I need help with Corrupted Registry in XP
Post by aigles_verts on 9th June 2010, 2:56 pm
A couple of weeks ago, I started having problems with my PC. It wouldn't open any applications (Word, SpySweeper, etc...). I would get a pop up window that would give me a list of programs to use in order to open whatever application I wanted to use. Internet Explorer was working.
I checked the Microsoft Knowledge Base and it appears that the registry on my PC is corrupted (since I can run anything with .com or .exe, etc...). I could not use the Guided Help option on the Microsoft website for the same reason.
I probably did something foolish by googling for solutions and I tried the one found at the link below.
http://www.pchell.com/support/recoverfromcorruptedregistry.shtml
Unfortunately, I did not get very far.
This is the section that I attempted to do. It is at the beginning of that link if you click on it.
Copy Repair Files Using the Recovery Console
This procedure assumes Windows is installed on Drive C, if you have installed Windows on another drive, please substitute the appropriate drive letter in the procedure below.
At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:
md tmp
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
I ran into problems with this next section as I got an error message saying that the subdirectories "system", "sam", "security", etc... did not exist in c:\windows\system32\config
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
When I restart the PC, I get a black screen with the error message that the file c:\windows\system32\config\system does not exist or is corrupted.
That's where I have been stuck so far. Any help you can provide me would be greatly appreciated.
aigles_verts
Posts Posts : 17
Joined Joined : 2010-04-13
Points Points : 24527
Re: I need help with Corrupted Registry in XP
Post by makxp77 on 12th June 2010, 3:51 pm
Throw in your windows disc your computer came with and select R for repair and let Winodws do a automatic repair!
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29104
Post by aigles_verts on 13th June 2010, 6:42 pm
I tried that already. I get the blue screen with I think the 3 options. I believe the 2nd option is for repair and the 3rd one is for a full reinstall of XP. When I select the Repair option, it takes me to the black screen and then to the Recovery Console command prompt.
However, I believe there used to be an automatic repair option that's not there anymore unless I am doing something wrong. It involves running the XP installation CD but this time choosing option 3 which is the XP reinstall option. After that, I would accept the license agreement (f8). The next screen would be a choice of reinstalling XP, Repairing or Quitting. The first time around the Repair option worked. I was able to use my PC although I was still having trouble opening any applications (Word, Excel, etcc..). Curiously Internet Explorer was still working.
But now, I am stuck either at the black screen or I get the blue screen with error message of config\system file missing or corrupt and an error code with lots of 0s.
aigles_verts
Posts Posts : 17
Post by makxp77 on 14th June 2010, 7:16 am
If anything will help you it will be below, if below does not help you save all files and re-install Windows
Manual steps to recover a corrupted registry that prevents Windows XP from starting
The procedure that this article describes uses Recovery Console and System Restore. This article also lists all the required steps in specific order to make sure that the process is fully completed. When you finish this procedure, the system returns to a state very close to the state before the problem occurred. If you have ever run NTBackup and completed a system state backup, you do not have to follow the procedures in parts two and three. You can go to part four.
Part one
In part one, you start the Recovery Console, create a temporary folder, back up the existing registry files to a new location, delete the registry files at their existing location, and then copy the registry files from the repair folder to the System32\Config folder. When you have finished this procedure, a registry is created that you can use to start Windows XP. This registry was created and saved during the initial setup of Windows XP. Therefore any changes and settings that occurred after the Setup program was finished are lost.
To complete part one, follow these steps:
Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
md tmp
Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy1.txt
With the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands.
Part two
To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
Note Print these instructions before you continue. You cannot view these instructions after you restart the computer in Safe Mode. If you use the NTFS file system, also print the instructions from Knowledge Base article KB309531. Step 7 contains a reference to the article.
Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
Press the F8 key.
On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console and is generally not visible during typical usage. Before you start this procedure, you must change several settings to make the folder visible:
Start Windows Explorer.
On the Tools menu, click Folder options.
Click the View tab.
Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
Click Yes when the dialog box that confirms that you want to display these files appears.
Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
Note This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
Note You may receive the following error message:
C:\System Volume Information is not accessible. Access is denied.
If you receive this message, see the following Microsoft Knowledge Base article to gain access to this folder and continue with the procedure:
309531 (http://support.microsoft.com/kb/309531/ ) How to gain access to the System Volume Information folder
Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder:
C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
_REGISTRY_USER_.DEFAULT
_REGISTRY_MACHINE_SECURITY
_REGISTRY_MACHINE_SOFTWARE
_REGISTRY_MACHINE_SYSTEM
_REGISTRY_MACHINE_SAM
Rename the files in the C:\Windows\Tmp folder as follows:
Rename _REGISTRY_USER_.DEFAULT to DEFAULT
Rename _REGISTRY_MACHINE_SECURITY to SECURITY
Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. Because you used the registry file that the Setup program created, this registry does not know that these restore points exist and are available. A new folder is created with a new GUID under System Volume Information and a restore point is created that includes a copy of the registry files that were copied during part one. Therefore, it is important not to use the most current folder, especially if the time stamp on the folder is the same as the current time.
The current system configuration is not aware of the previous restore points. You must have a previous copy of the registry from a previous restore point to make the previous restore points available again.
The registry files that were copied to the Tmp folder in the C:\Windows folder are moved to make sure that the files are available under Recovery Console. You must use these files to replace the registry files currently in the C:\Windows\System32\Config folder. By default, Recovery Console has limited folder access and cannot copy files from the System Volume folder.
Note The procedure described in this section assumes that you are running your computer with the FAT32 file system. For more information about how to access the System Volume Information Folder with the NTFS file system, click the following article number to view the article in the Microsoft Knowledge Base:
Part Three
In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
Start Recovery Console.
At the command prompt, type the following lines, pressing ENTER after you type each line:
del c:\windows\system32\config\sam
del c:\windows\system32\config\security
del c:\windows\system32\config\software
del c:\windows\system32\config\default
del c:\windows\system32\config\system
copy c:\windows\tmp\software c:\windows\system32\config\software
copy c:\windows\tmp\system c:\windows\system32\config\system
copy c:\windows\tmp\sam c:\windows\system32\config\sam
copy c:\windows\tmp\security c:\windows\system32\config\security
copy c:\windows\tmp\default c:\windows\system32\config\default
Note Some of these command lines may be wrapped for readability.
Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt
Part Four
Click Start, and then click All Programs.
Click Accessories, and then click System Tools.
Click System Restore, and then click Restore to a previous RestorePoint.
MiKeY
makxp77
Posts Posts : 216
