System(Vista) infected with Alpha Antivirus - Please help
Post by letseewatsup on Sat Apr 17, 2010 5:26 am
Hi I am running vista and now my system is infected with some kind of antivirus malware.
I cannot start any application. i keep getting pop up to buy the software (activate the antivirus software)
FYI, I cannot go to task manager, cannot run IE, firefox or any other application.
I am using this other system to seek help. PLEASE HELP!!!!
waiting for your response, please rescue me!!!1
FYI, when i click yes to the popups it takes me to -removed-
thanks
Nick
letseewatsup
OS : Window Vista
Re: System(Vista) infected with Alpha Antivirus - Please help
Post by Belahzur on Sat Apr 17, 2010 12:35 pm
Post by letseewatsup on Sat Apr 17, 2010 4:39 pm
thanks I was able to get rid of the virus...i restarted the system and got to taskmanager at the restart and killed the process that was causing this. THen used malwarebytes software to run the scan get rid of the virus.
But now the issue is that my internet does not work in Chrome and IE. THough i can still use Firefox. Just wondering what could have happened.
May be i need to reinstall these browsers?
Thanks,
Nick
letseewatsup
OS : Window Vista
Post by Belahzur on Sat Apr 17, 2010 7:16 pm
Hard to tell, use Firefox if you can.
Post by letseewatsup on Sun Apr 18, 2010 4:25 am
Thanks though!
letseewatsup
OS : Window Vista
Post by Belahzur on Sun Apr 18, 2010 4:45 pm
Can you get the OTL log posted please?
