I need help removing antivirus suite
Post by sk8dpr on Wed Apr 14, 2010 12:21 am
I have already read the guide on how to remove this virus, but yet it did not work. I just need some additional help on removing it because its interfering with some very important projects i have to do. Malwarebytes' Anti-Malware was able to identify the infection but when i clicked remove and restarted my system it was still there. Any additional help would be greatly appreciated, thank you.
Scan saved at 5:13:16 PM, on 4/13/2010
C:\Program Files\NOS\bin\getPlusPlus_Adobe.exe
C:\WINDOWS\system32\DllHost.exe
C:\Documents and Settings\Administrator\My Documents\Downloads\winlogon(3).scr
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [readericon] C:\Program Files\Digital Media Reader\readericon45G.exe
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [DivXUpdate] "C:\Program Files\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
O4 - HKLM\..\Run: [egcpoqhf] C:\Documents and Settings\Administrator\Local Settings\Application Data\jltyadgww\fjvxgnitssd.exe
O4 - HKCU\..\Run: [Power2GoExpress] NA
O4 - HKCU\..\Run: [egcpoqhf] C:\Documents and Settings\Administrator\Local Settings\Application Data\jltyadgww\fjvxgnitssd.exe
O4 - Global Startup: McAfee Security Scan Plus.lnk = ?
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} (get_atlcom Class) - [You must be registered and logged in to see this link.]
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe
O23 - Service: PrismXL - New Boundary Technologies, Inc. - C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
End of file - 4180 bytes
sk8dpr
Joined Joined : 2010-04-14
Points Points : 24263
Re: I need help removing antivirus suite
Post by Belahzur on Wed Apr 14, 2010 9:24 pm
    In Internet Explorer
    In Firefox
Points Points : 245049
