HP Deskjet F300 series problem !
Post by vikneshwaren on 18th April 2010, 2:48 pm
Hey, I've a serious problem with my Hp 3in1 printer. i've isntalled my softwares, drivers and the ink gadgets correctly more than 10 times. but it is showing the following errors as you can see clearly in the below pictures. both my ink gadget sare newer .but anyone solve my problem.. Thank You!
vikneshwaren
Posts Posts : 251
Joined Joined : 2008-12-23
OS OS : Microsoft Windows 7 Ultimate
Points Points : 29475
Re: HP Deskjet F300 series problem !
Post by makxp77 on 4th May 2010, 5:47 am
Sounds like the chip on the ink itself is bad or the chip in the ink insert went bad, try installing a new ink and see if that resolves the issue , if not then the 3in1 is a gonner buddy!
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29114
