BankerFox.A and win32/Nugel.E Removal Help
Post by paulw on Thu May 06, 2010 3:35 pm
I have recently acquired this trojan on my laptop running Vista Business ed. I tried running the OTL but it tells me that the .exe is infected. I have tried to disable my AVG to try and run RKill but again the .exe is infected. What do I do? Please help.
paulw
Posts Posts : 9
Joined Joined : 2010-05-06
OS OS : Vista Business
Points Points : 24173
Re: BankerFox.A and win32/Nugel.E Removal Help
Post by Belahzur on Thu May 06, 2010 9:15 pm
Points Points : 245059
Post by paulw on Fri May 07, 2010 1:04 pm
Thank you for getting back to me. I appreciate your help.
I only have the one document. The extra.txt doc did not come up on my desktop nor was it saved. Here is the 1st doc.
I am trying to send this file and each time I either copy paste the doc into the post-a-reply box it doesn't work or I try to upload the doc and it tells me the uploaded file is not valid?
paulw
Posts Posts : 9
Post by Belahzur on Fri May 07, 2010 5:07 pm
Copy and paste all the log into a new text document and then save that and try upload it.
Post by paulw on Sat May 08, 2010 1:55 am
Thank you. Here is the txt file.
paulw
Posts Posts : 9
Post by Belahzur on Sat May 08, 2010 11:31 pm
Please run OTL.exe.
    :OTL
    2010/05/06 00:02:18 | 000,000,000 | ---D | C] -- C:\Users\Paul\AppData\Local\ucxmwlkwq
  • Close OTL.exe
Post by paulw on Mon May 10, 2010 2:31 pm
Here is the txt doc after the Run Fix.
paulw
Posts Posts : 9
Post by Belahzur on Mon May 10, 2010 9:42 pm
Did you copy my entire fix script?
there was no log bit for moving this "ucxmwlkwq" folder.
Post by paulw on Tue May 11, 2010 12:01 am
This is what a pasted.
:OTL
paulw
Posts Posts : 9
Post by Belahzur on Tue May 11, 2010 7:35 pm
Okay.
Post by paulw on Wed May 12, 2010 1:24 pm
Here is the contents of the MBAM log.
paulw
Posts Posts : 9
Post by Belahzur on Wed May 12, 2010 10:14 pm
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by paulw on Thu May 13, 2010 1:19 am
Hello;
I was able to use ATF Cleaner and followed all of the instructions. When it came to the eset Online Scanner I was not able to get online. When I try to use Internet Explorer it says Internet Explorer cannot display the webpage. ([You must be registered and logged in to see this link.] When clicking on Diagnose Connection Problems, Windows Network Diagostics comes up with "[You must be registered and logged in to see this link.] is not set up to establish a connection on port "World Wide Web service (HTTP)" with this computer. Please help!
paulw
Posts Posts : 9
Post by Belahzur on Thu May 13, 2010 9:56 pm
    In Internet Explorer
    In Firefox
Try again now.
Post by paulw on Fri May 14, 2010 2:48 pm
Here is the log.txt for eset online scanner. As well my system tray is popping up telling me I have some blocked programs that have been disabled. This has never happened before 'til now. It is a Sun Java Update Scheduler. Could this be because of the trojan using this? It is disabled now and states that it was disabled 30/09/2009. Can I get rid of it?
Thanks for your help.
paulw
Posts Posts : 9
Post by Belahzur on Sat May 15, 2010 12:09 am
That log looks good, how is the machine running?
Post by paulw on Sat May 15, 2010 1:31 pm
Computer is working just fine. Thank you very much for all your help.
paulw
Posts Posts : 9
Post by Belahzur on Sat May 15, 2010 9:03 pm
