My computer caught System Guard Virus - Please Help!!!!!!!!!!!!!!!!
Post by newyorkgirl1982 on 27th April 2010, 1:26 am
I keep on getting messages from Antivirus software Alert - Threat: Win32/Nuqel.E and BankerFox.A I tried downloading an intivurus software from a legit company, but I can't install it. I can' open Control Panel. Please let me know how I an get rid of it.
Thanks!!!
newyorkgirl1982
Posts Posts : 3
Joined Joined : 2010-04-27
OS OS : Vista
Points Points : 24233
Re: My computer caught System Guard Virus - Please Help!!!!!!!!!!!!!!!!
Post by Dr Jay on 27th April 2010, 4:07 am
RKill by Grinler
  • Download Link #1.
    If you are using Vista please right click and run as Admin!
  • A black screen will briefly flash indicating a successful run.
  • If this does not occur please delete that application and download Link #2.
  • Continue process until the tool runs.
  • If the tool does not run from any of the links tell me about it.
This only kills the active infection, the actual infection will not be gone.
Posts Posts : 14314
Points Points : 302999
Post by newyorkgirl1982 on 28th April 2010, 12:45 am
Here the Log:
ComboFix 10-04-26.05 - ANNA 04/27/2010 20:28:31.1.2 - x86
Microsoft® Windows Vista™ Ultimate 6.0.6000.0.1252.1.1033.18.1982.1416 [GMT -4:00]
Running from: c:\users\ANNA\Desktop\commy.exe
SP: Windows Defender *enabled* (Outdated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
c:\$recycle.bin\S-1-5-21-51003140-4199384537-3980697693-500
c:\users\ANNA\AppData\Local\yoyhvjutw
c:\$recycle.bin\S-1-5-21-51003140-4199384537-3980697693-500\desktop.ini
c:\program files\gamevance\gamevancelib32.dll
c:\program files\Gamevance\gvtl.dll
c:\program files\Mail.Ru\Agent\Mra\dll\newmrasearch.dll
c:\users\ANNA\AppData\Local\Microsoft\Windows\Temporary Internet Files\pse_350_enu.exe
c:\users\ANNA\AppData\Local\yoyhvjutw\mwuyrcxtssd.exe
c:\windows\system32\AutoRun.inf
((((((((((((((((((((((((( Files Created from 2010-03-28 to 2010-04-28 )))))))))))))))))))))))))))))))
2010-04-28 00:36 . 2010-04-28 00:37 -------- d-----w- c:\users\ANNA\AppData\Local\temp
2010-04-28 00:36 . 2010-04-28 00:36 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-04-20 01:01 . 2010-04-20 01:01 -------- d-----w- c:\users\ANNA\AppData\Local\Yahoo!
2010-04-05 22:38 . 2010-04-05 22:38 -------- d-----w- c:\programdata\McAfee
2010-04-04 15:47 . 2009-11-24 21:39 1093064 ----a-w- c:\users\ANNA\AppData\Roaming\Mozilla\Firefox\Profiles\2ysnm7na.default\extensions\DTToolbar@toolbarnet.com\components\DTToolbarFF.dll
2010-04-03 16:47 . 2010-04-03 16:47 -------- d-----w- c:\program files\Common Files\Skype
2010-04-28 00:28 . 2009-11-30 16:57 -------- d-----w- c:\program files\Gamevance
2010-04-28 00:23 . 2009-06-28 16:13 -------- d-----w- c:\users\ANNA\AppData\Roaming\ICQ
2010-04-25 18:20 . 2009-06-28 16:07 67400 ----a-w- c:\programdata\nvModes.dat
2010-04-25 17:47 . 2009-06-28 07:16 -------- d-----w- c:\users\ANNA\AppData\Roaming\Skype
2010-04-25 14:26 . 2009-06-28 07:19 -------- d-----w- c:\users\ANNA\AppData\Roaming\skypePM
2010-03-11 08:43 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2010-03-11 08:24 . 2009-11-14 18:25 -------- d-----w- c:\programdata\Microsoft Help
2010-02-24 14:16 . 2009-10-02 23:04 181632 ------w- c:\windows\system32\MpSigStub.exe
2010-02-24 08:21 . 2009-06-28 16:05 123968 ----a-w- c:\users\ANNA\AppData\Local\GDIPFONTCACHEV1.DAT
2010-02-20 23:54 . 2010-03-11 08:12 24064 ----a-w- c:\windows\system32\nshhttp.dll
2010-02-20 23:51 . 2010-03-11 08:12 31232 ----a-w- c:\windows\system32\httpapi.dll
2010-02-20 21:30 . 2010-03-11 08:12 396800 ----a-w- c:\windows\system32\drivers\http.sys
2009-07-14 00:16 . 2009-07-14 00:16 1044480 ----a-w- c:\program files\mozilla firefox\plugins\libdivx.dll
2009-07-14 00:16 . 2009-07-14 00:16 200704 ----a-w- c:\program files\mozilla firefox\plugins\ssldivx.dll
2006-11-22 14:58 . 2006-11-22 14:58 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{201f27d4-3704-41d6-89c1-aa35e39143ed}]
2008-09-29 21:24 325000 ----a-w- c:\program files\AskBarDis\bar\bin\askBar.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{45F160E9-48B5-41C8-8093-CE70CEAE8F80}]
2009-06-29 07:18 753664 ----a-w- c:\windows\System32\wownetb.dll
"{3041d03e-fd4b-44e0-b742-2d9b88305f98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2008-09-29 325000]
[HKEY_CLASSES_ROOT\clsid\{3041d03e-fd4b-44e0-b742-2d9b88305f98}]
[HKEY_CLASSES_ROOT\TypeLib\{4b1c1e16-6b34-430e-b074-5928eca4c150}]
"{3041D03E-FD4B-44E0-B742-2D9B88305F98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2008-09-29 325000]
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-06-29 1232896]
"DAEMON Tools Lite"="c:\program files\DAEMON Tools Lite\daemon.exe" [2009-04-23 691656]
"ICQ"="c:\program files\ICQ6.5\ICQ.exe" [2009-11-16 172792]
"Google Update"="c:\users\ANNA\AppData\Local\Google\Update\GoogleUpdate.exe" [2010-04-10 136176]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2009-06-29 1006264]
"hpWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe" [2007-05-11 472632]
"WAWifiMessage"="c:\program files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe" [2007-01-10 317128]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-12-04 13556256]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-12-04 92704]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-27 35696]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-08-09 148888]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"MAgent"="c:\program files\Mail.Ru\Agent\MAgent.exe" [2009-12-08 7975608]
"Ad Muncher"="c:\program files\Ad Muncher\AdMunch.exe" [2010-01-24 862208]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
"Lanhtm"= {24A19C32-2C71-4DE7-8389-442D326AA4DD} - c:\windows\system32\svrsql.dll [2009-06-29 802816]
"aux1"=wdmaud.drv
R0 sptd;sptd;c:\windows\System32\Drivers\sptd.sys [2009-10-26 721904]
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt REG_MULTI_SZ hpqcxs08
2010-04-23 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2144488369-2711709791-3128680860-1000Core.job
- c:\users\ANNA\AppData\Local\Google\Update\GoogleUpdate.exe [2010-04-10 02:25]
2010-04-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2144488369-2711709791-3128680860-1000UA.job
IE: Block frame with Ad Muncher - [You must be registered and logged in to see this link.]
IE: Block image with Ad Muncher - [You must be registered and logged in to see this link.]
IE: Block link with Ad Muncher - [You must be registered and logged in to see this link.]
IE: Don't filter page with Ad Muncher - [You must be registered and logged in to see this link.]
IE: Report page to the Ad Muncher developers - [You must be registered and logged in to see this link.]
IE: {{7558B7E5-7B26-4201-BEDB-00D5FF534523} - c:\program files\Mail.Ru\Agent\magent.exe
FF - ProfilePath - c:\users\ANNA\AppData\Roaming\Mozilla\Firefox\Profiles\2ysnm7na.default\
FF - prefs.js: browser.search.selectedEngine - DAEMON Search
FF - component: c:\program files\Mozilla Firefox\extensions\{B13721C7-F507-4982-B2E5-502A71474FED}\components\NPComponent.dll
FF - component: c:\users\ANNA\AppData\Roaming\Mozilla\Firefox\Profiles\2ysnm7na.default\extensions\DTToolbar@toolbarnet.com\components\DTToolbarFF.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npbittorrent.dll
FF - plugin: c:\users\ANNA\AppData\Local\Google\Update\1.2.183.23\npGoogleOneClick8.dll
FF - plugin: c:\users\ANNA\AppData\Local\Yahoo!\BrowserPlus\2.7.1\Plugins\npybrowserplus_2.7.1.dll
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_popup_windows", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.enable_click_image_resizing", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("accessibility.browsewithcaret_shortcut.enabled", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("javascript.options.mem.high_water_mark", 32);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("javascript.options.mem.gc_frequency", 1600);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.trackpoint_hack.enabled", -1);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.debug", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.agedWeight", 2);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.bucketSize", 1);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.maxTimeGroupings", 25);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.timeGroupingSize", 604800);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.boundaryWeight", 25);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("browser.formfill.prefixWeight", 5);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("html5.enable", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox-branding.js - pref("app.update.download.backgroundInterval", 600);
c:\program files\Mozilla Firefox\defaults\pref\firefox-branding.js - pref("app.update.url.manual", "http://www.firefox.com");
c:\program files\Mozilla Firefox\defaults\pref\firefox-branding.js - pref("browser.search.param.yahoo-fr-ja", "mozff");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("xpinstall.whitelist.add", "addons.mozilla.org");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("xpinstall.whitelist.add.36", "getpersonas.com");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("lightweightThemes.update.enabled", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("browser.allTabs.previews", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.hide_infobar_for_outdated_plugin", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("toolbar.customization.usesheet", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.enable", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.max", 20);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.cachetime", 20);
HKCU-Run-geenjgom - c:\users\ANNA\AppData\Local\yoyhvjutw\mwuyrcxtssd.exe
HKLM-Run-Gamevance - c:\program files\Gamevance\gamevance32.exe
Rootkit scan 2010-04-27 20:37
Windows 6.0.6000 NTFS
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
Completion time: 2010-04-27 20:40:13
ComboFix-quarantined-files.txt 2010-04-28 00:40
Pre-Run: 25,367,384,064 bytes free
Post-Run: 26,896,666,624 bytes free
- - End Of File - - 9FBCB7606BE68521E7D6E446BB947BC0
newyorkgirl1982
Posts Posts : 3
OS OS : Vista
Post by Dr Jay on 28th April 2010, 2:35 am
  • Close any open browsers.
  • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
  • Open notepad and copy/paste the text in the box below into it:
    killall::
    Registry::
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{45F160E9-48B5-41C8-8093-CE70CEAE8F80}]
    collect::
    DDS::
    Reboot::
  • Save this as CFScript.txt, in the same location as ComboFix.exe
  • Referring to the picture above, drag CFScript into ComboFix.exe
  • When finished, it shall produce a log for you at C:\ComboFix.txt
  • Please post the contents of the log in your next reply.
Posts Posts : 14314
Post by newyorkgirl1982 on 29th April 2010, 4:23 am
Ok. I was able to do the second step. Here's my log:
ComboFix 10-04-28.03 - ANNA 04/28/2010 23:59:03.2.2 - x86
Microsoft® Windows Vista™ Ultimate 6.0.6000.0.1252.1.1033.18.1982.566 [GMT -4:00]
Running from: c:\users\ANNA\Desktop\ComboFix.exe
Command switches used :: c:\users\ANNA\Desktop\CFscript.txt
file zipped: c:\windows\System32\wownetb.dll
c:\users\ANNA\AppData\Local\asam.exe
c:\users\ANNA\AppData\Local\qtbndweam
c:\users\ANNA\AppData\Local\qtbndweam\gusamjntssd.exe
c:\users\ANNA\AppData\Local\syssvc.exe
((((((((((((((((((((((((( Files Created from 2010-03-28 to 2010-04-29 )))))))))))))))))))))))))))))))
2010-04-29 04:04 . 2010-04-29 04:06 -------- d-----w- c:\users\ANNA\AppData\Local\temp
2010-04-29 04:04 . 2010-04-29 04:04 -------- d-----w- c:\users\Public\AppData\Local\temp
2010-04-29 04:04 . 2010-04-29 04:04 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-04-29 03:02 . 2010-04-29 03:02 -------- d-----w- c:\windows\Sun
2010-04-28 01:15 . 2010-04-28 01:15 56 ---ha-w- c:\windows\system32\ezsidmv.dat
2010-04-28 00:22 . 2010-04-28 00:40 -------- d-----w- C:\commy
2010-04-29 03:58 . 2009-06-28 07:16 -------- d-----w- c:\users\ANNA\AppData\Roaming\Skype
2010-04-29 00:01 . 2009-06-28 07:19 -------- d-----w- c:\users\ANNA\AppData\Roaming\skypePM
2010-04-28 01:15 . 2009-06-28 16:13 -------- d-----w- c:\users\ANNA\AppData\Roaming\ICQ
"aux1"=wdmaud.drv
S0 sptd;sptd;c:\windows\System32\Drivers\sptd.sys [2009-10-26 721904]
2010-04-29 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2144488369-2711709791-3128680860-1000Core.job
2010-04-29 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2144488369-2711709791-3128680860-1000UA.job
HKCU-Run-eponqlcq - c:\users\ANNA\AppData\Local\qtbndweam\gusamjntssd.exe
HKCU-Run-asam - c:\users\ANNA\AppData\Local\asam.exe
HKLM-Run-asam - c:\users\ANNA\AppData\Local\asam.exe
hidden files:
c:\windows\system32\nvvsvc.exe
c:\windows\system32\WLANExt.exe
c:\program files\Hewlett-Packard\Shared\hpqwmiex.exe
c:\windows\system32\conime.exe
c:\windows\servicing\TrustedInstaller.exe
Completion time: 2010-04-29 00:14:31 - machine was rebooted
ComboFix-quarantined-files.txt 2010-04-29 04:14
ComboFix2.txt 2010-04-28 00:40
Pre-Run: 26,014,109,696 bytes free
Post-Run: 25,794,093,056 bytes free
- - End Of File - - 5AEBA19C6F68B54772ABE427AFE6F95C
Upload was successful
newyorkgirl1982
Posts Posts : 3
OS OS : Vista
Post by Dr Jay on 29th April 2010, 4:42 am
    killall::
    Registry::
    "Lanhtm"=-
    File::
    Reboot::
Posts Posts : 14314
