lap top problem
lap top problem
Post by nlsekhar on Sat May 22, 2010 9:23 am
you should change your battery or switch to outlet power immediately to keep from losing your work
1)i am getting this message while unpluging the charger...........
nlsekhar
Joined Joined : 2010-05-22
OS OS : xp service pack 2
Points Points : 23903
Re: lap top problem
Post by heavyjay on Sun May 23, 2010 11:10 pm
When do you see this?
Learning to make a difference
heavyjay
Posts Posts : 89
Joined Joined : 2010-05-05
OS OS : Vista, XP, Windows Mobile 6.1
Protection Protection : AVG for real time, SAS and MBAM as needed, Windows Firewall
Points Points : 24209
Re: lap top problem
Post by nlsekhar on Mon May 24, 2010 3:34 am
while un pluging the charger of laptop
nlsekhar
Re: lap top problem
Post by heavyjay on Mon May 24, 2010 3:47 pm
OK, if you're not seeing it while it's on AC power and it pops up as soon as you unplug it, you most likely just need a new battery.
heavyjay
Posts Posts : 89
