System freeze when drag and drop
Post by Voods on 15th April 2010, 3:38 pm
Hi..
I have been advised to post my problem here after assistance in the Malware/Virus section
I am still having problems with my system freezing when trying to drag and drop files on the desktop/in windows explorer.
Also when, I try to delete a file this sometimes happens.
I can rescue the system my terminating explorer, and re-loading it through the task manager, but not everything re-loads including some shell items.
My system has seemed to be degrading in performance over the last week, so something is wrong I feel.
Any assistance would be appreciated
Regards
Voods
Posts Posts : 229
Joined Joined : 2008-12-07
Protection Protection : Eset Smart Security 4
Points Points : 31474
Re: System freeze when drag and drop
Post by makxp77 on 20th April 2010, 3:55 am
Well sounds like you have a infection of some sort or your hard drive is going bad , do you have any blue screens of death or computer freezing then shutting down?
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29084
Post by Voods on 20th April 2010, 9:48 pm
Hi...Thanks for the reply.
I dont' appear t have any infections.
I have run MBAM, and Super anti spyware...and trojan hunter daily...
I also have Eset running, and do a scan every few days...
I don't think anything was picked up in the Malware section of the forum, but it be great if somebody could check again with a hijack this log.
I haven't had any blue screens either, or shutting down, but it has frozen now and again, or not booted down, but not that many times.
Regards
Voods
Posts Posts : 229
Post by makxp77 on 20th April 2010, 10:21 pm
Usually when hard drive freezes or drags realllly slow then it means two things:
1. Hard Drive is going bad
2. Infection of Spyware or virus
MiKeY
makxp77
Posts Posts : 216
