Old Computer Problem
Post by Restricted on Sat Jun 12, 2010 12:57 am
I have an old computer that hasn't been used in a long time. Whenever you put the power cord in and the cord to the monitor, the computer turns on, but nothing shows up on the screen. I can hear the fan running inside the computer and I can feel the air coming from the fan. The monitor does work, I use it on my other desktop. What could the issue be?
Restricted
Posts Posts : 158
Joined Joined : 2009-06-11
OS OS : Win7 Ultimate 32-bit
Protection Protection : Avira
Points Points : 28788
Re: Old Computer Problem
Post by kes3000 on Sat Jun 12, 2010 11:02 pm
do you hear the hard drive spinning?
you could try opening up the casing and removing the CMOS battery for a minute or so then putting it back in, or even replacing the battery altogether if it's a really old system. once its back in turn the computer on and see if it starts up then
kes3000
Posts Posts : 69
Joined Joined : 2009-08-14
OS OS : Windows XP Home Premium, Windows 7 Home Premium x64, Ubuntu
Protection Protection : ESET Smart Security 4, Malwarebytes Anti-Malware
Points Points : 27083
Post by arcksonn on Mon Jun 14, 2010 6:58 am
You need to check whether there is any problem with your system or your monitor try checking with any other computer, If the monitor light blink but it doesn't turns up mean there is some problem in the video signal from the CPU. If the Monitors light are not coming on then you need to try your system with some other monitor. As it is them expected to be problem with your monitor. In your Operating system also check out whether the drivers for the monitors are installed properly. You can find it in the devicemanager. Type "devmgmt.msc" in the run.
arcksonn
Joined Joined : 2010-06-08
OS OS : windows seven
Points Points : 23732
Post by Restricted on Tue Jun 15, 2010 5:31 pm
@kes3000 wrote:do you hear the hard drive spinning?
What does the harddrive sound like when its spinning?
Restricted
Posts Posts : 158
Post by Restricted on Mon Jun 21, 2010 5:32 am
I managed to find that battery you were talking about, removed it for about 5 5 minutes and it still doesn't work. Thank you.
Restricted
Posts Posts : 158
Post by theamp on Mon Jun 21, 2010 6:26 am
Is the graphics chip on the motherboard, or is it on a PCI card?
theamp
Posts Posts : 136
Joined Joined : 2010-05-15
Points Points : 24663
Post by Restricted on Wed Jun 23, 2010 12:01 am
It is integrated. I removed the ram, turned it on, and still nothing. I put the ram back in after it being out, and still nothing. But 1 question, is it normal to have only 1 RAM stick?
Restricted
Posts Posts : 158
Post by Nazzgull on Wed Jun 23, 2010 1:49 pm
It is normal for old motherboards. I suggest you to turn off that old monster and put motherboard in garbage. Your integrated GPU is probably dead, buy new one, i mean new motherboard. Start your computer from begin.
Points Points : 40445
