Replaced power supply, USB mouse/keyboard non-responsive
Post by flatsix on 30th May 2010, 11:15 pm
Hello -
My computer was suddenly not powering on. I replaced the power supply, and the computer booted up, albeit with 1 short beep followed by 3 short beeps at POST. I'm not sure what BIOS it is, but it is a 3-ish year old Asus motherboard.
The problem now is - it will boot to the Win XP login prompt, however it is completely unresponsive to my USB keyboard and mouse. Oddly, I believe it is providing USB power because I have another peripheral (USB MIDI synthesizer) hooked up that powers up just fine.
I tried pulling 3V CMOS battery, different USB mice/keyboards etc, no luck. Any ideas why the USB mouse/keyboard are not working after replacing PSU?
thanks!
flatsix
Joined Joined : 2010-05-30
OS OS : win xp
Points Points : 23873
Re: Replaced power supply, USB mouse/keyboard non-responsive
Post by makxp77 on 31st May 2010, 3:28 pm
While in login screen , try to un-plug then replug in usb devices, if not try to plug the usb devices into different usb ports if possible.
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29104
Post by flatsix on 31st May 2010, 4:07 pm
Have tried that, still no luck.
Also unseated/reseated RAM etc to see if bad RAM was the cause. Still no luck.
flatsix
OS OS : win xp
