XP Pro machine infected bankerfox.a and nuqel.e: HELP
Post by clay on 2nd June 2010, 3:12 am
I read your advice on OTL...but, computer cannot connect to internet. WORD, Notepad, paint...nothing will work. Advice you can give? Even the avg freeware is corrupted.
clay
Joined Joined : 2010-06-02
OS OS : vista
Points Points : 23848
Re: XP Pro machine infected bankerfox.a and nuqel.e: HELP
Post by Belahzur on 2nd June 2010, 8:07 pm
Points Points : 245111
Post by clay on 2nd June 2010, 11:47 pm
I put the otl on the desktop and tried to run it, and get message that the otl.exe is infected. Suggestions?
clay
OS OS : vista
Post by Belahzur on 3rd June 2010, 9:15 pm
We need to use the RKill Tool by Grinler
  • Please Download Rkill.com. Save it to your Desktop.
  • Before we begin, you should disable your anti-malware softwares you have installed so they do not interfere RKill running as some anti-malware softwares detect RKill as malicious. Please refer to this [You must be registered and logged in to see this link.] if you are not sure how.
  • NOTE: If you are unable to connect to the site to download rkill, then you should download it to a clean computer and copy it to the infected one via a USB flash drive or CDROM.
  • Once it is downloaded, double-click on the rkill.com in order to automatically attempt to stop any processes associated with Rogue programs.
  • Please be patient while the program looks for various malware programs and ends them.
  • When it has finished, the black window will automatically close and you can continue with the next step.
NOTE: If you get a message that rkill is an infection, do not be concerned. This message is just a fake warning given by the rogue program, when it terminates programs that may potentially remove it. If you run into these infections warnings that close Rkill, a trick is to leave the warning on the screen and then run Rkill again. By not closing the warning, this typically will allow you to bypass the malware trying to protect itself so that rkill can terminate the rogue program. So, please try running Rkill until the malware is no longer running. You will then be able to proceed with the rest of the steps.
If you continue having problems running rkill.com, you can download:
[You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
which are renamed copies of rkill.com, and try them instead.
Try OTL now please.
