Reading over a few recent posts on re-direct. (not to be mean)
Post by TheHebe on 14th April 2010, 12:54 pm
I too have this issue of re-directing. Goes crazy! I can't log into my website (own domain - Hebenstreit.org: look it's NOT there!) and webpage (verizon account allotment) with any ftp program. Also for my website I can get to the support page of the server, but as soon as I log in, I get the page not found error. Moreover a 'search' shows it's a chached view from 6 April for Cpanal activated on server. It seems this mal-ware logs your 'viewing pleasure' and re-directs with certain actions (passwords). I have not attempted paypal, ebay or any banking (finance) sites.
Reading over the 'helps' I see the Geek Officers requesting folks go to a site to download certain programs. (MY pain is Malbytes program. I (I suspect WE) can't access that site! This mal-ware seems to block or re-direct these helpful sites. bleepingcomputer is such a site it is as if it knows what is there! ha ha ADDED NOTE: I tried : Download OTL by OldTimer to your Desktop. as Belahzur had posted to [You must be registered and logged in to see this link.] Which is another one the mal-ware won't allow.
((It would seem the mal-ware allows 'prior to infestation visited sites, unless and up to the point you have keyed in a password.))
I did get combofix from a friend who uploaded it to their server or I'd not have gotten it.
I don't know your view on this, but it would seem to be easier if such programs (free anyway) were provided through this server (since we are logging in here with success) - perhaps in a stickie? You know your going to ask people to post the logs to a program they can't get through links, searches...
****This may interest the Geek Police also... I couldn't find my first post so I tried the Search Forums feature, results page showed, but upon clicking the desired entry I was ReDirected as it does with major search engines. ****
The lack of being able to obtain the programs required for diagnosis to gain help from Geek Police (and many see you as the last Great Hope), is beyond frustrating...
I've spend last night copying files I wish saved off my c: drive to prepare to format that drive and re-install to start from scratch!
TheHebe
Posts Posts : 4
Joined Joined : 2010-04-13
OS OS : Windows XP Home SP3
Points Points : 24336
Re: Reading over a few recent posts on re-direct. (not to be mean)
Post by Belahzur on 14th April 2010, 9:13 pm
Points Points : 245079
Post by TheHebe on 14th April 2010, 9:48 pm
Managed to get it! (surprised me)
Here it is:
exeHelper by Raktor
Build 20100414
Run at 17:45:55 on 04/14/10
Now searching...
Checking for sysguard processes...
Checking for bad processes...
Checking for bad files...
Resetting policies...
--Finished--
TheHebe
Posts Posts : 4
Post by Belahzur on 14th April 2010, 10:44 pm
  • Download combofix from here
