Urgent help! Wuauclt.exe infection Please Help
Re: Urgent help! Wuauclt.exe infection Please Help
Post by azn239 on Sun May 23, 2010 12:44 am
Here is the ckfile:
CKScanner - Additional Security Risks - These are not necessarily bad
scanner sequence 3.RP.11
----- EOF -----
azn239
OS : XP Professional
Post by Belahzur on Sun May 23, 2010 12:45 am
Updating Java:
  • Click the "Download JRE" button to the right.
  • In the Window that opens, select your platform, check the "agree" box, and click Continue.
  • Then from your desktop double-click on jre-6u20-windows-i586.exe that you downloaded to install the newest version.
Then download and install [You must be registered and logged in to see this link.]
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by azn239 on Sun May 23, 2010 12:47 am
Im not sure which platform to choose let alone what they mean =/
azn239
Post by Belahzur on Sun May 23, 2010 12:48 am
Windows, don't choose the x64 edition.
Post by azn239 on Sun May 23, 2010 1:07 am
I am goin to take a shower while it scanning since its taking awhile, ill be back in 5minutes Smile thank you so much for everything youve done for me so far XDXD
azn239
Post by azn239 on Sun May 23, 2010 1:34 am
is it normal for it to be a 99% for like 10minutes? It is not frozen at all, its still scanning files just seems to be taking very long for 1%.
azn239
Post by azn239 on Sun May 23, 2010 2:22 am
Heres the log of the ESET Scanner:
# version=7
# iexplore.exe=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# EOSSerial=577942be7b1c84458b01fb649048d1ee
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-05-23 02:18:08
# local_time=2010-05-22 10:18:08 (-0500, Eastern Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=512 16777215 100 0 0 0 0 0
# scanned=87449
# found=0
# cleaned=0
# scan_time=4335
azn239
Post by Belahzur on Sun May 23, 2010 1:56 pm
Post by azn239 on Sun May 23, 2010 2:00 pm
My computer is running great now, there are no more virus pop-ups and the eset scan said my computer has no threats. So i guess im done Smile?
azn239
Post by Belahzur on Sun May 23, 2010 2:15 pm
Yep. Smile
Post by azn239 on Sun May 23, 2010 4:26 pm
ty!
azn239
