Need To Speed Up Computer
Post by DR@G0N5 on 21st June 2010, 9:03 pm
Hello, I need some help to speed up my computer so it is more easier to use any ideas? I have AVG 9.0 and Ad-Aware (don't know which version) and both are free.
DR@G0N5
Posts Posts : 4
Joined Joined : 2010-06-21
Points Points : 23685
Re: Need To Speed Up Computer
Post by Dr Jay on 23rd June 2010, 5:01 am
I'll go out on a limb and say AVG is your issue.
It probably is bogging down your CPU.
Do you want to try to remove it?
I can get you a new antivirus that is better.
Posts Posts : 14309
Points Points : 302960
Post by DR@G0N5 on 24th June 2010, 10:32 pm
If it is, I'll remove it and see if my computer runs faster. What antivirus is there better? Should I get Norton? Comcast gives the whole suite if your a customer.
DR@G0N5
Posts Posts : 4
Post by Doctor Inferno on 25th June 2010, 12:23 am
Get Avira or Microsoft Security Essentials, they both offer great and free protection which I always recommend.
http://www.avira.com/en/download/index.php
http://www.microsoft.com/security_essentials/
Points Points : 104630
Post by DR@G0N5 on 27th June 2010, 12:28 am
Okay. I'll see if it will work.
DR@G0N5
Posts Posts : 4
