Internet Connection Problem
Post by selfster on 26th April 2010, 8:03 pm
I recently encountered a virus on my Dell Studio laptop which I got rid of using MalwareBytes software. This eliminated all the annoying pop-up messages and blocked applications. However, since then I have been unable to use any application that accesses the internet (other than Firefox for some reason). Applications like iTunes store, Internet Explorer and Google Chrome are all unable to display web pages. My laptop also is now unable to download Windows updates as it cannot access the internet.
I know that the connection is ok as I am able to access the internet via Firefox.
I've checked all of the programmes that are blocked by my Firewall and these are all checked as allowed programmes. I've tried restoring my laptop to a previous point where it was functioning properly but this has no effect on this.
Also I'm not sure if this is related but when I restart my laptop, I get the error message that "STLog.dll" cannot be found and that the ST service is unable to run.
I've tried restoring this file using the method recommended by Microsoft (a programme called "MicrosoftFixit50203") but this hasn't solved the problem either.
I'd really appreciate your help with this problem!
selfster
Posts Posts : 4
Joined Joined : 2010-04-26
OS OS : Windows Vista Home Premium
Protection Protection : Malwarebytes, Avast
Points Points : 24224
Re: Internet Connection Problem
Post by Gabethebabe on 27th April 2010, 8:19 am
Here is a proposed fix for the stlog.dll problem.
About your internet problem - since this is caused by malware and its removal, I think the best you can do is to read this and after that post here.
There you will find out if your computer is really clean and they might find out as well whether the infection changed some internet settings (like: installing a proxy) that now blocks your internet access.
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38258
