SYS >
[2004/08/04 02:05:44 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp2.cab:atapi.sys
[2009/10/26 00:55:45 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:atapi.sys
[2004/08/04 02:05:44 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp2.cab:atapi.sys
[2009/10/26 00:55:45 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:atapi.sys
[2008/04/13 14:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\ServicePackFiles\i386\atapi.sys
[2008/04/13 14:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\drivers\atapi.sys
[2004/10/19 14:43:36 | 000,086,656 | ---- | M] (Microsoft Corporation) MD5=A64013E98426E1877CB653685C5C0009 -- C:\Drivers\System\intl_chp\atapi.sys
[2004/08/03 23:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\$NtServicePackUninstall$\atapi.sys
[2004/08/03 23:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\system32\ReinstallBackups\0026\DriverFiles\i386\atapi.sys
< MD5 for: AUTOCHK.EXE >
[2008/04/13 20:12:12 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=23043C91A0F9DFB4B9E9F87B680863B4 -- C:\WINDOWS\ServicePackFiles\i386\autochk.exe
[2008/04/13 20:12:12 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=23043C91A0F9DFB4B9E9F87B680863B4 -- C:\WINDOWS\system32\autochk.exe
[2001/08/23 05:00:00 | 000,565,760 | R--- | M] (Microsoft Corporation) MD5=AE06F7BB251869EDBC9F50A36949A2E3 -- C:\cmdcons\autochk.exe
[2004/08/04 01:56:48 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=B3415B9D6026F65E43089ABED096C38C -- C:\WINDOWS\$NtServicePackUninstall$\autochk.exe
< MD5 for: BEEP.SYS >
[2001/08/23 13:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) MD5=DA1F27D85E0D1525F6621372E7B685E9 -- C:\WINDOWS\system32\dllcache\beep.sys
[2001/08/23 13:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) MD5=DA1F27D85E0D1525F6621372E7B685E9 -- C:\WINDOWS\system32\drivers\beep.sys
< MD5 for: EVENTLOG.DLL >
[2008/04/13 20:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\ServicePackFiles\i386\eventlog.dll
[2008/04/13 20:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\system32\eventlog.dll
[2006/04/25 20:23:46 | 000,023,552 | ---- | M] (UPEK Inc.) MD5=74380577CA44A5CA3D8C9C88BAC79931 -- C:\Program Files\ThinkVantage Fingerprint Software\eventlog.dll
[2004/08/04 01:56:44 | 000,055,808 | ---- | M] (Microsoft Corporation) MD5=82B24CB70E5944E6E34662205A2A5B78 -- C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll
< MD5 for: EXPLORER.EXE >
[2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\explorer.exe
[2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\ServicePackFiles\i386\explorer.exe
[2004/08/04 01:56:50 | 001,032,192 | ---- | M] (Microsoft Corporation) MD5=A0732187050030AE399B241436565E64 -- C:\WINDOWS\$NtServicePackUninstall$\explorer.exe
< MD5 for: IASTOR.SYS >
[2005/10/12 09:07:12 | 000,874,240 | ---- | M] (Intel Corporation) MD5=309C4D86D989FB1FCF64BD30DC81C51B -- C:\Drivers\Misc\sata_hdd\iastor.sys
[2005/10/12 09:07:12 | 000,874,240 | ---- | M] (Intel Corporation) MD5=309C4D86D989FB1FCF64BD30DC81C51B -- C:\WINDOWS\system32\drivers\iaStor.sys
[2005/10/12 09:07:12 | 000,874,240 | ---- | M] (Intel Corporation) MD5=309C4D86D989FB1FCF64BD30DC81C51B -- C:\WINDOWS\system32\ReinstallBackups\0015\DriverFiles\iaStor.sys
< MD5 for: IMM32.DLL >
[2008/04/13 20:11:54 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=0DA85218E92526972A821587E6A8BF8F -- C:\WINDOWS\ServicePackFiles\i386\imm32.dll
[2008/04/13 20:11:54 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=0DA85218E92526972A821587E6A8BF8F -- C:\WINDOWS\system32\imm32.dll
[2004/08/04 01:56:44 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=87CA7CE6469577F059297B9D6556D66D -- C:\WINDOWS\$NtServicePackUninstall$\imm32.dll
< MD5 for: KERNEL32.DLL >
[2007/04/16 12:07:27 | 000,986,112 | ---- | M] (Microsoft Corporation) MD5=09F7CB3687F86EDAA4CA081F7AB66C03 -- C:\WINDOWS\$hf_mig$\KB935839\SP2QFE\kernel32.dll
[2006/07/05 03:57:10 | 000,985,088 | ---- | M] (Microsoft Corporation) MD5=0FDD84928A5DDE2510761B7EC76CCEC9 -- C:\WINDOWS\$hf_mig$\KB917422\SP2QFE\kernel32.dll
[2006/07/05 03:57:10 | 000,985,088 | ---- | M] (Microsoft Corporation) MD5=0FDD84928A5DDE2510761B7EC76CCEC9 -- C:\WINDOWS\SoftwareDistribution\Download\040e86cafc583a58922d9f353b3a41cf\SP2QFE\kernel32.dll
[2006/07/05 03:46:36 | 000,928,768 | ---- | M] (Microsoft Corporation) MD5=7815BF93413A3E504DAC1676BDE2D78F -- C:\WINDOWS\SoftwareDistribution\Download\040e86cafc583a58922d9f353b3a41cf\SP1QFE\kernel32.dll
[2007/04/16 11:52:53 | 000,984,576 | ---- | M] (Microsoft Corporation) MD5=A01F9CA902A88F7CED06884174D6419D -- C:\WINDOWS\$NtServicePackUninstall$\kernel32.dll
[2009/03/21 10:06:58 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=B921FB870C9AC0D509B2CCABBBBE95F3 -- C:\WINDOWS\system32\dllcache\kernel32.dll
[2009/03/21 10:06:58 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=B921FB870C9AC0D509B2CCABBBBE95F3 -- C:\WINDOWS\system32\kernel32.dll
[2008/04/13 20:11:56 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=C24B983D211C34DA8FCC1AC38477971D -- C:\WINDOWS\$NtUninstallKB959426$\kernel32.dll
[2008/04/13 20:11:56 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=C24B983D211C34DA8FCC1AC38477971D -- C:\WINDOWS\ServicePackFiles\i386\kernel32.dll
[2006/07/05 03:55:02 | 000,984,064 | ---- | M] (Microsoft Corporation) MD5=D8DB5397DE07577C1CB50BA6D23B3AD4 -- C:\WINDOWS\$NtUninstallKB935839$\kernel32.dll
[2006/07/05 03:55:02 | 000,984,064 | ---- | M] (Microsoft Corporation) MD5=D8DB5397DE07577C1CB50BA6D23B3AD4 -- C:\WINDOWS\SoftwareDistribution\Download\040e86cafc583a58922d9f353b3a41cf\SP2GDR\kernel32.dll
[2009/03/21 09:59:23 | 000,991,744 | ---- | M] (Microsoft Corporation) MD5=DA11D9D6ECBDF0F93436A4B7C13F7BEC -- C:\WINDOWS\$hf_mig$\KB959426\SP3QFE\kernel32.dll
< MD5 for: MSWSOCK.DLL >
[2004/08/04 01:56:46 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=4E74AF063C3271FBEA20DD940CFD1184 -- C:\WINDOWS\$NtServicePackUninstall$\mswsock.dll
[2008/06/20 13:46:57 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=832E4DD8964AB7ACC880B2837CB1ED20 -- C:\WINDOWS\system32\dllcache\mswsock.dll
[2008/06/20 13:46:57 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=832E4DD8964AB7ACC880B2837CB1ED20 -- C:\WINDOWS\system32\mswsock.dll
[2008/04/13 20:12:01 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=B4138E99236F0F57D4CF49BAE98A0746 -- C:\WINDOWS\$NtUninstallKB951748$\mswsock.dll
[2008/04/13 20:12:01 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=B4138E99236F0F57D4CF49BAE98A0746 -- C:\WINDOWS\ServicePackFiles\i386\mswsock.dll
[2008/06/20 13:43:05 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=FCEE5FCB99F7C724593365C706D28388 -- C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\mswsock.dll
< MD5 for: NDIS.SYS >
[2008/04/13 15:20:37 | 000,182,656 | ---- | M] (Microsoft Corporation) MD5=1DF7F42665C94B825322FAE71721130D -- C:\WINDOWS\ServicePackFiles\i386\ndis.sys
[2008/04/13 15:20:37 | 000,182,656 | ---- | M] (Microsoft Corporation) MD5=1DF7F42665C94B825322FAE71721130D -- C:\WINDOWS\system32\drivers\ndis.sys
[2004/08/04 00:14:30 | 000,182,912 | ---- | M] (Microsoft Corporation) MD5=558635D3AF1C7546D26067D5D9B6959E -- C:\WINDOWS\$NtServicePackUninstall$\ndis.sys
< MD5 for: NETLOGON.DLL >
[2008/04/13 20:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\ServicePackFiles\i386\netlogon.dll
[2008/04/13 20:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\system32\netlogon.dll
[2004/08/04 01:56:46 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=96353FCECBA774BB8DA74A1C6507015A -- C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll
< MD5 for: NTFS.SYS >
[2007/02/09 07:23:36 | 000,574,976 | ---- | M] (Microsoft Corporation) MD5=05AB81909514BFD69CBB1F2C147CF6B9 -- C:\WINDOWS\$hf_mig$\KB930916\SP2QFE\ntfs.sys
[2007/02/09 07:10:35 | 000,574,464 | ---- | M] (Microsoft Corporation) MD5=19A811EF5F1ED5C926A028CE107FF1AF -- C:\WINDOWS\$NtServicePackUninstall$\ntfs.sys
[2001/08/23 05:00:00 | 000,533,504 | R--- | M] (Microsoft Corporation) MD5=70FAE0DCFDFAA0838D6778FCA028CE01 -- C:\cmdcons\ntfs.sys
[2008/04/13 15:15:53 | 000,574,976 | ---- | M] (Microsoft Corporation) MD5=78A08DD6A8D65E697C18E1DB01C5CDCA -- C:\WINDOWS\ServicePackFiles\i386\ntfs.sys
[2008/04/13 15:15:53 | 000,574,976 | ---- | M] (Microsoft Corporation) MD5=78A08DD6A8D65E697C18E1DB01C5CDCA -- C:\WINDOWS\system32\drivers\ntfs.sys
[2004/08/04 00:15:10 | 000,574,592 | ---- | M] (Microsoft Corporation) MD5=B78BE402C3F63DD55521F73876951CDD -- C:\WINDOWS\$NtUninstallKB930916$\ntfs.sys
< MD5 for: NTMSSVC.DLL >
[2008/04/13 20:12:02 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=156F64A3345BD23C600655FB4D10BC08 -- C:\WINDOWS\ServicePackFiles\i386\ntmssvc.dll
[2008/04/13 20:12:02 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=156F64A3345BD23C600655FB4D10BC08 -- C:\WINDOWS\system32\ntmssvc.dll
[2004/08/04 01:56:46 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=B62F29C00AC55A761B2E45877D85EA0F -- C:\WINDOWS\$NtServicePackUninstall$\ntmssvc.dll
< MD5 for: PROQUOTA.EXE >
[2004/08/04 01:56:56 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=4D9D45A4370E0C2AD00C362B7118E2A4 -- C:\WINDOWS\$NtServicePackUninstall$\proquota.exe
[2008/04/13 20:12:32 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=F6465A2EEF75468988A4FCF124148FA8 -- C:\WINDOWS\ServicePackFiles\i386\proquota.exe
[2008/04/13 20:12:32 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=F6465A2EEF75468988A4FCF124148FA8 -- C:\WINDOWS\system32\proquota.exe
< MD5 for: QMGR.DLL >
[2004/08/04 01:56:46 | 000,382,464 | ---- | M] (Microsoft Corporation) MD5=2C69EC7E5A311334D10DD95F338FCCEA -- C:\WINDOWS\$NtServicePackUninstall$\qmgr.dll
[2008/04/13 20:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\ServicePackFiles\i386\qmgr.dll
[2008/04/13 20:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\system32\bits\qmgr.dll
[2008/04/13 20:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\system32\qmgr.dll
< MD5 for: SCECLI.DLL >
[2004/08/04 01:56:46 | 000,180,224 | ---- | M] (Microsoft Corporation) MD5=0F78E27F563F2AAF74B91A49E2ABF19A -- C:\WINDOWS\$NtServicePackUninstall$\scecli.dll
[2008/04/13 20:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\ServicePackFiles\i386\scecli.dll
[2008/04/13 20:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\system32\scecli.dll
< MD5 for: SFCFILES.DLL >
[2004/08/04 01:56:46 | 001,580,544 | ---- | M] (Microsoft Corporation) MD5=30A609E00BD1D4FFC49D6B5A432BE7F2 -- C:\WINDOWS\$NtServicePackUninstall$\sfcfiles.dll
[2008/04/13 20:12:05 | 001,614,848 | ---- | M] (Microsoft Corporation) MD5=9DD07AF82244867CA36681EA2D29CE79 -- C:\WINDOWS\ServicePackFiles\i386\sfcfiles.dll
[2008/04/13 20:12:05 | 001,614,848 | ---- | M] (Microsoft Corporation) MD5=9DD07AF82244867CA36681EA2D29CE79 -- C:\WINDOWS\system32\sfcfiles.dll
< MD5 for: SPOOLSV.EXE >
[2005/06/10 17:17:14 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=AD3D9D191AEA7B5445FE1D82FFBB4788 -- C:\WINDOWS\$hf_mig$\KB896423\SP2QFE\spoolsv.exe
[2008/04/13 20:12:36 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=D8E14A61ACC1D4A6CD0D38AEBAC7FA3B -- C:\WINDOWS\ServicePackFiles\i386\spoolsv.exe
[2008/04/13 20:12:36 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=D8E14A61ACC1D4A6CD0D38AEBAC7FA3B -- C:\WINDOWS\system32\spoolsv.exe
[2005/06/10 16:53:32 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=DA81EC57ACD4CDC3D4C51CF3D409AF9F -- C:\WINDOWS\$NtServicePackUninstall$\spoolsv.exe
< MD5 for: SRSVC.DLL >
[2008/04/13 20:12:07 | 000,171,008 | ---- | M] (Microsoft Corporation) MD5=3805DF0AC4296A34BA4BF93B346CC378 -- C:\WINDOWS\ServicePackFiles\i386\srsvc.dll
[2008/04/13 20:12:07 | 000,171,008 | ---- | M] (Microsoft Corporation) MD5=3805DF0AC4296A34BA4BF93B346CC378 -- C:\WINDOWS\system32\srsvc.dll
[2004/08/04 01:56:46 | 000,170,496 | ---- | M] (Microsoft Corporation) MD5=92BDF74F12D6CBEC43C94D4B7F804838 -- C:\WINDOWS\$NtServicePackUninstall$\srsvc.dll
< MD5 for: SVCHOST.EXE >
[2008/04/13 20:12:36 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=27C6D03BCDB8CFEB96B716F3D8BE3E18 -- C:\WINDOWS\ServicePackFiles\i386\svchost.exe
[2008/04/13 20:12:36 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=27C6D03BCDB8CFEB96B716F3D8BE3E18 -- C:\WINDOWS\system32\svchost.exe
[2004/08/04 01:56:58 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=8F078AE4ED187AAABC0A305146DE6716 -- C:\WINDOWS\$NtServicePackUninstall$\svchost.exe
< MD5 for: TERMSRV.DLL >
[2004/08/04 01:56:48 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=B60C877D16D9C880B952FDA04ADF16E6 -- C:\WINDOWS\$NtServicePackUninstall$\termsrv.dll
[2008/04/13 20:12:07 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=FF3477C03BE7201C294C35F684B3479F -- C:\WINDOWS\ServicePackFiles\i386\termsrv.dll
[2008/04/13 20:12:07 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=FF3477C03BE7201C294C35F684B3479F -- C:\WINDOWS\system32\termsrv.dll
< MD5 for: USERINIT.EXE >
[2004/08/04 01:56:58 | 000,024,576 | ---- | M] (Microsoft Corporation) MD5=39B1FFB03C2296323832ACBAE50D2AFF -- C:\WINDOWS\$NtServicePackUninstall$\userinit.exe
[2008/04/13 20:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\ServicePackFiles\i386\userinit.exe
[2008/04/13 20:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\system32\userinit.exe
< MD5 for: WS2_32.DLL >
[2008/04/13 20:12:10 | 000,082,432 | ---- | M] (Microsoft Corporation) MD5=2CCC474EB85CEAA3E1FA1726580A3E5A -- C:\WINDOWS\ServicePackFiles\i386\ws2_32.dll
[2008/04/13 20:12:10 | 000,082,432 | ---- | M] (Microsoft Corporation) MD5=2CCC474EB85CEAA3E1FA1726580A3E5A -- C:\WINDOWS\system32\ws2_32.dll
[2004/08/04 01:56:48 | 000,082,944 | ---- | M] (Microsoft Corporation) MD5=2ED0B7F12A60F90092081C50FA0EC2B2 -- C:\WINDOWS\$NtServicePackUninstall$\ws2_32.dll
< MD5 for: XMLPROV.DLL >
[2008/04/13 20:12:11 | 000,129,024 | ---- | M] (Microsoft Corporation) MD5=295D21F14C335B53CB8154E5B1F892B9 -- C:\WINDOWS\ServicePackFiles\i386\xmlprov.dll
[2008/04/13 20:12:11 | 000,129,024 | ---- | M] (Microsoft Corporation) MD5=295D21F14C335B53CB8154E5B1F892B9 -- C:\WINDOWS\system32\xmlprov.dll
[2004/08/04 01:56:48 | 000,129,536 | ---- | M] (Microsoft Corporation) MD5=EEF46DAB68229A14DA3D8E73C99E2959 -- C:\WINDOWS\$NtServicePackUninstall$\xmlprov.dll
< %systemroot%\system32\*.dll /lockedfiles >
[1 C:\WINDOWS\system32\*.tmp files -> C:\WINDOWS\system32\*.tmp -> ]
========== Files - Unicode (All) ==========
[2010/01/06 11:41:51 | 000,000,036 | ---- | M] ()(C:\WINDOWS\System32\?‘) -- C:\WINDOWS\System32\‘
[2010/01/06 11:41:51 | 000,000,036 | ---- | C] ()(C:\WINDOWS\System32\?‘) -- C:\WINDOWS\System32\‘
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 26th June 2010, 8:43 pm
Hi greich2, Smile
I see you have Viewpoint installed...
Viewpoint Manager is considered as foistware instead of malware since it is installed without users approval but doesn't spy or do anything "bad". I suggest you remove the program now. Navigate to Start --> Control Panel --> Add or Remove Programs and uninstall the following programs if present.
  • Viewpoint
  • Viewpoint Manager
  • Viewpoint Media Player
  • Viewpoint Toolbar
Let me know if you decided to uninstall it.
Please run OTL.exe.
    :OTL
    :File
    :commands
    [emptytemp]
    [resethosts]
    [reboot]
  • Close OTL.exe
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56114
Post by greich2 on 26th June 2010, 8:55 pm
I removed Viewpoint media player. running OTL again now
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 26th June 2010, 8:56 pm
Awesome, I await the logs. Smile
Sneakyone
Posts Posts : 2707
Post by greich2 on 27th June 2010, 3:59 am
I tried running OTL, but it would not complete the fix you provided. It kept hanging up and not responding after a few minutes.
I did however run Malwarebytes. Here is the log. Please let me know what to do next. Thank you for all of your help.
Database version: 4245
6/26/2010 11:43:01 PM
mbam-log-2010-06-26 (23-43-01).txt
Scan type: Full scan (C:\|D:\|)
Objects scanned: 170855
Time elapsed: 20 minute(s), 56 second(s)
Registry Keys Infected: 4
Registry Values Infected: 2
Files Infected: 4
HKEY_CURRENT_USER\Software\avsoft (Trojan.Fraudpack) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\avsuite (Rogue.AntivirusSuite) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\avsoft (Trojan.Fraudpack) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\avsuite (Rogue.AntivirusSuite) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\hfrplqrx (Rogue.AVSecuritySuite) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\hfrplqrx (Rogue.AVSecuritySuite) -> Quarantined and deleted successfully.
C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg\pfvsljmtssd.exe (Rogue.AVSecuritySuite) -> Quarantined and deleted successfully.
C:\Documents and Settings\freich.freich-us\Local Settings\Temp\e.exe (Rogue.AVSecuritySuite) -> Quarantined and deleted successfully.
C:\Documents and Settings\freich.freich-us\Local Settings\Temporary Internet Files\Content.IE5\4S5S688S\ad18ad[1].exe (Rogue.AVSecuritySuite) -> Quarantined and deleted successfully.
C:\Documents and Settings\freich.freich-us\Local Settings\Application Data\syssvc.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 27th June 2010, 4:14 am
Hi greich2, Smile
Sneakyone
Posts Posts : 2707
Post by greich2 on 27th June 2010, 2:07 pm
Here is the combofix log:
ComboFix 10-06-26.02 - freich 06/27/2010 0:45.1.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2038.1257 [GMT -4:00]
Running from: c:\documents and settings\freich.freich-us\Desktop\commy.exe
AV: AVG Anti-Virus Free *On-access scanning enabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
AV: Symantec AntiVirus Corporate Edition *On-access scanning disabled* (Outdated) {FB06448E-52B8-493A-90F3-E43226D3305C}
c:\documents and settings\All Users\Start Menu\Programs\Internet Explorer.lnk
c:\program files\INSTALL.LOG
-------\Legacy_RPCPATCH
-------\Legacy_RPCTFTPD
((((((((((((((((((((((((( Files Created from 2010-05-27 to 2010-06-27 )))))))))))))))))))))))))))))))
2010-06-26 16:47 . 2010-06-27 03:43 -------- d-----w- c:\documents and settings\freich.freich-us\Local Settings\Application Data\lxlssnyhg
2010-06-24 13:40 . 2010-06-24 13:40 -------- d-----w- c:\program files\QuickTime
2010-06-23 12:30 . 2010-06-23 12:30 1975408 ----a-w- c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\GoogleToolbarInstaller_en32_signed.exe
2010-06-22 01:32 . 2010-05-06 10:41 743424 ------w- c:\windows\system32\dllcache\iedvtool.dll
2010-06-27 05:00 . 2006-11-06 23:43 4212 ---h--w- c:\windows\system32\zllictbl.dat
2010-06-27 03:19 . 2010-02-07 21:20 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-06-26 22:24 . 2010-06-27 02:29 22528 ----a-w- c:\windows\Internet Logs\xDB127.tmp
2010-06-26 22:23 . 2010-06-27 02:29 1400320 ----a-w- c:\windows\Internet Logs\xDB126.tmp
2010-06-26 22:15 . 2010-06-26 22:23 25600 ----a-w- c:\windows\Internet Logs\xDB125.tmp
2010-06-26 21:20 . 2010-06-26 22:23 1400320 ----a-w- c:\windows\Internet Logs\xDB124.tmp
2010-06-26 21:06 . 2010-06-26 21:20 372736 ----a-w- c:\windows\Internet Logs\xDB123.tmp
2010-06-26 20:50 . 2007-07-03 20:00 -------- d-----w- c:\program files\Viewpoint
2010-06-26 19:43 . 2010-06-26 21:19 1400832 ----a-w- c:\windows\Internet Logs\xDB122.tmp
2010-06-25 04:59 . 2007-07-04 00:17 -------- d-----w- c:\program files\Hewlett-Packard
2010-06-25 04:59 . 2007-03-21 18:00 -------- d--h--w- c:\program files\InstallShield Installation Information
2010-06-25 04:58 . 2007-07-03 20:00 -------- d-----w- c:\program files\AIM
2010-06-25 04:58 . 2009-10-26 20:21 -------- d-----w- c:\documents and settings\freich.freich-us\Application Data\Aim
2010-06-25 04:42 . 2009-10-21 13:34 -------- d-----w- c:\program files\CCleaner
2010-06-24 14:51 . 2009-12-06 03:56 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
2010-06-24 13:52 . 2010-06-24 14:51 174592 ----a-w- c:\windows\Internet Logs\xDB121.tmp
2010-06-24 13:40 . 2010-06-24 14:51 1365504 ----a-w- c:\windows\Internet Logs\xDB120.tmp
2010-06-23 12:31 . 2009-12-06 04:06 2605008 ----a-w- c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\install_flash_player_ax.exe
2010-06-23 12:30 . 2009-12-06 03:56 -------- d-----w- c:\program files\Google
2010-06-22 15:53 . 2010-06-22 16:03 149504 ----a-w- c:\windows\Internet Logs\xDB11F.tmp
2010-06-22 15:39 . 2010-06-22 16:03 1355776 ----a-w- c:\windows\Internet Logs\xDB11E.tmp
2010-06-22 13:27 . 2010-02-15 19:56 -------- d-----w- c:\program files\Microsoft Silverlight
2010-06-21 19:15 . 2010-06-21 19:19 204800 ----a-w- c:\windows\Internet Logs\xDB11D.tmp
2010-06-21 18:35 . 2010-06-21 19:18 1349632 ----a-w- c:\windows\Internet Logs\xDB11C.tmp
2010-06-18 07:23 . 2010-06-18 10:35 808448 ----a-w- c:\windows\Internet Logs\xDB11B.tmp
2010-06-18 03:16 . 2010-06-18 10:35 1379840 ----a-w- c:\windows\Internet Logs\xDB11A.tmp
2010-06-06 05:28 . 2010-06-06 14:29 185344 ----a-w- c:\windows\Internet Logs\xDB119.tmp
2010-06-06 05:20 . 2010-06-06 14:29 1338368 ----a-w- c:\windows\Internet Logs\xDB118.tmp
2010-06-04 12:26 . 2010-06-04 12:34 96768 ----a-w- c:\windows\Internet Logs\xDB117.tmp
2010-06-04 12:12 . 2010-06-04 12:34 1336832 ----a-w- c:\windows\Internet Logs\xDB116.tmp
2010-06-02 19:04 . 2010-06-02 19:09 52736 ----a-w- c:\windows\Internet Logs\xDB115.tmp
2010-06-02 18:58 . 2010-06-02 19:09 1335808 ----a-w- c:\windows\Internet Logs\xDB114.tmp
2010-06-02 13:07 . 2010-01-02 18:11 242896 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2010-06-02 13:07 . 2010-01-02 18:11 29584 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2010-06-01 20:24 . 2010-06-02 13:02 358912 ----a-w- c:\windows\Internet Logs\xDB113.tmp
2010-06-01 19:33 . 2010-06-02 13:02 1337856 ----a-w- c:\windows\Internet Logs\xDB112.tmp
2010-05-28 07:05 . 2010-05-28 19:18 29184 ----a-w- c:\windows\Internet Logs\xDB111.tmp
2010-05-28 06:24 . 2010-05-28 19:18 1334784 ----a-w- c:\windows\Internet Logs\xDB110.tmp
2010-05-28 06:22 . 2006-11-07 19:54 9922232 ----a-w- c:\windows\Internet Logs\tvDebug.zip
2010-05-28 02:30 . 2010-05-28 06:23 2749440 ----a-w- c:\windows\Internet Logs\xDB10F.tmp
2010-05-28 01:41 . 2010-05-28 06:23 1341440 ----a-w- c:\windows\Internet Logs\xDB10E.tmp
2010-05-25 02:54 . 2010-05-25 03:22 1336832 ----a-w- c:\windows\Internet Logs\xDB10C.tmp
2010-05-24 22:42 . 2010-05-25 03:22 198144 ----a-w- c:\windows\Internet Logs\xDB10D.tmp
2010-05-23 19:47 . 2010-05-23 19:50 799232 ----a-w- c:\windows\Internet Logs\xDB10B.tmp
2010-05-23 17:57 . 2010-05-23 19:50 1336832 ----a-w- c:\windows\Internet Logs\xDB10A.tmp
2010-05-12 17:07 . 2010-05-12 17:12 759808 ----a-w- c:\windows\Internet Logs\xDB109.tmp
2010-05-12 16:46 . 2010-05-12 17:12 1354240 ----a-w- c:\windows\Internet Logs\xDB108.tmp
2010-05-08 20:34 . 2010-02-19 06:28 256 ----a-w- c:\windows\system32\pool.bin
2010-05-08 20:25 . 2009-03-26 00:22 -------- d-----w- c:\documents and settings\freich.freich-us\Application Data\ArcSoft
2010-05-06 10:41 . 1980-01-01 05:00 916480 ----a-w- c:\windows\system32\wininet.dll
2010-05-03 20:29 . 2010-05-03 20:35 930304 ----a-w- c:\windows\Internet Logs\xDB107.tmp
2010-05-03 20:18 . 2010-05-03 20:35 1362432 ----a-w- c:\windows\Internet Logs\xDB106.tmp
2010-05-02 05:22 . 1980-01-01 05:00 1851264 ------w- c:\windows\system32\win32k.sys
2010-04-30 14:09 . 2010-04-30 16:33 206336 ----a-w- c:\windows\Internet Logs\xDB105.tmp
2010-04-30 13:39 . 2010-04-30 16:33 1326592 ----a-w- c:\windows\Internet Logs\xDB104.tmp
2010-04-29 19:39 . 2010-02-07 21:20 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-04-29 19:39 . 2010-02-07 21:20 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-04-26 21:27 . 2010-04-27 18:52 202752 ----a-w- c:\windows\Internet Logs\xDB103.tmp
2010-04-26 21:14 . 2010-04-27 18:51 1389056 ----a-w- c:\windows\Internet Logs\xDB102.tmp
2010-04-25 20:14 . 2010-04-25 20:24 1400320 ----a-w- c:\windows\Internet Logs\xDB100.tmp
2010-04-25 20:14 . 2010-04-25 20:24 37376 ----a-w- c:\windows\Internet Logs\xDB101.tmp
2010-04-25 01:49 . 2010-04-25 01:54 120832 ----a-w- c:\windows\Internet Logs\xDBFF.tmp
2010-04-25 01:47 . 2010-04-25 01:53 1317888 ----a-w- c:\windows\Internet Logs\xDBFE.tmp
2010-04-24 20:17 . 2010-04-24 20:31 38400 ----a-w- c:\windows\Internet Logs\xDBFD.tmp
2010-04-24 19:56 . 2010-04-24 20:31 1314816 ----a-w- c:\windows\Internet Logs\xDBFC.tmp
2010-04-24 19:50 . 2010-04-24 19:55 1315328 ----a-w- c:\windows\Internet Logs\xDBFA.tmp
2010-04-24 19:50 . 2010-04-24 19:55 47616 ----a-w- c:\windows\Internet Logs\xDBFB.tmp
2010-04-24 12:02 . 2010-04-24 12:07 132096 ----a-w- c:\windows\Internet Logs\xDBF9.tmp
2010-04-24 11:52 . 2010-04-24 12:07 1339904 ----a-w- c:\windows\Internet Logs\xDBF8.tmp
2010-04-21 13:50 . 2010-04-21 14:08 482816 ----a-w- c:\windows\Internet Logs\xDBF7.tmp
2010-04-21 12:49 . 2010-04-21 14:08 1318400 ----a-w- c:\windows\Internet Logs\xDBF6.tmp
2010-04-20 05:30 . 1980-01-01 05:00 285696 ----a-w- c:\windows\system32\atmfd.dll
2010-04-16 19:25 . 2010-04-16 19:35 950272 ----a-w- c:\windows\Internet Logs\xDBF5.tmp
2010-04-16 18:35 . 2010-04-16 19:35 1343488 ----a-w- c:\windows\Internet Logs\xDBF4.tmp
2010-04-03 20:53 . 2010-04-03 20:57 1158144 ----a-w- c:\windows\Internet Logs\xDBF2.tmp
2010-04-03 20:43 . 2010-04-03 20:57 241664 ----a-w- c:\windows\Internet Logs\xDBF3.tmp
2010-04-03 00:21 . 2010-04-03 00:21 54 ----a-w- c:\windows\system32\rp_stats.dat
2010-04-03 00:21 . 2010-04-03 00:21 39 ----a-w- c:\windows\system32\rp_rules.dat
2010-04-03 00:13 . 2010-04-03 00:21 265728 ----a-w- c:\windows\Internet Logs\xDBF1.tmp
2010-04-02 23:33 . 2010-04-03 00:21 1173504 ----a-w- c:\windows\Internet Logs\xDBF0.tmp
2010-03-30 21:16 . 2010-03-30 21:28 75776 ----a-w- c:\windows\Internet Logs\xDBEF.tmp
2010-03-30 20:59 . 2010-03-30 21:28 1158656 ----a-w- c:\windows\Internet Logs\xDBEE.tmp
2010-03-30 17:23 . 2010-03-30 19:29 432640 ----a-w- c:\windows\Internet Logs\xDBED.tmp
2010-03-30 16:20 . 2010-03-30 19:29 1162240 ----a-w- c:\windows\Internet Logs\xDBEC.tmp
2001-08-23 17:00 . 1980-01-01 05:00 94784 --sh--w- c:\windows\twain.dll
2008-04-14 00:12 . 1980-01-01 05:00 50688 --sh--w- c:\windows\twain_32.dll
2008-04-14 00:11 . 1980-01-01 05:00 1028096 --sha-w- c:\windows\system32\mfc42.dll
2008-04-14 00:12 . 1980-01-01 05:00 57344 --sha-w- c:\windows\system32\msvcirt.dll
2008-04-14 00:12 . 1980-01-01 05:00 413696 --sha-w- c:\windows\system32\msvcp60.dll
2008-04-14 00:12 . 1980-01-01 05:00 551936 --sh--w- c:\windows\system32\oleaut32.dll
2008-04-14 00:12 . 1980-01-01 05:00 84992 --sha-w- c:\windows\system32\olepro32.dll
2008-04-14 00:12 . 1980-01-01 05:00 11776 --sh--w- c:\windows\system32\regsvr32.exe
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{A3BC75A2-1F87-4686-AA43-5347D756017C}"= "c:\program files\AVG\AVG9\Toolbar\IEToolbar.dll" [2009-11-25 1230080]
[HKEY_CLASSES_ROOT\clsid\{a3bc75a2-1f87-4686-aa43-5347d756017c}]
"{CCC7A320-B3CA-4199-B1A6-9F516DD69829}"= "c:\program files\AVG\AVG9\Toolbar\IEToolbar.dll" [2009-11-25 1230080]
[HKEY_CLASSES_ROOT\clsid\{ccc7a320-b3ca-4199-b1a6-9f516dd69829}]
"ISUSPM"="c:\program files\Common Files\InstallShield\UpdateService\isuspm.exe" [2006-09-11 218032]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2010-06-23 39408]
"CoolSwitch"="c:\windows\System32\taskswitch.exe" [2001-10-08 45632]
"TweakAutomaticUpdates"="c:\windows\orclobi\gdswsuspatch_soon.exe" [2005-12-22 126887]
"Zone Labs Client"="c:\progra~1\ZONELA~1\INTEGR~1\iclient.exe" [2005-06-16 444160]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-04 208952]
"IMEKRMIG6.1"="c:\windows\ime\imkr6_1\IMEKRMIG.EXE" [2001-06-26 44032]
"MSPY2002"="c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2004-08-04 59392]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"SoundMAXPnP"="c:\program files\Analog Devices\Core\smax4pnp.exe" [2005-05-20 925696]
"TpShocks"="TpShocks.exe" [2005-11-07 106496]
"EZEJMNAP"="c:\progra~1\ThinkPad\UTILIT~1\EzEjMnAp.Exe" [2006-02-24 237568]
"TPHOTKEY"="c:\progra~1\Lenovo\PkgMgr\HOTKEY\TPHKMGR.exe" [2006-05-10 94208]
"LPManager"="c:\progra~1\THINKV~1\PrdCtr\LPMGR.exe" [2006-03-23 106496]
"PWRMGRTR"="c:\progra~1\ThinkPad\UTILIT~1\PWRMGRTR.DLL" [2006-03-23 151552]
"BLOG"="c:\progra~1\ThinkPad\UTILIT~1\BatLogEx.DLL" [2006-03-23 208896]
"SynTPLpr"="c:\program files\Synaptics\SynTP\SynTPLpr.exe" [2006-02-14 110592]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2006-02-14 512000]
"DLA"="c:\windows\System32\DLA\DLACTRLW.EXE" [2005-08-01 122940]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-09-11 86960]
"ntpgds"="c:\windows\orclobi\synctime.exe" [2003-04-07 110993]
"WD Button Manager"="WDBtnMgr.exe" [2007-07-04 339968]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-02-26 131072]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-02-26 155648]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-02-26 131072]
"AVG9_TRAY"="c:\progra~1\AVG\AVG9\avgtray.exe" [2010-06-02 2065248]
"ISUSPM Startup"="c:\progra~1\common~1\instal~1\update~1\isuspm.exe" [2006-09-11 218032]
"RoxWatchTray"="c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe" [2008-03-06 236016]
"Monitor"="c:\program files\LeapFrog\LeapFrog Connect\Monitor.exe" [2009-11-10 443728]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2010-06-24 417792]
"FirefoxConfig"="c:\windows\orclobi\config\firefoxconfig.exe" [2006-11-01 184670]
"ThunderbirdConfig"="c:\windows\orclobi\config\tbirdconfig.exe" [2006-11-01 183932]
"TSClientMSIUninstaller"="c:\windows\Installer\TSClientMsiTrans\tscuinst.vbs" [2007-10-30 13801]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-9-23 29696]
Bluetooth.lnk - c:\program files\ThinkPad\Bluetooth Software\BTTray.exe [2006-8-1 622653]
F1U201.401.lnk - c:\program files\Belkin\F1U201.401\usbshare.exe [2007-7-10 135168]
Microsoft Office OneNote 2003 Quick Launch.lnk - c:\program files\microsoft office\OFFICE11\ONENOTEM.EXE [2007-4-19 64864]
VPN Client.lnk - c:\windows\Installer\{D25122BC-A60E-4663-B602-B01718F12044}\Icon3E5562ED7.ico [2007-7-2 6144]
WD Backup Monitor.lnk - c:\program files\My Book\WD Backup\uBBMonitor.exe [2007-7-4 98304]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
2010-03-13 14:54 12464 ----a-w- c:\windows\system32\avgrsstx.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\PCANotify]
2004-11-01 16:50 8704 ------w- c:\windows\system32\PCANotify.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\psfus]
2006-04-26 00:20 40448 ------w- c:\windows\system32\psqlpwd.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\tpfnf2]
2005-07-06 03:45 28672 ------w- c:\windows\system32\notifyf2.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\tphotkey]
2005-12-01 00:16 24576 ------w- c:\windows\system32\tphklock.dll
Notification Packages REG_MULTI_SZ scecli psqlpwd
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Lavasoft Ad-Aware Service]
"ERSvc"=2 (0x2)
"c:\\Program Files\\AVG\\AVG9\\avgam.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgdiagex.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG9\\avgnsx.exe"=
R0 AVGIDSErHrxpx;AVG9IDSErHr;c:\windows\system32\drivers\AVGIDSxx.sys [1/2/2010 2:11 PM 25096]
R0 AvgRkx86;avgrkx86.sys;c:\windows\system32\drivers\avgrkx86.sys [1/2/2010 2:11 PM 52872]
R0 Lbd;Lbd;c:\windows\system32\drivers\Lbd.sys [1/2/2010 8:11 PM 64288]
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [1/2/2010 2:11 PM 216200]
R1 AvgTdiX;AVG Network Redirector;c:\windows\system32\drivers\avgtdix.sys [1/2/2010 2:11 PM 242896]
R2 avg9wd;AVG WatchDog;c:\program files\AVG\AVG9\avgwdsvc.exe [3/13/2010 10:54 AM 308064]
R2 avgfws9;AVG Firewall;c:\program files\AVG\AVG9\avgfws9.exe [6/2/2010 9:07 AM 2331544]
R2 Lavasoft Ad-Aware Service;Lavasoft Ad-Aware Service;c:\program files\Lavasoft\Ad-Aware\AAWService.exe [12/2/2009 9:19 AM 1181328]
R2 MyDesktopWindows;MyDesktopService;c:\windows\ORCLOBI\MyDesktop\MyDesktopService.exe [4/17/2007 3:30 PM 960512]
R2 QOSMyDesktop;QOS MyDesktop;c:\windows\ORCLOBI\MyDesktop\MyDesktopQOS.exe [4/21/2006 3:14 PM 450560]
R2 smihlp;SMI helper driver;c:\program files\ThinkVantage Fingerprint Software\smihlp.sys [4/25/2006 8:00 PM 3456]
R3 Avgfwdx;Avgfwdx;c:\windows\system32\drivers\avgfwdx.sys [1/2/2010 2:10 PM 30104]
R3 AVGIDSDriverxpx;AVG9IDSDriver;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys [1/2/2010 2:11 PM 122376]
R3 AVGIDSFilterxpx;AVG9IDSFilter;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys [1/2/2010 2:11 PM 30216]
R3 AVGIDSShimxpx;AVG9IDSShim;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys [1/2/2010 2:11 PM 26120]
S2 AVGIDSAgent;AVG9IDSAgent;c:\program files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe [3/13/2010 10:54 AM 5888008]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [4/7/2010 12:29 PM 135664]
S2 PMEMNT;PMEMNT;\??\c:\windows\pmemnt.sys --> c:\windows\pmemnt.sys [?]
S3 Avgfwfd;AVG network filter service;c:\windows\system32\drivers\avgfwdx.sys [1/2/2010 2:10 PM 30104]
S3 FlyUsb;FLY Fusion;c:\windows\system32\drivers\FlyUsb.sys [3/23/2010 1:40 PM 18560]
2010-06-27 c:\windows\Tasks\At1.job
- c:\windows\orclobi\gdswsuspatch.exe [2006-10-18 12:39]
2010-06-27 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-04-07 16:29]
2010-06-27 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-06-27 c:\windows\Tasks\PMTask.job
- c:\progra~1\ThinkPad\UTILIT~1\PWMIDTSK.EXE [2007-03-21 05:13]
uInternet Connection Wizard,ShellNext = wmplayer.exe
uInternet Settings,ProxyServer = http=127.0.0.1:5577
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
IE: Send to &Bluetooth Device... - c:\program files\ThinkPad\Bluetooth Software\btsendto_ie_ctx.htm
Trusted Zone: intuit.com\ttlc
Trusted Zone: oraclecorp.com\global-service
FF - ProfilePath - c:\documents and settings\freich.freich-us\Application Data\Mozilla\Firefox\Profiles\b6at4lbb.default\
FF - prefs.js: browser.search.selectedEngine - Yahoo! Search
FF - component: c:\program files\AVG\AVG9\Firefox\components\avgssff.dll
FF - component: c:\program files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils2.dll
FF - component: c:\program files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils3.dll
FF - component: c:\program files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils35.dll
FF - component: c:\program files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components\xpavgtbapi.dll
FF - plugin: c:\program files\Google\Google Earth\plugin\npgeplugin.dll
FF - plugin: c:\program files\Google\Update\1.2.183.29\npGoogleOneClick8.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
AddRemove-WZCLINE - c:\program files\WinZip\winzip32
Rootkit scan 2010-06-27 01:00
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
[HKEY_LOCAL_MACHINE\software\DeterministicNetworks\DNE\Parameters]
"SymbolicLinkValue"=hex(6):5c,00,52,00,65,00,67,00,69,00,73,00,74,00,72,00,79,
00,5c,00,4d,00,61,00,63,00,68,00,69,00,6e,00,65,00,5c,00,53,00,79,00,73,00,\
- - - - - - - > 'winlogon.exe'(1876)
c:\windows\system32\vrlogon.dll
c:\program files\ThinkVantage Fingerprint Software\infra.dll
c:\program files\ThinkVantage Fingerprint Software\homefus2.dll
c:\windows\system32\biologon.dll
c:\program files\ThinkVantage Fingerprint Software\homepass.dll
c:\program files\ThinkVantage Fingerprint Software\bio.dll
c:\program files\ThinkVantage Fingerprint Software\remote.dll
- - - - - - - > 'lsass.exe'(1932)
- - - - - - - > 'explorer.exe'(3076)
c:\windows\system32\btncopy.dll
c:\windows\system32\ibmpmsvc.exe
c:\program files\ThinkPad\Bluetooth Software\bin\btwdins.exe
c:\program files\AVG\AVG9\avgchsvx.exe
c:\program files\AVG\AVG9\avgrsx.exe
c:\program files\AVG\AVG9\avgcsrvx.exe
c:\program files\Cisco Systems\VPN Client\cvpnd.exe
c:\program files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
c:\program files\AVG\AVG9\avgnsx.exe
c:\program files\LeapFrog\LeapFrog Connect\CommandService.exe
c:\windows\System32\TPHDEXLG.EXE
c:\windows\system32\ZONELABS\vsmon.exe
c:\windows\System32\wbem\unsecapp.exe
c:\program files\AVG\AVG9\avgscanx.exe
c:\windows\system32\TpShocks.exe
c:\program files\Lenovo\PkgMgr\HOTKEY\TPONSCR.exe
c:\program files\Lenovo\PkgMgr\HOTKEY_1\TpScrex.exe
c:\windows\system32\WDBtnMgr.exe
c:\windows\system32\igfxsrvc.exe
c:\progra~1\ThinkPad\BLUETO~1\BTSTAC~1.EXE
c:\program files\Lavasoft\Ad-Aware\AAWTray.exe
Completion time: 2010-06-27 01:06:00 - machine was rebooted
ComboFix-quarantined-files.txt 2010-06-27 05:05
Pre-Run: 2,786,447,360 bytes free
Post-Run: 2,809,987,072 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
C:\OracleOB.dat="Oracle OBI Preinstallation Environment"
- - End Of File - - 3D0B271EE2B745686573ED165693921E
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 27th June 2010, 5:04 pm
Hi greich2, Smile
You are operating your computer with multiple Anti Virus programs:
AVG
Anti-virus programs take up an enormous amount of your computer's resources when they are actively scanning your computer. Having two anti-virus programs running at the same time can cause your computer to run very slow, become unstable and even, in rare cases, crash.
Please Uninstall Symantec AntiVirus Corporate Edition using Control Panel, Add/Remove Programs.
  1. Close any open browsers.
    Folder::
    DDS::
Sneakyone
Posts Posts : 2707
Post by greich2 on 27th June 2010, 6:00 pm
I cannot find anything in Add/Remove programs for Symantec Anitvirus other Symantec Live Reg-which I removed. Would it be under a different name?
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 27th June 2010, 8:21 pm
Hi greich2, Smile
    Folder::
    DDS::
    SecCenter::
Sneakyone
Posts Posts : 2707
Post by greich2 on 28th June 2010, 3:24 am
Here is the log from Combofix:
ComboFix 10-06-27.03 - freich 06/27/2010 23:16:46.2.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2038.1221 [GMT -4:00]
Command switches used :: c:\documents and settings\freich.freich-us\Desktop\CFscript.txt
AV: AVG Anti-Virus Free *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
((((((((((((((((((((((((( Files Created from 2010-05-28 to 2010-06-28 )))))))))))))))))))))))))))))))
2010-06-27 17:57 . 2010-06-27 17:57 -------- d-----w- c:\documents and settings\freich.freich-us\Application Data\Symantec
2010-06-27 17:57 . 2006-11-06 23:24 -------- d-----w- c:\program files\Common Files\Symantec Shared
2010-06-27 05:23 . 2006-11-06 23:43 4212 ---h--w- c:\windows\system32\zllictbl.dat
"ERSvc"=2 (0x2)
Rootkit scan 2010-06-27 23:21
@="FlashBroker"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(1868)
c:\windows\system32\igfxdev.dll
- - - - - - - > 'lsass.exe'(1924)
- - - - - - - > 'explorer.exe'(4444)
Completion time: 2010-06-27 23:22:53
ComboFix-quarantined-files.txt 2010-06-28 03:22
ComboFix2.txt 2010-06-27 05:06
Pre-Run: 2,755,764,224 bytes free
Post-Run: 2,773,127,168 bytes free
- - End Of File - - 8B96DD490900CFAF54945D0CAF05C926
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 28th June 2010, 4:48 am
Hi greich2, Smile
  • Click Start
  • Click Start
Sneakyone
Posts Posts : 2707
Post by greich2 on 28th June 2010, 10:17 am
Eset log:
D:\My Downloads\aim95.exe Win32/Adware.WBug.A application deleted - quarantined
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 28th June 2010, 7:33 pm
Hi greich2, Smile
Your computer is now clean. Now, time to remove the tools used, and update your computer to prevent vulnerability.
Updating System Restore
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE.
You now have a clean restore point.
To get rid of the bad ones:
  • Click OK
  • The System will do a calculation of temporary/old files, and then display a dialogue box.
  • At the bottom will be a System Restore box with a CLEANUP button click this
  • Accept the Warning and select OK again, the program will close and you are done.
Removing the tools
Now, to remove all of the tools we used and the files and folders they created, please do the following:
Download [You must be registered and logged in to see this link.] by OldTimer:
  • Double click OTC.exe.
  • Click the CleanUp! button.
Here are some prevention tips I have provided:
1. Don't download files from untrusted websites or websites that seem suspious.
2. Don't use torrents they are a good way to get lots of malware.
3. Don't download and use cracks/warez/keygens they are illegal and are another good way to contract malware.
4. Disable autorun [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
5. Always make sure you have the latest Windows updates. windowsupdate.microsoft.com
6. Don't ever click on the links inside of a popup.
7. Make sure you know what you install you can make sure it is not know for being a virus by just simply searching about it on google.
8. Use a Site Advisor so you don't go to sites that will infect you. [You must be registered and logged in to see this link.]
9. Also there are many holes and flaws in Internet Explorer I recommend using [You must be registered and logged in to see this link.] to keep you more safe.
10. Always keep your [You must be registered and logged in to see this link.] and Adobe updated.
11. Don't fall for the Scareware. What is Scareware? it is a website made to download a rogue Antivirus on your system that will scare you into buying their fake software due to false detections.
12. Always have a Firewall and a Antivirus.
Thanks for choosing GeekPolice, see [You must be registered and logged in to see this link.] if you would like to leave feedback or contribute to our site. Do you have any more questions?
For more information please visit [You must be registered and logged in to see this link.]
Sneakyone
Posts Posts : 2707
Post by greich2 on 29th June 2010, 3:18 am
Thank you very much for your help.
I have tried a couple of ways to setup a new restore point, but have been unable to do that. The program screen remains blank. Do I have to set a new restore point prior to deleting the old ones? I tried the method you stated and I also went thru the start menu, then help and support.
Please advise.
greich2
Posts Posts : 25
OS OS : windows xp
Post by Sneakyone on 29th June 2010, 6:02 am
Hi, Smile
You're welcome, do this to clean your restore points except your most recent one.
To remove all restore points except the most recent restore point, follow these steps:
  1. Click Start, and then click My Computer.
  2. Right-click the disk in which you want to free up space, and then click Properties.
  3. Click the General tab, and then click Disk Cleanup.
  4. Click the More Options tab, and then under System Restore, click Clean up.
  5. Click Yes to remove all but the most recent restore point.
  6. Click OK, click Yes to proceed with this action, and then click OK.
Sneakyone
Posts Posts : 2707
