Anti-spyware soft removal help needed
Post by nspraker on Fri Apr 23, 2010 1:35 pm
My PC running XP has become infected with anti-spyware soft. I have followed directions posted on the forum to remove by running in safe-mode with networking. Removing the proxy setting on internet connections lan setting and running a full scan of malwarebytes. I updated malwarebytes with the latest DB and removed all infected files. However, when I reboot, anti-spyware soft is still on my PC.
Any suggestions would be greatly appreciated.
Nancy
nspraker
OS : xp media
Re: Anti-spyware soft removal help needed
Post by Belahzur on Fri Apr 23, 2010 3:50 pm
