Need help removing Backdoor Tidserv!inf.
Post by ACADACA on 14th April 2010, 6:36 am
Hi All,
Nortons is telling me I have the above mentioned virus and it has to be removed manually. Its already posted emails out via my address book on gmail, and is causing alot of problems. Ive tried the manual removal as per the Symentek website, but having trouble with that, as it hasnt seemed to work.
Any help would be greatly appreciated. This is really getting bad.
Regards,
ACA
ACADACA
Posts Posts : 6
Joined Joined : 2010-04-14
OS OS : Windows XP Home
Points Points : 24388
Re: Need help removing Backdoor Tidserv!inf.
Post by ACADACA on 14th April 2010, 7:07 am
Ive run a full system scan, and the cirus is not deteced by Nortons. I dont receive any pop-ups either. The way I see that it is on the system os via the Norton Anti Virus history under "Unresolved Secuirty Issues"
It states that the virus is in 2 files:
c:\windows\system32\drivers\atapi.sys
c:\windows\system32\drivers\old5.tmp
Alos in 1 browser cashe file? Anyway, I tried the manula removal as per the website. i was able to expand the atapi.sys file, but could not find the old5.tmp in the Recovery command prompt program.
Ive disabled all the add-ons in firefox, and also dfownloaded an rund Hitman Pro 3.5.4. Ive also disabled System Restore, as per Syamtec website. On the most recent system scan I ran via Nortons it actually found and resolved another trojan virus (Trojan. FakeAV.gen24).
Im running another system scan with Nortons now, but the Tidserv!inf is still showing as an unresolved security risk
ACADACA
Posts Posts : 6
Post by Belahzur on 14th April 2010, 9:10 pm
Points Points : 245101
Post by ACADACA on 14th April 2010, 9:53 pm
Thank you for the reply mate. OLT.txt as per below:
OTL logfile created on: 15/04/2010 7:46:31 AM - Run 1
OTL by OldTimer - Version 3.2.1.1 Folder = C:\Documents and Settings\Compaq_Owner\Desktop
Locale: 00000C09 | Country: Australia | Language: ENA | Date Format: d/MM/yyyy
3.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 79.00% Memory free
4.00 Gb Paging File | 4.00 Gb Available in Paging File | 89.00% Paging File free
Paging file location(s): C:\pagefile.sys 1440 2880 [binary data]
Drive C: | 68.15 Gb Total Space | 15.71 Gb Free Space | 23.05% Space Free | Partition Type: NTFS
Drive D: | 6.36 Gb Total Space | 0.78 Gb Free Space | 12.22% Space Free | Partition Type: FAT32
Computer Name: YOUR-8ABC512DA0
Current User Name: Compaq_Owner
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/04/15 07:46:06 | 000,561,664 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Compaq_Owner\Desktop\OTL.exe
PRC - [2010/03/18 14:38:03 | 000,136,176 | ---- | M] (Google Inc.) -- C:\Program Files\Google\Update\1.2.183.23\GoogleCrashHandler.exe
PRC - [2010/02/19 15:24:16 | 000,908,248 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
PRC - [2009/08/22 16:32:54 | 000,117,640 | R--- | M] (Symantec Corporation) -- C:\Program Files\Norton AntiVirus\Engine\16.8.0.41\ccSvcHst.exe
PRC - [2008/12/18 08:00:30 | 000,078,104 | ---- | M] (iWin Inc.) -- C:\Program Files\iWin Games\iWinTrusted.exe
PRC - [2008/10/16 05:12:21 | 000,185,872 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
PRC - [2008/08/02 18:32:47 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2008/04/14 10:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2006/06/20 23:08:23 | 000,036,903 | ---- | M] (Hewlett-Packard) -- C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe
PRC - [2004/12/01 11:41:06 | 000,131,072 | ---- | M] (Iomega Corporation) -- C:\Program Files\Iomega HotBurn Pro\Autolaunch.exe
PRC - [2003/09/24 09:00:34 | 000,073,728 | ---- | M] (Iomega Corporation) -- C:\Program Files\Iomega\System32\AppServices.exe
PRC - [2002/07/17 02:03:00 | 000,094,208 | ---- | M] (SEIKO EPSON CORPORATION) -- C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe
PRC - [2002/01/29 13:33:14 | 000,077,824 | ---- | M] () -- C:\Program Files\Common Files\EPSON\EBAPI\eEBSvc.exe
MOD - [2010/04/15 07:46:06 | 000,561,664 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Compaq_Owner\Desktop\OTL.exe
MOD - [2006/06/20 23:08:20 | 000,024,613 | ---- | M] (BackWeb) -- C:\Documents and Settings\Compaq_Owner\Local Settings\temp\IadHide5.dll
SRV - File not found [Disabled | Stopped] -- -- (Iomega Activity Disk2)
SRV - [2009/11/28 13:40:39 | 000,030,192 | ---- | M] (Google) [On_Demand | Stopped] -- C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe -- (GoogleDesktopManager-110309-193829)
SRV - [2009/08/22 16:32:54 | 000,117,640 | R--- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Norton AntiVirus\Engine\16.8.0.41\ccSvcHst.exe -- (Norton AntiVirus)
SRV - [2008/12/18 08:00:30 | 000,078,104 | ---- | M] (iWin Inc.) [Auto | Running] -- C:\Program Files\iWin Games\iWinTrusted.exe -- (iWinTrusted)
SRV - [2003/09/24 09:00:34 | 000,073,728 | ---- | M] (Iomega Corporation) [Auto | Running] -- C:\Program Files\Iomega\System32\AppServices.exe -- (Iomega App Services)
SRV - [2002/07/17 02:03:00 | 000,094,208 | ---- | M] (SEIKO EPSON CORPORATION) [Auto | Running] -- C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe -- (EPSONStatusAgent2)
SRV - [2002/01/29 13:33:14 | 000,077,824 | ---- | M] () [Auto | Running] -- C:\Program Files\Common Files\EPSON\EBAPI\eEBSvc.exe -- (EpsonBidirectionalService)
DRV - [2010/02/03 19:00:00 | 001,324,720 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20100414.004\NAVEX15.SYS -- (NAVEX15)
DRV - [2010/02/03 19:00:00 | 000,084,912 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20100414.004\NAVENG.SYS -- (NAVENG)
DRV - [2010/01/28 16:44:11 | 000,482,432 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\ccHPx86.sys -- (ccHP)
DRV - [2009/10/29 08:37:22 | 000,329,592 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20100409.001\IDSXpx86.sys -- (IDSxpx86)
DRV - [2009/09/01 08:48:30 | 000,124,976 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SYMEVENT.SYS -- (SymEvent)
DRV - [2009/08/26 18:00:00 | 000,371,248 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys -- (eeCtrl)
DRV - [2009/08/26 18:00:00 | 000,102,448 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys -- (EraserUtilRebootDrv)
DRV - [2009/08/22 16:32:55 | 000,310,320 | ---- | M] (Symantec Corporation) [File_System | Boot | Running] -- C:\WINDOWS\system32\drivers\NAV\1008000.029\SYMEFA.SYS -- (SymEFA)
DRV - [2009/08/22 16:32:55 | 000,308,272 | ---- | M] (Symantec Corporation) [File_System | System | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\SRTSP.SYS -- (SRTSP)
DRV - [2009/08/22 16:32:55 | 000,259,632 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\BHDrvx86.sys -- (BHDrvx86)
DRV - [2009/08/22 16:32:55 | 000,217,136 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\SYMTDI.SYS -- (SYMTDI)
DRV - [2009/08/22 16:32:55 | 000,089,904 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\SYMFW.SYS -- (SYMFW)
DRV - [2009/08/22 16:32:55 | 000,043,696 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\NAV\1008000.029\SRTSPX.SYS -- (SRTSPX) Symantec Real Time Storage Protection (PEL)
DRV - [2009/08/22 16:32:55 | 000,036,400 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\SYMNDIS.SYS -- (SYMNDIS)
DRV - [2009/08/22 16:32:55 | 000,033,072 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\System32\Drivers\NAV\1008000.029\SYMIDS.SYS -- (SYMIDS)
DRV - [2009/08/22 16:32:45 | 000,036,400 | R--- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SymIM.sys -- (SymIMMP)
DRV - [2009/08/22 16:32:45 | 000,036,400 | R--- | M] (Symantec Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SymIM.sys -- (SymIM)
DRV - [2008/04/14 02:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2006/03/09 06:27:12 | 004,246,016 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2006/03/04 07:31:04 | 000,013,056 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nvnetbus.sys -- (nvnetbus)
DRV - [2006/03/04 07:31:02 | 000,034,176 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\NVENETFD.sys -- (NVENETFD)
DRV - [2006/01/26 09:24:30 | 001,149,888 | ---- | M] (Agere Systems) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\AGRSM.sys -- (AgereSoftModem)
DRV - [2006/01/25 12:15:00 | 003,535,520 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
DRV - [2005/03/10 07:53:00 | 000,036,352 | ---- | M] (Advanced Micro Devices) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\AmdK8.sys -- (AmdK8)
DRV - [2004/08/04 07:41:36 | 000,606,684 | ---- | M] (LT) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ltmdmnt.sys -- (ltmodem5)
DRV - [2004/08/04 07:31:34 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RTL8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
DRV - [2003/09/24 08:00:34 | 000,032,658 | ---- | M] (Iomega Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\iomdisk.sys -- (iomdisk)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [You must be registered and logged in to see this link.] [binary data]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
========== FireFox ==========
FF - prefs.js..browser.startup.homepage: "[You must be registered and logged in to see this link.]
FF - prefs.js..extensions.enabledItems: {e001c731-5e37-4538-a5cb-8168736a2360}:0.9.9.18
FF - prefs.js..extensions.enabledItems: {642BD07B-43AB-4157-921B-3E62B71AD39F}:1.8.3.0
FF - prefs.js..extensions.enabledItems: {c45c406e-ab73-11d8-be73-000a95be3b12}:1.1.8
FF - HKLM\software\mozilla\Firefox\extensions\\smartwebprinting@hp.com: C:\Program Files\HP\Digital Imaging\Smart Web Printing\MozillaAddOn3 [2010/01/30 23:40:46 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/02/22 22:05:14 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/02/19 15:24:26 | 000,000,000 | ---D | M]
[2008/08/27 10:12:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Extensions
[2010/04/14 21:24:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions
[2009/05/22 13:59:34 | 000,000,000 | ---D | M] (SkillGround Game Manager) -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\{642BD07B-43AB-4157-921B-3E62B71AD39F}
[2010/03/17 19:30:14 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\{9d1f059c-cada-4111-9696-41a62d64e3ba}
[2007/10/20 06:23:47 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\{a883dc70-3e3e-11db-a98b-0800200c9a66}
[2010/03/17 18:02:38 | 000,000,000 | ---D | M] (Web Developer) -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\{c45c406e-ab73-11d8-be73-000a95be3b12}
[2010/04/14 21:24:46 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\{e001c731-5e37-4538-a5cb-8168736a2360}
[2010/03/17 19:38:29 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\firebug@software.joehewitt.com
[2009/12/13 16:55:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\fxx4dtre.default\extensions\firefox@tvunetworks.com
[2010/04/14 21:24:50 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
O1 HOSTS File: ([2010/04/14 19:24:24 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
O2 - BHO: (HP Print Enhancer) - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\smart web printing\hpswp_printenhancer.dll (Hewlett-Packard Co.)
O2 - BHO: (Yahoo! IE Services Button) - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll (Yahoo! Inc.)
O2 - BHO: (Symantec Intrusion Prevention) - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton AntiVirus\Engine\16.8.0.41\IPSBHO.dll (Symantec Corporation)
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\Program Files\Google\GoogleToolbar4.dll (Google Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll (Google Inc.)
O2 - BHO: (MSN Toolbar Helper) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll (Microsoft Corp.)
O2 - BHO: (HP Smart BHO Class) - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\smart web printing\hpswp_BHO.dll (Hewlett-Packard Co.)
O3 - HKLM\..\Toolbar: (MSN Toolbar) - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll (Microsoft Corp.)
O3 - HKLM\..\Toolbar: (&Google) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\Program Files\Google\GoogleToolbar4.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (Yahoo!7 Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\ShellBrowser: (no name) - {C4069E3A-68F1-403E-B40E-20066696354B} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (&Google) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - c:\Program Files\Google\GoogleToolbar4.dll (Google Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Yahoo!7 Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
O4 - HKLM..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe (Apple Inc.)
O4 - HKLM..\Run: [Drag'n'Drop_Autolaunch] C:\Program Files\Iomega HotBurn Pro\Autolaunch.exe (Iomega Corporation)
O4 - HKLM..\Run: [Google Desktop Search] C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (Google)
O4 - HKLM..\Run: [HitmanPro35] C:\Program Files\Hitman Pro 3.5\HitmanPro35.exe (SurfRight B.V.)
O4 - HKLM..\Run: [HPBootOp] C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe (Hewlett-Packard Company)
O4 - HKLM..\Run: [IMJPMIG8.1] C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [MSPY2002] C:\WINDOWS\System32\IME\PINTLGNT\ImScInst.exe ()
O4 - HKLM..\Run: [NvCplDaemon] C:\WINDOWS\System32\NvCpl.DLL (NVIDIA Corporation)
O4 - HKLM..\Run: [PHIME2002A] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [PHIME2002ASync] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE (Microsoft Corporation)
O4 - HKLM..\Run: [Recguard] C:\WINDOWS\SMINST\Recguard.exe ()
O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Compaq Connections.lnk = C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe (Hewlett-Packard)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableStatusMessages = 0
O8 - Extra context menu item: Add to Google Photos Screensa&ver - C:\WINDOWS\System32\GPhotos.scr (Google Inc.)
O9 - Extra Button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll (Yahoo! Inc.)
O9 - Extra Button: Show or hide HP Smart Web Printing - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\smart web printing\hpswp_BHO.dll (Hewlett-Packard Co.)
O9 - Extra Button: Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\pchealth\helpctr\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm ()
O9 - Extra 'Tools' menuitem : Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\pchealth\helpctr\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm ()
O12 - Plugin for: .spop - C:\Program Files\Internet Explorer\PLUGINS\NPDocBox.dll (Intertrust Technologies, Inc.)
O15 - HKCU\..Trusted Domains: localhost ([]http in Local intranet)
O15 - HKCU\..Trusted Ranges: GD ([http] in Local intranet)
O16 - DPF: {0F733F27-5BBB-4D03-8D6B-19E2143880BF} [You must be registered and logged in to see this link.] (SkillGround Game Manager)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {483EB14D-AF1C-4951-81B0-4E2B41829FF6} [You must be registered and logged in to see this link.] (QOLCheck Control)
O16 - DPF: {6A344D34-5231-452A-8A57-D064AC9B7862} [You must be registered and logged in to see this link.] (Symantec Download Manager)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_19)
O16 - DPF: {CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_19)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_19)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 61.9.194.49 61.9.195.193
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O24 - Desktop WallPaper: C:\Documents and Settings\Compaq_Owner\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Compaq_Owner\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2004/11/23 14:58:04 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O32 - AutoRun File - [2001/07/27 15:07:38 | 000,000,000 | -HS- | M] () - D:\AUTOEXEC.BAT -- [ FAT32 ]
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
[2010/04/15 07:46:05 | 000,561,664 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Compaq_Owner\Desktop\OTL.exe
[2010/04/15 07:43:44 | 000,178,000 | ---- | C] (Kaspersky Lab) -- C:\Documents and Settings\Compaq_Owner\Desktop\TDSSKiller.exe
[2010/04/14 21:24:54 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Compaq_Owner\Application Data\QuickScan
[2010/04/14 20:34:00 | 000,000,000 | ---D | C] -- C:\rei
[2010/04/14 20:33:54 | 000,000,000 | ---D | C] -- C:\Program Files\Reimage
[2010/04/14 19:11:29 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
[2010/04/14 19:11:29 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
[2010/04/14 19:11:29 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
[2010/04/14 19:11:29 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
[2010/04/14 19:11:17 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
[2010/04/14 19:09:52 | 000,000,000 | ---D | C] -- C:\Qoobox
[2010/04/14 16:21:52 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Hitman Pro
[2010/04/14 16:21:47 | 000,000,000 | ---D | C] -- C:\Program Files\Hitman Pro 3.5
[2010/04/14 16:20:34 | 005,650,240 | ---- | C] (SurfRight B.V.) -- C:\Documents and Settings\Compaq_Owner\Desktop\HitmanPro35.exe
[2010/04/14 09:38:04 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Compaq_Owner\My Documents\Downloads
[2010/04/01 06:31:13 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Sun
[2010/04/01 06:30:31 | 000,153,376 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
[2010/04/01 06:30:31 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
[2010/04/01 06:30:31 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
[2010/03/25 06:14:32 | 000,000,000 | ---D | C] -- C:\Program Files\Notepad++
[2010/03/25 06:14:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Compaq_Owner\Application Data\Notepad++
[2010/03/19 07:07:36 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Compaq_Owner\My Documents\DCIM
[2010/01/01 23:13:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Google
[2010/01/01 23:08:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Google
[2009/08/01 03:01:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2009/01/13 16:31:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\iWin
[2008/10/10 19:13:57 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\HP
[2007/09/17 11:18:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Apple
[2006/06/20 22:02:28 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[2006/06/20 22:02:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2006/06/20 22:02:26 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[2006/02/19 10:28:56 | 000,012,288 | ---- | C] (Hewlett-Packard Development Company, L.P.) -- C:\WINDOWS\Fonts\RandFont.dll
[2 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[1 C:\Documents and Settings\Compaq_Owner\My Documents\*.tmp files -> C:\Documents and Settings\Compaq_Owner\My Documents\*.tmp -> ]
[2010/04/15 07:45:54 | 000,000,436 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{C607EA96-1167-4F03-B12B-C6CB7ADE0989}.job
[2010/04/15 07:43:00 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/04/15 03:23:13 | 000,000,246 | ---- | M] () -- C:\WINDOWS\System\hpsysdrv.dat
[2010/04/15 03:22:15 | 006,029,312 | ---- | M] () -- C:\Documents and Settings\Compaq_Owner\NTUSER.DAT
[2010/04/15 03:19:47 | 000,043,531 | ---- | M] () -- C:\WINDOWS\System32\nvapps.xml
[2010/04/15 03:19:40 | 000,000,868 | ---- | M] () -- C:\WINDOWS\tasks\Google Software Updater.job
[2010/04/15 03:19:28 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/04/15 03:19:17 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/04/15 03:19:12 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/04/15 03:18:52 | 3152,596,992 | -HS- | M] () -- C:\hiberfil.sys
[2010/04/15 03:17:16 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Compaq_Owner\ntuser.ini
[2010/04/15 03:01:49 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/04/14 21:11:54 | 000,000,332 | ---- | M] () -- C:\WINDOWS\System32\Compress.res
[2010/04/14 21:11:50 | 000,000,232 | ---- | M] () -- C:\WINDOWS\reimage.ini
[2010/04/14 20:34:02 | 000,001,723 | ---- | M] () -- C:\Documents and Settings\Compaq_Owner\Desktop\Reimage Repair.lnk
[2010/04/14 19:24:44 | 000,000,227 | ---- | M] () -- C:\WINDOWS\system.ini
[2010/04/14 19:24:24 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts
[2010/04/14 19:07:58 | 003,914,858 | R--- | M] () -- C:\Documents and Settings\Compaq_Owner\Desktop\ComboFix.exe
[2010/04/14 16:49:54 | 000,015,944 | ---- | M] () -- C:\WINDOWS\System32\drivers\hitmanpro35.sys
[2010/04/14 16:44:20 | 000,000,278 | ---- | M] () -- C:\WINDOWS\System32\.crusader
[2010/04/14 16:21:51 | 000,001,671 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Hitman Pro 3.5.lnk
[2010/04/14 16:20:59 | 005,650,240 | ---- | M] (SurfRight B.V.) -- C:\Documents and Settings\Compaq_Owner\Desktop\HitmanPro35.exe
[2010/04/14 16:03:44 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/04/14 15:40:41 | 002,686,206 | -H-- | M] () -- C:\Documents and Settings\Compaq_Owner\Local Settings\Application Data\IconCache.db
[2010/04/13 17:31:02 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/04/11 16:08:08 | 000,445,694 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
[2010/04/11 16:08:08 | 000,384,926 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2010/04/11 16:08:08 | 000,054,484 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2010/04/08 23:54:41 | 000,001,923 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Earth.lnk
[2010/04/08 10:11:48 | 000,029,184 | ---- | M] () -- C:\Documents and Settings\Compaq_Owner\My Documents\Letter to young Brian.doc
[2010/03/25 06:14:35 | 000,000,728 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Notepad++.lnk
[2010/03/22 10:43:42 | 000,178,000 | ---- | M] (Kaspersky Lab) -- C:\Documents and Settings\Compaq_Owner\Desktop\TDSSKiller.exe
[2010/03/17 13:20:49 | 000,030,208 | ---- | M] () -- C:\Documents and Settings\Compaq_Owner\My Documents\Bad Site reviews.doc
[2010/04/14 20:45:29 | 000,000,332 | ---- | C] () -- C:\WINDOWS\System32\Compress.res
[2010/04/14 20:41:27 | 3152,596,992 | -HS- | C] () -- C:\hiberfil.sys
[2010/04/14 20:34:37 | 000,000,232 | ---- | C] () -- C:\WINDOWS\reimage.ini
[2010/04/14 20:34:02 | 000,001,723 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\Desktop\Reimage Repair.lnk
[2010/04/14 19:11:29 | 000,261,632 | ---- | C] () -- C:\WINDOWS\PEV.exe
[2010/04/14 19:11:29 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
[2010/04/14 19:11:29 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
[2010/04/14 19:11:29 | 000,077,312 | ---- | C] () -- C:\WINDOWS\MBR.exe
[2010/04/14 19:11:29 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
[2010/04/14 19:07:42 | 003,914,858 | R--- | C] () -- C:\Documents and Settings\Compaq_Owner\Desktop\ComboFix.exe
[2010/04/14 16:44:20 | 000,000,278 | ---- | C] () -- C:\WINDOWS\System32\.crusader
[2010/04/14 16:22:03 | 000,015,944 | ---- | C] () -- C:\WINDOWS\System32\drivers\hitmanpro35.sys
[2010/04/14 16:21:51 | 000,001,671 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Hitman Pro 3.5.lnk
[2010/04/14 15:32:39 | 000,000,868 | ---- | C] () -- C:\WINDOWS\tasks\Google Software Updater.job
[2010/04/08 23:54:41 | 000,001,923 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Google Earth.lnk
[2010/04/06 11:03:29 | 000,029,184 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\My Documents\Letter to young Brian.doc
[2010/03/25 06:14:35 | 000,000,728 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Notepad++.lnk
[2010/03/16 09:56:18 | 000,030,208 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\My Documents\Bad Site reviews.doc
[2010/02/07 21:41:10 | 001,380,403 | ---- | C] () -- C:\WINDOWS\System32\avgsdk.dll
[2009/05/07 20:26:14 | 000,000,015 | ---- | C] () -- C:\WINDOWS\smapanel.ini
[2008/12/31 16:04:42 | 000,691,560 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.dll
[2008/11/07 13:25:14 | 000,000,094 | ---- | C] () -- C:\WINDOWS\awshkwv.ini
[2008/11/07 02:37:32 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
[2008/11/07 02:34:00 | 000,000,416 | ---- | C] () -- C:\WINDOWS\System32\dtu100.dll.manifest
[2008/11/07 02:34:00 | 000,000,416 | ---- | C] () -- C:\WINDOWS\System32\dpl100.dll.manifest
[2008/11/07 02:33:02 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\DivXWMPExtType.dll
[2008/11/04 16:32:52 | 000,000,072 | R--- | C] () -- C:\WINDOWS\System32\epDPE.ini
[2008/11/04 16:31:02 | 000,122,880 | ---- | C] () -- C:\WINDOWS\System32\EEBAPI.dll
[2008/11/04 16:31:02 | 000,102,400 | ---- | C] () -- C:\WINDOWS\System32\EEBDSCVR.dll
[2008/11/04 16:31:01 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\EBAPI.dll
[2008/09/27 14:56:39 | 000,000,013 | ---- | C] () -- C:\WINDOWS\save.ini
[2008/09/27 14:49:48 | 000,000,023 | ---- | C] () -- C:\WINDOWS\word.INI
[2008/09/27 14:49:31 | 000,000,044 | ---- | C] () -- C:\WINDOWS\guess.INI
[2008/09/27 14:49:30 | 000,000,112 | ---- | C] () -- C:\WINDOWS\used.ini
[2008/09/27 14:40:25 | 000,000,072 | ---- | C] () -- C:\WINDOWS\firstdic.ini
[2008/09/27 14:34:52 | 000,000,036 | ---- | C] () -- C:\WINDOWS\HEADAT.INI
[2008/08/27 14:53:04 | 000,036,012 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\Start Menu.rar
[2008/08/19 16:07:32 | 000,765,952 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
[2008/08/19 16:07:31 | 000,180,224 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
[2008/08/02 07:39:52 | 000,000,162 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2008/07/26 16:12:29 | 006,029,312 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\NTUSER.DAT
[2008/07/26 16:12:29 | 000,001,024 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\ntuser.dat.LOG
[2008/07/26 16:12:29 | 000,000,178 | -HS- | C] () -- C:\Documents and Settings\Compaq_Owner\ntuser.ini
[2007/09/02 14:41:42 | 000,000,072 | ---- | C] () -- C:\WINDOWS\MediaManager.INI
[2007/07/21 13:52:26 | 000,000,152 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\PluginManager.log
[2007/06/27 17:09:28 | 000,000,034 | ---- | C] () -- C:\WINDOWS\Progs_.ini
[2006/12/23 07:13:37 | 000,000,029 | ---- | C] () -- C:\WINDOWS\DEBUGSM.INI
[2006/11/25 07:13:16 | 000,086,528 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2006/09/24 18:13:08 | 000,096,768 | ---- | C] () -- C:\WINDOWS\SlantAdj.dll
[2006/09/24 18:03:09 | 000,000,004 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\pid.txt
[2006/09/24 17:26:26 | 000,000,135 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\Local Settings\Application Data\fusioncache.dat
[2006/09/24 17:23:51 | 000,001,912 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\Application Data\wklnhst.dat
[2006/09/24 15:17:54 | 005,180,760 | ---- | C] () -- C:\Documents and Settings\Compaq_Owner\CONFIGW.EXE
[2006/09/24 15:08:43 | 000,262,144 | ---- | C] () -- C:\Documents and Settings\All Users\NTUSER.DAT
[2006/09/24 15:08:43 | 000,001,024 | -H-- | C] () -- C:\Documents and Settings\All Users\NTUSER.DAT.LOG
[2006/06/20 23:43:03 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2006/06/20 23:12:19 | 000,028,848 | ---- | C] () -- C:\WINDOWS\System32\drivers\USBkey.sys
[2006/06/20 23:07:49 | 000,012,993 | ---- | C] () -- C:\WINDOWS\System32\CHODDI.SYS
[2006/06/20 23:07:40 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\hpreg.dll
[2006/06/20 22:42:04 | 000,000,102 | ---- | C] () -- C:\WINDOWS\WININIT.INI
[2006/06/20 22:34:30 | 000,002,836 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\hpzinstall.log
[2006/06/20 22:33:07 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
[2006/06/20 22:29:48 | 001,662,976 | ---- | C] () -- C:\WINDOWS\System32\nvwdmcpl.dll
[2006/06/20 22:29:48 | 001,019,904 | ---- | C] () -- C:\WINDOWS\System32\nvwimg.dll
[2006/06/20 22:29:47 | 001,466,368 | ---- | C] () -- C:\WINDOWS\System32\nview.dll
[2006/06/20 22:29:47 | 000,573,440 | ---- | C] () -- C:\WINDOWS\System32\nvhwvid.dll
[2006/06/20 22:29:47 | 000,466,944 | ---- | C] () -- C:\WINDOWS\System32\nvshell.dll
[2006/06/20 22:29:47 | 000,286,720 | ---- | C] () -- C:\WINDOWS\System32\nvnt4cpl.dll
[2006/06/20 22:29:46 | 000,106,496 | ---- | C] () -- C:\WINDOWS\System32\nvapi.dll
[2006/06/20 22:11:55 | 000,000,780 | ---- | C] () -- C:\WINDOWS\orun32.ini
[2006/06/20 22:06:40 | 000,323,584 | ---- | C] () -- C:\WINDOWS\System32\pythoncom22.dll
[2006/06/20 22:06:40 | 000,094,208 | ---- | C] () -- C:\WINDOWS\System32\pywintypes22.dll
[2006/06/20 22:06:12 | 000,016,896 | ---- | C] () -- C:\WINDOWS\System32\bcbmm.dll
[2005/01/26 05:51:49 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
[2004/09/16 13:26:40 | 000,012,634 | ---- | C] () -- C:\WINDOWS\ADFUUD.SYS
[2004/06/25 05:03:30 | 000,000,578 | ---- | C] () -- C:\WINDOWS\System32\oeminfo.ini
@Alternate Data Stream - 98 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:2EF99E25
@Alternate Data Stream - 128 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:A73B0434
ACADACA
Posts Posts : 6
Extras.txt as per below:
OTL Extras logfile created on: 15/04/2010 7:46:31 AM - Run 1
File Age = 30 Days
Output = Standard
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"DisableMonitoring" = 1
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe" = C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe:*:Enabled:Compaq Connections -- (Hewlett-Packard)
"C:\Program Files\HP\Digital Imaging\bin\hposid01.exe" = C:\Program Files\HP\Digital Imaging\bin\hposid01.exe:*:Enabled:hposid01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqcopy2.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqcopy2.exe:*:Enabled:hpqcopy2.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqusgm.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqusgm.exe:*:Enabled:hpqusgm.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqusgh.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqusgh.exe:*:Enabled:hpqusgh.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\HP Software Update\hpwucli.exe" = C:\Program Files\HP\HP Software Update\hpwucli.exe:*:Enabled:hpwucli.exe -- (Hewlett-Packard)
"C:\Program Files\HP\Digital Imaging\smart web printing\SmartWebPrintExe.exe" = C:\Program Files\HP\Digital Imaging\smart web printing\SmartWebPrintExe.exe:*:Enabled:smartwebprintexe.exe -- (Hewlett-Packard Co.)
"C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" = C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE:*:Enabled:Microsoft Office Outlook -- (Microsoft Corporation)
"C:\Program Files\DNA\btdna.exe" = C:\Program Files\DNA\btdna.exe:*:Enabled:DNA -- (BitTorrent, Inc.)
"C:\Program Files\BitTorrent\bittorrent.exe" = C:\Program Files\BitTorrent\bittorrent.exe:*:Enabled:BitTorrent -- ()
"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" = C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger -- (Yahoo! Inc.)
"C:\Program Files\Yahoo!\Messenger\YServer.exe" = C:\Program Files\Yahoo!\Messenger\YServer.exe:*:Enabled:Yahoo! FT Server -- (Yahoo! Inc.)
"C:\Program Files\iWin Games\iWinGames.exe" = C:\Program Files\iWin Games\iWinGames.exe:*:Enabled:iWin Games application. -- (iWin Inc.)
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- (Lime Wire, LLC)
"C:\Program Files\SkillGround\Games\UTG\Main.exe" = C:\Program Files\SkillGround\Games\UTG\Main.exe:*:Enabled:UTG -- ()
"{0289B35E-DC07-4c7a-9710-BBD686EA4B7D}" = Status
"{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
"{075473F5-846A-448B-BCB3-104AA1760205}" = Sonic RecordNow Data
"{08C0729E-3E50-11DF-9D81-005056806466}" = Google Earth
"{0A65A3BD-54B5-4d0d-B084-7688507813F5}" = SlideShow
"{0D2E9DCB-9938-475E-B4DD-8851738852FF}" = AIO_Scan
"{0D499481-22C6-4B25-8AC2-6D3F6C885FB9}" = OpenOffice.org Installer 1.0
"{1341D838-719C-4A05-B50F-49420CA1B4BB}" = HP Boot Optimizer
"{13F3917B56CD4C25848BDC69916971BB}" = DivX Converter
"{1451DE6B-ABE1-4F62-BE9A-B363A17588A2}" = QuickTime
"{15C0AF59-4877-49B6-B8C6-A61CE54515F5}" = cp_OnlineProjectsConfig
"{1746EA69-DCB6-4408-B5A5-E75F55439CDF}" = Scan
"{179C56A4-F57F-4561-8BBF-F911D26EB435}" = WebReg
"{18D10072035C4515918F7E37EAFAACFC}" = AutoUpdate
"{21657574-BD54-48A2-9450-EB03B2C7FC29}" = Sonic MyDVD
"{23012310-3E05-46A5-88A9-C6CBCABCAC79}" = Customer Experience Enhancement
"{2376813B-2E5A-4641-B7B3-A0D5ADB55229}" = HPPhotoSmartExpress
"{24557DC0-0839-496f-82F9-C4EB72EFE4FA}" = HP Deskjet All-In-One Software 8.0
"{2614F54E-A828-49FA-93BA-45A3F756BFAA}" = 32 Bit HP CIO Components Installer
"{26A24AE4-039D-4CA4-87B4-2F83216010FF}" = Java(TM) 6 Update 19
"{2F58D60D-2BFD-4467-9B4D-64E7355C329D}" = Sonic_PrimoSDK
"{3248F0A8-6813-11D6-A77B-00B0D0150050}" = J2SE Runtime Environment 5.0 Update 5
"{3248F0A8-6813-11D6-A77B-00B0D0160070}" = Java(TM) 6 Update 7
"{33BF0960-DBA3-4187-B6CC-C969FCFA2D25}" = SkinsHP1
"{352F5013-07DC-446D-8DB6-38F339086C60}" = LightScribe 1.4.84.1
"{36D620AD-EEBA-4973-BA86-0C9AE6396620}" = OptionalContentQFolder
"{36FDBE6E-6684-462B-AE98-9A39A1B200CC}" = HP Product Assistant
"{39CB30DB-27F8-4dd4-A294-CB4AE3B584FD}" = Copy
"{3AC54383-31D1-4907-961B-B12CBB1D0AE8}" = MobileMe Control Panel
"{3FA365DF-2D68-45ED-8F83-8C8A33E65143}" = Apple Application Support
"{3FC7CBBC4C1E11DCA1A752EA55D89593}" = DivX Version Checker
"{416D80BA-6F6D-4672-B7CF-F54DA2F80B44}" = Microsoft Works
"{41E776A5-9B12-416D-9A12-B4F7B044EBED}" = CP_Package_Basic1
"{45D707E9-F3C4-11D9-A373-0050BAE317E1}" = HP DVD Play 2.1
"{53EE9E42-CECB-4C92-BF76-9CA65DAF8F1C}" = FullDPAppQFolder
"{657F8B33-CBBB-45F4-9087-274F22C89400}" = DJ_AIO_ProductContext
"{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}" = Sonic Express Labeler
"{6696D9A4-28A8-4F5A-8E9A-2E8974C8C39C}" = RandMap
"{66E6CE0C-5A1E-430C-B40A-0C90FF1804A8}" = eSupportQFolder
"{67D3F1A0-A1F2-49b7-B9EE-011277B170CD}" = HPProductAssistant
"{6C11D561-620B-47DA-A693-4C597F3CDF40}" = EPSON Smart Panel
"{6C5D7191-140A-11D6-B5A0-0050DA208A93}" = ArcSoft PhotoImpression
"{74DC0593-6BC6-4001-AD5F-D810AFB68D86}" = HP Update
"{767CC44C-9BBC-438D-BAD3-FD4595DD148B}" = VC80CRTRedist - 8.0.50727.762
"{77DCDCE3-2DED-62F3-8154-05E745472D07}" = Acrobat.com
"{7B63B2922B174135AFC0E1377DD81EC2}" = DivX Codec
"{7DDEABFB-0621-4321-B385-CB86D3A6F90F}" = F4100
"{8105684D-8CA6-440D-8F58-7E5FD67A499D}" = Easy Internet Sign-up
"{82081779-4175-4666-A457-AB711CD37EF0}" = cp_LightScribeConfig
"{829DAAD6-BB11-4BB7-921B-07FFB703F944}" = CP_Package_Variety3
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110074983}" = BeTrapped!
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110111700}" = Zuma Deluxe
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110113233}" = Bookworm Deluxe
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11015843}" = Ricochet Lost Worlds
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110160733}" = Slingo
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110166840}" = Ballistik
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110176513}" = Feeding Frenzy
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110194827}" = Jewel Quest
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110245793}" = Insaniquarium Deluxe
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110265407}" = Bejeweled 2 Deluxe
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11029123}" = Bricks of Egypt
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110313550}" = Jigsaw 365
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110325350}" = Mah Jong Medley
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110353813}" = Magic Ball 2
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110371640}" = Poker Superstars
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110375480}" = Luxor
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11037623}" = Tradewinds 2
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110379827}" = Wonderland - Secret Worlds
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110411970}" = Chuzzle
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11042853}" = Tumblebugs
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-110491263}" = Aloha Solitaire
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11052313}" = Magic Match
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11109097}" = Luxor - Amun Rising
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111097223}" = Saints & Sinners Bowling
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111118433}" = Mystery Case Files - Huntsville
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111152487}" = Pastime Puzzles
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111155550}" = Tradewinds Legends
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111168850}" = Brave Dwarves Back
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-111170320}" = 7 Wonders of the Ancient World
"{82C36957-D2B8-4EF2-B88C-5FA03AA848C7-11117633}" = Professor Fizzwizzle
"{82E55892-6FFD-403F-AA97-D726846768AA}" = CP_AtenaShokunin1Config
"{866A0078-DEA7-4348-9C9A-999AF2991EAA}" = SlideShowMusic
"{8A534F71-3202-4464-A422-B767295E67B9}" = CP_Package_Variety2
"{8AB8D458-939E-403F-0097-9BA1C1F013D5}" = The Sims 2
"{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
"{8CE4E6E9-9D55-43FB-9DDB-688C976BFC05}" = Unload
"{8FD3F4BA-A4A6-4380-00A6-CC6853AB2DC2}" = The Sims 2 University
"{8FF6F5CA-4E30-4E3B-B951-204CAAA2716A}" = SmartWebPrinting
"{90120000-0016-0000-0000-0000000FF1CE}" = Microsoft Office Excel 2007
"{90120000-0016-0000-0000-0000000FF1CE}_EXCEL_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0000-0000-0000000FF1CE}_EXCEL_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0016-0409-0000-0000000FF1CE}_EXCEL_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0000-0000-0000000FF1CE}" = Microsoft Office PowerPoint 2007
"{90120000-0018-0000-0000-0000000FF1CE}_POWERPOINT_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0000-0000-0000000FF1CE}_POWERPOINT_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0018-0409-0000-0000000FF1CE}_POWERPOINT_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0000-0000-0000000FF1CE}" = Microsoft Office Outlook 2007
"{90120000-001A-0000-0000-0000000FF1CE}_OUTLOOK_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0000-0000-0000000FF1CE}_OUTLOOK_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-001A-0409-0000-0000000FF1CE}_OUTLOOK_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0000-0000-0000000FF1CE}" = Microsoft Office Word 2007
"{90120000-001B-0000-0000-0000000FF1CE}_WORD_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0000-0000-0000000FF1CE}_WORD_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-001B-0409-0000-0000000FF1CE}_WORD_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_EXCEL_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_OUTLOOK_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_POWERPOINT_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_VISSTD_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_WORD_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_EXCEL_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_OUTLOOK_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_POWERPOINT_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_VISSTD_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_WORD_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_EXCEL_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_OUTLOOK_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_POWERPOINT_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_VISSTD_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_WORD_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0053-0000-0000-0000000FF1CE}" = Microsoft Office Visio Standard 2007
"{90120000-0053-0000-0000-0000000FF1CE}_VISSTD_{0FD405D3-CAF8-4CA6-8BFD-911D2F8A6585}" = Microsoft Office Visio 2007 Service Pack 2 (SP2)
"{90120000-0053-0000-0000-0000000FF1CE}_VISSTD_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0054-0409-0000-0000000FF1CE}" = Microsoft Office Visio MUI (English) 2007
"{90120000-0054-0409-0000-0000000FF1CE}_VISSTD_{519D9F45-CBF4-4E57-B419-11F196CCA8AE}" = Microsoft Office Visio 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_EXCEL_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_OUTLOOK_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_POWERPOINT_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_VISSTD_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_WORD_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_EXCEL_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_OUTLOOK_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_POWERPOINT_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_VISSTD_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_WORD_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{9391F2BC-B6F3-4AAC-82CC-5A74A4ED388E}" = EPSON Photo Print
"{93E5A317-24EC-4744-812C-16FECFE86E6A}" = CP_Package_Variety1
"{95D08F4E-DFC2-4ce3-ACB7-8C8E206217E9}" = MarketResearch
"{9A3EABC0-CA06-11D4-BF77-00104B130C19}" = EPSON TWAIN 5
"{9C2D4047-0E40-499a-AC7A-C4B9BB12FE03}" = TrayApp
"{9ECB4705-B9CB-405A-B6D4-33BDF707308E}" = DJ_AIO_Software
"{A29800BA-0BF1-4E63-9F31-DF05A87F4104}" = InstantShareDevices
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A36CD345-625C-4d6c-B3E2-76E1248CB451}" = SolutionCenter
"{A96E97134CA649888820BCDE5E300BBD}" = H.264 Decoder
"{AAC389499AEF40428987B3D30CFC76C9}" = MKV Splitter
"{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}" = Apple Mobile Device Support
"{AB708C9B-97C8-4AC9-899B-DBF226AC9382}" = Sonic RecordNow Audio
"{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3.1
"{ACE22C48-49D7-4531-BE20-5C3D03393AB6}" = F4100_Help
"{AEF9DC35ADDF4825B049ACBFD1C6EB37}" = AAC Decoder
"{B12665F4-4E93-4AB4-B7FC-37053B524629}" = Sonic RecordNow Copy
"{B13A7C41581B411290FBC0395694E2A9}" = DivX Converter
"{B148AB4B-C8FA-474B-B981-F2943C5B5BCD}" = OGA Notifier 1.7.0105.35.0
"{B2157760-AA3C-4E2E-BFE6-D20BC52495D9}" = cp_PosterPrintConfig
"{B2EFE303-A594-11D5-95EB-005004BC1C65}" = EPSON PhotoQuicker3.2
"{B6286A44-7505-471A-A72B-04EC2DB2F442}" = CueTour
"{B69CC1A5-0404-11D6-ABCB-005004C21D30}" = EPSON Copy Utility
"{B69CFE29-FD03-4E0A-87A7-6ED97F98E5B3}" = CP_Panorama1Config
"{B7050CBDB2504B34BC2A9CA0A692CC29}" = DivX Web Player
"{BE77A81F-B315-4666-9BF3-AE70C0ADB057}" = BufferChm
"{C1C6767D-B395-43CB-BF99-051B58B86DA6}" = PhotoGallery
"{C3FAA091-B278-44A7-BF48-190811C5F9F7}" = cp_UpdateProjectsConfig
"{C53CCE8A-8DEE-4E2C-8A4D-425F0FF70471}" = Iomega DVD Wizard
"{C716522C-3731-4667-8579-40B098294500}" = Toolbox
"{C7888C3F-0506-555F-7907-CDD3F81719A5}" = Adobe Media Player
"{CCB1507A-AAEA-4778-AC4B-DD5EAB1A961E}" = Iomega HotBurn Pro
"{D0E39A1D-0CEE-4D85-B4A2-E3BE990D075E}" = Destination Component
"{D6E4E5D6-7693-4BB4-95BA-21F38FAFEE90}" = Safari
"{DA5784C0-06BB-4884-A7C4-89CC206EA2B6}" = ninemsn Toolbar
"{DB518BA6-CB74-4EB6-9ABD-880B6D6E1F38}" = HpSdpAppCoreApp
"{DC83F417-8068-4074-BA2F-C4F8AB872556}" = DJ_AIO_Software_min
"{E06F04B9-45E6-4AC0-8083-85F7515F40F7}" = UnloadSupport
"{EB21A812-671B-4D08-B974-2A347F0D8F70}" = HP Photosmart Essential
"{EB75DE50-5754-4F6F-875D-126EDF8E4CB3}" = HPSSupply
"{EBAE381B-60A6-4863-AA9F-FCAB755BC9E5}" = ScanToWeb
"{ED2C557E-9C18-41FF-B58E-A05EEF0B3B5F}" = CP_CalendarTemplates1
"{EF1ADA5A-0B1A-4662-8C55-7475A61D8B65}" = DeviceDiscovery
"{F439D7AF-03F3-4F8E-AEC4-571BFE977C61}" = iTunes
"Adobe Acrobat 5.0" = Adobe Acrobat 4.0, 5.0
"Adobe AIR" = Adobe AIR
"Adobe Flash Player ActiveX" = Adobe Flash Player ActiveX
"Agere Systems Soft Modem" = Agere Systems PCI-SV92PP Soft Modem
"DivX Plus DirectShow Filters" = DivX Plus DirectShow Filters
"EPSON Printer and Utilities" = EPSON Printer Software
"EXCEL" = Microsoft Office Excel 2007
"Google Desktop" = Google Desktop
"Google Updater" = Google Updater
"HitmanPro35" = Hitman Pro 3.5
"HP Imaging Device Functions" = HP Imaging Device Functions 8.0
"HP Photo & Imaging" = HP Photosmart Premier Software 6.5
"HP Smart Web Printing" = HP Smart Web Printing 4.60
"HP Solution Center & Imaging Support Tools" = HP Solution Center 8.0
"HPExtendedCapabilities" = HP Customer Participation Program 8.0
"HPOOVClient-5577497 Uninstaller" = Compaq Connections (remove only)
"InstallShield_{23012310-3E05-46A5-88A9-C6CBCABCAC79}" = Customer Experience Enhancement
"InstallShield_{8105684D-8CA6-440D-8F58-7E5FD67A499D}" = Easy Internet Sign-up
"iWin Toolbar" = iWin Toolbar
"iWinArcade" = iWin Games (remove only)
"LimeWire" = LimeWire 4.18.8
"Loan And Mortgage 2_is1" = Loan And Mortgage 2.3.1
"Luxor 3" = Luxor 3 (remove only)
"Money2005b" = Microsoft Money
"Mozilla Firefox (3.5.8)" = Mozilla Firefox (3.5.8)
"NAV" = Norton AntiVirus
"Notepad++" = Notepad++
"NVIDIA Drivers" = NVIDIA Drivers
"OUTLOOK" = Microsoft Office Outlook 2007
"Pattern Piano and Keyboard Demo3.1" = Pattern Piano and Keyboard Demo
"PC-Doctor 5 for Windows" = PC-Doctor 5 for Windows
"Picasa 3" = Picasa 3
"POWERPOINT" = Microsoft Office PowerPoint 2007
"RealPlayer 6.0" = RealPlayer
"Reimage Repair" = Reimage Repair
"SkillGround" = SkillGround Game Manager
"SopCast" = SopCast 3.0.3
"VISSTD" = Microsoft Office Visio Standard 2007
"WORD" = Microsoft Office Word 2007
"Xvid_is1" = Xvid 1.1.3 final uninstall
"Yahoo! Companion" = Yahoo!7 Toolbar
"Yahoo! Extras" = Yahoo! Browser Services
"Yahoo! Mail" = Yahoo! Internet Mail
"Yahoo! Messenger" = Yahoo! Messenger
"YInstHelper" = Yahoo! Install Manager
"BitTorrent" = BitTorrent
"BitTorrent DNA" = DNA
[ Application Events ]
Error - 14/04/2010 2:28:40 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Description = Failed auto update retrieval of third-party root list sequence number
with error: This network connection does not exist.
Error - 14/04/2010 2:29:22 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Error - 14/04/2010 2:29:24 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Error - 14/04/2010 2:29:27 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Error - 14/04/2010 2:29:30 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Error - 14/04/2010 2:29:33 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
Error - 14/04/2010 2:29:34 AM | Computer Name = YOUR-8ABC512DA0 | Source = crypt32 | ID = 131080
[ OSession Events ]
Error - 20/07/2009 9:32:59 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 6, Application Name: Microsoft Office Outlook, Application Version:
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 52
seconds with 0 seconds of active time. This session ended with a crash.
Error - 20/07/2009 9:33:04 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 2
Error - 20/07/2009 9:33:07 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 10
Error - 20/07/2009 9:33:12 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
Error - 31/07/2009 10:21:14 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 1903
Error - 31/07/2009 10:42:57 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 1295
Error - 31/07/2009 11:12:33 PM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 15
Error - 1/08/2009 2:25:51 AM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 11589
Error - 1/08/2009 2:25:58 AM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 3
Error - 10/04/2010 11:48:26 AM | Computer Name = YOUR-8ABC512DA0 | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 0, Application Name: Microsoft Office Word, Application Version:
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 7471
seconds with 5340 seconds of active time. This session ended with a crash.
[ System Events ]
Error - 14/04/2010 6:37:58 AM | Computer Name = YOUR-8ABC512DA0 | Source = Service Control Manager | ID = 7001
Description = The DHCP Client service depends on the NetBios over Tcpip service
which failed to start because of the following error: %%31
Description = The DNS Client service depends on the TCP/IP Protocol Driver service
Description = The TCP/IP NetBIOS Helper service depends on the AFD service which
Description = The Apple Mobile Device service depends on the TCP/IP Protocol Driver
service which failed to start because of the following error: %%31
Description = The Bonjour Service service depends on the TCP/IP Protocol Driver
Description = The IPSEC Services service depends on the IPSEC driver service which
Error - 14/04/2010 6:37:58 AM | Computer Name = YOUR-8ABC512DA0 | Source = Service Control Manager | ID = 7026
AFD AmdK8 BHDrvx86 ccHP eeCtrl Fips IDSxpx86 IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss SRTSP SRTSPX
SYMTDI
Tcpip
Error - 14/04/2010 6:39:52 AM | Computer Name = YOUR-8ABC512DA0 | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service EventSystem
with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
Error - 14/04/2010 6:44:09 AM | Computer Name = YOUR-8ABC512DA0 | Source = Service Control Manager | ID = 7022
Description = The HP CUE DeviceDiscovery Service service hung on starting.
Error - 14/04/2010 1:21:37 PM | Computer Name = YOUR-8ABC512DA0 | Source = Service Control Manager | ID = 7022
ACADACA
Posts Posts : 6
Joined Joined : 2010-04-14
OS OS : Windows XP Home
Points Points : 24388
Re: Need help removing Backdoor Tidserv!inf.
Post by Belahzur on 14th April 2010, 10:44 pm
  • Download combofix from here
Points Points : 245101
Post by ACADACA on 14th April 2010, 11:26 pm
As per below mate:
ComboFix 10-04-14.01 - Compaq_Owner 15/04/2010 8:55.2.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.3006.2430 [GMT 10:00]
Running from: c:\documents and settings\Compaq_Owner\Desktop\Combo-Fix.exe
AV: Norton AntiVirus *On-access scanning disabled* (Updated) {E10A9785-9598-4754-B552-92431C1C35F8}
FW: Norton AntiVirus *enabled* {990F9400-4CEE-43EA-A83A-D013ADD8EA6E}
c:\docume~1\COMPAQ~1\LOCALS~1\Temp\IadHide5.dll
c:\documents and settings\Compaq_Owner\Local Settings\temp\IadHide5.dll
((((((((((((((((((((((((( Files Created from 2010-03-14 to 2010-04-14 )))))))))))))))))))))))))))))))
2010-04-14 15:48 . 2004-08-03 22:59 95360 ------w- c:\windows\system32\drivers\atapi.sys
2010-04-14 11:24 . 2010-04-14 22:51 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\QuickScan
2010-04-14 10:34 . 2010-04-14 11:11 -------- d-----w- C:\rei
2010-04-14 10:33 . 2010-04-14 10:33 -------- d-----w- c:\program files\Reimage
2010-04-14 10:09 . 2010-04-14 10:09 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\Mozilla
2010-04-14 10:08 . 2010-04-14 10:08 -------- d-sh--w- c:\documents and settings\Administrator\PrivacIE
2010-04-14 10:07 . 2010-04-14 10:07 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\Symantec
2010-04-14 06:22 . 2010-04-14 06:49 15944 ----a-w- c:\windows\system32\drivers\hitmanpro35.sys
2010-04-14 06:21 . 2010-04-14 06:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Hitman Pro
2010-04-14 06:21 . 2010-04-14 06:21 -------- d-----w- c:\program files\Hitman Pro 3.5
2010-03-24 20:14 . 2010-04-14 02:19 -------- d-----w- c:\program files\Notepad++
2010-03-24 20:14 . 2010-03-24 20:15 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\Notepad++
2010-04-14 12:34 . 2008-11-01 18:49 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2010-04-14 09:21 . 2009-01-11 02:57 -------- d-----w- c:\program files\iWin
2010-04-14 09:21 . 2009-01-11 02:56 -------- d-----w- c:\program files\iWin Games
2010-04-11 05:58 . 2008-08-09 22:22 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\DNA
2010-04-08 13:54 . 2006-06-20 13:16 -------- d-----w- c:\program files\Google
2010-03-31 22:56 . 2008-08-09 22:22 -------- d-----w- c:\program files\DNA
2010-03-31 20:31 . 2006-06-20 12:16 -------- d-----w- c:\program files\Common Files\Java
2010-03-31 20:30 . 2006-06-20 12:16 -------- d-----w- c:\program files\Java
2010-03-23 22:30 . 2010-01-31 03:21 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\HPAppData
2010-03-10 16:09 . 2006-10-24 10:13 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2010-03-08 17:28 . 2008-11-27 19:12 411368 ----a-w- c:\windows\system32\deploytk.dll
2010-02-25 06:24 . 2004-08-04 04:00 916480 ------w- c:\windows\system32\wininet.dll
2010-02-07 11:41 . 2010-02-07 11:41 352513 ----a-w- c:\windows\system32\savapi3.dll
2010-02-07 11:41 . 2010-02-07 11:41 1380403 ----a-w- c:\windows\system32\avgsdk.dll
2010-01-30 13:41 . 2010-01-30 13:40 23088 ----a-w- c:\windows\hpqins15.dat
2009-11-28 03:40 . 2009-03-23 02:52 119808 ----a-w- c:\program files\mozilla firefox\components\GoogleDesktopMozilla.dll
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-08-02 68856]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-04 208952]
"MSPY2002"="c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2004-08-04 59392]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"RTHDCPL"="RTHDCPL.EXE" [2006-03-08 16010240]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2006-01-25 7311360]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2005-07-22 237568]
"HPBootOp"="c:\program files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" [2006-02-15 249856]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2006-12-10 49152]
"Drag'n'Drop_Autolaunch"="c:\program files\Iomega HotBurn Pro\Autolaunch.exe" [2004-12-01 131072]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-10-15 185872]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-08-13 177440]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2009-11-28 30192]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-12-21 35760]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-12-11 948672]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-11-10 417792]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-01-22 141608]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-02-18 248040]
"HitmanPro35"="c:\program files\Hitman Pro 3.5\HitmanPro35.exe" [2010-04-14 5650240]
c:\documents and settings\Administrator\Start Menu\Programs\Startup\
Pin.lnk - c:\hp\bin\CLOAKER.EXE [2006-6-20 27136]
Compaq Connections.lnk - c:\program files\Compaq Connections\5577497\Program\Compaq Connections.exe [2006-6-20 36903]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2008-3-25 214360]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SymEFA.sys]
@="FSFilter Activity Monitor"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
2008-04-14 00:12 1695232 ----a-w- c:\program files\Messenger\msmsgs.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\nwiz]
2006-01-25 02:15 1519616 ----a-w- c:\windows\system32\nwiz.exe
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Compaq Connections\\5577497\\Program\\Compaq Connections.exe"=
"c:\\Program Files\\DNA\\btdna.exe"=
"c:\\Program Files\\BitTorrent\\bittorrent.exe"=
"c:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"=
"c:\\Program Files\\iWin Games\\iWinGames.exe"=
"c:\\Program Files\\SkillGround\\Games\\UTG\\Main.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqcopy2.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqnrs08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqusgm.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqusgh.exe"=
"c:\\Program Files\\HP\\HP Software Update\\hpwucli.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\smart web printing\\SmartWebPrintExe.exe"=
"c:\\WINDOWS\\system32\\spoolsv.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\IcmpSettings]
"AllowInboundEchoRequest"= 1 (0x1)
R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\NAV\1008000.029\SymEFA.sys [28/01/2010 4:44 PM 310320]
R1 BHDrvx86;Symantec Heuristics Driver;c:\windows\system32\drivers\NAV\1008000.029\BHDrvx86.sys [28/01/2010 4:44 PM 259632]
R1 ccHP;Symantec Hash Provider;c:\windows\system32\drivers\NAV\1008000.029\cchpx86.sys [28/01/2010 4:44 PM 482432]
R1 IDSxpx86;IDSxpx86;c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20100409.001\IDSXpx86.sys [13/04/2010 6:00 AM 329592]
R2 iWinTrusted;iWinTrusted;c:\program files\iWin Games\iWinTrusted.exe [18/12/2008 8:00 AM 78104]
R2 Norton AntiVirus;Norton AntiVirus;c:\program files\Norton AntiVirus\Engine\16.8.0.41\ccSvcHst.exe [28/01/2010 4:44 PM 117640]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [3/09/2009 4:00 PM 102448]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [1/01/2010 11:08 PM 135664]
S3 GoogleDesktopManager-110309-193829;Google Desktop Manager 5.9.911.3589;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [23/03/2009 12:51 PM 30192]
*Deregistered* - dnbudf
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
2010-04-13 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-04-11 01:34]
2010-04-14 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-07-26 17:23]
2010-04-14 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-01-01 13:08]
2010-04-14 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-04-14 c:\windows\Tasks\User_Feed_Synchronization-{C607EA96-1167-4F03-B12B-C6CB7ADE0989}.job
- c:\windows\system32\msfeedssync.exe [2009-03-07 18:31]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office12\EXCEL.EXE/3000
Rootkit scan 2010-04-15 09:11
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Norton AntiVirus]
"ImagePath"="\"c:\program files\Norton AntiVirus\Engine\16.8.0.41\ccSvcHst.exe\" /s \"Norton AntiVirus\" /m \"c:\program files\Norton AntiVirus\Engine\16.8.0.41\diMaster.dll\" /prefetch:1"
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Iomega Activity Disk2]
"ImagePath"="\"\""
- - - - - - - > 'explorer.exe'(2912)
c:\progra~1\WINDOW~1\wmpband.dll
c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\MSVCR80.dll
c:\program files\Google\Update\1.2.183.23\GoogleCrashHandler.exe
c:\program files\Common Files\EPSON\EBAPI\eEBSVC.exe
c:\program files\Common Files\EPSON\EBAPI\SAgent2.exe
c:\progra~1\Iomega\System32\AppServices.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\windows\RTHDCPL.EXE
c:\program files\HP\Digital Imaging\bin\hpqSTE08.exe
c:\program files\HP\Digital Imaging\bin\hpqbam08.exe
Completion time: 2010-04-15 09:23:23 - machine was rebooted
ComboFix-quarantined-files.txt 2010-04-14 23:22
Pre-Run: 16,851,562,496 bytes free
Post-Run: 16,837,758,976 bytes free
- - End Of File - - EE305CB1A15788716C9AC58A086496B8
ACADACA
Posts Posts : 6
Post by Belahzur on 15th April 2010, 7:59 pm
I see that you are running Limewire.
    BitTorrent
    DNA
    Java(TM) 6 Update 7
    LimeWire 4.18.8
ComboFix /uninstall
Post by ACADACA on 16th April 2010, 9:41 pm
Mate the computer is running well. Better than it has for a while actually! My apologies for the delay in replying.
The virus is still showing up in Nortons as a nUNRESOLVED SECURITY THREAT though, when I open the HISTORY link? Im going to remove those programs now then Ill run the uninstall for combofix.
ACADACA
Posts Posts : 6
