Antispyware Soft taking over laptop- need help to remove
Post by d0rf1n on 15th May 2010, 11:58 am
A program called Antispyware Soft has been downloaded on my laptop and it is now taken it over completely. It makes loads of pop ups saying viruses have been detected- Bankerfox.A and Win32/Nuqel.E and asks me to buy their program to remove them. I now can't open the control panel to use add/remove programs and I can't go on any websites but it randomly opens porn sites itself.
Please can someone help me with trying to remove it? I have access to another PC to use this forum/ download any programs I need to fix it.
Thank you.
d0rf1n
Joined Joined : 2010-05-15
Points Points : 24013
Re: Antispyware Soft taking over laptop- need help to remove
Post by Kenny94 on 15th May 2010, 3:30 pm
Hi d0rf1n And Welcome to GP!
Great you have another PC.
Please do the following….. From a clean computer download the following tools to a flash drive. Or Copy to a USB/CD or other media to use on the infected system.
Also, print out or save these instructions into note pad on a flash drive. (so you can see how to run the tools). If you can't save it to the desktop of the infected computer, you can run it right off of the flash drive.
Please note that these fixes are not instantaneous. Most infections require more than one round to properly eradicate.
Stay with me until given the 'all clear' even if symptoms diminish. Lack of symptoms does not always mean the job is complete.
Kindly follow my instructions and please do no fixing on your own or running of scanners unless requested by me or another helper.
  1. Download ComboFix from below:
    * IMPORTANT !!! Place combofix.exe on your Desktop
  2. Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with ComboFix.
    You can get help on disabling your protection programs [You must be registered and logged in to see this link.]
  3. Double click on combofix.exe & follow the prompts.
  4. As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed.
    The Windows recovery console will allow you to boot up into a special recovery mode that allows us to help you in the case that your computer has a problem after an attempted removal of malware.
    With malware infections being as they are today, it's strongly recommended to have this pre-installed on your machine before doing any malware removal.
    Follow the prompts to allow ComboFix to download and install the Microsoft Windows Recovery Console, and when prompted, agree to the End-User License Agreement.
    ComboFix will now automatically install the Microsoft Windows Recovery Console onto your computer, which will show up as a new option when booting up your computer. Do not select the Microsoft Windows Recovery Console option when you start your computer unless requested to by a helper.
    Once the Microsoft Windows Recovery Console is installed using ComboFix, you should see a message that says:
    The Recovery Console was successfully installed.
  5. Your desktop may go blank. This is normal. It will return when ComboFix is done. ComboFix may reboot your machine. This is normal.
  6. When finished, it shall produce a log for you. Post that log in your next reply
  7. Ensure your AntiVirus and AntiSpyware applications are re-enabled.
Kenny94
Tech Officer
Tech Officer
Posts Posts : 2019
Joined Joined : 2010-04-22
Protection Protection : Avira/Router and Malwarebytes
Points Points : 33551
