Trojan Problem
Re: Trojan Problem
Post by Dr Jay on Thu Apr 22, 2010 11:52 pm
Your logs are clean. How is your computer running?
Posts Posts : 13713
Points Points : 302059
Re: Trojan Problem
Post by dychang on Fri Apr 23, 2010 12:43 am
internet explorer and google chrome do not work. firefox works.
dychang
Posts Posts : 64
Joined Joined : 2009-01-13
Points Points : 29208
Re: Trojan Problem
Post by Dr Jay on Fri Apr 23, 2010 1:01 am
  • Extract it to Desktop and double click SREngLdr.EXE to run it
  • Select System Repair from the left pane.
  • Click on File Association
  • Select all entries that has an Error status click [Repair]
  • Refer to this image for an example:
  • Close SREng now.
Let me know what was fixed.
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Fri Apr 23, 2010 1:27 am
There was an error with .JS
But when i click repair nothing happened. Still says error.
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Fri Apr 23, 2010 1:36 am
Ok.
Let's go out on a limb.
SysProt Antirootkit
Download
SysProt Antirootkit from the link below (you will find it at the bottom
of the page under attachments, or you can get it from one of the
mirrors).
Unzip it into a folder on your desktop.
  • Double click Sysprot.exe to start the program.
  • Click on the Log tab.
  • In the Write to log box select the following items.
    • Process << Selected
    • Kernel Modules << Selected
    • SSDT << Selected
    • Kernel Hooks << Selected
    • IRP Hooks << NOT Selected
    • Ports << NOT Selected
    • Hidden Files << Selected
  • At the bottom of the page
    • Hidden Objects Only << Selected
  • Click on the Create Log button on the bottom right.
  • After a few seconds a new window should appear.
  • Select Scan Root Drive. Click on the Start button.
  • When it is complete a new window will appear to indicate that the scan is finished.
  • The
    log will be saved automatically in the same folder Sysprot.exe was
    extracted to. Open the text file and copy/paste the log here.
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Fri Apr 23, 2010 1:49 am
SysProt AntiRootkit v1.0.1.0
by swatkat
No Hidden Processes found
No Hidden Kernel Modules found
No SSDT Hooks found
No Kernel Hooks found
No hidden files/folders found
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Fri Apr 23, 2010 1:56 am
Please download [You must be registered and logged in to see this link.] and save it to your Desktop.
Note: You must be logged on to the system with an account that has Administrator privileges to run this program.
  • Close ALL OTHER PROGRAMS.
  • Double-click on OTS to start the program (if you are running on Vista then right-click the program and
    choose Run as Administrator).
  • At the top, tick on Scan All Users section and Include MD5.
  • At File Age set it to 90 Days
  • In the Processes, Modules, Services, Drivers, and Registry
    section, please set on Safe List.
  • In the Files Created Within and Files Modified Within section, set it to File Age
  • At the bottom, tick on all Safe List and Use Company Name WhiteList option
  • Under Additional Scans, tick on the "Extras" button and then click the checkboxes in front of the following items to select them:
      Reg - Disabled MS Config Items
      Reg - Drivers32
      Reg - Ext
      Reg - IE
      Explorer Bar
      Reg - NetSvcs
      Reg - Safeboot Minimal
      Reg - Safeboot Network
      File - Lop Check
      File - Purity Scan
  • Do NOT change any other settings.
  • Then, in the Custom Scans box, place this in:
    %systemroot%\*. /mp /s
    %systemroot%\System32\*.sys
    %systemroot%\System32\drivers\*.dll
    %systemroot%\System32\drivers\*.ini
    %systemroot%\System32\drivers\*.exe
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
  • Now click the Run Scan button on the toolbar.
  • Let it run unhindered until it finishes.
  • When the scan is complete Notepad will open with the report file loaded in it.
  • Click the Format menu and make sure that Wordwrap is not checked. If it is then click on it to uncheck it.
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Fri Apr 23, 2010 2:21 am
[code]
OTS logfile created on: 4/22/2010 10:10:40 PM - Run 1
OTS by OldTimer - Version 3.1.29.0 Folder = C:\Users\Stephanie\Downloads
64bit-Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 8.0.6001.18882)
4.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 48.00% Memory free
8.00 Gb Paging File | 6.00 Gb Available in Paging File | 74.00% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 284.39 Gb Total Space | 27.88 Gb Free Space | 9.80% Space Free | Partition Type: NTFS
Drive D: | 13.70 Gb Total Space | 2.10 Gb Free Space | 15.32% Space Free | Partition Type: NTFS
Computer Name: STEPHANIE-PC
Current User Name: Stephanie
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: All users
Company Name Whitelist: On
Skip Microsoft Files: Off
File Age = 90 Days
[Processes - Safe List]
ots (2).exe -> C:\Users\Stephanie\Downloads\OTS (2).exe -> [2010/04/22 22:01:54 | 000,638,976 | ---- | M | MD5 = DB2AB821FA03D3E233BE4F64B6D83320] (OldTimer Tools)
applemobiledeviceservice.exe -> C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe -> [2010/03/19 10:49:20 | 000,144,672 | ---- | M | MD5 = ACB095E7E1663F1B83A41C22C5D75F90] (Apple Inc.)
googlecrashhandler.exe -> C:\Users\Stephanie\AppData\Local\Google\Update\1.2.183.23\GoogleCrashHandler.exe -> [2010/03/18 04:03:07 | 000,136,176 | ---- | M | MD5 = 5466909C288218D868AAB8061D308E71] (Google Inc.)
sansadispatch.exe -> C:\Users\Stephanie\AppData\Roaming\SanDisk\Sansa Updater\SansaDispatch.exe -> [2010/03/12 03:13:55 | 000,079,872 | ---- | M | MD5 = E5F661A0A9689AF91FD293BB983E3EAD] (SanDisk Corporation)
rimautoupdate.exe -> C:\Program Files (x86)\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe -> [2010/03/10 22:32:26 | 000,648,536 | ---- | M | MD5 = F19C447D7DA713D3FBAA672D0CDA9D94] (Research In Motion Limited)
googledesktop.exe -> C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe -> [2010/01/23 18:22:26 | 000,030,192 | ---- | M | MD5 = F0187E45268E86AAAA932CBD9087BEA8] (Google)
sidebar.exe -> C:\Program Files (x86)\Windows Sidebar\sidebar.exe -> [2009/04/11 02:28:03 | 001,233,920 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
tvcapsvc.exe -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVCapSvc.exe -> [2009/02/09 18:14:02 | 000,296,320 | ---- | M | MD5 = 862E9DEC4B802DD58D897A151A17C527] ()
tvsched.exe -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVSched.exe -> [2009/02/09 18:14:02 | 000,116,096 | ---- | M | MD5 = 5DCE4656BF1EBA4EB475D192F23B0B56] ()
tvagent.exe -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\TVAgent.exe -> [2009/02/09 18:13:36 | 000,206,120 | ---- | M | MD5 = A7A5FC14A6D2A400AB8F2E0FA58D82FD] (CyberLink Corp.)
clmlsvc.exe -> C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe -> [2008/12/25 16:41:20 | 000,189,736 | ---- | M | MD5 = 498A9E93BCBBB3FBCEAB2ADA3B66658E] (CyberLink)
tsmagent.exe -> C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\TSMAgent.exe -> [2008/12/25 16:41:16 | 001,316,136 | ---- | M | MD5 = 1131F49F162539DD4834C67B4E93CD89] (CyberLink Corp.)
blservice.exe -> C:\Program Files (x86)\SMINST\BLService.exe -> [2008/12/17 20:11:40 | 000,365,952 | ---- | M | MD5 = BC0A4D47472B042537F4E57B950415FA] ()
dvdagent.exe -> C:\Program Files (x86)\Hewlett-Packard\Media\DVD\DVDAgent.exe -> [2008/11/28 21:04:26 | 001,148,200 | ---- | M | MD5 = B6F6228AB545E2819A60C0D63A84E52E] (CyberLink Corp.)
viewpointservice.exe -> C:\Program Files (x86)\Viewpoint\Common\ViewpointService.exe -> [2007/01/04 17:38:08 | 000,024,652 | ---- | M | MD5 = 5F974FDE801C73952770736BECDE11E7] (Viewpoint Corporation)
googletalk.exe -> C:\Users\Stephanie\AppData\Roaming\Google\Google Talk\googletalk.exe -> [2007/01/01 17:22:02 | 003,739,648 | ---- | M | MD5 = BCD9CBF0621F9A6767276A2E0BF1DD15] (Google)
[Modules - Safe List]
comdlg32.dll -> C:\Windows\SysWOW64\comdlg32.dll -> [2009/04/11 02:28:18 | 000,450,560 | ---- | M | MD5 = 4AA2A0E26CEF1A803741253DCF9A1503] (Microsoft Corporation)
[Win32 Services - Safe List]
(Apple Mobile Device) Apple Mobile Device [Auto | Running] -> C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe -> [2010/03/19 10:49:20 | 000,144,672 | ---- | M | MD5 = ACB095E7E1663F1B83A41C22C5D75F90] (Apple Inc.)
(GoogleDesktopManager-110309-193829) Google Desktop Manager 5.9.911.3589 [On_Demand | Stopped] -> C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe -> [2010/01/23 18:22:26 | 000,030,192 | ---- | M | MD5 = F0187E45268E86AAAA932CBD9087BEA8] (Google)
(clr_optimization_v2.0.50727_64) Microsoft .NET Framework NGEN v2.0.50727_X64 [On_Demand | Stopped] -> C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorsvw.exe -> [2009/03/30 00:39:54 | 000,089,920 | ---- | M | MD5 = CE07A466201096F021CD09D631B21540] (Microsoft Corporation)
(TVCapSvc) TV Background Capture Service (TVBCS) [Auto | Running] -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVCapSvc.exe -> [2009/02/09 18:14:02 | 000,296,320 | ---- | M | MD5 = 862E9DEC4B802DD58D897A151A17C527] ()
(TVSched) TV Task Scheduler (TVTS) [Auto | Running] -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\Kernel\TV\TVSched.exe -> [2009/02/09 18:14:02 | 000,116,096 | ---- | M | MD5 = 5DCE4656BF1EBA4EB475D192F23B0B56] ()
(Recovery Service for Windows) Recovery Service for Windows [Auto | Running] -> C:\Program Files (x86)\SMINST\BLService.exe -> [2008/12/17 20:11:40 | 000,365,952 | ---- | M | MD5 = BC0A4D47472B042537F4E57B950415FA] ()
(Microsoft Office Groove Audit Service) Microsoft Office Groove Audit Service [On_Demand | Stopped] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveAuditService.exe -> [2008/10/25 11:44:08 | 000,065,888 | ---- | M | MD5 = 7C4C76B39D5525C4A465E0BE32528E19] (Microsoft Corporation)
(Viewpoint Manager Service) Viewpoint Manager Service [Auto | Running] -> C:\Program Files (x86)\Viewpoint\Common\ViewpointService.exe -> [2007/01/04 17:38:08 | 000,024,652 | ---- | M | MD5 = 5F974FDE801C73952770736BECDE11E7] (Viewpoint Corporation)
(MSDTC) Distributed Transaction Coordinator [Unknown | Stopped] -> C:\Windows\SysWOW64\Msdtc -> [2006/11/02 09:34:14 | 000,000,000 | ---D | M]
(vds) Virtual Disk [On_Demand | Stopped] -> C:\Windows\SysWOW64\wbem\vds.mof -> [2006/11/02 02:35:15 | 000,060,994 | ---- | M | MD5 = 21A96F0C1B123F2463C6D624F125EAC9] ()
(VSS) Volume Shadow Copy [On_Demand | Stopped] -> C:\Windows\SysWOW64\wbem\vss.mof -> [2006/11/02 02:35:15 | 000,055,846 | ---- | M | MD5 = 9E4414C27EEC14EAF36A4BD24CFEEA93] ()
[Driver Services - Safe List]
({55662437-DA8C-40c0-AADA-2C816A897A49}) Power Control [2009/05/21 20:32:39] [Kernel | Auto | Running] -> C:\Program Files (x86)\Hewlett-Packard\Media\DVD\000.fcl -> [2008/11/28 21:04:24 | 000,146,928 | ---- | M | MD5 = 1CACFEF9E5DD866C5B79A135EE729E18] (CyberLink Corp.)
(Tcpip) TCP/IP Protocol Driver [Kernel | Boot | Running] -> C:\Windows\SysWOW64\wbem\tcpip.mof -> [2006/09/18 17:36:40 | 000,003,066 | ---- | M | MD5 = EEC4A068DE477651214F6C8014ECBEC0] ()
(mpsdrv) Windows Firewall Authorization Driver [Kernel | On_Demand | Running] -> C:\Windows\SysWOW64\wbem\mpsdrv.mof -> [2006/09/18 17:35:23 | 000,001,088 | ---- | M | MD5 = 74D68CB40BCD45AAE89A8BECC87D3868] ()
(ASPI) Advanced SCSI Programming Interface Driver [Kernel | On_Demand | Stopped] -> C:\Windows\SysWOW64\drivers\ASPI32.SYS -> [2002/07/17 16:20:32 | 000,084,832 | ---- | M | MD5 = E54E27976E2C5A6465D44C10B1D87AC0] (Adaptec)
[Registry - Safe List]
< Internet Explorer Settings [HKEY_LOCAL_MACHINE\] > -> ->
HKEY_LOCAL_MACHINE\: Main\\"Default_Page_URL" -> [You must be registered and logged in to see this link.] ->
HKEY_LOCAL_MACHINE\: Main\\"Local Page" -> C:\Windows\SysWOW64\blank.htm ->
HKEY_LOCAL_MACHINE\: Main\\"Start Page" -> [You must be registered and logged in to see this link.] ->
< Internet Explorer Settings [HKEY_USERS\.DEFAULT\] > -> ->
HKEY_USERS\.DEFAULT\: "ProxyEnable" -> 0 ->
< Internet Explorer Settings [HKEY_USERS\S-1-5-18\] > -> ->
HKEY_USERS\S-1-5-18\: "ProxyEnable" -> 0 ->
< Internet Explorer Settings [HKEY_USERS\S-1-5-19\] > -> ->
< Internet Explorer Settings [HKEY_USERS\S-1-5-20\] > -> ->
< Internet Explorer Settings [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Main\\"Default_Page_URL" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Main\\"Default_Search_URL" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Main\\"Search Page" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Main\\"Start Page" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Main\\"StartPageCache" -> 1 ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Search\\"Default_Search_URL" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: Search\\"SearchAssistant" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: SearchURL\\"" -> [You must be registered and logged in to see this link.] ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: "ProxyEnable" -> 0 ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: "ProxyOverride" -> ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: "ProxyServer" -> http=127.0.0.1:5555 ->
< FireFox Settings [Prefs.js] > -> C:\Users\Stephanie\AppData\Roaming\Mozilla\FireFox\Profiles\kofsij80.default\prefs.js ->
extensions.enabledItems -> [You must be registered and logged in to see this link.]:1.0.0.586 ->
extensions.enabledItems -> [You must be registered and logged in to see this link.]:7 ->
network.proxy.type -> 4 ->
< FireFox Extensions [HKLM] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla
HKLM\software\mozilla\Firefox\Extensions -> ->
HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions -> ->
HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Components -> C:\Program Files (x86)\Mozilla Firefox\components [C:\PROGRAM FILES (X86)\MOZILLA FIREFOX\COMPONENTS] -> [2010/04/21 00:32:05 | 000,000,000 | ---D | M]
HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Plugins -> C:\Program Files (x86)\Mozilla Firefox\plugins [C:\PROGRAM FILES (X86)\MOZILLA FIREFOX\PLUGINS] -> [2010/04/21 00:32:05 | 000,000,000 | ---D | M]
< FireFox Extensions [User Folders] > ->
-> C:\Users\Stephanie\AppData\Roaming\Mozilla\Extensions -> [2009/10/11 21:19:46 | 000,000,000 | ---D | M]
-> C:\Users\Stephanie\AppData\Roaming\Mozilla\Firefox\Profiles\kofsij80.default\extensions -> [2010/04/22 00:57:48 | 000,000,000 | ---D | M]
Microsoft .NET Framework Assistant -> C:\Users\Stephanie\AppData\Roaming\Mozilla\Firefox\Profiles\kofsij80.default\extensions\{20a82645-c095-46ed-80e3-08825760534b} -> [2009/10/11 21:41:39 | 000,000,000 | ---D | M]
-> C:\Users\Stephanie\AppData\Roaming\Mozilla\Firefox\Profiles\kofsij80.default\extensions\LogMeInClient@logmein.com -> [2010/03/08 11:12:27 | 000,000,000 | ---D | M]
< FireFox Extensions [Program Folders] > ->
-> C:\Program Files (x86)\Mozilla Firefox\extensions -> [2010/04/21 00:42:10 | 000,000,000 | ---D | M]
~[Filtered]~
Reset Hosts
127.0.0.1 localhost
::1 localhost
< BHO's [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\ ->
{22BF413B-C6D2-4d91-82A9-A0F997BA588C} [HKLM] -> C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll [Skype add-on (mastermind)] -> [2009/06/02 11:56:14 | 001,082,880 | ---- | M | MD5 = CE16731D20BC8AFD532AC7A526D809A9] (Skype Technologies S.A.)
{5C255C8A-E604-49b4-9D64-90988571CECB} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{72853161-30C5-4D22-B7F9-0BBC1D38A37E} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [Groove GFS Browser Helper] -> [2009/02/12 15:19:32 | 002,217,848 | ---- | M | MD5 = A6B5A41C0ED007AB6C43CAD899E533D8] (Microsoft Corporation)
{9030D464-4C02-4ABF-8ECC-5164760863C6} [HKLM] -> C:\Program Files (x86)\Common Files\microsoft shared\Windows Live\WindowsLiveLogin.dll [Windows Live Sign-in Helper] -> [2009/01/22 15:41:30 | 000,408,448 | ---- | M | MD5 = B7899C3E21B299D7A3C0DA96CAE340BD] (Microsoft Corporation)
{d2ce3e00-f94a-4740-988e-03dc2f38c34f} [HKLM] -> c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll [Microsoft Live Search Toolbar Helper] -> [2008/08/29 00:09:08 | 000,086,032 | ---- | M | MD5 = C12121B120411F2C9A457AF8339AB6C6] (Microsoft Corp.)
< Internet Explorer ToolBars [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ToolBar ->
"{1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414}" [HKLM] -> c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll [Microsoft Live Search Toolbar] -> [2008/08/29 00:09:08 | 000,086,032 | ---- | M | MD5 = C12121B120411F2C9A457AF8339AB6C6] (Microsoft Corp.)
"{CCC7A320-B3CA-4199-B1A6-9F516DD69829}" [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
< Internet Explorer ToolBars [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\Software\Microsoft\Internet Explorer\Toolbar\ ->
WebBrowser\\"{604BC32A-9680-40D1-9AC6-E06B23A1BA4C}" [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
WebBrowser\\"{CCC7A320-B3CA-4199-B1A6-9F516DD69829}" [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
< Run [HKEY_LOCAL_MACHINE\] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ->
"" -> [] -> File not found
"BlackBerryAutoUpdate" -> C:\Program Files (x86)\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe [C:\Program Files (x86)\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe /background] -> [2010/03/10 22:32:26 | 000,648,536 | ---- | M | MD5 = F19C447D7DA713D3FBAA672D0CDA9D94] (Research In Motion Limited)
"CLMLServer for HP TouchSmart" -> C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe ["C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe"] -> [2008/12/25 16:41:20 | 000,189,736 | ---- | M | MD5 = 498A9E93BCBBB3FBCEAB2ADA3B66658E] (CyberLink)
"DVDAgent" -> C:\Program Files (x86)\Hewlett-Packard\Media\DVD\DVDAgent.exe ["C:\Program Files (x86)\Hewlett-Packard\Media\DVD\DVDAgent.exe"] -> [2008/11/28 21:04:26 | 001,148,200 | ---- | M | MD5 = B6F6228AB545E2819A60C0D63A84E52E] (CyberLink Corp.)
"Google Desktop Search" -> C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe ["C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe" /startup] -> [2010/01/23 18:22:26 | 000,030,192 | ---- | M | MD5 = F0187E45268E86AAAA932CBD9087BEA8] (Google)
"GrooveMonitor" -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe ["C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe"] -> [2008/10/25 11:44:34 | 000,031,072 | ---- | M | MD5 = 644795F6985C740F5E36E9336B837D0B] (Microsoft Corporation)
"HP Health Check Scheduler" -> c:\Program Files (x86)\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe [c:\Program Files (x86)\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe] -> [2008/10/09 11:58:56 | 000,075,008 | ---- | M | MD5 = AE37F6508716D2DD6122744C46686BEC] (Hewlett-Packard)
"Malwarebytes Anti-Malware (reboot)" -> C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe ["C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript] -> [2010/03/30 00:46:02 | 001,086,856 | ---- | M | MD5 = 6FD614E7109CC0A3DAFE65F9D394F66E] (Malwarebytes Corporation)
"RoxWatchTray" -> C:\Program Files (x86)\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe ["C:\Program Files (x86)\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe"] -> [2009/07/08 13:31:24 | 000,236,016 | ---- | M | MD5 = BC9884D6D1D66993733B802E3F24B6B3] (Sonic Solutions)
"TSMAgent" -> C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\TSMAgent.exe ["C:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\TSMAgent.exe"] -> [2008/12/25 16:41:16 | 001,316,136 | ---- | M | MD5 = 1131F49F162539DD4834C67B4E93CD89] (CyberLink Corp.)
"TVAgent" -> C:\Program Files (x86)\Hewlett-Packard\Media\TV\TVAgent.exe ["C:\Program Files (x86)\Hewlett-Packard\Media\TV\TVAgent.exe"] -> [2009/02/09 18:13:36 | 000,206,120 | ---- | M | MD5 = A7A5FC14A6D2A400AB8F2E0FA58D82FD] (CyberLink Corp.)
"UCam_Menu" -> C:\Program Files (x86)\Hewlett-Packard\Media\Webcam\MUITransfer\MUIStartMenu.exe ["C:\Program Files (x86)\Hewlett-Packard\Media\Webcam\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\Hewlett-Packard\Media\Webcam" update "Software\Hewlett-Packard\Media\Webcam"] -> [2008/11/15 01:02:14 | 000,218,408 | ---- | M | MD5 = E86D6EEABEF5596F95E3810DB26948C8] (CyberLink Corp.)
"UpdateLBPShortCut" -> C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe ["C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"] -> [2008/06/13 22:11:32 | 000,210,216 | ---- | M | MD5 = 601D77C0AA637A99073210894554B6BA] (CyberLink Corp.)
"UpdateP2GoShortCut" -> C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe ["C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"] -> [2008/10/30 15:51:46 | 000,210,216 | ---- | M | MD5 = 4B57A44B5DDFDE882A050CDA5FC3E092] (CyberLink Corp.)
"UpdatePDIRShortCut" -> C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe ["C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\PowerDirector" UpdateWithCreateOnce "SOFTWARE\CyberLink\PowerDirector\7.0"] -> [2008/06/13 22:11:32 | 000,210,216 | ---- | M | MD5 = 601D77C0AA637A99073210894554B6BA] (CyberLink Corp.)
"UpdatePSTShortCut" -> C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe ["C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"] -> [2008/11/26 15:34:22 | 000,210,216 | ---- | M | MD5 = 82A3031F7FAA61CB5E040B0D98A104AF] (CyberLink Corp.)
< Run [HKEY_USERS\S-1-5-19\] > -> HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ->
"Sidebar" -> C:\Program Files (x86)\Windows Sidebar\Sidebar.exe [%ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem] -> [2009/04/11 02:28:03 | 001,233,920 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
"WindowsWelcomeCenter" -> C:\Windows\SysWow64\oobefldr.dll [rundll32.exe oobefldr.dll,ShowWelcomeCenter] -> [2009/04/11 02:28:23 | 002,153,472 | ---- | M | MD5 = 16FC5B430123238E522B18E63C257AF8] (Microsoft Corporation)
< Run [HKEY_USERS\S-1-5-20\] > -> HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ->
< Run [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ->
"Aim6" -> C:\Program Files (x86)\AIM6\aim6.exe ["C:\Program Files (x86)\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.] -> [2009/05/19 01:23:16 | 000,049,968 | ---- | M | MD5 = 5B4AF27E83DA8385A9B08E76DA730C91] (AOL LLC)
"googletalk" -> C:\Users\Stephanie\AppData\Roaming\Google\Google Talk\googletalk.exe [C:\Users\Stephanie\AppData\Roaming\Google\Google Talk\googletalk.exe /autostart] -> [2007/01/01 17:22:02 | 003,739,648 | ---- | M | MD5 = BCD9CBF0621F9A6767276A2E0BF1DD15] (Google)
"msnmsgr" -> C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe ["C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background] -> [2009/07/26 16:44:34 | 003,883,856 | ---- | M | MD5 = D39DA5B7139B4B5147B3C6A94978B5AA] (Microsoft Corporation)
"SansaDispatch" -> C:\Users\Stephanie\AppData\Roaming\SanDisk\Sansa Updater\SansaDispatch.exe [C:\Users\Stephanie\AppData\Roaming\SanDisk\Sansa Updater\SansaDispatch.exe] -> [2010/03/12 03:13:55 | 000,079,872 | ---- | M | MD5 = E5F661A0A9689AF91FD293BB983E3EAD] (SanDisk Corporation)
"Sidebar" -> C:\Program Files (x86)\Windows Sidebar\sidebar.exe [C:\Program Files (x86)\Windows Sidebar\sidebar.exe] -> [2009/04/11 02:28:03 | 001,233,920 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
"WMPNSCFG" -> C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe [C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe] -> File not found
< CurrentVersion Policy Settings - Explorer [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer ->
\\"NoActiveDesktop" -> [1] -> File not found
< CurrentVersion Policy Settings - System [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System ->
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats
< CurrentVersion Policy Settings [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer ->
< CurrentVersion Policy Settings [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System ->
< Internet Explorer Menu Extensions [HKEY_USERS\S-1-5-19\] > -> HKEY_USERS\S-1-5-19\Software\Microsoft\Internet Explorer\MenuExt\ ->
Add to Google Photos Screensa&ver -> C:\Windows\SysWow64\GPhotos.scr [res://C:\Windows\system32\GPhotos.scr/200] -> [2010/02/19 19:47:50 | 003,604,480 | ---- | M | MD5 = D909DFE8CA0FA8E505B7C6B4621AF745] (Google Inc.)
< Internet Explorer Menu Extensions [HKEY_USERS\S-1-5-20\] > -> HKEY_USERS\S-1-5-20\Software\Microsoft\Internet Explorer\MenuExt\ ->
< Internet Explorer Menu Extensions [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\Software\Microsoft\Internet Explorer\MenuExt\ ->
< Internet Explorer Extensions [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\ ->
{2670000A-7350-4f3c-8081-5663EE0C6C49}:{48E73304-E1D6-4330-914C-F5F514E3486C} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll [Button: Send to OneNote] -> [2008/10/25 07:52:00 | 000,604,056 | ---- | M | MD5 = E003E1BE8780DD39DF02C3F06CDEDF04] (Microsoft Corporation)
{2670000A-7350-4f3c-8081-5663EE0C6C49}:{48E73304-E1D6-4330-914C-F5F514E3486C} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll [Menu: S&end to OneNote] -> [2008/10/25 07:52:00 | 000,604,056 | ---- | M | MD5 = E003E1BE8780DD39DF02C3F06CDEDF04] (Microsoft Corporation)
{77BF5300-1474-4EC7-9980-D32B190E9B07}:{77BF5300-1474-4EC7-9980-D32B190E9B07} [HKLM] -> C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll [Button: Skype] -> [2009/06/02 11:56:14 | 001,082,880 | ---- | M | MD5 = CE16731D20BC8AFD532AC7A526D809A9] (Skype Technologies S.A.)
< Default Prefix > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\URL\DefaultPrefix
< Trusted Sites Domains [HKEY_LOCAL_MACHINE\] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 0 domain(s) found. ->
< Trusted Sites Ranges [HKEY_LOCAL_MACHINE\] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 0 range(s) found. ->
< Trusted Sites Domains [HKEY_USERS\.DEFAULT\] > -> HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 0 domain(s) found. ->
< Trusted Sites Ranges [HKEY_USERS\.DEFAULT\] > -> HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 1 range(s) found. ->
Range1 [:Range = 127.0.0.1] -> http = Local intranet | ->
< Trusted Sites Domains [HKEY_USERS\S-1-5-18\] > -> HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 0 domain(s) found. ->
< Trusted Sites Ranges [HKEY_USERS\S-1-5-18\] > -> HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 1 range(s) found. ->
< Trusted Sites Domains [HKEY_USERS\S-1-5-19\] > -> HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 0 domain(s) found. ->
< Trusted Sites Ranges [HKEY_USERS\S-1-5-19\] > -> HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 0 range(s) found. ->
< Trusted Sites Domains [HKEY_USERS\S-1-5-20\] > -> HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 0 domain(s) found. ->
< Trusted Sites Ranges [HKEY_USERS\S-1-5-20\] > -> HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 0 range(s) found. ->
< Trusted Sites Domains [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\ -> [Key] 1 domain(s) found. ->
localhost .[http] -> Local intranet ->
< Trusted Sites Ranges [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ ->
HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Ranges\ -> [Key] 2 range(s) found. ->
GD [:Range = 127.0.0.1] -> http = Local intranet | ->
< Downloaded Program Files > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\ ->
{8AD9C840-044E-11D1-B3E9-00805F499D93} [HKLM] -> [You must be registered and logged in to see this link.] [Java Plug-in 1.6.0_18] ->
{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [HKLM] -> [You must be registered and logged in to see this link.] [Java Plug-in 1.6.0_07] ->
{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA} [HKLM] -> [You must be registered and logged in to see this link.] [Java Plug-in 1.6.0_18] ->
{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [HKLM] -> [You must be registered and logged in to see this link.] [Java Plug-in 1.6.0_18] ->
{FD0B6769-6490-4A91-AA0A-B5AE0DC75AC9} [HKLM] -> [You must be registered and logged in to see this link.] [Performance Viewer Activex Control] ->
< Name Servers [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\ ->
DhcpNameServer -> 192.168.2.50 216.220.96.17 ->
< Name Servers [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Adapters\ ->
{75B191AD-E0A8-438A-BDB2-EC5D29142D7C}\\DhcpNameServer -> 192.168.2.50 216.220.96.17 (Realtek RTL8102E Family PCI-E Fast Ethernet NIC (NDIS 6.0)) ->
{F90732FA-B7B2-4A3E-AF2F-E22A3F22891F}\\DhcpNameServer -> 208.59.247.45 208.59.247.46 192.168.1.1 208.59.247.45 208.59.247.46 (Broadcom 802.11b/g WLAN) ->
< Winlogon settings [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon ->
*Shell* -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\\Shell ->
explorer.exe -> C:\Windows\SysWow64\explorer.exe -> [2009/04/11 02:27:36 | 002,926,592 | ---- | M | MD5 = D07D4C3038F3578FFCE1C0237F2A1253] (Microsoft Corporation)
*MultiFile Done* -> ->
< ShellExecuteHooks [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks ->
"{B5A7F190-DDA6-4420-B3BA-52453494E6CD}" [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [Groove GFS Stub Execution Hook] -> [2009/02/12 15:19:32 | 002,217,848 | ---- | M | MD5 = A6B5A41C0ED007AB6C43CAD899E533D8] (Microsoft Corporation)
< Vista Public Profile Authorized Applications List > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile\AuthorizedApplications ->
< Vista Standard Profile Authorized Applications List > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications ->
< Vista Active Firewall Rules > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules ->
{02B048F8-F6B9-4D25-82C1-B8167CA72757} -> lport=2869 | protocol=6 | dir=in | action=allow | name=windows live messenger (upnp-in) | app=system |
{CBC50CB0-34DD-42BD-A53A-0539C0B7DD98} -> lport=6004 | profile=private | protocol=17 | dir=in | action=allow | name=microsoft office outlook | app=c:\program files (x86)\microsoft office\office12\outlook.exe |
{F306F0B2-151E-404C-8AB1-5B4C5435E727} -> lport=1900 | protocol=17 | dir=in | action=allow | name=windows live messenger (ssdp-in) | app=svchost.exe | svc=ssdpsrv |
< Vista Active Application Exception Rules > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules ->
{086254D1-F936-426F-A55F-A0DF29F7EF5D} -> profile=private | protocol=6 | dir=in | action=allow | name=bittorrent | app=c:\program files (x86)\bittorrent\bittorrent.exe |
{0D967056-9663-40DE-80FE-55DECAE2E3CF} -> profile=private | protocol=6 | dir=in | action=allow | name=microsoft office onenote | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
{0F4B7AA6-9DDF-4A1A-9492-4C4E8BD50EC9} -> dir=in | action=allow | name=hp touchsmart photo | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartphoto.exe |
{0F8B2BCE-1BEC-4CBA-923C-89D2A232392B} -> dir=in | action=allow | name=skype | app=c:\program files (x86)\skype\phone\skype.exe |
{11D22930-C2B3-4FE7-B162-5C8154035993} -> profile=private | protocol=6 | dir=in | action=allow | name=google talk plugin | app=c:\users\stephanie\appdata\local\google\google talk plugin\googletalkplugin.dll |
{15CCAD21-727A-43F9-914F-C0054864FC88} -> dir=in | action=allow | name=quick play resident program | app=c:\program files (x86)\hewlett-packard\media\tv\qpservice.exe |
{200FAD99-AAB3-49D0-9739-9A2205C23CB0} -> dir=in | action=allow | name=hp touchsmart photo | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartphoto.exe |
{2348E35A-4BE7-4D26-BCC1-366B06FF2731} -> profile=private | dir=in | action=allow | name=avgnsa.exe | app=c:\program files (x86)\avg\avg8\avgnsa.exe |
{2C687107-B50A-40CD-80D6-25C671B2B8F8} -> profile=private | protocol=17 | dir=in | action=allow | name=microsoft office onenote | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
{2ECFC0E1-13E1-4932-A1A5-2DFC005CD989} -> dir=in | action=allow | name=hp touchsmart music | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartmusic.exe |
{3259AE1C-4E15-4747-96E0-54D2DA313D6E} -> profile=public | protocol=6 | dir=in | action=allow | name=aol loader | app=c:\program files (x86)\common files\aol\loader\aolload.exe |
{39AAB840-CE72-4C9B-B9DF-85198DC9E692} -> dir=in | action=allow | name=cyberlink powerdirector | app=c:\program files (x86)\cyberlink\powerdirector\pdr.exe |
{3D3C88B7-04C1-4018-BB3C-6C192393F47B} -> profile=public | protocol=6 | dir=in | action=allow | name=aim | app=c:\program files (x86)\aim6\aim6.exe |
{4582FB5B-96FA-45B1-960C-168BB811524E} -> profile=public | protocol=17 | dir=in | action=allow | name=aim | app=c:\program files (x86)\aim6\aim6.exe |
{477CA2AA-7D2C-4A6B-B52A-E23DBBA52CB4} -> profile=private | protocol=17 | dir=in | action=allow | name=bittorrent | app=c:\program files (x86)\bittorrent\bittorrent.exe |
{4C1D311C-2200-4732-ADF1-FFA74ECDA443} -> profile=public | protocol=6 | dir=in | action=allow | name=microsoft office onenote | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
{5E455DE9-48A1-4EBA-B9F0-7A84C4A09B78} -> profile=private | protocol=17 | dir=in | action=allow | name=itunes | app=c:\program files (x86)\itunes\itunes.exe |
{6E75C581-47AC-4B5E-B6EA-E391ED6978AC} -> dir=in | action=allow | name=hp touchsmart video | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartvideo.exe |
{6FAC5DDB-BAE0-4551-8AFC-F172F377DB83} -> dir=in | action=allow | name=cyberlink media service | app=c:\program files (x86)\hewlett-packard\touchsmart\media\kernel\clml\clmlsvc.exe |
{77FF893B-F222-49F7-A421-8ADDF920D4FE} -> dir=in | action=allow | name=quick play | app=c:\program files (x86)\hewlett-packard\media\tv\qp.exe |
{7CEC41B6-70D0-454E-A547-A39A71D7496C} -> dir=in | action=allow | name=hp touchsmart media resident program | app=c:\program files (x86)\hewlett-packard\media\dvd\tsmagent.exe |
{8463B747-15D6-40BE-90D9-5257AEB63E80} -> profile=private | protocol=17 | dir=in | action=allow | name=google talk plugin | app=c:\users\stephanie\appdata\local\google\google talk plugin\googletalkplugin.exe |
{866F0DA9-C9AE-4537-BB6A-A7864AD29C18} -> dir=in | action=allow | name=hp touchsmart video | app=c:\program files (x86)\hewlett-packard\touchsmart\media\hptouchsmartvideo.exe |
{8AE82D9F-5804-4745-9195-E91048D360D5} -> profile=public | protocol=17 | dir=in | action=allow | name=aol loader | app=c:\program files (x86)\common files\aol\loader\aolload.exe |
{8B32D8F0-58F9-4019-912F-455AE1CC3E75} -> dir=in | action=allow | name=windows live messenger | app=c:\program files (x86)\windows live\messenger\msnmsgr.exe |
{983EDF57-EAD1-458A-8088-8C89C935F3FE} -> dir=in | action=allow | name=cyberlink media service | app=c:\program files (x86)\hewlett-packard\media\dvd\kernel\clml\clmlsvc.exe |
{AC65BCDA-1D41-4B24-ACAE-843D1DBA71AB} -> profile=private | protocol=17 | dir=in | action=allow | name=google talk plugin | app=c:\users\stephanie\appdata\local\google\google talk plugin\googletalkplugin.dll |
{AE170123-B28F-4BF0-AFFD-295D046F0DA8} -> profile=private | protocol=6 | dir=in | action=allow | name=microsoft office groove | app=c:\program files (x86)\microsoft office\office12\groove.exe |
{BA0219BB-CC78-4666-B89F-6DDF3CEEBAEA} -> dir=in | action=allow | name=hp touchsmart music | app=c:\program files (x86)\hewlett-packard\media\dvd\hptouchsmartmusic.exe |
{C41AD297-B324-474E-9E83-1F9945E78E3E} -> profile=public | protocol=17 | dir=in | action=allow | name=microsoft office onenote | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
{C5E8FEC8-07D7-42E4-935E-A045190E68D2} -> profile=private | protocol=6 | dir=in | action=allow | name=google talk plugin | app=c:\users\stephanie\appdata\local\google\google talk plugin\googletalkplugin.exe |
{C6A42D09-22C6-4873-9D4F-65C11A6E765F} -> profile=private | protocol=17 | dir=in | action=allow | name=bonjour service | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
{D0C143BF-8AA7-4B9D-A010-C65DA5D30EC2} -> profile=private | protocol=6 | dir=in | action=allow | name=bonjour service | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
{D100FBDC-756F-4C5D-A438-93E90595523C} -> profile=private | protocol=17 | dir=in | action=allow | name=microsoft office groove | app=c:\program files (x86)\microsoft office\office12\groove.exe |
{D90ECFCA-B27E-4FF1-9A0C-8E2F23C024FE} -> profile=private | protocol=6 | dir=in | action=allow | name=itunes | app=c:\program files (x86)\itunes\itunes.exe |
{E35B4941-7F76-4125-A82D-EBC183C94FA5} -> profile=private | dir=in | action=allow | name=avgupd.exe | app=c:\program files (x86)\avg\avg8\avgupd.exe |
{E787A46D-9C9D-4E35-8381-6DE7B599BC87} -> dir=in | action=allow | name=hp mediasmart dvd | app=c:\program files (x86)\hewlett-packard\media\dvd\hpdvdsmart.exe |
{EBE4DD6E-2AAC-499D-9902-7AD8820D02F4} -> dir=in | action=allow | name=windows live call | app=c:\program files (x86)\windows live\messenger\wlcsdk.exe |
{FF6C964B-56E1-43C8-A46B-4E03CE14817E} -> dir=in | action=allow | name=hp touchsmart media resident program | app=c:\program files (x86)\hewlett-packard\touchsmart\media\tsmagent.exe |
TCP Query User{45417DC6-7EFD-45BE-A516-78A54C872C2D}C:\program files (x86)\java\jre6\bin\java.exe -> profile=private | protocol=6 | dir=in | action=allow | name=java(tm) platform se binary | app=c:\program files (x86)\java\jre6\bin\java.exe |
TCP Query User{7E0EFB4E-7ADA-4235-A246-EB05903D5FA1}C:\program files (x86)\aim6\aim6.exe -> profile=private | protocol=6 | dir=in | action=allow | name=aim | app=c:\program files (x86)\aim6\aim6.exe |
TCP Query User{7FB3BCD4-0D26-407D-8A53-CD89E7E256B7}C:\program files (x86)\bittorrent\bittorrent.exe -> profile=public | protocol=6 | dir=in | action=allow | name=bittorrent | app=c:\program files (x86)\bittorrent\bittorrent.exe |
TCP Query User{9457EAEA-C797-4D2E-A724-F3D74AE60ABA}C:\program files (x86)\internet explorer\iexplore.exe -> profile=private | protocol=6 | dir=in | action=allow | name=internet explorer | app=c:\program files (x86)\internet explorer\iexplore.exe |
TCP Query User{A4064BF3-CEA7-4B45-8976-9F09626C9DF7}C:\program files (x86)\mozilla firefox\firefox.exe -> profile=private | protocol=6 | dir=in | action=allow | name=firefox | app=c:\program files (x86)\mozilla firefox\firefox.exe |
UDP Query User{4F37351A-0692-4AB5-9F6A-692AE64DB899}C:\program files (x86)\aim6\aim6.exe -> profile=private | protocol=17 | dir=in | action=allow | name=aim | app=c:\program files (x86)\aim6\aim6.exe |
UDP Query User{83CDB6F1-0813-4D1F-9506-4B6B58B45E8F}C:\program files (x86)\bittorrent\bittorrent.exe -> profile=public | protocol=17 | dir=in | action=allow | name=bittorrent | app=c:\program files (x86)\bittorrent\bittorrent.exe |
UDP Query User{A635F32F-716E-459C-BD3D-17EC26EE89F3}C:\program files (x86)\internet explorer\iexplore.exe -> profile=private | protocol=17 | dir=in | action=allow | name=internet explorer | app=c:\program files (x86)\internet explorer\iexplore.exe |
UDP Query User{A8F6E8A7-543B-40DB-A3FC-20C6A4A56C73}C:\program files (x86)\java\jre6\bin\java.exe -> profile=private | protocol=17 | dir=in | action=allow | name=java(tm) platform se binary | app=c:\program files (x86)\java\jre6\bin\java.exe |
UDP Query User{E3AFCA6A-E683-450B-93A2-1441AFE7FB19}C:\program files (x86)\mozilla firefox\firefox.exe -> profile=private | protocol=17 | dir=in | action=allow | name=firefox | app=c:\program files (x86)\mozilla firefox\firefox.exe |
< SafeBoot AlternateShell [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot ->
< CDROM Autorun Setting [HKEY_LOCAL_MACHINE]> -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdrom ->
"AutoRun" -> 1 ->
"DisplayName" -> CD-ROM Driver ->
dychang
Posts Posts : 64
Re: Trojan Problem
Post by dychang on Fri Apr 23, 2010 2:22 am
"ImagePath" -> C:\Windows\SysNative\DRIVERS\cdrom.sys [system32\DRIVERS\cdrom.sys] -> [2009/04/11 01:34:39 | 000,079,872 | ---- | M | MD5 = C025AA69BE3D0D25C7A2E746EF6F94FC] (Microsoft Corporation)
< MountPoints2 [HKEY_CURRENT_USER] > -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2 ->
\{9ae7409b-6795-11de-8296-00235a9e0270}
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{9ae7409b-6795-11de-8296-00235a9e0270}\shell\AutoRun\command
\{9ae7409b-6795-11de-8296-00235a9e0270}\shell\AutoRun\command\\"" -> F:\WD_Windows_Tools\Setup.exe [F:\WD_Windows_Tools\Setup.exe] -> File not found
\{b9d0a090-229b-11df-9500-00235a9e0270}
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command
\{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command\\"" -> F:\setup.exe [F:\setup.exe] -> File not found
\{ff292315-702b-11de-9ad9-00235a9e0270}
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command
\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command\\"" -> G:\slacker.synclauncher.exe [G:\slacker.synclauncher.exe] -> File not found
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command
\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command\\"" -> G:\slacker.synclauncher.exe [G:\slacker.synclauncher.exe] -> File not found
< Registry Shell Spawning - Select to Repair > -> HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\shell\[command]\command ->
64bit-comfile [open] -> "%1" %* -> File not found
64bit-exefile [open] -> "%1" %* -> File not found
< File Associations - Select to Repair > -> HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\ ->
.com [@ = comfile] -> "%1" %* ->
.exe [@ = exefile] -> "%1" %* ->
[Registry - Additional Scans - Safe List]
< Drivers32 [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32 ->
"msacm.l3acm" -> C:\Windows\SysWOW64\l3codeca.acm [C:\Windows\SysWOW64\l3codeca.acm] -> [2008/01/20 22:51:46 | 000,062,464 | ---- | M | MD5 = 733A9243A14753652F9FA9C8BBC44F98] (Fraunhofer Institut Integrierte Schaltungen IIS)
"msacm.l3codecp" -> C:\Windows\SysWow64\l3codecp.acm [l3codecp.acm] -> [2008/01/20 22:51:46 | 000,220,672 | ---- | M | MD5 = 95A6DAE184FC86AB9215374B7C6390F9] (Fraunhofer Institut Integrierte Schaltungen IIS)
"msacm.siren" -> C:\Windows\SysWow64\sirenacm.dll [sirenacm.dll] -> [2009/07/26 16:44:56 | 000,048,448 | ---- | M | MD5 = CF1C4265A73D50A1CE97FD308CE1AFC9] (Microsoft Corporation)
"vidc.cvid" -> C:\Windows\SysWow64\iccvid.dll [iccvid.dll] -> [2006/11/02 11:02:31 | 000,081,920 | ---- | M | MD5 = 81ECD1670CD56677FC124B9479DBE5F0] (Radius Inc.)
"vidc.XVID" -> C:\Windows\SysWow64\xvidvfw.dll [xvidvfw.dll] -> [2006/02/28 21:17:30 | 000,159,744 | ---- | M | MD5 = 1F4E1A1E9F8C7C0EE4CFA7743527ED96] ()
< Ext (PreApproved) - [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\ ->
{02BCC737-B171-4746-94C9-0D8A0B2C0089} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\IEAWSDC.DLL [Microsoft Office Template and Media Control] -> [2008/10/25 06:18:50 | 000,172,880 | ---- | M | MD5 = E6BC6BA065287D7B6C22D9231E80AF3B] ()
{02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} [HKLM] -> C:\Program Files (x86)\QuickTime\QTPlugin.ocx [QuickTime Object] -> [2010/03/17 23:28:24 | 000,800,048 | ---- | M | MD5 = AD99EC8908185A02307CF071EF7BD9CF] (Apple Inc.)
{03D19749-C5FA-4CCC-99AB-00AB2AF45ACD} [HKLM] -> C:\Windows\Downloaded Program Files\CONFLICT.1\RACtrl.dll [File Transfer ActiveX Client] -> [2009/09/24 11:06:36 | 004,023,624 | ---- | M | MD5 = F386CDC88689C67B30BD313EA5A4DE1D] ()
{03F998B2-0E00-11D3-A498-00104B6EB52E} [HKLM] -> C:\Program Files (x86)\Viewpoint\Viewpoint Media Player\AxMetaStream.dll [MetaStreamCtl Class] -> [2008/02/06 20:58:48 | 000,262,214 | ---- | M | MD5 = B683D285F81C01F2A0EED59E79C35C77] (Viewpoint Corporation)
{07B06095-5687-4D13-9E32-12B4259C9813} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\STSUPLD.DLL [STSUpld UploadCtl Class] -> [2006/10/26 23:59:30 | 000,227,128 | ---- | M | MD5 = 40A2F9DBE7434EB9B866D4B67FCA6C5B] (Microsoft Corporation)
{0D012ABD-CEED-11D2-9C76-00105AA73033} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveDocumentShareTool.dll [Groove DocumentShareView] -> [2009/02/14 06:03:38 | 003,070,832 | ---- | M | MD5 = ECA43292F8C283A96756A95DAA2BF93B] (Microsoft Corporation)
{166B1BCA-3F9C-11CF-8075-444553540000} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{19916E01-B44E-4E31-94A4-4696DF46157B} [HKLM] -> C:\Windows\SysWOW64\icardie.dll [InformationCardSigninHelper Class] -> [2009/03/08 07:31:51 | 000,059,904 | ---- | M | MD5 = 17A6B9EFC1D37368379F4E77EC3F2761] (Microsoft Corporation)
{1B00725B-C455-4DE6-BFB6-AD540AD427CD} [HKLM] -> C:\Program Files (x86)\Viewpoint\Viewpoint Media Player\AxMetaStream.dll [MetaStreamCtl Class] -> [2008/02/06 20:58:48 | 000,262,214 | ---- | M | MD5 = B683D285F81C01F2A0EED59E79C35C77] (Viewpoint Corporation)
{233C1507-6A77-46A4-9443-F871F945D258} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{3050F819-98B5-11CF-BB82-00AA00BDCE0B} [HKLM] -> C:\Windows\SysWOW64\mshtmled.dll [HtmlDlgSafeHelper Class] -> [2009/03/08 07:31:24 | 000,066,560 | ---- | M | MD5 = 7C9AAF547A0AF93C3F1BB7DC3AED4ECC] (Microsoft Corporation)
{333C7BC4-460F-11D0-BC04-0080C7055A83} [HKLM] -> C:\Windows\SysWOW64\tdc.ocx [Tabular Data Control] -> [2009/03/08 07:30:54 | 000,066,560 | ---- | M | MD5 = 9BAA9D6879028C32FCE8808C4C7E86BE] (Microsoft Corporation)
{3FD37ABB-F90A-4DE5-AA38-179629E64C2F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSSUPP.DLL [SharePoint Spreadsheet Launcher] -> [2009/03/06 04:23:08 | 000,140,168 | ---- | M | MD5 = 29598106730A792694FA91E1184E5501] (Microsoft Corporation)
{4063BE15-3B08-470D-A0D5-B37161CFFD69} [HKLM] -> C:\Program Files (x86)\QuickTime\QTPlugin.ocx [QuickTime Object] -> [2010/03/17 23:28:24 | 000,800,048 | ---- | M | MD5 = AD99EC8908185A02307CF071EF7BD9CF] (Apple Inc.)
{4849E17D-2DEF-40D7-98DE-DB555B4A589C} [HKLM] -> C:\Windows\Downloaded Program Files\CONFLICT.1\RACtrl.dll [Telnet ActiveX Client] -> [2009/09/24 11:06:36 | 004,023,624 | ---- | M | MD5 = F386CDC88689C67B30BD313EA5A4DE1D] ()
{4F07F79F-087F-42cf-8B36-7A88D06088E9} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msgsc.14.0.8089.0726.dll [Reg Error: Value error.] -> [2009/07/26 16:44:56 | 000,221,520 | ---- | M | MD5 = 7EE6C2556E674AB1A6EBF89C1800302F] (Microsoft Corporation)
{556EEC63-31E2-47C3-BF29-DFF799D2FE04} [HKLM] -> C:\Windows\Downloaded Program Files\CONFLICT.1\RACtrl.dll [Remote Access ActiveX Client] -> [2009/09/24 11:06:36 | 004,023,624 | ---- | M | MD5 = F386CDC88689C67B30BD313EA5A4DE1D] ()
{56A58823-AE99-11D5-B90B-0050DACD1F75} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveCommonComponents.dll [Groove Data List Display] -> [2009/02/14 06:03:28 | 002,687,336 | ---- | M | MD5 = 9E1E3647CDE6AF66D3CD634624A99365] (Microsoft Corporation)
{5852F5ED-8BF4-11D4-A245-0080C6F74284} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\wsdetect.dll [isInstalled Class] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = 6C51E76334351F609DD152611709AE2A] (Sun Microsystems, Inc.)
{62B4D041-4667-40B6-BB50-4BC0A5043A73} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSSUPP.DLL [SharePoint Export Database Launcher] -> [2009/03/06 04:23:08 | 000,140,168 | ---- | M | MD5 = 29598106730A792694FA91E1184E5501] (Microsoft Corporation)
{65BCBEE4-7728-41A0-97BE-14E1CAE36AAE} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\STSLIST.DLL [Microsoft Office List 12.0] -> [2009/03/06 03:01:06 | 002,335,648 | ---- | M | MD5 = 573689497BF82AD0FEAF4581AB6E4042] (Microsoft Corporation)
{67DABFBF-D0AB-41FA-9C46-CC0F21721616} [HKLM] -> C:\Program Files (x86)\DivX\DivX Plus Web Player\npdivx32.dll [DivXBrowserPlugin Object] -> [2009/11/13 20:47:26 | 002,471,224 | ---- | M | MD5 = EDBA797E78300759A09AF77C77F5D9E7] (DivX,Inc.)
{6BF52A52-394A-11d3-B153-00C04F79FAA6} [HKLM] -> C:\Windows\SysWOW64\wmp.dll [Windows Media Player] -> [2009/09/10 12:49:49 | 010,626,560 | ---- | M | MD5 = 2DF7EC6673A1CB823A73C6AFFD54CF66] (Microsoft Corporation)
{760C4B83-E211-11D2-BF3E-00805FBE84A6} [HKLM] -> C:\Windows\SysWOW64\msnetobj.dll [Windows Media Services DRM Storage object] -> [2009/04/11 02:28:21 | 000,179,712 | ---- | M | MD5 = 584C4A26F210B823BBF73BB985CAA2CE] (Microsoft Corporation)
{761497BB-D6F0-462C-B6EB-D4DAF1D92D43} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{8075631E-5146-11D5-A672-00B0D022E945} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\INLAUNCH.DLL [SharepointOpenXMLDocuments] -> [2009/03/06 04:26:06 | 000,065,400 | ---- | M | MD5 = E34C3EAC482B0FE3913E23FC2E85424C] (Microsoft Corporation)
{88d969c0-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [XML DOM Document 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{88d969c1-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [Free Threaded XML DOM Document 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{88d969c2-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [XML Schema Cache 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{88d969c3-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [XSL Template 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{88d969c4-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [XML Data Source Object 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{88d969c5-f192-11d4-a65f-0040963251e5} [HKLM] -> c:\Windows\SysWOW64\msxml4.dll [XML HTTP 4.0] -> [2009/07/21 01:05:40 | 001,348,432 | ---- | M | MD5 = 09DEF3ABB6A196749299359AC5578DD8] (Microsoft Corporation)
{8AD9C840-044E-11D1-B3E9-00805F499D93} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_18] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{8E4062D9-FE1B-4b9e-AA16-5E8EEF68F48E} [HKLM] -> C:\Windows\SysWOW64\RegCtrl.dll [Registration Control] -> [2008/01/20 22:49:42 | 000,040,960 | ---- | M | MD5 = 355B623E5E870E2166AAF997DBAE9C89] (Microsoft Corporation)
{9203C2CB-1DC1-482D-967E-597AFF270F0D} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSSUPP.DLL [SharePoint OpenDocuments Class] -> [2009/03/06 04:23:08 | 000,140,168 | ---- | M | MD5 = 29598106730A792694FA91E1184E5501] (Microsoft Corporation)
{9F9C4924-C3F3-4459-A396-9E9E0D8B83D1} [HKLM] -> Reg Error: Key error. [SharePoint OpenDocuments Class] -> File not found
{A9FC132B-096D-460B-B7D5-1DB0FAE0C062} [HKLM] -> C:\Windows\SysWOW64\msnetobj.dll [RMGetLicense Class] -> [2009/04/11 02:28:21 | 000,179,712 | ---- | M | MD5 = 584C4A26F210B823BBF73BB985CAA2CE] (Microsoft Corporation)
{BAEB32D0-732D-11d2-8BF4-0060B0A4A9EA} [HKLM] -> C:\Program Files (x86)\AIM6\services\imApp\ver6_9_15_1\isAim.dll [aimlocator Class] -> [2009/05/19 01:18:18 | 000,062,256 | ---- | M | MD5 = 55C0A183F02DF1A0AD491DE93FDF1DEB] (AOL LLC)
{BDEADE3E-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSClientEventSubscription Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE3F-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSClientMiscApis Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE40-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSClientCommentThread Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE42-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSClientComment Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE43-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSBrowserUI Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE98-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWS Post Data] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADE9E-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [SharePoint Spreadsheet Launcher] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEB3-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [Web Discussions] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEB4-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [Web Discussions] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEB5-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [Web Discussions] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEB7-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSDiscussionServers Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEB8-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSClientCollaboration Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEDA-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OSE.Discussion] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEDB-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OSE.Discussions] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEDC-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OSE.DiscussionServer] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEDD-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OSE.DiscussionServers] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEDE-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OSE Global Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEE0-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSCLT.DLL [OWSDiscussionBar Class] -> [2008/11/21 02:34:20 | 000,798,584 | ---- | M | MD5 = 7A61912304B78F99CB1E6E311FEFF253] (Microsoft Corporation)
{BDEADEF2-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> Reg Error: Key error. [SharePoint OpenDocuments Class] -> File not found
{BDEADEF4-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> Reg Error: Key error. [SharePoint Stssync Handler] -> File not found
{BDEADEF5-C265-11D0-BCED-00A0C90AB50F} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\OWSSUPP.DLL [SharePoint Stssync Handler] -> [2009/03/06 04:23:08 | 000,140,168 | ---- | M | MD5 = 29598106730A792694FA91E1184E5501] (Microsoft Corporation)
{C2828995-4A83-4100-A212-3024BA117356} [HKLM] -> C:\Program Files (x86)\Windows Live SkyDrive\Microsoft.Live.Folders.RichUpload.3.dll [Windows Live Upload Tool] -> [2008/10/29 11:46:56 | 000,245,112 | ---- | M | MD5 = DA204A2BAB5780A0DF37EB5BE58FCA57] (Microsoft Corporation)
{C9712B19-838B-45A5-ABF2-9A315DDDED50} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\AUTHZAX.DLL [Microsoft Office 12 Authorization Control] -> [2008/10/25 06:18:46 | 000,054,152 | ---- | M | MD5 = 96ED72080E20A360AB0D2597D1AC4EF6] (Microsoft Corporation)
{CA8A9780-280D-11CF-A24D-444553540000} [HKLM] -> C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroPDF.dll [Adobe PDF Reader] -> [2010/04/03 19:22:06 | 000,660,912 | ---- | M | MD5 = 5EB22D662FA979B2F83BF0E71DC58C78] (Adobe Systems, Inc.)
{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_07] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_07] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_07] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_18] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_18] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC} [HKLM] -> C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll [Java Plug-in 1.6.0_18] -> [2009/12/17 18:14:04 | 000,108,320 | ---- | M | MD5 = AD9E4059789D2389B746C58421194722] ()
{CAFEEFAC-DEC7-0000-0000-ABCDEFFEDCBA} [HKLM] -> C:\Windows\SysWOW64\deploytk.dll [Deployment Toolkit] -> [2009/12/17 18:14:00 | 000,411,368 | ---- | M | MD5 = E0BBCEC12A1DE6E25C612AD205B719B4] (Sun Microsystems, Inc.)
{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBC} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{CB927D12-4FF7-4A9E-A169-56E4B8A75598} [HKLM] -> C:\Program Files (x86)\QuickTime\QTPlugin.ocx [Behavior Object] -> [2010/03/17 23:28:24 | 000,800,048 | ---- | M | MD5 = AD99EC8908185A02307CF071EF7BD9CF] (Apple Inc.)
{CDEC13B2-0B3C-400E-B909-E27EE89C6799} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\STSUPLD.DLL [STSUpld CopyCtl Class] -> [2006/10/26 23:59:30 | 000,227,128 | ---- | M | MD5 = 40A2F9DBE7434EB9B866D4B67FCA6C5B] (Microsoft Corporation)
{CFCDAA03-8BE4-11cf-B84B-0020AFBBCCFA} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{D2517915-48CE-4286-970F-921E881B8C5C} [HKLM] -> C:\Program Files (x86)\Common Files\microsoft shared\Windows Live\WindowsLiveLogin.dll [Windows Live Sign-in Control] -> [2009/01/22 15:41:30 | 000,408,448 | ---- | M | MD5 = B7899C3E21B299D7A3C0DA96CAE340BD] (Microsoft Corporation)
{D27CDB6E-AE6D-11cf-96B8-444553540000} [HKLM] -> C:\Windows\SysWOW64\Macromed\Flash\Flash10a.ocx [Shockwave Flash Object] -> [2008/09/10 22:10:10 | 003,787,168 | R--- | M | MD5 = C0A6D238F9E2F89571F7D026DDD305DB] (Adobe Systems, Inc.)
{D719897A-B07A-4C0C-AEA9-9B663A28DFCB} [HKLM] -> C:\Program Files (x86)\iTunes\ITDetector.ocx [iTunesDetector Class] -> [2010/03/26 01:09:52 | 000,111,912 | ---- | M | MD5 = 396E2789307D32DDE30D932891AE5A63] (Apple Inc.)
{DFEAF541-F3E1-4c24-ACAC-99C30715084A} [HKLM] -> c:\Program Files (x86)\Microsoft Silverlight\3.0.50106.0\npctrl.dll [Microsoft Silverlight] -> [2010/01/06 01:33:56 | 000,876,872 | ---- | M | MD5 = 98C15480C8AD4FEF5CF62769FAE65C92] ( Microsoft Corporation)
{E01D1C6A-4F40-11D3-8958-00105A272DCF} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveTextTools.dll [Groove Text View] -> [2009/02/14 06:03:54 | 001,161,568 | ---- | M | MD5 = 53BABBB23E0A507C79D2FB488EABBBD9] (Microsoft Corporation)
{E13AAC70-70AE-4988-808C-B267F2C20E79} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe [Reg Error: Value error.] -> [2009/07/26 16:44:34 | 003,883,856 | ---- | M | MD5 = D39DA5B7139B4B5147B3C6A94978B5AA] (Microsoft Corporation)
{E1771B7F-98BE-407F-BA67-AA16ADA5D0C5} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msgsc.14.0.8089.0726.dll [Reg Error: Value error.] -> [2009/07/26 16:44:56 | 000,221,520 | ---- | M | MD5 = 7EE6C2556E674AB1A6EBF89C1800302F] (Microsoft Corporation)
{E543A17A-F212-49C0-B63D-BF09B460250E} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\oisctrl.dll [OISClientLauncher Class] -> [2009/03/06 04:23:50 | 000,022,432 | ---- | M | MD5 = EA9E5B8D043D01851977B6D4C4C8F2A8] (Microsoft Corporation)
{E7339A62-0E31-4A5E-BA3D-F2FEDFBF8BE5} [HKLM] -> C:\Program Files (x86)\Common Files\microsoft shared\Portal\PortalConnectCore.dll [PersonalSite Class] -> [2008/10/26 05:42:16 | 000,482,656 | ---- | M | MD5 = 2569192656E36C43D807DC37D5335919] ()
{EE09B103-97E0-11CF-978F-00A02463E06F} [HKLM] -> C:\Windows\SysWOW64\scrrun.dll [scripting.Dictionary] -> [2009/04/11 02:28:24 | 000,172,032 | ---- | M | MD5 = 3DB1530CDD7AEF2BCFA6FB77D097CDDA] (Microsoft Corporation)
{F06608C7-1874-4EEA-B3B2-DF99EBB144B8} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msgsc.14.0.8089.0726.dll [Reg Error: Value error.] -> [2009/07/26 16:44:56 | 000,221,520 | ---- | M | MD5 = 7EE6C2556E674AB1A6EBF89C1800302F] (Microsoft Corporation)
{FA5369ED-D19A-434C-8F59-EE90D690D36C} [HKLM] -> C:\Windows\Downloaded Program Files\CONFLICT.1\RACtrl.dll [Chat Activex Control] -> [2009/09/24 11:06:36 | 004,023,624 | ---- | M | MD5 = F386CDC88689C67B30BD313EA5A4DE1D] ()
{FD0B6769-6490-4A91-AA0A-B5AE0DC75AC9} [HKLM] -> C:\Windows\Downloaded Program Files\CONFLICT.1\RACtrl.dll [Performance Viewer Activex Control] -> [2009/09/24 11:06:36 | 004,023,624 | ---- | M | MD5 = F386CDC88689C67B30BD313EA5A4DE1D] ()
3E4D4F1C-2AEE-11D1-9D3D-00C04FC30DF6 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
435899C9-44AB-11D1-AF00-080036234103 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
4F664F91-FF01-11D0-8AED-00C04FD7B597 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
65303443-AD66-11D1-9D65-00C04FC30DF6 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
92337A8C-E11D-11D0-BE48-00C04FC30DF6 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
C3701884-B39B-11D1-9D68-00C04FC30DF6 [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
< Ext (Settings) - [HKEY_CURRENT_USER] > -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\ ->
{1E61ED7C-7CB8-49D6-B9E9-AB4C880C8414} [HKLM] -> c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll [Microsoft Live Search Toolbar] -> [2008/08/29 00:09:08 | 000,086,032 | ---- | M | MD5 = C12121B120411F2C9A457AF8339AB6C6] (Microsoft Corp.)
{22BF413B-C6D2-4D91-82A9-A0F997BA588C} [HKLM] -> C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll [Skype add-on (mastermind)] -> [2009/06/02 11:56:14 | 001,082,880 | ---- | M | MD5 = CE16731D20BC8AFD532AC7A526D809A9] (Skype Technologies S.A.)
{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{6D53EC84-6AAE-4787-AEEE-F4628F01010C} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{A3BC75A2-1F87-4686-AA43-5347D756017C} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{CCC7A320-B3CA-4199-B1A6-9F516DD69829} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{D27CDB6E-AE6D-11CF-96B8-444553540000} [HKLM] -> C:\Windows\SysWOW64\Macromed\Flash\Flash10a.ocx [Shockwave Flash Object] -> [2008/09/10 22:10:10 | 003,787,168 | R--- | M | MD5 = C0A6D238F9E2F89571F7D026DDD305DB] (Adobe Systems, Inc.)
{D2CE3E00-F94A-4740-988E-03DC2F38C34F} [HKLM] -> c:\Program Files (x86)\MSN\Toolbar\3.0.0541.0\msneshellx.dll [Microsoft Live Search Toolbar Helper] -> [2008/08/29 00:09:08 | 000,086,032 | ---- | M | MD5 = C12121B120411F2C9A457AF8339AB6C6] (Microsoft Corp.)
< Ext (Stats) - [HKEY_CURRENT_USER] > -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\ ->
{08B0E5C0-4FCB-11CF-AAA5-00401C608501} [HKLM] -> Reg Error: Key error. [Reg Error: Value error.] -> File not found
{2670000A-7350-4F3C-8081-5663EE0C6C49} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{39125640-8D80-11DC-A2FE-C5C455D89593} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{53DBCD97-3FDF-4B60-975B-2596B57482EF} [HKLM] -> C:\Program Files (x86)\Common Files\Research In Motion\BBWebSLLauncher\BBWebSLLauncher.dll [WebSLLauncher Class] -> [2010/03/10 18:57:32 | 000,124,248 | ---- | M | MD5 = C514D0F7D692B11CB1E8D5DB50EC29F2] (Research In Motion Limited)
{5C255C8A-E604-49B4-9D64-90988571CECB} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{6BF52A52-394A-11D3-B153-00C04F79FAA6} [HKLM] -> C:\Windows\SysWOW64\wmp.dll [Windows Media Player] -> [2009/09/10 12:49:49 | 010,626,560 | ---- | M | MD5 = 2DF7EC6673A1CB823A73C6AFFD54CF66] (Microsoft Corporation)
{77BF5300-1474-4EC7-9980-D32B190E9B07} [HKLM] -> C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll [Skype add-on (button)] -> [2009/06/02 11:56:14 | 001,082,880 | ---- | M | MD5 = CE16731D20BC8AFD532AC7A526D809A9] (Skype Technologies S.A.)
{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{92780B25-18CC-41C8-B9BE-3C9C571A8263} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{DFEAF541-F3E1-4C24-ACAC-99C30715084A} [HKLM] -> c:\Program Files (x86)\Microsoft Silverlight\3.0.50106.0\npctrl.dll [Microsoft Silverlight] -> [2010/01/06 01:33:56 | 000,876,872 | ---- | M | MD5 = 98C15480C8AD4FEF5CF62769FAE65C92] ( Microsoft Corporation)
{e3e02f12-2adb-478c-8742-5f0819f9f0f4} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{e473a65c-8087-49a3-affd-c5bc4a10669b} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{fc345d4c-b8f4-4674-bff7-3c37d2e535ee} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{fd6484ed-ebe3-4c3d-938a-8238003b41b7} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
{FF4E22ED-17D0-4D43-AD6F-E53D11FA3C61} [HKLM] -> Reg Error: Key error. [Reg Error: Key error.] -> File not found
.bat [@ = batfile] -> "%1" %* ->
.cmd [@ = cmdfile] -> "%1" %* ->
.cpl [@ = cplfile] -> C:\Windows\SysWow64\control.exe -> [2006/11/02 05:44:59 | 000,211,968 | ---- | M | MD5 = 027E5E14C9CFF810377701BDEAD8210F] (Microsoft Corporation)
.pif [@ = piffile] -> "%1" %* ->
.scr [@ = scrfile] -> "%1" /S ->
< File Associations - Select to Repair > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Classes\\ ->
.html [@ = FirefoxHTML] -> C:\Program Files (x86)\Mozilla Firefox\firefox.exe -> [2010/04/21 00:31:58 | 000,910,296 | ---- | M | MD5 = 49958506B773E40D31832E3EEDA522E7] (Mozilla Corporation)
< HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost > -> ->
*netsvcs* -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost\\netsvcs ->
Ias -> C:\Windows\SysWOW64\ias -> [2008/01/20 23:08:35 | 000,000,000 | ---D | M]
Wmi -> C:\Windows\SysWOW64\wmi.dll -> [2006/11/02 05:44:15 | 000,005,120 | ---- | M | MD5 = BFE74095684093F14D24801C8C0D16E3] (Microsoft Corporation)
< Protocol Handlers [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\ ->
grooveLocalGWS:{88FED34C-F0CA-4636-A375-3CB6248B04CD} [HKLM] -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll[Local Groove Web Services Protocol] -> [2009/02/12 15:19:38 | 000,178,040 | ---- | M | MD5 = 68747446F9D982938DB6B110F2908271] (Microsoft Corporation)
livecall:{828030A1-22C1-4009-854F-8E305202313F} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msgrapp.14.0.8089.0726.dll[Reg Error: Value error.] -> [2009/07/26 16:44:54 | 000,061,264 | ---- | M | MD5 = 61B0C981F7C10B8861809ADC1B31E8E5] (Microsoft Corporation)
msnim:{828030A1-22C1-4009-854F-8E305202313F} [HKLM] -> C:\Program Files (x86)\Windows Live\Messenger\msgrapp.14.0.8089.0726.dll[Reg Error: Value error.] -> [2009/07/26 16:44:54 | 000,061,264 | ---- | M | MD5 = 61B0C981F7C10B8861809ADC1B31E8E5] (Microsoft Corporation)
skype4com:{FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} [HKLM] -> C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll[IEProtocolHandler Class] -> [2009/06/02 11:56:14 | 001,942,824 | R--- | M | MD5 = BE8FC3EF67D58F8D711EA94F8C17D8F7] (Skype Technologies)
< SafeBoot-Minimal Settings > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ ->
{36FC9E60-C465-11CF-8056-444553540000} -> Universal Serial Bus controllers
{4D36E965-E325-11CE-BFC1-08002BE10318} -> CD-ROM Drive
{4D36E967-E325-11CE-BFC1-08002BE10318} -> DiskDrive
{4D36E969-E325-11CE-BFC1-08002BE10318} -> Standard floppy disk controller
{4D36E96A-E325-11CE-BFC1-08002BE10318} -> Hdc
{4D36E96B-E325-11CE-BFC1-08002BE10318} -> Keyboard
{4D36E96F-E325-11CE-BFC1-08002BE10318} -> Mouse
{4D36E977-E325-11CE-BFC1-08002BE10318} -> PCMCIA Adapters
{4D36E97B-E325-11CE-BFC1-08002BE10318} -> SCSIAdapter
{4D36E97D-E325-11CE-BFC1-08002BE10318} -> System
{4D36E980-E325-11CE-BFC1-08002BE10318} -> Floppy disk drive
{533C5B84-EC70-11D2-9505-00C04F79DEAF} -> Volume shadow copy
{6BDD1FC1-810F-11D0-BEC7-08002BE2092F} -> IEEE 1394 Bus host controllers
{71A27CDD-812A-11D0-BEC7-08002BE2092F} -> Volume
{745A17A0-74D3-11D0-B6FE-00A0C90F57DA} -> Human Interface Devices
{D48179BE-EC20-11D1-B6B8-00C04FA372A7} -> SBP2 IEEE 1394 Devices
{D94EE5D8-D189-4994-83D2-F68D7D41B0E6} -> SecurityDevices
AppInfo -> 64bit -> File not found
AppMgmt -> Service
Base -> Driver Group
Boot Bus Extender -> Driver Group
Boot file system -> Driver Group
DcomLaunch -> 64bit -> File not found
EventLog -> 64bit -> File not found
File system -> Driver Group
Filter -> Driver Group
HelpSvc -> Service
NTDS -> 64bit -> File not found
PCI Configuration -> Driver Group
PEVSystemStart -> Service
PlugPlay -> 64bit -> File not found
PNP Filter -> Driver Group
Primary disk -> Driver Group
procexp90.Sys -> Driver
ProfSvc -> 64bit -> File not found
RpcSs -> 64bit -> File not found
sacsvr -> Service
SCSI Class -> Driver Group
sermouse.sys -> 64bit -> File not found
SWPRV -> 64bit -> File not found
System Bus Extender -> Driver Group
TabletInputService -> 64bit -> File not found
TBS -> 64bit -> File not found
VDS -> C:\Windows\SysWOW64\wbem\vds.mof -> [2006/11/02 02:35:15 | 000,060,994 | ---- | M | MD5 = 21A96F0C1B123F2463C6D624F125EAC9] ()
vga.sys -> 64bit -> File not found
vgasave.sys -> 64bit -> File not found
volmgr.sys -> 64bit -> File not found
volmgrx.sys -> 64bit -> File not found
Wdf01000.sys -> 64bit -> File not found
WinDefend -> 64bit -> File not found
WinMgmt -> 64bit -> File not found
< SafeBoot-Network Settings > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ ->
{4D36E972-E325-11CE-BFC1-08002BE10318} -> Net
{4D36E973-E325-11CE-BFC1-08002BE10318} -> NetClient
{4D36E974-E325-11CE-BFC1-08002BE10318} -> NetService
{4D36E975-E325-11CE-BFC1-08002BE10318} -> NetTrans
{50DD5230-BA8A-11D1-BF5D-0000F805F530} -> Smart card readers
AFD -> 64bit -> File not found
AppMgmt -> Service
BFE -> 64bit -> File not found
bowser -> 64bit -> File not found
Browser -> 64bit -> File not found
dfsc -> 64bit -> File not found
DnsCache -> 64bit -> File not found
Dot3Svc -> 64bit -> File not found
Eaphost -> 64bit -> File not found
HelpSvc -> Service
IKEEXT -> 64bit -> File not found
ipnat.sys -> 64bit -> File not found
LanmanServer -> 64bit -> File not found
LanmanWorkstation -> 64bit -> File not found
LmHosts -> 64bit -> File not found
Messenger -> Service
MPSDrv -> C:\Windows\SysWOW64\wbem\mpsdrv.mof -> [2006/09/18 17:35:23 | 000,001,088 | ---- | M | MD5 = 74D68CB40BCD45AAE89A8BECC87D3868] ()
MPSSvc -> 64bit -> File not found
mrxsmb -> 64bit -> File not found
mrxsmb10 -> 64bit -> File not found
mrxsmb20 -> 64bit -> File not found
NativeWifiP -> 64bit -> File not found
NDIS -> 64bit -> File not found
NDIS Wrapper -> Driver Group
Ndisuio -> 64bit -> File not found
NetBIOS -> 64bit -> File not found
NetBIOSGroup -> Driver Group
NetBT -> 64bit -> File not found
NetDDEGroup -> Driver Group
NetMan -> 64bit -> File not found
Network -> Driver Group
NetworkProvider -> Driver Group
NlaSvc -> 64bit -> File not found
Nsi -> 64bit -> File not found
nsiproxy.sys -> 64bit -> File not found
PNP_TDI -> Driver Group
PolicyAgent -> 64bit -> File not found
rdbss -> 64bit -> File not found
rdpencdd.sys -> 64bit -> File not found
rdsessmgr -> Service
sacsvr -> Service
SharedAccess -> 64bit -> File not found
Streams Drivers -> Driver Group
Tcpip -> C:\Windows\SysWOW64\wbem\tcpip.mof -> [2006/09/18 17:36:40 | 000,003,066 | ---- | M | MD5 = EEC4A068DE477651214F6C8014ECBEC0] ()
TDI -> Driver Group
Wlansvc -> 64bit -> File not found
WudfPf -> Driver
WudfRd -> 64bit -> File not found
WudfSvc -> 64bit -> File not found
WudfUsbccidDriver -> Driver
< Security Center Settings > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center ->
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\ -> ->
\Svc\\"oobe_av" -> [1] -> File not found
\\"EnableFirewall" -> [1] -> File not found
\\"DisableNotifications" -> [0] -> File not found
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\ -> ->
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\ -> ->
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\Logging\ -> ->
< Winsock2 Catalogs [HKEY_LOCAL_MACHINE] > -> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WinSock2\Parameters\ ->
NameSpace_Catalog5\Catalog_Entries\000000000005 [Bluetooth Namespace] -> C:\Windows\SysWOW64\wshbth.dll -> [2009/04/11 02:28:26 | 000,034,304 | ---- | M | MD5 = EFA80360111D8D179E39E314A49C9ED4] (Microsoft Corporation)
NameSpace_Catalog5\Catalog_Entries\000000000008 [mdnsNSP] -> C:\Program Files (x86)\Bonjour\mdnsNSP.dll -> [2010/02/12 11:46:12 | 000,152,864 | ---- | M | MD5 = 109D9238C7DA72F9733D3DB85A31F5C4] (Apple Inc.)
< Default Protocols [HKEY_LOCAL_MACHINE\] - Select to Repair > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\ProtocolDefaults ->
ldap -> 4 = Restricted sites (Not a Default Protocol) ->
news -> 4 = Restricted sites (Not a Default Protocol) ->
nntp -> 4 = Restricted sites (Not a Default Protocol) ->
oecmd -> 4 = Restricted sites (Not a Default Protocol) ->
snews -> 4 = Restricted sites (Not a Default Protocol) ->
< Default Protocols [HKEY_USERS\S-1-5-19\] - Select to Repair > -> HKEY_USERS\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\ProtocolDefaults ->
@ivt -> @ivt protocol not assigned ->
file -> file protocol not assigned ->
ftp -> ftp protocol not assigned ->
http -> http protocol not assigned ->
https -> https protocol not assigned ->
shell -> shell protocol not assigned ->
< Default Protocols [HKEY_USERS\S-1-5-20\] - Select to Repair > -> HKEY_USERS\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\ProtocolDefaults ->
< Uninstall List [HKEY_LOCAL_MACHINE\] > -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ ->
{00203668-8170-44A0-BE44-B632FA4D780F} -> Adobe AIR
{004B0DCB-4C60-465B-8F01-44B0A4111187} -> SlingPlayer
{0054A0F6-00C9-4498-B821-B5C9578F433E} -> HP Help and Support
{01FB4998-33C4-4431-85ED-079E3EEFE75D} -> HP MediaSmart Webcam
{082702D5-5DD8-4600-BCE5-48B15174687F} -> HP Doc Viewer
{0E7DBD52-B097-4F2B-A7C7-F105B0D20FDB} -> LightScribe System Software 1.14.17.1
{154A4184-1A3D-4BF9-A5AE-4FA1660445F3} -> HP Total Care Advisor
{15BC8CD0-A65B-47D0-A2DD-90A824590FA8} -> Microsoft Works
{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79} -> CyberLink DVD Suite
{205A5182-EFC8-4C25-B61D-C164F8FF4048} -> BlackBerry Desktop Software 5.0.1
{205C6BDD-7B73-42DE-8505-9A093F35A238} -> Windows Live Upload Tool
{22B775E7-6C42-4FC5-8E10-9A5E3257BD94} -> MSVCRT
{24D753CA-6AE9-4E30-8F5F-EFC93E08BF3D} -> Skype™ 4.0
{254C37AA-6B72-4300-84F6-98A82419187E} -> ActiveCheck component for HP Active Support Library
{26604C7E-A313-4D12-867F-7C6E7820BE4C} -> JMicron JMB38X Flash Media Controller
{26A24AE4-039D-4CA4-87B4-2F83216015FF} -> Java(TM) 6 Update 18
{28BE306E-5DA6-4F9C-BDB0-DBA3C8C6FFFD} -> QuickTime
{2FDBBCEA-62DB-45F4-B6E5-0E1FB2A1F29D} -> Visual C++ 8.0 Runtime Setup Package (x64)
{3248F0A8-6813-11D6-A77B-00B0D0160070} -> Java(TM) 6 Update 7
{32A640BD-4244-4FAF-8796-EA401652E26A} -> BlackBerry Device Software v4.6.0 for the BlackBerry 9000 smartphone
{34D2AB40-150D-475D-AE32-BD23FB5EE355} -> HP Quick Launch Buttons 6.40 L1
{352310C3-E46B-42D3-8F32-54721FDD72D9} -> NetZero Preloader
{3877C901-7B90-4727-A639-B6ED2DD59D43} -> ESU for Microsoft Vista
{3B4E636E-9D65-4D67-BA61-189800823F52} -> Windows Live Communications Platform
{40BF1E83-20EB-11D8-97C5-0009C5020658} -> Power2Go
{45338B07-A236-4270-9A77-EBB4115517B5} -> Windows Live Sign-in Assistant
{45A136EC-88BF-4B95-99F5-C45D3930E1CC} -> HP MULTIPLE MODEM INSTALLER for VISTA
{47F36D92-E58E-456D-B73C-3382737E4C42} -> HP Update
{4916DFBD-403B-4707-AA64-294DC082B99F} -> HP Total Care Setup
{4A03706F-666A-4037-7777-5F2748764D10} -> Java Auto Updater
{553255F3-78FD-40F1-A6F8-6882140265FE} -> Apple Application Support
{57A5AEC1-97FC-474D-92C4-908FCC2253D4} -> HP Customer Experience Enhancements
{5EE7D259-D137-4438-9A5F-42F432EC0421} -> VC80CRTRedist - 8.0.50727.4053
{62880A3B-2F9C-4C58-8FFA-1DA280262B5E} -> BlackBerry Device Software Updater
{6423EF83-6E1D-4D22-A36F-689CD19FD4D2} -> Juno Preloader
{65DA2EC9-0642-47E9-AAE2-B5267AA14D75} -> Activation Assistant for the 2007 Microsoft Office suites
{669D4A35-146B-4314-89F1-1AC3D7B88367} -> HPAsset component for HP Active Support Library
{67626E09-5366-4480-8F1E-93FADF50CA15} -> HP MediaSmart TV
{689E0AB3-50B2-4E5A-9DCE-6DA9F5BE1314} -> BlackBerry® Media Sync
{6956856F-B6B3-4BE0-BA0B-8F495BE32033} -> Apple Software Update
{6A370610-3778-44AF-9AAC-69B2FD1A3356} -> Microsoft Live Search Toolbar
{732A3F80-008B-4350-BD58-EC5AE98707B8} -> HP Common Access Service Library
{770657D0-A123-3C07-8E44-1C83EC895118} -> Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
{77DCDCE3-2DED-62F3-8154-05E745472D07} -> Acrobat.com
{7B798B31-2F33-4DC8-BDA4-D36488E86636} -> Slingbox - Watch Your TV Anywhere
{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71} -> Windows Live Essentials
{837b34e3-7c30-493c-8f6a-2b0f04e2912c} -> Microsoft Visual C++ 2005 Redistributable
{8833FFB6-5B0C-4764-81AA-06DFEED9A476} -> Realtek 8169 8168 8101E 8102E Ethernet Driver
{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00} -> Microsoft Silverlight
{90120000-0015-0409-0000-0000000FF1CE} -> Microsoft Office Access MUI (English) 2007
{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0016-0409-0000-0000000FF1CE} -> Microsoft Office Excel MUI (English) 2007
{90120000-0016-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0018-0409-0000-0000000FF1CE} -> Microsoft Office PowerPoint MUI (English) 2007
{90120000-0018-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0019-0409-0000-0000000FF1CE} -> Microsoft Office Publisher MUI (English) 2007
{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-001A-0409-0000-0000000FF1CE} -> Microsoft Office Outlook MUI (English) 2007
{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-001B-0409-0000-0000000FF1CE} -> Microsoft Office Word MUI (English) 2007
{90120000-001B-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-001F-0409-0000-0000000FF1CE} -> Microsoft Office Proof (English) 2007
{90120000-001F-0409-0000-0000000FF1CE}_ENTERPRISE_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-001F-040C-0000-0000000FF1CE} -> Microsoft Office Proof (French) 2007
{90120000-001F-040C-0000-0000000FF1CE}_ENTERPRISE_{F580DDD5-8D37-4998-968E-EBB76BB86787} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-001F-0C0A-0000-0000000FF1CE} -> Microsoft Office Proof (Spanish) 2007
{90120000-001F-0C0A-0000-0000000FF1CE}_ENTERPRISE_{187308AB-5FA7-4F14-9AB9-D290383A10D9} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9} -> Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
{90120000-0020-0409-0000-0000000FF1CE} -> Compatibility Pack for the 2007 Office system
{90120000-002A-0000-1000-0000000FF1CE}_ENTERPRISE_{E64BA721-2310-4B55-BE5A-2925F9706192} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-002A-0000-1000-0000000FF1CE}_HOMESTUDENTR_{E64BA721-2310-4B55-BE5A-2925F9706192} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-002A-0409-1000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-002A-0409-1000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-002C-0409-0000-0000000FF1CE} -> Microsoft Office Proofing (English) 2007
{90120000-0030-0000-0000-0000000FF1CE} -> Microsoft Office Enterprise 2007
{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{3D019598-7B59-447A-80AE-815B703B84FF} -> Security Update for Microsoft Office system 2007 (972581)
{90120000-0044-0409-0000-0000000FF1CE} -> Microsoft Office InfoPath MUI (English) 2007
{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-006E-0409-0000-0000000FF1CE} -> Microsoft Office Shared MUI (English) 2007
{90120000-006E-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-00A1-0409-0000-0000000FF1CE} -> Microsoft Office OneNote MUI (English) 2007
{90120000-00A1-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-00BA-0409-0000-0000000FF1CE} -> Microsoft Office Groove MUI (English) 2007
{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0114-0409-0000-0000000FF1CE} -> Microsoft Office Groove Setup Metadata MUI (English) 2007
{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0115-0409-0000-0000000FF1CE} -> Microsoft Office Shared Setup Metadata MUI (English) 2007
{90120000-0115-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0116-0409-1000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0116-0409-1000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{90120000-0117-0409-0000-0000000FF1CE} -> Microsoft Office Access Setup Metadata MUI (English) 2007
{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E} -> Microsoft Office 2007 Service Pack 2 (SP2)
{91120000-002F-0000-0000-0000000FF1CE} -> Microsoft Office Home and Student 2007
{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B} -> Microsoft Office 2007 Service Pack 2 (SP2)
{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF} -> Security Update for Microsoft Office system 2007 (972581)
{95120000-00AF-0409-0000-0000000FF1CE} -> Microsoft Office PowerPoint Viewer 2007 (English)
{A49F249F-0C91-497F-86DF-B2585E8E76B7} -> Microsoft Visual C++ 2005 Redistributable
dychang
Posts Posts : 64
Joined Joined : 2009-01-13
Points Points : 29208
Re: Trojan Problem
{A85FD55B-891B-4314-97A5-EA96C0BD80B5} -> Windows Live Messenger
{AC76BA86-7AD7-1033-7B44-A93000000001} -> Adobe Reader 9.3.2
{AC76BA86-7AD7-2448-0000-900000000003} -> Chinese Traditional Fonts Support For Adobe Reader 9
{B2EE25B9-5B00-4ACF-94F0-92433C28C39E} -> HP MediaSmart Music/Photo/Video
{B7050CBDB2504B34BC2A9CA0A692CC29} -> DivX Plus Web Player
{B98BE95C-E76F-4246-B8E6-BEB8EE791D06} -> Roxio Media Manager
{BBF6D0CD-A081-369F-B0B8-F168594CBB6B} -> Google Talk Plugin
{C4124E95-5061-4776-8D5D-E3D931C778E1} -> Microsoft VC9 runtime libraries
{C4CF43CE-94AE-498E-9EB1-C804E05CB3CA} -> HP User Guides 0125
{C59C179C-668D-49A9-B6EA-0121CCFC1243} -> LabelPrint
{CB099890-1D5F-11D5-9EA9-0050BAE317E1} -> PowerDirector
{CE7E3BE0-2DD3-4416-A690-F9E4A99A8CFF} -> HP Active Support Library
{DCCAD079-F92C-44DA-B258-624FC6517A5A} -> HP MediaSmart DVD
{E3A5A8AB-58F6-45FF-AFCB-C9AE18C05001} -> IDT Audio
{E5E29403-3D25-40C6-892B-F9FEE2A95585} -> HP Wireless Assistant
{E8020EC7-5DD8-80C9-7237-7B2E9BDA8CC6} -> muvee Reveal
{ECEE0279-785F-4CB3-9F28-E69813234BF8} -> SPORE Creature Creator Trial Edition
{F0E12BBA-AD66-4022-A453-A1C8A0C4D570} -> Microsoft Choice Guard
{F6BD194C-4190-4D73-B1B1-C48C99921BFE} -> Windows Live Call
{FC053571-8507-44E4-8B6D-AACEAB8CA57C} -> Sansa Media Converter
Activation Assistant for the 2007 Microsoft Office suites -> Activation Assistant for the 2007 Microsoft Office suites
Adobe AIR -> Adobe AIR
Adobe Flash Player ActiveX -> Adobe Flash Player 10 ActiveX
Adobe Flash Player Plugin -> Adobe Flash Player 10 Plugin
AIM_6 -> AIM 6
Any Video Converter Professional_is1 -> Any Video Converter Professional 3.0.3
Aura Video Converter_is1 -> Aura Video Converter 1.2.1
BlackBerry_{205A5182-EFC8-4C25-B61D-C164F8FF4048} -> BlackBerry Desktop Software 5.0.1
com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 -> Acrobat.com
ENTERPRISE -> Microsoft Office Enterprise 2007
Free DVD Ripper 2.25_is1 -> Free DVD Ripper Version 2.25
Google Desktop -> Google Desktop
Handbrake -> Handbrake 0.9.4
HOMESTUDENTR -> Microsoft Office Home and Student 2007
HP.MediaSmartSlingPlayer_is1 -> HP MediaSmart SlingPlayer
InstallShield_{004B0DCB-4C60-465B-8F01-44B0A4111187} -> SlingPlayer
InstallShield_{01FB4998-33C4-4431-85ED-079E3EEFE75D} -> HP MediaSmart Webcam
InstallShield_{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79} -> CyberLink DVD Suite
InstallShield_{40BF1E83-20EB-11D8-97C5-0009C5020658} -> Power2Go
InstallShield_{67626E09-5366-4480-8F1E-93FADF50CA15} -> HP MediaSmart TV
InstallShield_{B2EE25B9-5B00-4ACF-94F0-92433C28C39E} -> HP MediaSmart Music/Photo/Video
InstallShield_{C59C179C-668D-49A9-B6EA-0121CCFC1243} -> LabelPrint
InstallShield_{CB099890-1D5F-11D5-9EA9-0050BAE317E1} -> PowerDirector
InstallShield_{DCCAD079-F92C-44DA-B258-624FC6517A5A} -> HP MediaSmart DVD
Malwarebytes' Anti-Malware_is1 -> Malwarebytes' Anti-Malware
Mozilla Firefox (3.6.3) -> Mozilla Firefox (3.6.3)
NSS -> Norton Security Scan
Picasa 3 -> Picasa 3
Samsung ML-1740 Series -> Samsung ML-1740 Series
ViewpointMediaPlayer -> Viewpoint Media Player
VLC media player -> VLC media player 1.0.0
WildTangent hp Master Uninstall -> My HP Games
WinLiveSuite_Wave3 -> Windows Live Essentials
< Uninstall List [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ ->
{226b64e8-dc75-4eea-a6c8-abcb496320f2}-Google Talk -> Google Talk (remove only)
BitTorrent -> BitTorrent
Google Chrome -> Google Chrome
Move Media Player -> Move Media Player
Sansa Updater -> Sansa Updater
< EventViewer Logs - Last 10 Errors > -> Event Information -> Description
Application [ Error ] 4/22/2010 9:28:52 AM Computer Name = Stephanie-PC | Source = SideBySide | ID = 16842830 -> Description = Activation context generation failed for "C:\Users\Stephanie\Downloads\esetsmartinstaller_enu(7).exe".Error in manifest or policy file "" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18005_none_1509f8bef40ee4da.manifest. Component 2: C:\Windows\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18005_none_5cb72f96088b0de0.manifest.
Application [ Error ] 4/22/2010 11:04:41 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: Continuously busy for more than a second
Application [ Error ] 4/22/2010 11:04:41 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledEvent 5683460
Application [ Error ] 4/22/2010 11:04:41 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledSPRetry 5683460
Application [ Error ] 4/22/2010 11:04:47 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: Continuously busy for more than a second
Application [ Error ] 4/22/2010 11:04:48 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledEvent 5689310
Application [ Error ] 4/22/2010 11:04:48 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledSPRetry 5689310
Application [ Error ] 4/22/2010 11:04:49 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: Continuously busy for more than a second
Application [ Error ] 4/22/2010 11:04:50 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledEvent 5691728
Application [ Error ] 4/22/2010 11:04:50 AM Computer Name = Stephanie-PC | Source = Bonjour Service | ID = 100 -> Description = Task Scheduling Error: m->NextScheduledSPRetry 5691728
Media Center [ Error ] 10/11/2009 9:57:02 PM Computer Name = Stephanie-PC | Source = MCUpdate | ID = 0 -> Description = DownloadPackgeTask.SubTasksComplete: failed downloading package SportsSchedule.
System [ Error ] 11/27/2009 2:53:28 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X SD Host Controller' (PCI\VEN_197B&DEV_2381&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&02E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/27/2009 2:53:29 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X MS Host Controller' (PCI\VEN_197B&DEV_2383&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&03E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/27/2009 2:53:29 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X xD Host Controller' (PCI\VEN_197B&DEV_2384&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&04E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/30/2009 3:10:57 AM Computer Name = Stephanie-PC | Source = HTTP | ID = 15016 -> Description =
System [ Error ] 11/30/2009 3:12:18 AM Computer Name = Stephanie-PC | Source = Service Control Manager | ID = 7000 -> Description =
System [ Error ] 11/30/2009 3:12:18 AM Computer Name = Stephanie-PC | Source = Service Control Manager | ID = 7009 -> Description =
System [ Error ] 11/30/2009 3:15:27 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X SD/MMC Host Controller' (PCI\VEN_197B&DEV_2382&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&00E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/30/2009 3:15:27 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X SD Host Controller' (PCI\VEN_197B&DEV_2381&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&02E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/30/2009 3:15:27 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X MS Host Controller' (PCI\VEN_197B&DEV_2383&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&03E4) disappeared from the system without first being prepared for removal.
System [ Error ] 11/30/2009 3:15:27 AM Computer Name = Stephanie-PC | Source = PlugPlayManager | ID = 12 -> Description = The device 'JMB38X xD Host Controller' (PCI\VEN_197B&DEV_2384&SUBSYS_30F7103C&REV_00\4&37ba8cc&0&04E4) disappeared from the system without first being prepared for removal.
[Files/Folders - Created Within 90 Days]
SysProt -> C:\Users\Stephanie\Desktop\SysProt -> [2010/04/22 21:46:00 | 000,000,000 | ---D | C]
SREngLdr.EXE -> C:\Users\Stephanie\Desktop\SREngLdr.EXE -> [2010/04/22 21:23:49 | 001,830,424 | ---- | C | MD5 = EA58EC54663535B38BD5B7E976BABAC3] (Smallfrogs Studio)
Upload -> C:\Users\Stephanie\Desktop\Upload -> [2010/04/22 21:23:49 | 000,000,000 | ---D | C]
hijackthis -> C:\Users\Stephanie\Desktop\hijackthis -> [2010/04/22 01:37:39 | 000,000,000 | ---D | C]
WinRAR -> C:\Users\Stephanie\AppData\Roaming\WinRAR -> [2010/04/22 01:35:29 | 000,000,000 | ---D | C]
ESET -> C:\Program Files (x86)\ESET -> [2010/04/22 00:31:37 | 000,000,000 | ---D | C]
32788R22FWJFW -> C:\32788R22FWJFW -> [2010/04/21 01:07:40 | 000,000,000 | ---D | C]
Malwarebytes -> C:\Users\Stephanie\AppData\Roaming\Malwarebytes -> [2010/04/20 00:06:36 | 000,000,000 | ---D | C]
mbamswissarmy.sys -> C:\Windows\SysWow64\drivers\mbamswissarmy.sys -> [2010/04/20 00:06:17 | 000,038,224 | ---- | C | MD5 = 75B8EF2A089127E8A3B38F46CC366D79] (Malwarebytes Corporation)
Malwarebytes' Anti-Malware -> C:\Program Files (x86)\Malwarebytes' Anti-Malware -> [2010/04/20 00:06:15 | 000,000,000 | ---D | C]
Malwarebytes -> C:\ProgramData\Malwarebytes -> [2010/04/20 00:06:15 | 000,000,000 | ---D | C]
lcykohynw -> C:\Users\Stephanie\AppData\Local\lcykohynw -> [2010/04/19 22:59:12 | 000,000,000 | ---D | C]
iTunes -> C:\Program Files (x86)\iTunes -> [2010/04/05 21:07:18 | 000,000,000 | ---D | C]
{93E26451-CD9A-43A5-A2FA-C42392EA4001} -> C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001} -> [2010/04/05 21:07:18 | 000,000,000 | ---D | C]
QuickTime -> C:\Program Files (x86)\QuickTime -> [2010/04/05 21:00:39 | 000,000,000 | ---D | C]
Bonjour -> C:\Program Files (x86)\Bonjour -> [2010/04/05 20:56:46 | 000,000,000 | ---D | C]
NYAWC Volunteer Council -> C:\Users\Stephanie\Documents\NYAWC Volunteer Council -> [2010/04/03 19:42:01 | 000,000,000 | ---D | C]
nshhttp.dll -> C:\Windows\SysWow64\nshhttp.dll -> [2010/03/15 20:52:08 | 000,024,064 | ---- | C | MD5 = 478ABCCF01166AC6D6AD0FA188051418] (Microsoft Corporation)
httpapi.dll -> C:\Windows\SysWow64\httpapi.dll -> [2010/03/15 20:52:01 | 000,030,720 | ---- | C | MD5 = F86293D93760C70ADF4F19E66E3FA5E8] (Microsoft Corporation)
Config.Msi -> C:\Config.Msi -> [2010/03/15 20:50:45 | 000,000,000 | -HSD | C]
Taxes 2009 -> C:\Users\Stephanie\Documents\Taxes 2009 -> [2010/03/14 23:01:17 | 000,000,000 | ---D | C]
Aura Video Converter -> C:\Users\Stephanie\Documents\Aura Video Converter -> [2010/03/12 10:39:51 | 000,000,000 | ---D | C]
Aura4You -> C:\Users\Stephanie\AppData\Roaming\Aura4You -> [2010/03/12 10:39:26 | 000,000,000 | ---D | C]
Aura4You -> C:\Program Files (x86)\Aura4You -> [2010/03/12 10:39:24 | 000,000,000 | ---D | C]
Any Video Converter Professional -> C:\Users\Stephanie\Documents\Any Video Converter Professional -> [2010/03/12 04:29:57 | 000,000,000 | ---D | C]
AnvSoft -> C:\Users\Stephanie\AppData\Roaming\AnvSoft -> [2010/03/12 04:29:26 | 000,000,000 | ---D | C]
AnvSoft -> C:\Program Files (x86)\AnvSoft -> [2010/03/12 04:29:21 | 000,000,000 | ---D | C]
Sansa Media Converter -> C:\Users\Stephanie\Documents\Sansa Media Converter -> [2010/03/12 03:24:13 | 000,000,000 | ---D | C]
xactengine2_0.dll -> C:\Windows\SysWow64\xactengine2_0.dll -> [2010/03/12 03:23:27 | 000,230,096 | ---- | C | MD5 = 2112FE0C46662D429347A7D7B49E3ECE] (Microsoft Corporation)
x3daudio1_0.dll -> C:\Windows\SysWow64\x3daudio1_0.dll -> [2010/03/12 03:23:27 | 000,014,032 | ---- | C | MD5 = 4E961525CC7FF0E5D7DA19E170B7C14C] (Microsoft Corporation)
d3dx9_29.dll -> C:\Windows\SysWow64\d3dx9_29.dll -> [2010/03/12 03:23:15 | 002,332,368 | ---- | C | MD5 = 99F4FC172A5ACE36CF00AA7038D23F2C] (Microsoft Corporation)
d3dx9_28.dll -> C:\Windows\SysWow64\d3dx9_28.dll -> [2010/03/12 03:23:14 | 002,323,664 | ---- | C | MD5 = BE19B603DFBAA829EE5B7749B3BA97DB] (Microsoft Corporation)
d3dx9_26.dll -> C:\Windows\SysWow64\d3dx9_26.dll -> [2010/03/12 03:23:09 | 002,297,552 | ---- | C | MD5 = 523AB607EEF81CC4D909E7FEBD8A788E] (Microsoft Corporation)
d3dx9_25.dll -> C:\Windows\SysWow64\d3dx9_25.dll -> [2010/03/12 03:22:59 | 002,337,488 | ---- | C | MD5 = 5B48FE9D6686F0D54B26A005ACE24D1D] (Microsoft Corporation)
d3dx9_24.dll -> C:\Windows\SysWow64\d3dx9_24.dll -> [2010/03/12 03:22:50 | 002,222,800 | ---- | C | MD5 = BC831661963763AC4D504C5CABB1FDD9] (Microsoft Corporation)
iviaspi.sys -> C:\Windows\SysWow64\iviaspi.sys -> [2010/03/12 03:22:05 | 000,014,608 | ---- | C | MD5 = 3FF38C4092E47392E815F4D44266BDD7] (InterVideo, Inc.)
SanDisk -> C:\Program Files (x86)\SanDisk -> [2010/03/12 03:21:55 | 000,000,000 | ---D | C]
SanDisk -> C:\Users\Stephanie\AppData\Roaming\SanDisk -> [2010/03/12 03:13:42 | 000,000,000 | ---D | C]
jscript.dll -> C:\Windows\SysWow64\jscript.dll -> [2010/02/23 23:05:53 | 000,726,528 | ---- | C | MD5 = 46E35CDEA68DFCE274BE2B51EB9F0D36] (Microsoft Corporation)
secproc_isv.dll -> C:\Windows\SysWow64\secproc_isv.dll -> [2010/02/23 23:05:36 | 000,471,552 | ---- | C | MD5 = F4BFD5330DA0899771EB24A0DDEF87AF] (Microsoft Corporation)
secproc.dll -> C:\Windows\SysWow64\secproc.dll -> [2010/02/23 23:05:34 | 000,471,552 | ---- | C | MD5 = C7EF2D81B9AC543DA9205701C45F62BD] (Microsoft Corporation)
RMActivate_isv.exe -> C:\Windows\SysWow64\RMActivate_isv.exe -> [2010/02/23 23:05:23 | 000,526,336 | ---- | C | MD5 = 447D3599FA65A9A8BCF7F9048BDB7035] (Microsoft Corporation)
RMActivate.exe -> C:\Windows\SysWow64\RMActivate.exe -> [2010/02/23 23:05:22 | 000,518,144 | ---- | C | MD5 = 8FB90F7CFBCCF50DF2E3080A2BC6F23B] (Microsoft Corporation)
RMActivate_ssp.exe -> C:\Windows\SysWow64\RMActivate_ssp.exe -> [2010/02/23 23:05:22 | 000,347,136 | ---- | C | MD5 = D1194E75C78C451698D7DFFDAB22C5DA] (Microsoft Corporation)
RMActivate_ssp_isv.exe -> C:\Windows\SysWow64\RMActivate_ssp_isv.exe -> [2010/02/23 23:05:22 | 000,346,624 | ---- | C | MD5 = A64C3712DF40DF6BD489A98E280130E7] (Microsoft Corporation)
msdrm.dll -> C:\Windows\SysWow64\msdrm.dll -> [2010/02/23 23:05:21 | 000,332,288 | ---- | C | MD5 = 2D74D853886BDD0CDE60BE5FDF22AD9A] (Microsoft Corporation)
secproc_ssp_isv.dll -> C:\Windows\SysWow64\secproc_ssp_isv.dll -> [2010/02/23 23:05:21 | 000,152,576 | ---- | C | MD5 = 7857CFD06825D710E18793D5306C7724] (Microsoft Corporation)
secproc_ssp.dll -> C:\Windows\SysWow64\secproc_ssp.dll -> [2010/02/23 23:05:21 | 000,152,064 | ---- | C | MD5 = B385C4E499591941E362E324969BB6FB] (Microsoft Corporation)
gameux.dll -> C:\Windows\SysWow64\gameux.dll -> [2010/02/23 23:05:14 | 001,696,256 | ---- | C | MD5 = 9C92BDBD4B2930DE83053D851D90B409] (Microsoft Corporation)
Apphlpdm.dll -> C:\Windows\SysWow64\Apphlpdm.dll -> [2010/02/23 23:05:13 | 000,028,672 | ---- | C | MD5 = 00AD6E3868B390745F9E3C58A557BC31] (Microsoft Corporation)
GameUXLegacyGDFs.dll -> C:\Windows\SysWow64\GameUXLegacyGDFs.dll -> [2010/02/23 23:05:12 | 004,240,384 | ---- | C | MD5 = 7EE94754C9AF5B8A4A97E620C4C07541] (Microsoft)
InstallShield -> C:\Users\Stephanie\AppData\Roaming\InstallShield -> [2010/02/23 21:41:00 | 000,000,000 | ---D | C]
PX Storage Engine -> C:\Program Files (x86)\Common Files\PX Storage Engine -> [2010/02/23 21:36:40 | 000,000,000 | ---D | C]
Sonic Shared -> C:\Program Files (x86)\Common Files\Sonic Shared -> [2010/02/23 21:30:18 | 000,000,000 | ---D | C]
Roxio -> C:\Program Files (x86)\Roxio -> [2010/02/23 21:30:18 | 000,000,000 | ---D | C]
Research In Motion -> C:\ProgramData\Research In Motion -> [2010/02/23 21:09:56 | 000,000,000 | ---D | C]
$AVG -> C:\$AVG -> [2010/02/20 03:05:35 | 000,000,000 | -H-D | C]
avg9 -> C:\ProgramData\avg9 -> [2010/02/20 03:04:39 | 000,000,000 | ---D | C]
Norton Security Scan -> C:\Program Files (x86)\Norton Security Scan -> [2010/02/20 02:55:12 | 000,000,000 | ---D | C]
NortonInstaller -> C:\Program Files (x86)\NortonInstaller -> [2010/02/20 02:55:10 | 000,000,000 | ---D | C]
DivX Shared -> C:\Program Files (x86)\Common Files\DivX Shared -> [2010/02/15 12:55:48 | 000,000,000 | ---D | C]
DivX -> C:\Program Files (x86)\DivX -> [2010/02/15 12:55:35 | 000,000,000 | ---D | C]
quartz.dll -> C:\Windows\SysWow64\quartz.dll -> [2010/02/10 01:05:57 | 001,314,816 | ---- | C | MD5 = EDA91FB72ED5F9B16B8AF72C2E68583C] (Microsoft Corporation)
msvfw32.dll -> C:\Windows\SysWow64\msvfw32.dll -> [2010/02/10 01:05:56 | 000,123,904 | ---- | C | MD5 = EACACA0F2FF4CC54A909E3C5721FCDE8] (Microsoft Corporation)
avifil32.dll -> C:\Windows\SysWow64\avifil32.dll -> [2010/02/10 01:05:56 | 000,091,136 | ---- | C | MD5 = 9EFDF7F0153C066BE619450E3D5D59DD] (Microsoft Corporation)
mciavi32.dll -> C:\Windows\SysWow64\mciavi32.dll -> [2010/02/10 01:05:56 | 000,082,944 | ---- | C | MD5 = 49481223D2451181266FD6BA51ACACAC] (Microsoft Corporation)
Cooliris -> C:\Users\Stephanie\AppData\Local\Cooliris -> [2010/02/02 23:56:28 | 000,000,000 | ---D | C]
Sun -> C:\ProgramData\Sun -> [2010/01/27 20:56:38 | 000,000,000 | ---D | C]
My Google Gadgets -> C:\Users\Stephanie\Documents\My Google Gadgets -> [2010/01/23 18:24:16 | 000,000,000 | ---D | C]
[Files/Folders - Modified Within 90 Days]
ntuser.dat -> C:\Users\Stephanie\ntuser.dat -> [2010/04/22 22:13:04 | 003,145,728 | -HS- | M | Unable to obtain MD5] ()
User_Feed_Synchronization-{89441D96-6562-40FB-A12A-527F67025E10}.job -> C:\Windows\tasks\User_Feed_Synchronization-{89441D96-6562-40FB-A12A-527F67025E10}.job -> [2010/04/22 22:12:59 | 000,000,438 | -H-- | M | MD5 = 4B751A9EF1B8CEE7E710024B4C2CA0C8] ()
GoogleUpdateTaskUserS-1-5-21-1413613182-2839125087-4029887168-1000UA.job -> C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-1413613182-2839125087-4029887168-1000UA.job -> [2010/04/22 22:08:00 | 000,000,924 | ---- | M | MD5 = 13AAED837E4BFD6D2AC06A77F84843CB] ()
bootstat.dat -> C:\Windows\bootstat.dat -> [2010/04/22 21:21:00 | 000,067,584 | --S- | M | MD5 = 9C9C00EAF2491E7BB0C85879982B2C76] ()
GetSystemInfo_STEPHANIE-PC_Stephanie_2010_04_22_12_59_26.zip -> C:\Users\Stephanie\Desktop\GetSystemInfo_STEPHANIE-PC_Stephanie_2010_04_22_12_59_26.zip -> [2010/04/22 13:06:18 | 000,279,877 | ---- | M | MD5 = 4023A210D5AE204622DF12A9C2C7324B] ()
GoogleUpdateTaskUserS-1-5-21-1413613182-2839125087-4029887168-1000Core.job -> C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-1413613182-2839125087-4029887168-1000Core.job -> [2010/04/22 04:08:00 | 000,000,872 | ---- | M | MD5 = BDBB33E9CC54E376952ADE7BF9BF20BB] ()
SA.DAT -> C:\Windows\tasks\SA.DAT -> [2010/04/22 01:41:54 | 000,000,006 | -H-- | M | MD5 = F1A6CD5ADAAB953A6764EA364E17BFB8] ()
hiberfil.sys -> C:\hiberfil.sys -> [2010/04/22 01:41:48 | 4193,210,368 | -HS- | M | Unable to obtain MD5] ()
bthservsdp.dat -> C:\Windows\bthservsdp.dat -> [2010/04/22 01:41:07 | 000,000,012 | ---- | M | Unable to obtain MD5] ()
ntuser.dat{8e63ebe6-9241-11de-91c1-00235a9e0270}.TMContainer00000000000000000001.regtrans-ms -> C:\Users\Stephanie\ntuser.dat{8e63ebe6-9241-11de-91c1-00235a9e0270}.TMContainer00000000000000000001.regtrans-ms -> [2010/04/22 01:41:06 | 000,524,288 | -HS- | M | Unable to obtain MD5] ()
ntuser.dat{8e63ebe6-9241-11de-91c1-00235a9e0270}.TM.blf -> C:\Users\Stephanie\ntuser.dat{8e63ebe6-9241-11de-91c1-00235a9e0270}.TM.blf -> [2010/04/22 01:41:06 | 000,065,536 | -HS- | M | Unable to obtain MD5] ()
IconCache.db -> C:\Users\Stephanie\AppData\Local\IconCache.db -> [2010/04/22 01:41:02 | 003,287,713 | -H-- | M | MD5 = EDD3588AF0ECE6C201D9CDC78C5A0E41] ()
hijackthis.rar -> C:\Users\Stephanie\Desktop\hijackthis.rar -> [2010/04/22 01:32:25 | 089,958,810 | ---- | M | MD5 = A56DCAA39473BE3E7548B369A4187F19] ()
d3d9caps.dat -> C:\Users\Stephanie\AppData\Local\d3d9caps.dat -> [2010/04/22 00:21:45 | 000,000,680 | ---- | M | MD5 = 5C9E9DEFB8661AE0500BF7456CC5D797] ()
DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini -> C:\Users\Stephanie\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini -> [2010/04/21 02:24:59 | 000,243,200 | ---- | M | MD5 = F26329FCBA46D8DDF8816FD9871177B2] ()
Malwarebytes' Anti-Malware.lnk -> C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk -> [2010/04/20 00:06:19 | 000,000,848 | ---- | M | MD5 = 14E021DF7641A3BF8216BBE58FF3C868] ()
Adobe Reader 9.lnk -> C:\Users\Public\Desktop\Adobe Reader 9.lnk -> [2010/04/19 23:27:56 | 000,001,917 | ---- | M | MD5 = 9854B1DE380BCDB1A848E5197C7CE219] ()
Norton Security Scan for Stephanie.job -> C:\Windows\tasks\Norton Security Scan for Stephanie.job -> [2010/04/19 04:50:21 | 000,000,506 | -H-- | M | MD5 = FED19157691F30D9A10231B79BA2793C] ()
HPCeeScheduleForStephanie.job -> C:\Windows\tasks\HPCeeScheduleForStephanie.job -> [2010/04/16 06:45:08 | 000,000,350 | ---- | M | MD5 = 02E4075D8D6DD182ABF170CD04262217] ()
iTunes.lnk -> C:\Users\Public\Desktop\iTunes.lnk -> [2010/04/05 21:08:56 | 000,001,804 | ---- | M | MD5 = 5E8DBC4AF36B6774C5999823DE3F51F8] ()
QuickTime Player.lnk -> C:\Users\Public\Desktop\QuickTime Player.lnk -> [2010/04/05 21:01:15 | 000,001,756 | ---- | M | MD5 = E3485FDDEB9DD97BDEDFC77076D58E0E] ()
Google Chrome.lnk -> C:\Users\Stephanie\Desktop\Google Chrome.lnk -> [2010/04/02 02:08:33 | 000,002,062 | ---- | M | MD5 = 020BBE059F79A5734FD7AAFA75A54CB6] ()
mbamswissarmy.sys -> C:\Windows\SysWow64\drivers\mbamswissarmy.sys -> [2010/03/30 00:46:30 | 000,038,224 | ---- | M | MD5 = 75B8EF2A089127E8A3B38F46CC366D79] (Malwarebytes Corporation)
Desktop Manager.lnk -> C:\Users\Public\Desktop\Desktop Manager.lnk -> [2010/03/26 01:05:29 | 000,001,899 | ---- | M | MD5 = 3B6F9534FCC915FC91A0431E8D266C37] ()
i hate my life.xlsx -> C:\Users\Stephanie\Desktop\i hate my life.xlsx -> [2010/03/25 01:15:44 | 000,009,949 | ---- | M | MD5 = 14401A3354C18A3B06F6E0216730C35D] ()
Aura Video Converter.lnk -> C:\Users\Stephanie\Desktop\Aura Video Converter.lnk -> [2010/03/12 10:39:34 | 000,000,976 | ---- | M | MD5 = D2B9096C12857773DC72C42A4A5055D5] ()
Any Video Converter Professional.lnk -> C:\Users\Stephanie\Desktop\Any Video Converter Professional.lnk -> [2010/03/12 04:29:32 | 000,001,024 | ---- | M | MD5 = 1D5E8EDC17D735883FD829613AD06A36] ()
Sansa Media Converter.lnk -> C:\Users\Public\Desktop\ Sansa Media Converter.lnk -> [2010/03/12 03:22:27 | 000,002,084 | ---- | M | MD5 = B8C88BA6C9C8D1396EBF3E26560E52C2] ()
MVI_7876.AVI -> C:\Users\Stephanie\Desktop\MVI_7876.AVI -> [2010/02/28 17:29:29 | 164,960,746 | ---- | M | MD5 = 54DCCFC4932597C77772CF6E2275E94F] ()
GDIPFONTCACHEV1.DAT -> C:\Users\Stephanie\AppData\Local\GDIPFONTCACHEV1.DAT -> [2010/02/26 02:02:21 | 000,122,976 | ---- | M | MD5 = 9A05C5B504E970892079B82813B989CA] ()
nshhttp.dll -> C:\Windows\SysWow64\nshhttp.dll -> [2010/02/20 19:06:41 | 000,024,064 | ---- | M | MD5 = 478ABCCF01166AC6D6AD0FA188051418] (Microsoft Corporation)
httpapi.dll -> C:\Windows\SysWow64\httpapi.dll -> [2010/02/20 19:05:14 | 000,030,720 | ---- | M | MD5 = F86293D93760C70ADF4F19E66E3FA5E8] (Microsoft Corporation)
Norton Security Scan.lnk -> C:\Users\Public\Desktop\Norton Security Scan.lnk -> [2010/02/20 02:55:17 | 000,001,179 | ---- | M | MD5 = B9C2B3B4B5F9A278232AAF3699DD1C08] ()
DivX Movies.lnk -> C:\Users\Stephanie\Desktop\DivX Movies.lnk -> [2010/02/15 12:55:36 | 000,001,422 | ---- | M | MD5 = 15B10441F6CCC11B0DA46B4EB8BF1C4C] ()
MVI_0207.zip -> C:\Users\Stephanie\Desktop\MVI_0207.zip -> [2010/01/30 02:28:38 | 080,505,574 | ---- | M | MD5 = 07CA751517416AE3E29D5001858F8FED] ()
secproc_isv.dll -> C:\Windows\SysWow64\secproc_isv.dll -> [2010/01/25 08:00:35 | 000,471,552 | ---- | M | MD5 = F4BFD5330DA0899771EB24A0DDEF87AF] (Microsoft Corporation)
secproc_ssp_isv.dll -> C:\Windows\SysWow64\secproc_ssp_isv.dll -> [2010/01/25 08:00:35 | 000,152,576 | ---- | M | MD5 = 7857CFD06825D710E18793D5306C7724] (Microsoft Corporation)
secproc_ssp.dll -> C:\Windows\SysWow64\secproc_ssp.dll -> [2010/01/25 08:00:35 | 000,152,064 | ---- | M | MD5 = B385C4E499591941E362E324969BB6FB] (Microsoft Corporation)
secproc.dll -> C:\Windows\SysWow64\secproc.dll -> [2010/01/25 08:00:22 | 000,471,552 | ---- | M | MD5 = C7EF2D81B9AC543DA9205701C45F62BD] (Microsoft Corporation)
msdrm.dll -> C:\Windows\SysWow64\msdrm.dll -> [2010/01/25 07:58:52 | 000,332,288 | ---- | M | MD5 = 2D74D853886BDD0CDE60BE5FDF22AD9A] (Microsoft Corporation)
RMActivate_isv.exe -> C:\Windows\SysWow64\RMActivate_isv.exe -> [2010/01/25 04:21:20 | 000,526,336 | ---- | M | MD5 = 447D3599FA65A9A8BCF7F9048BDB7035] (Microsoft Corporation)
RMActivate_ssp_isv.exe -> C:\Windows\SysWow64\RMActivate_ssp_isv.exe -> [2010/01/25 04:21:20 | 000,346,624 | ---- | M | MD5 = A64C3712DF40DF6BD489A98E280130E7] (Microsoft Corporation)
RMActivate.exe -> C:\Windows\SysWow64\RMActivate.exe -> [2010/01/25 04:21:18 | 000,518,144 | ---- | M | MD5 = 8FB90F7CFBCCF50DF2E3080A2BC6F23B] (Microsoft Corporation)
RMActivate_ssp.exe -> C:\Windows\SysWow64\RMActivate_ssp.exe -> [2010/01/25 04:21:18 | 000,347,136 | ---- | M | MD5 = D1194E75C78C451698D7DFFDAB22C5DA] (Microsoft Corporation)
Google Desktop.lnk -> C:\Users\Public\Desktop\Google Desktop.lnk -> [2010/01/23 18:23:09 | 000,001,125 | ---- | M | MD5 = 098FD1F39DD1BFB69F63B38A44472EC1] ()
11 C:\Users\Stephanie\AppData\Local\Temp\*.tmp files -> C:\Users\Stephanie\AppData\Local\Temp\*.tmp ->
[Files - No Company Name]
GetSystemInfo_STEPHANIE-PC_Stephanie_2010_04_22_12_59_26.zip -> C:\Users\Stephanie\Desktop\GetSystemInfo_STEPHANIE-PC_Stephanie_2010_04_22_12_59_26.zip -> [2010/04/22 13:03:27 | 000,279,877 | ---- | C | MD5 = 4023A210D5AE204622DF12A9C2C7324B] ()
IconCache.db -> C:\Users\Stephanie\AppData\Local\IconCache.db -> [2010/04/22 01:41:02 | 003,287,713 | -H-- | C | MD5 = EDD3588AF0ECE6C201D9CDC78C5A0E41] ()
hijackthis.rar -> C:\Users\Stephanie\Desktop\hijackthis.rar -> [2010/04/22 01:19:14 | 089,958,810 | ---- | C | MD5 = A56DCAA39473BE3E7548B369A4187F19] ()
hiberfil.sys -> C:\hiberfil.sys -> [2010/04/22 00:36:42 | 4193,210,368 | -HS- | C | Unable to obtain MD5] ()
d3d9caps.dat -> C:\Users\Stephanie\AppData\Local\d3d9caps.dat -> [2010/04/20 09:27:32 | 000,000,680 | ---- | C | MD5 = 5C9E9DEFB8661AE0500BF7456CC5D797] ()
Malwarebytes' Anti-Malware.lnk -> C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk -> [2010/04/20 00:06:19 | 000,000,848 | ---- | C | MD5 = 14E021DF7641A3BF8216BBE58FF3C868] ()
iTunes.lnk -> C:\Users\Public\Desktop\iTunes.lnk -> [2010/04/05 21:08:56 | 000,001,804 | ---- | C | MD5 = 5E8DBC4AF36B6774C5999823DE3F51F8] ()
QuickTime Player.lnk -> C:\Users\Public\Desktop\QuickTime Player.lnk -> [2010/04/05 21:01:15 | 000,001,756 | ---- | C | MD5 = E3485FDDEB9DD97BDEDFC77076D58E0E] ()
Desktop Manager.lnk -> C:\Users\Public\Desktop\Desktop Manager.lnk -> [2010/03/26 01:05:29 | 000,001,899 | ---- | C | MD5 = 3B6F9534FCC915FC91A0431E8D266C37] ()
i hate my life.xlsx -> C:\Users\Stephanie\Desktop\i hate my life.xlsx -> [2010/03/22 21:55:00 | 000,009,949 | ---- | C | MD5 = 14401A3354C18A3B06F6E0216730C35D] ()
Aura Video Converter.lnk -> C:\Users\Stephanie\Desktop\Aura Video Converter.lnk -> [2010/03/12 10:39:34 | 000,000,976 | ---- | C | MD5 = D2B9096C12857773DC72C42A4A5055D5] ()
Any Video Converter Professional.lnk -> C:\Users\Stephanie\Desktop\Any Video Converter Professional.lnk -> [2010/03/12 04:29:32 | 000,001,024 | ---- | C | MD5 = 1D5E8EDC17D735883FD829613AD06A36] ()
Sansa Media Converter.lnk -> C:\Users\Public\Desktop\ Sansa Media Converter.lnk -> [2010/03/12 03:22:27 | 000,002,084 | ---- | C | MD5 = B8C88BA6C9C8D1396EBF3E26560E52C2] ()
MVI_7876.AVI -> C:\Users\Stephanie\Desktop\MVI_7876.AVI -> [2010/02/28 17:25:58 | 164,960,746 | ---- | C | MD5 = 54DCCFC4932597C77772CF6E2275E94F] ()
Norton Security Scan for Stephanie.job -> C:\Windows\tasks\Norton Security Scan for Stephanie.job -> [2010/02/20 02:55:21 | 000,000,506 | -H-- | C | MD5 = FED19157691F30D9A10231B79BA2793C] ()
Norton Security Scan.lnk -> C:\Users\Public\Desktop\Norton Security Scan.lnk -> [2010/02/20 02:55:17 | 000,001,179 | ---- | C | MD5 = B9C2B3B4B5F9A278232AAF3699DD1C08] ()
DivX Movies.lnk -> C:\Users\Stephanie\Desktop\DivX Movies.lnk -> [2010/02/15 12:55:36 | 000,001,422 | ---- | C | MD5 = 15B10441F6CCC11B0DA46B4EB8BF1C4C] ()
Adobe Reader 9.lnk -> C:\Users\Public\Desktop\Adobe Reader 9.lnk -> [2010/01/31 22:37:20 | 000,001,917 | ---- | C | MD5 = 9854B1DE380BCDB1A848E5197C7CE219] ()
MVI_0207.zip -> C:\Users\Stephanie\Desktop\MVI_0207.zip -> [2010/01/30 02:28:29 | 080,505,574 | ---- | C | MD5 = 07CA751517416AE3E29D5001858F8FED] ()
Google Desktop.lnk -> C:\Users\Public\Desktop\Google Desktop.lnk -> [2010/01/23 18:23:09 | 000,001,125 | ---- | C | MD5 = 098FD1F39DD1BFB69F63B38A44472EC1] ()
EhStorAuthn.dll -> C:\Windows\SysWow64\EhStorAuthn.dll -> [2009/12/03 02:06:21 | 000,117,248 | ---- | C | MD5 = 358A03A7A47F0AD71E84306AC635A626] ()
msjetoledb40.dll -> C:\Windows\SysWow64\msjetoledb40.dll -> [2009/12/03 02:04:10 | 000,368,640 | ---- | C | MD5 = 52CB0185C73E1BA86CC7F726F22523C3] ()
ractrlkeyhook.dll -> C:\Windows\SysWow64\ractrlkeyhook.dll -> [2009/09/10 11:21:44 | 000,008,520 | ---- | C | MD5 = 7628119761CD4C1E2FDC54A8DAB1606D] ()
tcpmon.ini -> C:\Windows\SysWow64\tcpmon.ini -> [2008/01/20 22:50:05 | 000,060,124 | ---- | C | MD5 = 47F22CAD4A16BB40153555D631546B94] ()
GlobalUserInterface.CompositeFont -> C:\Windows\Fonts\GlobalUserInterface.CompositeFont -> [2006/11/02 11:07:25 | 000,037,665 | ---- | C | MD5 = E3E173CDA7B3982D762143BE19047ED5] ()
GlobalSerif.CompositeFont -> C:\Windows\Fonts\GlobalSerif.CompositeFont -> [2006/11/02 11:07:25 | 000,029,779 | ---- | C | MD5 = B77AB4697B17FBBB25E41A15CC31D94E] ()
GlobalSansSerif.CompositeFont -> C:\Windows\Fonts\GlobalSansSerif.CompositeFont -> [2006/11/02 11:07:25 | 000,026,489 | ---- | C | MD5 = D6B2075824BA9FAA4B37D98B13447F32] ()
GlobalMonospace.CompositeFont -> C:\Windows\Fonts\GlobalMonospace.CompositeFont -> [2006/11/02 11:07:25 | 000,026,040 | ---- | C | MD5 = B7F882C45E520600053327AA42FA3A4F] ()
xvidvfw.dll -> C:\Windows\SysWow64\xvidvfw.dll -> [2006/02/28 21:17:30 | 000,159,744 | ---- | C | MD5 = 1F4E1A1E9F8C7C0EE4CFA7743527ED96] ()
xvidcore.dll -> C:\Windows\SysWow64\xvidcore.dll -> [2005/12/30 20:10:30 | 000,761,856 | ---- | C | MD5 = 81CCA8C60DD2EDAF394B6E75FF8E325F] ()
[File - Lop Check]
acccore -> C:\Users\Stephanie\AppData\Roaming\acccore -> [2009/06/18 20:59:33 | 000,000,000 | ---D | M]
AnvSoft -> C:\Users\Stephanie\AppData\Roaming\AnvSoft -> [2010/03/12 04:29:26 | 000,000,000 | ---D | M]
Aura4You -> C:\Users\Stephanie\AppData\Roaming\Aura4You -> [2010/03/12 10:39:26 | 000,000,000 | ---D | M]
BitTorrent -> C:\Users\Stephanie\AppData\Roaming\BitTorrent -> [2009/08/26 13:07:28 | 000,000,000 | ---D | M]
HandBrake -> C:\Users\Stephanie\AppData\Roaming\HandBrake -> [2009/11/24 20:30:23 | 000,000,000 | ---D | M]
Research In Motion -> C:\Users\Stephanie\AppData\Roaming\Research In Motion -> [2009/07/14 00:13:51 | 000,000,000 | ---D | M]
SanDisk -> C:\Users\Stephanie\AppData\Roaming\SanDisk -> [2010/03/12 03:13:42 | 000,000,000 | ---D | M]
SCHEDLGU.TXT -> C:\Windows\Tasks\SCHEDLGU.TXT -> [2010/04/22 01:41:08 | 000,032,558 | ---- | M | Unable to obtain MD5] ()
User_Feed_Synchronization-{89441D96-6562-40FB-A12A-527F67025E10}.job -> C:\Windows\Tasks\User_Feed_Synchronization-{89441D96-6562-40FB-A12A-527F67025E10}.job -> [2010/04/22 22:12:59 | 000,000,438 | -H-- | M | MD5 = 4B751A9EF1B8CEE7E710024B4C2CA0C8] ()
[File - Purity Scan]
[Custom Scans]
< %systemroot%\*. /mp /s >
< %systemroot%\system32\*.dll /lockedfiles >
dxtmsft.dll : Unable to obtain MD5 -> C:\Windows\SysWOW64\dxtmsft.dll -> [2009/03/08 07:31:42 | 000,348,160 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
dxtrans.dll : Unable to obtain MD5 -> C:\Windows\SysWOW64\dxtrans.dll -> [2009/03/08 07:31:37 | 000,216,064 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
iepeers.dll : Unable to obtain MD5 -> C:\Windows\SysWOW64\iepeers.dll -> [2010/01/02 02:32:32 | 000,184,320 | ---- | M | Unable to obtain MD5] (Microsoft Corporation)
< %systemroot%\system32\*.exe /lockedfiles >
< %systemroot%\system32\drivers\*.sys /lockedfiles >
< %systemroot%\System32\config\*.sav >
< %systemroot%\System32\*.sys >
iviaspi.sys -> C:\Windows\SysWOW64\iviaspi.sys -> [2008/10/14 13:01:30 | 000,014,608 | ---- | M | MD5 = 3FF38C4092E47392E815F4D44266BDD7] (InterVideo, Inc.)
< %systemroot%\System32\drivers\*.dll >
< %systemroot%\System32\drivers\*.ini >
< %systemroot%\System32\drivers\*.exe >
< %SYSTEMDRIVE%\*.* >
bootmgr -> C:\bootmgr -> [2009/04/11 02:36:36 | 000,333,257 | RHS- | M | MD5 = 14B9D882551EC9FFB3C51A7D94C4266C] ()
IPH.PH -> C:\IPH.PH -> [2009/06/18 20:59:15 | 000,000,367 | -H-- | M | MD5 = D68D4E12A7B9A9DE17DD55A347C7F5AE] ()
msdia80.dll -> C:\msdia80.dll -> [2006/12/02 03:37:14 | 000,904,704 | ---- | M | MD5 = 800B746FDC4D80469AFC7E5E9B510C9C] (Microsoft Corporation)
pagefile.sys -> C:\pagefile.sys -> [2010/04/22 01:41:46 | 211,832,831 | -HS- | M | Unable to obtain MD5] ()
< %PROGRAMFILES%\*. >
Activation Assistant for the 2007 Microsoft Office suites -> C:\Program Files (x86)\Activation Assistant for the 2007 Microsoft Office suites -> [2009/02/23 01:54:37 | 000,000,000 | ---D | M]
Adobe -> C:\Program Files (x86)\Adobe -> [2010/01/31 22:37:14 | 000,000,000 | ---D | M]
AIM6 -> C:\Program Files (x86)\AIM6 -> [2009/06/18 20:59:14 | 000,000,000 | ---D | M]
AnvSoft -> C:\Program Files (x86)\AnvSoft -> [2010/03/12 04:29:21 | 000,000,000 | ---D | M]
Apple Software Update -> C:\Program Files (x86)\Apple Software Update -> [2009/08/22 16:39:39 | 000,000,000 | ---D | M]
Aura4You -> C:\Program Files (x86)\Aura4You -> [2010/03/12 10:39:24 | 000,000,000 | ---D | M]
AVG -> C:\Program Files (x86)\AVG -> [2010/02/20 03:04:39 | 000,000,000 | ---D | M]
BitTorrent -> C:\Program Files (x86)\BitTorrent -> [2009/08/16 02:58:06 | 000,000,000 | ---D | M]
Bonjour -> C:\Program Files (x86)\Bonjour -> [2010/04/05 20:56:46 | 000,000,000 | ---D | M]
Common Files -> C:\Program Files (x86)\Common Files -> [2010/02/23 21:36:40 | 000,000,000 | ---D | M]
CyberLink -> C:\Program Files (x86)\CyberLink -> [2009/02/23 02:09:59 | 000,000,000 | ---D | M]
DivX -> C:\Program Files (x86)\DivX -> [2010/02/15 12:56:32 | 000,000,000 | ---D | M]
ESET -> C:\Program Files (x86)\ESET -> [2010/04/22 00:31:37 | 000,000,000 | ---D | M]
Free DVD Ripper -> C:\Program Files (x86)\Free DVD Ripper -> [2009/11/15 04:46:13 | 000,000,000 | ---D | M]
Google -> C:\Program Files (x86)\Google -> [2010/01/23 18:22:25 | 000,000,000 | ---D | M]
Handbrake -> C:\Program Files (x86)\Handbrake -> [2009/11/24 20:30:17 | 000,000,000 | ---D | M]
Hewlett-Packard -> C:\Program Files (x86)\Hewlett-Packard -> [2009/05/21 23:33:52 | 000,000,000 | ---D | M]
Hewlett-Packard Company -> C:\Program Files (x86)\Hewlett-Packard Company -> [2009/02/23 00:55:57 | 000,000,000 | ---D | M]
Hp -> C:\Program Files (x86)\Hp -> [2009/02/23 02:21:19 | 000,000,000 | ---D | M]
HP Games -> C:\Program Files (x86)\HP Games -> [2009/02/23 01:56:22 | 000,000,000 | ---D | M]
InstallShield Installation Information -> C:\Program Files (x86)\InstallShield Installation Information -> [2010/03/12 03:21:55 | 000,000,000 | -H-D | M]
Intel -> C:\Program Files (x86)\Intel -> [2009/05/21 22:53:07 | 000,000,000 | ---D | M]
Internet Explorer -> C:\Program Files (x86)\Internet Explorer -> [2010/01/27 20:58:46 | 000,000,000 | ---D | M]
iTunes -> C:\Program Files (x86)\iTunes -> [2010/04/05 21:08:45 | 000,000,000 | ---D | M]
Java -> C:\Program Files (x86)\Java -> [2010/01/27 20:55:13 | 000,000,000 | ---D | M]
JunoPreloader -> C:\Program Files (x86)\JunoPreloader -> [2009/02/23 02:13:14 | 000,000,000 | ---D | M]
Malwarebytes' Anti-Malware -> C:\Program Files (x86)\Malwarebytes' Anti-Malware -> [2010/04/20 00:06:20 | 000,000,000 | ---D | M]
Microsoft -> C:\Program Files (x86)\Microsoft -> [2009/10/04 20:51:38 | 000,000,000 | ---D | M]
Microsoft Office -> C:\Program Files (x86)\Microsoft Office -> [2009/07/03 02:39:50 | 000,000,000 | ---D | M]
Microsoft Silverlight -> C:\Program Files (x86)\Microsoft Silverlight -> [2010/01/23 17:59:50 | 000,000,000 | ---D | M]
Microsoft Visual Studio -> C:\Program Files (x86)\Microsoft Visual Studio -> [2009/07/03 02:40:16 | 000,000,000 | ---D | M]
Microsoft Visual Studio 8 -> C:\Program Files (x86)\Microsoft Visual Studio 8 -> [2009/07/03 02:14:28 | 000,000,000 | ---D | M]
Microsoft Works -> C:\Program Files (x86)\Microsoft Works -> [2009/06/19 03:02:55 | 000,000,000 | ---D | M]
Microsoft.NET -> C:\Program Files (x86)\Microsoft.NET -> [2009/02/23 01:53:17 | 000,000,000 | ---D | M]
Mozilla Firefox -> C:\Program Files (x86)\Mozilla Firefox -> [2010/04/21 00:32:07 | 000,000,000 | ---D | M]
MSBuild -> C:\Program Files (x86)\MSBuild -> [2009/07/03 02:40:45 | 000,000,000 | ---D | M]
MSN -> C:\Program Files (x86)\MSN -> [2009/02/23 02:13:27 | 000,000,000 | ---D | M]
MSXML 4.0 -> C:\Program Files (x86)\MSXML 4.0 -> [2009/06/18 19:31:56 | 000,000,000 | ---D | M]
muvee Technologies -> C:\Program Files (x86)\muvee Technologies -> [2009/05/22 00:03:16 | 000,000,000 | ---D | M]
NetZeroPreloader -> C:\Program Files (x86)\NetZeroPreloader -> [2009/02/23 02:13:51 | 000,000,000 | ---D | M]
Norton Security Scan -> C:\Program Files (x86)\Norton Security Scan -> [2010/02/20 02:55:12 | 000,000,000 | ---D | M]
NortonInstaller -> C:\Program Files (x86)\NortonInstaller -> [2010/02/20 02:55:10 | 000,000,000 | ---D | M]
Online Services -> C:\Program Files (x86)\Online Services -> [2009/06/18 18:30:37 | 000,000,000 | R--D | M]
QuickTime -> C:\Program Files (x86)\QuickTime -> [2010/04/05 21:01:44 | 000,000,000 | ---D | M]
Realtek -> C:\Program Files (x86)\Realtek -> [2009/05/21 22:56:13 | 000,000,000 | ---D | M]
Reference Assemblies -> C:\Program Files (x86)\Reference Assemblies -> [2006/11/02 11:07:27 | 000,000,000 | ---D | M]
Research In Motion -> C:\Program Files (x86)\Research In Motion -> [2010/02/23 21:13:42 | 000,000,000 | ---D | M]
Roxio -> C:\Program Files (x86)\Roxio -> [2010/02/23 21:36:32 | 000,000,000 | ---D | M]
SAMSUNG -> C:\Program Files (x86)\SAMSUNG -> [2009/06/18 22:04:20 | 000,000,000 | ---D | M]
SanDisk -> C:\Program Files (x86)\SanDisk -> [2010/03/12 03:21:55 | 000,000,000 | ---D | M]
Skype -> C:\Program Files (x86)\Skype -> [2009/06/18 19:06:18 | 000,000,000 | R--D | M]
Sling Media -> C:\Program Files (x86)\Sling Media -> [2009/02/23 01:55:37 | 000,000,000 | ---D | M]
SMINST -> C:\Program Files (x86)\SMINST -> [2009/06/18 18:37:32 | 000,000,000 | ---D | M]
Uninstall Information -> C:\Program Files (x86)\Uninstall Information -> [2006/11/02 11:36:07 | 000,000,000 | -H-D | M]
VideoLAN -> C:\Program Files (x86)\VideoLAN -> [2009/07/22 23:59:27 | 000,000,000 | ---D | M]
Viewpoint -> C:\Program Files (x86)\Viewpoint -> [2009/06/18 20:59:05 | 000,000,000 | ---D | M]
Windows Calendar -> C:\Program Files (x86)\Windows Calendar -> [2009/12/03 02:59:30 | 000,000,000 | ---D | M]
Windows Collaboration -> C:\Program Files (x86)\Windows Collaboration -> [2008/01/20 23:09:47 | 000,000,000 | ---D | M]
Windows Defender -> C:\Program Files (x86)\Windows Defender -> [2008/01/20 23:09:41 | 000,000,000 | ---D | M]
Windows Live -> C:\Program Files (x86)\Windows Live -> [2009/06/18 21:12:09 | 000,000,000 | ---D | M]
Windows Live SkyDrive -> C:\Program Files (x86)\Windows Live SkyDrive -> [2009/06/18 21:11:57 | 000,000,000 | ---D | M]
Windows Mail -> C:\Program Files (x86)\Windows Mail -> [2010/03/15 21:37:25 | 000,000,000 | ---D | M]
Windows Media Player -> C:\Program Files (x86)\Windows Media Player -> [2009/12/03 02:59:30 | 000,000,000 | ---D | M]
Windows NT -> C:\Program Files (x86)\Windows NT -> [2006/11/02 11:07:27 | 000,000,000 | ---D | M]
Windows Photo Gallery -> C:\Program Files (x86)\Windows Photo Gallery -> [2009/12/03 02:59:27 | 000,000,000 | ---D | M]
Windows Portable Devices -> C:\Program Files (x86)\Windows Portable Devices -> [2009/12/04 03:40:58 | 000,000,000 | ---D | M]
Windows Sidebar -> C:\Program Files (x86)\Windows Sidebar -> [2009/12/03 02:59:30 | 000,000,000 | ---D | M]
< %appdata%\*.* >
desktop.ini -> C:\Users\Stephanie\AppData\Roaming\desktop.ini -> [2009/07/14 00:06:23 | 000,000,006 | -HS- | M | MD5 = BEA07E6D2B8DCE396FE21BAA61B34956] ()
[/code]
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Fri Apr 23, 2010 1:44 pm
I see you are running BitTorrent, a P2P application. I suggest to read the following, and then decide whether you want to keep it or not: [You must be registered and logged in to see this link.]
I see you have Viewpoint installed...
Viewpoint Manager is considered as foistware instead of malware since it is installed without users approval but doesn't spy or do anything "bad". I suggest you remove the program now. Navigate to Start --> Control Panel --> Add or Remove Programs and uninstall the following programs if present.
  • Viewpoint
  • Viewpoint Manager
  • Viewpoint Media Player
  • Viewpoint Toolbar
Let me know if you decided to uninstall it.
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Start OTS. Copy/Paste the information in bold below into the panel where it says "Paste fix here" and then click the Run Fix button.
[Kill All Processes]
[Unregister Dlls]
[Registry - Safe List]
< Internet Explorer Settings [HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\] > ->
YN -> HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\: "ProxyServer" -> http=127.0.0.1:5555
< MountPoints2 [HKEY_CURRENT_USER] > -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
YN -> \{b9d0a090-229b-11df-9500-00235a9e0270} ->
YN -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command ->
YY -> \{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command\\"" -> F:\setup.exe [F:\setup.exe]
YN -> \{ff292315-702b-11de-9ad9-00235a9e0270} ->
YN -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command ->
YY -> \{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command\\"" -> G:\slacker.synclauncher.exe [G:\slacker.synclauncher.exe]
YN -> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command ->
YY -> \{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command\\"" -> G:\slacker.synclauncher.exe [G:\slacker.synclauncher.exe]
NY -> lcykohynw -> C:\Users\Stephanie\AppData\Local\lcykohynw
NY -> {93E26451-CD9A-43A5-A2FA-C42392EA4001} -> C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001}
[Purity]
[Empty Temp Folders]
[EmptyFlash]
[Reboot]
The fix should only take a very short time. When the fix is completed a message box will popup telling you that it is finished. Click the Ok button and Notepad will open with a log of actions taken during the fix. Post that information back here.
Posts Posts : 13713
Points Points : 302059
Re: Trojan Problem
Post by dychang on Sat Apr 24, 2010 5:10 am
All Processes Killed
Registry value HKEY_USERS\S-1-5-21-1413613182-2839125087-4029887168-1000\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyServer deleted successfully.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b9d0a090-229b-11df-9500-00235a9e0270}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{b9d0a090-229b-11df-9500-00235a9e0270}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b9d0a090-229b-11df-9500-00235a9e0270}\shell\AutoRun\command not found.
File F:\setup.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{ff292315-702b-11de-9ad9-00235a9e0270}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\AutoRun\command not found.
File G:\slacker.synclauncher.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ff292315-702b-11de-9ad9-00235a9e0270}\shell\slacker\command not found.
C:\Users\Stephanie\AppData\Local\lcykohynw folder moved successfully.
C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001}\x64\x64 folder moved successfully.
C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001}\x64 folder moved successfully.
C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001} folder moved successfully.
[Purity]
Purity scan complete.
User: All Users
User: Default
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Public
User: Stephanie
->Temp folder emptied: 2308579 bytes
->Temporary Internet Files folder emptied: 978737 bytes
->Java cache emptied: 29626 bytes
->FireFox cache emptied: 85792616 bytes
->Google Chrome cache emptied: 310738606 bytes
->Flash cache emptied: 3814 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
Windows Temp folder emptied: 15364 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33170 bytes
%systemroot%\system32\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 0 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33237 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 381.00 mb
[EMPTYFLASH]
User: All Users
User: Default
User: Default User
User: Public
User: Stephanie
Total Flash Files Cleaned = 0.00 mb
< End of fix log >
OTS by OldTimer - Version 3.1.29.0 fix logfile created on 04242010_010120
C:\Users\Stephanie\AppData\Local\Temp\ehmsas.txt moved successfully.
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Sat Apr 24, 2010 5:18 am
Tell me of any issues currently, that are plaguing your computer.
Is the Internet Explorer/Chrome still dysfunctional?
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Sat Apr 24, 2010 5:35 am
they work fine now. the computer seems to be running at the way it was before the problems. thanks!
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Sat Apr 24, 2010 1:29 pm
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Sun Apr 25, 2010 6:00 am
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Sun Apr 25, 2010 7:10 pm
You did not post anything. Please re-post.
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Mon Apr 26, 2010 5:52 am
Results of screen317's Security Check version 0.99.3
Windows Vista (UAC is enabled)
Out of date service pack!!
Internet Explorer 8
Antivirus/Firewall Check:
Windows Firewall Disabled!
WMI entry may not exist for antivirus; attempting automatic update.
Java(TM) 6 Update 18
Java(TM) 6 Update 7
Out of date Java installed!
Adobe Reader 9.3.2
Process Check:
objlist.exe by Laurent
Norton ccSvcHst.exe
DNS Vulnerability Check:
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Tue Apr 27, 2010 1:36 am
Please consider updating to Windows Vista Service Packs 1 & 2.
Windows Vista Service Packs 1 & 2 contain all the updates released since the first release plus support for new types of hardware and emerging hardware standards.
It is now available via [You must be registered and logged in to see this link.] or as a standalone installation [You must be registered and logged in to see this link.].
Software recommendations
Antivirus/Antispyware
  • [You must be registered and logged in to see this link.]: this is Microsoft's free antivirus/antispyware program. It equips you with protection against viruses, spyware, trojans, rootkits, and worms. It is also light on the computer's performance. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
  • [You must be registered and logged in to see this link.]: this is one of the most powerful, and easiest to use security software. The free version equips you with protection against viruses, spyware, trojans, rootkits, worms, and rogue software. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
Firewall
Note: Please keep ALL of these programs up-to-date and run them whenever you suspect a problem to prevent malware problems.
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13713
Re: Trojan Problem
Post by dychang on Tue Apr 27, 2010 3:05 am
No more questions. I would like to thank you for your time and patience! Thank you very much.
dychang
Posts Posts : 64
Re: Trojan Problem
Post by Dr Jay on Tue Apr 27, 2010 3:07 am
You're welcome!
Posts Posts : 13713
