HELP! I believe it's antivirus pro again!
Post by lastings89 on Thu Apr 29, 2010 6:50 pm
I've received this virus/spyware or whatever in the past, but safely removed it with rkill and MalwareBytes. I was infected again with this, but had copyright violation law also. I removed the copyright violation law because it was easy to remove under add/remove programs. I'm currently in safe mode with network. I finally accessed my desktop and "Start" menu when I got rid of the copyright violation. I try running rkill or malware and it won't let me saying the program is infected. I see the virus/spyware in the tool bar in the bottom and popups keep occuring randomly. I can't run malwarebytes because it says its infected nor the task manager. I'm currently in safe mode with network access running Kaspersky Virus Removal. Do you have any suggestions? thank you in advance.
lastings89
OS : Vista ultimate
# Likes : 0
Re: HELP! I believe it's antivirus pro again!
Post by lastings89 on Thu Apr 29, 2010 6:54 pm
Oh on a side note, I did run malwarebytes in safe mode and found infected files. I removed them, but it still comes up when I run windows normally.
lastings89
OS : Vista ultimate
# Likes : 0
Post by Belahzur on Thu Apr 29, 2010 7:53 pm
# Likes : 1
Post by lastings89 on Thu Apr 29, 2010 9:24 pm
It's letting me run Malwarebytes again...I'm doing a scan. currently.
lastings89
OS : Vista ultimate
# Likes : 0
Post by Belahzur on Fri Apr 30, 2010 7:09 pm
Okay, standing by.
# Likes : 1
