Antivirus Soft -- In need of help
Re: Antivirus Soft -- In need of help
Post by Belahzur on 19th April 2010, 5:32 pm
Okay, how is the machine running now?
Points Points : 245079
Post by kaputski on 19th April 2010, 5:37 pm
It's been running pretty good since last night... On the surface it doesn't seem that there is any viruses... but that last scan on ESET found like 27 errors/infections... So as long as it got rid of them I guess we're good Smile
Although, after the scan i click on remove infections (step 4) then it took me to a page to purchase or 30 day trial.. so not sure if it did remove them or not
kaputski
Posts Posts : 18
Joined Joined : 2010-04-17
OS OS : Vista
Points Points : 24518
Post by Belahzur on 19th April 2010, 6:12 pm
Post by kaputski on 19th April 2010, 11:17 pm
restore point created
kaputski
Posts Posts : 18
OS OS : Vista
Post by Belahzur on 20th April 2010, 11:58 am
Okay,
