My laptop won't recognize the charger cable.
Post by RAWRalicious on Wed Jun 09, 2010 8:49 pm
So I've had my Toshiba Satellite for a little over a year now and it won't recognize the charger cable. My battery's about to die, too. Even when I try to charge it while it's off, it won't recognize it. I think the cable itself is damaged, but I don't see any external problems when I look at it.
I went to acclaim.toshiba.com to do a DIY Replacement order and it said that the cable's damaged, but I want to make sure it is before I order one. Just in case it's not a dead battery or a damaged port.
RAWRalicious
Posts Posts : 9
Joined Joined : 2010-01-15
OS OS : Windows Vista
Points Points : 25271
Re: My laptop won't recognize the charger cable.
Post by makxp77 on Mon Jun 14, 2010 7:35 am
Try checking to see if where you plug the cable into the laptop the laptop power jack is not loose, I know that many Toshiba laptop power jacks have a big issue with them , if it is not loose then replace the cable.
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29054
Post by Cyril on Tue Aug 03, 2010 10:01 pm
I've had the same problem on another type of computer. Mostly, it seems that the cables wear down after a time and for some, they're really expensive to replace.
If you notice that to need to replace it, I'd like to recommend eBay. To replace one of mine, it would cost $40 - $60 to buy a new one, but cost me only about $8 from eBay.
So if all else fails, I hope I saved you a bit of money.
-Cyril
Cyril
Posts Posts : 4
Joined Joined : 2010-04-24
Points Points : 24196
