Unknown Problem
Unknown Problem
Post by aww1157 on 4th June 2010, 11:18 pm
Hi, My computer, running XP3, has been failing to connect to several websites. Other than that, it seems to be running OK. I downloaded OTL and attempted to run the scan twice but it keeps freezing up and will not complete the scan. I attempted to download and run HiJackThis but it would not install. Any suggestions?
Thanks!!
aww1157
Posts Posts : 64
Joined Joined : 2009-01-23
OS OS : Windows XP SP2
Points Points : 29243
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 4:07 am
Forgot to mention, I have run Avira scans and Malwarebytes, both came out clean.
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 5th June 2010, 5:52 pm
Posts Posts : 14309
Points Points : 302970
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 8:13 pm
Sent you a PM Jay. Thanks
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 5th June 2010, 8:43 pm
Please download MySystem-Search from one of the following links:
  • Save the file to your Desktop.
  • Double-click on mss.exe
  • Allow it to run, and follow the prompts.
  • Once done, it will launch a log.
  • Post it in your next reply.
Note: the logs are long. Please use more than one post, if necessary.
Posts Posts : 14309
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:15 pm
MySystem-Search
Run on 06/05/2010 at 15:49:02
MSS v1.2
Basic System Information
Host Name: WINTEC
OS Name: Microsoft Windows XP Professional
OS Version: 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Owner
Registered Organization: Owner
Product ID: 76487-OEM-0081336-89780
Original Install Date: 12/31/2004, 11:13:02 PM
System Up Time: 4 Days, 19 Hours, 55 Minutes, 31 Seconds
System Manufacturer: FOXCON
System Model: AWRDACPI
System type: X86-based PC
Processor(s): 1 Processor(s) Installed.
[01]: x86 Family 15 Model 4 Stepping 3 GenuineIntel ~3000 Mhz
BIOS Version: FOXCON - 42302e31
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
System Locale: en-us;English (United States)
Input Locale: en-us;English (United States)
Time Zone: (GMT-08:00) Pacific Time (US & Canada)
Total Physical Memory: 2,038 MB
Available Physical Memory: 1,413 MB
Virtual Memory: Max Size: 2,048 MB
Virtual Memory: Available: 2,008 MB
Virtual Memory: In Use: 40 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\WINTEC
Hotfix(s): 270 Hotfix(s) Installed.
[01]: File 1
[02]: File 1
[03]: File 1
[04]: File 1
[05]: File 1
[06]: File 1
[07]: File 1
[08]: File 1
[09]: File 1
[10]: File 1
[11]: File 1
[12]: File 1
[13]: File 1
[14]: File 1
[15]: File 1
[16]: File 1
[17]: File 1
[18]: File 1
[19]: File 1
[20]: File 1
[21]: File 1
[22]: File 1
[23]: File 1
[24]: File 1
[25]: File 1
[26]: File 1
[27]: File 1
[28]: File 1
[29]: File 1
[30]: File 1
[31]: File 1
[32]: File 1
[33]: File 1
[34]: File 1
[35]: File 1
[36]: File 1
[37]: File 1
[38]: File 1
[39]: File 1
[40]: File 1
[41]: File 1
[42]: File 1
[43]: File 1
[44]: File 1
[45]: File 1
[46]: File 1
[47]: File 1
[48]: File 1
[49]: File 1
[50]: File 1
[51]: File 1
[52]: File 1
[53]: File 1
[54]: File 1
[55]: File 1
[56]: File 1
[57]: File 1
[58]: File 1
[59]: File 1
[60]: File 1
[61]: File 1
[62]: File 1
[63]: File 1
[64]: File 1
[65]: File 1
[66]: File 1
[67]: File 1
[68]: File 1
[69]: File 1
[70]: File 1
[71]: File 1
[72]: File 1
[73]: File 1
[74]: File 1
[75]: File 1
[76]: File 1
[77]: File 1
[78]: File 1
[79]: File 1
[80]: File 1
[81]: File 1
[82]: File 1
[83]: File 1
[84]: File 1
[85]: File 1
[86]: File 1
[87]: File 1
[88]: File 1
[89]: File 1
[90]: File 1
[91]: File 1
[92]: File 1
[93]: File 1
[94]: File 1
[95]: File 1
[96]: File 1
[97]: File 1
[98]: File 1
[99]: File 1
[100]: File 1
[101]: File 1
[102]: File 1
[103]: File 1
[104]: File 1
[105]: File 1
[106]: File 1
[107]: File 1
[108]: File 1
[109]: File 1
[110]: File 1
[111]: File 1
[112]: File 1
[113]: File 1
[114]: File 1
[115]: File 1
[116]: File 1
[117]: File 1
[118]: File 1
[119]: File 1
[120]: File 1
[121]: File 1
[122]: File 1
[123]: Q147222
[124]: KB887998 - QFE
[125]: KB930494 - QFE
[126]: KB953295 - QFE
[127]: SP3 - SP
[128]: M953297 - Update
[129]: S867460 - Update
[130]: KB900325 - Update
[131]: Q936181
[132]: Q954430
[133]: Q973688
[134]: IDNMitigationAPIs - Update
[135]: NLSDownlevelMapping - Update
[136]: KB929399
[137]: KB952069_WM9
[138]: KB954155_WM9
[139]: KB968816_WM9
[140]: KB973540_WM9
[141]: KB917734_WMP10
[142]: KB936782_WMP10
[143]: KB939683
[144]: KB954154_WM11
[145]: KB925398_WMP64
[146]: KB923689
[147]: KB941569
[148]: KB928090-IE7 - Update
[149]: KB929969 - Update
[150]: KB931768-IE7 - Update
[151]: KB933566-IE7 - Update
[152]: KB937143-IE7 - Update
[153]: KB938127-IE7 - Update
[154]: KB939653-IE7 - Update
[155]: KB942615-IE7 - Update
[156]: KB944533-IE7 - Update
[157]: KB947864-IE7 - Update
[158]: KB950759-IE7 - Update
[159]: KB953838-IE7 - Update
[160]: KB963027-IE7 - Update
[161]: KB969897-IE7 - Update
[162]: KB972260-IE7 - Update
[163]: KB974455-IE7 - Update
[164]: KB976325-IE7 - Update
[165]: KB976749-IE7 - Update
[166]: KB978207-IE7 - Update
[167]: KB980182-IE7 - Update
[168]: KB971513 - Update
[169]: MSCompPackV1 - Update
[170]: KB936929 - Service Pack
[171]: KB952011 - Update
[172]: KB953295 - Update
[173]: KB915800-v4 - Update
[174]: KB923561 - Update
[175]: KB938464 - Update
[176]: KB938464-v2 - Update
[177]: KB946648 - Update
[178]: KB950760 - Update
[179]: KB950762 - Update
[180]: KB950974 - Update
[181]: KB951066 - Update
[182]: KB951072-v2 - Update
[183]: KB951376 - Update
[184]: KB951376-v2 - Update
[185]: KB951698 - Update
[186]: KB951748 - Update
[187]: KB951978 - Update
[188]: KB952004 - Update
[189]: KB952287 - Update
[190]: KB952954 - Update
[191]: KB953839 - Update
[192]: KB954211 - Update
[193]: KB954550-v5 - Update
[194]: KB954600 - Update
[195]: KB955069 - Update
[196]: KB955759 - Update
[197]: KB955839 - Update
[198]: KB956391 - Update
[199]: KB956572 - Update
[200]: KB956744 - Update
[201]: KB956802 - Update
[202]: KB956803 - Update
[203]: KB956841 - Update
[204]: KB956844 - Update
[205]: KB957095 - Update
[206]: KB957097 - Update
[207]: KB958644 - Update
[208]: KB958687 - Update
[209]: KB958690 - Update
[210]: KB958869 - Update
[211]: KB959426 - Update
[212]: KB960225 - Update
[213]: KB960715 - Update
[214]: KB960803 - Update
[215]: KB960859 - Update
[216]: KB961118 - Update
[217]: KB961371 - Update
[218]: KB961373 - Update
[219]: KB961501 - Update
[220]: KB967715 - Update
[221]: KB968389 - U
NetWork Card(s): 2 NIC(s) Installed.
[01]: Realtek RTL8139/810x Family Fast Ethernet NIC
Connection Name: Local Area Connection
Status: Media disconnected
[02]: Compact Wireless-G USB Adapter
Connection Name: Wireless Network Connection 4
DHCP Enabled: Yes
DHCP Server: 192.168.1.1
IP address(es)
[01]: 192.168.1.101
CD Emulation Drivers running?
Peer-to-Peer applications?
File associations
.exe=exefile
.scr=scrfile
.pif=piffile
.com=comfile
.bat=batfile
.cmd=cmdfile
.log=txtfile
.txt=txtfile
.reg=regfile
.sys=sysfile
.dll=dllfile
Running processes
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:17 pm
Image Name PID Session Name Session# Mem Usage
System Idle Process 0 Console 0 28 K
System 4 Console 0 236 K
smss.exe 756 Console 0 416 K
csrss.exe 816 Console 0 5,504 K
winlogon.exe 840 Console 0 5,020 K
services.exe 884 Console 0 3,340 K
lsass.exe 896 Console 0 8,492 K
svchost.exe 1104 Console 0 5,760 K
svchost.exe 1148 Console 0 5,104 K
svchost.exe 1292 Console 0 42,996 K
svchost.exe 1508 Console 0 6,896 K
spoolsv.exe 1700 Console 0 6,888 K
sched.exe 1756 Console 0 796 K
avguard.exe 1780 Console 0 15,968 K
svchost.exe 1852 Console 0 3,500 K
mDNSResponder.exe 416 Console 0 3,692 K
cisvc.exe 428 Console 0 188 K
ehRecvr.exe 488 Console 0 4,636 K
ehSched.exe 584 Console 0 4,628 K
jqs.exe 672 Console 0 1,400 K
MDM.EXE 712 Console 0 3,012 K
SMAgent.exe 776 Console 0 1,824 K
svchost.exe 812 Console 0 6,432 K
svchost.exe 800 Console 0 4,348 K
WLService.exe 1184 Console 0 1,648 K
searchindexer.exe 1232 Console 0 13,964 K
WUSB54GC.exe 1240 Console 0 19,480 K
alg.exe 2212 Console 0 3,732 K
explorer.exe 2660 Console 0 31,988 K
ehtray.exe 3528 Console 0 1,844 K
igfxtray.exe 3596 Console 0 3,568 K
hkcmd.exe 3660 Console 0 3,008 K
ehmsas.exe 3976 Console 0 2,696 K
igfxpers.exe 284 Console 0 2,888 K
svchost.exe 1728 Console 0 3,532 K
SMax4PNP.exe 1480 Console 0 4,148 K
SMax4.exe 2376 Console 0 4,140 K
issch.exe 2424 Console 0 1,548 K
QTTask.exe 2716 Console 0 2,508 K
hpztsb09.exe 2752 Console 0 3,028 K
hpcmpmgr.exe 3088 Console 0 8,532 K
hpwuSchd2.exe 3136 Console 0 5,528 K
hphmon05.exe 3332 Console 0 4,708 K
jusched.exe 3356 Console 0 2,868 K
avgnt.exe 3440 Console 0 1,552 K
msmsgs.exe 3788 Console 0 2,144 K
ctfmon.exe 3868 Console 0 4,288 K
HPZipm12.exe 3904 Console 0 2,224 K
AWC.exe 444 Console 0 25,544 K
dllhost.exe 2248 Console 0 6,316 K
WindowsSearch.exe 2584 Console 0 10,432 K
cidaemon.exe 3952 Console 0 472 K
ISUSPM.exe 2240 Console 0 14,924 K
agent.exe 2076 Console 0 3,976 K
searchprotocolhost.exe 624 Console 0 5,256 K
searchfilterhost.exe 1412 Console 0 4,484 K
mss.exe 3780 Console 0 2,496 K
cmd.exe 3852 Console 0 1,784 K
wmiprvse.exe 1808 Console 0 8,468 K
wmiprvse.exe 168 Console 0 4,968 K
tasklist.exe 3576 Console 0 4,588 K
Hidden objects
PATH: C:\windows
$hf_mig$
$MSI31Uninstall_KB893803v2$
$NtServicePackUninstall$
$NtServicePackUninstallIDNMitigationAPIs$
$NtServicePackUninstallNLSDownlevelMapping$
$NtUninstallbasecsp$
$NtUninstallKB873333$
$NtUninstallKB873339$
$NtUninstallKB885250$
$NtUninstallKB885835$
$NtUninstallKB885836$
$NtUninstallKB886185$
$NtUninstallKB887472$
$NtUninstallKB887742$
$NtUninstallKB887998$
$NtUninstallKB888113$
$NtUninstallKB888302$
$NtUninstallKB890046$
$NtUninstallKB890859$
$NtUninstallKB891781$
$NtUninstallKB893066$
$NtUninstallKB893086$
$NtUninstallKB893756$
$NtUninstallKB894391$
$NtUninstallKB896358$
$NtUninstallKB896422$
$NtUninstallKB896423$
$NtUninstallKB896424$
$NtUninstallKB896428$
$NtUninstallKB896727$
$NtUninstallKB898461$
$NtUninstallKB899587$
$NtUninstallKB899588$
$NtUninstallKB899589$
$NtUninstallKB899591$
$NtUninstallKB900325$
$NtUninstallKB900485$
$NtUninstallKB900725$
$NtUninstallKB901017$
$NtUninstallKB901214$
$NtUninstallKB902344$
$NtUninstallKB902400$
$NtUninstallKB903157$
$NtUninstallKB904706$
$NtUninstallKB904942$
$NtUninstallKB905414$
$NtUninstallKB905749$
$NtUninstallKB908519$
$NtUninstallKB908531$
$NtUninstallKB910437$
$NtUninstallKB911280$
$NtUninstallKB911562$
$NtUninstallKB911567$
$NtUninstallKB911927$
$NtUninstallKB912919$
$NtUninstallKB913580$
$NtUninstallKB914388$
$NtUninstallKB914389$
$NtUninstallKB914440$
$NtUninstallKB915800-v4$
$NtUninstallKB915865$
$NtUninstallKB916281$
$NtUninstallKB916595$
$NtUninstallKB917159$
$NtUninstallKB917344$
$NtUninstallKB917422$
$NtUninstallKB917734_WMP10$
$NtUninstallKB917953$
$NtUninstallKB918118$
$NtUninstallKB918439$
$NtUninstallKB918899$
$NtUninstallKB918899_0$
$NtUninstallKB919007$
$NtUninstallKB920213$
$NtUninstallKB920214$
$NtUninstallKB920670$
$NtUninstallKB920683$
$NtUninstallKB920685$
$NtUninstallKB920872$
$NtUninstallKB921398$
$NtUninstallKB921503$
$NtUninstallKB921883$
$NtUninstallKB922582$
$NtUninstallKB922616$
$NtUninstallKB922819$
$NtUninstallKB923191$
$NtUninstallKB923414$
$NtUninstallKB923561$
$NtUninstallKB923561_0$
$NtUninstallKB923689$
$NtUninstallKB923694$
$NtUninstallKB923980$
$NtUninstallKB924191$
$NtUninstallKB924270$
$NtUninstallKB924496$
$NtUninstallKB924496_0$
$NtUninstallKB924667$
$NtUninstallKB925398_WMP64$
$NtUninstallKB925486$
$NtUninstallKB925720$
$NtUninstallKB925766$
$NtUninstallKB925902$
$NtUninstallKB926255$
$NtUninstallKB926436$
$NtUninstallKB927779$
$NtUninstallKB927802$
$NtUninstallKB927891$
$NtUninstallKB928255$
$NtUninstallKB928843$
$NtUninstallKB929123$
$NtUninstallKB929338$
$NtUninstallKB929399$
$NtUninstallKB930178$
$NtUninstallKB930494$
$NtUninstallKB930916$
$NtUninstallKB931261$
$NtUninstallKB931784$
$NtUninstallKB931836$
$NtUninstallKB932168$
$NtUninstallKB932823-v3$
$NtUninstallKB933360$
$NtUninstallKB933729$
$NtUninstallKB935839$
$NtUninstallKB935840$
$NtUninstallKB936021$
$NtUninstallKB936357$
$NtUninstallKB936782_WMP10$
$NtUninstallKB937894$
$NtUninstallKB938464$
$NtUninstallKB938464-v2$
$NtUninstallKB938464_0$
$NtUninstallKB938828$
$NtUninstallKB938829$
$NtUninstallKB939683$
$NtUninstallKB940157$
$NtUninstallKB941202$
$NtUninstallKB941568$
$NtUninstallKB941569$
$NtUninstallKB941644$
$NtUninstallKB941693$
$NtUninstallKB942763$
$NtUninstallKB943055$
$NtUninstallKB943460$
$NtUninstallKB943485$
$NtUninstallKB943729$
$NtUninstallKB944653$
$NtUninstallKB945553$
$NtUninstallKB946026$
$NtUninstallKB946648$
$NtUninstallKB946648_0$
$NtUninstallKB948590$
$NtUninstallKB948881$
$NtUninstallKB950749$
$NtUninstallKB950760$
$NtUninstallKB950762$
$NtUninstallKB950762_0$
$NtUninstallKB950974$
$NtUninstallKB950974_0$
$NtUninstallKB951066$
$NtUninstallKB951066_0$
$NtUninstallKB951072-v2$
$NtUninstallKB951376$
$NtUninstallKB951376-v2$
$NtUninstallKB951376-v2_0$
$NtUninstallKB951376_0$
$NtUninstallKB951698$
$NtUninstallKB951698_0$
$NtUninstallKB951748$
$NtUninstallKB951748_0$
$NtUninstallKB951978$
$NtUninstallKB952004$
$NtUninstallKB952004_0$
$NtUninstallKB952011$
$NtUninstallKB952069_WM9$
$NtUninstallKB952287$
$NtUninstallKB952287_0$
$NtUninstallKB952954$
$NtUninstallKB952954_0$
$NtUninstallKB953295$
$NtUninstallKB953839$
$NtUninstallKB954154_WM11$
$NtUninstallKB954155_WM9$
$NtUninstallKB954211$
$NtUninstallKB954211_0$
$NtUninstallKB954459$
$NtUninstallKB954600$
$NtUninstallKB954600_0$
$NtUninstallKB955069$
$NtUninstallKB955069_0$
$NtUninstallKB955759$
$NtUninstallKB955839$
$NtUninstallKB956391$
$NtUninstallKB956572$
$NtUninstallKB956572_0$
$NtUninstallKB956744$
$NtUninstallKB956802$
$NtUninstallKB956802_0$
$NtUninstallKB956803$
$NtUninstallKB956803_0$
$NtUninstallKB956841$
$NtUninstallKB956841_0$
$NtUninstallKB956844$
$NtUninstallKB957095$
$NtUninstallKB957095_0$
$NtUninstallKB957097$
$NtUninstallKB957097_0$
$NtUninstallKB958644$
$NtUninstallKB958644_0$
$NtUninstallKB958687$
$NtUninstallKB958687_0$
$NtUninstallKB958690$
$NtUninstallKB958690_0$
$NtUninstallKB958869$
$NtUninstallKB959426$
$NtUninstallKB959426_0$
$NtUninstallKB960225$
$NtUninstallKB960225_0$
$NtUninstallKB960715$
$NtUninstallKB960803$
$NtUninstallKB960803_0$
$NtUninstallKB960859$
$NtUninstallKB961118$
$NtUninstallKB961118_0$
$NtUninstallKB961371$
$NtUninstallKB961373$
$NtUninstallKB961373_0$
$NtUninstallKB961501$
$NtUninstallKB963093$
$NtUninstallKB967715$
$NtUninstallKB967715_0$
$NtUninstallKB968389$
$NtUninstallKB968537$
$NtUninstallKB968816_WM9$
$NtUninstallKB969059$
$NtUninstallKB969898$
$NtUninstallKB969947$
$NtUninstallKB970238$
$NtUninstallKB970430$
$NtUninstallKB970653-v3$
$NtUninstallKB971468$
$NtUninstallKB971486$
$NtUninstallKB971513$
$NtUninstallKB971557$
$NtUninstallKB971633$
$NtUninstallKB971657$
$NtUninstallKB971737$
$NtUninstallKB971961$
$NtUninstallKB972270$
$NtUninstallKB973346$
$NtUninstallKB973354$
$NtUninstallKB973507$
$NtUninstallKB973525$
$NtUninstallKB973540_WM9$
$NtUninstallKB973687$
$NtUninstallKB973768$
$NtUninstallKB973815$
$NtUninstallKB973869$
$NtUninstallKB973904$
$NtUninstallKB974112$
$NtUninstallKB974318$
$NtUninstallKB974392$
$NtUninstallKB974571$
$NtUninstallKB975025$
$NtUninstallKB975467$
$NtUninstallKB975560$
$NtUninstallKB975561$
$NtUninstallKB975713$
$NtUninstallKB976098-v2$
$NtUninstallKB977165-v2$
$NtUninstallKB977816$
$NtUninstallKB977914$
$NtUninstallKB978037$
$NtUninstallKB978251$
$NtUninstallKB978262$
$NtUninstallKB978338$
$NtUninstallKB978542$
$NtUninstallKB978601$
$NtUninstallKB978706$
$NtUninstallKB979306$
$NtUninstallKB979309$
$NtUninstallKB979683$
$NtUninstallKB980232$
$NtUninstallKB981349$
$NtUninstallKB981793$
$NtUninstallMSCompPackV1$
$NtUninstallWIC$
$NtUninstallWMFDist11$
$NtUninstallwmp11$
$NtUninstallWudf01000$
ie7
inf
Installer
msdownld.tmp
WindowsShell.Manifest
aww1157
Posts Posts : 64
Re: Unknown Problem
PATH: C:\windows\system32
7DB1AFB434.sys
cdplayer.exe.manifest
dllcache
KGyGaAvL.sys
logonui.exe.manifest
mlfcache.dat
ncpa.cpl.manifest
nwc.cpl.manifest
sapi.cpl.manifest
Scrnscps.GID
WindowsLogon.manifest
wuaucpl.cpl.manifest
PATH: C:\windows\system32\drivers
PATH: C:\
boot.ini
boot.ini.whitecanyon
ehthumbs.db
hiberfil.sys
IO.SYS
MSDOS.SYS
MSOCache
NTDETECT.COM
ntldr
pagefile.sys
RECYCLER
System Volume Information
User Profile check
public
! REG.EXE VERSION 3.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
ProfilesDirectory REG_EXPAND_SZ %SystemDrive%\Documents and Settings
DefaultUserProfile REG_SZ Default User
AllUsersProfile REG_SZ All Users
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-18
Flags REG_DWORD 0xc
State REG_DWORD 0x0
RefCount REG_DWORD 0x1
Sid REG_BINARY 010100000000000512000000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-19
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\LocalService
Sid REG_BINARY 010100000000000513000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
CentralProfile REG_SZ
ProfileLoadTimeLow REG_DWORD 0xaf392666
ProfileLoadTimeHigh REG_DWORD 0x1cb0135
RefCount REG_DWORD 0x4
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-20
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\NetworkService
Sid REG_BINARY 010100000000000514000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0xaf0bd9b8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-161134817-1714075396-1781636095-1003
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\default
Sid REG_BINARY 010500000000000515000000E1B89A0904B72A66FF9B316AEB030000
Flags REG_DWORD 0x0
State REG_DWORD 0x100
ProfileLoadTimeLow REG_DWORD 0x95cc1270
ProfileLoadTimeHigh REG_DWORD 0x1c9528f
RefCount REG_DWORD 0x0
RunLogonscriptSync REG_DWORD 0x0
OptimizedLogonStatus REG_DWORD 0xb
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-161134817-1714075396-1781636095-1004
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\Test
Sid REG_BINARY 010500000000000515000000E1B89A0904B72A66FF9B316AEC030000
Flags REG_DWORD 0x0
State REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0x5c0db250
ProfileLoadTimeHigh REG_DWORD 0x1c5c908
NextLogonCacheable REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-161134817-1714075396-1781636095-1005
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\test2
Sid REG_BINARY 010500000000000515000000E1B89A0904B72A66FF9B316AED030000
Flags REG_DWORD 0x0
State REG_DWORD 0x4
ProfileLoadTimeLow REG_DWORD 0x663a39b8
ProfileLoadTimeHigh REG_DWORD 0x1c5c90a
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-161134817-1714075396-1781636095-1010
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\Owner
Sid REG_BINARY 010500000000000515000000E1B89A0904B72A66FF9B316AF2030000
Flags REG_DWORD 0x1
ProfileLoadTimeLow REG_DWORD 0xbe6e8680
RefCount REG_DWORD 0x2
NextLogonCacheable REG_DWORD 0x0
Current Scheduled Tasks
PATH: C:\Windows\Tasks
Ad-Aware Update (Weekly).job
Google Software Updater.job
HP Usg Daily.job
desktop.ini
Microsoft_Hardware_Launch_IType_exe.job
SA.DAT
Windows Drivers and NT-Services
Volume in drive C has no label.
Volume Serial Number is A4EE-8BEA
09/10/1999 12:06 PM 25,244 ASPI32.SYS
08/17/2001 06:59 AM 3,072 audstub.sys
08/17/2001 01:51 PM 3,328 pciide.sys
08/17/2001 02:48 PM 12,160 mouhid.sys
01/06/2004 12:58 AM 69,575 HidCom.sys
07/17/2004 11:35 AM 67,866 netwlan5.img
07/17/2004 11:36 AM 64,352 ativmc20.cod
07/17/2004 10:55 PM 129,045 cxthsfs2.cty
08/03/2004 03:31 PM 20,992 RTL8139.sys
08/03/2004 10:29 PM 57,856 atinbtxx.sys
08/03/2004 10:29 PM 701,440 ati2mtag.sys
08/03/2004 10:29 PM 327,040 ati2mtaa.sys
08/03/2004 10:29 PM 11,615 ati1mdxx.sys
08/03/2004 10:29 PM 12,047 ati1pdxx.sys
08/03/2004 10:29 PM 52,224 atinraxx.sys
08/03/2004 10:29 PM 56,623 ati1btxx.sys
08/03/2004 10:29 PM 13,824 atinmdxx.sys
08/03/2004 10:29 PM 14,336 atinpdxx.sys
08/03/2004 10:29 PM 31,744 atinxbxx.sys
08/03/2004 10:29 PM 73,216 atintuxx.sys
08/03/2004 10:29 PM 13,824 atinttxx.sys
08/03/2004 10:29 PM 28,672 atinsnxx.sys
08/03/2004 10:29 PM 26,367 ati1snxx.sys
08/03/2004 10:29 PM 104,960 atinrvxx.sys
08/03/2004 10:29 PM 21,343 ati1ttxx.sys
08/03/2004 10:29 PM 29,455 ati1xbxx.sys
08/03/2004 10:29 PM 34,735 ati1xsxx.sys
08/03/2004 10:29 PM 36,463 ati1tuxx.sys
08/03/2004 10:29 PM 30,671 ati1raxx.sys
08/03/2004 10:29 PM 63,663 ati1rvxx.sys
08/03/2004 10:29 PM 63,488 atinxsxx.sys
08/03/2004 10:29 PM 452,736 mtxparhm.sys
08/03/2004 10:29 PM 11,295 wadv08nt.sys
08/03/2004 10:29 PM 11,807 wadv07nt.sys
08/03/2004 10:29 PM 11,871 wadv09nt.sys
08/03/2004 10:29 PM 11,935 wadv11nt.sys
08/03/2004 10:29 PM 25,471 watv10nt.sys
08/03/2004 10:29 PM 22,271 watv06nt.sys
08/03/2004 10:29 PM 166,912 s3gnbm.sys
08/03/2004 10:29 PM 1,897,408 nv4_mini.sys
08/03/2004 10:41 PM 1,309,184 mtlstrm.sys
08/03/2004 10:41 PM 13,776 recagent.sys
08/03/2004 10:41 PM 126,686 mtlmnt5.sys
08/03/2004 10:41 PM 180,360 ntmtlfax.sys
08/03/2004 10:41 PM 129,535 slnt7554.sys
08/03/2004 10:41 PM 404,990 slntamr.sys
08/03/2004 10:41 PM 95,424 slnthal.sys
08/03/2004 10:41 PM 13,240 slwdmsup.sys
08/03/2004 10:41 PM 220,032 hsfbs2s2.sys
08/03/2004 10:41 PM 685,056 hsfcxts2.sys
08/03/2004 10:41 PM 11,868 mdmxsdk.sys
08/03/2004 10:41 PM 1,041,536 hsfdpsp2.sys
08/10/2004 03:45 AM 11,008 mhndrv.sys
08/10/2004 05:00 AM 352,256 atmuni.sys
08/10/2004 05:00 AM 31,360 atmepvc.sys
08/10/2004 05:00 AM 4,736 usbd.sys
08/10/2004 05:00 AM 58,112 vdmindvd.sys
08/10/2004 05:00 AM 646 gmreadme.txt
08/10/2004 05:00 AM 4,352 wmilib.sys
08/10/2004 05:00 AM 32,896 ipfltdrv.sys
08/10/2004 05:00 AM 125,056 ftdisk.sys
08/10/2004 05:00 AM 7,680 mcd.sys
08/10/2004 05:00 AM 12,160 fsvga.sys
08/10/2004 05:00 AM 4,224 beep.sys
08/10/2004 05:00 AM 5,888 rootmdm.sys
08/10/2004 05:00 AM 12,032 riodrv.sys
08/10/2004 05:00 AM 12,032 rio8drv.sys
08/10/2004 05:00 AM 3,440,660 gm.dls
08/10/2004 05:00 AM 4,224 rdpcdd.sys
08/10/2004 05:00 AM 34,432 rawwan.sys
08/10/2004 05:00 AM 16,512 raspti.sys
08/10/2004 05:00 AM 13,952 cbidf2k.sys
08/10/2004 05:00 AM 18,688 cdaudio.sys
08/10/2004 05:00 AM 8,832 rasacd.sys
08/10/2004 05:00 AM 21,376 tsbvcap.sys
08/10/2004 05:00 AM 17,792 ptilink.sys
08/10/2004 05:00 AM 262,528 cinemst2.sys
08/10/2004 05:00 AM 51,712 tosdvd.sys
08/10/2004 05:00 AM 11,776 cpqdap01.sys
08/10/2004 05:00 AM 2,944 null.sys
08/10/2004 05:00 AM 11,648 acpiec.sys
08/10/2004 05:00 AM 12,032 ws2ifsl.sys
08/10/2004 05:00 AM 7,936 fs_rec.sys
08/10/2004 05:00 AM 6,784 parvdm.sys
08/10/2004 05:00 AM 4,224 mnmdd.sys
08/10/2004 05:00 AM 3,456 oprghdlr.sys
08/10/2004 05:00 AM 55,936 nwlnkspx.sys
08/10/2004 05:00 AM 5,888 dmload.sys
08/10/2004 05:00 AM 63,232 nwlnknb.sys
08/10/2004 05:00 AM 32,512 nwlnkfwd.sys
08/10/2004 05:00 AM 12,416 nwlnkflt.sys
08/10/2004 05:00 AM 10,496 dxapi.sys
08/10/2004 05:00 AM 14,592 smclib.sys
08/10/2004 05:00 AM 3,328 dxgthk.sys
08/10/2004 05:00 AM 12,032 nikedrv.sys
08/10/2004 11:39 PM 41,984 DGIVECP.SYS
09/13/2004 09:00 AM 88,960 MidiSyn.sys
01/01/2005 10:16 PM 20,747 AegisP.sys
02/01/2005 07:18 PM 17,992 bcm42rly.sys
02/28/2005 09:01 PM 392,704 senfilt.sys
03/03/2005 08:10 PM 74,496 Rtlnicxp.sys
03/04/2005 04:53 AM 127,872 aeaudio.sys
03/28/2005 09:19 AM 220,992 smwdm.sys
04/24/2005 07:56 PM 889,628 ialmnt5.sys
09/21/2005 08:07 AM etc
11/17/2005 06:38 PM 2,048 rt73.bin
11/24/2005 07:51 PM 245,248 rt73.sys
09/28/2006 06:55 PM 77,568 WudfPf.sys
09/28/2006 07:00 PM 82,944 WudfRd.sys
10/18/2006 04:00 AM 36,624 pxhelp20.sys
10/18/2006 08:00 PM 38,528 wpdusb.sys
11/13/2007 03:25 AM 20,480 secdrv.sys
04/13/2008 09:36 AM 144,384 hdaudbus.sys
04/13/2008 09:39 AM 142,592 aec.sys
04/13/2008 11:31 AM 35,840 processr.sys
04/13/2008 11:31 AM 42,752 p3.sys
04/13/2008 11:31 AM 36,736 crusoe.sys
04/13/2008 11:31 AM 37,376 amdk6.sys
04/13/2008 11:31 AM 36,352 intelppm.sys
04/13/2008 11:31 AM 37,760 amdk7.sys
04/13/2008 11:32 AM 66,048 udfs.sys
04/13/2008 11:32 AM 19,072 msfs.sys
04/13/2008 11:32 AM 30,848 npfs.sys
04/13/2008 11:32 AM 180,608 mrxdav.sys
04/13/2008 11:32 AM 196,224 rdpdr.sys
04/13/2008 11:32 AM 129,792 fltmgr.sys
04/13/2008 11:33 AM 44,544 fips.sys
04/13/2008 11:34 AM 163,584 nwrdr.sys
04/13/2008 11:36 AM 5,888 smbali.sys
04/13/2008 11:36 AM 187,776 acpi.sys
04/13/2008 11:36 AM 42,368 agp440.sys
04/13/2008 11:36 AM 42,752 alim1541.sys
04/13/2008 11:36 AM 43,008 amdagp.sys
04/13/2008 11:36 AM 40,960 sisagp.sys
04/13/2008 11:36 AM 44,928 agpcpq.sys
04/13/2008 11:36 AM 44,672 uagp35.sys
04/13/2008 11:36 AM 42,240 viaagp.sys
04/13/2008 11:36 AM 46,464 gagp30kx.sys
04/13/2008 11:36 AM 37,248 isapnp.sys
04/13/2008 11:36 AM 63,744 mf.sys
04/13/2008 11:36 AM 120,192 pcmcia.sys
04/13/2008 11:36 AM 79,232 sdbus.sys
04/13/2008 11:36 AM 68,224 pci.sys
04/13/2008 11:36 AM 15,488 mssmbios.sys
04/13/2008 11:36 AM 73,472 sr.sys
04/13/2008 11:38 AM 71,168 dxg.sys
04/13/2008 11:39 AM 92,544 mqac.sys
04/13/2008 11:39 AM 384,768 update.sys
04/13/2008 11:39 AM 42,368 mountmgr.sys
04/13/2008 11:39 AM 23,040 mouclass.sys
04/13/2008 11:39 AM 24,576 kbdclass.sys
04/13/2008 11:39 AM 14,592 kbdhid.sys
04/13/2008 11:39 AM 5,376 mspclock.sys
04/13/2008 11:39 AM 4,992 mspqm.sys
04/13/2008 11:39 AM 7,552 mskssrv.sys
04/13/2008 11:39 AM 4,352 swenum.sys
04/13/2008 11:40 AM 80,128 parport.sys
04/13/2008 11:40 AM 15,744 serenum.sys
04/13/2008 11:40 AM 27,392 fdc.sys
04/13/2008 11:40 AM 20,480 flpydisk.sys
04/13/2008 11:40 AM 57,600 redbook.sys
04/13/2008 11:40 AM 24,960 pciidex.sys
04/13/2008 11:40 AM 5,504 intelide.sys
04/13/2008 11:40 AM 96,512 atapi.sys
04/13/2008 11:40 AM 96,384 scsiport.sys
04/13/2008 11:40 AM 14,208 diskdump.sys
04/13/2008 11:40 AM 62,976 cdrom.sys
04/13/2008 11:40 AM 11,008 sffp_sd.sys
04/13/2008 11:40 AM 11,904 sffdisk.sys
04/13/2008 11:40 AM 36,352 disk.sys
04/13/2008 11:40 AM 10,240 sffp_mmc.sys
04/13/2008 11:40 AM 11,392 sfloppy.sys
04/13/2008 11:40 AM 19,712 partmgr.sys
04/13/2008 11:40 AM 14,976 tape.sys
04/13/2008 11:40 AM 42,112 imapi.sys
04/13/2008 11:41 AM 52,352 volsnap.sys
04/13/2008 11:43 AM 12,672 mutohpen.sys
04/13/2008 11:43 AM 14,208 wacompen.sys
04/13/2008 11:44 AM 81,664 videoprt.sys
04/13/2008 11:44 AM 20,992 vga.sys
04/13/2008 11:44 AM 153,344 dmio.sys
04/13/2008 11:44 AM 799,744 dmboot.sys
04/13/2008 11:45 AM 52,864 dmusic.sys
04/13/2008 11:45 AM 6,272 splitter.sys
04/13/2008 11:45 AM 172,416 kmixer.sys
04/13/2008 11:45 AM 56,576 swmidi.sys
04/13/2008 11:45 AM 2,944 drmkaud.sys
04/13/2008 11:45 AM 60,160 drmk.sys
04/13/2008 11:45 AM 49,408 stream.sys
04/13/2008 11:45 AM 24,960 hidparse.sys
04/13/2008 11:45 AM 36,864 hidclass.sys
04/13/2008 11:45 AM 19,200 hidir.sys
04/13/2008 11:45 AM 10,368 hidusb.sys
04/13/2008 11:45 AM 46,592 irbus.sys
04/13/2008 11:45 AM 15,104 usbscan.sys
04/13/2008 11:45 AM 20,608 usbuhci.sys
04/13/2008 11:45 AM 30,208 usbehci.sys
04/13/2008 11:45 AM 143,872 usbport.sys
04/13/2008 11:45 AM 59,520 usbhub.sys
04/13/2008 11:45 AM 26,368 usbstor.sys
04/13/2008 11:45 AM 32,128 usbccgp.sys
04/13/2008 11:45 AM 25,600 usbcamd.sys
04/13/2008 11:45 AM 25,728 usbcamd2.sys
04/13/2008 11:45 AM 15,872 usbintel.sys
04/13/2008 11:46 AM 25,344 sonydcam.sys
04/13/2008 11:46 AM 121,984 usbvideo.sys
04/13/2008 11:46 AM 18,944 bthusb.sys
04/13/2008 11:46 AM 25,600 hidbth.sys
04/13/2008 11:46 AM 36,480 bthprint.sys
04/13/2008 11:46 AM 59,136 rfcomm.sys
04/13/2008 11:46 AM 37,888 bthmodem.sys
04/13/2008 11:46 AM 17,024 bthenum.sys
04/13/2008 11:47 AM 25,856 usbprint.sys
04/13/2008 11:51 AM 61,824 nic1394.sys
04/13/2008 11:51 AM 59,904 atmarpc.sys
04/13/2008 11:51 AM 60,800 arp1394.sys
04/13/2008 11:51 AM 55,808 atmlane.sys
04/13/2008 11:51 AM 101,120 bthpan.sys
04/13/2008 11:53 AM 40,320 nmnt.sys
04/13/2008 11:53 AM 71,552 bridge.sys
04/13/2008 11:53 AM 36,608 ip6fw.sys
04/13/2008 11:54 AM 11,264 irenum.sys
04/13/2008 11:55 AM 14,592 ndisuio.sys
04/13/2008 11:56 AM 12,288 tunmp.sys
04/13/2008 11:56 AM 34,688 netbios.sys
04/13/2008 11:56 AM 88,320 nwlnkipx.sys
04/13/2008 11:56 AM 35,072 msgpc.sys
04/13/2008 11:56 AM 69,120 psched.sys
04/13/2008 11:56 AM 12,800 usb8023x.sys
04/13/2008 11:56 AM 30,592 rndismpx.sys
04/13/2008 11:56 AM 30,592 rndismp.sys
04/13/2008 11:56 AM 12,800 usb8023.sys
04/13/2008 11:57 AM 20,864 ipinip.sys
04/13/2008 11:57 AM 152,832 ipnat.sys
04/13/2008 11:57 AM 34,560 wanarp.sys
04/13/2008 11:57 AM 10,112 ndistapi.sys
04/13/2008 11:57 AM 14,336 asyncmac.sys
04/13/2008 11:57 AM 40,576 ndproxy.sys
04/13/2008 11:57 AM 41,472 raspppoe.sys
04/13/2008 12:00 PM 19,072 tdi.sys
04/13/2008 12:00 PM 30,080 modem.sys
04/13/2008 12:14 PM 63,744 cdfs.sys
04/13/2008 12:14 PM 143,744 fastfat.sys
04/13/2008 12:15 PM 64,512 serial.sys
04/13/2008 12:15 PM 574,976 ntfs.sys
04/13/2008 12:15 PM 60,800 sysaudio.sys
04/13/2008 12:16 PM 49,536 classpnp.sys
04/13/2008 12:16 PM 141,056 ks.sys
04/13/2008 12:17 PM 105,344 mup.sys
04/13/2008 12:17 PM 83,072 wdmaud.sys
04/13/2008 12:18 PM 52,480 i8042prt.sys
04/13/2008 12:19 PM 146,048 portcls.sys
04/13/2008 12:19 PM 75,264 ipsec.sys
04/13/2008 12:19 PM 51,328 rasl2tp.sys
04/13/2008 12:19 PM 48,384 raspptp.sys
04/13/2008 12:20 PM 182,656 ndis.sys
04/13/2008 12:20 PM 91,520 ndiswan.sys
04/13/2008 12:21 PM 162,816 netbt.sys
04/13/2008 12:28 PM 175,744 rdbss.sys
04/13/2008 05:11 PM 3,647 adv07nt5.dll
04/13/2008 05:11 PM 3,135 adv08nt5.dll
04/13/2008 05:11 PM 3,615 adv05nt5.dll
04/13/2008 05:11 PM 4,255 adv01nt5.dll
04/13/2008 05:11 PM 3,967 adv02nt5.dll
04/13/2008 05:11 PM 3,775 adv11nt5.dll
04/13/2008 05:11 PM 3,711 adv09nt5.dll
04/13/2008 05:11 PM 17,279 atv10nt5.dll
04/13/2008 05:11 PM 14,143 atv06nt5.dll
04/13/2008 05:11 PM 21,183 atv01nt5.dll
04/13/2008 05:11 PM 11,359 atv02nt5.dll
04/13/2008 05:11 PM 25,471 atv04nt5.dll
04/13/2008 05:11 PM 15,423 ch7xxnt5.dll
04/13/2008 05:12 PM 3,901 siint5.dll
04/13/2008 05:12 PM 11,325 vchnt5.dll
04/13/2008 05:13 PM 12,040 tdpipe.sys
04/13/2008 05:13 PM 40,840 termdd.sys
04/13/2008 05:13 PM 21,896 tdtcp.sys
04/13/2008 05:13 PM 139,656 rdpwd.sys
05/08/2008 07:02 AM 203,136 rmcast.sys
06/13/2008 04:05 AM 272,128 bthport.sys
06/20/2008 04:51 AM 361,600 tcpip.sys
08/14/2008 03:04 AM 138,496 afd.sys
02/13/2009 12:17 PM 45,416 avgntdd.sys
02/13/2009 12:29 PM 22,360 avgntmgr.sys
03/25/2009 06:29 AM 130,432 Rtnicxp.sys
03/30/2009 10:33 AM 96,104 avipbb.sys
05/11/2009 10:12 AM 28,520 ssmdrv.sys
06/24/2009 04:18 AM 92,928 ksecdd.sys
08/26/2009 10:40 PM 21,568 HPZius12.sys
08/26/2009 10:41 PM 16,496 HPZipr12.sys
08/26/2009 10:41 PM 49,920 HPZid412.sys
09/08/2009 09:33 AM disdn
10/20/2009 09:20 AM 265,728 http.sys
11/25/2009 12:19 PM 56,816 avgntflt.sys
12/31/2009 09:50 AM 353,792 srv.sys
02/11/2010 05:02 AM 226,880 tcpip6.sys
02/24/2010 06:11 AM 455,680 mrxsmb.sys
04/05/2010 09:45 PM UMDF
04/29/2010 03:39 PM 20,952 mbam.sys
04/29/2010 03:39 PM 38,224 mbamswissarmy.sys
05/21/2010 11:20 AM .
05/21/2010 11:20 AM ..
297 File(s) 29,109,559 bytes
5 Dir(s) 135,971,717,120 bytes free
Virtual drives found?
Environment variables
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Owner\Application Data
CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=WINTEC
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Owner
LOGONSERVER=\\WINTEC
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime\QTSystem\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 3, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0403
PROMPT=$P$G
QTJAVA=C:\Program Files\Java\jre6\lib\ext\QTJava.zip
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
TMP=C:\DOCUME~1\Owner\LOCALS~1\Temp
USERDOMAIN=WINTEC
USERNAME=Owner
USERPROFILE=C:\Documents and Settings\Owner
windir=C:\WINDOWS
Stealth malware?
Internet Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main
Default_Page_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
Default_Search_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Search Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Enable_Disk_Cache REG_SZ yes
Cache_Percent_of_Disk REG_BINARY 0A000000
Delete_Temp_Files_On_Exit REG_SZ yes
Local Page REG_EXPAND_SZ %SystemRoot%\system32\blank.htm
Anchor_Visitation_Horizon REG_BINARY 01000000
Use_Async_DNS REG_SZ yes
Placeholder_Width REG_BINARY 1A000000
Placeholder_Height REG_BINARY 1A000000
Start Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
CompanyName REG_SZ Microsoft Corporation
Custom_Key REG_SZ MICROSO
Wizard_Version REG_SZ 6.0.2600.0000
Default_Secondary_Page_URL REG_MULTI_SZ \0\0
Extensions Off Page REG_SZ about:NoAdd-ons
Security Risk Page REG_SZ about:SecurityRisk
Check_Associations REG_SZ yes
IEWatsonDisable REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\ErrorThresholds
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
User Agent REG_SZ Mozilla/4.0 (compatible; MSIE 7.0; Win32)
IE5_UA_Backup_Flag REG_SZ 5.0
NoNetAutodial REG_DWORD 0x0
MigrateProxy REG_DWORD 0x1
EnableNegotiate REG_DWORD 0x1
ProxyEnable REG_DWORD 0x0
EmailName REG_SZ IEUser@
AutoConfigProxy REG_SZ wininet.dll
MimeExclusionListForCache REG_SZ multipart/mixed multipart/x-mixed-replace multipart/x-byteranges
WarnOnPost REG_BINARY 01000000
UseSchannelDirectly REG_BINARY 01000000
EnableHttp1_1 REG_DWORD 0x1
SecureProtocols REG_DWORD 0xa0
PrivDiscUiShown REG_DWORD 0x1
PrivacyAdvanced REG_DWORD 0x0
WarnonZoneCrossing REG_DWORD 0x0
EnableAutodial REG_DWORD 0x0
WarnOnIntranet REG_DWORD 0x0
ProxyHttp1.1 REG_DWORD 0x1
ShowPunycode REG_DWORD 0x0
EnablePunycode REG_DWORD 0x1
UrlEncoding REG_DWORD 0x0
DisableIDNPrompt REG_DWORD 0x0
CertificateRevocation REG_DWORD 0x0
DisableCachingOfSSLPages REG_DWORD 0x0
WarnonBadCertRecving REG_DWORD 0x1
WarnOnPostRedirect REG_DWORD 0x1
MaxConnectionsPerServer REG_DWORD 0xa
MaxConnectionsPer1_0Server REG_DWORD 0xa
ProxyOverride REG_SZ *.local
SyncMode5 REG_DWORD 0x4
GlobalUserOffline REG_DWORD 0x0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Lockdown_Zones
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\P3P
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Protocols
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main
Disable script Debugger REG_SZ yes
Search Page REG_SZ
Anchor Underline REG_SZ yes
Cache_Update_Frequency REG_SZ Once_Per_Session
Display Inline Images REG_SZ yes
Do404Search REG_BINARY 01000000
Local Page REG_SZ C:\WINDOWS\system32\blank.htm
Save_Session_History_On_Exit REG_SZ no
Show_FullURL REG_SZ no
Show_StatusBar REG_SZ yes
Show_ToolBar REG_SZ yes
Show_URLinStatusBar REG_SZ yes
Show_URLToolBar REG_SZ yes
Use_DlgBox_Colors REG_SZ yes
XMLHTTP REG_DWORD 0x1
UseClearType REG_SZ no
SearchMigrated REG_DWORD 0x1
SearchMigratedDefaultName REG_SZ Yahoo! Search
SearchMigratedDefaultURL REG_SZ http://search.yahoo.com/search?p={searchTerms}&ei=utf-8&fr=b1ie7
Expand Alt Text REG_SZ no
Move System Caret REG_SZ no
NoUpdateCheck REG_DWORD 0x1
NscSingleExpand REG_DWORD 0x0
DisablescriptDebuggerIE REG_SZ yes
Error Dlg Displayed On Every Error REG_SZ no
Page_Transitions REG_DWORD 0x1
FavIntelliMenus REG_SZ no
Enable Browser Extensions REG_SZ yes
UseThemes REG_DWORD 0x1
EnableSearchPane REG_DWORD 0x0
Force Offscreen Composition REG_DWORD 0x0
NotifyDownloadComplete REG_SZ yes
AllowWindowReuse REG_DWORD 0x1
Enable AutoImageResize REG_SZ yes
Play_Animations REG_SZ yes
Play_Background_Sounds REG_SZ yes
Show image placeholders REG_DWORD 0x0
Print_Background REG_SZ no
AutoSearch REG_DWORD 0x4
FullScreen REG_SZ no
Window_Placement REG_BINARY 2C0000000200000003000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A0100000D000000B7030000D7020000
CompatibilityFlags REG_DWORD 0x0
SearchMigratedInstalled REG_DWORD 0x1
RunOnceHasShown REG_DWORD 0x1
RunOnceComplete REG_DWORD 0x1
Start Page REG_SZ http://www.google.com/
FormSuggest PW Ask REG_SZ no
Use FormSuggest REG_SZ no
AutoHide REG_SZ yes
AlwaysShowMenus REG_DWORD 0x1
StatusBarWeb REG_DWORD 0x0
Friendly http errors REG_SZ no
SmoothScroll REG_DWORD 0x0
Use StyleSheets REG_SZ yes
Use Search Asst REG_SZ
Search Bar REG_SZ
SearchAssistant REG_SZ
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Default Feeds
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks
{CFBFAE00-17A6-11D0-99CB-00C04FD64497} REG_SZ
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F0626A63-410B-45E2-99A1-3F2475B2D695}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar
{2318C2B1-4965-11d4-9B18-009027A5CD4F} REG_BINARY 00
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar\QuickComplete
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\MenuExt
Security Center
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:19 pm
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
NoRemove REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Acrobat 4.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe AIR
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Shockwave Player
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Advanced SystemCare 3_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Amazon MP3 Downloader
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Avira AntiVir Desktop
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Branding
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\CCleaner
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Connection Manager
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DirectDrawEx
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DXM_Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Easy DVD Shrink
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fontcore
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Google Updater
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IDNMitigationAPIs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE40
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE4Data
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE5BAKEX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ie7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IEData
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IncrediMail
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\InstallShield Uninstall Information
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884267
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB885353
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB886612
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887078
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887626
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB888656
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB889858
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB891122
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB892130
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB892313
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893240
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893241
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895181
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895316
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895572
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB897586
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB898549
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB900325
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB900399
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB902344
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB903157
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB907658
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB909520
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB911565
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB911854
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB913433
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB915800-v4
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB917734_WMP10
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB923561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB923689
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB925398_WMP64
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB925766
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB928090-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB929399
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB929969
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB931768-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB931906
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB933566-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB936782_WMP10
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB937143-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB938127-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB938464
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB938464-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB939653-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB939683
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB940157
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB941569
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB942615-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB943729
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB944533-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB946648
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB947864-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950759-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950760
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950762
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950974
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951066
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951072-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951376
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951376-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951698
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951978
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952004
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952011
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952069_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952287
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952954
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB953295
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB953838-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB953839
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954154_WM11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954155_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954211
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954459
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954550-v5
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954600
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955069
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955759
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955839
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956390-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956391
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956572
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956744
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956802
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956841
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956844
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB957095
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB957097
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958644
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958690
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB959426
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960225
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960715
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960859
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961118
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961371
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961373
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961501
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB963027-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB963093
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB967715
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968389
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968537
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968816_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969059
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969897-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969898
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969947
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970238
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970430
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970653-v3
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971468
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971486
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971513
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971557
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971633
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971657
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971737
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971961
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972260-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972270
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973346
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973354
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973507
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973525
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973540_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973768
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973815
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973904
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974112
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974318
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974392
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974455-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974571
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975025
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975467
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975560
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975713
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976098-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976325-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976749-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977165-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977816
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977914
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978037
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978207-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978251
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978262
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978338
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978601
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978706
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979306
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979309
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979683
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980182-IE7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980232
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981349
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981793
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\M953297
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Malwarebytes' Anti-Malware_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 1.1 (1033)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 3.5 SP1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft PhotoDraw 2000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MobileOptionPack
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MPlayer2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSCompPackV1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30a-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-Beta
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSN Music Assistant
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NetMeeting
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NLSDownlevelMapping
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PCHealth
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PhotoScape
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PokerStars
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SchedulingAgent
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Screenscapes
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SpeedFan
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SpywareBlaster_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WGA
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WgaNotify
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WIC
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows Media Format Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows Media Player
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows XP Service Pack
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WMCSetup
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WMFDist11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\wmp11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wudf01000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{00000409-78E1-11D2-B60F-006097C998E7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{00040409-78E1-11D2-B60F-006097C998E7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{002D9D5E-29BA-3E6D-9BC4-3D7D6DBC735C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{07287123-B8AC-41CE-8346-3D777245C35B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0EFDF2F9-836D-4EB7-A32D-038BD3F1FB2A}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{15BC8CD0-A65B-47D0-A2DD-90A824590FA8}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1A528690-6A2D-4BC5-B143-8C4AE8D19D96}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{216AB108-2AE1-4130-B3D5-20B2C4C80F8F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216015FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216017FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216017FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216019FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216020FB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{287ECFA4-719A-2143-A09B-D6A12DE54E40}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2CCBABCB-6427-4A55-B091-49864623C43F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3FA365DF-2D68-45ED-8F83-8C8A33E65143}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4A03706F-666A-4037-7777-5F2748764D10}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4CCC7F68-A437-4559-A840-F5E010934951}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5372B9A6-6E51-4f90-9B40-E0A3B8475C4E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{63569CE9-FA00-469C-AF5C-E5D4D93ACF91}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6956856F-B6B3-4BE0-BA0B-8F495BE32033}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7299052b-02a4-4627-81f2-1818da5d550d}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{766273C1-A39B-47EB-ACE8-DEBDD8094BCC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{770657D0-A123-3C07-8E44-1C83EC895118}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7BBDFB3E-F8BE-4D52-98BA-B6087F8F1D58}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{86493ADD-824D-4B8E-BD72-8C5DCDC52A71}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8777AC6D-89F9-4793-8266-DE406F343E89}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8A708DD8-A5E6-11D4-A706-000629E95E20}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90120000-0020-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{91120409-6000-11D3-8CFE-0150048383C9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94FB906A-CF42-4128-A509-D353026A607E}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95120000-00AF-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95120000-00B9-0409-0000-0000000FF1CE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{98E8A2EF-4EAE-43B8-A172-74842B764777}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{998D6972-F58E-479D-9248-8F179E55AE38}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A2BCA9F1-566C-4805-97D1-7FDC93386723}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB958483
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC76BA86-7AD7-1033-7B44-A93000000001}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC76BA86-7AD7-5464-3428-900000000004}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BB8B979E-E336-47E7-96BC-1031C1B94561}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C04E32E0-0416-434D-AFB9-6969D703A9EF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB200003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB431780
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB946922
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB947748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB949272
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952137
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952677
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953300
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953990
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB954832
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB956860
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957541
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957543
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958129
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958481
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB974417
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CAE7D1D9-3794-4169-B4DD-964ADBC534EE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB350003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB953595
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB958484
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB963707
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DDA2B32F-EB16-4C96-A130-4E4A4C1E6B12}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DE2EBD6F-81B6-4E9A-B137-C11FD6790CFF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{EFE26D3B-2789-4068-A5BB-77E389FAEB98}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F0A37341-D692-11D4-A984-009027EC0A9C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F662A8E6-F4DC-41A2-901E-8C11F044BDEC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F855C3AE-992D-4B84-A09D-07103CDCDAC2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF0D5234-E7D8-41DA-9287-C89C3B045ADC}
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\LEGO Digital Designer
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Move Networks Player - IE
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\New LEGO Digital Designer
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Octoshape add-in for Adobe Flash Player
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\UnityWebPlayer
Autorun
aww1157
Posts Posts : 64
Joined Joined : 2009-01-23
OS OS : Windows XP SP2
Points Points : 29243
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:25 pm
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
MSMSGS REG_SZ "C:\Program Files\Messenger\msmsgs.exe" /background
ctfmon.exe REG_SZ C:\WINDOWS\system32\ctfmon.exe
swg REG_SZ C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
Advanced SystemCare 3 REG_SZ "C:\Program Files\IObit\Advanced SystemCare 3\AWC.exe" /startup
ehTray REG_SZ C:\WINDOWS\ehome\ehtray.exe
IgfxTray REG_SZ C:\WINDOWS\system32\igfxtray.exe
HotKeysCmds REG_SZ C:\WINDOWS\system32\hkcmd.exe
Persistence REG_SZ C:\WINDOWS\system32\igfxpers.exe
SoundMAXPnP REG_SZ C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
SoundMAX REG_SZ "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
ISUSPM Startup REG_SZ C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
ISUSScheduler REG_SZ "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
QuickTime Task REG_SZ "C:\Program Files\QuickTime\qttask.exe" -atboottime
HPDJ Taskbar Utility REG_SZ C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb09.exe
HPHUPD05 REG_SZ C:\Program Files\Hewlett-Packard\\{5372B9A6-6E51-4f90-9B40-E0A3B8475C4E}\hphupd05.exe
HP Component Manager REG_SZ "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
HP Software Update REG_SZ "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe"
HPHmon05 REG_SZ C:\WINDOWS\system32\hphmon05.exe
SunJavaUpdateSched REG_SZ "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
avgnt REG_SZ "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
Adobe Reader Speed Launcher REG_SZ "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
Adobe ARM REG_SZ "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\OptionalComponents
Restrictions - Internet Explorer
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel
Homepage REG_DWORD 0x0
Restrictions - REGEDIT
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\Shell
Restrictions - Explorer
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoDriveTypeAutoRun REG_DWORD 0x91
LinkResolveIgnoreLinkInfo REG_DWORD 0x0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
ActiveX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{01113300-3E00-11D2-8470-0060089874ED}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{02BCC737-B171-4746-94C9-0D8A0B2C0089}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{166B1BCA-3F9C-11CF-8075-444553540000}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{6414512B-B978-451D-A0D8-FCFDF33E833C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{6F15128C-E66A-490C-B848-5000B5ABEEAC}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{73ECB3AA-4717-450C-A2AB-D00DAD9EE203}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{A9F8D9EC-3D0A-4A60-BD82-FBD64BAD370D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{BCC0FF27-31D9-4614-A68E-C18E1ADA4389}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E77F23EB-E7AB-4502-8F37-247DBAF1A147}
DNS Settings
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2BA9F2CC-8E15-48FD-8443-22BAE0EF50CF}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2D63CA42-AAE2-4147-8DEF-45A3BCC61316}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{86FD6B7A-5F0C-44EC-BB4C-2EB13F106315}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{B2165220-0C71-435A-B975-F64C9B7FE0A6}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{F1ACF0F0-12F2-4E66-8424-4EC7BE5104FA}
Windows IP Configuration
Host Name . . . . . . . . . . . . : wintec
DNS Suffix Search List. . . . . . : home
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet NIC
Physical Address. . . . . . . . . : 00-01-6C-D8-DE-77
Ethernet adapter Wireless Network Connection 4:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Compact Wireless-G USB Adapter #2
Physical Address. . . . . . . . . : 00-18-39-1E-00-5F
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
68.238.64.12
Lease Obtained. . . . . . . . . . : Saturday, June 05, 2010 7:55:10 AM
Lease Expires . . . . . . . . . . : Sunday, June 06, 2010 7:55:10 AM
AppInit DLLs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
AppInit_DLLs REG_SZ
Shell Service Object Delay Load
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
PostBootReminder REG_SZ {7849596a-48ea-486e-8937-a2a3009f31a9}
CDBurn REG_SZ {fbeb8a05-beee-4442-804e-409d6c4515e9}
WebCheck REG_SZ {E6FB5E20-DE35-11CF-9C87-00AA005127ED}
SysTray REG_SZ {35CEC8A3-2BE6-11D2-8773-92E220524153}
WPDShServiceObj REG_SZ {AAA288BA-9A4C-45B0-95D7-94D524869DB5}
Shell Execute Hooks
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks
{AEB6717E-7E19-11d0-97EE-00C04FD91972} REG_SZ
{56F9679E-7826-4C84-81F3-532071A8BCC5} REG_SZ
Image File Execution Options
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:26 pm
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\apitrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Cleanup.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\cqw32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divx.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divxdec.ax
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DJSMAR00.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRMINST.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\enc98.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncodeDivXExt.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncryptPatchVer.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\front.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\fullsoft.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBROWSER.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmarq.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmm.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\install.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ishscan.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ISSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\javai.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm_g.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\main123w.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mngreg32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msci_uno.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscoree.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorsvr.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorwks.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msjava.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mso.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVOPTRF.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NeVideoFX.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPMLIC.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSWSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\photohse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PMSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ppw32hlp.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\printhse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\prwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ps80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\psdmt.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qfinder.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qpw.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\salwrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup32.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\sevinst.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\symlcnet.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\tcore_ebook.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFDTCTT8.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ua80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\udtapi.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ums.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vb40032.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vbe6.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\wpwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xlmlEN.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xwsetup.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Your Image File Name Here without a path
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\_INSTPGM.EXE
Security Providers
Local Security Authority
! REG.EXE VERSION 3.0
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa
Authentication Packages REG_MULTI_SZ msv1_0\0\0
Bounds REG_BINARY 0030000000200000
Security Packages REG_MULTI_SZ kerberos\0msv1_0\0schannel\0wdigest\0\0
ImpersonatePrivilegeUpgradeToolHasRun REG_DWORD 0x1
LsaPid REG_DWORD 0x380
SecureBoot REG_DWORD 0x1
auditbaseobjects REG_DWORD 0x0
crashonauditfail REG_DWORD 0x0
disabledomaincreds REG_DWORD 0x0
everyoneincludesanonymous REG_DWORD 0x0
fipsalgorithmpolicy REG_DWORD 0x0
forceguest REG_DWORD 0x1
fullprivilegeauditing REG_BINARY 00
limitblankpassworduse REG_DWORD 0x1
lmcompatibilitylevel REG_DWORD 0x0
nodefaultadminowner REG_DWORD 0x1
nolmhash REG_DWORD 0x0
restrictanonymous REG_DWORD 0x0
restrictanonymoussam REG_DWORD 0x1
Notification Packages REG_MULTI_SZ \0scecli\0scecli\0\0
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\AccessProviders
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Audit
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Data
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\GBG
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\JD
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Kerberos
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\MSV1_0
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Skew1
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SSO
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SspiCache
SafeBoot
AppCert DLLs
Extra
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\0
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\1
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\2
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\3
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\4
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\5
HKEY_LOCAL_MACHINE\HARDWARE\DEscriptION\System\MultifunctionAdapter\6
App Paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\AcroRd32.exe
REG_SZ C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
Path REG_SZ C:\Program Files\Adobe\Reader 9.0\Reader\
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\bckgzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\bckgzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ccleaner.exe
REG_SZ C:\Program Files\CCleaner\ccleaner.exe
Path REG_SZ C:\Program Files\CCleaner
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\chkrzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\chkrzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\cmmgr32.exe
ProfilesUpgraded REG_DWORD 0x1
Path REG_SZ C:\WINDOWS\system32
CmstpExtensionDll REG_SZ C:\WINDOWS\system32\cmcfg32.dll
CMInternalVersion REG_SZ 1.2
CmNative REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\CONF.EXE
REG_SZ C:\Program Files\NetMeeting\conf.exe
Path REG_SZ C:\Program Files\NetMeeting;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\dialer.exe
REG_SZ C:\Program Files\Windows NT\dialer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\excel.exe
Path REG_SZ C:\Program Files\Microsoft Office\OFFICE11\
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE
SaveURL REG_SZ 1
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\frontpg.exe
useURL REG_SZ yes
Path REG_SZ C:\Program Files\Microsoft Office\Office\
REG_SZ C:\PROGRA~1\MICROS~2\Office\FRONTPG.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\HELPCTR.EXE
REG_SZ C:\WINDOWS\PCHealth\HelpCtr\Binaries\HelpCtr.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\HijackThis.exe
Path REG_SZ C:\DOCUME~1\Owner\LOCALS~1\Temp\Temporary Directory 1 for HiJackThis[1].zip
REG_SZ C:\DOCUME~1\Owner\LOCALS~1\Temp\Temporary Directory 1 for HiJackThis[1].zip\hijackthis.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hrtzzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\hrtzzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hypertrm.exe
REG_SZ "C:\Program Files\Windows NT\hypertrm.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN1.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN1.EXE"
Path REG_SZ C:\Program Files\Internet Explorer\Connection Wizard;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN2.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN2.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\IEXPLORE.EXE
REG_SZ C:\Program Files\Internet Explorer\IEXPLORE.EXE
Path REG_SZ C:\Program Files\Internet Explorer;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ImLc.exe
REG_SZ C:\PROGRA~1\INCRED~1\bin\ImLc.exe
Path REG_SZ C:\PROGRA~1\INCRED~1\bin
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ImLcU.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\impackr.exe
REG_SZ C:\PROGRA~1\INCRED~1\bin\impackr.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\impackrU.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ImpCnt.exe
REG_SZ C:\PROGRA~1\INCRED~1\bin\ImpCnt.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ImpCntU.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ImpContent.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\IncMailU.exe
REG_SZ C:\PROGRA~1\INCRED~1\bin\IncMail.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\INETWIZ.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\INETWIZ.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\install.exe
RunAsOnNonAdminInstall REG_DWORD 0x1
BlockOnTSNonInstallMode REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe
Path REG_SZ "C:\Program Files\Common Files\Motive\InstallHelper.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\ClientSyncLoader.htm
Path REG_SZ C:\Program Files\Common Files\Motive\ClientSyncLoader.htm
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\ClientSyncLoader.htm\LEGACY_MOTIVE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\ClientSyncLoaderDriver.htm
Path REG_SZ C:\Program Files\Common Files\Motive\ClientSyncLoaderDriver.htm
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\ClientSyncLoaderDriver.htm\LEGACY_MOTIVE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\hourglass.gif
Path REG_SZ C:\Program Files\Common Files\Motive\hourglass.gif
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\InstallHelper.exe\hourglass.gif\LEGACY_MOTIVE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ISIGNUP.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ISIGNUP.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\javaws.exe
REG_SZ C:\Program Files\Java\jre6\bin\javaws.exe
Path REG_SZ C:\Program Files\Java\jre6\bin
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mbam.exe
REG_SZ C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
Path REG_SZ C:\Program Files\Malwarebytes' Anti-Malware
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\migwiz.exe
REG_EXPAND_SZ %SystemRoot%\system32\usmt\migwiz.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\moviemk.exe
REG_SZ C:\Program Files\Movie Maker\moviemk.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mplayer2.exe
Path REG_SZ "C:\Program Files\Windows Media Player"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSACCESS.EXE
REG_SZ C:\PROGRA~1\MICROS~2\Office\MSACCESS.EXE
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSCONFIG.EXE
REG_SZ C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msimn.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\msimn.exe
Path REG_EXPAND_SZ %ProgramFiles%\Outlook Express
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by aww1157 on 5th June 2010, 11:27 pm
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msinfo32.exe
REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo\MSInfo32.exe
Path REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSMSGS.EXE
REG_SZ C:\Program Files\Messenger\msmsgs.exe
Path REG_SZ C:\Program Files\Messenger;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MsoHtmEd.exe
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msoxmled.exe
useURL REG_SZ 1
REG_SZ C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSOXMLED.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSPUB.EXE
REG_SZ C:\PROGRA~1\MICROS~2\Office\MSPUB.EXE
useURL REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mspview.exe
Path REG_SZ C:\Program Files\Common Files\Microsoft Shared\MODI\11.0\
REG_SZ C:\PROGRA~1\COMMON~1\MICROS~1\MODI\11.0\MSPVIEW.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msworks.exe
REG_SZ C:\Program Files\Microsoft Works\msworks.exe
Path REG_SZ C:\Program Files\Microsoft Works\
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ois.exe
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\OIS.EXE
SaveURL REG_SZ 0
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\OUTLOOK.EXE
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\OUTLOOK.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pbrush.exe
REG_EXPAND_SZ %SystemRoot%\system32\mspaint.exe
Path REG_EXPAND_SZ %SystemRoot%\system32
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\PHOTODRW.EXE
REG_SZ C:\Program Files\Microsoft Office\Office\PHOTODRW.EXE
Path REG_SZ C:\Program Files\Microsoft Office\Office\;C:\Program Files\Microsoft Office\Office
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\PhotoScape.exe
REG_SZ "C:\Program Files\PhotoScape\PhotoScape.exe"
Path REG_SZ "C:\Program Files\PhotoScape\PhotoScape.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\PictureViewer.exe
REG_SZ C:\Program Files\QuickTime\PictureViewer.exe
Path REG_SZ C:\Program Files\QuickTime\
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pinball.exe
REG_SZ C:\Program Files\Windows NT\Pinball\pinball.exe
Path REG_SZ C:\Program Files\Windows NT\Pinball
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\powerpnt.exe
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\POWERPNT.EXE
SaveURL REG_SZ 1
useURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\QuickTimePlayer.exe
REG_SZ C:\Program Files\QuickTime\QuickTimePlayer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\rvsezm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\rvsezm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\schdpl32.exe
Path REG_SZ C:\Program Files\Microsoft Office\OFFICE11\1033\
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\1033\SCHDPL32.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\setup.exe
Path REG_SZ C:\Program Files\REALTEK Semiconductor Corporation\REALTEK Gigabit and Fast Ethernet NIC Driver
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\shvlzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\shvlzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\smax4.exe
REG_SZ C:\Program Files\Analog Devices\SoundMAX\smax4.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\SoundMAX
Path REG_SZ C:\Program Files\Analog Devices\SoundMAX
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\table30.exe
UseShortName REG_SZ
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wab.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wab.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wabmig.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wabmig.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WinDVD.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\winnt32.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\Winword.exe
useURL REG_SZ 1
REG_SZ C:\PROGRA~1\MICROS~2\OFFICE11\WINWORD.EXE
SaveURL REG_SZ 1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WKSAB.EXE
REG_SZ C:\Program Files\Microsoft Works\WKSAB.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wkscal.exe
REG_SZ C:\PROGRA~1\MICROS~4\WksCal.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wksdb.exe
REG_SZ C:\Program Files\Microsoft Works\wksdb.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WKSSB.EXE
REG_SZ C:\Program Files\Microsoft Works\WKSSB.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wksss.exe
REG_SZ C:\Program Files\Microsoft Works\wksss.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wkswp.exe
REG_SZ C:\Program Files\Microsoft Works\wkswp.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wmplayer.exe
REG_SZ C:\Program Files\Windows Media Player\wmplayer.exe
Path REG_SZ C:\Program Files\Windows Media Player
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WORDPAD.EXE
REG_EXPAND_SZ "%ProgramFiles%\Windows NT\Accessories\WORDPAD.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WRITE.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\XPSViewer.exe
REG_SZ "C:\WINDOWS\system32\XPSViewer\XPSViewer.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\YourApp.exe
Path REG_SZ C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor
Mozilla
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla
REG_SZ
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox\Extensions
{20a82645-c095-46ed-80e3-08825760534b} REG_SZ c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
[You must be registered and logged in to see this link.] REG_EXPAND_SZ C:\Program Files\Java\jre6\lib\deploy\jqs\ff
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Mozilla
CurrentVersion REG_SZ 1.7.5
Shared Task Scheduler
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler
{438755C2-A8BA-11D1-B96B-00A0C90312E1} REG_SZ Browseui preloader
{8C7461EF-2B13-11d2-BE35-3078302C2030} REG_SZ Component Categories cache daemon
SafeBootMinimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vds
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
SafeBootNetwork
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AFD
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Browser
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Dhcp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DnsCache
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ip6fw.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ipnat.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanServer
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanWorkstation
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LmHosts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Messenger
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS Wrapper
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Ndisuio
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOSGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBT
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetDDEGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetMan
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetworkProvider
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NtLmSsp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP_TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpcdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpwd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdsessmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SharedAccess
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Streams Drivers
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Tcpip
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdpipe.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdtcp.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\termservice
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WZCSVC
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E973-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E974-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E975-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
File Rename Operations - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\FileRenameOperations
Known DLLs - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDlls
advapi32 REG_SZ advapi32.dll
comdlg32 REG_SZ comdlg32.dll
DllDirectory REG_EXPAND_SZ %SystemRoot%\system32
gdi32 REG_SZ gdi32.dll
imagehlp REG_SZ imagehlp.dll
kernel32 REG_SZ kernel32.dll
lz32 REG_SZ lz32.dll
ole32 REG_SZ ole32.dll
oleaut32 REG_SZ oleaut32.dll
olecli32 REG_SZ olecli32.dll
olecnv32 REG_SZ olecnv32.dll
olesvr32 REG_SZ olesvr32.dll
olethk32 REG_SZ olethk32.dll
rpcrt4 REG_SZ rpcrt4.dll
shell32 REG_SZ shell32.dll
url REG_SZ url.dll
urlmon REG_SZ urlmon.dll
user32 REG_SZ user32.dll
version REG_SZ version.dll
wininet REG_SZ wininet.dll
wldap32 REG_SZ wldap32.dll
Adobe Products
{END OF FILE}
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 6th June 2010, 3:05 am
  • Click Start
  • Click Start
Posts Posts : 14309
Points Points : 302970
Re: Unknown Problem
Post by aww1157 on 6th June 2010, 5:59 pm
# version=7
# iexplore.exe=7.00.6000.17023 (vista_gdr.100222-0012)
# api_version=3.0.2
# EOSSerial=16ae6919aeb8a544930e49b9d3db017b
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-06-06 11:56:49
# local_time=2010-06-06 04:56:49 (-0800, Pacific Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=512 16777215 100 0 23297621 23297621 0 0
# compatibility_mode=768 16777215 100 0 14998616 14998616 0 0
# compatibility_mode=1797 16775141 100 94 57914 48359272 0 0
# scanned=62126
# found=1
# cleaned=1
# scan_time=5453
C:\Program Files\Mozilla Firefox\chrome\m3ffxtbr.jar Win32/Toolbar.MyWebSearch application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 6th June 2010, 6:22 pm
Alternate link: [You must be registered and logged in to see this link.].
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. If you are prompted to restart, please allow it to restart your computer. Failure to do this, will cause the infection to still be active on the computer.
  • The log can also be found at C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
Posts Posts : 14309
Re: Unknown Problem
Post by aww1157 on 7th June 2010, 4:27 am
It didn't pick it up.
Database version: 4174
Internet Explorer 7.0.5730.11
6/6/2010 9:25:43 PM
mbam-log-2010-06-06 (21-25-43).txt
Scan type: Full scan (C:\|)
Objects scanned: 173343
Time elapsed: 47 minute(s), 47 second(s)
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 7th June 2010, 4:35 am
Note: please close all other applications running on your system.
Double click GetSystemInfo.exe to open it. It will display an agreement. Click on I Agree to continue.
Click the Settings button.
Set the slider to Maximum.
IMPORTANT! Then, click Customize - choose Driver / Ports tab and uncheck Scan Ports.
On the General tab, make sure all of the boxes are checked.
On the Misc tab, make sure all the checkboxes are checked.
Then, click OK on the windows that you launched.
It will begin scanning.
It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop.
It should automatically upload it to [You must be registered and logged in to see this link.] If it does not, then please submit it manually by going to the site and doing the upload process.
It will redirect to a page, where it will provide a sharing URL for specialists. Copy and paste the url of the GSI Parser report in your next reply.
Posts Posts : 14309
Re: Unknown Problem
Post by aww1157 on 7th June 2010, 3:45 pm
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 7th June 2010, 9:14 pm
Your logs are clean.
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 14309
Re: Unknown Problem
Post by aww1157 on 7th June 2010, 10:30 pm
Results of screen317's Security Check version 0.99.4
Windows XP Service Pack 3
Internet Explorer 7 Out of date!
Antivirus/Firewall Check:
Windows Firewall Enabled!
Avira AntiVir Personal - Free Antivirus
Antivirus up to date!
HijackThis 2.0.2
CCleaner
Java(TM) 6 Update 20
Java DB 10.4.1.3
Adobe Flash Player
Adobe Reader 9.3.2
Process Check:
objlist.exe by Laurent
Avira Antivir avgnt.exe
Avira Antivir avguard.exe
DNS Vulnerability Check:
aww1157
Posts Posts : 64
Re: Unknown Problem
Post by Dr Jay on 7th June 2010, 10:31 pm
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 14309
