I got 5 viruses going to a Technical Help forum.
Post by Albert on 27th April 2010, 10:11 pm
I got 5 viruses going to a Technical Help forum. You can see which forum I got them from from the data I'm posting below. Can these viruses be easily deleted?
Are they harmful?
I installed Kapersky Internet Security 9 about a week ago .............and did a full scan to try and get rid of these viruses but they could not be removed with Kapersky.
Kapersky seemed hopeless because it informed me with a pop-up when I went to the Tech Forum that the viruses were being installed on my computer and Kapersky did nothing to stop them. This pissed me right off!
Any suggestions?
Thanks.
Status: Infected (events: 5)
4/25/2010 4:40:35 PM Infected virus HEUR:Trojan-Downloader.Script.Generic http://www.techsupportforum.com/clientscript/passivevideo.js High
4/25/2010 4:40:36 PM Infected virus HEUR:Trojan-Downloader.Script.Generic http://www.techsupportforum.com/clientscript/vbulletin_md5.js High
4/25/2010 4:40:36 PM Infected virus HEUR:Trojan-Downloader.Script.Generic http://www.techsupportforum.com/clientscript/vbulletin_lightbox.js?v=384 High
4/27/2010 10:11:37 AM Infected virus HEUR:Trojan-Downloader.Script.Generic http://www.techsupportforum.com/clientscript/vbulletin_menu.js?v=384 High
4/27/2010 10:11:38 AM Infected virus HEUR:Trojan-Downloader.Script.Generic http://www.techsupportforum.com/clientscript/vbulletin_post_loader.js?v=384 High
Albert
Posts Posts : 103
Joined Joined : 2008-07-25
Points Points : 30836
Re: I got 5 viruses going to a Technical Help forum.
Post by Belahzur on 28th April 2010, 12:14 am
Points Points : 245079
Post by Albert on 28th April 2010, 5:13 am
Belahzur....I had the viruses fixed....I deleted my history from my browser and that fixed it.
Albert
Posts Posts : 103
