Best antivirus / antimalware / antispyware for Win7 64bit?
Post by copywriter on 5th June 2010, 2:15 am
I would like to know what are the best antivirus / antimalware / antiadware solutions to use on a computer running the Windows 7 operating system with 64 bits. I have never run a 64 bit computer before in my entire life. I am also utterly clueless about what antivirus solutions even work with Windows 7. Thanks in advance.
copywriter
Posts Posts : 3
Joined Joined : 2010-04-10
OS OS : Windows Home
Points Points : 24347
Re: Best antivirus / antimalware / antispyware for Win7 64bit?
Post by CompGuy911 on 7th June 2010, 8:31 pm
Get avast! Free Antivirus. It is the best out there.
Get it here - http://www.avast.com/free-antivirus-download
CompGuy911
Posts Posts : 8
Joined Joined : 2010-06-06
OS OS : Windows 7 and XP
Protection Protection : avast! Free Antivirus
Points Points : 23821
Post by vikneshwaren on 8th June 2010, 3:33 pm
I would recommend the AIO Security Suite : Kaspersky Internet Security or Kaspersky Pure. Its the best and used my most of the peoples.
vikneshwaren
Posts Posts : 251
Joined Joined : 2008-12-23
OS OS : Microsoft Windows 7 Ultimate
Points Points : 29445
Post by amyclinton on 10th August 2010, 1:15 pm
hi,
I work on 2 OS Vista & Win 7 and have installed the combo of Kaspersky & Advanced System Protector on Vista and Macfee & Advanced System Protector on Win 7.All 3 of them are good and the reason of using Advanced System Protector on both the OS is that it not only blocks the spyware b4 it can enter your system,will also clean the infections if any and it gives routine updates of the latest definitions and makes the browsing safe and is very easy to use.The On Execution Scanner & Alert Shields make it more efficient in the case of internet access. It isCompatible with Windows 2000, XP ,win 7and Vista (both 32 and 64 bit)
For me the Advanced System Protector is the Best Antimalware/antispyware
U can also give a try
free version of ASP is also available
http://www.systweak.com/AntiSpyware/Download/
amyclinton
Joined Joined : 2010-08-10
OS OS : win 7
Points Points : 23121
Post by Kenny94 on 12th August 2010, 1:48 am
I use Avira AntiVir Premium and Malwarebytes Pro on my personal PC.
Kenny94
Tech Officer
Tech Officer
Posts Posts : 2019
Joined Joined : 2010-04-22
Protection Protection : Avira/Router and Malwarebytes
Points Points : 33531
Post by Buttons on 14th August 2010, 12:10 am
I have Comodo Internet Security, Superantispyware Pro, Malwarebytes' Pro, WinPatrol Plus and Sandboxie with Firefox add-ons like Noscript, Adlbock Plus and WOT.
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26306
